1 |
greg |
1.1 |
#ifndef lint |
2 |
schorsch |
1.43 |
static const char RCSid[] = "$Id: rtcontrib.c,v 1.42 2006/04/05 14:33:34 greg Exp $"; |
3 |
greg |
1.1 |
#endif |
4 |
5 |
* Gather rtrace output to compute contributions from particular sources |
6 |
7 |
8 |
greg |
1.4 |
#include "standard.h" |
9 |
greg |
1.1 |
#include <ctype.h> |
10 |
greg |
1.7 |
#include <signal.h> |
11 |
greg |
1.1 |
#include "platform.h" |
12 |
#include "rtprocess.h" |
13 |
#include "selcall.h" |
14 |
#include "color.h" |
15 |
#include "resolu.h" |
16 |
#include "lookup.h" |
17 |
#include "calcomp.h" |
18 |
19 |
greg |
1.19 |
#ifndef MAXMODLIST |
20 |
greg |
1.1 |
#define MAXMODLIST 1024 /* maximum modifiers we'll track */ |
21 |
greg |
1.19 |
#endif |
22 |
greg |
1.1 |
23 |
int treebufsiz = BUFSIZ; /* current tree buffer size */ |
24 |
25 |
greg |
1.2 |
typedef double DCOLOR[3]; /* double-precision color */ |
26 |
27 |
greg |
1.1 |
28 |
greg |
1.31 |
* The MODCONT structure is used to accumulate ray contributions |
29 |
greg |
1.1 |
* for a particular modifier, which may be subdivided into bins |
30 |
greg |
1.31 |
* if binv is non-zero. If outspec contains a %s in it, this will |
31 |
greg |
1.1 |
* be replaced with the modifier name. If outspec contains a %d in it, |
32 |
* this will be used to create one output file per bin, otherwise all bins |
33 |
* will be written to the same file, in order. If the global outfmt |
34 |
* is 'c', then a 4-byte RGBE pixel will be output for each bin value |
35 |
* and the file will conform to a RADIANCE image if xres & yres are set. |
36 |
37 |
typedef struct { |
38 |
const char *outspec; /* output file specification */ |
39 |
const char *modname; /* modifier name */ |
40 |
EPNODE *binv; /* bin value expression */ |
41 |
int nbins; /* number of accumulation bins */ |
42 |
greg |
1.2 |
DCOLOR cbin[1]; /* contribution bins (extends struct) */ |
43 |
greg |
1.1 |
} MODCONT; /* modifier contribution */ |
44 |
45 |
static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); } |
46 |
47 |
LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */ |
48 |
49 |
greg |
1.31 |
#define CNT_UNKNOWN 0 /* unknown record length */ |
50 |
#define CNT_PIPE (-1) /* output to a pipe */ |
51 |
52 |
* The STREAMOUT structure holds an open FILE pointer and a count of |
53 |
* the number of RGB triplets per record, or CNT_UNKNOWN (0) if |
54 |
* unknown or CNT_PIPE (-1) if writing to a command. |
55 |
56 |
typedef struct { |
57 |
FILE *ofp; /* output file pointer */ |
58 |
int reclen; /* triplets/record */ |
59 |
} STREAMOUT; |
60 |
61 |
/* close output stream and free record */ |
62 |
static void |
63 |
closestream(void *p) |
64 |
65 |
STREAMOUT *sop = (STREAMOUT *)p; |
66 |
greg |
1.33 |
int status; |
67 |
greg |
1.31 |
if (sop->reclen == CNT_PIPE) |
68 |
greg |
1.33 |
status = pclose(sop->ofp); |
69 |
greg |
1.31 |
else |
70 |
greg |
1.33 |
status = fclose(sop->ofp); |
71 |
if (status) |
72 |
error(SYSTEM, "error closing output stream"); |
73 |
greg |
1.31 |
free(p); |
74 |
75 |
greg |
1.1 |
76 |
greg |
1.31 |
LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */ |
77 |
greg |
1.1 |
78 |
greg |
1.14 |
#define OF_MODIFIER 01 |
79 |
#define OF_BIN 02 |
80 |
81 |
greg |
1.32 |
STREAMOUT *getostream(const char *ospec, const char *mname, int bn, int noopen); |
82 |
greg |
1.14 |
int ofname(char *oname, const char *ospec, const char *mname, int bn); |
83 |
void printheader(FILE *fout, const char *info); |
84 |
greg |
1.30 |
void printresolu(FILE *fout); |
85 |
greg |
1.1 |
86 |
87 |
* The rcont structure is used to manage i/o with a particular |
88 |
* rtrace child process. Input is passed unchanged from stdin, |
89 |
* and output is processed in input order and accumulated according |
90 |
* to the corresponding modifier and bin number. |
91 |
92 |
struct rtproc { |
93 |
struct rtproc *next; /* next in list of processes */ |
94 |
SUBPROC pd; /* rtrace pipe descriptors */ |
95 |
greg |
1.2 |
unsigned long raynum; /* ray number for this tree */ |
96 |
int bsiz; /* ray tree buffer length */ |
97 |
char *buf; /* ray tree buffer */ |
98 |
int nbr; /* number of bytes from rtrace */ |
99 |
greg |
1.5 |
}; /* rtrace process buffer */ |
100 |
greg |
1.1 |
101 |
/* rtrace command and defaults */ |
102 |
greg |
1.18 |
char *rtargv[256+2*MAXMODLIST] = { "rtrace", |
103 |
"-dj", ".5", "-dr", "3", |
104 |
greg |
1.42 |
"-ab", "1", "-ad", "350", }; |
105 |
greg |
1.40 |
106 |
greg |
1.13 |
int rtargc = 9; |
107 |
greg |
1.1 |
/* overriding rtrace options */ |
108 |
greg |
1.40 |
char *myrtopts[] = { "-h-", "-x", "1", "-y", "0", |
109 |
greg |
1.6 |
"-dt", "0", "-as", "0", "-aa", "0", NULL }; |
110 |
greg |
1.1 |
111 |
greg |
1.40 |
#define RTCOEFF "-o~~TmWdp" /* compute coefficients only */ |
112 |
#define RTCONTRIB "-o~~TmVdp" /* compute ray contributions */ |
113 |
114 |
greg |
1.1 |
struct rtproc rt0; /* head of rtrace process list */ |
115 |
116 |
struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */ |
117 |
118 |
char persistfn[] = "pfXXXXXX"; /* persist file name */ |
119 |
120 |
int gargc; /* global argc */ |
121 |
char **gargv; /* global argv */ |
122 |
#define progname gargv[0] |
123 |
124 |
char *octree; /* global octree argument */ |
125 |
126 |
int inpfmt = 'a'; /* input format */ |
127 |
int outfmt = 'a'; /* output format */ |
128 |
129 |
int header = 1; /* output header? */ |
130 |
greg |
1.35 |
int force_open = 0; /* truncate existing output? */ |
131 |
greg |
1.1 |
int xres = 0; /* horiz. output resolution */ |
132 |
int yres = 0; /* vert. output resolution */ |
133 |
134 |
greg |
1.14 |
unsigned long raysleft; /* number of rays left to trace */ |
135 |
greg |
1.1 |
long waitflush; /* how long until next flush */ |
136 |
137 |
unsigned long lastray = 0; /* last ray number sent */ |
138 |
unsigned long lastdone = 0; /* last ray processed */ |
139 |
140 |
greg |
1.2 |
int using_stdout = 0; /* are we using stdout? */ |
141 |
142 |
greg |
1.1 |
const char *modname[MAXMODLIST]; /* ordered modifier name list */ |
143 |
int nmods = 0; /* number of modifiers */ |
144 |
145 |
greg |
1.29 |
#define queue_length() (lastray - lastdone) |
146 |
147 |
greg |
1.31 |
MODCONT *growmodifier(MODCONT *mp, int nb); |
148 |
MODCONT *addmodifier(char *modn, char *outf, char *binv, int bincnt); |
149 |
void addmodfile(char *fname, char *outf, char *binv, int bincnt); |
150 |
greg |
1.1 |
151 |
greg |
1.5 |
void init(int np); |
152 |
greg |
1.1 |
int done_rprocs(struct rtproc *rtp); |
153 |
greg |
1.14 |
void recover_output(FILE *fin); |
154 |
void trace_contribs(FILE *fin); |
155 |
greg |
1.1 |
struct rtproc *wait_rproc(void); |
156 |
struct rtproc *get_rproc(void); |
157 |
greg |
1.3 |
void queue_raytree(struct rtproc *rtp); |
158 |
void process_queue(void); |
159 |
greg |
1.1 |
160 |
greg |
1.14 |
void put_contrib(const DCOLOR cnt, FILE *fout); |
161 |
greg |
1.2 |
void add_contrib(const char *modn); |
162 |
greg |
1.1 |
void done_contrib(void); |
163 |
164 |
greg |
1.29 |
/* return number of open rtrace processes */ |
165 |
static int |
166 |
nrtprocs(void) |
167 |
168 |
int nrtp = 0; |
169 |
struct rtproc *rtp; |
170 |
171 |
for (rtp = &rt0; rtp != NULL; rtp = rtp->next) |
172 |
nrtp += rtp->pd.running; |
173 |
return(nrtp); |
174 |
175 |
176 |
greg |
1.1 |
/* set input/output format */ |
177 |
static void |
178 |
setformat(const char *fmt) |
179 |
180 |
switch (fmt[0]) { |
181 |
case 'f': |
182 |
case 'd': |
183 |
greg |
1.10 |
SET_FILE_BINARY(stdin); |
184 |
/* fall through */ |
185 |
case 'a': |
186 |
greg |
1.1 |
inpfmt = fmt[0]; |
187 |
break; |
188 |
default: |
189 |
goto fmterr; |
190 |
191 |
switch (fmt[1]) { |
192 |
case '\0': |
193 |
outfmt = inpfmt; |
194 |
return; |
195 |
case 'a': |
196 |
case 'f': |
197 |
case 'd': |
198 |
case 'c': |
199 |
outfmt = fmt[1]; |
200 |
break; |
201 |
default: |
202 |
goto fmterr; |
203 |
204 |
if (!fmt[2]) |
205 |
return; |
206 |
fmterr: |
207 |
sprintf(errmsg, "Illegal i/o format: -f%s", fmt); |
208 |
error(USER, errmsg); |
209 |
210 |
211 |
/* gather rays from rtrace and output contributions */ |
212 |
int |
213 |
main(int argc, char *argv[]) |
214 |
215 |
greg |
1.40 |
int contrib = 0; |
216 |
greg |
1.1 |
int nprocs = 1; |
217 |
greg |
1.14 |
int recover = 0; |
218 |
greg |
1.1 |
char *curout = NULL; |
219 |
char *binval = NULL; |
220 |
greg |
1.31 |
int bincnt = 0; |
221 |
greg |
1.5 |
char fmt[8]; |
222 |
greg |
1.2 |
int i, j; |
223 |
greg |
1.25 |
/* need at least one argument */ |
224 |
if (argc < 2) { |
225 |
fprintf(stderr, |
226 |
greg |
1.40 |
"Usage: %s [-n nprocs][-V][-r][-e expr][-f source][-o ospec][-b binv] {-m mod | -M file} [rtrace options] octree\n", |
227 |
greg |
1.25 |
argv[0]); |
228 |
exit(1); |
229 |
230 |
greg |
1.2 |
/* global program name */ |
231 |
greg |
1.1 |
gargv = argv; |
232 |
greg |
1.11 |
/* initialize calcomp routines */ |
233 |
greg |
1.1 |
esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW; |
234 |
esupport &= ~(E_OUTCHAN); |
235 |
greg |
1.11 |
varset("PI", ':', PI); |
236 |
greg |
1.1 |
/* get our options */ |
237 |
greg |
1.2 |
for (i = 1; i < argc-1; i++) { |
238 |
/* expand arguments */ |
239 |
while ((j = expandarg(&argc, &argv, i)) > 0) |
240 |
241 |
if (j < 0) { |
242 |
fprintf(stderr, "%s: cannot expand '%s'", |
243 |
argv[0], argv[i]); |
244 |
exit(1); |
245 |
246 |
if (argv[i][0] == '-') |
247 |
switch (argv[i][1]) { |
248 |
case 'n': /* number of processes */ |
249 |
greg |
1.21 |
if (argv[i][2] || i >= argc-2) break; |
250 |
greg |
1.2 |
nprocs = atoi(argv[++i]); |
251 |
if (nprocs <= 0) |
252 |
error(USER, "illegal number of processes"); |
253 |
continue; |
254 |
greg |
1.40 |
case 'V': /* output contributions */ |
255 |
switch (argv[i][2]) { |
256 |
case '\0': |
257 |
contrib = !contrib; |
258 |
continue; |
259 |
case '+': case '1': |
260 |
case 'T': case 't': |
261 |
case 'Y': case 'y': |
262 |
contrib = 1; |
263 |
continue; |
264 |
case '-': case '0': |
265 |
case 'F': case 'f': |
266 |
case 'N': case 'n': |
267 |
contrib = 0; |
268 |
continue; |
269 |
270 |
break; |
271 |
case 'r': /* recover output */ |
272 |
if (argv[i][2]) break; |
273 |
recover++; |
274 |
continue; |
275 |
greg |
1.2 |
case 'h': /* output header? */ |
276 |
277 |
case '\0': |
278 |
header = !header; |
279 |
continue; |
280 |
greg |
1.3 |
281 |
282 |
283 |
greg |
1.2 |
header = 1; |
284 |
continue; |
285 |
greg |
1.3 |
286 |
287 |
288 |
greg |
1.2 |
header = 0; |
289 |
continue; |
290 |
291 |
break; |
292 |
greg |
1.35 |
case 'f': /* file or force or format */ |
293 |
greg |
1.2 |
if (!argv[i][2]) { |
294 |
greg |
1.9 |
char *fpath; |
295 |
greg |
1.21 |
if (i >= argc-2) break; |
296 |
greg |
1.9 |
fpath = getpath(argv[++i], |
297 |
getrlibpath(), R_OK); |
298 |
if (fpath == NULL) { |
299 |
sprintf(errmsg, |
300 |
"cannot find file '%s'", |
301 |
argv[i]); |
302 |
303 |
304 |
fcompile(fpath); |
305 |
greg |
1.2 |
continue; |
306 |
307 |
greg |
1.35 |
if (argv[i][2] == 'o') { |
308 |
force_open++; |
309 |
continue; |
310 |
311 |
greg |
1.2 |
setformat(argv[i]+2); |
312 |
continue; |
313 |
case 'e': /* expression */ |
314 |
greg |
1.21 |
315 |
greg |
1.2 |
scompile(argv[++i], NULL, 0); |
316 |
greg |
1.1 |
continue; |
317 |
greg |
1.2 |
case 'o': /* output file spec. */ |
318 |
greg |
1.21 |
319 |
greg |
1.2 |
curout = argv[++i]; |
320 |
greg |
1.1 |
continue; |
321 |
greg |
1.2 |
case 'x': /* horiz. output resolution */ |
322 |
greg |
1.21 |
323 |
greg |
1.2 |
xres = atoi(argv[++i]); |
324 |
greg |
1.1 |
continue; |
325 |
greg |
1.2 |
case 'y': /* vert. output resolution */ |
326 |
greg |
1.21 |
327 |
greg |
1.2 |
yres = atoi(argv[++i]); |
328 |
continue; |
329 |
greg |
1.31 |
case 'b': /* bin expression/count */ |
330 |
331 |
if (argv[i][2] == 'n') { |
332 |
bincnt = atoi(argv[++i]); |
333 |
continue; |
334 |
335 |
336 |
greg |
1.2 |
binval = argv[++i]; |
337 |
continue; |
338 |
case 'm': /* modifier name */ |
339 |
greg |
1.21 |
340 |
greg |
1.2 |
rtargv[rtargc++] = "-ti"; |
341 |
rtargv[rtargc++] = argv[++i]; |
342 |
greg |
1.31 |
addmodifier(argv[i], curout, binval, bincnt); |
343 |
greg |
1.1 |
continue; |
344 |
greg |
1.17 |
case 'M': /* modifier file */ |
345 |
greg |
1.21 |
346 |
greg |
1.19 |
rtargv[rtargc++] = "-tI"; |
347 |
348 |
greg |
1.31 |
addmodfile(argv[i], curout, binval, bincnt); |
349 |
greg |
1.17 |
continue; |
350 |
greg |
1.39 |
case 'P': /* persist file */ |
351 |
error(USER, "persist file is automatic"); |
352 |
break; |
353 |
greg |
1.1 |
354 |
greg |
1.2 |
rtargv[rtargc++] = argv[i]; /* assume rtrace option */ |
355 |
greg |
1.1 |
356 |
greg |
1.2 |
/* set global argument list */ |
357 |
gargc = argc; gargv = argv; |
358 |
greg |
1.1 |
/* add "mandatory" rtrace settings */ |
359 |
greg |
1.2 |
for (j = 0; myrtopts[j] != NULL; j++) |
360 |
rtargv[rtargc++] = myrtopts[j]; |
361 |
greg |
1.40 |
rtargv[rtargc++] = contrib ? RTCONTRIB : RTCOEFF; |
362 |
greg |
1.2 |
/* just asking for defaults? */ |
363 |
if (!strcmp(argv[i], "-defaults")) { |
364 |
greg |
1.1 |
char sxres[16], syres[16]; |
365 |
char *rtpath; |
366 |
greg |
1.2 |
printf("-n %-2d\t\t\t\t# number of processes\n", nprocs); |
367 |
greg |
1.40 |
printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-', |
368 |
contrib ? "contributions" : "coefficients"); |
369 |
greg |
1.1 |
fflush(stdout); /* report OUR options */ |
370 |
rtargv[rtargc++] = header ? "-h+" : "-h-"; |
371 |
sprintf(fmt, "-f%c%c", inpfmt, outfmt); |
372 |
rtargv[rtargc++] = fmt; |
373 |
rtargv[rtargc++] = "-x"; |
374 |
sprintf(sxres, "%d", xres); |
375 |
rtargv[rtargc++] = sxres; |
376 |
rtargv[rtargc++] = "-y"; |
377 |
sprintf(syres, "%d", yres); |
378 |
rtargv[rtargc++] = syres; |
379 |
rtargv[rtargc++] = "-defaults"; |
380 |
rtargv[rtargc] = NULL; |
381 |
rtpath = getpath(rtargv[0], getenv("PATH"), X_OK); |
382 |
if (rtpath == NULL) { |
383 |
eputs(rtargv[0]); |
384 |
eputs(": command not found\n"); |
385 |
exit(1); |
386 |
387 |
execv(rtpath, rtargv); |
388 |
perror(rtpath); /* execv() should not return */ |
389 |
exit(1); |
390 |
greg |
1.5 |
391 |
if (nprocs > 1) { /* add persist file if parallel */ |
392 |
greg |
1.2 |
rtargv[rtargc++] = "-PP"; |
393 |
rtargv[rtargc++] = mktemp(persistfn); |
394 |
395 |
greg |
1.1 |
/* add format string */ |
396 |
sprintf(fmt, "-f%cf", inpfmt); |
397 |
398 |
/* octree argument is last */ |
399 |
greg |
1.2 |
if (i <= 0 || i != argc-1 || argv[i][0] == '-') |
400 |
error(USER, "missing octree argument"); |
401 |
rtargv[rtargc++] = octree = argv[i]; |
402 |
greg |
1.1 |
403 |
greg |
1.24 |
/* start rtrace */ |
404 |
greg |
1.1 |
init(nprocs); |
405 |
greg |
1.14 |
if (recover) /* perform recovery if requested */ |
406 |
recover_output(stdin); |
407 |
greg |
1.24 |
trace_contribs(stdin); /* compute contributions */ |
408 |
greg |
1.1 |
quit(0); |
409 |
410 |
411 |
schorsch |
1.26 |
#ifndef SIGALRM |
412 |
#define SIGALRM SIGTERM |
413 |
#endif |
414 |
greg |
1.1 |
/* kill persistent rtrace process */ |
415 |
static void |
416 |
killpersist(void) |
417 |
418 |
FILE *fp = fopen(persistfn, "r"); |
419 |
schorsch |
1.26 |
RT_PID pid; |
420 |
greg |
1.1 |
421 |
if (fp == NULL) |
422 |
return; |
423 |
if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0) |
424 |
unlink(persistfn); |
425 |
fclose(fp); |
426 |
427 |
428 |
/* close rtrace processes and clean up */ |
429 |
int |
430 |
done_rprocs(struct rtproc *rtp) |
431 |
432 |
int st0, st1 = 0; |
433 |
434 |
if (rtp->next != NULL) { /* close last opened first! */ |
435 |
st1 = done_rprocs(rtp->next); |
436 |
free((void *)rtp->next); |
437 |
rtp->next = NULL; |
438 |
439 |
st0 = close_process(&rtp->pd); |
440 |
if (st0 < 0) |
441 |
error(WARNING, "unknown return status from rtrace process"); |
442 |
else if (st0 > 0) |
443 |
return(st0); |
444 |
return(st1); |
445 |
446 |
447 |
/* exit with status */ |
448 |
void |
449 |
quit(int status) |
450 |
451 |
int rtstat; |
452 |
453 |
if (rt0.next != NULL) /* terminate persistent rtrace */ |
454 |
killpersist(); |
455 |
/* clean up rtrace process(es) */ |
456 |
rtstat = done_rprocs(&rt0); |
457 |
if (status == 0) |
458 |
status = rtstat; |
459 |
exit(status); /* flushes all output streams */ |
460 |
461 |
462 |
greg |
1.5 |
/* start rtrace processes and initialize */ |
463 |
greg |
1.1 |
void |
464 |
init(int np) |
465 |
466 |
467 |
int i; |
468 |
int maxbytes; |
469 |
greg |
1.2 |
/* make sure we have something to do */ |
470 |
if (!nmods) |
471 |
error(USER, "No modifiers specified"); |
472 |
greg |
1.1 |
/* assign ray variables */ |
473 |
scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0); |
474 |
scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0); |
475 |
/* set up signal handling */ |
476 |
greg |
1.3 |
signal(SIGINT, quit); |
477 |
#ifdef SIGHUP |
478 |
signal(SIGHUP, quit); |
479 |
#endif |
480 |
#ifdef SIGTERM |
481 |
signal(SIGTERM, quit); |
482 |
#endif |
483 |
#ifdef SIGPIPE |
484 |
greg |
1.1 |
signal(SIGPIPE, quit); |
485 |
#endif |
486 |
rtp = &rt0; /* start rtrace process(es) */ |
487 |
for (i = 0; i++ < np; ) { |
488 |
errno = 0; |
489 |
maxbytes = open_process(&rtp->pd, rtargv); |
490 |
if (maxbytes == 0) { |
491 |
eputs(rtargv[0]); |
492 |
493 |
exit(1); |
494 |
495 |
if (maxbytes < 0) |
496 |
error(SYSTEM, "cannot start rtrace process"); |
497 |
if (maxbytes > treebufsiz) |
498 |
treebufsiz = maxbytes; |
499 |
greg |
1.2 |
rtp->raynum = 0; |
500 |
greg |
1.1 |
rtp->bsiz = 0; |
501 |
rtp->buf = NULL; |
502 |
greg |
1.2 |
rtp->nbr = 0; |
503 |
greg |
1.1 |
if (i == np) /* last process? */ |
504 |
break; |
505 |
if (i == 1) |
506 |
sleep(2); /* wait for persist file */ |
507 |
rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc)); |
508 |
if (rtp->next == NULL) |
509 |
error(SYSTEM, "out of memory in init"); |
510 |
rtp = rtp->next; |
511 |
512 |
rtp->next = NULL; /* terminate list */ |
513 |
if (yres > 0) { |
514 |
if (xres > 0) |
515 |
greg |
1.14 |
raysleft = (unsigned long)xres*yres; |
516 |
greg |
1.1 |
else |
517 |
raysleft = yres; |
518 |
} else |
519 |
raysleft = 0; |
520 |
waitflush = xres; |
521 |
522 |
523 |
greg |
1.31 |
/* grow modifier to accommodate more bins */ |
524 |
MODCONT * |
525 |
growmodifier(MODCONT *mp, int nb) |
526 |
527 |
if (nb <= mp->nbins) |
528 |
return mp; |
529 |
mp = (MODCONT *)realloc(mp, sizeof(MODCONT) + sizeof(DCOLOR)*(nb-1)); |
530 |
if (mp == NULL) |
531 |
error(SYSTEM, "out of memory in growmodifier"); |
532 |
memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(nb-mp->nbins)); |
533 |
mp->nbins = nb; |
534 |
return mp; |
535 |
536 |
537 |
greg |
1.1 |
/* add modifier to our list to track */ |
538 |
MODCONT * |
539 |
greg |
1.31 |
addmodifier(char *modn, char *outf, char *binv, int bincnt) |
540 |
greg |
1.1 |
541 |
LUENT *lep = lu_find(&modconttab, modn); |
542 |
MODCONT *mp; |
543 |
greg |
1.32 |
int i; |
544 |
greg |
1.1 |
545 |
if (lep->data != NULL) { |
546 |
sprintf(errmsg, "duplicate modifier '%s'", modn); |
547 |
548 |
549 |
if (nmods >= MAXMODLIST) |
550 |
error(USER, "too many modifiers"); |
551 |
modname[nmods++] = modn; /* XXX assumes static string */ |
552 |
lep->key = modn; /* XXX assumes static string */ |
553 |
mp = (MODCONT *)malloc(sizeof(MODCONT)); |
554 |
if (mp == NULL) |
555 |
error(SYSTEM, "out of memory in addmodifier"); |
556 |
mp->outspec = outf; /* XXX assumes static string */ |
557 |
mp->modname = modn; /* XXX assumes static string */ |
558 |
if (binv != NULL) |
559 |
mp->binv = eparse(binv); |
560 |
else |
561 |
mp->binv = eparse("0"); |
562 |
mp->nbins = 1; |
563 |
setcolor(mp->cbin[0], 0., 0., 0.); |
564 |
greg |
1.31 |
if (mp->binv->type == NUM) /* assume one bin if constant */ |
565 |
bincnt = 1; |
566 |
else if (bincnt > 1) |
567 |
mp = growmodifier(mp, bincnt); |
568 |
greg |
1.32 |
lep->data = (char *)mp; |
569 |
/* allocate output streams */ |
570 |
greg |
1.41 |
for (i = outf==NULL || outf[0]=='!' ? 0 : bincnt; i-- > 0; ) |
571 |
greg |
1.32 |
getostream(mp->outspec, mp->modname, i, 1); |
572 |
greg |
1.1 |
return mp; |
573 |
574 |
575 |
greg |
1.17 |
/* add modifiers from a file list */ |
576 |
void |
577 |
greg |
1.31 |
addmodfile(char *fname, char *outf, char *binv, int bincnt) |
578 |
greg |
1.17 |
579 |
char *mname[MAXMODLIST]; |
580 |
int i; |
581 |
greg |
1.20 |
/* find the file & store strings */ |
582 |
if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) { |
583 |
sprintf(errmsg, "cannot find modifier file '%s'", fname); |
584 |
error(SYSTEM, errmsg); |
585 |
586 |
greg |
1.17 |
for (i = 0; mname[i]; i++) /* add each one */ |
587 |
greg |
1.31 |
addmodifier(mname[i], outf, binv, bincnt); |
588 |
greg |
1.17 |
589 |
590 |
greg |
1.1 |
/* put string to stderr */ |
591 |
void |
592 |
eputs(char *s) |
593 |
594 |
static int midline = 0; |
595 |
596 |
if (!*s) return; |
597 |
if (!midline) { |
598 |
fputs(progname, stderr); |
599 |
fputs(": ", stderr); |
600 |
601 |
fputs(s, stderr); |
602 |
midline = s[strlen(s)-1] != '\n'; |
603 |
604 |
605 |
greg |
1.14 |
/* construct output file name and return flags whether modifier/bin present */ |
606 |
int |
607 |
ofname(char *oname, const char *ospec, const char *mname, int bn) |
608 |
609 |
const char *mnp = NULL; |
610 |
const char *bnp = NULL; |
611 |
const char *cp; |
612 |
613 |
if (ospec == NULL) |
614 |
return -1; |
615 |
for (cp = ospec; *cp; cp++) /* check format position(s) */ |
616 |
if (*cp == '%') { |
617 |
do |
618 |
++cp; |
619 |
while (isdigit(*cp)); |
620 |
switch (*cp) { |
621 |
case '%': |
622 |
break; |
623 |
case 's': |
624 |
if (mnp != NULL) |
625 |
return -1; |
626 |
mnp = cp; |
627 |
break; |
628 |
case 'd': |
629 |
if (bnp != NULL) |
630 |
return -1; |
631 |
bnp = cp; |
632 |
break; |
633 |
default: |
634 |
return -1; |
635 |
636 |
637 |
if (mnp != NULL) { /* create file name */ |
638 |
if (bnp != NULL) { |
639 |
if (bnp > mnp) |
640 |
sprintf(oname, ospec, mname, bn); |
641 |
else |
642 |
sprintf(oname, ospec, bn, mname); |
643 |
return OF_MODIFIER|OF_BIN; |
644 |
645 |
sprintf(oname, ospec, mname); |
646 |
return OF_MODIFIER; |
647 |
648 |
649 |
sprintf(oname, ospec, bn); |
650 |
return OF_BIN; |
651 |
652 |
strcpy(oname, ospec); |
653 |
return 0; |
654 |
655 |
656 |
greg |
1.1 |
/* write header to the given output stream */ |
657 |
void |
658 |
greg |
1.14 |
printheader(FILE *fout, const char *info) |
659 |
greg |
1.1 |
660 |
extern char VersionID[]; |
661 |
FILE *fin = fopen(octree, "r"); |
662 |
663 |
if (fin == NULL) |
664 |
quit(1); |
665 |
greg |
1.2 |
checkheader(fin, "ignore", fout); /* copy octree header */ |
666 |
greg |
1.1 |
fclose(fin); |
667 |
printargs(gargc-1, gargv, fout); /* add our command */ |
668 |
fprintf(fout, "SOFTWARE= %s\n", VersionID); |
669 |
fputnow(fout); |
670 |
greg |
1.14 |
if (info != NULL) /* add extra info if given */ |
671 |
fputs(info, fout); |
672 |
greg |
1.1 |
switch (outfmt) { /* add output format */ |
673 |
case 'a': |
674 |
fputformat("ascii", fout); |
675 |
break; |
676 |
case 'f': |
677 |
fputformat("float", fout); |
678 |
break; |
679 |
case 'd': |
680 |
fputformat("double", fout); |
681 |
break; |
682 |
case 'c': |
683 |
fputformat(COLRFMT, fout); |
684 |
break; |
685 |
686 |
fputc('\n', fout); |
687 |
greg |
1.30 |
688 |
689 |
/* write resolution string to given output stream */ |
690 |
void |
691 |
printresolu(FILE *fout) |
692 |
693 |
greg |
1.1 |
if (xres > 0) { |
694 |
if (yres > 0) /* resolution string */ |
695 |
fprtresolu(xres, yres, fout); |
696 |
fflush(fout); |
697 |
698 |
699 |
700 |
greg |
1.32 |
/* Get output stream pointer (open and write header if new and noopen==0) */ |
701 |
greg |
1.31 |
STREAMOUT * |
702 |
greg |
1.32 |
getostream(const char *ospec, const char *mname, int bn, int noopen) |
703 |
greg |
1.31 |
704 |
static STREAMOUT stdos; |
705 |
int ofl; |
706 |
char oname[1024]; |
707 |
LUENT *lep; |
708 |
STREAMOUT *sop; |
709 |
greg |
1.1 |
710 |
if (ospec == NULL) { /* use stdout? */ |
711 |
greg |
1.32 |
if (!noopen && !using_stdout) { |
712 |
greg |
1.31 |
stdos.reclen = 0; |
713 |
greg |
1.10 |
if (outfmt != 'a') |
714 |
SET_FILE_BINARY(stdout); |
715 |
if (header) |
716 |
greg |
1.14 |
printheader(stdout, NULL); |
717 |
greg |
1.30 |
printresolu(stdout); |
718 |
greg |
1.31 |
using_stdout = 1; |
719 |
greg |
1.10 |
720 |
greg |
1.31 |
stdos.ofp = stdout; |
721 |
greg |
1.32 |
stdos.reclen += noopen; |
722 |
greg |
1.31 |
return &stdos; |
723 |
greg |
1.1 |
724 |
greg |
1.14 |
ofl = ofname(oname, ospec, mname, bn); /* get output name */ |
725 |
if (ofl < 0) { |
726 |
sprintf(errmsg, "bad output format '%s'", ospec); |
727 |
728 |
729 |
lep = lu_find(&ofiletab, oname); /* look it up */ |
730 |
greg |
1.1 |
if (lep->key == NULL) /* new entry */ |
731 |
greg |
1.14 |
lep->key = strcpy((char *)malloc(strlen(oname)+1), oname); |
732 |
greg |
1.31 |
sop = (STREAMOUT *)lep->data; |
733 |
if (sop == NULL) { /* allocate stream */ |
734 |
sop = (STREAMOUT *)malloc(sizeof(STREAMOUT)); |
735 |
if (sop == NULL) |
736 |
error(SYSTEM, "out of memory in getostream"); |
737 |
greg |
1.34 |
sop->reclen = oname[0] == '!' ? CNT_PIPE : CNT_UNKNOWN; |
738 |
greg |
1.32 |
sop->ofp = NULL; /* open iff noopen==0 */ |
739 |
greg |
1.31 |
lep->data = (char *)sop; |
740 |
741 |
greg |
1.32 |
if (!noopen && sop->ofp == NULL) { /* open output stream */ |
742 |
greg |
1.34 |
long i; |
743 |
greg |
1.14 |
if (oname[0] == '!') /* output to command */ |
744 |
greg |
1.31 |
sop->ofp = popen(oname+1, "w"); |
745 |
greg |
1.35 |
else if (!force_open && access(oname, F_OK) == 0) |
746 |
errno = EEXIST; /* file exists */ |
747 |
else /* else open it */ |
748 |
greg |
1.31 |
sop->ofp = fopen(oname, "w"); |
749 |
if (sop->ofp == NULL) { |
750 |
greg |
1.14 |
sprintf(errmsg, "cannot open '%s' for writing", oname); |
751 |
greg |
1.1 |
752 |
753 |
greg |
1.10 |
754 |
greg |
1.31 |
SET_FILE_BINARY(sop->ofp); |
755 |
greg |
1.14 |
if (header) { |
756 |
char info[512]; |
757 |
char *cp = info; |
758 |
greg |
1.32 |
if (ofl & OF_MODIFIER || sop->reclen == 1) { |
759 |
greg |
1.30 |
sprintf(cp, "MODIFIER=%s\n", mname); |
760 |
while (*cp) ++cp; |
761 |
762 |
greg |
1.14 |
if (ofl & OF_BIN) { |
763 |
sprintf(cp, "BIN=%d\n", bn); |
764 |
while (*cp) ++cp; |
765 |
766 |
*cp = '\0'; |
767 |
greg |
1.31 |
printheader(sop->ofp, info); |
768 |
greg |
1.14 |
769 |
greg |
1.31 |
printresolu(sop->ofp); |
770 |
greg |
1.2 |
/* play catch-up */ |
771 |
greg |
1.34 |
for (i = sop->reclen > 1 ? sop->reclen*lastdone : lastdone; |
772 |
i--; ) { |
773 |
greg |
1.2 |
static const DCOLOR nocontrib = BLKCOLOR; |
774 |
greg |
1.31 |
put_contrib(nocontrib, sop->ofp); |
775 |
greg |
1.2 |
if (outfmt == 'a') |
776 |
greg |
1.31 |
putc('\n', sop->ofp); |
777 |
greg |
1.2 |
778 |
if (xres > 0) |
779 |
greg |
1.31 |
fflush(sop->ofp); |
780 |
greg |
1.1 |
781 |
greg |
1.32 |
if (sop->reclen != CNT_PIPE) /* add to length if noopen */ |
782 |
sop->reclen += noopen; |
783 |
greg |
1.31 |
return sop; /* return open stream */ |
784 |
greg |
1.1 |
785 |
786 |
/* read input ray into buffer */ |
787 |
int |
788 |
getinp(char *buf, FILE *fp) |
789 |
790 |
greg |
1.36 |
double dv[3]; |
791 |
float fv[3]; |
792 |
greg |
1.4 |
char *cp; |
793 |
int i; |
794 |
795 |
greg |
1.1 |
switch (inpfmt) { |
796 |
case 'a': |
797 |
greg |
1.4 |
cp = buf; /* make sure we get 6 floats */ |
798 |
for (i = 0; i < 6; i++) { |
799 |
if (fgetword(cp, buf+127-cp, fp) == NULL) |
800 |
greg |
1.36 |
return -1; |
801 |
if (i >= 3) |
802 |
dv[i-3] = atof(cp); |
803 |
greg |
1.4 |
if ((cp = fskip(cp)) == NULL || *cp) |
804 |
greg |
1.36 |
return -1; |
805 |
greg |
1.4 |
*cp++ = ' '; |
806 |
807 |
getc(fp); /* get/put eol */ |
808 |
*cp-- = '\0'; *cp = '\n'; |
809 |
greg |
1.36 |
if (DOT(dv,dv) <= FTINY*FTINY) |
810 |
return 0; /* dummy ray */ |
811 |
greg |
1.1 |
return strlen(buf); |
812 |
case 'f': |
813 |
if (fread(buf, sizeof(float), 6, fp) < 6) |
814 |
greg |
1.36 |
return -1; |
815 |
memcpy(fv, buf+3*sizeof(float), 3*sizeof(float)); |
816 |
if (DOT(fv,fv) <= FTINY*FTINY) |
817 |
818 |
greg |
1.1 |
return sizeof(float)*6; |
819 |
case 'd': |
820 |
if (fread(buf, sizeof(double), 6, fp) < 6) |
821 |
greg |
1.36 |
return -1; |
822 |
memcpy(dv, buf+3*sizeof(double), 3*sizeof(double)); |
823 |
824 |
825 |
greg |
1.1 |
return sizeof(double)*6; |
826 |
827 |
error(INTERNAL, "botched input format"); |
828 |
greg |
1.36 |
return -1; /* pro forma return */ |
829 |
greg |
1.1 |
830 |
831 |
greg |
1.2 |
static float rparams[9]; /* traced ray parameters */ |
832 |
greg |
1.1 |
833 |
/* return channel (ray) value */ |
834 |
double |
835 |
chanvalue(int n) |
836 |
837 |
if (--n < 0 || n >= 6) |
838 |
error(USER, "illegal channel number ($N)"); |
839 |
greg |
1.2 |
return rparams[n+3]; |
840 |
greg |
1.1 |
841 |
842 |
greg |
1.2 |
/* add current ray contribution to the appropriate modifier bin */ |
843 |
greg |
1.1 |
void |
844 |
greg |
1.2 |
add_contrib(const char *modn) |
845 |
greg |
1.1 |
846 |
LUENT *le = lu_find(&modconttab, modn); |
847 |
MODCONT *mp = (MODCONT *)le->data; |
848 |
int bn; |
849 |
850 |
if (mp == NULL) { |
851 |
sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn); |
852 |
853 |
854 |
greg |
1.2 |
eclock++; /* get bin number */ |
855 |
greg |
1.1 |
bn = (int)(evalue(mp->binv) + .5); |
856 |
if (bn <= 0) |
857 |
bn = 0; |
858 |
greg |
1.31 |
else if (bn >= mp->nbins) /* new bin */ |
859 |
le->data = (char *)(mp = growmodifier(mp, bn+1)); |
860 |
greg |
1.2 |
addcolor(mp->cbin[bn], rparams); |
861 |
greg |
1.1 |
862 |
863 |
/* output newline to ASCII file and/or flush as requested */ |
864 |
static int |
865 |
puteol(const LUENT *e, void *p) |
866 |
867 |
greg |
1.31 |
STREAMOUT *sop = (STREAMOUT *)e->data; |
868 |
greg |
1.1 |
869 |
870 |
greg |
1.31 |
871 |
greg |
1.1 |
if (!waitflush) |
872 |
greg |
1.31 |
fflush(sop->ofp); |
873 |
if (ferror(sop->ofp)) { |
874 |
greg |
1.1 |
sprintf(errmsg, "write error on file '%s'", e->key); |
875 |
876 |
877 |
return 0; |
878 |
879 |
880 |
greg |
1.2 |
/* put out ray contribution to file */ |
881 |
void |
882 |
greg |
1.14 |
put_contrib(const DCOLOR cnt, FILE *fout) |
883 |
greg |
1.2 |
884 |
float fv[3]; |
885 |
COLR cv; |
886 |
887 |
switch (outfmt) { |
888 |
case 'a': |
889 |
fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]); |
890 |
break; |
891 |
case 'f': |
892 |
fv[0] = cnt[0]; |
893 |
fv[1] = cnt[1]; |
894 |
fv[2] = cnt[2]; |
895 |
fwrite(fv, sizeof(float), 3, fout); |
896 |
break; |
897 |
case 'd': |
898 |
fwrite(cnt, sizeof(double), 3, fout); |
899 |
break; |
900 |
case 'c': |
901 |
setcolr(cv, cnt[0], cnt[1], cnt[2]); |
902 |
fwrite(cv, sizeof(cv), 1, fout); |
903 |
break; |
904 |
default: |
905 |
error(INTERNAL, "botched output format"); |
906 |
907 |
908 |
909 |
greg |
1.1 |
/* output ray tallies and clear for next primary */ |
910 |
void |
911 |
done_contrib(void) |
912 |
913 |
greg |
1.31 |
int i, j; |
914 |
MODCONT *mp; |
915 |
STREAMOUT *sop; |
916 |
greg |
1.1 |
/* output modifiers in order */ |
917 |
for (i = 0; i < nmods; i++) { |
918 |
mp = (MODCONT *)lu_find(&modconttab,modname[i])->data; |
919 |
greg |
1.31 |
sop = getostream(mp->outspec, mp->modname, 0,0); |
920 |
put_contrib(mp->cbin[0], sop->ofp); |
921 |
greg |
1.12 |
if (mp->nbins > 3 && /* minor optimization */ |
922 |
greg |
1.31 |
sop == getostream(mp->outspec, mp->modname, 1,0)) |
923 |
greg |
1.12 |
for (j = 1; j < mp->nbins; j++) |
924 |
greg |
1.31 |
put_contrib(mp->cbin[j], sop->ofp); |
925 |
greg |
1.12 |
else |
926 |
927 |
greg |
1.14 |
put_contrib(mp->cbin[j], |
928 |
greg |
1.31 |
getostream(mp->outspec,mp->modname,j,0)->ofp); |
929 |
greg |
1.1 |
/* clear for next ray tree */ |
930 |
greg |
1.2 |
memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins); |
931 |
greg |
1.1 |
932 |
--waitflush; /* terminate records */ |
933 |
lu_doall(&ofiletab, puteol, NULL); |
934 |
greg |
1.2 |
if (using_stdout & (outfmt == 'a')) |
935 |
putc('\n', stdout); |
936 |
if (!waitflush) { |
937 |
greg |
1.1 |
waitflush = xres; |
938 |
greg |
1.2 |
if (using_stdout) |
939 |
fflush(stdout); |
940 |
941 |
greg |
1.1 |
942 |
943 |
greg |
1.3 |
/* queue completed ray tree produced by rtrace process */ |
944 |
void |
945 |
queue_raytree(struct rtproc *rtp) |
946 |
947 |
struct rtproc *rtu, *rtl = NULL; |
948 |
/* insert following ray order */ |
949 |
for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next) |
950 |
if (rtp->raynum < rtu->raynum) |
951 |
break; |
952 |
rtu = (struct rtproc *)malloc(sizeof(struct rtproc)); |
953 |
if (rtu == NULL) |
954 |
error(SYSTEM, "out of memory in queue_raytree"); |
955 |
*rtu = *rtp; |
956 |
if (rtl == NULL) { |
957 |
rtu->next = rt_unproc; |
958 |
rt_unproc = rtu; |
959 |
} else { |
960 |
rtu->next = rtl->next; |
961 |
rtl->next = rtu; |
962 |
963 |
rtp->raynum = 0; /* clear path for next ray tree */ |
964 |
rtp->bsiz = 0; |
965 |
rtp->buf = NULL; |
966 |
rtp->nbr = 0; |
967 |
968 |
969 |
/* process completed ray trees from our queue */ |
970 |
greg |
1.1 |
void |
971 |
greg |
1.3 |
process_queue(void) |
972 |
greg |
1.1 |
973 |
greg |
1.3 |
char modname[128]; |
974 |
/* ray-ordered queue */ |
975 |
while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) { |
976 |
struct rtproc *rtp = rt_unproc; |
977 |
greg |
1.2 |
int n = rtp->nbr; |
978 |
greg |
1.1 |
const char *cp = rtp->buf; |
979 |
while (n > 0) { /* process rays */ |
980 |
greg |
1.2 |
register char *mnp = modname; |
981 |
greg |
1.1 |
/* skip leading tabs */ |
982 |
while (n > 0 && *cp == '\t') { |
983 |
cp++; n--; |
984 |
985 |
greg |
1.2 |
if (!n || !(isalpha(*cp) | (*cp == '_'))) |
986 |
error(USER, "bad modifier name from rtrace"); |
987 |
/* get modifier name */ |
988 |
greg |
1.40 |
while (n > 1 && *cp != '\t') { |
989 |
if (mnp - modname >= sizeof(modname)-2) |
990 |
error(INTERNAL, "modifier name too long"); |
991 |
greg |
1.1 |
*mnp++ = *cp++; n--; |
992 |
993 |
*mnp = '\0'; |
994 |
greg |
1.2 |
cp++; n--; /* eat following tab */ |
995 |
greg |
1.1 |
if (n < (int)(sizeof(float)*9)) |
996 |
error(USER, "incomplete ray value from rtrace"); |
997 |
/* add ray contribution */ |
998 |
greg |
1.2 |
memcpy(rparams, cp, sizeof(float)*9); |
999 |
greg |
1.1 |
cp += sizeof(float)*9; n -= sizeof(float)*9; |
1000 |
greg |
1.2 |
add_contrib(modname); |
1001 |
greg |
1.1 |
1002 |
done_contrib(); /* sum up contributions & output */ |
1003 |
lastdone = rtp->raynum; |
1004 |
greg |
1.36 |
if (rtp->buf != NULL) /* free up buffer space */ |
1005 |
free(rtp->buf); |
1006 |
greg |
1.3 |
rt_unproc = rtp->next; |
1007 |
free(rtp); /* done with this ray tree */ |
1008 |
greg |
1.1 |
1009 |
1010 |
1011 |
/* wait for rtrace process to finish with ray tree */ |
1012 |
struct rtproc * |
1013 |
wait_rproc(void) |
1014 |
1015 |
struct rtproc *rtfree = NULL; |
1016 |
fd_set readset, errset; |
1017 |
int nr; |
1018 |
struct rtproc *rt; |
1019 |
int n; |
1020 |
1021 |
do { |
1022 |
nr = 0; /* prepare select call */ |
1023 |
FD_ZERO(&readset); FD_ZERO(&errset); n = 0; |
1024 |
for (rt = &rt0; rt != NULL; rt = rt->next) { |
1025 |
if (rt->raynum) { |
1026 |
FD_SET(rt->pd.r, &readset); |
1027 |
++nr; |
1028 |
1029 |
FD_SET(rt->pd.r, &errset); |
1030 |
if (rt->pd.r >= n) |
1031 |
n = rt->pd.r + 1; |
1032 |
1033 |
if (!nr) /* no rays pending */ |
1034 |
break; |
1035 |
if (nr > 1) { /* call select for multiple proc's */ |
1036 |
errno = 0; |
1037 |
if (select(n, &readset, NULL, &errset, NULL) < 0) |
1038 |
error(SYSTEM, "select call error in wait_rproc()"); |
1039 |
} else |
1040 |
FD_ZERO(&errset); |
1041 |
nr = 0; |
1042 |
1043 |
if (!FD_ISSET(rt->pd.r, &readset) && |
1044 |
!FD_ISSET(rt->pd.r, &errset)) |
1045 |
continue; |
1046 |
if (rt->buf == NULL) { |
1047 |
rt->bsiz = treebufsiz; |
1048 |
rt->buf = (char *)malloc(treebufsiz); |
1049 |
greg |
1.2 |
} else if (rt->nbr + BUFSIZ > rt->bsiz) { |
1050 |
greg |
1.1 |
if (rt->bsiz + BUFSIZ <= treebufsiz) |
1051 |
1052 |
else |
1053 |
greg |
1.28 |
treebufsiz = rt->bsiz += BUFSIZ; |
1054 |
greg |
1.1 |
rt->buf = (char *)realloc(rt->buf, rt->bsiz); |
1055 |
1056 |
if (rt->buf == NULL) |
1057 |
error(SYSTEM, "out of memory in wait_rproc"); |
1058 |
greg |
1.2 |
nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr); |
1059 |
if (nr <= 0) |
1060 |
greg |
1.1 |
error(USER, "rtrace process died"); |
1061 |
greg |
1.2 |
rt->nbr += nr; /* advance & check */ |
1062 |
if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4, |
1063 |
"~\t~\t", 4)) { |
1064 |
rt->nbr -= 4; /* elide terminator */ |
1065 |
greg |
1.3 |
queue_raytree(rt); |
1066 |
greg |
1.1 |
rtfree = rt; /* ready for next ray */ |
1067 |
1068 |
1069 |
} while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */ |
1070 |
return rtfree; |
1071 |
1072 |
1073 |
/* return next available rtrace process */ |
1074 |
struct rtproc * |
1075 |
get_rproc(void) |
1076 |
1077 |
1078 |
/* check for idle rtrace */ |
1079 |
1080 |
if (!rtp->raynum) |
1081 |
return rtp; |
1082 |
return wait_rproc(); /* need to wait for one */ |
1083 |
1084 |
1085 |
/* trace ray contributions (main loop) */ |
1086 |
void |
1087 |
greg |
1.5 |
trace_contribs(FILE *fin) |
1088 |
greg |
1.1 |
1089 |
char inpbuf[128]; |
1090 |
int iblen; |
1091 |
1092 |
/* loop over input */ |
1093 |
greg |
1.36 |
while ((iblen = getinp(inpbuf, fin)) >= 0) { |
1094 |
if (!iblen || /* need reset? */ |
1095 |
queue_length() > 10*nrtprocs() || |
1096 |
lastray+1 < lastray) { |
1097 |
greg |
1.1 |
while (wait_rproc() != NULL) |
1098 |
greg |
1.3 |
process_queue(); |
1099 |
greg |
1.34 |
if (lastray+1 < lastray) |
1100 |
lastdone = lastray = 0; |
1101 |
greg |
1.1 |
1102 |
rtp = get_rproc(); /* get avail. rtrace process */ |
1103 |
greg |
1.36 |
rtp->raynum = ++lastray; /* assign ray */ |
1104 |
if (iblen) { /* trace ray if valid */ |
1105 |
writebuf(rtp->pd.w, inpbuf, iblen); |
1106 |
} else { /* else bypass dummy ray */ |
1107 |
queue_raytree(rtp); /* empty tree */ |
1108 |
greg |
1.38 |
if ((yres <= 0) | (waitflush > 1)) |
1109 |
greg |
1.36 |
waitflush = 1; /* flush after this */ |
1110 |
1111 |
greg |
1.38 |
process_queue(); /* catch up with results */ |
1112 |
greg |
1.14 |
if (raysleft && !--raysleft) |
1113 |
greg |
1.38 |
break; /* preemptive EOI */ |
1114 |
greg |
1.1 |
1115 |
while (wait_rproc() != NULL) /* process outstanding rays */ |
1116 |
greg |
1.3 |
process_queue(); |
1117 |
greg |
1.14 |
if (raysleft) |
1118 |
greg |
1.2 |
error(USER, "unexpected EOF on input"); |
1119 |
greg |
1.14 |
lu_done(&ofiletab); /* close output files */ |
1120 |
1121 |
1122 |
/* seek on the given output file */ |
1123 |
static int |
1124 |
myseeko(const LUENT *e, void *p) |
1125 |
1126 |
greg |
1.31 |
1127 |
off_t nbytes = *(off_t *)p; |
1128 |
1129 |
if (sop->reclen > 1) |
1130 |
nbytes = nbytes * sop->reclen; |
1131 |
if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) { |
1132 |
greg |
1.14 |
sprintf(errmsg, "seek error on file '%s'", e->key); |
1133 |
1134 |
1135 |
schorsch |
1.43 |
return 0; |
1136 |
greg |
1.14 |
1137 |
1138 |
/* recover output if possible */ |
1139 |
void |
1140 |
recover_output(FILE *fin) |
1141 |
1142 |
greg |
1.31 |
off_t lastout = -1; |
1143 |
int outvsiz, recsiz; |
1144 |
char *outvfmt; |
1145 |
int i, j; |
1146 |
MODCONT *mp; |
1147 |
int ofl; |
1148 |
char oname[1024]; |
1149 |
LUENT *ment, *oent; |
1150 |
STREAMOUT sout; |
1151 |
off_t nvals; |
1152 |
int xr, yr; |
1153 |
greg |
1.14 |
1154 |
switch (outfmt) { |
1155 |
case 'a': |
1156 |
error(USER, "cannot recover ASCII output"); |
1157 |
return; |
1158 |
case 'f': |
1159 |
outvsiz = sizeof(float)*3; |
1160 |
outvfmt = "float"; |
1161 |
break; |
1162 |
case 'd': |
1163 |
outvsiz = sizeof(double)*3; |
1164 |
outvfmt = "double"; |
1165 |
break; |
1166 |
case 'c': |
1167 |
outvsiz = sizeof(COLR); |
1168 |
outvfmt = COLRFMT; |
1169 |
break; |
1170 |
default: |
1171 |
1172 |
return; |
1173 |
1174 |
/* check modifier outputs */ |
1175 |
1176 |
ment = lu_find(&modconttab,modname[i]); |
1177 |
mp = (MODCONT *)ment->data; |
1178 |
if (mp->outspec == NULL) |
1179 |
error(USER, "cannot recover from stdout"); |
1180 |
greg |
1.31 |
if (mp->outspec[0] == '!') |
1181 |
error(USER, "cannot recover from command"); |
1182 |
greg |
1.14 |
for (j = 0; ; j++) { /* check each bin's file */ |
1183 |
ofl = ofname(oname, mp->outspec, mp->modname, j); |
1184 |
if (ofl < 0) |
1185 |
error(USER, "bad output file specification"); |
1186 |
oent = lu_find(&ofiletab, oname); |
1187 |
greg |
1.31 |
if (oent->data != NULL) { |
1188 |
sout = *(STREAMOUT *)oent->data; |
1189 |
} else { |
1190 |
greg |
1.34 |
sout.reclen = CNT_UNKNOWN; |
1191 |
greg |
1.31 |
sout.ofp = NULL; |
1192 |
1193 |
if (sout.ofp != NULL) { /* already open? */ |
1194 |
greg |
1.14 |
if (ofl & OF_BIN) |
1195 |
continue; |
1196 |
break; |
1197 |
1198 |
/* open output */ |
1199 |
greg |
1.31 |
sout.ofp = fopen(oname, "rb+"); |
1200 |
if (sout.ofp == NULL) { |
1201 |
greg |
1.23 |
if (j) |
1202 |
break; /* assume end of modifier */ |
1203 |
sprintf(errmsg, "missing recover file '%s'", |
1204 |
oname); |
1205 |
1206 |
1207 |
greg |
1.31 |
nvals = lseek(fileno(sout.ofp), 0, SEEK_END); |
1208 |
greg |
1.14 |
if (nvals <= 0) { |
1209 |
lastout = 0; /* empty output, quit here */ |
1210 |
greg |
1.31 |
fclose(sout.ofp); |
1211 |
greg |
1.14 |
break; |
1212 |
1213 |
greg |
1.32 |
if (sout.reclen == CNT_UNKNOWN) { |
1214 |
greg |
1.31 |
if (!(ofl & OF_BIN)) { |
1215 |
greg |
1.14 |
sprintf(errmsg, |
1216 |
greg |
1.32 |
"need -bn to recover file '%s'", |
1217 |
greg |
1.14 |
oname); |
1218 |
greg |
1.32 |
1219 |
greg |
1.14 |
1220 |
greg |
1.31 |
recsiz = outvsiz; |
1221 |
} else |
1222 |
recsiz = outvsiz * sout.reclen; |
1223 |
1224 |
lseek(fileno(sout.ofp), 0, SEEK_SET); |
1225 |
if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) { |
1226 |
sprintf(errmsg, "format mismatch for '%s'", |
1227 |
oname); |
1228 |
1229 |
1230 |
if ((xres > 0) & (yres > 0) && |
1231 |
(!fscnresolu(&xr, &yr, sout.ofp) || |
1232 |
xr != xres || |
1233 |
yr != yres)) { |
1234 |
sprintf(errmsg, "resolution mismatch for '%s'", |
1235 |
oname); |
1236 |
1237 |
greg |
1.14 |
1238 |
greg |
1.31 |
nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz; |
1239 |
if ((lastout < 0) | (nvals < lastout)) |
1240 |
greg |
1.14 |
lastout = nvals; |
1241 |
greg |
1.31 |
if (oent->key == NULL) /* new entry */ |
1242 |
greg |
1.14 |
oent->key = strcpy((char *) |
1243 |
1244 |
greg |
1.31 |
if (oent->data == NULL) |
1245 |
oent->data = (char *)malloc(sizeof(STREAMOUT)); |
1246 |
*(STREAMOUT *)oent->data = sout; |
1247 |
greg |
1.14 |
if (!(ofl & OF_BIN)) |
1248 |
break; /* no bin separation */ |
1249 |
1250 |
if (!lastout) { /* empty output */ |
1251 |
greg |
1.16 |
error(WARNING, "no previous data to recover"); |
1252 |
greg |
1.14 |
lu_done(&ofiletab); /* reclose all outputs */ |
1253 |
return; |
1254 |
1255 |
greg |
1.31 |
if (j > mp->nbins) /* reallocate modifier bins */ |
1256 |
ment->data = (char *)(mp = growmodifier(mp, j)); |
1257 |
greg |
1.14 |
1258 |
greg |
1.15 |
if (lastout < 0) { |
1259 |
greg |
1.16 |
error(WARNING, "no output files to recover"); |
1260 |
greg |
1.15 |
return; |
1261 |
1262 |
greg |
1.24 |
if (raysleft && lastout >= raysleft) { |
1263 |
error(WARNING, "output appears to be complete"); |
1264 |
/* XXX should read & discard input? */ |
1265 |
quit(0); |
1266 |
1267 |
greg |
1.14 |
/* seek on all files */ |
1268 |
nvals = lastout * outvsiz; |
1269 |
lu_doall(&ofiletab, myseeko, &nvals); |
1270 |
greg |
1.28 |
/* skip repeated input */ |
1271 |
greg |
1.14 |
for (nvals = 0; nvals < lastout; nvals++) |
1272 |
greg |
1.36 |
if (getinp(oname, fin) < 0) |
1273 |
greg |
1.14 |
1274 |
lastray = lastdone = (unsigned long)lastout; |
1275 |
if (raysleft) |
1276 |
raysleft -= lastray; |
1277 |
greg |
1.1 |
