--- ray/src/util/rtpict.pl 2018/05/22 15:16:53 2.6 +++ ray/src/util/rtpict.pl 2019/08/16 04:32:46 2.12 @@ -1,33 +1,39 @@ #!/usr/bin/perl -w -# RCSid $Id: rtpict.pl,v 2.6 2018/05/22 15:16:53 greg Exp $ +# RCSid $Id: rtpict.pl,v 2.12 2019/08/16 04:32:46 greg Exp $ # # Run rtrace in parallel mode to simulate rpict -n option +# May also be used to render layered images with -o* option # # G. Ward # use strict; -# we'll call rpict if this is not overridden +# we'll run rpict if no -n or -o* option my $nprocs = 1; # rtrace options and the associated number of arguments -my %rtraceC = ("-dt",1, "-dc",1, "-dj",1, "-ds",1, "-dr",1, "-dp",1, - "-ss",1, "-st",1, "-e",1, "-am",1, - "-ab",1, "-af",1, "-ai",1, "-aI",1, "-ae",1, "-aE",1, - "-av",3, "-aw",1, "-aa",1, "-ar",1, "-ad",1, "-as",1, - "-me",3, "-ma",3, "-mg",1, "-ms",1, "-lr",1, "-lw",1); +my %rtraceC = ('-dt',1, '-dc',1, '-dj',1, '-ds',1, '-dr',1, '-dp',1, + '-ss',1, '-st',1, '-e',1, '-am',1, + '-ab',1, '-af',1, '-ai',1, '-aI',1, '-ae',1, '-aE',1, + '-av',3, '-aw',1, '-aa',1, '-ar',1, '-ad',1, '-as',1, + '-me',3, '-ma',3, '-mg',1, '-ms',1, '-lr',1, '-lw',1); # boolean rtrace options -my @boolO = ("-w", "-bv", "-dv", "-i", "-u"); +my @boolO = ('-w', '-bv', '-dv', '-i', '-u'); # view options and the associated number of arguments -my %vwraysC = ("-vf",1, "-vtv",0, "-vtl",0, "-vth",0, "-vta",0, "-vts",0, "-vtc",0, - "-x",1, "-y",1, "-vp",3, "-vd",3, "-vu",3, "-vh",1, "-vv",1, - "-vo",1, "-va",1, "-vs",1, "-vl",1, "-pa",1, "-pj",1, "-pd",1); +my %vwraysC = ('-vf',1, '-vtv',0, '-vtl',0, '-vth',0, '-vta',0, '-vts',0, '-vtc',0, + '-x',1, '-y',1, '-vp',3, '-vd',3, '-vu',3, '-vh',1, '-vv',1, + '-vo',1, '-va',1, '-vs',1, '-vl',1, '-pa',1, '-pj',1); # options we need to silently ignore -my %ignoreC = ("-t",1, "-ps",1, "-pt",1, "-pm",1); +my %ignoreC = ('-t',1, '-ps',1, '-pt',1, '-pm',1, '-pd',1); # Starting options for rtrace (rpict values) -my @rtraceA = split(' ', "rtrace -u- -dt .05 -dc .5 -ds .25 -dr 1 " . - "-aa .2 -ar 64 -ad 512 -as 128 -lr 7 -lw 1e-03"); -my @vwraysA = ("vwrays", "-ff", "-pj", ".67"); -my @vwrightA = ("vwright", "-vtv"); -my @rpictA = ("rpict"); +my @rtraceA = split(' ', 'rtrace -u- -dt .05 -dc .5 -ds .25 -dr 1 ' . + '-aa .2 -ar 64 -ad 512 -as 128 -lr 7 -lw 1e-03'); +my @vwraysA = ('vwrays', '-ff', '-pj', '.67'); +my @vwrightA = ('vwright', '-vtv'); +my @rpictA = ('rpict'); +my $outpatt = '^-o[vrxlLRXnNsmM]+'; +my $refDepth = ""; +my $irrad = 0; +my $outlyr; +my $outdir; my $outpic; my $outzbf; OPTION: # sort through options @@ -44,6 +50,11 @@ while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) { # Check booleans for my $boopt (@boolO) { if ("$ARGV[0]" =~ ('^' . $boopt . '[-+01tfynTFYN]?$')) { + if ("$ARGV[0]" eq '-i') { + $irrad = ! $irrad; + } elsif ("$ARGV[0]" =~ /^-i[-+01tfynTFYN]/) { + $irrad = ("$ARGV[0]" =~ /^-i[+1tyTY]/); + } push @rtraceA, $ARGV[0]; push @rpictA, shift(@ARGV); next OPTION; @@ -81,43 +92,104 @@ while ($#ARGV >= 0 && "$ARGV[0]" =~ /^[-\@]/) { next OPTION; } # Check for output file or number of processes - if ("$ARGV[0]" eq "-o") { + if ("$ARGV[0]" eq '-o') { shift @ARGV; $outpic = shift(@ARGV); - } elsif ("$ARGV[0]" eq "-z") { + } elsif ("$ARGV[0]" eq '-z') { push @rpictA, shift(@ARGV); $outzbf = $ARGV[0]; push @rpictA, shift(@ARGV); - } elsif ("$ARGV[0]" eq "-n") { + } elsif ("$ARGV[0]" eq '-n') { shift @ARGV; $nprocs = shift(@ARGV); + } elsif ("$ARGV[0]" eq '-d') { + shift @ARGV; + $refDepth = ' -d ' . shift(@ARGV); + } elsif ("$ARGV[0]" =~ "$outpatt") { + push @rtraceA, $ARGV[0]; + $outlyr = substr(shift(@ARGV), 2); + $outdir = shift(@ARGV); } else { die "Unsupported option: " . $ARGV[0] . "\n"; } } die "Number of processes must be positive" if ($nprocs <= 0); +if (defined $outdir) { # check conflicting options + die "Options -o and -o* are mutually exclusive\n" if (defined $outpic); + die "Options -z and -o* are mutually exclusive\n" if (defined $outzbf); +} if (defined $outpic) { # redirect output? die "File '$outpic' already exists\n" if (-e $outpic); open STDOUT, '>', "$outpic"; } -if ($nprocs == 1) { # may as well run rpict? +##################################################################### +##### May as well run rpict? +if ($nprocs == 1 && !defined($outdir)) { push(@rpictA, $ARGV[0]) if ($#ARGV == 0); exec @rpictA ; } -push @rtraceA, ("-n", "$nprocs"); +# OK, we're running rtrace in some capacity... +push @rtraceA, ('-n', "$nprocs"); die "Need single octree argument\n" if ($#ARGV != 0); my $oct = $ARGV[0]; my $view = `@vwrightA 0`; +chomp $view; my @res = split(/\s/, `@vwraysA -d`); -if (defined $outzbf) { # generating depth buffer? - my $tres = "/tmp/rtp$$"; - system "@vwraysA | @rtraceA -fff -ovl $res[4] $oct > $tres" || exit 1; - system( q{getinfo -c rcalc -if4 -of -e '$1=$1;$2=$2;$3=$3' < } . - "$tres | pvalue -r -df -Y $res[3] +X $res[1] | " . - "getinfo -a 'VIEW=$view'" ); - system( "getinfo - < $tres | rcalc -if4 -of > $outzbf" . q{ -e '$1=$4'} ); - unlink $tres; - exit; +##################################################################### +##### Generating picture with depth buffer? +if (defined $outzbf) { + exec "@vwraysA | @rtraceA -fff -olv @res $oct | " . + "rsplit -ih -iH -f -of $outzbf -oh -oH -of3 - | " . + "pvalue -r -df | getinfo -a 'VIEW=$view'"; } - # no depth buffer, so simpler -exec "@vwraysA | @rtraceA -ffc @res $oct | getinfo -a 'VIEW=$view'"; +##################################################################### +##### Base case with output picture only? +if (! defined $outdir) { + exec "@vwraysA | @rtraceA -ffc @res $oct | getinfo -a 'VIEW=$view'"; +} +##################################################################### +##### Layered image output case +my @rsplitA = ("rsplit", "'-t '", "-ih", "-iH", "-oh", "-oH"); +# Supported rtrace -o* options and output file name.typ +my %rtoutC = ( + v => 'radiance.hdr', + r => 'r_refl.hdr', + x => 'r_unrefl.hdr', + l => 'd_effective.dpt', + L => 'd_firstsurf.dpt', + R => 'd_refl.dpt', + X => 'd_unrefl.dpt', + n => 'perturbed.nrm', + N => 'unperturbed.nrm', + s => 'surface.idx', + m => 'modifier.idx', + M => 'material.idx' +); +# Arguments for rsplit based on output file type +my %rcodeC = ( + '.hdr', ['-of3', '!pvalue -r -df -u'], + '.dpt', ['-of', "!rcode_depth$refDepth -ff"], + '.nrm', ['-of3', '!rcode_norm -ff'], + '.idx', ['-oa', '!rcode_ident "-t "'] +); +if ($irrad) { # adjust actions for -i+ option + $rtoutC{'v'} = 'irradiance.hdr'; + delete $rtoutC{'r'}; + delete $rtoutC{'x'}; + delete $rtoutC{'R'}; + delete $rtoutC{'X'}; +} +if (! -d $outdir) { + mkdir $outdir or die("Cannot create output directory '$outdir'\n"); +} + # construct rsplit command +foreach my $oval (split //, $outlyr) { + die "Duplicate or unsupported type '$oval' in -o$outlyr\n" + if (!defined $rtoutC{$oval}); + my ($otyp) = ($rtoutC{$oval} =~ /(\.[^.]+)$/); + push @rsplitA, $rcodeC{$otyp}[0]; + push @rsplitA, qq{'$rcodeC{$otyp}[1] > "$outdir/$rtoutC{$oval}"'}; + delete $rtoutC{$oval}; +} + # call rtrace + rsplit +exec "@vwraysA | @rtraceA -fff @res $oct | getinfo -a 'VIEW=$view' | @rsplitA";
