root/radiance/ray/src/util/rtpict.pl
Fri Jan 5 18:33:26 2024 UTC (4 months, 4 weeks ago) by greg
Diff to previous 2.29 , to selected 2.5
fix(rtpict): Renamed rmtxcomb to rcomb
Mon Dec 11 19:21:43 2023 UTC (5 months, 3 weeks ago) by greg
Changes since 2.28: +30 -10 lines
Diff to previous 2.28 , to selected 2.5
feat(rtpict): Added -co+ option support for hyperspectral image output
Fri Nov 17 23:30:07 2023 UTC (6 months, 2 weeks ago) by greg
Changes since 2.27: +11 -5 lines
Diff to previous 2.27 , to selected 2.5
fix(rtpict): More reliable support for -pc and -pXYZ options
Wed Nov 15 18:02:53 2023 UTC (6 months, 2 weeks ago) by greg
Changes since 2.26: +3 -2 lines
Diff to previous 2.26 , to selected 2.5
Tue Jan 24 21:54:49 2023 UTC (16 months, 1 week ago) by greg
Diff to previous 2.25 , to selected 2.5
Tue Apr 12 00:30:58 2022 UTC (2 years, 1 month ago) by greg
Changes since 2.24: +6 -7 lines
Diff to previous 2.24 , to selected 2.5
perf(rtpict): Swapped sort -R command for cnt -s
Mon Apr 11 18:08:19 2022 UTC (2 years, 1 month ago) by greg
Diff to previous 2.23 , to selected 2.5
feat(cnt): Added -s option to shuffle output
Mon Apr 11 14:59:54 2022 UTC (2 years, 1 month ago) by greg
Changes since 2.22: +4 -4 lines
Diff to previous 2.22 , to selected 2.5
perf(rtpict): Minor optimization to last addition
Mon Apr 11 04:03:36 2022 UTC (2 years, 1 month ago) by greg
Changes since 2.21: +22 -7 lines
Diff to previous 2.21 , to selected 2.5
perf(rtpict): Improved random sampling to avoid ambient cache collisions
Sun Apr 10 16:00:14 2022 UTC (2 years, 1 month ago) by greg
Changes since 2.20: +5 -5 lines
Diff to previous 2.20 , to selected 2.5
perf(rtpict): Minor simplification of overture command
Sun Apr 10 03:46:27 2022 UTC (2 years, 1 month ago) by greg
Changes since 2.19: +25 -2 lines
Diff to previous 2.19 , to selected 2.5
perf(rtpict): Added overture calculation with ambient cache and -n > 1
Sat Dec 4 16:29:29 2021 UTC (2 years, 5 months ago) by greg
Diff to previous 2.18 , to selected 2.5
feat(vwrays,rtpict): Added support for -pd option to sample depth-of-field
Wed Apr 8 16:20:00 2020 UTC (4 years, 1 month ago) by greg
Diff to previous 2.17 , to selected 2.5
Added support for photon-mapping (thanks to Roland)
Wed Apr 8 02:39:30 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.16: +5 -3 lines
Diff to previous 2.16 , to selected 2.5
Added check for -P* persist option to preclude running rpict
Wed Apr 8 00:58:32 2020 UTC (4 years, 1 month ago) by greg
Diff to previous 2.15 , to selected 2.5
Added support for persist mode, which rtrace will complain about if -n > 1
Sun Mar 15 16:54:19 2020 UTC (4 years, 2 months ago) by greg
Changes since 2.14: +4 -2 lines
Added check so we don't overwrite output files created in earlier run with -o*
Sat Mar 14 20:09:55 2020 UTC (4 years, 2 months ago) by greg
Added check for missing @file
Fri Dec 13 21:43:47 2019 UTC (4 years, 5 months ago) by greg
Changes since 2.12: +5 -5 lines
Additional quoting to protect spaces in octree and z-buffer file names
Fri Aug 16 04:32:46 2019 UTC (4 years, 9 months ago) by greg
Moved -pd to ignored options where it belongs
Wed Aug 14 22:57:24 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.10: +3 -5 lines
Simplified -o with -z slightly
Wed Aug 14 22:18:03 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.9: +7 -7 lines
Made it so output names don't collide when rcode2bmp run on all
Tue Jul 23 18:17:55 2019 UTC (4 years, 10 months ago) by greg
Changes since 2.8: +86 -100 lines
Added -o* option to rtpict
Tue Jul 23 01:03:30 2019 UTC (4 years, 10 months ago) by greg
Changes since 2.7: +95 -4 lines
Add -o* option (and -d) to support layered image folders
Fri Jul 5 00:20:57 2019 UTC (4 years, 11 months ago) by greg
Changes since 2.6: +6 -9 lines
Tue May 22 15:16:53 2018 UTC (6 years ago) by greg
Fixed issue with boolean option toggling (thanks to Axel Jacobs)
Wed Mar 21 17:56:08 2018 UTC (6 years, 2 months ago) by greg
Changes since 2.4: +24 -8 lines
Added support for -z option (depth buffer output)
Tue Mar 20 23:05:48 2018 UTC (6 years, 2 months ago) by greg
Added check if output picture exists with -o option to match rpict behavior
Tue Mar 20 22:48:10 2018 UTC (6 years, 2 months ago) by greg
Removed rtpict from Windows build, while fixing quoting so it *could* run
Tue Mar 20 01:38:27 2018 UTC (6 years, 2 months ago) by greg
Changes since 2.1: +25 -21 lines
Fixed issues with boolean arguments and miscellaneous
Mon Mar 19 23:40:33 2018 UTC (6 years, 2 months ago) by greg
Diff to selected 2.5
