root/radiance/ray/src/util/rtpict.pl
Revision: 2.27
Committed: Wed Nov 15 18:02:53 2023 UTC (17 months, 3 weeks ago) by greg
Changes since 2.26: +3 -2 lines
1 #!/usr/bin/perl -w
2 # RCSid $Id: rtpict.pl,v 2.26 2023/01/24 21:54:49 greg Exp $
3 #
4 # Run rtrace in parallel mode to simulate rpict -n option
5 # May also be used to render layered images with -o* option
6 #
7 # G. Ward
8 #
9 use strict;
10 # we'll run rpict if no -n or -o* option
11 my $nprocs = 1;
12 # rtrace options and the associated number of arguments
13 my %rtraceC = ('-dt',1, '-dc',1, '-dj',1, '-ds',1, '-dr',1, '-dp',1,
14 '-ss',1, '-st',1, '-e',1, '-am',1, '-P',1, '-PP',1,
15 '-ab',1, '-af',1, '-ai',1, '-aI',1, '-ae',1, '-aE',1,
16 '-av',3, '-aw',1, '-aa',1, '-ar',1, '-ad',1, '-as',1,
17 '-me',3, '-ma',3, '-mg',1, '-ms',1, '-lr',1, '-lw',1,
18 '-ap',2, '-am',1, '-ac',1, '-aC',1,
19 '-cs',1, '-cw',2, '-pc',8, '-pRGB',0, '-pXYZ',0);
20 # boolean rtrace options
21 my @boolO = ('-w', '-bv', '-dv', '-i', '-u');
22 # view options and the associated number of arguments
23 my %vwraysC = ('-vf',1, '-vtv',0, '-vtl',0, '-vth',0, '-vta',0, '-vts',0, '-vtc',0,
24 '-x',1, '-y',1, '-vp',3, '-vd',3, '-vu',3, '-vh',1, '-vv',1,
25 '-vo',1, '-va',1, '-vs',1, '-vl',1, '-pa',1, '-pj',1, '-pd',1);
26 # options we need to silently ignore
27 my %ignoreC = ('-t',1, '-ps',1, '-pt',1, '-pm',1,);
28 # Starting options for rtrace (rpict values)
29 my @rtraceA = split(' ', 'rtrace -u- -dt .05 -dc .5 -ds .25 -dr 1 ' .
30 '-aa .2 -ar 64 -ad 512 -as 128 -lr 7 -lw 1e-04');
31 my @vwraysA = ('vwrays', '-pj', '.67');
32 my @vwrightA = ('vwright', '-vtv');
33 my @rpictA = ('rpict', '-ps', '1');
34 my $outpatt = '^-o[vrxlLRXnNsmM]+';
35 my $refDepth = "";
36 my $irrad = 0;
37 my $persist = 0;
38 my $ambounce = 0;
39 my $ambcache = 1;
40 my $ambfile;
41 my $outlyr;
42 my $outdir;
43 my $outpic;
44 my $outzbf;
45 OPTION: # sort through options
46 while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) {
47 # Check for file inclusion
48 if ("$ARGV[0]" =~ /^\@/) {
49 open my $handle, '<', substr($ARGV[0], 1) or die "No file for $ARGV[0]\n";
50 shift @ARGV;
51 chomp(my @args = <$handle>);
52 close $handle;
53 unshift @ARGV, split(/\s+/, "@args");
54 next OPTION;
55 }
56 # Check booleans
57 for my $boopt (@boolO) {
58 if ("$ARGV[0]" =~ ('^' . $boopt . '[-+01tfynTFYN]?$')) {
59 if ("$ARGV[0]" eq '-i') {
60 $irrad = ! $irrad;
61 } elsif ("$ARGV[0]" =~ /^-i[-+01tfynTFYN]/) {
62 $irrad = ("$ARGV[0]" =~ /^-i[+1tyTY]/);
63 }
64 push @rtraceA, $ARGV[0];
65 push @rpictA, shift(@ARGV);
66 next OPTION;
67 }
68 }
69 # Check view options
70 if (defined $vwraysC{$ARGV[0]}) {
71 push @vwraysA, $ARGV[0];
72 my $isvopt = ("$ARGV[0]" =~ /^-v/);
73 push(@vwrightA, $ARGV[0]) if ($isvopt);
74 push @rpictA, shift(@ARGV);
75 for (my $i = $vwraysC{$rpictA[-1]}; $i-- > 0; ) {
76 push @vwraysA, $ARGV[0];
77 push(@vwrightA, $ARGV[0]) if ($isvopt);
78 push @rpictA, shift(@ARGV);
79 }
80 next OPTION;
81 }
82 # Check rtrace options
83 if (defined $rtraceC{$ARGV[0]}) {
84 if ("$ARGV[0]" =~ /^-PP?$/) {
85 $persist = 1;
86 } elsif ("$ARGV[0]" eq '-ab') {
87 $ambounce = $ARGV[1];
88 } elsif ("$ARGV[0]" eq '-aa') {
89 $ambcache = ($ARGV[1] > 0.0);
90 } elsif ("$ARGV[0]" eq '-af') {
91 $ambfile = "$ARGV[1]";
92 }
93 push @rtraceA, $ARGV[0];
94 push @rpictA, shift(@ARGV);
95 for (my $i = $rtraceC{$rpictA[-1]}; $i-- > 0; ) {
96 push @rtraceA, $ARGV[0];
97 push @rpictA, shift(@ARGV);
98 }
99 next OPTION;
100 }
101 # Check options to ignore
102 if (defined $ignoreC{$ARGV[0]}) {
103 push @rpictA, shift(@ARGV);
104 for (my $i = $ignoreC{$rpictA[-1]}; $i-- > 0; ) {
105 push @rpictA, shift(@ARGV);
106 }
107 next OPTION;
108 }
109 # Check for output file or number of processes
110 if ("$ARGV[0]" eq '-o') {
111 shift @ARGV;
112 $outpic = shift(@ARGV);
113 } elsif ("$ARGV[0]" eq '-z') {
114 push @rpictA, shift(@ARGV);
115 $outzbf = $ARGV[0];
116 push @rpictA, shift(@ARGV);
117 } elsif ("$ARGV[0]" eq '-n') {
118 shift @ARGV;
119 $nprocs = shift(@ARGV);
120 } elsif ("$ARGV[0]" eq '-d') {
121 shift @ARGV;
122 $refDepth = ' -d ' . shift(@ARGV);
123 } elsif ("$ARGV[0]" =~ "$outpatt") {
124 push @rtraceA, $ARGV[0];
125 $outlyr = substr(shift(@ARGV), 2);
126 $outdir = shift(@ARGV);
127 } else {
128 die "Unsupported option: " . $ARGV[0] . "\n";
129 }
130 }
131 die "Number of processes must be positive" if ($nprocs <= 0);
132 if (defined $outdir) { # check conflicting options
133 die "Options -o and -o* are mutually exclusive\n" if (defined $outpic);
134 die "Options -z and -o* are mutually exclusive\n" if (defined $outzbf);
135 }
136 if (defined $outpic) { # redirect output?
137 die "File '$outpic' already exists\n" if (-e $outpic);
138 open STDOUT, '>', "$outpic";
139 }
140 #####################################################################
141 ##### May as well run rpict?
142 if ($nprocs == 1 && $persist == 0 && !defined($outdir)) {
143 push(@rpictA, $ARGV[0]) if ($#ARGV == 0);
144 exec @rpictA ;
145 }
146 # OK, we're running rtrace in some capacity...
147 push @rtraceA, ('-n', "$nprocs");
148 die "Need single octree argument\n" if ($#ARGV != 0);
149 my $oct = $ARGV[0];
150 my $view = `@vwrightA 0`;
151 chomp $view;
152 my @res = split(/\s/, `@vwraysA -d`);
153 #####################################################################
154 ##### Resort pixels to reduce ambient cache collisions?
155 if ($nprocs > 1 && $ambounce > 0 && $ambcache && defined($ambfile)) {
156 if (!defined($outzbf) && !defined($outdir)) {
157 # Straight picture output, so just shuffle sample order
158 system "cnt -s $res[1] $res[3] > /tmp/ord$$.txt";
159 die "cnt error\n" if ( $? );
160 system "@vwraysA -ff -i < /tmp/ord$$.txt " .
161 "| @rtraceA -ffa -ov '$oct' > /tmp/pix$$.txt";
162 die "Error running rtrace\n" if ( $? );
163 system "( getinfo < /tmp/pix$$.txt | getinfo -a 'VIEW=$view'; " .
164 "getinfo - < /tmp/pix$$.txt | rlam /tmp/ord$$.txt - " .
165 "| sort -k2rn -k1n ) | pvalue -r -Y $res[3] +X $res[1]";
166 die "rlam error\n" if ( $? );
167 unlink ("/tmp/ord$$.txt", "/tmp/pix$$.txt");
168 exit 0;
169 }
170 # Else randomize overture calculation to prime ambient cache
171 my @ores = (int($res[1]/6), int($res[3]/6));
172 print STDERR "Running $ores[0] by $ores[1] overture calculation " .
173 "to populate '$ambfile'...\n";
174 system "cnt -s @ores | @vwraysA -i -ff -x $ores[0] -y $ores[1] -pj 0 " .
175 "| @rtraceA -ff -ov '$oct' > /dev/null";
176 die "Failure running overture\n" if ( $? );
177 print STDERR "Finished overture.\n";
178 }
179 #####################################################################
180 ##### Generating picture with depth buffer?
181 if (defined $outzbf) {
182 exec "@vwraysA -ff | @rtraceA -fff -olv @res '$oct' | " .
183 "rsplit -ih -iH -f -of '$outzbf' -oh -oH -of3 - | " .
184 "pvalue -r -df | getinfo -a 'VIEW=$view'";
185 }
186 #####################################################################
187 ##### Base case with output picture only?
188 if (! defined $outdir) {
189 exec "@vwraysA -ff | @rtraceA -ffc @res '$oct' | getinfo -a 'VIEW=$view'";
190 }
191 #####################################################################
192 ##### Layered image output case
193 my @rsplitA = ("rsplit", "'-t '", "-ih", "-iH", "-oh", "-oH");
194 # Supported rtrace -o* options and output file name.typ
195 my %rtoutC = (
196 v => 'radiance.hdr',
197 r => 'r_refl.hdr',
198 x => 'r_unrefl.hdr',
199 l => 'd_effective.dpt',
200 L => 'd_firstsurf.dpt',
201 R => 'd_refl.dpt',
202 X => 'd_unrefl.dpt',
203 n => 'perturbed.nrm',
204 N => 'unperturbed.nrm',
205 s => 'surface.idx',
206 m => 'modifier.idx',
207 M => 'material.idx'
208 );
209 # Arguments for rsplit based on output file type
210 my %rcodeC = (
211 '.hdr', ['-of3', '!pvalue -r -df -u'],
212 '.dpt', ['-of', "!rcode_depth$refDepth -ff"],
213 '.nrm', ['-of3', '!rcode_norm -ff'],
214 '.idx', ['-oa', '!rcode_ident "-t "']
215 );
216 if ($irrad) { # adjust actions for -i+ option
217 $rtoutC{'v'} = 'irradiance.hdr';
218 delete $rtoutC{'r'};
219 delete $rtoutC{'x'};
220 delete $rtoutC{'R'};
221 delete $rtoutC{'X'};
222 }
223 if (! -d $outdir) {
224 mkdir $outdir or die("Cannot create output directory '$outdir'\n");
225 }
226 # construct rsplit command
227 foreach my $oval (split //, $outlyr) {
228 die "Duplicate or unsupported type '$oval' in -o$outlyr\n"
229 if (!defined $rtoutC{$oval});
230 my $outfile = "$outdir/$rtoutC{$oval}";
231 die "File '$outfile' already exists\n" if (-e $outfile);
232 my ($otyp) = ($rtoutC{$oval} =~ /(\.[^.]+)$/);
233 push @rsplitA, $rcodeC{$otyp}[0];
234 push @rsplitA, qq{'$rcodeC{$otyp}[1] > "$outfile"'};
235 delete $rtoutC{$oval};
236 }
237 # call rtrace + rsplit
238 exec "@vwraysA -ff | @rtraceA -fff @res '$oct' | getinfo -a 'VIEW=$view' | @rsplitA";
