root/radiance/ray/src/util/rtpict.pl
Revision: 2.29
Committed: Mon Dec 11 19:21:43 2023 UTC (5 months, 2 weeks ago) by greg
Changes since 2.28: +30 -10 lines
feat(rtpict): Added -co+ option support for hyperspectral image output
1 #!/usr/bin/perl -w
2 # RCSid $Id: rtpict.pl,v 2.28 2023/11/17 23:30:07 greg Exp $
3 #
4 # Run rtrace in parallel mode to simulate rpict -n option
5 # May also be used to render layered images with -o* option
6 #
7 # G. Ward
8 #
9 use strict;
10 # we'll run rpict if no -n or -o* option
11 my $nprocs = 1;
12 # rtrace options and the associated number of arguments
13 my %rtraceC = ('-dt',1, '-dc',1, '-dj',1, '-ds',1, '-dr',1, '-dp',1,
14 '-ss',1, '-st',1, '-e',1, '-am',1, '-P',1, '-PP',1,
15 '-ab',1, '-af',1, '-ai',1, '-aI',1, '-ae',1, '-aE',1,
16 '-av',3, '-aw',1, '-aa',1, '-ar',1, '-ad',1, '-as',1,
17 '-me',3, '-ma',3, '-mg',1, '-ms',1, '-lr',1, '-lw',1,
18 '-ap',2, '-am',1, '-ac',1, '-aC',1,
19 '-cs',1, '-cw',2, '-pc',8, '-pXYZ',0);
20 # boolean rtrace options
21 my @boolO = ('-w', '-bv', '-dv', '-i', '-u', '-co');
22 # view options and the associated number of arguments
23 my %vwraysC = ('-vf',1, '-vtv',0, '-vtl',0, '-vth',0, '-vta',0, '-vts',0, '-vtc',0,
24 '-x',1, '-y',1, '-vp',3, '-vd',3, '-vu',3, '-vh',1, '-vv',1,
25 '-vo',1, '-va',1, '-vs',1, '-vl',1, '-pa',1, '-pj',1, '-pd',1);
26 # options we need to silently ignore
27 my %ignoreC = ('-t',1, '-ps',1, '-pt',1, '-pm',1,);
28 # Starting options for rtrace (rpict values)
29 my @rtraceA = split(' ', 'rtrace -u- -dt .05 -dc .5 -ds .25 -dr 1 ' .
30 '-aa .2 -ar 64 -ad 512 -as 128 -lr 7 -lw 1e-04');
31 my @vwraysA = ('vwrays', '-pj', '.67');
32 my @vwrightA = ('vwright', '-vtv');
33 my @rpictA = ('rpict', '-ps', '1');
34 my @pvalueA = ('pvalue', '-r');
35 my $outpatt = '^-o[vrxlLRXnNsmM]+';
36 my $refDepth = "";
37 my $irrad = 0;
38 my $specout = 0;
39 my $ncsamp = 3;
40 my $persist = 0;
41 my $ambounce = 0;
42 my $ambcache = 1;
43 my $ambfile;
44 my $outlyr;
45 my $outdir;
46 my $outpic;
47 my $outzbf;
48 OPTION: # sort through options
49 while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) {
50 # Check for file inclusion
51 if ("$ARGV[0]" =~ /^\@/) {
52 open my $handle, '<', substr($ARGV[0], 1) or die "No file for $ARGV[0]\n";
53 shift @ARGV;
54 chomp(my @args = <$handle>);
55 close $handle;
56 unshift @ARGV, split(/\s+/, "@args");
57 next OPTION;
58 }
59 # Check booleans
60 for my $boopt (@boolO) {
61 if ("$ARGV[0]" =~ ('^' . $boopt . '[-+01tfynTFYN]?$')) {
62 if ("$ARGV[0]" eq '-i') {
63 $irrad = ! $irrad;
64 } elsif ("$ARGV[0]" =~ /^-i[-+01tfynTFYN]/) {
65 $irrad = ("$ARGV[0]" =~ /^-i[+1tyTY]/);
66 } elsif ("$ARGV[0]" eq '-co') {
67 $specout = ! $specout;
68 } elsif ("$ARGV[0]" =~ /^-co[-+01tfynTFYN]/) {
69 $specout = ("$ARGV[0]" =~ /^-co[+1tyTY]/);
70 }
71 push(@rpictA, $ARGV[0]) if ("$ARGV[0]" !~ /^-co/);
72 push @rtraceA, shift(@ARGV);
73 next OPTION;
74 }
75 }
76 # Check view options
77 if (defined $vwraysC{$ARGV[0]}) {
78 push @vwraysA, $ARGV[0];
79 my $isvopt = ("$ARGV[0]" =~ /^-v/);
80 push(@vwrightA, $ARGV[0]) if ($isvopt);
81 push @rpictA, shift(@ARGV);
82 for (my $i = $vwraysC{$rpictA[-1]}; $i-- > 0; ) {
83 push @vwraysA, $ARGV[0];
84 push(@vwrightA, $ARGV[0]) if ($isvopt);
85 push @rpictA, shift(@ARGV);
86 }
87 next OPTION;
88 }
89 # Check rtrace options
90 if (defined $rtraceC{$ARGV[0]}) {
91 if ("$ARGV[0]" =~ /^-PP?$/) {
92 $persist = 1;
93 } elsif ("$ARGV[0]" eq '-ab') {
94 $ambounce = $ARGV[1];
95 } elsif ("$ARGV[0]" eq '-aa') {
96 $ambcache = ($ARGV[1] > 0.0);
97 } elsif ("$ARGV[0]" eq '-af') {
98 $ambfile = "$ARGV[1]";
99 } elsif ("$ARGV[0]" eq '-pXYZ') {
100 push @pvalueA, $ARGV[0];
101 $specout = 0;
102 } elsif ("$ARGV[0]" eq '-pc') {
103 push @pvalueA, '-p';
104 push @pvalueA, @ARGV[1..8];
105 $specout = 0;
106 } elsif ("$ARGV[0]" eq '-cs') {
107 $ncsamp = $ARGV[1];
108 }
109 push @rtraceA, $ARGV[0];
110 push @rpictA, shift(@ARGV);
111 for (my $i = $rtraceC{$rpictA[-1]}; $i-- > 0; ) {
112 push @rtraceA, $ARGV[0];
113 push @rpictA, shift(@ARGV);
114 }
115 next OPTION;
116 }
117 # Check options to ignore
118 if (defined $ignoreC{$ARGV[0]}) {
119 push @rpictA, shift(@ARGV);
120 for (my $i = $ignoreC{$rpictA[-1]}; $i-- > 0; ) {
121 push @rpictA, shift(@ARGV);
122 }
123 next OPTION;
124 }
125 # Check for output file or number of processes
126 if ("$ARGV[0]" eq '-o') {
127 shift @ARGV;
128 $outpic = shift(@ARGV);
129 } elsif ("$ARGV[0]" eq '-z') {
130 push @rpictA, shift(@ARGV);
131 $outzbf = $ARGV[0];
132 push @rpictA, shift(@ARGV);
133 } elsif ("$ARGV[0]" eq '-n') {
134 shift @ARGV;
135 $nprocs = shift(@ARGV);
136 } elsif ("$ARGV[0]" eq '-d') {
137 shift @ARGV;
138 $refDepth = ' -d ' . shift(@ARGV);
139 } elsif ("$ARGV[0]" =~ "$outpatt") {
140 push @rtraceA, $ARGV[0];
141 $outlyr = substr(shift(@ARGV), 2);
142 $outdir = shift(@ARGV);
143 } else {
144 die "Unsupported option: " . $ARGV[0] . "\n";
145 }
146 }
147 die "Number of processes must be positive" if ($nprocs <= 0);
148 if ($specout) {
149 $specout = ($ncsamp > 3);
150 }
151 if (defined $outdir) { # check conflicting options
152 die "Options -o and -o* are mutually exclusive\n" if (defined $outpic);
153 die "Options -z and -o* are mutually exclusive\n" if (defined $outzbf);
154 }
155 if (defined $outpic) { # redirect output?
156 die "File '$outpic' already exists\n" if (-e $outpic);
157 open STDOUT, '>', "$outpic";
158 }
159 #####################################################################
160 ##### May as well run rpict?
161 if ($specout == 0 && $nprocs == 1 && $persist == 0 && !defined($outdir)) {
162 push(@rpictA, $ARGV[0]) if ($#ARGV == 0);
163 exec @rpictA ;
164 }
165 # OK, we're running rtrace in some capacity...
166 push @rtraceA, ('-n', "$nprocs");
167 die "Need single octree argument\n" if ($#ARGV != 0);
168 my $oct = $ARGV[0];
169 my $view = `@vwrightA 0`;
170 chomp $view;
171 my @res = split(/\s/, `@vwraysA -d`);
172 #####################################################################
173 ##### Resort pixels to reduce ambient cache collisions?
174 if ($nprocs > 1 && $ambounce > 0 && $ambcache && defined($ambfile)) {
175 if ($specout == 0 && !defined($outzbf) && !defined($outdir)) {
176 # Straight picture output, so just shuffle sample order
177 system "cnt -s $res[1] $res[3] > /tmp/ord$$.txt";
178 die "cnt error\n" if ( $? );
179 system "@vwraysA -ff -i < /tmp/ord$$.txt " .
180 "| @rtraceA -ffa -ov '$oct' > /tmp/pix$$.txt";
181 die "Error running rtrace\n" if ( $? );
182 system "( getinfo < /tmp/pix$$.txt | getinfo -a 'VIEW=$view'; " .
183 "getinfo - < /tmp/pix$$.txt | rlam /tmp/ord$$.txt - " .
184 "| sort -k2rn -k1n ) | @pvalueA -Y $res[3] +X $res[1]";
185 die "rlam error\n" if ( $? );
186 unlink ("/tmp/ord$$.txt", "/tmp/pix$$.txt");
187 exit 0;
188 }
189 # Else randomize overture calculation to prime ambient cache
190 my @ores = (int($res[1]/6), int($res[3]/6));
191 print STDERR "Running $ores[0] by $ores[1] overture calculation " .
192 "to populate '$ambfile'...\n";
193 system "cnt -s @ores | @vwraysA -i -ff -x $ores[0] -y $ores[1] -pj 0 " .
194 "| @rtraceA -ff -ov -pY '$oct' > /dev/null";
195 die "Failure running overture\n" if ( $? );
196 print STDERR "Finished overture.\n";
197 }
198 #####################################################################
199 ##### Generating picture with depth buffer?
200 if (defined $outzbf) {
201 my $picvt = $specout ? 'rmtxcomb -fc -' : "@pvalueA -df";
202 exec "@vwraysA -ff | @rtraceA -fff -olv @res '$oct' | " .
203 "rsplit -ih -iH -f -of '$outzbf' -oh -oH -of$ncsamp - | " .
204 $picvt . " | getinfo -a 'VIEW=$view'";
205 }
206 #####################################################################
207 ##### Base case with output picture only?
208 if (! defined $outdir) {
209 exec "@vwraysA -ff | @rtraceA -ffc @res '$oct' | getinfo -a 'VIEW=$view'";
210 }
211 #####################################################################
212 ##### Layered image output case
213 my @rsplitA = ("rsplit", "'-t '", "-ih", "-iH", "-oh", "-oH");
214 # Supported rtrace -o* options and output file name.typ
215 my %rtoutC = (
216 v => 'radiance.hdr',
217 r => 'r_refl.hdr',
218 x => 'r_unrefl.hdr',
219 l => 'd_effective.dpt',
220 L => 'd_firstsurf.dpt',
221 R => 'd_refl.dpt',
222 X => 'd_unrefl.dpt',
223 n => 'perturbed.nrm',
224 N => 'unperturbed.nrm',
225 s => 'surface.idx',
226 m => 'modifier.idx',
227 M => 'material.idx'
228 );
229 # Arguments for rsplit based on output file type
230 my %rcodeC = (
231 '.hdr', ['-of3', "!@pvalueA -df -u"],
232 '.hsr', ["-of$ncsamp", '!rmtxcomb -fc -'],
233 '.dpt', ['-of', "!rcode_depth$refDepth -ff"],
234 '.nrm', ['-of3', '!rcode_norm -ff'],
235 '.idx', ['-oa', '!rcode_ident "-t "']
236 );
237 if ($specout) { # adjust actions for -co+ option
238 $rtoutC{'v'} = 'radiance.hsr';
239 $rtoutC{'r'} = 'r_refl.hsr';
240 $rtoutC{'x'} = 'r_unrefl.hsr';
241 }
242 if ($irrad) { # adjust actions for -i+ option
243 $rtoutC{'v'} = $specout ? 'irradiance.hsr' : 'irradiance.hdr';
244 delete $rtoutC{'r'};
245 delete $rtoutC{'x'};
246 delete $rtoutC{'R'};
247 delete $rtoutC{'X'};
248 }
249 if (! -d $outdir) {
250 mkdir $outdir or die("Cannot create output directory '$outdir'\n");
251 }
252 # construct rsplit command
253 foreach my $oval (split //, $outlyr) {
254 die "Duplicate or unsupported type '$oval' in -o$outlyr\n"
255 if (!defined $rtoutC{$oval});
256 my $outfile = "$outdir/$rtoutC{$oval}";
257 die "File '$outfile' already exists\n" if (-e $outfile);
258 my ($otyp) = ($rtoutC{$oval} =~ /(\.[^.]+)$/);
259 push @rsplitA, $rcodeC{$otyp}[0];
260 push @rsplitA, qq{'$rcodeC{$otyp}[1] > "$outfile"'};
261 delete $rtoutC{$oval};
262 }
263 # call rtrace + rsplit
264 exec "@vwraysA -ff | @rtraceA -fff @res '$oct' | getinfo -a 'VIEW=$view' | @rsplitA";
