root/radiance/ray/src/util/rtpict.pl
Revision: 2.28
Committed: Fri Nov 17 23:30:07 2023 UTC (6 months, 1 week ago) by greg
Changes since 2.27: +11 -5 lines
fix(rtpict): More reliable support for -pc and -pXYZ options
1 #!/usr/bin/perl -w
2 # RCSid $Id: rtpict.pl,v 2.27 2023/11/15 18:02:53 greg Exp $
3 #
4 # Run rtrace in parallel mode to simulate rpict -n option
5 # May also be used to render layered images with -o* option
6 #
7 # G. Ward
8 #
9 use strict;
10 # we'll run rpict if no -n or -o* option
11 my $nprocs = 1;
12 # rtrace options and the associated number of arguments
13 my %rtraceC = ('-dt',1, '-dc',1, '-dj',1, '-ds',1, '-dr',1, '-dp',1,
14 '-ss',1, '-st',1, '-e',1, '-am',1, '-P',1, '-PP',1,
15 '-ab',1, '-af',1, '-ai',1, '-aI',1, '-ae',1, '-aE',1,
16 '-av',3, '-aw',1, '-aa',1, '-ar',1, '-ad',1, '-as',1,
17 '-me',3, '-ma',3, '-mg',1, '-ms',1, '-lr',1, '-lw',1,
18 '-ap',2, '-am',1, '-ac',1, '-aC',1,
19 '-cs',1, '-cw',2, '-pc',8, '-pXYZ',0);
20 # boolean rtrace options
21 my @boolO = ('-w', '-bv', '-dv', '-i', '-u');
22 # view options and the associated number of arguments
23 my %vwraysC = ('-vf',1, '-vtv',0, '-vtl',0, '-vth',0, '-vta',0, '-vts',0, '-vtc',0,
24 '-x',1, '-y',1, '-vp',3, '-vd',3, '-vu',3, '-vh',1, '-vv',1,
25 '-vo',1, '-va',1, '-vs',1, '-vl',1, '-pa',1, '-pj',1, '-pd',1);
26 # options we need to silently ignore
27 my %ignoreC = ('-t',1, '-ps',1, '-pt',1, '-pm',1,);
28 # Starting options for rtrace (rpict values)
29 my @rtraceA = split(' ', 'rtrace -u- -dt .05 -dc .5 -ds .25 -dr 1 ' .
30 '-aa .2 -ar 64 -ad 512 -as 128 -lr 7 -lw 1e-04');
31 my @vwraysA = ('vwrays', '-pj', '.67');
32 my @vwrightA = ('vwright', '-vtv');
33 my @rpictA = ('rpict', '-ps', '1');
34 my @pvalueA = ('pvalue', '-r');
35 my $outpatt = '^-o[vrxlLRXnNsmM]+';
36 my $refDepth = "";
37 my $irrad = 0;
38 my $persist = 0;
39 my $ambounce = 0;
40 my $ambcache = 1;
41 my $ambfile;
42 my $outlyr;
43 my $outdir;
44 my $outpic;
45 my $outzbf;
46 OPTION: # sort through options
47 while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) {
48 # Check for file inclusion
49 if ("$ARGV[0]" =~ /^\@/) {
50 open my $handle, '<', substr($ARGV[0], 1) or die "No file for $ARGV[0]\n";
51 shift @ARGV;
52 chomp(my @args = <$handle>);
53 close $handle;
54 unshift @ARGV, split(/\s+/, "@args");
55 next OPTION;
56 }
57 # Check booleans
58 for my $boopt (@boolO) {
59 if ("$ARGV[0]" =~ ('^' . $boopt . '[-+01tfynTFYN]?$')) {
60 if ("$ARGV[0]" eq '-i') {
61 $irrad = ! $irrad;
62 } elsif ("$ARGV[0]" =~ /^-i[-+01tfynTFYN]/) {
63 $irrad = ("$ARGV[0]" =~ /^-i[+1tyTY]/);
64 }
65 push @rtraceA, $ARGV[0];
66 push @rpictA, shift(@ARGV);
67 next OPTION;
68 }
69 }
70 # Check view options
71 if (defined $vwraysC{$ARGV[0]}) {
72 push @vwraysA, $ARGV[0];
73 my $isvopt = ("$ARGV[0]" =~ /^-v/);
74 push(@vwrightA, $ARGV[0]) if ($isvopt);
75 push @rpictA, shift(@ARGV);
76 for (my $i = $vwraysC{$rpictA[-1]}; $i-- > 0; ) {
77 push @vwraysA, $ARGV[0];
78 push(@vwrightA, $ARGV[0]) if ($isvopt);
79 push @rpictA, shift(@ARGV);
80 }
81 next OPTION;
82 }
83 # Check rtrace options
84 if (defined $rtraceC{$ARGV[0]}) {
85 if ("$ARGV[0]" =~ /^-PP?$/) {
86 $persist = 1;
87 } elsif ("$ARGV[0]" eq '-ab') {
88 $ambounce = $ARGV[1];
89 } elsif ("$ARGV[0]" eq '-aa') {
90 $ambcache = ($ARGV[1] > 0.0);
91 } elsif ("$ARGV[0]" eq '-af') {
92 $ambfile = "$ARGV[1]";
93 } elsif ("$ARGV[0]" eq '-pXYZ') {
94 push @pvalueA, $ARGV[0];
95 } elsif ("$ARGV[0]" eq '-pc') {
96 push @pvalueA, '-p';
97 push @pvalueA, @ARGV[1..8];
98 }
99 push @rtraceA, $ARGV[0];
100 push @rpictA, shift(@ARGV);
101 for (my $i = $rtraceC{$rpictA[-1]}; $i-- > 0; ) {
102 push @rtraceA, $ARGV[0];
103 push @rpictA, shift(@ARGV);
104 }
105 next OPTION;
106 }
107 # Check options to ignore
108 if (defined $ignoreC{$ARGV[0]}) {
109 push @rpictA, shift(@ARGV);
110 for (my $i = $ignoreC{$rpictA[-1]}; $i-- > 0; ) {
111 push @rpictA, shift(@ARGV);
112 }
113 next OPTION;
114 }
115 # Check for output file or number of processes
116 if ("$ARGV[0]" eq '-o') {
117 shift @ARGV;
118 $outpic = shift(@ARGV);
119 } elsif ("$ARGV[0]" eq '-z') {
120 push @rpictA, shift(@ARGV);
121 $outzbf = $ARGV[0];
122 push @rpictA, shift(@ARGV);
123 } elsif ("$ARGV[0]" eq '-n') {
124 shift @ARGV;
125 $nprocs = shift(@ARGV);
126 } elsif ("$ARGV[0]" eq '-d') {
127 shift @ARGV;
128 $refDepth = ' -d ' . shift(@ARGV);
129 } elsif ("$ARGV[0]" =~ "$outpatt") {
130 push @rtraceA, $ARGV[0];
131 $outlyr = substr(shift(@ARGV), 2);
132 $outdir = shift(@ARGV);
133 } else {
134 die "Unsupported option: " . $ARGV[0] . "\n";
135 }
136 }
137 die "Number of processes must be positive" if ($nprocs <= 0);
138 if (defined $outdir) { # check conflicting options
139 die "Options -o and -o* are mutually exclusive\n" if (defined $outpic);
140 die "Options -z and -o* are mutually exclusive\n" if (defined $outzbf);
141 }
142 if (defined $outpic) { # redirect output?
143 die "File '$outpic' already exists\n" if (-e $outpic);
144 open STDOUT, '>', "$outpic";
145 }
146 #####################################################################
147 ##### May as well run rpict?
148 if ($nprocs == 1 && $persist == 0 && !defined($outdir)) {
149 push(@rpictA, $ARGV[0]) if ($#ARGV == 0);
150 exec @rpictA ;
151 }
152 # OK, we're running rtrace in some capacity...
153 push @rtraceA, ('-n', "$nprocs");
154 die "Need single octree argument\n" if ($#ARGV != 0);
155 my $oct = $ARGV[0];
156 my $view = `@vwrightA 0`;
157 chomp $view;
158 my @res = split(/\s/, `@vwraysA -d`);
159 #####################################################################
160 ##### Resort pixels to reduce ambient cache collisions?
161 if ($nprocs > 1 && $ambounce > 0 && $ambcache && defined($ambfile)) {
162 if (!defined($outzbf) && !defined($outdir)) {
163 # Straight picture output, so just shuffle sample order
164 system "cnt -s $res[1] $res[3] > /tmp/ord$$.txt";
165 die "cnt error\n" if ( $? );
166 system "@vwraysA -ff -i < /tmp/ord$$.txt " .
167 "| @rtraceA -ffa -ov '$oct' > /tmp/pix$$.txt";
168 die "Error running rtrace\n" if ( $? );
169 system "( getinfo < /tmp/pix$$.txt | getinfo -a 'VIEW=$view'; " .
170 "getinfo - < /tmp/pix$$.txt | rlam /tmp/ord$$.txt - " .
171 "| sort -k2rn -k1n ) | @pvalueA -Y $res[3] +X $res[1]";
172 die "rlam error\n" if ( $? );
173 unlink ("/tmp/ord$$.txt", "/tmp/pix$$.txt");
174 exit 0;
175 }
176 # Else randomize overture calculation to prime ambient cache
177 my @ores = (int($res[1]/6), int($res[3]/6));
178 print STDERR "Running $ores[0] by $ores[1] overture calculation " .
179 "to populate '$ambfile'...\n";
180 system "cnt -s @ores | @vwraysA -i -ff -x $ores[0] -y $ores[1] -pj 0 " .
181 "| @rtraceA -ff -ov '$oct' > /dev/null";
182 die "Failure running overture\n" if ( $? );
183 print STDERR "Finished overture.\n";
184 }
185 #####################################################################
186 ##### Generating picture with depth buffer?
187 if (defined $outzbf) {
188 exec "@vwraysA -ff | @rtraceA -fff -olv @res '$oct' | " .
189 "rsplit -ih -iH -f -of '$outzbf' -oh -oH -of3 - | " .
190 "@pvalueA -df | getinfo -a 'VIEW=$view'";
191 }
192 #####################################################################
193 ##### Base case with output picture only?
194 if (! defined $outdir) {
195 exec "@vwraysA -ff | @rtraceA -ffc @res '$oct' | getinfo -a 'VIEW=$view'";
196 }
197 #####################################################################
198 ##### Layered image output case
199 my @rsplitA = ("rsplit", "'-t '", "-ih", "-iH", "-oh", "-oH");
200 # Supported rtrace -o* options and output file name.typ
201 my %rtoutC = (
202 v => 'radiance.hdr',
203 r => 'r_refl.hdr',
204 x => 'r_unrefl.hdr',
205 l => 'd_effective.dpt',
206 L => 'd_firstsurf.dpt',
207 R => 'd_refl.dpt',
208 X => 'd_unrefl.dpt',
209 n => 'perturbed.nrm',
210 N => 'unperturbed.nrm',
211 s => 'surface.idx',
212 m => 'modifier.idx',
213 M => 'material.idx'
214 );
215 # Arguments for rsplit based on output file type
216 my %rcodeC = (
217 '.hdr', ['-of3', "!@pvalueA -df -u"],
218 '.dpt', ['-of', "!rcode_depth$refDepth -ff"],
219 '.nrm', ['-of3', '!rcode_norm -ff'],
220 '.idx', ['-oa', '!rcode_ident "-t "']
221 );
222 if ($irrad) { # adjust actions for -i+ option
223 $rtoutC{'v'} = 'irradiance.hdr';
224 delete $rtoutC{'r'};
225 delete $rtoutC{'x'};
226 delete $rtoutC{'R'};
227 delete $rtoutC{'X'};
228 }
229 if (! -d $outdir) {
230 mkdir $outdir or die("Cannot create output directory '$outdir'\n");
231 }
232 # construct rsplit command
233 foreach my $oval (split //, $outlyr) {
234 die "Duplicate or unsupported type '$oval' in -o$outlyr\n"
235 if (!defined $rtoutC{$oval});
236 my $outfile = "$outdir/$rtoutC{$oval}";
237 die "File '$outfile' already exists\n" if (-e $outfile);
238 my ($otyp) = ($rtoutC{$oval} =~ /(\.[^.]+)$/);
239 push @rsplitA, $rcodeC{$otyp}[0];
240 push @rsplitA, qq{'$rcodeC{$otyp}[1] > "$outfile"'};
241 delete $rtoutC{$oval};
242 }
243 # call rtrace + rsplit
244 exec "@vwraysA -ff | @rtraceA -fff @res '$oct' | getinfo -a 'VIEW=$view' | @rsplitA";
