root/radiance/ray/src/util/rtcontrib.c
Revision: 1.54
Committed: Sun Jun 14 18:21:58 2009 UTC (14 years, 10 months ago) by greg
Changes since 1.53: +16 -11 lines
Added ability to specify constant name in rtcontrib -bn option
2 static const char RCSid[] = "$Id: rtcontrib.c,v 1.53 2009/06/11 18:32:24 greg Exp $";
5 * Gather rtrace output to compute contributions from particular sources
6 */
7
8 #include "standard.h"
9 #include <ctype.h>
10 #include <signal.h>
11 #include "platform.h"
12 #include "rtprocess.h"
13 #include "selcall.h"
14 #include "color.h"
15 #include "resolu.h"
16 #include "lookup.h"
17 #include "calcomp.h"
18
19 #ifndef MAXMODLIST
20 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
21 #endif
22
23 int treebufsiz = BUFSIZ; /* current tree buffer size */
24
25 typedef double DCOLOR[3]; /* double-precision color */
26
27 /*
28 * The MODCONT structure is used to accumulate ray contributions
29 * for a particular modifier, which may be subdivided into bins
30 * if binv evaluates > 0. If outspec contains a %s in it, this will
31 * be replaced with the modifier name. If outspec contains a %d in it,
32 * this will be used to create one output file per bin, otherwise all bins
33 * will be written to the same file, in order. If the global outfmt
34 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
35 * and the file will conform to a RADIANCE image if xres & yres are set.
36 */
37 typedef struct {
38 const char *outspec; /* output file specification */
39 const char *modname; /* modifier name */
40 EPNODE *binv; /* bin value expression */
41 int nbins; /* number of accumulation bins */
42 DCOLOR cbin[1]; /* contribution bins (extends struct) */
43 } MODCONT; /* modifier contribution */
44
45 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
46
47 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
48
49 /*
50 * The STREAMOUT structure holds an open FILE pointer and a count of
51 * the number of RGB triplets per record, or 0 if unknown.
52 */
53 typedef struct {
54 FILE *ofp; /* output file pointer */
55 int outpipe; /* output is to a pipe */
56 int reclen; /* triplets/record */
57 int xr, yr; /* output resolution for picture */
58 } STREAMOUT;
59
60 /* close output stream and free record */
61 static void
62 closestream(void *p)
63 {
64 STREAMOUT *sop = (STREAMOUT *)p;
65 int status;
66 if (sop->outpipe)
67 status = pclose(sop->ofp);
68 else
69 status = fclose(sop->ofp);
70 if (status)
71 error(SYSTEM, "error closing output stream");
72 free(p);
73 }
74
75 LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
76
77 #define OF_MODIFIER 01
78 #define OF_BIN 02
79
80 STREAMOUT *getostream(const char *ospec, const char *mname, int bn, int noopen);
81 int ofname(char *oname, const char *ospec, const char *mname, int bn);
82 void printheader(FILE *fout, const char *info);
83 void printresolu(FILE *fout, int xr, int yr);
84
85 /*
86 * The rcont structure is used to manage i/o with a particular
87 * rtrace child process. Input is passed unchanged from stdin,
88 * and output is processed in input order and accumulated according
89 * to the corresponding modifier and bin number.
90 */
91 struct rtproc {
92 struct rtproc *next; /* next in list of processes */
93 SUBPROC pd; /* rtrace pipe descriptors */
94 unsigned long raynum; /* ray number for this tree */
95 int bsiz; /* ray tree buffer length */
96 char *buf; /* ray tree buffer */
97 int nbr; /* number of bytes from rtrace */
98 }; /* rtrace process buffer */
99
100 /* rtrace command and defaults */
101 char *rtargv[256+2*MAXMODLIST] = { "rtrace",
102 "-dj", ".9", "-dr", "3",
103 "-ab", "1", "-ad", "350", };
104
105 int rtargc = 9;
106 /* overriding rtrace options */
107 char *myrtopts[] = { "-h-", "-x", "1", "-y", "0",
108 "-dt", "0", "-as", "0", "-aa", "0", NULL };
109
110 #define RTCOEFF "-o~~TmWdp" /* compute coefficients only */
111 #define RTCONTRIB "-o~~TmVdp" /* compute ray contributions */
112
113 struct rtproc rt0; /* head of rtrace process list */
114
115 struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
116
117 #define PERSIST_NONE 0 /* no persist file */
118 #define PERSIST_SINGLE 1 /* user set -P persist */
119 #define PERSIST_PARALL 2 /* user set -PP persist */
120 #define PERSIST_OURS 3 /* -PP persist belongs to us */
121 int persist_state = PERSIST_NONE; /* persist file state */
122 char persistfn[] = "pfXXXXXX"; /* our persist file name, if set */
123
124 int gargc; /* global argc */
125 char **gargv; /* global argv */
126 #define progname gargv[0]
127
128 char *octree; /* global octree argument */
129
130 int inpfmt = 'a'; /* input format */
131 int outfmt = 'a'; /* output format */
132
133 int header = 1; /* output header? */
134 int force_open = 0; /* truncate existing output? */
135 int recover = 0; /* recover previous output? */
136 int accumulate = 1; /* input rays per output record */
137 int xres = 0; /* horiz. output resolution */
138 int yres = 0; /* vert. output resolution */
139
140 int account; /* current accumulation count */
141 unsigned long raysleft; /* number of rays left to trace */
142 long waitflush; /* how long until next flush */
143
144 unsigned long lastray = 0; /* last ray number sent */
145 unsigned long lastdone = 0; /* last ray processed */
146
147 int using_stdout = 0; /* are we using stdout? */
148
149 const char *modname[MAXMODLIST]; /* ordered modifier name list */
150 int nmods = 0; /* number of modifiers */
151
152 #define queue_length() (lastray - lastdone)
153
154 MODCONT *growmodifier(MODCONT *mp, int nb);
155 MODCONT *addmodifier(char *modn, char *outf, char *binv, int bincnt);
156 void addmodfile(char *fname, char *outf, char *binv, int bincnt);
157
158 void init(int np);
159 int done_rprocs(struct rtproc *rtp);
160 void reload_output(void);
161 void recover_output(FILE *fin);
162 void trace_contribs(FILE *fin);
163 struct rtproc *wait_rproc(void);
164 struct rtproc *get_rproc(void);
165 void queue_raytree(struct rtproc *rtp);
166 void process_queue(void);
167
168 void put_contrib(const DCOLOR cnt, FILE *fout);
169 void add_contrib(const char *modn);
170 void done_contrib(int navg);
171
172 /* return number of open rtrace processes */
173 static int
174 nrtprocs(void)
175 {
176 int nrtp = 0;
177 struct rtproc *rtp;
178
179 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
180 nrtp += rtp->pd.running;
181 return(nrtp);
182 }
183
184 /* set input/output format */
185 static void
186 setformat(const char *fmt)
187 {
188 switch (fmt[0]) {
189 case 'f':
190 case 'd':
191 SET_FILE_BINARY(stdin);
192 /* fall through */
193 case 'a':
194 inpfmt = fmt[0];
195 break;
196 default:
197 goto fmterr;
198 }
199 switch (fmt[1]) {
200 case '\0':
201 outfmt = inpfmt;
202 return;
203 case 'a':
204 case 'f':
205 case 'd':
206 case 'c':
207 outfmt = fmt[1];
208 break;
209 default:
210 goto fmterr;
211 }
212 if (!fmt[2])
213 return;
214 fmterr:
215 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
216 error(USER, errmsg);
217 }
218
219 /* gather rays from rtrace and output contributions */
220 int
221 main(int argc, char *argv[])
222 {
223 int contrib = 0;
224 int nprocs = 1;
225 char *curout = NULL;
226 char *binval = NULL;
227 int bincnt = 0;
228 char fmt[8];
229 int i, j;
230 /* need at least one argument */
231 if (argc < 2) {
232 fprintf(stderr,
233 "Usage: %s [-n nprocs][-V][-r][-e expr][-f source][-o ospec][-b binv] {-m mod | -M file} [rtrace options] octree\n",
234 argv[0]);
235 exit(1);
236 }
237 /* global program name */
238 gargv = argv;
239 /* initialize calcomp routines */
240 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
241 esupport &= ~(E_OUTCHAN);
242 varset("PI", ':', PI);
243 /* get our options */
244 for (i = 1; i < argc-1; i++) {
245 /* expand arguments */
246 while ((j = expandarg(&argc, &argv, i)) > 0)
247 ;
248 if (j < 0) {
249 fprintf(stderr, "%s: cannot expand '%s'\n",
250 argv[0], argv[i]);
251 exit(1);
252 }
253 if (argv[i][0] == '-')
254 switch (argv[i][1]) {
255 case 'n': /* number of processes */
256 if (argv[i][2] || i >= argc-2) break;
257 nprocs = atoi(argv[++i]);
258 if (nprocs <= 0)
259 error(USER, "illegal number of processes");
260 continue;
261 case 'V': /* output contributions */
262 switch (argv[i][2]) {
263 case '\0':
264 contrib = !contrib;
265 continue;
266 case '+': case '1':
267 case 'T': case 't':
268 case 'Y': case 'y':
269 contrib = 1;
270 continue;
271 case '-': case '0':
272 case 'F': case 'f':
273 case 'N': case 'n':
274 contrib = 0;
275 continue;
276 }
277 break;
278 case 'c': /* input rays per output */
279 if (argv[i][2] || i >= argc-2) break;
280 accumulate = atoi(argv[++i]);
281 continue;
282 case 'r': /* recover output */
283 if (argv[i][2]) break;
284 recover = 1;
285 continue;
286 case 'h': /* output header? */
287 switch (argv[i][2]) {
288 case '\0':
289 header = !header;
290 continue;
291 case '+': case '1':
292 case 'T': case 't':
293 case 'Y': case 'y':
294 header = 1;
295 continue;
296 case '-': case '0':
297 case 'F': case 'f':
298 case 'N': case 'n':
299 header = 0;
300 continue;
301 }
302 break;
303 case 'f': /* file or force or format */
304 if (!argv[i][2]) {
305 char *fpath;
306 if (i >= argc-2) break;
307 fpath = getpath(argv[++i],
308 getrlibpath(), R_OK);
309 if (fpath == NULL) {
310 sprintf(errmsg,
311 "cannot find file '%s'",
312 argv[i]);
313 error(USER, errmsg);
314 }
315 fcompile(fpath);
316 continue;
317 }
318 if (argv[i][2] == 'o') {
319 force_open = 1;
320 continue;
321 }
322 setformat(argv[i]+2);
323 continue;
324 case 'e': /* expression */
325 if (argv[i][2] || i >= argc-2) break;
326 scompile(argv[++i], NULL, 0);
327 continue;
328 case 'o': /* output file spec. */
329 if (argv[i][2] || i >= argc-2) break;
330 curout = argv[++i];
331 continue;
332 case 'x': /* horiz. output resolution */
333 if (argv[i][2] || i >= argc-2) break;
334 xres = atoi(argv[++i]);
335 continue;
336 case 'y': /* vert. output resolution */
337 if (argv[i][2] || i >= argc-2) break;
338 yres = atoi(argv[++i]);
339 continue;
340 case 'b': /* bin expression/count */
341 if (i >= argc-2) break;
342 if (argv[i][2] == 'n') {
343 bincnt = (int)(eval(argv[++i]) + .5);
344 continue;
345 }
346 if (argv[i][2]) break;
347 binval = argv[++i];
348 continue;
349 case 'm': /* modifier name */
350 if (argv[i][2] || i >= argc-2) break;
351 rtargv[rtargc++] = "-ti";
352 rtargv[rtargc++] = argv[++i];
353 addmodifier(argv[i], curout, binval, bincnt);
354 continue;
355 case 'M': /* modifier file */
356 if (argv[i][2] || i >= argc-2) break;
357 rtargv[rtargc++] = "-tI";
358 rtargv[rtargc++] = argv[++i];
359 addmodfile(argv[i], curout, binval, bincnt);
360 continue;
361 case 'P': /* persist file */
362 if (i >= argc-2) break;
363 persist_state = (argv[i][2] == 'P') ?
364 PERSIST_PARALL : PERSIST_SINGLE;
365 rtargv[rtargc++] = argv[i];
366 rtargv[rtargc++] = argv[++i];
367 continue;
368 }
369 rtargv[rtargc++] = argv[i]; /* assume rtrace option */
370 }
371 if (accumulate <= 0) /* no output flushing for single record */
372 xres = yres = 0;
373 /* set global argument list */
374 gargc = argc; gargv = argv;
375 /* add "mandatory" rtrace settings */
376 for (j = 0; myrtopts[j] != NULL; j++)
377 rtargv[rtargc++] = myrtopts[j];
378 rtargv[rtargc++] = contrib ? RTCONTRIB : RTCOEFF;
379 /* just asking for defaults? */
380 if (!strcmp(argv[i], "-defaults")) {
381 char sxres[16], syres[16];
382 char *rtpath;
383 printf("-n %-2d\t\t\t\t# number of processes\n", nprocs);
384 printf("-c %-5d\t\t\t# accumulated rays per record\n",
385 accumulate);
386 printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-',
387 contrib ? "contributions" : "coefficients");
388 fflush(stdout); /* report OUR options */
389 rtargv[rtargc++] = header ? "-h+" : "-h-";
390 sprintf(fmt, "-f%c%c", inpfmt, outfmt);
391 rtargv[rtargc++] = fmt;
392 rtargv[rtargc++] = "-x";
393 sprintf(sxres, "%d", xres);
394 rtargv[rtargc++] = sxres;
395 rtargv[rtargc++] = "-y";
396 sprintf(syres, "%d", yres);
397 rtargv[rtargc++] = syres;
398 rtargv[rtargc++] = "-defaults";
399 rtargv[rtargc] = NULL;
400 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
401 if (rtpath == NULL) {
402 eputs(rtargv[0]);
403 eputs(": command not found\n");
404 exit(1);
405 }
406 execv(rtpath, rtargv);
407 perror(rtpath); /* execv() should not return */
408 exit(1);
409 }
410 if (nprocs > 1) { /* add persist file if parallel */
411 if (persist_state == PERSIST_SINGLE)
412 error(USER, "use -PP option for multiple processes");
413 if (persist_state == PERSIST_NONE) {
414 rtargv[rtargc++] = "-PP";
415 rtargv[rtargc++] = mktemp(persistfn);
416 persist_state = PERSIST_OURS;
417 }
418 }
419 /* add format string */
420 sprintf(fmt, "-f%cf", inpfmt);
421 rtargv[rtargc++] = fmt;
422 /* octree argument is last */
423 if (i <= 0 || i != argc-1 || argv[i][0] == '-')
424 error(USER, "missing octree argument");
425 rtargv[rtargc++] = octree = argv[i];
426 rtargv[rtargc] = NULL;
427 /* start rtrace & recover if requested */
428 init(nprocs);
429 /* compute contributions */
430 trace_contribs(stdin);
431 /* clean up */
432 quit(0);
433 }
434
435 #ifndef SIGALRM
436 #define SIGALRM SIGTERM
437 #endif
438 /* kill persistent rtrace process */
439 static void
440 killpersist(void)
441 {
442 FILE *fp = fopen(persistfn, "r");
443 RT_PID pid;
444
445 if (fp == NULL)
446 return;
447 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
448 unlink(persistfn);
449 fclose(fp);
450 }
451
452 /* close rtrace processes and clean up */
453 int
454 done_rprocs(struct rtproc *rtp)
455 {
456 int st0, st1 = 0;
457
458 if (rtp->next != NULL) { /* close last opened first! */
459 st1 = done_rprocs(rtp->next);
460 free((void *)rtp->next);
461 rtp->next = NULL;
462 }
463 st0 = close_process(&rtp->pd);
464 if (st0 < 0)
465 error(WARNING, "unknown return status from rtrace process");
466 else if (st0 > 0)
467 return(st0);
468 return(st1);
469 }
470
471 /* exit with status */
472 void
473 quit(int status)
474 {
475 int rtstat;
476
477 if (persist_state == PERSIST_OURS) /* terminate waiting rtrace */
478 killpersist();
479 /* clean up rtrace process(es) */
480 rtstat = done_rprocs(&rt0);
481 if (status == 0)
482 status = rtstat;
483 exit(status); /* flushes all output streams */
484 }
485
486 /* start rtrace processes and initialize */
487 void
488 init(int np)
489 {
490 struct rtproc *rtp;
491 int i;
492 int maxbytes;
493 /* make sure we have something to do */
494 if (!nmods)
495 error(USER, "No modifiers specified");
496 /* assign ray variables */
497 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
498 scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
499 /* set up signal handling */
500 signal(SIGINT, quit);
501 #ifdef SIGHUP
502 signal(SIGHUP, quit);
503 #endif
504 #ifdef SIGTERM
505 signal(SIGTERM, quit);
506 #endif
507 #ifdef SIGPIPE
508 signal(SIGPIPE, quit);
509 #endif
510 rtp = &rt0; /* start rtrace process(es) */
511 for (i = 0; i++ < np; ) {
512 errno = 0;
513 maxbytes = open_process(&rtp->pd, rtargv);
514 if (maxbytes == 0) {
515 eputs(rtargv[0]);
516 eputs(": command not found\n");
517 exit(1);
518 }
519 if (maxbytes < 0)
520 error(SYSTEM, "cannot start rtrace process");
521 if (maxbytes > treebufsiz)
522 treebufsiz = maxbytes;
523 rtp->raynum = 0;
524 rtp->bsiz = 0;
525 rtp->buf = NULL;
526 rtp->nbr = 0;
527 if (i == np) /* last process? */
528 break;
529 if (i == 1)
530 sleep(2); /* wait for persist file */
531 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
532 if (rtp->next == NULL)
533 error(SYSTEM, "out of memory in init");
534 rtp = rtp->next;
535 }
536 rtp->next = NULL; /* terminate list */
537 if (yres > 0) {
538 if (xres > 0)
539 raysleft = (unsigned long)xres*yres;
540 else
541 raysleft = yres;
542 } else
543 raysleft = 0;
544 if ((account = accumulate) > 0)
545 raysleft *= accumulate;
546 waitflush = xres;
547 if (!recover)
548 return;
549 /* recover previous values */
550 if (accumulate <= 0)
551 reload_output();
552 else
553 recover_output(stdin);
554 }
555
556 /* grow modifier to accommodate more bins */
557 MODCONT *
558 growmodifier(MODCONT *mp, int nb)
559 {
560 if (nb <= mp->nbins)
561 return mp;
562 mp = (MODCONT *)realloc(mp, sizeof(MODCONT) + sizeof(DCOLOR)*(nb-1));
563 if (mp == NULL)
564 error(SYSTEM, "out of memory in growmodifier");
565 memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(nb-mp->nbins));
566 mp->nbins = nb;
567 return mp;
568 }
569
570 /* add modifier to our list to track */
571 MODCONT *
572 addmodifier(char *modn, char *outf, char *binv, int bincnt)
573 {
574 LUENT *lep = lu_find(&modconttab, modn);
575 MODCONT *mp;
576 int i;
577
578 if (lep->data != NULL) {
579 sprintf(errmsg, "duplicate modifier '%s'", modn);
580 error(USER, errmsg);
581 }
582 if (nmods >= MAXMODLIST)
583 error(INTERNAL, "too many modifiers");
584 modname[nmods++] = modn; /* XXX assumes static string */
585 lep->key = modn; /* XXX assumes static string */
586 mp = (MODCONT *)malloc(sizeof(MODCONT));
587 if (mp == NULL)
588 error(SYSTEM, "out of memory in addmodifier");
589 mp->outspec = outf; /* XXX assumes static string */
590 mp->modname = modn; /* XXX assumes static string */
591 if (binv == NULL)
592 binv = "0"; /* use single bin if unspecified */
593 mp->binv = eparse(binv);
594 if (mp->binv->type == NUM) { /* check value if constant */
595 bincnt = (int)(evalue(mp->binv) + 1.5);
596 if (bincnt != 1) {
597 sprintf(errmsg, "illegal non-zero constant for bin (%s)",
598 binv);
599 error(USER, errmsg);
600 }
601 }
602 mp->nbins = 1; /* initialize results holder */
603 setcolor(mp->cbin[0], 0., 0., 0.);
604 if (bincnt > 1)
605 mp = growmodifier(mp, bincnt);
606 lep->data = (char *)mp;
607 /* allocate output streams */
608 for (i = bincnt; i-- > 0; )
609 getostream(mp->outspec, mp->modname, i, 1);
610 return mp;
611 }
612
613 /* add modifiers from a file list */
614 void
615 addmodfile(char *fname, char *outf, char *binv, int bincnt)
616 {
617 char *mname[MAXMODLIST];
618 int i;
619 /* find the file & store strings */
620 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
621 sprintf(errmsg, "cannot find modifier file '%s'", fname);
622 error(SYSTEM, errmsg);
623 }
624 for (i = 0; mname[i]; i++) /* add each one */
625 addmodifier(mname[i], outf, binv, bincnt);
626 }
627
628 /* put string to stderr */
629 void
630 eputs(char *s)
631 {
632 static int midline = 0;
633
634 if (!*s) return;
635 if (!midline) {
636 fputs(progname, stderr);
637 fputs(": ", stderr);
638 }
639 fputs(s, stderr);
640 midline = s[strlen(s)-1] != '\n';
641 }
642
643 /* construct output file name and return flags whether modifier/bin present */
644 int
645 ofname(char *oname, const char *ospec, const char *mname, int bn)
646 {
647 const char *mnp = NULL;
648 const char *bnp = NULL;
649 const char *cp;
650
651 if (ospec == NULL)
652 return -1;
653 for (cp = ospec; *cp; cp++) /* check format position(s) */
654 if (*cp == '%') {
655 do
656 ++cp;
657 while (isdigit(*cp));
658 switch (*cp) {
659 case '%':
660 break;
661 case 's':
662 if (mnp != NULL)
663 return -1;
664 mnp = cp;
665 break;
666 case 'd':
667 if (bnp != NULL)
668 return -1;
669 bnp = cp;
670 break;
671 default:
672 return -1;
673 }
674 }
675 if (mnp != NULL) { /* create file name */
676 if (bnp != NULL) {
677 if (bnp > mnp)
678 sprintf(oname, ospec, mname, bn);
679 else
680 sprintf(oname, ospec, bn, mname);
681 return OF_MODIFIER|OF_BIN;
682 }
683 sprintf(oname, ospec, mname);
684 return OF_MODIFIER;
685 }
686 if (bnp != NULL) {
687 sprintf(oname, ospec, bn);
688 return OF_BIN;
689 }
690 strcpy(oname, ospec);
691 return 0;
692 }
693
694 /* write header to the given output stream */
695 void
696 printheader(FILE *fout, const char *info)
697 {
698 extern char VersionID[];
699 FILE *fin = fopen(octree, "r");
700
701 if (fin == NULL)
702 quit(1);
703 checkheader(fin, "ignore", fout); /* copy octree header */
704 fclose(fin);
705 printargs(gargc-1, gargv, fout); /* add our command */
706 fprintf(fout, "SOFTWARE= %s\n", VersionID);
707 fputnow(fout);
708 if (info != NULL) /* add extra info if given */
709 fputs(info, fout);
710 switch (outfmt) { /* add output format */
711 case 'a':
712 fputformat("ascii", fout);
713 break;
714 case 'f':
715 fputformat("float", fout);
716 break;
717 case 'd':
718 fputformat("double", fout);
719 break;
720 case 'c':
721 fputformat(COLRFMT, fout);
722 break;
723 }
724 fputc('\n', fout);
725 }
726
727 /* write resolution string to given output stream */
728 void
729 printresolu(FILE *fout, int xr, int yr)
730 {
731 if ((xr > 0) & (yr > 0)) /* resolution string */
732 fprtresolu(xr, yr, fout);
733 if (xres > 0) /* global flush flag */
734 fflush(fout);
735 }
736
737 /* Get output stream pointer (open and write header if new and noopen==0) */
738 STREAMOUT *
739 getostream(const char *ospec, const char *mname, int bn, int noopen)
740 {
741 static const DCOLOR nocontrib = BLKCOLOR;
742 static STREAMOUT stdos;
743 int ofl;
744 char oname[1024];
745 LUENT *lep;
746 STREAMOUT *sop;
747
748 if (ospec == NULL) { /* use stdout? */
749 if (!noopen && !using_stdout) {
750 if (outfmt != 'a')
751 SET_FILE_BINARY(stdout);
752 if (header)
753 printheader(stdout, NULL);
754 printresolu(stdout, xres, yres);
755 stdos.xr = xres; stdos.yr = yres;
756 using_stdout = 1;
757 }
758 stdos.ofp = stdout;
759 stdos.reclen += noopen;
760 return &stdos;
761 }
762 ofl = ofname(oname, ospec, mname, bn); /* get output name */
763 if (ofl < 0) {
764 sprintf(errmsg, "bad output format '%s'", ospec);
765 error(USER, errmsg);
766 }
767 lep = lu_find(&ofiletab, oname); /* look it up */
768 if (lep->key == NULL) /* new entry */
769 lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
770 sop = (STREAMOUT *)lep->data;
771 if (sop == NULL) { /* allocate stream */
772 sop = (STREAMOUT *)malloc(sizeof(STREAMOUT));
773 if (sop == NULL)
774 error(SYSTEM, "out of memory in getostream");
775 sop->outpipe = oname[0] == '!';
776 sop->reclen = 0;
777 sop->ofp = NULL; /* open iff noopen==0 */
778 sop->xr = xres; sop->yr = yres;
779 lep->data = (char *)sop;
780 if (!sop->outpipe & !force_open & !recover &&
781 access(oname, F_OK) == 0) {
782 errno = EEXIST; /* file exists */
783 goto openerr;
784 }
785 }
786 if (!noopen && sop->ofp == NULL) { /* open output stream */
787 long i;
788 if (oname[0] == '!') /* output to command */
789 sop->ofp = popen(oname+1, "w");
790 else /* else open file */
791 sop->ofp = fopen(oname, "w");
792 if (sop->ofp == NULL)
793 goto openerr;
794 if (outfmt != 'a')
795 SET_FILE_BINARY(sop->ofp);
796 if (header) {
797 char info[512];
798 char *cp = info;
799 if (ofl & OF_MODIFIER || sop->reclen == 1) {
800 sprintf(cp, "MODIFIER=%s\n", mname);
801 while (*cp) ++cp;
802 }
803 if (ofl & OF_BIN) {
804 sprintf(cp, "BIN=%d\n", bn);
805 while (*cp) ++cp;
806 }
807 *cp = '\0';
808 printheader(sop->ofp, info);
809 }
810 if (accumulate > 0) { /* global resolution */
811 sop->xr = xres; sop->yr = yres;
812 }
813 printresolu(sop->ofp, sop->xr, sop->yr);
814 /* play catch-up */
815 for (i = accumulate > 0 ? lastdone/accumulate : 0; i--; ) {
816 int j = sop->reclen;
817 if (j <= 0) j = 1;
818 while (j--)
819 put_contrib(nocontrib, sop->ofp);
820 if (outfmt == 'a')
821 putc('\n', sop->ofp);
822 }
823 if (xres > 0)
824 fflush(sop->ofp);
825 }
826 sop->reclen += noopen; /* add to length if noopen */
827 return sop; /* return output stream */
828 openerr:
829 sprintf(errmsg, "cannot open '%s' for writing", oname);
830 error(SYSTEM, errmsg);
831 return NULL; /* pro forma return */
832 }
833
834 /* read input ray into buffer */
835 int
836 getinp(char *buf, FILE *fp)
837 {
838 double dv[3], *dvp;
839 float *fvp;
840 char *cp;
841 int i;
842
843 switch (inpfmt) {
844 case 'a':
845 cp = buf; /* make sure we get 6 floats */
846 for (i = 0; i < 6; i++) {
847 if (fgetword(cp, buf+127-cp, fp) == NULL)
848 return -1;
849 if (i >= 3)
850 dv[i-3] = atof(cp);
851 if ((cp = fskip(cp)) == NULL || *cp)
852 return -1;
853 *cp++ = ' ';
854 }
855 getc(fp); /* get/put eol */
856 *cp-- = '\0'; *cp = '\n';
857 if (DOT(dv,dv) <= FTINY*FTINY)
858 return 0; /* dummy ray */
859 return strlen(buf);
860 case 'f':
861 if (fread(buf, sizeof(float), 6, fp) < 6)
862 return -1;
863 fvp = (float *)buf + 3;
864 if (DOT(fvp,fvp) <= FTINY*FTINY)
865 return 0; /* dummy ray */
866 return sizeof(float)*6;
867 case 'd':
868 if (fread(buf, sizeof(double), 6, fp) < 6)
869 return -1;
870 dvp = (double *)buf + 3;
871 if (DOT(dvp,dvp) <= FTINY*FTINY)
872 return 0; /* dummy ray */
873 return sizeof(double)*6;
874 }
875 error(INTERNAL, "botched input format");
876 return -1; /* pro forma return */
877 }
878
879 static float rparams[9]; /* traced ray parameters */
880
881 /* return channel (ray) value */
882 double
883 chanvalue(int n)
884 {
885 if (--n < 0 || n >= 6)
886 error(USER, "illegal channel number ($N)");
887 return rparams[n+3];
888 }
889
890 /* add current ray contribution to the appropriate modifier bin */
891 void
892 add_contrib(const char *modn)
893 {
894 LUENT *le = lu_find(&modconttab, modn);
895 MODCONT *mp = (MODCONT *)le->data;
896 int bn;
897
898 if (mp == NULL) {
899 sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
900 error(USER, errmsg);
901 }
902 eclock++; /* get bin number */
903 bn = (int)(evalue(mp->binv) + .5);
904 if (bn <= 0)
905 bn = 0;
906 else if (bn >= mp->nbins) /* new bin */
907 le->data = (char *)(mp = growmodifier(mp, bn+1));
908 addcolor(mp->cbin[bn], rparams);
909 }
910
911 /* output newline to ASCII file and/or flush as requested */
912 static int
913 puteol(const LUENT *e, void *p)
914 {
915 STREAMOUT *sop = (STREAMOUT *)e->data;
916
917 if (outfmt == 'a')
918 putc('\n', sop->ofp);
919 if (!waitflush)
920 fflush(sop->ofp);
921 if (ferror(sop->ofp)) {
922 sprintf(errmsg, "write error on file '%s'", e->key);
923 error(SYSTEM, errmsg);
924 }
925 return 0;
926 }
927
928 /* put out ray contribution to file */
929 void
930 put_contrib(const DCOLOR cnt, FILE *fout)
931 {
932 float fv[3];
933 COLR cv;
934
935 switch (outfmt) {
936 case 'a':
937 fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
938 break;
939 case 'f':
940 copycolor(fv, cnt);
941 fwrite(fv, sizeof(float), 3, fout);
942 break;
943 case 'd':
944 fwrite(cnt, sizeof(double), 3, fout);
945 break;
946 case 'c':
947 setcolr(cv, cnt[0], cnt[1], cnt[2]);
948 fwrite(cv, sizeof(cv), 1, fout);
949 break;
950 default:
951 error(INTERNAL, "botched output format");
952 }
953 }
954
955 /* output ray tallies and clear for next accumulation */
956 void
957 done_contrib(int navg)
958 {
959 double sf = 1.;
960 int i, j;
961 MODCONT *mp;
962 STREAMOUT *sop;
963 /* set average scaling */
964 if (navg > 1)
965 sf = 1. / (double)navg;
966 /* output modifiers in order */
967 for (i = 0; i < nmods; i++) {
968 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
969 if (navg > 1) /* average scaling */
970 for (j = mp->nbins; j--; )
971 scalecolor(mp->cbin[j], sf);
972 sop = getostream(mp->outspec, mp->modname, 0,0);
973 put_contrib(mp->cbin[0], sop->ofp);
974 if (mp->nbins > 3 && /* minor optimization */
975 sop == getostream(mp->outspec, mp->modname, 1,0))
976 for (j = 1; j < mp->nbins; j++)
977 put_contrib(mp->cbin[j], sop->ofp);
978 else
979 for (j = 1; j < mp->nbins; j++)
980 put_contrib(mp->cbin[j],
981 getostream(mp->outspec,mp->modname,j,0)->ofp);
982 /* clear for next time */
983 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
984 }
985 --waitflush; /* terminate records */
986 lu_doall(&ofiletab, puteol, NULL);
987 if (using_stdout & (outfmt == 'a'))
988 putc('\n', stdout);
989 if (!waitflush) {
990 waitflush = xres;
991 if (using_stdout)
992 fflush(stdout);
993 }
994 }
995
996 /* queue completed ray tree produced by rtrace process */
997 void
998 queue_raytree(struct rtproc *rtp)
999 {
1000 struct rtproc *rtu, *rtl = NULL;
1001 /* insert following ray order */
1002 for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
1003 if (rtp->raynum < rtu->raynum)
1004 break;
1005 rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
1006 if (rtu == NULL)
1007 error(SYSTEM, "out of memory in queue_raytree");
1008 *rtu = *rtp;
1009 if (rtl == NULL) {
1010 rtu->next = rt_unproc;
1011 rt_unproc = rtu;
1012 } else {
1013 rtu->next = rtl->next;
1014 rtl->next = rtu;
1015 }
1016 rtp->raynum = 0; /* clear path for next ray tree */
1017 rtp->bsiz = 0;
1018 rtp->buf = NULL;
1019 rtp->nbr = 0;
1020 }
1021
1022 /* process completed ray trees from our queue */
1023 void
1024 process_queue(void)
1025 {
1026 char modname[128];
1027 /* ray-ordered queue */
1028 while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
1029 struct rtproc *rtp = rt_unproc;
1030 int n = rtp->nbr;
1031 const char *cp = rtp->buf;
1032 while (n > 0) { /* process rays */
1033 register char *mnp = modname;
1034 /* skip leading tabs */
1035 while (n > 0 && *cp == '\t') {
1036 cp++; n--;
1037 }
1038 if (!n || !(isalpha(*cp) | (*cp == '_')))
1039 error(USER, "bad modifier name from rtrace");
1040 /* get modifier name */
1041 while (n > 1 && *cp != '\t') {
1042 if (mnp - modname >= sizeof(modname)-2)
1043 error(INTERNAL, "modifier name too long");
1044 *mnp++ = *cp++; n--;
1045 }
1046 *mnp = '\0';
1047 cp++; n--; /* eat following tab */
1048 if (n < (int)(sizeof(float)*9))
1049 error(USER, "incomplete ray value from rtrace");
1050 /* add ray contribution */
1051 memcpy(rparams, cp, sizeof(float)*9);
1052 cp += sizeof(float)*9; n -= sizeof(float)*9;
1053 add_contrib(modname);
1054 }
1055 /* time to produce record? */
1056 if (account > 0 && !--account)
1057 done_contrib(account = accumulate);
1058 lastdone = rtp->raynum;
1059 if (rtp->buf != NULL) /* free up buffer space */
1060 free(rtp->buf);
1061 rt_unproc = rtp->next;
1062 free(rtp); /* done with this ray tree */
1063 }
1064 }
1065
1066 /* wait for rtrace process to finish with ray tree */
1067 struct rtproc *
1068 wait_rproc(void)
1069 {
1070 struct rtproc *rtfree = NULL;
1071 fd_set readset, errset;
1072 int nr;
1073 struct rtproc *rt;
1074 int n;
1075
1076 do {
1077 nr = 0; /* prepare select call */
1078 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
1079 for (rt = &rt0; rt != NULL; rt = rt->next) {
1080 if (rt->raynum) {
1081 FD_SET(rt->pd.r, &readset);
1082 ++nr;
1083 }
1084 FD_SET(rt->pd.r, &errset);
1085 if (rt->pd.r >= n)
1086 n = rt->pd.r + 1;
1087 }
1088 if (!nr) /* no rays pending */
1089 break;
1090 if (nr > 1) { /* call select for multiple proc's */
1091 errno = 0;
1092 if (select(n, &readset, NULL, &errset, NULL) < 0)
1093 error(SYSTEM, "select call error in wait_rproc()");
1094 } else
1095 FD_ZERO(&errset);
1096 nr = 0;
1097 for (rt = &rt0; rt != NULL; rt = rt->next) {
1098 if (!FD_ISSET(rt->pd.r, &readset) &&
1099 !FD_ISSET(rt->pd.r, &errset))
1100 continue;
1101 if (rt->buf == NULL) {
1102 rt->bsiz = treebufsiz;
1103 rt->buf = (char *)malloc(treebufsiz);
1104 } else if (rt->nbr + BUFSIZ > rt->bsiz) {
1105 if (rt->bsiz + BUFSIZ <= treebufsiz)
1106 rt->bsiz = treebufsiz;
1107 else
1108 treebufsiz = rt->bsiz += BUFSIZ;
1109 rt->buf = (char *)realloc(rt->buf, rt->bsiz);
1110 }
1111 if (rt->buf == NULL)
1112 error(SYSTEM, "out of memory in wait_rproc");
1113 nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
1114 if (nr <= 0)
1115 error(USER, "rtrace process died");
1116 rt->nbr += nr; /* advance & check */
1117 if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4,
1118 "~\t~\t", 4)) {
1119 rt->nbr -= 4; /* elide terminator */
1120 queue_raytree(rt);
1121 rtfree = rt; /* ready for next ray */
1122 }
1123 }
1124 } while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
1125 return rtfree;
1126 }
1127
1128 /* return next available rtrace process */
1129 struct rtproc *
1130 get_rproc(void)
1131 {
1132 struct rtproc *rtp;
1133 /* check for idle rtrace */
1134 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
1135 if (!rtp->raynum)
1136 return rtp;
1137 return wait_rproc(); /* need to wait for one */
1138 }
1139
1140 /* trace ray contributions (main loop) */
1141 void
1142 trace_contribs(FILE *fin)
1143 {
1144 static int ignore_warning_given = 0;
1145 char inpbuf[128];
1146 int iblen;
1147 struct rtproc *rtp;
1148 /* loop over input */
1149 while ((iblen = getinp(inpbuf, fin)) >= 0) {
1150 if (!iblen && accumulate != 1) {
1151 if (!ignore_warning_given++)
1152 error(WARNING,
1153 "dummy ray(s) ignored during accumulation\n");
1154 continue;
1155 }
1156 if (!iblen || /* need flush/reset? */
1157 queue_length() > 10*nrtprocs() ||
1158 lastray+1 < lastray) {
1159 while (wait_rproc() != NULL)
1160 process_queue();
1161 if (lastray+1 < lastray)
1162 lastdone = lastray = 0;
1163 }
1164 rtp = get_rproc(); /* get avail. rtrace process */
1165 rtp->raynum = ++lastray; /* assign ray */
1166 if (iblen) { /* trace ray if valid */
1167 writebuf(rtp->pd.w, inpbuf, iblen);
1168 } else { /* else bypass dummy ray */
1169 queue_raytree(rtp); /* queue empty ray/record */
1170 if ((yres <= 0) | (xres <= 0))
1171 waitflush = 1; /* flush right after */
1172 }
1173 process_queue(); /* catch up with results */
1174 if (raysleft && !--raysleft)
1175 break; /* preemptive EOI */
1176 }
1177 while (wait_rproc() != NULL) /* process outstanding rays */
1178 process_queue();
1179 if (accumulate <= 0)
1180 done_contrib(0); /* output tallies */
1181 else if (account < accumulate) {
1182 error(WARNING, "partial accumulation in final record");
1183 done_contrib(accumulate - account);
1184 }
1185 if (raysleft)
1186 error(USER, "unexpected EOF on input");
1187 lu_done(&ofiletab); /* close output files */
1188 }
1189
1190 /* get ray contribution from previous file */
1191 static int
1192 get_contrib(DCOLOR cnt, FILE *finp)
1193 {
1194 COLOR fv;
1195 COLR cv;
1196
1197 switch (outfmt) {
1198 case 'a':
1199 return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3);
1200 case 'f':
1201 if (fread(fv, sizeof(fv[0]), 3, finp) != 3)
1202 return(0);
1203 copycolor(cnt, fv);
1204 return(1);
1205 case 'd':
1206 return(fread(cnt, sizeof(cnt[0]), 3, finp) == 3);
1207 case 'c':
1208 if (fread(cv, sizeof(cv), 1, finp) != 1)
1209 return(0);
1210 colr_color(fv, cv);
1211 copycolor(cnt, fv);
1212 return(1);
1213 default:
1214 error(INTERNAL, "botched output format");
1215 }
1216 return(0); /* pro forma return */
1217 }
1218
1219 /* close output file opened for input */
1220 static int
1221 myclose(const LUENT *e, void *p)
1222 {
1223 STREAMOUT *sop = (STREAMOUT *)e->data;
1224
1225 if (sop->ofp == NULL)
1226 return(0);
1227 fclose(sop->ofp);
1228 sop->ofp = NULL;
1229 return(0);
1230 }
1231
1232 /* load previously accumulated values */
1233 void
1234 reload_output(void)
1235 {
1236 int i, j;
1237 MODCONT *mp;
1238 int ofl;
1239 char oname[1024];
1240 char *fmode = "rb";
1241 char *outvfmt;
1242 LUENT *ment, *oent;
1243 int xr, yr;
1244 STREAMOUT sout;
1245 DCOLOR rgbv;
1246
1247 switch (outfmt) {
1248 case 'a':
1249 outvfmt = "ascii";
1250 fmode = "r";
1251 break;
1252 case 'f':
1253 outvfmt = "float";
1254 break;
1255 case 'd':
1256 outvfmt = "double";
1257 break;
1258 case 'c':
1259 outvfmt = COLRFMT;
1260 break;
1261 default:
1262 error(INTERNAL, "botched output format");
1263 return;
1264 }
1265 /* reload modifier values */
1266 for (i = 0; i < nmods; i++) {
1267 ment = lu_find(&modconttab,modname[i]);
1268 mp = (MODCONT *)ment->data;
1269 if (mp->outspec == NULL)
1270 error(USER, "cannot reload from stdout");
1271 if (mp->outspec[0] == '!')
1272 error(USER, "cannot reload from command");
1273 for (j = 0; ; j++) { /* load each modifier bin */
1274 ofl = ofname(oname, mp->outspec, mp->modname, j);
1275 if (ofl < 0)
1276 error(USER, "bad output file specification");
1277 oent = lu_find(&ofiletab, oname);
1278 if (oent->data != NULL) {
1279 sout = *(STREAMOUT *)oent->data;
1280 } else {
1281 sout.reclen = 0;
1282 sout.outpipe = 0;
1283 sout.xr = xres; sout.yr = yres;
1284 sout.ofp = NULL;
1285 }
1286 if (sout.ofp == NULL) { /* open output as input */
1287 sout.ofp = fopen(oname, fmode);
1288 if (sout.ofp == NULL) {
1289 if (j)
1290 break; /* assume end of modifier */
1291 sprintf(errmsg, "missing reload file '%s'",
1292 oname);
1293 error(WARNING, errmsg);
1294 break;
1295 }
1296 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1297 sprintf(errmsg, "format mismatch for '%s'",
1298 oname);
1299 error(USER, errmsg);
1300 }
1301 if ((sout.xr > 0) & (sout.yr > 0) &&
1302 (!fscnresolu(&xr, &yr, sout.ofp) ||
1303 (xr != sout.xr) |
1304 (yr != sout.yr))) {
1305 sprintf(errmsg, "resolution mismatch for '%s'",
1306 oname);
1307 error(USER, errmsg);
1308 }
1309 }
1310 /* read in RGB value */
1311 if (!get_contrib(rgbv, sout.ofp)) {
1312 if (!j) {
1313 fclose(sout.ofp);
1314 break; /* ignore empty file */
1315 }
1316 if (j < mp->nbins) {
1317 sprintf(errmsg, "missing data in '%s'",
1318 oname);
1319 error(USER, errmsg);
1320 }
1321 break;
1322 }
1323 if (j >= mp->nbins) /* grow modifier size */
1324 ment->data = (char *)(mp = growmodifier(mp, j+1));
1325 copycolor(mp->cbin[j], rgbv);
1326 if (oent->key == NULL) /* new file entry */
1327 oent->key = strcpy((char *)
1328 malloc(strlen(oname)+1), oname);
1329 if (oent->data == NULL)
1330 oent->data = (char *)malloc(sizeof(STREAMOUT));
1331 *(STREAMOUT *)oent->data = sout;
1332 }
1333 }
1334 lu_doall(&ofiletab, myclose, NULL); /* close all files */
1335 }
1336
1337 /* seek on the given output file */
1338 static int
1339 myseeko(const LUENT *e, void *p)
1340 {
1341 STREAMOUT *sop = (STREAMOUT *)e->data;
1342 off_t nbytes = *(off_t *)p;
1343
1344 if (sop->reclen > 1)
1345 nbytes = nbytes * sop->reclen;
1346 if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) {
1347 sprintf(errmsg, "seek error on file '%s'", e->key);
1348 error(SYSTEM, errmsg);
1349 }
1350 return 0;
1351 }
1352
1353 /* recover output if possible */
1354 void
1355 recover_output(FILE *fin)
1356 {
1357 off_t lastout = -1;
1358 int outvsiz, recsiz;
1359 char *outvfmt;
1360 int i, j;
1361 MODCONT *mp;
1362 int ofl;
1363 char oname[1024];
1364 LUENT *ment, *oent;
1365 STREAMOUT sout;
1366 off_t nvals;
1367 int xr, yr;
1368
1369 switch (outfmt) {
1370 case 'a':
1371 error(USER, "cannot recover ASCII output");
1372 return;
1373 case 'f':
1374 outvsiz = sizeof(float)*3;
1375 outvfmt = "float";
1376 break;
1377 case 'd':
1378 outvsiz = sizeof(double)*3;
1379 outvfmt = "double";
1380 break;
1381 case 'c':
1382 outvsiz = sizeof(COLR);
1383 outvfmt = COLRFMT;
1384 break;
1385 default:
1386 error(INTERNAL, "botched output format");
1387 return;
1388 }
1389 /* check modifier outputs */
1390 for (i = 0; i < nmods; i++) {
1391 ment = lu_find(&modconttab,modname[i]);
1392 mp = (MODCONT *)ment->data;
1393 if (mp->outspec == NULL)
1394 error(USER, "cannot recover from stdout");
1395 if (mp->outspec[0] == '!')
1396 error(USER, "cannot recover from command");
1397 for (j = 0; ; j++) { /* check each bin's file */
1398 ofl = ofname(oname, mp->outspec, mp->modname, j);
1399 if (ofl < 0)
1400 error(USER, "bad output file specification");
1401 oent = lu_find(&ofiletab, oname);
1402 if (oent->data != NULL) {
1403 sout = *(STREAMOUT *)oent->data;
1404 } else {
1405 sout.reclen = 0;
1406 sout.outpipe = 0;
1407 sout.ofp = NULL;
1408 }
1409 if (sout.ofp != NULL) { /* already open? */
1410 if (ofl & OF_BIN)
1411 continue;
1412 break;
1413 }
1414 /* open output */
1415 sout.ofp = fopen(oname, "rb+");
1416 if (sout.ofp == NULL) {
1417 if (j)
1418 break; /* assume end of modifier */
1419 sprintf(errmsg, "missing recover file '%s'",
1420 oname);
1421 error(WARNING, errmsg);
1422 break;
1423 }
1424 nvals = lseek(fileno(sout.ofp), 0, SEEK_END);
1425 if (nvals <= 0) {
1426 lastout = 0; /* empty output, quit here */
1427 fclose(sout.ofp);
1428 break;
1429 }
1430 if (!sout.reclen) {
1431 if (!(ofl & OF_BIN)) {
1432 sprintf(errmsg,
1433 "need -bn to recover file '%s'",
1434 oname);
1435 error(USER, errmsg);
1436 }
1437 recsiz = outvsiz;
1438 } else
1439 recsiz = outvsiz * sout.reclen;
1440
1441 lseek(fileno(sout.ofp), 0, SEEK_SET);
1442 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1443 sprintf(errmsg, "format mismatch for '%s'",
1444 oname);
1445 error(USER, errmsg);
1446 }
1447 sout.xr = xres; sout.yr = yres;
1448 if ((sout.xr > 0) & (sout.yr > 0) &&
1449 (!fscnresolu(&xr, &yr, sout.ofp) ||
1450 (xr != sout.xr) |
1451 (yr != sout.yr))) {
1452 sprintf(errmsg, "resolution mismatch for '%s'",
1453 oname);
1454 error(USER, errmsg);
1455 }
1456 nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz;
1457 if ((lastout < 0) | (nvals < lastout))
1458 lastout = nvals;
1459 if (oent->key == NULL) /* new entry */
1460 oent->key = strcpy((char *)
1461 malloc(strlen(oname)+1), oname);
1462 if (oent->data == NULL)
1463 oent->data = (char *)malloc(sizeof(STREAMOUT));
1464 *(STREAMOUT *)oent->data = sout;
1465 if (!(ofl & OF_BIN))
1466 break; /* no bin separation */
1467 }
1468 if (!lastout) { /* empty output */
1469 error(WARNING, "no previous data to recover");
1470 lu_done(&ofiletab); /* reclose all outputs */
1471 return;
1472 }
1473 if (j > mp->nbins) /* reallocate modifier bins */
1474 ment->data = (char *)(mp = growmodifier(mp, j));
1475 }
1476 if (lastout < 0) {
1477 error(WARNING, "no output files to recover");
1478 return;
1479 }
1480 if (raysleft && lastout >= raysleft/accumulate) {
1481 error(WARNING, "output appears to be complete");
1482 /* XXX should read & discard input? */
1483 quit(0);
1484 }
1485 /* seek on all files */
1486 nvals = lastout * outvsiz;
1487 lu_doall(&ofiletab, myseeko, &nvals);
1488 /* skip repeated input */
1489 for (nvals = 0; nvals < lastout; nvals++)
1490 if (getinp(oname, fin) < 0)
1491 error(USER, "unexpected EOF on input");
1492 lastray = lastdone = (unsigned long)lastout * accumulate;
1493 if (raysleft)
1494 raysleft -= lastray;
1495 }
