root/radiance/ray/src/util/rtpict.pl
Revision: 2.18
Committed: Wed Apr 8 16:20:00 2020 UTC (5 years, 1 month ago) by greg
Added support for photon-mapping (thanks to Roland)
1 #!/usr/bin/perl -w
2 # RCSid $Id: rtpict.pl,v 2.17 2020/04/08 02:39:30 greg Exp $
3 #
4 # Run rtrace in parallel mode to simulate rpict -n option
5 # May also be used to render layered images with -o* option
6 #
7 # G. Ward
8 #
9 use strict;
10 # we'll run rpict if no -n or -o* option
11 my $nprocs = 1;
12 # rtrace options and the associated number of arguments
13 my %rtraceC = ('-dt',1, '-dc',1, '-dj',1, '-ds',1, '-dr',1, '-dp',1,
14 '-ss',1, '-st',1, '-e',1, '-am',1, '-P',1, '-PP',1,
15 '-ab',1, '-af',1, '-ai',1, '-aI',1, '-ae',1, '-aE',1,
16 '-av',3, '-aw',1, '-aa',1, '-ar',1, '-ad',1, '-as',1,
17 '-me',3, '-ma',3, '-mg',1, '-ms',1, '-lr',1, '-lw',1,
18 '-ap',2, '-am',1, '-ac',1, '-aC',1);
19 # boolean rtrace options
20 my @boolO = ('-w', '-bv', '-dv', '-i', '-u');
21 # view options and the associated number of arguments
22 my %vwraysC = ('-vf',1, '-vtv',0, '-vtl',0, '-vth',0, '-vta',0, '-vts',0, '-vtc',0,
23 '-x',1, '-y',1, '-vp',3, '-vd',3, '-vu',3, '-vh',1, '-vv',1,
24 '-vo',1, '-va',1, '-vs',1, '-vl',1, '-pa',1, '-pj',1);
25 # options we need to silently ignore
26 my %ignoreC = ('-t',1, '-ps',1, '-pt',1, '-pm',1, '-pd',1);
27 # Starting options for rtrace (rpict values)
28 my @rtraceA = split(' ', 'rtrace -u- -dt .05 -dc .5 -ds .25 -dr 1 ' .
29 '-aa .2 -ar 64 -ad 512 -as 128 -lr 7 -lw 1e-03');
30 my @vwraysA = ('vwrays', '-ff', '-pj', '.67');
31 my @vwrightA = ('vwright', '-vtv');
32 my @rpictA = ('rpict', '-ps', '1');
33 my $outpatt = '^-o[vrxlLRXnNsmM]+';
34 my $refDepth = "";
35 my $irrad = 0;
36 my $persist = 0;
37 my $outlyr;
38 my $outdir;
39 my $outpic;
40 my $outzbf;
41 OPTION: # sort through options
42 while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) {
43 # Check for file inclusion
44 if ("$ARGV[0]" =~ /^\@/) {
45 open my $handle, '<', substr($ARGV[0], 1) or die "No file for $ARGV[0]\n";
46 shift @ARGV;
47 chomp(my @args = <$handle>);
48 close $handle;
49 unshift @ARGV, split(/\s+/, "@args");
50 next OPTION;
51 }
52 # Check booleans
53 for my $boopt (@boolO) {
54 if ("$ARGV[0]" =~ ('^' . $boopt . '[-+01tfynTFYN]?$')) {
55 if ("$ARGV[0]" eq '-i') {
56 $irrad = ! $irrad;
57 } elsif ("$ARGV[0]" =~ /^-i[-+01tfynTFYN]/) {
58 $irrad = ("$ARGV[0]" =~ /^-i[+1tyTY]/);
59 }
60 push @rtraceA, $ARGV[0];
61 push @rpictA, shift(@ARGV);
62 next OPTION;
63 }
64 }
65 # Check view options
66 if (defined $vwraysC{$ARGV[0]}) {
67 push @vwraysA, $ARGV[0];
68 my $isvopt = ("$ARGV[0]" =~ /^-v/);
69 push(@vwrightA, $ARGV[0]) if ($isvopt);
70 push @rpictA, shift(@ARGV);
71 for (my $i = $vwraysC{$rpictA[-1]}; $i-- > 0; ) {
72 push @vwraysA, $ARGV[0];
73 push(@vwrightA, $ARGV[0]) if ($isvopt);
74 push @rpictA, shift(@ARGV);
75 }
76 next OPTION;
77 }
78 # Check rtrace options
79 if (defined $rtraceC{$ARGV[0]}) {
80 $persist ||= ("$ARGV[0]" =~ /^-PP?$/);
81 push @rtraceA, $ARGV[0];
82 push @rpictA, shift(@ARGV);
83 for (my $i = $rtraceC{$rpictA[-1]}; $i-- > 0; ) {
84 push @rtraceA, $ARGV[0];
85 push @rpictA, shift(@ARGV);
86 }
87 next OPTION;
88 }
89 # Check options to ignore
90 if (defined $ignoreC{$ARGV[0]}) {
91 push @rpictA, shift(@ARGV);
92 for (my $i = $ignoreC{$rpictA[-1]}; $i-- > 0; ) {
93 push @rpictA, shift(@ARGV);
94 }
95 next OPTION;
96 }
97 # Check for output file or number of processes
98 if ("$ARGV[0]" eq '-o') {
99 shift @ARGV;
100 $outpic = shift(@ARGV);
101 } elsif ("$ARGV[0]" eq '-z') {
102 push @rpictA, shift(@ARGV);
103 $outzbf = $ARGV[0];
104 push @rpictA, shift(@ARGV);
105 } elsif ("$ARGV[0]" eq '-n') {
106 shift @ARGV;
107 $nprocs = shift(@ARGV);
108 } elsif ("$ARGV[0]" eq '-d') {
109 shift @ARGV;
110 $refDepth = ' -d ' . shift(@ARGV);
111 } elsif ("$ARGV[0]" =~ "$outpatt") {
112 push @rtraceA, $ARGV[0];
113 $outlyr = substr(shift(@ARGV), 2);
114 $outdir = shift(@ARGV);
115 } else {
116 die "Unsupported option: " . $ARGV[0] . "\n";
117 }
118 }
119 die "Number of processes must be positive" if ($nprocs <= 0);
120 if (defined $outdir) { # check conflicting options
121 die "Options -o and -o* are mutually exclusive\n" if (defined $outpic);
122 die "Options -z and -o* are mutually exclusive\n" if (defined $outzbf);
123 }
124 if (defined $outpic) { # redirect output?
125 die "File '$outpic' already exists\n" if (-e $outpic);
126 open STDOUT, '>', "$outpic";
127 }
128 #####################################################################
129 ##### May as well run rpict?
130 if ($nprocs == 1 && $persist == 0 && !defined($outdir)) {
131 push(@rpictA, $ARGV[0]) if ($#ARGV == 0);
132 exec @rpictA ;
133 }
134 # OK, we're running rtrace in some capacity...
135 push @rtraceA, ('-n', "$nprocs");
136 die "Need single octree argument\n" if ($#ARGV != 0);
137 my $oct = $ARGV[0];
138 my $view = `@vwrightA 0`;
139 chomp $view;
140 my @res = split(/\s/, `@vwraysA -d`);
141 #####################################################################
142 ##### Generating picture with depth buffer?
143 if (defined $outzbf) {
144 exec "@vwraysA | @rtraceA -fff -olv @res '$oct' | " .
145 "rsplit -ih -iH -f -of '$outzbf' -oh -oH -of3 - | " .
146 "pvalue -r -df | getinfo -a 'VIEW=$view'";
147 }
148 #####################################################################
149 ##### Base case with output picture only?
150 if (! defined $outdir) {
151 exec "@vwraysA | @rtraceA -ffc @res '$oct' | getinfo -a 'VIEW=$view'";
152 }
153 #####################################################################
154 ##### Layered image output case
155 my @rsplitA = ("rsplit", "'-t '", "-ih", "-iH", "-oh", "-oH");
156 # Supported rtrace -o* options and output file name.typ
157 my %rtoutC = (
158 v => 'radiance.hdr',
159 r => 'r_refl.hdr',
160 x => 'r_unrefl.hdr',
161 l => 'd_effective.dpt',
162 L => 'd_firstsurf.dpt',
163 R => 'd_refl.dpt',
164 X => 'd_unrefl.dpt',
165 n => 'perturbed.nrm',
166 N => 'unperturbed.nrm',
167 s => 'surface.idx',
168 m => 'modifier.idx',
169 M => 'material.idx'
170 );
171 # Arguments for rsplit based on output file type
172 my %rcodeC = (
173 '.hdr', ['-of3', '!pvalue -r -df -u'],
174 '.dpt', ['-of', "!rcode_depth$refDepth -ff"],
175 '.nrm', ['-of3', '!rcode_norm -ff'],
176 '.idx', ['-oa', '!rcode_ident "-t "']
177 );
178 if ($irrad) { # adjust actions for -i+ option
179 $rtoutC{'v'} = 'irradiance.hdr';
180 delete $rtoutC{'r'};
181 delete $rtoutC{'x'};
182 delete $rtoutC{'R'};
183 delete $rtoutC{'X'};
184 }
185 if (! -d $outdir) {
186 mkdir $outdir or die("Cannot create output directory '$outdir'\n");
187 }
188 # construct rsplit command
189 foreach my $oval (split //, $outlyr) {
190 die "Duplicate or unsupported type '$oval' in -o$outlyr\n"
191 if (!defined $rtoutC{$oval});
192 my $outfile = "$outdir/$rtoutC{$oval}";
193 die "File '$outfile' already exists\n" if (-e $outfile);
194 my ($otyp) = ($rtoutC{$oval} =~ /(\.[^.]+)$/);
195 push @rsplitA, $rcodeC{$otyp}[0];
196 push @rsplitA, qq{'$rcodeC{$otyp}[1] > "$outfile"'};
197 delete $rtoutC{$oval};
198 }
199 # call rtrace + rsplit
200 exec "@vwraysA | @rtraceA -fff @res '$oct' | getinfo -a 'VIEW=$view' | @rsplitA";
