root/radiance/ray/src/util/rtcontrib.c
Revision: 1.51
Committed: Sat Dec 6 01:08:53 2008 UTC (15 years, 5 months ago) by greg
Changes since 1.50: +2 -2 lines
2 static const char RCSid[] = "$Id: rtcontrib.c,v 1.50 2008/05/01 16:42:06 greg Exp $";
5 * Gather rtrace output to compute contributions from particular sources
6 */
7
8 #include "standard.h"
9 #include <ctype.h>
10 #include <signal.h>
11 #include "platform.h"
12 #include "rtprocess.h"
13 #include "selcall.h"
14 #include "color.h"
15 #include "resolu.h"
16 #include "lookup.h"
17 #include "calcomp.h"
18
19 #ifndef MAXMODLIST
20 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
21 #endif
22
23 int treebufsiz = BUFSIZ; /* current tree buffer size */
24
25 typedef double DCOLOR[3]; /* double-precision color */
26
27 /*
28 * The MODCONT structure is used to accumulate ray contributions
29 * for a particular modifier, which may be subdivided into bins
30 * if binv evaluates > 0. If outspec contains a %s in it, this will
31 * be replaced with the modifier name. If outspec contains a %d in it,
32 * this will be used to create one output file per bin, otherwise all bins
33 * will be written to the same file, in order. If the global outfmt
34 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
35 * and the file will conform to a RADIANCE image if xres & yres are set.
36 */
37 typedef struct {
38 const char *outspec; /* output file specification */
39 const char *modname; /* modifier name */
40 EPNODE *binv; /* bin value expression */
41 int nbins; /* number of accumulation bins */
42 DCOLOR cbin[1]; /* contribution bins (extends struct) */
43 } MODCONT; /* modifier contribution */
44
45 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
46
47 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
48
49 /*
50 * The STREAMOUT structure holds an open FILE pointer and a count of
51 * the number of RGB triplets per record, or 0 if unknown.
52 */
53 typedef struct {
54 FILE *ofp; /* output file pointer */
55 int outpipe; /* output is to a pipe */
56 int reclen; /* triplets/record */
57 int xr, yr; /* output resolution for picture */
58 } STREAMOUT;
59
60 /* close output stream and free record */
61 static void
62 closestream(void *p)
63 {
64 STREAMOUT *sop = (STREAMOUT *)p;
65 int status;
66 if (sop->outpipe)
67 status = pclose(sop->ofp);
68 else
69 status = fclose(sop->ofp);
70 if (status)
71 error(SYSTEM, "error closing output stream");
72 free(p);
73 }
74
75 LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
76
77 #define OF_MODIFIER 01
78 #define OF_BIN 02
79
80 STREAMOUT *getostream(const char *ospec, const char *mname, int bn, int noopen);
81 int ofname(char *oname, const char *ospec, const char *mname, int bn);
82 void printheader(FILE *fout, const char *info);
83 void printresolu(FILE *fout, int xr, int yr);
84
85 /*
86 * The rcont structure is used to manage i/o with a particular
87 * rtrace child process. Input is passed unchanged from stdin,
88 * and output is processed in input order and accumulated according
89 * to the corresponding modifier and bin number.
90 */
91 struct rtproc {
92 struct rtproc *next; /* next in list of processes */
93 SUBPROC pd; /* rtrace pipe descriptors */
94 unsigned long raynum; /* ray number for this tree */
95 int bsiz; /* ray tree buffer length */
96 char *buf; /* ray tree buffer */
97 int nbr; /* number of bytes from rtrace */
98 }; /* rtrace process buffer */
99
100 /* rtrace command and defaults */
101 char *rtargv[256+2*MAXMODLIST] = { "rtrace",
102 "-dj", ".9", "-dr", "3",
103 "-ab", "1", "-ad", "350", };
104
105 int rtargc = 9;
106 /* overriding rtrace options */
107 char *myrtopts[] = { "-h-", "-x", "1", "-y", "0",
108 "-dt", "0", "-as", "0", "-aa", "0", NULL };
109
110 #define RTCOEFF "-o~~TmWdp" /* compute coefficients only */
111 #define RTCONTRIB "-o~~TmVdp" /* compute ray contributions */
112
113 struct rtproc rt0; /* head of rtrace process list */
114
115 struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
116
117 #define PERSIST_NONE 0 /* no persist file */
118 #define PERSIST_SINGLE 1 /* user set -P persist */
119 #define PERSIST_PARALL 2 /* user set -PP persist */
120 #define PERSIST_OURS 3 /* -PP persist belongs to us */
121 int persist_state = PERSIST_NONE; /* persist file state */
122 char persistfn[] = "pfXXXXXX"; /* our persist file name, if set */
123
124 int gargc; /* global argc */
125 char **gargv; /* global argv */
126 #define progname gargv[0]
127
128 char *octree; /* global octree argument */
129
130 int inpfmt = 'a'; /* input format */
131 int outfmt = 'a'; /* output format */
132
133 int header = 1; /* output header? */
134 int force_open = 0; /* truncate existing output? */
135 int recover = 0; /* recover previous output? */
136 int accumulate = 1; /* input rays per output record */
137 int xres = 0; /* horiz. output resolution */
138 int yres = 0; /* vert. output resolution */
139
140 int account; /* current accumulation count */
141 unsigned long raysleft; /* number of rays left to trace */
142 long waitflush; /* how long until next flush */
143
144 unsigned long lastray = 0; /* last ray number sent */
145 unsigned long lastdone = 0; /* last ray processed */
146
147 int using_stdout = 0; /* are we using stdout? */
148
149 const char *modname[MAXMODLIST]; /* ordered modifier name list */
150 int nmods = 0; /* number of modifiers */
151
152 #define queue_length() (lastray - lastdone)
153
154 MODCONT *growmodifier(MODCONT *mp, int nb);
155 MODCONT *addmodifier(char *modn, char *outf, char *binv, int bincnt);
156 void addmodfile(char *fname, char *outf, char *binv, int bincnt);
157
158 void init(int np);
159 int done_rprocs(struct rtproc *rtp);
160 void reload_output(void);
161 void recover_output(FILE *fin);
162 void trace_contribs(FILE *fin);
163 struct rtproc *wait_rproc(void);
164 struct rtproc *get_rproc(void);
165 void queue_raytree(struct rtproc *rtp);
166 void process_queue(void);
167
168 void put_contrib(const DCOLOR cnt, FILE *fout);
169 void add_contrib(const char *modn);
170 void done_contrib(int navg);
171
172 /* return number of open rtrace processes */
173 static int
174 nrtprocs(void)
175 {
176 int nrtp = 0;
177 struct rtproc *rtp;
178
179 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
180 nrtp += rtp->pd.running;
181 return(nrtp);
182 }
183
184 /* set input/output format */
185 static void
186 setformat(const char *fmt)
187 {
188 switch (fmt[0]) {
189 case 'f':
190 case 'd':
191 SET_FILE_BINARY(stdin);
192 /* fall through */
193 case 'a':
194 inpfmt = fmt[0];
195 break;
196 default:
197 goto fmterr;
198 }
199 switch (fmt[1]) {
200 case '\0':
201 outfmt = inpfmt;
202 return;
203 case 'a':
204 case 'f':
205 case 'd':
206 case 'c':
207 outfmt = fmt[1];
208 break;
209 default:
210 goto fmterr;
211 }
212 if (!fmt[2])
213 return;
214 fmterr:
215 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
216 error(USER, errmsg);
217 }
218
219 /* gather rays from rtrace and output contributions */
220 int
221 main(int argc, char *argv[])
222 {
223 int contrib = 0;
224 int nprocs = 1;
225 char *curout = NULL;
226 char *binval = NULL;
227 int bincnt = 0;
228 char fmt[8];
229 int i, j;
230 /* need at least one argument */
231 if (argc < 2) {
232 fprintf(stderr,
233 "Usage: %s [-n nprocs][-V][-r][-e expr][-f source][-o ospec][-b binv] {-m mod | -M file} [rtrace options] octree\n",
234 argv[0]);
235 exit(1);
236 }
237 /* global program name */
238 gargv = argv;
239 /* initialize calcomp routines */
240 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
241 esupport &= ~(E_OUTCHAN);
242 varset("PI", ':', PI);
243 /* get our options */
244 for (i = 1; i < argc-1; i++) {
245 /* expand arguments */
246 while ((j = expandarg(&argc, &argv, i)) > 0)
247 ;
248 if (j < 0) {
249 fprintf(stderr, "%s: cannot expand '%s'",
250 argv[0], argv[i]);
251 exit(1);
252 }
253 if (argv[i][0] == '-')
254 switch (argv[i][1]) {
255 case 'n': /* number of processes */
256 if (argv[i][2] || i >= argc-2) break;
257 nprocs = atoi(argv[++i]);
258 if (nprocs <= 0)
259 error(USER, "illegal number of processes");
260 continue;
261 case 'V': /* output contributions */
262 switch (argv[i][2]) {
263 case '\0':
264 contrib = !contrib;
265 continue;
266 case '+': case '1':
267 case 'T': case 't':
268 case 'Y': case 'y':
269 contrib = 1;
270 continue;
271 case '-': case '0':
272 case 'F': case 'f':
273 case 'N': case 'n':
274 contrib = 0;
275 continue;
276 }
277 break;
278 case 'c': /* input rays per output */
279 if (argv[i][2] || i >= argc-2) break;
280 accumulate = atoi(argv[++i]);
281 continue;
282 case 'r': /* recover output */
283 if (argv[i][2]) break;
284 recover = 1;
285 continue;
286 case 'h': /* output header? */
287 switch (argv[i][2]) {
288 case '\0':
289 header = !header;
290 continue;
291 case '+': case '1':
292 case 'T': case 't':
293 case 'Y': case 'y':
294 header = 1;
295 continue;
296 case '-': case '0':
297 case 'F': case 'f':
298 case 'N': case 'n':
299 header = 0;
300 continue;
301 }
302 break;
303 case 'f': /* file or force or format */
304 if (!argv[i][2]) {
305 char *fpath;
306 if (i >= argc-2) break;
307 fpath = getpath(argv[++i],
308 getrlibpath(), R_OK);
309 if (fpath == NULL) {
310 sprintf(errmsg,
311 "cannot find file '%s'",
312 argv[i]);
313 error(USER, errmsg);
314 }
315 fcompile(fpath);
316 continue;
317 }
318 if (argv[i][2] == 'o') {
319 force_open = 1;
320 continue;
321 }
322 setformat(argv[i]+2);
323 continue;
324 case 'e': /* expression */
325 if (argv[i][2] || i >= argc-2) break;
326 scompile(argv[++i], NULL, 0);
327 continue;
328 case 'o': /* output file spec. */
329 if (argv[i][2] || i >= argc-2) break;
330 curout = argv[++i];
331 continue;
332 case 'x': /* horiz. output resolution */
333 if (argv[i][2] || i >= argc-2) break;
334 xres = atoi(argv[++i]);
335 continue;
336 case 'y': /* vert. output resolution */
337 if (argv[i][2] || i >= argc-2) break;
338 yres = atoi(argv[++i]);
339 continue;
340 case 'b': /* bin expression/count */
341 if (i >= argc-2) break;
342 if (argv[i][2] == 'n') {
343 bincnt = atoi(argv[++i]);
344 continue;
345 }
346 if (argv[i][2]) break;
347 binval = argv[++i];
348 continue;
349 case 'm': /* modifier name */
350 if (argv[i][2] || i >= argc-2) break;
351 rtargv[rtargc++] = "-ti";
352 rtargv[rtargc++] = argv[++i];
353 addmodifier(argv[i], curout, binval, bincnt);
354 continue;
355 case 'M': /* modifier file */
356 if (argv[i][2] || i >= argc-2) break;
357 rtargv[rtargc++] = "-tI";
358 rtargv[rtargc++] = argv[++i];
359 addmodfile(argv[i], curout, binval, bincnt);
360 continue;
361 case 'P': /* persist file */
362 if (i >= argc-2) break;
363 persist_state = (argv[i][2] == 'P') ?
364 PERSIST_PARALL : PERSIST_SINGLE;
365 rtargv[rtargc++] = argv[i];
366 rtargv[rtargc++] = argv[++i];
367 continue;
368 }
369 rtargv[rtargc++] = argv[i]; /* assume rtrace option */
370 }
371 if (accumulate <= 0) /* no output flushing for single record */
372 xres = yres = 0;
373 /* set global argument list */
374 gargc = argc; gargv = argv;
375 /* add "mandatory" rtrace settings */
376 for (j = 0; myrtopts[j] != NULL; j++)
377 rtargv[rtargc++] = myrtopts[j];
378 rtargv[rtargc++] = contrib ? RTCONTRIB : RTCOEFF;
379 /* just asking for defaults? */
380 if (!strcmp(argv[i], "-defaults")) {
381 char sxres[16], syres[16];
382 char *rtpath;
383 printf("-n %-2d\t\t\t\t# number of processes\n", nprocs);
384 printf("-c %-5d\t\t\t# accumulated rays per record\n",
385 accumulate);
386 printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-',
387 contrib ? "contributions" : "coefficients");
388 fflush(stdout); /* report OUR options */
389 rtargv[rtargc++] = header ? "-h+" : "-h-";
390 sprintf(fmt, "-f%c%c", inpfmt, outfmt);
391 rtargv[rtargc++] = fmt;
392 rtargv[rtargc++] = "-x";
393 sprintf(sxres, "%d", xres);
394 rtargv[rtargc++] = sxres;
395 rtargv[rtargc++] = "-y";
396 sprintf(syres, "%d", yres);
397 rtargv[rtargc++] = syres;
398 rtargv[rtargc++] = "-defaults";
399 rtargv[rtargc] = NULL;
400 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
401 if (rtpath == NULL) {
402 eputs(rtargv[0]);
403 eputs(": command not found\n");
404 exit(1);
405 }
406 execv(rtpath, rtargv);
407 perror(rtpath); /* execv() should not return */
408 exit(1);
409 }
410 if (nprocs > 1) { /* add persist file if parallel */
411 if (persist_state == PERSIST_SINGLE)
412 error(USER, "use -PP option for multiple processes");
413 if (persist_state == PERSIST_NONE) {
414 rtargv[rtargc++] = "-PP";
415 rtargv[rtargc++] = mktemp(persistfn);
416 persist_state = PERSIST_OURS;
417 }
418 }
419 /* add format string */
420 sprintf(fmt, "-f%cf", inpfmt);
421 rtargv[rtargc++] = fmt;
422 /* octree argument is last */
423 if (i <= 0 || i != argc-1 || argv[i][0] == '-')
424 error(USER, "missing octree argument");
425 rtargv[rtargc++] = octree = argv[i];
426 rtargv[rtargc] = NULL;
427 /* start rtrace & recover if requested */
428 init(nprocs);
429 /* compute contributions */
430 trace_contribs(stdin);
431 /* clean up */
432 quit(0);
433 }
434
435 #ifndef SIGALRM
436 #define SIGALRM SIGTERM
437 #endif
438 /* kill persistent rtrace process */
439 static void
440 killpersist(void)
441 {
442 FILE *fp = fopen(persistfn, "r");
443 RT_PID pid;
444
445 if (fp == NULL)
446 return;
447 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
448 unlink(persistfn);
449 fclose(fp);
450 }
451
452 /* close rtrace processes and clean up */
453 int
454 done_rprocs(struct rtproc *rtp)
455 {
456 int st0, st1 = 0;
457
458 if (rtp->next != NULL) { /* close last opened first! */
459 st1 = done_rprocs(rtp->next);
460 free((void *)rtp->next);
461 rtp->next = NULL;
462 }
463 st0 = close_process(&rtp->pd);
464 if (st0 < 0)
465 error(WARNING, "unknown return status from rtrace process");
466 else if (st0 > 0)
467 return(st0);
468 return(st1);
469 }
470
471 /* exit with status */
472 void
473 quit(int status)
474 {
475 int rtstat;
476
477 if (persist_state == PERSIST_OURS) /* terminate waiting rtrace */
478 killpersist();
479 /* clean up rtrace process(es) */
480 rtstat = done_rprocs(&rt0);
481 if (status == 0)
482 status = rtstat;
483 exit(status); /* flushes all output streams */
484 }
485
486 /* start rtrace processes and initialize */
487 void
488 init(int np)
489 {
490 struct rtproc *rtp;
491 int i;
492 int maxbytes;
493 /* make sure we have something to do */
494 if (!nmods)
495 error(USER, "No modifiers specified");
496 /* assign ray variables */
497 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
498 scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
499 /* set up signal handling */
500 signal(SIGINT, quit);
501 #ifdef SIGHUP
502 signal(SIGHUP, quit);
503 #endif
504 #ifdef SIGTERM
505 signal(SIGTERM, quit);
506 #endif
507 #ifdef SIGPIPE
508 signal(SIGPIPE, quit);
509 #endif
510 rtp = &rt0; /* start rtrace process(es) */
511 for (i = 0; i++ < np; ) {
512 errno = 0;
513 maxbytes = open_process(&rtp->pd, rtargv);
514 if (maxbytes == 0) {
515 eputs(rtargv[0]);
516 eputs(": command not found\n");
517 exit(1);
518 }
519 if (maxbytes < 0)
520 error(SYSTEM, "cannot start rtrace process");
521 if (maxbytes > treebufsiz)
522 treebufsiz = maxbytes;
523 rtp->raynum = 0;
524 rtp->bsiz = 0;
525 rtp->buf = NULL;
526 rtp->nbr = 0;
527 if (i == np) /* last process? */
528 break;
529 if (i == 1)
530 sleep(2); /* wait for persist file */
531 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
532 if (rtp->next == NULL)
533 error(SYSTEM, "out of memory in init");
534 rtp = rtp->next;
535 }
536 rtp->next = NULL; /* terminate list */
537 if (yres > 0) {
538 if (xres > 0)
539 raysleft = (unsigned long)xres*yres;
540 else
541 raysleft = yres;
542 } else
543 raysleft = 0;
544 if ((account = accumulate) > 0)
545 raysleft *= accumulate;
546 waitflush = xres;
547 if (!recover)
548 return;
549 /* recover previous values */
550 if (accumulate <= 0)
551 reload_output();
552 else
553 recover_output(stdin);
554 }
555
556 /* grow modifier to accommodate more bins */
557 MODCONT *
558 growmodifier(MODCONT *mp, int nb)
559 {
560 if (nb <= mp->nbins)
561 return mp;
562 mp = (MODCONT *)realloc(mp, sizeof(MODCONT) + sizeof(DCOLOR)*(nb-1));
563 if (mp == NULL)
564 error(SYSTEM, "out of memory in growmodifier");
565 memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(nb-mp->nbins));
566 mp->nbins = nb;
567 return mp;
568 }
569
570 /* add modifier to our list to track */
571 MODCONT *
572 addmodifier(char *modn, char *outf, char *binv, int bincnt)
573 {
574 LUENT *lep = lu_find(&modconttab, modn);
575 MODCONT *mp;
576 int i;
577
578 if (lep->data != NULL) {
579 sprintf(errmsg, "duplicate modifier '%s'", modn);
580 error(USER, errmsg);
581 }
582 if (nmods >= MAXMODLIST)
583 error(USER, "too many modifiers");
584 modname[nmods++] = modn; /* XXX assumes static string */
585 lep->key = modn; /* XXX assumes static string */
586 mp = (MODCONT *)malloc(sizeof(MODCONT));
587 if (mp == NULL)
588 error(SYSTEM, "out of memory in addmodifier");
589 mp->outspec = outf; /* XXX assumes static string */
590 mp->modname = modn; /* XXX assumes static string */
591 if (binv != NULL)
592 mp->binv = eparse(binv);
593 else
594 mp->binv = eparse("0");
595 mp->nbins = 1;
596 setcolor(mp->cbin[0], 0., 0., 0.);
597 if (mp->binv->type == NUM) /* assume one bin if constant */
598 bincnt = 1;
599 else if (bincnt > 1)
600 mp = growmodifier(mp, bincnt);
601 lep->data = (char *)mp;
602 /* allocate output streams */
603 for (i = bincnt; i-- > 0; )
604 getostream(mp->outspec, mp->modname, i, 1);
605 return mp;
606 }
607
608 /* add modifiers from a file list */
609 void
610 addmodfile(char *fname, char *outf, char *binv, int bincnt)
611 {
612 char *mname[MAXMODLIST];
613 int i;
614 /* find the file & store strings */
615 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
616 sprintf(errmsg, "cannot find modifier file '%s'", fname);
617 error(SYSTEM, errmsg);
618 }
619 for (i = 0; mname[i]; i++) /* add each one */
620 addmodifier(mname[i], outf, binv, bincnt);
621 }
622
623 /* put string to stderr */
624 void
625 eputs(char *s)
626 {
627 static int midline = 0;
628
629 if (!*s) return;
630 if (!midline) {
631 fputs(progname, stderr);
632 fputs(": ", stderr);
633 }
634 fputs(s, stderr);
635 midline = s[strlen(s)-1] != '\n';
636 }
637
638 /* construct output file name and return flags whether modifier/bin present */
639 int
640 ofname(char *oname, const char *ospec, const char *mname, int bn)
641 {
642 const char *mnp = NULL;
643 const char *bnp = NULL;
644 const char *cp;
645
646 if (ospec == NULL)
647 return -1;
648 for (cp = ospec; *cp; cp++) /* check format position(s) */
649 if (*cp == '%') {
650 do
651 ++cp;
652 while (isdigit(*cp));
653 switch (*cp) {
654 case '%':
655 break;
656 case 's':
657 if (mnp != NULL)
658 return -1;
659 mnp = cp;
660 break;
661 case 'd':
662 if (bnp != NULL)
663 return -1;
664 bnp = cp;
665 break;
666 default:
667 return -1;
668 }
669 }
670 if (mnp != NULL) { /* create file name */
671 if (bnp != NULL) {
672 if (bnp > mnp)
673 sprintf(oname, ospec, mname, bn);
674 else
675 sprintf(oname, ospec, bn, mname);
676 return OF_MODIFIER|OF_BIN;
677 }
678 sprintf(oname, ospec, mname);
679 return OF_MODIFIER;
680 }
681 if (bnp != NULL) {
682 sprintf(oname, ospec, bn);
683 return OF_BIN;
684 }
685 strcpy(oname, ospec);
686 return 0;
687 }
688
689 /* write header to the given output stream */
690 void
691 printheader(FILE *fout, const char *info)
692 {
693 extern char VersionID[];
694 FILE *fin = fopen(octree, "r");
695
696 if (fin == NULL)
697 quit(1);
698 checkheader(fin, "ignore", fout); /* copy octree header */
699 fclose(fin);
700 printargs(gargc-1, gargv, fout); /* add our command */
701 fprintf(fout, "SOFTWARE= %s\n", VersionID);
702 fputnow(fout);
703 if (info != NULL) /* add extra info if given */
704 fputs(info, fout);
705 switch (outfmt) { /* add output format */
706 case 'a':
707 fputformat("ascii", fout);
708 break;
709 case 'f':
710 fputformat("float", fout);
711 break;
712 case 'd':
713 fputformat("double", fout);
714 break;
715 case 'c':
716 fputformat(COLRFMT, fout);
717 break;
718 }
719 fputc('\n', fout);
720 }
721
722 /* write resolution string to given output stream */
723 void
724 printresolu(FILE *fout, int xr, int yr)
725 {
726 if ((xr > 0) & (yr > 0)) /* resolution string */
727 fprtresolu(xr, yr, fout);
728 if (xres > 0) /* global flush flag */
729 fflush(fout);
730 }
731
732 /* Get output stream pointer (open and write header if new and noopen==0) */
733 STREAMOUT *
734 getostream(const char *ospec, const char *mname, int bn, int noopen)
735 {
736 static const DCOLOR nocontrib = BLKCOLOR;
737 static STREAMOUT stdos;
738 int ofl;
739 char oname[1024];
740 LUENT *lep;
741 STREAMOUT *sop;
742
743 if (ospec == NULL) { /* use stdout? */
744 if (!noopen && !using_stdout) {
745 if (outfmt != 'a')
746 SET_FILE_BINARY(stdout);
747 if (header)
748 printheader(stdout, NULL);
749 printresolu(stdout, xres, yres);
750 stdos.xr = xres; stdos.yr = yres;
751 using_stdout = 1;
752 }
753 stdos.ofp = stdout;
754 stdos.reclen += noopen;
755 return &stdos;
756 }
757 ofl = ofname(oname, ospec, mname, bn); /* get output name */
758 if (ofl < 0) {
759 sprintf(errmsg, "bad output format '%s'", ospec);
760 error(USER, errmsg);
761 }
762 lep = lu_find(&ofiletab, oname); /* look it up */
763 if (lep->key == NULL) /* new entry */
764 lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
765 sop = (STREAMOUT *)lep->data;
766 if (sop == NULL) { /* allocate stream */
767 sop = (STREAMOUT *)malloc(sizeof(STREAMOUT));
768 if (sop == NULL)
769 error(SYSTEM, "out of memory in getostream");
770 sop->outpipe = oname[0] == '!';
771 sop->reclen = 0;
772 sop->ofp = NULL; /* open iff noopen==0 */
773 sop->xr = xres; sop->yr = yres;
774 lep->data = (char *)sop;
775 if (!sop->outpipe & !force_open & !recover &&
776 access(oname, F_OK) == 0) {
777 errno = EEXIST; /* file exists */
778 goto openerr;
779 }
780 }
781 if (!noopen && sop->ofp == NULL) { /* open output stream */
782 long i;
783 if (oname[0] == '!') /* output to command */
784 sop->ofp = popen(oname+1, "w");
785 else /* else open file */
786 sop->ofp = fopen(oname, "w");
787 if (sop->ofp == NULL)
788 goto openerr;
789 if (outfmt != 'a')
790 SET_FILE_BINARY(sop->ofp);
791 if (header) {
792 char info[512];
793 char *cp = info;
794 if (ofl & OF_MODIFIER || sop->reclen == 1) {
795 sprintf(cp, "MODIFIER=%s\n", mname);
796 while (*cp) ++cp;
797 }
798 if (ofl & OF_BIN) {
799 sprintf(cp, "BIN=%d\n", bn);
800 while (*cp) ++cp;
801 }
802 *cp = '\0';
803 printheader(sop->ofp, info);
804 }
805 if (accumulate > 0) { /* global resolution */
806 sop->xr = xres; sop->yr = yres;
807 }
808 printresolu(sop->ofp, sop->xr, sop->yr);
809 /* play catch-up */
810 for (i = accumulate > 0 ? lastdone/accumulate : 0; i--; ) {
811 int j = sop->reclen;
812 if (j <= 0) j = 1;
813 while (j--)
814 put_contrib(nocontrib, sop->ofp);
815 if (outfmt == 'a')
816 putc('\n', sop->ofp);
817 }
818 if (xres > 0)
819 fflush(sop->ofp);
820 }
821 sop->reclen += noopen; /* add to length if noopen */
822 return sop; /* return output stream */
823 openerr:
824 sprintf(errmsg, "cannot open '%s' for writing", oname);
825 error(SYSTEM, errmsg);
826 return NULL; /* pro forma return */
827 }
828
829 /* read input ray into buffer */
830 int
831 getinp(char *buf, FILE *fp)
832 {
833 double dv[3], *dvp;
834 float *fvp;
835 char *cp;
836 int i;
837
838 switch (inpfmt) {
839 case 'a':
840 cp = buf; /* make sure we get 6 floats */
841 for (i = 0; i < 6; i++) {
842 if (fgetword(cp, buf+127-cp, fp) == NULL)
843 return -1;
844 if (i >= 3)
845 dv[i-3] = atof(cp);
846 if ((cp = fskip(cp)) == NULL || *cp)
847 return -1;
848 *cp++ = ' ';
849 }
850 getc(fp); /* get/put eol */
851 *cp-- = '\0'; *cp = '\n';
852 if (DOT(dv,dv) <= FTINY*FTINY)
853 return 0; /* dummy ray */
854 return strlen(buf);
855 case 'f':
856 if (fread(buf, sizeof(float), 6, fp) < 6)
857 return -1;
858 fvp = (float *)buf + 3;
859 if (DOT(fvp,fvp) <= FTINY*FTINY)
860 return 0; /* dummy ray */
861 return sizeof(float)*6;
862 case 'd':
863 if (fread(buf, sizeof(double), 6, fp) < 6)
864 return -1;
865 dvp = (double *)buf + 3;
866 if (DOT(dvp,dvp) <= FTINY*FTINY)
867 return 0; /* dummy ray */
868 return sizeof(double)*6;
869 }
870 error(INTERNAL, "botched input format");
871 return -1; /* pro forma return */
872 }
873
874 static float rparams[9]; /* traced ray parameters */
875
876 /* return channel (ray) value */
877 double
878 chanvalue(int n)
879 {
880 if (--n < 0 || n >= 6)
881 error(USER, "illegal channel number ($N)");
882 return rparams[n+3];
883 }
884
885 /* add current ray contribution to the appropriate modifier bin */
886 void
887 add_contrib(const char *modn)
888 {
889 LUENT *le = lu_find(&modconttab, modn);
890 MODCONT *mp = (MODCONT *)le->data;
891 int bn;
892
893 if (mp == NULL) {
894 sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
895 error(USER, errmsg);
896 }
897 eclock++; /* get bin number */
898 bn = (int)(evalue(mp->binv) + .5);
899 if (bn <= 0)
900 bn = 0;
901 else if (bn >= mp->nbins) /* new bin */
902 le->data = (char *)(mp = growmodifier(mp, bn+1));
903 addcolor(mp->cbin[bn], rparams);
904 }
905
906 /* output newline to ASCII file and/or flush as requested */
907 static int
908 puteol(const LUENT *e, void *p)
909 {
910 STREAMOUT *sop = (STREAMOUT *)e->data;
911
912 if (outfmt == 'a')
913 putc('\n', sop->ofp);
914 if (!waitflush)
915 fflush(sop->ofp);
916 if (ferror(sop->ofp)) {
917 sprintf(errmsg, "write error on file '%s'", e->key);
918 error(SYSTEM, errmsg);
919 }
920 return 0;
921 }
922
923 /* put out ray contribution to file */
924 void
925 put_contrib(const DCOLOR cnt, FILE *fout)
926 {
927 float fv[3];
928 COLR cv;
929
930 switch (outfmt) {
931 case 'a':
932 fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
933 break;
934 case 'f':
935 copycolor(fv, cnt);
936 fwrite(fv, sizeof(float), 3, fout);
937 break;
938 case 'd':
939 fwrite(cnt, sizeof(double), 3, fout);
940 break;
941 case 'c':
942 setcolr(cv, cnt[0], cnt[1], cnt[2]);
943 fwrite(cv, sizeof(cv), 1, fout);
944 break;
945 default:
946 error(INTERNAL, "botched output format");
947 }
948 }
949
950 /* output ray tallies and clear for next accumulation */
951 void
952 done_contrib(int navg)
953 {
954 double sf = 1.;
955 int i, j;
956 MODCONT *mp;
957 STREAMOUT *sop;
958 /* set average scaling */
959 if (navg > 1)
960 sf = 1. / (double)navg;
961 /* output modifiers in order */
962 for (i = 0; i < nmods; i++) {
963 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
964 if (navg > 1) /* average scaling */
965 for (j = mp->nbins; j--; )
966 scalecolor(mp->cbin[j], sf);
967 sop = getostream(mp->outspec, mp->modname, 0,0);
968 put_contrib(mp->cbin[0], sop->ofp);
969 if (mp->nbins > 3 && /* minor optimization */
970 sop == getostream(mp->outspec, mp->modname, 1,0))
971 for (j = 1; j < mp->nbins; j++)
972 put_contrib(mp->cbin[j], sop->ofp);
973 else
974 for (j = 1; j < mp->nbins; j++)
975 put_contrib(mp->cbin[j],
976 getostream(mp->outspec,mp->modname,j,0)->ofp);
977 /* clear for next time */
978 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
979 }
980 --waitflush; /* terminate records */
981 lu_doall(&ofiletab, puteol, NULL);
982 if (using_stdout & (outfmt == 'a'))
983 putc('\n', stdout);
984 if (!waitflush) {
985 waitflush = xres;
986 if (using_stdout)
987 fflush(stdout);
988 }
989 }
990
991 /* queue completed ray tree produced by rtrace process */
992 void
993 queue_raytree(struct rtproc *rtp)
994 {
995 struct rtproc *rtu, *rtl = NULL;
996 /* insert following ray order */
997 for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
998 if (rtp->raynum < rtu->raynum)
999 break;
1000 rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
1001 if (rtu == NULL)
1002 error(SYSTEM, "out of memory in queue_raytree");
1003 *rtu = *rtp;
1004 if (rtl == NULL) {
1005 rtu->next = rt_unproc;
1006 rt_unproc = rtu;
1007 } else {
1008 rtu->next = rtl->next;
1009 rtl->next = rtu;
1010 }
1011 rtp->raynum = 0; /* clear path for next ray tree */
1012 rtp->bsiz = 0;
1013 rtp->buf = NULL;
1014 rtp->nbr = 0;
1015 }
1016
1017 /* process completed ray trees from our queue */
1018 void
1019 process_queue(void)
1020 {
1021 char modname[128];
1022 /* ray-ordered queue */
1023 while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
1024 struct rtproc *rtp = rt_unproc;
1025 int n = rtp->nbr;
1026 const char *cp = rtp->buf;
1027 while (n > 0) { /* process rays */
1028 register char *mnp = modname;
1029 /* skip leading tabs */
1030 while (n > 0 && *cp == '\t') {
1031 cp++; n--;
1032 }
1033 if (!n || !(isalpha(*cp) | (*cp == '_')))
1034 error(USER, "bad modifier name from rtrace");
1035 /* get modifier name */
1036 while (n > 1 && *cp != '\t') {
1037 if (mnp - modname >= sizeof(modname)-2)
1038 error(INTERNAL, "modifier name too long");
1039 *mnp++ = *cp++; n--;
1040 }
1041 *mnp = '\0';
1042 cp++; n--; /* eat following tab */
1043 if (n < (int)(sizeof(float)*9))
1044 error(USER, "incomplete ray value from rtrace");
1045 /* add ray contribution */
1046 memcpy(rparams, cp, sizeof(float)*9);
1047 cp += sizeof(float)*9; n -= sizeof(float)*9;
1048 add_contrib(modname);
1049 }
1050 /* time to produce record? */
1051 if (account > 0 && !--account)
1052 done_contrib(account = accumulate);
1053 lastdone = rtp->raynum;
1054 if (rtp->buf != NULL) /* free up buffer space */
1055 free(rtp->buf);
1056 rt_unproc = rtp->next;
1057 free(rtp); /* done with this ray tree */
1058 }
1059 }
1060
1061 /* wait for rtrace process to finish with ray tree */
1062 struct rtproc *
1063 wait_rproc(void)
1064 {
1065 struct rtproc *rtfree = NULL;
1066 fd_set readset, errset;
1067 int nr;
1068 struct rtproc *rt;
1069 int n;
1070
1071 do {
1072 nr = 0; /* prepare select call */
1073 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
1074 for (rt = &rt0; rt != NULL; rt = rt->next) {
1075 if (rt->raynum) {
1076 FD_SET(rt->pd.r, &readset);
1077 ++nr;
1078 }
1079 FD_SET(rt->pd.r, &errset);
1080 if (rt->pd.r >= n)
1081 n = rt->pd.r + 1;
1082 }
1083 if (!nr) /* no rays pending */
1084 break;
1085 if (nr > 1) { /* call select for multiple proc's */
1086 errno = 0;
1087 if (select(n, &readset, NULL, &errset, NULL) < 0)
1088 error(SYSTEM, "select call error in wait_rproc()");
1089 } else
1090 FD_ZERO(&errset);
1091 nr = 0;
1092 for (rt = &rt0; rt != NULL; rt = rt->next) {
1093 if (!FD_ISSET(rt->pd.r, &readset) &&
1094 !FD_ISSET(rt->pd.r, &errset))
1095 continue;
1096 if (rt->buf == NULL) {
1097 rt->bsiz = treebufsiz;
1098 rt->buf = (char *)malloc(treebufsiz);
1099 } else if (rt->nbr + BUFSIZ > rt->bsiz) {
1100 if (rt->bsiz + BUFSIZ <= treebufsiz)
1101 rt->bsiz = treebufsiz;
1102 else
1103 treebufsiz = rt->bsiz += BUFSIZ;
1104 rt->buf = (char *)realloc(rt->buf, rt->bsiz);
1105 }
1106 if (rt->buf == NULL)
1107 error(SYSTEM, "out of memory in wait_rproc");
1108 nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
1109 if (nr <= 0)
1110 error(USER, "rtrace process died");
1111 rt->nbr += nr; /* advance & check */
1112 if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4,
1113 "~\t~\t", 4)) {
1114 rt->nbr -= 4; /* elide terminator */
1115 queue_raytree(rt);
1116 rtfree = rt; /* ready for next ray */
1117 }
1118 }
1119 } while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
1120 return rtfree;
1121 }
1122
1123 /* return next available rtrace process */
1124 struct rtproc *
1125 get_rproc(void)
1126 {
1127 struct rtproc *rtp;
1128 /* check for idle rtrace */
1129 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
1130 if (!rtp->raynum)
1131 return rtp;
1132 return wait_rproc(); /* need to wait for one */
1133 }
1134
1135 /* trace ray contributions (main loop) */
1136 void
1137 trace_contribs(FILE *fin)
1138 {
1139 static int ignore_warning_given = 0;
1140 char inpbuf[128];
1141 int iblen;
1142 struct rtproc *rtp;
1143 /* loop over input */
1144 while ((iblen = getinp(inpbuf, fin)) >= 0) {
1145 if (!iblen && accumulate != 1) {
1146 if (!ignore_warning_given++)
1147 error(WARNING,
1148 "dummy ray(s) ignored during accumulation\n");
1149 continue;
1150 }
1151 if (!iblen || /* need reset? */
1152 queue_length() > 10*nrtprocs() ||
1153 lastray+1 < lastray) {
1154 while (wait_rproc() != NULL)
1155 process_queue();
1156 if (lastray+1 < lastray)
1157 lastdone = lastray = 0;
1158 }
1159 rtp = get_rproc(); /* get avail. rtrace process */
1160 rtp->raynum = ++lastray; /* assign ray */
1161 if (iblen) { /* trace ray if valid */
1162 writebuf(rtp->pd.w, inpbuf, iblen);
1163 } else { /* else bypass dummy ray */
1164 queue_raytree(rtp); /* empty tree */
1165 if ((yres <= 0) | (waitflush > 1))
1166 waitflush = 1; /* flush after this */
1167 }
1168 process_queue(); /* catch up with results */
1169 if (raysleft && !--raysleft)
1170 break; /* preemptive EOI */
1171 }
1172 while (wait_rproc() != NULL) /* process outstanding rays */
1173 process_queue();
1174 if (accumulate <= 0)
1175 done_contrib(0); /* output tallies */
1176 else if (account < accumulate) {
1177 error(WARNING, "partial accumulation in final record");
1178 done_contrib(accumulate - account);
1179 }
1180 if (raysleft)
1181 error(USER, "unexpected EOF on input");
1182 lu_done(&ofiletab); /* close output files */
1183 }
1184
1185 /* get ray contribution from previous file */
1186 static int
1187 get_contrib(DCOLOR cnt, FILE *finp)
1188 {
1189 COLOR fv;
1190 COLR cv;
1191
1192 switch (outfmt) {
1193 case 'a':
1194 return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3);
1195 case 'f':
1196 if (fread(fv, sizeof(fv[0]), 3, finp) != 3)
1197 return(0);
1198 copycolor(cnt, fv);
1199 return(1);
1200 case 'd':
1201 return(fread(cnt, sizeof(cnt[0]), 3, finp) == 3);
1202 case 'c':
1203 if (fread(cv, sizeof(cv), 1, finp) != 1)
1204 return(0);
1205 colr_color(fv, cv);
1206 copycolor(cnt, fv);
1207 return(1);
1208 default:
1209 error(INTERNAL, "botched output format");
1210 }
1211 return(0); /* pro forma return */
1212 }
1213
1214 /* close output file opened for input */
1215 static int
1216 myclose(const LUENT *e, void *p)
1217 {
1218 STREAMOUT *sop = (STREAMOUT *)e->data;
1219
1220 if (sop->ofp == NULL)
1221 return(0);
1222 fclose(sop->ofp);
1223 sop->ofp = NULL;
1224 return(0);
1225 }
1226
1227 /* load previously accumulated values */
1228 void
1229 reload_output(void)
1230 {
1231 int i, j;
1232 MODCONT *mp;
1233 int ofl;
1234 char oname[1024];
1235 char *fmode = "rb";
1236 char *outvfmt;
1237 LUENT *ment, *oent;
1238 int xr, yr;
1239 STREAMOUT sout;
1240 DCOLOR rgbv;
1241
1242 switch (outfmt) {
1243 case 'a':
1244 outvfmt = "ascii";
1245 fmode = "r";
1246 break;
1247 case 'f':
1248 outvfmt = "float";
1249 break;
1250 case 'd':
1251 outvfmt = "double";
1252 break;
1253 case 'c':
1254 outvfmt = COLRFMT;
1255 break;
1256 default:
1257 error(INTERNAL, "botched output format");
1258 return;
1259 }
1260 /* reload modifier values */
1261 for (i = 0; i < nmods; i++) {
1262 ment = lu_find(&modconttab,modname[i]);
1263 mp = (MODCONT *)ment->data;
1264 if (mp->outspec == NULL)
1265 error(USER, "cannot reload from stdout");
1266 if (mp->outspec[0] == '!')
1267 error(USER, "cannot reload from command");
1268 for (j = 0; ; j++) { /* load each modifier bin */
1269 ofl = ofname(oname, mp->outspec, mp->modname, j);
1270 if (ofl < 0)
1271 error(USER, "bad output file specification");
1272 oent = lu_find(&ofiletab, oname);
1273 if (oent->data != NULL) {
1274 sout = *(STREAMOUT *)oent->data;
1275 } else {
1276 sout.reclen = 0;
1277 sout.outpipe = 0;
1278 sout.xr = xres; sout.yr = yres;
1279 sout.ofp = NULL;
1280 }
1281 if (sout.ofp == NULL) { /* open output as input */
1282 sout.ofp = fopen(oname, fmode);
1283 if (sout.ofp == NULL) {
1284 if (j)
1285 break; /* assume end of modifier */
1286 sprintf(errmsg, "missing reload file '%s'",
1287 oname);
1288 error(WARNING, errmsg);
1289 break;
1290 }
1291 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1292 sprintf(errmsg, "format mismatch for '%s'",
1293 oname);
1294 error(USER, errmsg);
1295 }
1296 if ((sout.xr > 0) & (sout.yr > 0) &&
1297 (!fscnresolu(&xr, &yr, sout.ofp) ||
1298 (xr != sout.xr) |
1299 (yr != sout.yr))) {
1300 sprintf(errmsg, "resolution mismatch for '%s'",
1301 oname);
1302 error(USER, errmsg);
1303 }
1304 }
1305 /* read in RGB value */
1306 if (!get_contrib(rgbv, sout.ofp)) {
1307 if (!j) {
1308 fclose(sout.ofp);
1309 break; /* ignore empty file */
1310 }
1311 if (j < mp->nbins) {
1312 sprintf(errmsg, "missing data in '%s'",
1313 oname);
1314 error(USER, errmsg);
1315 }
1316 break;
1317 }
1318 if (j >= mp->nbins) /* grow modifier size */
1319 ment->data = (char *)(mp = growmodifier(mp, j+1));
1320 copycolor(mp->cbin[j], rgbv);
1321 if (oent->key == NULL) /* new file entry */
1322 oent->key = strcpy((char *)
1323 malloc(strlen(oname)+1), oname);
1324 if (oent->data == NULL)
1325 oent->data = (char *)malloc(sizeof(STREAMOUT));
1326 *(STREAMOUT *)oent->data = sout;
1327 }
1328 }
1329 lu_doall(&ofiletab, myclose, NULL); /* close all files */
1330 }
1331
1332 /* seek on the given output file */
1333 static int
1334 myseeko(const LUENT *e, void *p)
1335 {
1336 STREAMOUT *sop = (STREAMOUT *)e->data;
1337 off_t nbytes = *(off_t *)p;
1338
1339 if (sop->reclen > 1)
1340 nbytes = nbytes * sop->reclen;
1341 if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) {
1342 sprintf(errmsg, "seek error on file '%s'", e->key);
1343 error(SYSTEM, errmsg);
1344 }
1345 return 0;
1346 }
1347
1348 /* recover output if possible */
1349 void
1350 recover_output(FILE *fin)
1351 {
1352 off_t lastout = -1;
1353 int outvsiz, recsiz;
1354 char *outvfmt;
1355 int i, j;
1356 MODCONT *mp;
1357 int ofl;
1358 char oname[1024];
1359 LUENT *ment, *oent;
1360 STREAMOUT sout;
1361 off_t nvals;
1362 int xr, yr;
1363
1364 switch (outfmt) {
1365 case 'a':
1366 error(USER, "cannot recover ASCII output");
1367 return;
1368 case 'f':
1369 outvsiz = sizeof(float)*3;
1370 outvfmt = "float";
1371 break;
1372 case 'd':
1373 outvsiz = sizeof(double)*3;
1374 outvfmt = "double";
1375 break;
1376 case 'c':
1377 outvsiz = sizeof(COLR);
1378 outvfmt = COLRFMT;
1379 break;
1380 default:
1381 error(INTERNAL, "botched output format");
1382 return;
1383 }
1384 /* check modifier outputs */
1385 for (i = 0; i < nmods; i++) {
1386 ment = lu_find(&modconttab,modname[i]);
1387 mp = (MODCONT *)ment->data;
1388 if (mp->outspec == NULL)
1389 error(USER, "cannot recover from stdout");
1390 if (mp->outspec[0] == '!')
1391 error(USER, "cannot recover from command");
1392 for (j = 0; ; j++) { /* check each bin's file */
1393 ofl = ofname(oname, mp->outspec, mp->modname, j);
1394 if (ofl < 0)
1395 error(USER, "bad output file specification");
1396 oent = lu_find(&ofiletab, oname);
1397 if (oent->data != NULL) {
1398 sout = *(STREAMOUT *)oent->data;
1399 } else {
1400 sout.reclen = 0;
1401 sout.outpipe = 0;
1402 sout.ofp = NULL;
1403 }
1404 if (sout.ofp != NULL) { /* already open? */
1405 if (ofl & OF_BIN)
1406 continue;
1407 break;
1408 }
1409 /* open output */
1410 sout.ofp = fopen(oname, "rb+");
1411 if (sout.ofp == NULL) {
1412 if (j)
1413 break; /* assume end of modifier */
1414 sprintf(errmsg, "missing recover file '%s'",
1415 oname);
1416 error(WARNING, errmsg);
1417 break;
1418 }
1419 nvals = lseek(fileno(sout.ofp), 0, SEEK_END);
1420 if (nvals <= 0) {
1421 lastout = 0; /* empty output, quit here */
1422 fclose(sout.ofp);
1423 break;
1424 }
1425 if (!sout.reclen) {
1426 if (!(ofl & OF_BIN)) {
1427 sprintf(errmsg,
1428 "need -bn to recover file '%s'",
1429 oname);
1430 error(USER, errmsg);
1431 }
1432 recsiz = outvsiz;
1433 } else
1434 recsiz = outvsiz * sout.reclen;
1435
1436 lseek(fileno(sout.ofp), 0, SEEK_SET);
1437 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1438 sprintf(errmsg, "format mismatch for '%s'",
1439 oname);
1440 error(USER, errmsg);
1441 }
1442 sout.xr = xres; sout.yr = yres;
1443 if ((sout.xr > 0) & (sout.yr > 0) &&
1444 (!fscnresolu(&xr, &yr, sout.ofp) ||
1445 (xr != sout.xr) |
1446 (yr != sout.yr))) {
1447 sprintf(errmsg, "resolution mismatch for '%s'",
1448 oname);
1449 error(USER, errmsg);
1450 }
1451 nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz;
1452 if ((lastout < 0) | (nvals < lastout))
1453 lastout = nvals;
1454 if (oent->key == NULL) /* new entry */
1455 oent->key = strcpy((char *)
1456 malloc(strlen(oname)+1), oname);
1457 if (oent->data == NULL)
1458 oent->data = (char *)malloc(sizeof(STREAMOUT));
1459 *(STREAMOUT *)oent->data = sout;
1460 if (!(ofl & OF_BIN))
1461 break; /* no bin separation */
1462 }
1463 if (!lastout) { /* empty output */
1464 error(WARNING, "no previous data to recover");
1465 lu_done(&ofiletab); /* reclose all outputs */
1466 return;
1467 }
1468 if (j > mp->nbins) /* reallocate modifier bins */
1469 ment->data = (char *)(mp = growmodifier(mp, j));
1470 }
1471 if (lastout < 0) {
1472 error(WARNING, "no output files to recover");
1473 return;
1474 }
1475 if (raysleft && lastout >= raysleft/accumulate) {
1476 error(WARNING, "output appears to be complete");
1477 /* XXX should read & discard input? */
1478 quit(0);
1479 }
1480 /* seek on all files */
1481 nvals = lastout * outvsiz;
1482 lu_doall(&ofiletab, myseeko, &nvals);
1483 /* skip repeated input */
1484 for (nvals = 0; nvals < lastout; nvals++)
1485 if (getinp(oname, fin) < 0)
1486 error(USER, "unexpected EOF on input");
1487 lastray = lastdone = (unsigned long)lastout * accumulate;
1488 if (raysleft)
1489 raysleft -= lastray;
1490 }
