| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rtcontrib.c,v 1.59 2010/10/10 01:26:51 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Gather rtrace output to compute contributions from particular sources
| 6 |
| 7 |
| 8 |
#include "standard.h"
| 9 |
#include <ctype.h>
| 10 |
#include <signal.h>
| 11 |
#include "platform.h"
| 12 |
#include "rtprocess.h"
| 13 |
#include "selcall.h"
| 14 |
#include "color.h"
| 15 |
#include "resolu.h"
| 16 |
#include "lookup.h"
| 17 |
#include "calcomp.h"
| 18 |
| 19 |
#ifndef MAXMODLIST
| 20 |
#define MAXMODLIST 1024 /* maximum modifiers we'll track */
| 21 |
#endif
| 22 |
| 23 |
size_t treebufsiz = BUFSIZ; /* current tree buffer size */
| 24 |
| 25 |
typedef double DCOLOR[3]; /* double-precision color */
| 26 |
| 27 |
| 28 |
* The MODCONT structure is used to accumulate ray contributions
| 29 |
* for a particular modifier, which may be subdivided into bins
| 30 |
* if binv evaluates > 0. If outspec contains a %s in it, this will
| 31 |
* be replaced with the modifier name. If outspec contains a %d in it,
| 32 |
* this will be used to create one output file per bin, otherwise all bins
| 33 |
* will be written to the same file, in order. If the global outfmt
| 34 |
* is 'c', then a 4-byte RGBE pixel will be output for each bin value
| 35 |
* and the file will conform to a RADIANCE image if xres & yres are set.
| 36 |
| 37 |
typedef struct {
| 38 |
const char *outspec; /* output file specification */
| 39 |
const char *modname; /* modifier name */
| 40 |
EPNODE *binv; /* bin value expression */
| 41 |
int nbins; /* number of accumulation bins */
| 42 |
DCOLOR cbin[1]; /* contribution bins (extends struct) */
| 43 |
} MODCONT; /* modifier contribution */
| 44 |
| 45 |
static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
| 46 |
| 47 |
LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
| 48 |
| 49 |
| 50 |
* The STREAMOUT structure holds an open FILE pointer and a count of
| 51 |
* the number of RGB triplets per record, or 0 if unknown.
| 52 |
| 53 |
typedef struct {
| 54 |
FILE *ofp; /* output file pointer */
| 55 |
int outpipe; /* output is to a pipe */
| 56 |
int reclen; /* triplets/record */
| 57 |
int xr, yr; /* output resolution for picture */
| 58 |
} STREAMOUT;
| 59 |
| 60 |
/* close output stream and free record */
| 61 |
static void
| 62 |
closestream(void *p)
| 63 |
| 64 |
STREAMOUT *sop = (STREAMOUT *)p;
| 65 |
int status;
| 66 |
if (sop->outpipe)
| 67 |
status = pclose(sop->ofp);
| 68 |
else
| 69 |
status = fclose(sop->ofp);
| 70 |
if (status)
| 71 |
error(SYSTEM, "error closing output stream");
| 72 |
free(p);
| 73 |
| 74 |
| 75 |
LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
| 76 |
| 77 |
#define OF_MODIFIER 01
| 78 |
#define OF_BIN 02
| 79 |
| 80 |
STREAMOUT *getostream(const char *ospec, const char *mname, int bn, int noopen);
| 81 |
int ofname(char *oname, const char *ospec, const char *mname, int bn);
| 82 |
void printheader(FILE *fout, const char *info);
| 83 |
void printresolu(FILE *fout, int xr, int yr);
| 84 |
| 85 |
| 86 |
* The rcont structure is used to manage i/o with a particular
| 87 |
* rtrace child process. Input is passed unchanged from stdin,
| 88 |
* and output is processed in input order and accumulated according
| 89 |
* to the corresponding modifier and bin number.
| 90 |
| 91 |
struct rtproc {
| 92 |
struct rtproc *next; /* next in list of processes */
| 93 |
SUBPROC pd; /* rtrace pipe descriptors */
| 94 |
unsigned long raynum; /* ray number for this tree */
| 95 |
size_t bsiz; /* ray tree buffer length */
| 96 |
char *buf; /* ray tree buffer */
| 97 |
size_t nbr; /* number of bytes from rtrace */
| 98 |
}; /* rtrace process buffer */
| 99 |
| 100 |
/* rtrace command and defaults */
| 101 |
char *rtargv[256+2*MAXMODLIST] = { "rtrace",
| 102 |
"-dj", ".9", "-dr", "3",
| 103 |
"-ab", "1", "-ad", "350", };
| 104 |
| 105 |
int rtargc = 9;
| 106 |
/* overriding rtrace options */
| 107 |
char *myrtopts[] = { "-h-", "-x", "1", "-y", "0",
| 108 |
"-dt", "0", "-as", "0", "-aa", "0", NULL };
| 109 |
| 110 |
#define RTCOEFF "-o~~TmWdp" /* compute coefficients only */
| 111 |
#define RTCONTRIB "-o~~TmVdp" /* compute ray contributions */
| 112 |
| 113 |
struct rtproc rt0; /* head of rtrace process list */
| 114 |
| 115 |
struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
| 116 |
| 117 |
#define PERSIST_NONE 0 /* no persist file */
| 118 |
#define PERSIST_SINGLE 1 /* user set -P persist */
| 119 |
#define PERSIST_PARALL 2 /* user set -PP persist */
| 120 |
#define PERSIST_OURS 3 /* -PP persist belongs to us */
| 121 |
int persist_state = PERSIST_NONE; /* persist file state */
| 122 |
char persistfn[] = "pfXXXXXX"; /* our persist file name, if set */
| 123 |
| 124 |
int gargc; /* global argc */
| 125 |
char **gargv; /* global argv */
| 126 |
#define progname gargv[0]
| 127 |
| 128 |
char *octree; /* global octree argument */
| 129 |
| 130 |
int inpfmt = 'a'; /* input format */
| 131 |
int outfmt = 'a'; /* output format */
| 132 |
| 133 |
int header = 1; /* output header? */
| 134 |
int force_open = 0; /* truncate existing output? */
| 135 |
int recover = 0; /* recover previous output? */
| 136 |
int accumulate = 1; /* input rays per output record */
| 137 |
int xres = 0; /* horiz. output resolution */
| 138 |
int yres = 0; /* vert. output resolution */
| 139 |
| 140 |
int account; /* current accumulation count */
| 141 |
unsigned long raysleft; /* number of rays left to trace */
| 142 |
long waitflush; /* how long until next flush */
| 143 |
| 144 |
unsigned long lastray = 0; /* last ray number sent */
| 145 |
unsigned long lastdone = 0; /* last ray processed */
| 146 |
| 147 |
int using_stdout = 0; /* are we using stdout? */
| 148 |
| 149 |
const char *modname[MAXMODLIST]; /* ordered modifier name list */
| 150 |
int nmods = 0; /* number of modifiers */
| 151 |
| 152 |
#define queue_length() (lastray - lastdone)
| 153 |
| 154 |
MODCONT *growmodifier(MODCONT *mp, int nb);
| 155 |
MODCONT *addmodifier(char *modn, char *outf, char *binv, int bincnt);
| 156 |
void addmodfile(char *fname, char *outf, char *binv, int bincnt);
| 157 |
| 158 |
void init(int np);
| 159 |
int done_rprocs(struct rtproc *rtp);
| 160 |
void reload_output(void);
| 161 |
void recover_output(FILE *fin);
| 162 |
void trace_contribs(FILE *fin);
| 163 |
struct rtproc *wait_rproc(void);
| 164 |
struct rtproc *get_rproc(void);
| 165 |
void queue_raytree(struct rtproc *rtp);
| 166 |
void process_queue(void);
| 167 |
| 168 |
void put_contrib(const DCOLOR cnt, FILE *fout);
| 169 |
void add_contrib(const char *modn);
| 170 |
void done_contrib(int navg);
| 171 |
| 172 |
/* return number of open rtrace processes */
| 173 |
static int
| 174 |
nrtprocs(void)
| 175 |
| 176 |
int nrtp = 0;
| 177 |
struct rtproc *rtp;
| 178 |
| 179 |
for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
| 180 |
nrtp += rtp->pd.running;
| 181 |
return(nrtp);
| 182 |
| 183 |
| 184 |
/* set input/output format */
| 185 |
static void
| 186 |
setformat(const char *fmt)
| 187 |
| 188 |
switch (fmt[0]) {
| 189 |
case 'f':
| 190 |
case 'd':
| 191 |
SET_FILE_BINARY(stdin);
| 192 |
/* fall through */
| 193 |
case 'a':
| 194 |
inpfmt = fmt[0];
| 195 |
break;
| 196 |
default:
| 197 |
goto fmterr;
| 198 |
| 199 |
switch (fmt[1]) {
| 200 |
case '\0':
| 201 |
outfmt = inpfmt;
| 202 |
return;
| 203 |
case 'a':
| 204 |
case 'f':
| 205 |
case 'd':
| 206 |
case 'c':
| 207 |
outfmt = fmt[1];
| 208 |
break;
| 209 |
default:
| 210 |
goto fmterr;
| 211 |
| 212 |
if (!fmt[2])
| 213 |
return;
| 214 |
fmterr:
| 215 |
sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
| 216 |
error(USER, errmsg);
| 217 |
| 218 |
| 219 |
/* gather rays from rtrace and output contributions */
| 220 |
int
| 221 |
main(int argc, char *argv[])
| 222 |
| 223 |
int contrib = 0;
| 224 |
int nprocs = 1;
| 225 |
char *curout = NULL;
| 226 |
char *binval = NULL;
| 227 |
int bincnt = 0;
| 228 |
char fmt[8];
| 229 |
int i, j;
| 230 |
/* need at least one argument */
| 231 |
if (argc < 2) {
| 232 |
fprintf(stderr,
| 233 |
"Usage: %s [-n nprocs][-V][-r][-e expr][-f source][-o ospec][-b binv] {-m mod | -M file} [rtrace options] octree\n",
| 234 |
argv[0]);
| 235 |
exit(1);
| 236 |
| 237 |
/* global program name */
| 238 |
gargv = argv;
| 239 |
/* initialize calcomp routines */
| 240 |
esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
| 241 |
esupport &= ~(E_OUTCHAN);
| 242 |
varset("PI", ':', PI);
| 243 |
/* get our options */
| 244 |
for (i = 1; i < argc-1; i++) {
| 245 |
/* expand arguments */
| 246 |
while ((j = expandarg(&argc, &argv, i)) > 0)
| 247 |
| 248 |
if (j < 0) {
| 249 |
fprintf(stderr, "%s: cannot expand '%s'\n",
| 250 |
argv[0], argv[i]);
| 251 |
exit(1);
| 252 |
| 253 |
if (argv[i][0] == '-')
| 254 |
switch (argv[i][1]) {
| 255 |
case 'n': /* number of processes */
| 256 |
if (argv[i][2] || i >= argc-2) break;
| 257 |
nprocs = atoi(argv[++i]);
| 258 |
if (nprocs <= 0)
| 259 |
error(USER, "illegal number of processes");
| 260 |
continue;
| 261 |
case 'V': /* output contributions */
| 262 |
switch (argv[i][2]) {
| 263 |
case '\0':
| 264 |
contrib = !contrib;
| 265 |
continue;
| 266 |
case '+': case '1':
| 267 |
case 'T': case 't':
| 268 |
case 'Y': case 'y':
| 269 |
contrib = 1;
| 270 |
continue;
| 271 |
case '-': case '0':
| 272 |
case 'F': case 'f':
| 273 |
case 'N': case 'n':
| 274 |
contrib = 0;
| 275 |
continue;
| 276 |
| 277 |
break;
| 278 |
case 'c': /* input rays per output */
| 279 |
| 280 |
accumulate = atoi(argv[++i]);
| 281 |
continue;
| 282 |
case 'r': /* recover output */
| 283 |
if (argv[i][2]) break;
| 284 |
recover = 1;
| 285 |
continue;
| 286 |
case 'h': /* output header? */
| 287 |
| 288 |
case '\0':
| 289 |
header = !header;
| 290 |
continue;
| 291 |
case '+': case '1':
| 292 |
case 'T': case 't':
| 293 |
case 'Y': case 'y':
| 294 |
header = 1;
| 295 |
continue;
| 296 |
case '-': case '0':
| 297 |
case 'F': case 'f':
| 298 |
case 'N': case 'n':
| 299 |
header = 0;
| 300 |
continue;
| 301 |
| 302 |
break;
| 303 |
case 'f': /* file or force or format */
| 304 |
if (!argv[i][2]) {
| 305 |
char *fpath;
| 306 |
if (i >= argc-2) break;
| 307 |
fpath = getpath(argv[++i],
| 308 |
getrlibpath(), R_OK);
| 309 |
if (fpath == NULL) {
| 310 |
sprintf(errmsg,
| 311 |
"cannot find file '%s'",
| 312 |
argv[i]);
| 313 |
| 314 |
| 315 |
fcompile(fpath);
| 316 |
continue;
| 317 |
| 318 |
if (argv[i][2] == 'o') {
| 319 |
force_open = 1;
| 320 |
continue;
| 321 |
| 322 |
setformat(argv[i]+2);
| 323 |
continue;
| 324 |
case 'e': /* expression */
| 325 |
| 326 |
scompile(argv[++i], NULL, 0);
| 327 |
continue;
| 328 |
case 'o': /* output file spec. */
| 329 |
| 330 |
curout = argv[++i];
| 331 |
continue;
| 332 |
case 'x': /* horiz. output resolution */
| 333 |
| 334 |
xres = atoi(argv[++i]);
| 335 |
continue;
| 336 |
case 'y': /* vert. output resolution */
| 337 |
| 338 |
yres = atoi(argv[++i]);
| 339 |
continue;
| 340 |
case 'b': /* bin expression/count */
| 341 |
| 342 |
if (argv[i][2] == 'n') {
| 343 |
bincnt = (int)(eval(argv[++i]) + .5);
| 344 |
continue;
| 345 |
| 346 |
| 347 |
binval = argv[++i];
| 348 |
continue;
| 349 |
case 'm': /* modifier name */
| 350 |
| 351 |
rtargv[rtargc++] = "-ti";
| 352 |
rtargv[rtargc++] = argv[++i];
| 353 |
addmodifier(argv[i], curout, binval, bincnt);
| 354 |
continue;
| 355 |
case 'M': /* modifier file */
| 356 |
| 357 |
rtargv[rtargc++] = "-tI";
| 358 |
| 359 |
addmodfile(argv[i], curout, binval, bincnt);
| 360 |
continue;
| 361 |
case 'P': /* persist file */
| 362 |
| 363 |
persist_state = (argv[i][2] == 'P') ?
| 364 |
PERSIST_PARALL : PERSIST_SINGLE;
| 365 |
rtargv[rtargc++] = argv[i];
| 366 |
| 367 |
continue;
| 368 |
| 369 |
rtargv[rtargc++] = argv[i]; /* assume rtrace option */
| 370 |
| 371 |
if (accumulate <= 0) /* no output flushing for single record */
| 372 |
xres = yres = 0;
| 373 |
/* set global argument list */
| 374 |
gargc = argc; gargv = argv;
| 375 |
/* add "mandatory" rtrace settings */
| 376 |
for (j = 0; myrtopts[j] != NULL; j++)
| 377 |
rtargv[rtargc++] = myrtopts[j];
| 378 |
rtargv[rtargc++] = contrib ? RTCONTRIB : RTCOEFF;
| 379 |
/* just asking for defaults? */
| 380 |
if (!strcmp(argv[i], "-defaults")) {
| 381 |
char nps[8], sxres[16], syres[16];
| 382 |
char *rtpath;
| 383 |
printf("-c %-5d\t\t\t# accumulated rays per record\n",
| 384 |
accumulate);
| 385 |
printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-',
| 386 |
contrib ? "contributions" : "coefficients");
| 387 |
fflush(stdout); /* report OUR options */
| 388 |
rtargv[rtargc++] = "-n";
| 389 |
sprintf(nps, "%d", nprocs);
| 390 |
rtargv[rtargc++] = nps;
| 391 |
rtargv[rtargc++] = header ? "-h+" : "-h-";
| 392 |
sprintf(fmt, "-f%c%c", inpfmt, outfmt);
| 393 |
rtargv[rtargc++] = fmt;
| 394 |
rtargv[rtargc++] = "-x";
| 395 |
sprintf(sxres, "%d", xres);
| 396 |
rtargv[rtargc++] = sxres;
| 397 |
rtargv[rtargc++] = "-y";
| 398 |
sprintf(syres, "%d", yres);
| 399 |
rtargv[rtargc++] = syres;
| 400 |
rtargv[rtargc++] = "-defaults";
| 401 |
rtargv[rtargc] = NULL;
| 402 |
rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
| 403 |
if (rtpath == NULL) {
| 404 |
eputs(rtargv[0]);
| 405 |
eputs(": command not found\n");
| 406 |
exit(1);
| 407 |
| 408 |
execv(rtpath, rtargv);
| 409 |
perror(rtpath); /* execv() should not return */
| 410 |
exit(1);
| 411 |
| 412 |
if (nprocs > 1) { /* add persist file if parallel */
| 413 |
if (persist_state == PERSIST_SINGLE)
| 414 |
error(USER, "use -PP option for multiple processes");
| 415 |
if (persist_state == PERSIST_NONE) {
| 416 |
rtargv[rtargc++] = "-PP";
| 417 |
rtargv[rtargc++] = mktemp(persistfn);
| 418 |
persist_state = PERSIST_OURS;
| 419 |
| 420 |
| 421 |
/* add format string */
| 422 |
sprintf(fmt, "-f%cf", inpfmt);
| 423 |
| 424 |
/* octree argument is last */
| 425 |
if (i <= 0 || i != argc-1 || argv[i][0] == '-')
| 426 |
error(USER, "missing octree argument");
| 427 |
rtargv[rtargc++] = octree = argv[i];
| 428 |
| 429 |
/* start rtrace & recover if requested */
| 430 |
init(nprocs);
| 431 |
/* compute contributions */
| 432 |
trace_contribs(stdin);
| 433 |
/* clean up */
| 434 |
quit(0);
| 435 |
| 436 |
| 437 |
#ifndef SIGALRM
| 438 |
#define SIGALRM SIGTERM
| 439 |
#endif
| 440 |
/* kill persistent rtrace process */
| 441 |
static void
| 442 |
killpersist(void)
| 443 |
| 444 |
FILE *fp = fopen(persistfn, "r");
| 445 |
RT_PID pid;
| 446 |
| 447 |
if (fp == NULL)
| 448 |
return;
| 449 |
if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
| 450 |
unlink(persistfn);
| 451 |
fclose(fp);
| 452 |
| 453 |
| 454 |
/* close rtrace processes and clean up */
| 455 |
int
| 456 |
| 457 |
| 458 |
int st0, st1 = 0;
| 459 |
| 460 |
if (rtp->next != NULL) { /* close last opened first! */
| 461 |
st1 = done_rprocs(rtp->next);
| 462 |
free((void *)rtp->next);
| 463 |
rtp->next = NULL;
| 464 |
| 465 |
st0 = close_process(&rtp->pd);
| 466 |
if (st0 < 0)
| 467 |
error(WARNING, "unknown return status from rtrace process");
| 468 |
else if (st0 > 0)
| 469 |
return(st0);
| 470 |
return(st1);
| 471 |
| 472 |
| 473 |
/* exit with status */
| 474 |
void
| 475 |
quit(int status)
| 476 |
| 477 |
int rtstat;
| 478 |
| 479 |
if (persist_state == PERSIST_OURS) /* terminate waiting rtrace */
| 480 |
killpersist();
| 481 |
/* clean up rtrace process(es) */
| 482 |
rtstat = done_rprocs(&rt0);
| 483 |
if (status == 0)
| 484 |
status = rtstat;
| 485 |
exit(status); /* flushes all output streams */
| 486 |
| 487 |
| 488 |
/* start rtrace processes and initialize */
| 489 |
void
| 490 |
init(int np)
| 491 |
| 492 |
struct rtproc *rtp;
| 493 |
int i;
| 494 |
int maxbytes;
| 495 |
/* make sure we have something to do */
| 496 |
if (!nmods)
| 497 |
error(USER, "No modifiers specified");
| 498 |
/* assign ray variables */
| 499 |
scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
| 500 |
scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
| 501 |
/* set up signal handling */
| 502 |
signal(SIGINT, quit);
| 503 |
#ifdef SIGHUP
| 504 |
signal(SIGHUP, quit);
| 505 |
#endif
| 506 |
#ifdef SIGTERM
| 507 |
signal(SIGTERM, quit);
| 508 |
#endif
| 509 |
#ifdef SIGPIPE
| 510 |
signal(SIGPIPE, quit);
| 511 |
#endif
| 512 |
rtp = &rt0; /* start rtrace process(es) */
| 513 |
for (i = 0; i++ < np; ) {
| 514 |
errno = 0;
| 515 |
maxbytes = open_process(&rtp->pd, rtargv);
| 516 |
if (maxbytes == 0) {
| 517 |
eputs(rtargv[0]);
| 518 |
| 519 |
exit(1);
| 520 |
| 521 |
if (maxbytes < 0)
| 522 |
error(SYSTEM, "cannot start rtrace process");
| 523 |
if (maxbytes > treebufsiz)
| 524 |
treebufsiz = maxbytes;
| 525 |
rtp->raynum = 0;
| 526 |
rtp->bsiz = 0;
| 527 |
rtp->buf = NULL;
| 528 |
rtp->nbr = 0;
| 529 |
if (i == np) /* last process? */
| 530 |
break;
| 531 |
if (i == 1)
| 532 |
sleep(2); /* wait for persist file */
| 533 |
rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
| 534 |
if (rtp->next == NULL)
| 535 |
error(SYSTEM, "out of memory in init");
| 536 |
rtp = rtp->next;
| 537 |
| 538 |
rtp->next = NULL; /* terminate list */
| 539 |
if (yres > 0) {
| 540 |
if (xres > 0)
| 541 |
raysleft = (unsigned long)xres*yres;
| 542 |
else
| 543 |
raysleft = yres;
| 544 |
} else
| 545 |
raysleft = 0;
| 546 |
if ((account = accumulate) > 0)
| 547 |
raysleft *= accumulate;
| 548 |
waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
| 549 |
if (!recover)
| 550 |
return;
| 551 |
/* recover previous values */
| 552 |
| 553 |
reload_output();
| 554 |
else
| 555 |
recover_output(stdin);
| 556 |
| 557 |
| 558 |
/* grow modifier to accommodate more bins */
| 559 |
MODCONT *
| 560 |
| 561 |
| 562 |
if (nb <= mp->nbins)
| 563 |
return mp;
| 564 |
mp = (MODCONT *)realloc(mp, sizeof(MODCONT) + sizeof(DCOLOR)*(nb-1));
| 565 |
if (mp == NULL)
| 566 |
error(SYSTEM, "out of memory in growmodifier");
| 567 |
memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(nb-mp->nbins));
| 568 |
mp->nbins = nb;
| 569 |
return mp;
| 570 |
| 571 |
| 572 |
/* add modifier to our list to track */
| 573 |
MODCONT *
| 574 |
| 575 |
| 576 |
LUENT *lep = lu_find(&modconttab, modn);
| 577 |
MODCONT *mp;
| 578 |
int i;
| 579 |
| 580 |
if (lep->data != NULL) {
| 581 |
sprintf(errmsg, "duplicate modifier '%s'", modn);
| 582 |
| 583 |
| 584 |
if (nmods >= MAXMODLIST)
| 585 |
error(INTERNAL, "too many modifiers");
| 586 |
modname[nmods++] = modn; /* XXX assumes static string */
| 587 |
lep->key = modn; /* XXX assumes static string */
| 588 |
mp = (MODCONT *)malloc(sizeof(MODCONT));
| 589 |
if (mp == NULL)
| 590 |
error(SYSTEM, "out of memory in addmodifier");
| 591 |
mp->outspec = outf; /* XXX assumes static string */
| 592 |
mp->modname = modn; /* XXX assumes static string */
| 593 |
if (binv == NULL)
| 594 |
binv = "0"; /* use single bin if unspecified */
| 595 |
mp->binv = eparse(binv);
| 596 |
if (mp->binv->type == NUM) { /* check value if constant */
| 597 |
bincnt = (int)(evalue(mp->binv) + 1.5);
| 598 |
if (bincnt != 1) {
| 599 |
sprintf(errmsg, "illegal non-zero constant for bin (%s)",
| 600 |
binv);
| 601 |
| 602 |
| 603 |
| 604 |
mp->nbins = 1; /* initialize results holder */
| 605 |
setcolor(mp->cbin[0], 0., 0., 0.);
| 606 |
if (bincnt > 1)
| 607 |
mp = growmodifier(mp, bincnt);
| 608 |
lep->data = (char *)mp;
| 609 |
/* allocate output streams */
| 610 |
for (i = bincnt; i-- > 0; )
| 611 |
getostream(mp->outspec, mp->modname, i, 1);
| 612 |
return mp;
| 613 |
| 614 |
| 615 |
/* add modifiers from a file list */
| 616 |
void
| 617 |
| 618 |
| 619 |
char *mname[MAXMODLIST];
| 620 |
int i;
| 621 |
/* find the file & store strings */
| 622 |
if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
| 623 |
sprintf(errmsg, "cannot find modifier file '%s'", fname);
| 624 |
error(SYSTEM, errmsg);
| 625 |
| 626 |
for (i = 0; mname[i]; i++) /* add each one */
| 627 |
addmodifier(mname[i], outf, binv, bincnt);
| 628 |
| 629 |
| 630 |
/* put string to stderr */
| 631 |
void
| 632 |
eputs(char *s)
| 633 |
| 634 |
static int midline = 0;
| 635 |
| 636 |
if (!*s) return;
| 637 |
if (!midline) {
| 638 |
fputs(progname, stderr);
| 639 |
fputs(": ", stderr);
| 640 |
| 641 |
fputs(s, stderr);
| 642 |
midline = s[strlen(s)-1] != '\n';
| 643 |
| 644 |
| 645 |
/* construct output file name and return flags whether modifier/bin present */
| 646 |
int
| 647 |
| 648 |
| 649 |
const char *mnp = NULL;
| 650 |
const char *bnp = NULL;
| 651 |
const char *cp;
| 652 |
| 653 |
if (ospec == NULL)
| 654 |
return -1;
| 655 |
for (cp = ospec; *cp; cp++) /* check format position(s) */
| 656 |
if (*cp == '%') {
| 657 |
do
| 658 |
++cp;
| 659 |
while (isdigit(*cp));
| 660 |
switch (*cp) {
| 661 |
case '%':
| 662 |
break;
| 663 |
case 's':
| 664 |
if (mnp != NULL)
| 665 |
return -1;
| 666 |
mnp = cp;
| 667 |
break;
| 668 |
case 'd':
| 669 |
case 'i':
| 670 |
case 'o':
| 671 |
case 'x':
| 672 |
case 'X':
| 673 |
if (bnp != NULL)
| 674 |
return -1;
| 675 |
bnp = cp;
| 676 |
break;
| 677 |
default:
| 678 |
return -1;
| 679 |
| 680 |
| 681 |
if (mnp != NULL) { /* create file name */
| 682 |
if (bnp != NULL) {
| 683 |
if (bnp > mnp)
| 684 |
sprintf(oname, ospec, mname, bn);
| 685 |
else
| 686 |
sprintf(oname, ospec, bn, mname);
| 687 |
return OF_MODIFIER|OF_BIN;
| 688 |
| 689 |
sprintf(oname, ospec, mname);
| 690 |
return OF_MODIFIER;
| 691 |
| 692 |
if (bnp != NULL) {
| 693 |
sprintf(oname, ospec, bn);
| 694 |
return OF_BIN;
| 695 |
| 696 |
strcpy(oname, ospec);
| 697 |
return 0;
| 698 |
| 699 |
| 700 |
/* write header to the given output stream */
| 701 |
void
| 702 |
| 703 |
| 704 |
extern char VersionID[];
| 705 |
FILE *fin = fopen(octree, "r");
| 706 |
| 707 |
if (fin == NULL)
| 708 |
quit(1);
| 709 |
checkheader(fin, "ignore", fout); /* copy octree header */
| 710 |
fclose(fin);
| 711 |
printargs(gargc-1, gargv, fout); /* add our command */
| 712 |
fprintf(fout, "SOFTWARE= %s\n", VersionID);
| 713 |
fputnow(fout);
| 714 |
if (info != NULL) /* add extra info if given */
| 715 |
fputs(info, fout);
| 716 |
switch (outfmt) { /* add output format */
| 717 |
case 'a':
| 718 |
fputformat("ascii", fout);
| 719 |
break;
| 720 |
case 'f':
| 721 |
fputformat("float", fout);
| 722 |
break;
| 723 |
case 'd':
| 724 |
fputformat("double", fout);
| 725 |
break;
| 726 |
case 'c':
| 727 |
fputformat(COLRFMT, fout);
| 728 |
break;
| 729 |
| 730 |
fputc('\n', fout);
| 731 |
| 732 |
| 733 |
/* write resolution string to given output stream */
| 734 |
void
| 735 |
| 736 |
| 737 |
if ((xr > 0) & (yr > 0)) /* resolution string */
| 738 |
fprtresolu(xr, yr, fout);
| 739 |
| 740 |
| 741 |
/* Get output stream pointer (open and write header if new and noopen==0) */
| 742 |
STREAMOUT *
| 743 |
| 744 |
| 745 |
static const DCOLOR nocontrib = BLKCOLOR;
| 746 |
static STREAMOUT stdos;
| 747 |
int ofl;
| 748 |
char oname[1024];
| 749 |
LUENT *lep;
| 750 |
STREAMOUT *sop;
| 751 |
| 752 |
if (ospec == NULL) { /* use stdout? */
| 753 |
if (!noopen && !using_stdout) {
| 754 |
if (outfmt != 'a')
| 755 |
SET_FILE_BINARY(stdout);
| 756 |
if (header)
| 757 |
printheader(stdout, NULL);
| 758 |
printresolu(stdout, xres, yres);
| 759 |
if (waitflush > 0)
| 760 |
fflush(stdout);
| 761 |
stdos.xr = xres; stdos.yr = yres;
| 762 |
using_stdout = 1;
| 763 |
| 764 |
stdos.ofp = stdout;
| 765 |
stdos.reclen += noopen;
| 766 |
return &stdos;
| 767 |
| 768 |
ofl = ofname(oname, ospec, mname, bn); /* get output name */
| 769 |
if (ofl < 0) {
| 770 |
sprintf(errmsg, "bad output format '%s'", ospec);
| 771 |
| 772 |
| 773 |
lep = lu_find(&ofiletab, oname); /* look it up */
| 774 |
if (lep->key == NULL) /* new entry */
| 775 |
lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
| 776 |
sop = (STREAMOUT *)lep->data;
| 777 |
if (sop == NULL) { /* allocate stream */
| 778 |
sop = (STREAMOUT *)malloc(sizeof(STREAMOUT));
| 779 |
if (sop == NULL)
| 780 |
error(SYSTEM, "out of memory in getostream");
| 781 |
sop->outpipe = oname[0] == '!';
| 782 |
sop->reclen = 0;
| 783 |
sop->ofp = NULL; /* open iff noopen==0 */
| 784 |
sop->xr = xres; sop->yr = yres;
| 785 |
lep->data = (char *)sop;
| 786 |
if (!sop->outpipe & !force_open & !recover &&
| 787 |
access(oname, F_OK) == 0) {
| 788 |
errno = EEXIST; /* file exists */
| 789 |
goto openerr;
| 790 |
| 791 |
| 792 |
if (!noopen && sop->ofp == NULL) { /* open output stream */
| 793 |
long i;
| 794 |
if (oname[0] == '!') /* output to command */
| 795 |
sop->ofp = popen(oname+1, "w");
| 796 |
else /* else open file */
| 797 |
sop->ofp = fopen(oname, "w");
| 798 |
if (sop->ofp == NULL)
| 799 |
goto openerr;
| 800 |
if (outfmt != 'a')
| 801 |
SET_FILE_BINARY(sop->ofp);
| 802 |
if (header) {
| 803 |
char info[512];
| 804 |
char *cp = info;
| 805 |
if (ofl & OF_MODIFIER || sop->reclen == 1) {
| 806 |
sprintf(cp, "MODIFIER=%s\n", mname);
| 807 |
while (*cp) ++cp;
| 808 |
| 809 |
if (ofl & OF_BIN) {
| 810 |
sprintf(cp, "BIN=%d\n", bn);
| 811 |
while (*cp) ++cp;
| 812 |
| 813 |
*cp = '\0';
| 814 |
printheader(sop->ofp, info);
| 815 |
| 816 |
if (accumulate > 0) { /* global resolution */
| 817 |
| 818 |
| 819 |
printresolu(sop->ofp, sop->xr, sop->yr);
| 820 |
/* play catch-up */
| 821 |
for (i = accumulate > 0 ? lastdone/accumulate : 0; i--; ) {
| 822 |
int j = sop->reclen;
| 823 |
if (j <= 0) j = 1;
| 824 |
while (j--)
| 825 |
put_contrib(nocontrib, sop->ofp);
| 826 |
if (outfmt == 'a')
| 827 |
putc('\n', sop->ofp);
| 828 |
| 829 |
if (waitflush > 0)
| 830 |
fflush(sop->ofp);
| 831 |
| 832 |
sop->reclen += noopen; /* add to length if noopen */
| 833 |
return sop; /* return output stream */
| 834 |
openerr:
| 835 |
sprintf(errmsg, "cannot open '%s' for writing", oname);
| 836 |
| 837 |
return NULL; /* pro forma return */
| 838 |
| 839 |
| 840 |
/* read input ray into buffer */
| 841 |
int
| 842 |
getinp(char *buf, FILE *fp)
| 843 |
| 844 |
double dv[3], *dvp;
| 845 |
float *fvp;
| 846 |
char *cp;
| 847 |
int i;
| 848 |
| 849 |
switch (inpfmt) {
| 850 |
case 'a':
| 851 |
cp = buf; /* make sure we get 6 floats */
| 852 |
for (i = 0; i < 6; i++) {
| 853 |
if (fgetword(cp, buf+127-cp, fp) == NULL)
| 854 |
return -1;
| 855 |
if (i >= 3)
| 856 |
dv[i-3] = atof(cp);
| 857 |
if ((cp = fskip(cp)) == NULL || *cp)
| 858 |
return -1;
| 859 |
*cp++ = ' ';
| 860 |
| 861 |
getc(fp); /* get/put eol */
| 862 |
*cp-- = '\0'; *cp = '\n';
| 863 |
if (DOT(dv,dv) <= FTINY*FTINY)
| 864 |
return 0; /* dummy ray */
| 865 |
return strlen(buf);
| 866 |
case 'f':
| 867 |
if (fread(buf, sizeof(float), 6, fp) < 6)
| 868 |
return -1;
| 869 |
fvp = (float *)buf + 3;
| 870 |
if (DOT(fvp,fvp) <= FTINY*FTINY)
| 871 |
| 872 |
return sizeof(float)*6;
| 873 |
case 'd':
| 874 |
if (fread(buf, sizeof(double), 6, fp) < 6)
| 875 |
return -1;
| 876 |
dvp = (double *)buf + 3;
| 877 |
if (DOT(dvp,dvp) <= FTINY*FTINY)
| 878 |
| 879 |
return sizeof(double)*6;
| 880 |
| 881 |
error(INTERNAL, "botched input format");
| 882 |
return -1; /* pro forma return */
| 883 |
| 884 |
| 885 |
static float rparams[9]; /* traced ray parameters */
| 886 |
| 887 |
/* return channel (ray) value */
| 888 |
double
| 889 |
chanvalue(int n)
| 890 |
| 891 |
if (--n < 0 || n >= 6)
| 892 |
error(USER, "illegal channel number ($N)");
| 893 |
return rparams[n+3];
| 894 |
| 895 |
| 896 |
/* add current ray contribution to the appropriate modifier bin */
| 897 |
void
| 898 |
| 899 |
| 900 |
LUENT *le = lu_find(&modconttab, modn);
| 901 |
MODCONT *mp = (MODCONT *)le->data;
| 902 |
int bn;
| 903 |
| 904 |
if (mp == NULL) {
| 905 |
sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
| 906 |
| 907 |
| 908 |
eclock++; /* get bin number */
| 909 |
bn = (int)(evalue(mp->binv) + .5);
| 910 |
if (bn <= 0)
| 911 |
bn = 0;
| 912 |
else if (bn >= mp->nbins) /* new bin */
| 913 |
le->data = (char *)(mp = growmodifier(mp, bn+1));
| 914 |
addcolor(mp->cbin[bn], rparams);
| 915 |
| 916 |
| 917 |
/* output newline to ASCII file and/or flush as requested */
| 918 |
static int
| 919 |
puteol(const LUENT *e, void *p)
| 920 |
| 921 |
STREAMOUT *sop = (STREAMOUT *)e->data;
| 922 |
| 923 |
if (outfmt == 'a')
| 924 |
| 925 |
if (!waitflush)
| 926 |
fflush(sop->ofp);
| 927 |
if (ferror(sop->ofp)) {
| 928 |
sprintf(errmsg, "write error on file '%s'", e->key);
| 929 |
| 930 |
| 931 |
return 0;
| 932 |
| 933 |
| 934 |
/* put out ray contribution to file */
| 935 |
void
| 936 |
| 937 |
| 938 |
float fv[3];
| 939 |
COLR cv;
| 940 |
| 941 |
switch (outfmt) {
| 942 |
case 'a':
| 943 |
fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
| 944 |
break;
| 945 |
case 'f':
| 946 |
copycolor(fv, cnt);
| 947 |
fwrite(fv, sizeof(float), 3, fout);
| 948 |
break;
| 949 |
case 'd':
| 950 |
fwrite(cnt, sizeof(double), 3, fout);
| 951 |
break;
| 952 |
case 'c':
| 953 |
setcolr(cv, cnt[0], cnt[1], cnt[2]);
| 954 |
fwrite(cv, sizeof(cv), 1, fout);
| 955 |
break;
| 956 |
default:
| 957 |
error(INTERNAL, "botched output format");
| 958 |
| 959 |
| 960 |
| 961 |
/* output ray tallies and clear for next accumulation */
| 962 |
void
| 963 |
| 964 |
| 965 |
double sf = 1.;
| 966 |
int i, j;
| 967 |
MODCONT *mp;
| 968 |
STREAMOUT *sop;
| 969 |
/* set average scaling */
| 970 |
if (navg > 1)
| 971 |
sf = 1. / (double)navg;
| 972 |
/* output modifiers in order */
| 973 |
for (i = 0; i < nmods; i++) {
| 974 |
mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
| 975 |
if (navg > 1) /* average scaling */
| 976 |
for (j = mp->nbins; j--; )
| 977 |
scalecolor(mp->cbin[j], sf);
| 978 |
sop = getostream(mp->outspec, mp->modname, 0,0);
| 979 |
put_contrib(mp->cbin[0], sop->ofp);
| 980 |
if (mp->nbins > 3 && /* minor optimization */
| 981 |
sop == getostream(mp->outspec, mp->modname, 1,0))
| 982 |
for (j = 1; j < mp->nbins; j++)
| 983 |
put_contrib(mp->cbin[j], sop->ofp);
| 984 |
else
| 985 |
| 986 |
| 987 |
getostream(mp->outspec,mp->modname,j,0)->ofp);
| 988 |
/* clear for next time */
| 989 |
memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
| 990 |
| 991 |
--waitflush; /* terminate records */
| 992 |
lu_doall(&ofiletab, puteol, NULL);
| 993 |
if (using_stdout & (outfmt == 'a'))
| 994 |
putc('\n', stdout);
| 995 |
if (!waitflush) {
| 996 |
| 997 |
if (using_stdout)
| 998 |
fflush(stdout);
| 999 |
| 1000 |
| 1001 |
| 1002 |
/* queue completed ray tree produced by rtrace process */
| 1003 |
void
| 1004 |
| 1005 |
| 1006 |
struct rtproc *rtu, *rtl = NULL;
| 1007 |
/* insert following ray order */
| 1008 |
for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
| 1009 |
if (rtp->raynum < rtu->raynum)
| 1010 |
break;
| 1011 |
rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
| 1012 |
if (rtu == NULL)
| 1013 |
error(SYSTEM, "out of memory in queue_raytree");
| 1014 |
*rtu = *rtp;
| 1015 |
if (rtl == NULL) {
| 1016 |
rtu->next = rt_unproc;
| 1017 |
rt_unproc = rtu;
| 1018 |
} else {
| 1019 |
rtu->next = rtl->next;
| 1020 |
rtl->next = rtu;
| 1021 |
| 1022 |
rtp->raynum = 0; /* clear path for next ray tree */
| 1023 |
rtp->bsiz = 0;
| 1024 |
rtp->buf = NULL;
| 1025 |
rtp->nbr = 0;
| 1026 |
| 1027 |
| 1028 |
/* process completed ray trees from our queue */
| 1029 |
void
| 1030 |
process_queue(void)
| 1031 |
| 1032 |
char modname[128];
| 1033 |
/* ray-ordered queue */
| 1034 |
while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
| 1035 |
struct rtproc *rtp = rt_unproc;
| 1036 |
int n = rtp->nbr;
| 1037 |
const char *cp = rtp->buf;
| 1038 |
while (n > 0) { /* process rays */
| 1039 |
register char *mnp = modname;
| 1040 |
/* skip leading tabs */
| 1041 |
while (n > 0 && *cp == '\t') {
| 1042 |
cp++; n--;
| 1043 |
| 1044 |
if (!n || !(isalpha(*cp) | (*cp == '_')))
| 1045 |
error(USER, "bad modifier name from rtrace");
| 1046 |
/* get modifier name */
| 1047 |
while (n > 1 && *cp != '\t') {
| 1048 |
if (mnp - modname >= sizeof(modname)-2)
| 1049 |
error(INTERNAL, "modifier name too long");
| 1050 |
*mnp++ = *cp++; n--;
| 1051 |
| 1052 |
*mnp = '\0';
| 1053 |
cp++; n--; /* eat following tab */
| 1054 |
if (n < (int)(sizeof(float)*9))
| 1055 |
error(USER, "incomplete ray value from rtrace");
| 1056 |
/* add ray contribution */
| 1057 |
memcpy(rparams, cp, sizeof(float)*9);
| 1058 |
cp += sizeof(float)*9; n -= sizeof(float)*9;
| 1059 |
add_contrib(modname);
| 1060 |
| 1061 |
/* time to produce record? */
| 1062 |
if (account > 0 && !--account)
| 1063 |
done_contrib(account = accumulate);
| 1064 |
lastdone = rtp->raynum;
| 1065 |
if (rtp->buf != NULL) /* free up buffer space */
| 1066 |
free(rtp->buf);
| 1067 |
rt_unproc = rtp->next;
| 1068 |
free(rtp); /* done with this ray tree */
| 1069 |
| 1070 |
| 1071 |
| 1072 |
/* wait for rtrace process to finish with ray tree */
| 1073 |
struct rtproc *
| 1074 |
wait_rproc(void)
| 1075 |
| 1076 |
struct rtproc *rtfree = NULL;
| 1077 |
fd_set readset, errset;
| 1078 |
ssize_t nr;
| 1079 |
struct rtproc *rt;
| 1080 |
int n;
| 1081 |
| 1082 |
do {
| 1083 |
nr = 0; /* prepare select call */
| 1084 |
FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
| 1085 |
for (rt = &rt0; rt != NULL; rt = rt->next) {
| 1086 |
if (rt->raynum) {
| 1087 |
FD_SET(rt->pd.r, &readset);
| 1088 |
++nr;
| 1089 |
| 1090 |
FD_SET(rt->pd.r, &errset);
| 1091 |
if (rt->pd.r >= n)
| 1092 |
n = rt->pd.r + 1;
| 1093 |
| 1094 |
if (!nr) /* no rays pending */
| 1095 |
break;
| 1096 |
if (nr > 1) { /* call select for multiple proc's */
| 1097 |
errno = 0;
| 1098 |
if (select(n, &readset, NULL, &errset, NULL) < 0)
| 1099 |
error(SYSTEM, "select call error in wait_rproc()");
| 1100 |
} else
| 1101 |
FD_ZERO(&errset);
| 1102 |
nr = 0;
| 1103 |
| 1104 |
if (!FD_ISSET(rt->pd.r, &readset) &&
| 1105 |
!FD_ISSET(rt->pd.r, &errset))
| 1106 |
continue;
| 1107 |
if (rt->buf == NULL) {
| 1108 |
rt->bsiz = treebufsiz;
| 1109 |
rt->buf = (char *)malloc(treebufsiz);
| 1110 |
} else if (rt->nbr + BUFSIZ > rt->bsiz) {
| 1111 |
if (rt->bsiz + BUFSIZ <= treebufsiz)
| 1112 |
| 1113 |
else
| 1114 |
treebufsiz = rt->bsiz += BUFSIZ;
| 1115 |
rt->buf = (char *)realloc(rt->buf, rt->bsiz);
| 1116 |
| 1117 |
| 1118 |
error(SYSTEM, "out of memory in wait_rproc");
| 1119 |
nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
| 1120 |
if (nr <= 0)
| 1121 |
error(USER, "rtrace process died");
| 1122 |
rt->nbr += nr; /* advance & check */
| 1123 |
if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4,
| 1124 |
"~\t~\t", 4)) {
| 1125 |
rt->nbr -= 4; /* elide terminator */
| 1126 |
queue_raytree(rt);
| 1127 |
rtfree = rt; /* ready for next ray */
| 1128 |
| 1129 |
| 1130 |
} while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
| 1131 |
return rtfree;
| 1132 |
| 1133 |
| 1134 |
/* return next available rtrace process */
| 1135 |
struct rtproc *
| 1136 |
get_rproc(void)
| 1137 |
| 1138 |
struct rtproc *rtp;
| 1139 |
/* check for idle rtrace */
| 1140 |
| 1141 |
if (!rtp->raynum)
| 1142 |
return rtp;
| 1143 |
return wait_rproc(); /* need to wait for one */
| 1144 |
| 1145 |
| 1146 |
/* trace ray contributions (main loop) */
| 1147 |
void
| 1148 |
| 1149 |
| 1150 |
static int ignore_warning_given = 0;
| 1151 |
char inpbuf[128];
| 1152 |
int iblen;
| 1153 |
struct rtproc *rtp;
| 1154 |
/* loop over input */
| 1155 |
while ((iblen = getinp(inpbuf, fin)) >= 0) {
| 1156 |
if (!iblen && accumulate != 1) {
| 1157 |
if (!ignore_warning_given++)
| 1158 |
error(WARNING,
| 1159 |
"dummy ray(s) ignored during accumulation\n");
| 1160 |
continue;
| 1161 |
| 1162 |
if (!iblen || /* need flush/reset? */
| 1163 |
queue_length() > 10*nrtprocs() ||
| 1164 |
lastray+1 < lastray) {
| 1165 |
while (wait_rproc() != NULL)
| 1166 |
process_queue();
| 1167 |
if (lastray+1 < lastray)
| 1168 |
lastdone = lastray = 0;
| 1169 |
| 1170 |
rtp = get_rproc(); /* get avail. rtrace process */
| 1171 |
rtp->raynum = ++lastray; /* assign ray */
| 1172 |
if (iblen) { /* trace ray if valid */
| 1173 |
writebuf(rtp->pd.w, inpbuf, iblen);
| 1174 |
} else { /* else bypass dummy ray */
| 1175 |
queue_raytree(rtp); /* queue empty ray/record */
| 1176 |
if ((yres <= 0) | (xres <= 0))
| 1177 |
waitflush = 1; /* flush right after */
| 1178 |
| 1179 |
process_queue(); /* catch up with results */
| 1180 |
if (raysleft && !--raysleft)
| 1181 |
break; /* preemptive EOI */
| 1182 |
| 1183 |
while (wait_rproc() != NULL) /* process outstanding rays */
| 1184 |
process_queue();
| 1185 |
| 1186 |
done_contrib(0); /* output tallies */
| 1187 |
else if (account < accumulate) {
| 1188 |
error(WARNING, "partial accumulation in final record");
| 1189 |
done_contrib(accumulate - account);
| 1190 |
| 1191 |
if (raysleft)
| 1192 |
error(USER, "unexpected EOF on input");
| 1193 |
lu_done(&ofiletab); /* close output files */
| 1194 |
| 1195 |
| 1196 |
/* get ray contribution from previous file */
| 1197 |
static int
| 1198 |
get_contrib(DCOLOR cnt, FILE *finp)
| 1199 |
| 1200 |
COLOR fv;
| 1201 |
COLR cv;
| 1202 |
| 1203 |
switch (outfmt) {
| 1204 |
case 'a':
| 1205 |
return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3);
| 1206 |
case 'f':
| 1207 |
if (fread(fv, sizeof(fv[0]), 3, finp) != 3)
| 1208 |
return(0);
| 1209 |
copycolor(cnt, fv);
| 1210 |
return(1);
| 1211 |
case 'd':
| 1212 |
return(fread(cnt, sizeof(cnt[0]), 3, finp) == 3);
| 1213 |
case 'c':
| 1214 |
if (fread(cv, sizeof(cv), 1, finp) != 1)
| 1215 |
return(0);
| 1216 |
colr_color(fv, cv);
| 1217 |
copycolor(cnt, fv);
| 1218 |
return(1);
| 1219 |
default:
| 1220 |
| 1221 |
| 1222 |
return(0); /* pro forma return */
| 1223 |
| 1224 |
| 1225 |
/* close output file opened for input */
| 1226 |
static int
| 1227 |
myclose(const LUENT *e, void *p)
| 1228 |
| 1229 |
| 1230 |
| 1231 |
| 1232 |
return(0);
| 1233 |
fclose(sop->ofp);
| 1234 |
sop->ofp = NULL;
| 1235 |
return(0);
| 1236 |
| 1237 |
| 1238 |
/* load previously accumulated values */
| 1239 |
void
| 1240 |
reload_output(void)
| 1241 |
| 1242 |
int i, j;
| 1243 |
MODCONT *mp;
| 1244 |
int ofl;
| 1245 |
char oname[1024];
| 1246 |
char *fmode = "rb";
| 1247 |
char *outvfmt;
| 1248 |
LUENT *ment, *oent;
| 1249 |
int xr, yr;
| 1250 |
STREAMOUT sout;
| 1251 |
DCOLOR rgbv;
| 1252 |
| 1253 |
switch (outfmt) {
| 1254 |
case 'a':
| 1255 |
outvfmt = "ascii";
| 1256 |
fmode = "r";
| 1257 |
break;
| 1258 |
case 'f':
| 1259 |
outvfmt = "float";
| 1260 |
break;
| 1261 |
case 'd':
| 1262 |
outvfmt = "double";
| 1263 |
break;
| 1264 |
case 'c':
| 1265 |
outvfmt = COLRFMT;
| 1266 |
break;
| 1267 |
default:
| 1268 |
| 1269 |
return;
| 1270 |
| 1271 |
/* reload modifier values */
| 1272 |
| 1273 |
ment = lu_find(&modconttab,modname[i]);
| 1274 |
mp = (MODCONT *)ment->data;
| 1275 |
if (mp->outspec == NULL)
| 1276 |
error(USER, "cannot reload from stdout");
| 1277 |
if (mp->outspec[0] == '!')
| 1278 |
error(USER, "cannot reload from command");
| 1279 |
for (j = 0; ; j++) { /* load each modifier bin */
| 1280 |
ofl = ofname(oname, mp->outspec, mp->modname, j);
| 1281 |
if (ofl < 0)
| 1282 |
error(USER, "bad output file specification");
| 1283 |
oent = lu_find(&ofiletab, oname);
| 1284 |
if (oent->data != NULL) {
| 1285 |
sout = *(STREAMOUT *)oent->data;
| 1286 |
} else {
| 1287 |
sout.reclen = 0;
| 1288 |
sout.outpipe = 0;
| 1289 |
sout.xr = xres; sout.yr = yres;
| 1290 |
sout.ofp = NULL;
| 1291 |
| 1292 |
if (sout.ofp == NULL) { /* open output as input */
| 1293 |
sout.ofp = fopen(oname, fmode);
| 1294 |
| 1295 |
if (j)
| 1296 |
break; /* assume end of modifier */
| 1297 |
sprintf(errmsg, "missing reload file '%s'",
| 1298 |
oname);
| 1299 |
error(WARNING, errmsg);
| 1300 |
break;
| 1301 |
| 1302 |
if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
| 1303 |
sprintf(errmsg, "format mismatch for '%s'",
| 1304 |
oname);
| 1305 |
| 1306 |
| 1307 |
if ((sout.xr > 0) & (sout.yr > 0) &&
| 1308 |
(!fscnresolu(&xr, &yr, sout.ofp) ||
| 1309 |
(xr != sout.xr) |
| 1310 |
(yr != sout.yr))) {
| 1311 |
sprintf(errmsg, "resolution mismatch for '%s'",
| 1312 |
oname);
| 1313 |
| 1314 |
| 1315 |
| 1316 |
/* read in RGB value */
| 1317 |
if (!get_contrib(rgbv, sout.ofp)) {
| 1318 |
if (!j) {
| 1319 |
fclose(sout.ofp);
| 1320 |
break; /* ignore empty file */
| 1321 |
| 1322 |
if (j < mp->nbins) {
| 1323 |
sprintf(errmsg, "missing data in '%s'",
| 1324 |
oname);
| 1325 |
| 1326 |
| 1327 |
break;
| 1328 |
| 1329 |
if (j >= mp->nbins) /* grow modifier size */
| 1330 |
ment->data = (char *)(mp = growmodifier(mp, j+1));
| 1331 |
copycolor(mp->cbin[j], rgbv);
| 1332 |
if (oent->key == NULL) /* new file entry */
| 1333 |
oent->key = strcpy((char *)
| 1334 |
| 1335 |
if (oent->data == NULL)
| 1336 |
oent->data = (char *)malloc(sizeof(STREAMOUT));
| 1337 |
*(STREAMOUT *)oent->data = sout;
| 1338 |
| 1339 |
| 1340 |
lu_doall(&ofiletab, myclose, NULL); /* close all files */
| 1341 |
| 1342 |
| 1343 |
/* seek on the given output file */
| 1344 |
static int
| 1345 |
myseeko(const LUENT *e, void *p)
| 1346 |
| 1347 |
| 1348 |
off_t nbytes = *(off_t *)p;
| 1349 |
| 1350 |
if (sop->reclen > 1)
| 1351 |
nbytes = nbytes * sop->reclen;
| 1352 |
if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) {
| 1353 |
sprintf(errmsg, "seek error on file '%s'", e->key);
| 1354 |
| 1355 |
| 1356 |
return 0;
| 1357 |
| 1358 |
| 1359 |
/* recover output if possible */
| 1360 |
void
| 1361 |
| 1362 |
| 1363 |
off_t lastout = -1;
| 1364 |
int outvsiz, recsiz;
| 1365 |
char *outvfmt;
| 1366 |
int i, j;
| 1367 |
MODCONT *mp;
| 1368 |
int ofl;
| 1369 |
char oname[1024];
| 1370 |
LUENT *ment, *oent;
| 1371 |
STREAMOUT sout;
| 1372 |
off_t nvals;
| 1373 |
int xr, yr;
| 1374 |
| 1375 |
switch (outfmt) {
| 1376 |
case 'a':
| 1377 |
error(USER, "cannot recover ASCII output");
| 1378 |
return;
| 1379 |
case 'f':
| 1380 |
outvsiz = sizeof(float)*3;
| 1381 |
outvfmt = "float";
| 1382 |
break;
| 1383 |
case 'd':
| 1384 |
outvsiz = sizeof(double)*3;
| 1385 |
outvfmt = "double";
| 1386 |
break;
| 1387 |
case 'c':
| 1388 |
outvsiz = sizeof(COLR);
| 1389 |
outvfmt = COLRFMT;
| 1390 |
break;
| 1391 |
default:
| 1392 |
| 1393 |
return;
| 1394 |
| 1395 |
/* check modifier outputs */
| 1396 |
| 1397 |
| 1398 |
| 1399 |
| 1400 |
error(USER, "cannot recover from stdout");
| 1401 |
| 1402 |
error(USER, "cannot recover from command");
| 1403 |
for (j = 0; ; j++) { /* check each bin's file */
| 1404 |
| 1405 |
if (ofl < 0)
| 1406 |
| 1407 |
| 1408 |
| 1409 |
| 1410 |
} else {
| 1411 |
sout.reclen = 0;
| 1412 |
sout.outpipe = 0;
| 1413 |
sout.ofp = NULL;
| 1414 |
| 1415 |
if (sout.ofp != NULL) { /* already open? */
| 1416 |
if (ofl & OF_BIN)
| 1417 |
continue;
| 1418 |
break;
| 1419 |
| 1420 |
/* open output */
| 1421 |
sout.ofp = fopen(oname, "rb+");
| 1422 |
| 1423 |
if (j)
| 1424 |
| 1425 |
sprintf(errmsg, "missing recover file '%s'",
| 1426 |
oname);
| 1427 |
| 1428 |
break;
| 1429 |
| 1430 |
nvals = lseek(fileno(sout.ofp), 0, SEEK_END);
| 1431 |
if (nvals <= 0) {
| 1432 |
lastout = 0; /* empty output, quit here */
| 1433 |
fclose(sout.ofp);
| 1434 |
break;
| 1435 |
| 1436 |
if (!sout.reclen) {
| 1437 |
if (!(ofl & OF_BIN)) {
| 1438 |
sprintf(errmsg,
| 1439 |
"need -bn to recover file '%s'",
| 1440 |
oname);
| 1441 |
| 1442 |
| 1443 |
recsiz = outvsiz;
| 1444 |
} else
| 1445 |
recsiz = outvsiz * sout.reclen;
| 1446 |
| 1447 |
lseek(fileno(sout.ofp), 0, SEEK_SET);
| 1448 |
| 1449 |
| 1450 |
oname);
| 1451 |
| 1452 |
| 1453 |
| 1454 |
| 1455 |
| 1456 |
(xr != sout.xr) |
| 1457 |
(yr != sout.yr))) {
| 1458 |
| 1459 |
oname);
| 1460 |
| 1461 |
| 1462 |
nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz;
| 1463 |
if ((lastout < 0) | (nvals < lastout))
| 1464 |
lastout = nvals;
| 1465 |
if (oent->key == NULL) /* new entry */
| 1466 |
| 1467 |
| 1468 |
| 1469 |
| 1470 |
| 1471 |
| 1472 |
break; /* no bin separation */
| 1473 |
| 1474 |
if (!lastout) { /* empty output */
| 1475 |
error(WARNING, "no previous data to recover");
| 1476 |
lu_done(&ofiletab); /* reclose all outputs */
| 1477 |
return;
| 1478 |
| 1479 |
if (j > mp->nbins) /* reallocate modifier bins */
| 1480 |
ment->data = (char *)(mp = growmodifier(mp, j));
| 1481 |
| 1482 |
if (lastout < 0) {
| 1483 |
error(WARNING, "no output files to recover");
| 1484 |
return;
| 1485 |
| 1486 |
if (raysleft && lastout >= raysleft/accumulate) {
| 1487 |
error(WARNING, "output appears to be complete");
| 1488 |
/* XXX should read & discard input? */
| 1489 |
quit(0);
| 1490 |
| 1491 |
/* seek on all files */
| 1492 |
nvals = lastout * outvsiz;
| 1493 |
lu_doall(&ofiletab, myseeko, &nvals);
| 1494 |
/* skip repeated input */
| 1495 |
for (nvals = 0; nvals < lastout; nvals++)
| 1496 |
if (getinp(oname, fin) < 0)
| 1497 |
| 1498 |
lastray = lastdone = (unsigned long)lastout * accumulate;
| 1499 |
if (raysleft)
| 1500 |
raysleft -= lastray;
| 1501 |
