root/radiance/ray/src/util/rtcontrib.c
Revision: 1.39
Committed: Fri Oct 21 01:12:59 2005 UTC (18 years, 6 months ago) by greg
Changes since 1.38: +4 -1 lines
Added check for -P and -PP option, which causes conflict
2 static const char RCSid[] = "$Id: rtcontrib.c,v 1.38 2005/10/11 23:55:37 greg Exp $";
5 * Gather rtrace output to compute contributions from particular sources
6 */
7
8 #include "standard.h"
9 #include <ctype.h>
10 #include <signal.h>
11 #include "platform.h"
12 #include "rtprocess.h"
13 #include "selcall.h"
14 #include "color.h"
15 #include "resolu.h"
16 #include "lookup.h"
17 #include "calcomp.h"
18
19 #ifndef MAXMODLIST
20 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
21 #endif
22
23 int treebufsiz = BUFSIZ; /* current tree buffer size */
24
25 typedef double DCOLOR[3]; /* double-precision color */
26
27 /*
28 * The MODCONT structure is used to accumulate ray contributions
29 * for a particular modifier, which may be subdivided into bins
30 * if binv is non-zero. If outspec contains a %s in it, this will
31 * be replaced with the modifier name. If outspec contains a %d in it,
32 * this will be used to create one output file per bin, otherwise all bins
33 * will be written to the same file, in order. If the global outfmt
34 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
35 * and the file will conform to a RADIANCE image if xres & yres are set.
36 */
37 typedef struct {
38 const char *outspec; /* output file specification */
39 const char *modname; /* modifier name */
40 EPNODE *binv; /* bin value expression */
41 int nbins; /* number of accumulation bins */
42 DCOLOR cbin[1]; /* contribution bins (extends struct) */
43 } MODCONT; /* modifier contribution */
44
45 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
46
47 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
48
49 #define CNT_UNKNOWN 0 /* unknown record length */
50 #define CNT_PIPE (-1) /* output to a pipe */
51 /*
52 * The STREAMOUT structure holds an open FILE pointer and a count of
53 * the number of RGB triplets per record, or CNT_UNKNOWN (0) if
54 * unknown or CNT_PIPE (-1) if writing to a command.
55 */
56 typedef struct {
57 FILE *ofp; /* output file pointer */
58 int reclen; /* triplets/record */
59 } STREAMOUT;
60
61 /* close output stream and free record */
62 static void
63 closestream(void *p)
64 {
65 STREAMOUT *sop = (STREAMOUT *)p;
66 int status;
67 if (sop->reclen == CNT_PIPE)
68 status = pclose(sop->ofp);
69 else
70 status = fclose(sop->ofp);
71 if (status)
72 error(SYSTEM, "error closing output stream");
73 free(p);
74 }
75
76 LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
77
78 #define OF_MODIFIER 01
79 #define OF_BIN 02
80
81 STREAMOUT *getostream(const char *ospec, const char *mname, int bn, int noopen);
82 int ofname(char *oname, const char *ospec, const char *mname, int bn);
83 void printheader(FILE *fout, const char *info);
84 void printresolu(FILE *fout);
85
86 /*
87 * The rcont structure is used to manage i/o with a particular
88 * rtrace child process. Input is passed unchanged from stdin,
89 * and output is processed in input order and accumulated according
90 * to the corresponding modifier and bin number.
91 */
92 struct rtproc {
93 struct rtproc *next; /* next in list of processes */
94 SUBPROC pd; /* rtrace pipe descriptors */
95 unsigned long raynum; /* ray number for this tree */
96 int bsiz; /* ray tree buffer length */
97 char *buf; /* ray tree buffer */
98 int nbr; /* number of bytes from rtrace */
99 }; /* rtrace process buffer */
100
101 /* rtrace command and defaults */
102 char *rtargv[256+2*MAXMODLIST] = { "rtrace",
103 "-dj", ".5", "-dr", "3",
104 "-ab", "1", "-ad", "128", };
105 int rtargc = 9;
106 /* overriding rtrace options */
107 char *myrtopts[] = { "-o~~TmWdp", "-h-", "-x", "1", "-y", "0",
108 "-dt", "0", "-as", "0", "-aa", "0", NULL };
109
110 struct rtproc rt0; /* head of rtrace process list */
111
112 struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
113
114 char persistfn[] = "pfXXXXXX"; /* persist file name */
115
116 int gargc; /* global argc */
117 char **gargv; /* global argv */
118 #define progname gargv[0]
119
120 char *octree; /* global octree argument */
121
122 int inpfmt = 'a'; /* input format */
123 int outfmt = 'a'; /* output format */
124
125 int header = 1; /* output header? */
126 int force_open = 0; /* truncate existing output? */
127 int xres = 0; /* horiz. output resolution */
128 int yres = 0; /* vert. output resolution */
129
130 unsigned long raysleft; /* number of rays left to trace */
131 long waitflush; /* how long until next flush */
132
133 unsigned long lastray = 0; /* last ray number sent */
134 unsigned long lastdone = 0; /* last ray processed */
135
136 int using_stdout = 0; /* are we using stdout? */
137
138 const char *modname[MAXMODLIST]; /* ordered modifier name list */
139 int nmods = 0; /* number of modifiers */
140
141 #define queue_length() (lastray - lastdone)
142
143 MODCONT *growmodifier(MODCONT *mp, int nb);
144 MODCONT *addmodifier(char *modn, char *outf, char *binv, int bincnt);
145 void addmodfile(char *fname, char *outf, char *binv, int bincnt);
146
147 void init(int np);
148 int done_rprocs(struct rtproc *rtp);
149 void recover_output(FILE *fin);
150 void trace_contribs(FILE *fin);
151 struct rtproc *wait_rproc(void);
152 struct rtproc *get_rproc(void);
153 void queue_raytree(struct rtproc *rtp);
154 void process_queue(void);
155
156 void put_contrib(const DCOLOR cnt, FILE *fout);
157 void add_contrib(const char *modn);
158 void done_contrib(void);
159
160 /* return number of open rtrace processes */
161 static int
162 nrtprocs(void)
163 {
164 int nrtp = 0;
165 struct rtproc *rtp;
166
167 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
168 nrtp += rtp->pd.running;
169 return(nrtp);
170 }
171
172 /* set input/output format */
173 static void
174 setformat(const char *fmt)
175 {
176 switch (fmt[0]) {
177 case 'f':
178 case 'd':
179 SET_FILE_BINARY(stdin);
180 /* fall through */
181 case 'a':
182 inpfmt = fmt[0];
183 break;
184 default:
185 goto fmterr;
186 }
187 switch (fmt[1]) {
188 case '\0':
189 outfmt = inpfmt;
190 return;
191 case 'a':
192 case 'f':
193 case 'd':
194 case 'c':
195 outfmt = fmt[1];
196 break;
197 default:
198 goto fmterr;
199 }
200 if (!fmt[2])
201 return;
202 fmterr:
203 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
204 error(USER, errmsg);
205 }
206
207 /* gather rays from rtrace and output contributions */
208 int
209 main(int argc, char *argv[])
210 {
211 int nprocs = 1;
212 int recover = 0;
213 char *curout = NULL;
214 char *binval = NULL;
215 int bincnt = 0;
216 char fmt[8];
217 int i, j;
218 /* need at least one argument */
219 if (argc < 2) {
220 fprintf(stderr,
221 "Usage: %s [-n nprocs][-r][-e expr][-f source][-o ospec][-b binv] {-m mod | -M file} [rtrace options] octree\n",
222 argv[0]);
223 exit(1);
224 }
225 /* global program name */
226 gargv = argv;
227 /* initialize calcomp routines */
228 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
229 esupport &= ~(E_OUTCHAN);
230 varset("PI", ':', PI);
231 /* get our options */
232 for (i = 1; i < argc-1; i++) {
233 /* expand arguments */
234 while ((j = expandarg(&argc, &argv, i)) > 0)
235 ;
236 if (j < 0) {
237 fprintf(stderr, "%s: cannot expand '%s'",
238 argv[0], argv[i]);
239 exit(1);
240 }
241 if (argv[i][0] == '-')
242 switch (argv[i][1]) {
243 case 'r': /* recover output */
244 if (argv[i][2]) break;
245 recover++;
246 continue;
247 case 'n': /* number of processes */
248 if (argv[i][2] || i >= argc-2) break;
249 nprocs = atoi(argv[++i]);
250 if (nprocs <= 0)
251 error(USER, "illegal number of processes");
252 continue;
253 case 'h': /* output header? */
254 switch (argv[i][2]) {
255 case '\0':
256 header = !header;
257 continue;
258 case '+': case '1':
259 case 'T': case 't':
260 case 'Y': case 'y':
261 header = 1;
262 continue;
263 case '-': case '0':
264 case 'F': case 'f':
265 case 'N': case 'n':
266 header = 0;
267 continue;
268 }
269 break;
270 case 'f': /* file or force or format */
271 if (!argv[i][2]) {
272 char *fpath;
273 if (i >= argc-2) break;
274 fpath = getpath(argv[++i],
275 getrlibpath(), R_OK);
276 if (fpath == NULL) {
277 sprintf(errmsg,
278 "cannot find file '%s'",
279 argv[i]);
280 error(USER, errmsg);
281 }
282 fcompile(fpath);
283 continue;
284 }
285 if (argv[i][2] == 'o') {
286 force_open++;
287 continue;
288 }
289 setformat(argv[i]+2);
290 continue;
291 case 'e': /* expression */
292 if (argv[i][2] || i >= argc-2) break;
293 scompile(argv[++i], NULL, 0);
294 continue;
295 case 'o': /* output file spec. */
296 if (argv[i][2] || i >= argc-2) break;
297 curout = argv[++i];
298 continue;
299 case 'x': /* horiz. output resolution */
300 if (argv[i][2] || i >= argc-2) break;
301 xres = atoi(argv[++i]);
302 continue;
303 case 'y': /* vert. output resolution */
304 if (argv[i][2] || i >= argc-2) break;
305 yres = atoi(argv[++i]);
306 continue;
307 case 'b': /* bin expression/count */
308 if (i >= argc-2) break;
309 if (argv[i][2] == 'n') {
310 bincnt = atoi(argv[++i]);
311 continue;
312 }
313 if (argv[i][2]) break;
314 binval = argv[++i];
315 continue;
316 case 'm': /* modifier name */
317 if (argv[i][2] || i >= argc-2) break;
318 rtargv[rtargc++] = "-ti";
319 rtargv[rtargc++] = argv[++i];
320 addmodifier(argv[i], curout, binval, bincnt);
321 continue;
322 case 'M': /* modifier file */
323 if (argv[i][2] || i >= argc-2) break;
324 rtargv[rtargc++] = "-tI";
325 rtargv[rtargc++] = argv[++i];
326 addmodfile(argv[i], curout, binval, bincnt);
327 continue;
328 case 'P': /* persist file */
329 error(USER, "persist file is automatic");
330 break;
331 }
332 rtargv[rtargc++] = argv[i]; /* assume rtrace option */
333 }
334 /* set global argument list */
335 gargc = argc; gargv = argv;
336 /* add "mandatory" rtrace settings */
337 for (j = 0; myrtopts[j] != NULL; j++)
338 rtargv[rtargc++] = myrtopts[j];
339 /* just asking for defaults? */
340 if (!strcmp(argv[i], "-defaults")) {
341 char sxres[16], syres[16];
342 char *rtpath;
343 printf("-n %-2d\t\t\t\t# number of processes\n", nprocs);
344 fflush(stdout); /* report OUR options */
345 rtargv[rtargc++] = header ? "-h+" : "-h-";
346 sprintf(fmt, "-f%c%c", inpfmt, outfmt);
347 rtargv[rtargc++] = fmt;
348 rtargv[rtargc++] = "-x";
349 sprintf(sxres, "%d", xres);
350 rtargv[rtargc++] = sxres;
351 rtargv[rtargc++] = "-y";
352 sprintf(syres, "%d", yres);
353 rtargv[rtargc++] = syres;
354 rtargv[rtargc++] = "-oTW";
355 rtargv[rtargc++] = "-defaults";
356 rtargv[rtargc] = NULL;
357 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
358 if (rtpath == NULL) {
359 eputs(rtargv[0]);
360 eputs(": command not found\n");
361 exit(1);
362 }
363 execv(rtpath, rtargv);
364 perror(rtpath); /* execv() should not return */
365 exit(1);
366 }
367 if (nprocs > 1) { /* add persist file if parallel */
368 rtargv[rtargc++] = "-PP";
369 rtargv[rtargc++] = mktemp(persistfn);
370 }
371 /* add format string */
372 sprintf(fmt, "-f%cf", inpfmt);
373 rtargv[rtargc++] = fmt;
374 /* octree argument is last */
375 if (i <= 0 || i != argc-1 || argv[i][0] == '-')
376 error(USER, "missing octree argument");
377 rtargv[rtargc++] = octree = argv[i];
378 rtargv[rtargc] = NULL;
379 /* start rtrace */
380 init(nprocs);
381 if (recover) /* perform recovery if requested */
382 recover_output(stdin);
383 trace_contribs(stdin); /* compute contributions */
384 quit(0);
385 }
386
387 #ifndef SIGALRM
388 #define SIGALRM SIGTERM
389 #endif
390 /* kill persistent rtrace process */
391 static void
392 killpersist(void)
393 {
394 FILE *fp = fopen(persistfn, "r");
395 RT_PID pid;
396
397 if (fp == NULL)
398 return;
399 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
400 unlink(persistfn);
401 fclose(fp);
402 }
403
404 /* close rtrace processes and clean up */
405 int
406 done_rprocs(struct rtproc *rtp)
407 {
408 int st0, st1 = 0;
409
410 if (rtp->next != NULL) { /* close last opened first! */
411 st1 = done_rprocs(rtp->next);
412 free((void *)rtp->next);
413 rtp->next = NULL;
414 }
415 st0 = close_process(&rtp->pd);
416 if (st0 < 0)
417 error(WARNING, "unknown return status from rtrace process");
418 else if (st0 > 0)
419 return(st0);
420 return(st1);
421 }
422
423 /* exit with status */
424 void
425 quit(int status)
426 {
427 int rtstat;
428
429 if (rt0.next != NULL) /* terminate persistent rtrace */
430 killpersist();
431 /* clean up rtrace process(es) */
432 rtstat = done_rprocs(&rt0);
433 if (status == 0)
434 status = rtstat;
435 exit(status); /* flushes all output streams */
436 }
437
438 /* start rtrace processes and initialize */
439 void
440 init(int np)
441 {
442 struct rtproc *rtp;
443 int i;
444 int maxbytes;
445 /* make sure we have something to do */
446 if (!nmods)
447 error(USER, "No modifiers specified");
448 /* assign ray variables */
449 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
450 scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
451 /* set up signal handling */
452 signal(SIGINT, quit);
453 #ifdef SIGHUP
454 signal(SIGHUP, quit);
455 #endif
456 #ifdef SIGTERM
457 signal(SIGTERM, quit);
458 #endif
459 #ifdef SIGPIPE
460 signal(SIGPIPE, quit);
461 #endif
462 rtp = &rt0; /* start rtrace process(es) */
463 for (i = 0; i++ < np; ) {
464 errno = 0;
465 maxbytes = open_process(&rtp->pd, rtargv);
466 if (maxbytes == 0) {
467 eputs(rtargv[0]);
468 eputs(": command not found\n");
469 exit(1);
470 }
471 if (maxbytes < 0)
472 error(SYSTEM, "cannot start rtrace process");
473 if (maxbytes > treebufsiz)
474 treebufsiz = maxbytes;
475 rtp->raynum = 0;
476 rtp->bsiz = 0;
477 rtp->buf = NULL;
478 rtp->nbr = 0;
479 if (i == np) /* last process? */
480 break;
481 if (i == 1)
482 sleep(2); /* wait for persist file */
483 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
484 if (rtp->next == NULL)
485 error(SYSTEM, "out of memory in init");
486 rtp = rtp->next;
487 }
488 rtp->next = NULL; /* terminate list */
489 if (yres > 0) {
490 if (xres > 0)
491 raysleft = (unsigned long)xres*yres;
492 else
493 raysleft = yres;
494 } else
495 raysleft = 0;
496 waitflush = xres;
497 }
498
499 /* grow modifier to accommodate more bins */
500 MODCONT *
501 growmodifier(MODCONT *mp, int nb)
502 {
503 if (nb <= mp->nbins)
504 return mp;
505 mp = (MODCONT *)realloc(mp, sizeof(MODCONT) + sizeof(DCOLOR)*(nb-1));
506 if (mp == NULL)
507 error(SYSTEM, "out of memory in growmodifier");
508 memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(nb-mp->nbins));
509 mp->nbins = nb;
510 return mp;
511 }
512
513 /* add modifier to our list to track */
514 MODCONT *
515 addmodifier(char *modn, char *outf, char *binv, int bincnt)
516 {
517 LUENT *lep = lu_find(&modconttab, modn);
518 MODCONT *mp;
519 int i;
520
521 if (lep->data != NULL) {
522 sprintf(errmsg, "duplicate modifier '%s'", modn);
523 error(USER, errmsg);
524 }
525 if (nmods >= MAXMODLIST)
526 error(USER, "too many modifiers");
527 modname[nmods++] = modn; /* XXX assumes static string */
528 lep->key = modn; /* XXX assumes static string */
529 mp = (MODCONT *)malloc(sizeof(MODCONT));
530 if (mp == NULL)
531 error(SYSTEM, "out of memory in addmodifier");
532 mp->outspec = outf; /* XXX assumes static string */
533 mp->modname = modn; /* XXX assumes static string */
534 if (binv != NULL)
535 mp->binv = eparse(binv);
536 else
537 mp->binv = eparse("0");
538 mp->nbins = 1;
539 setcolor(mp->cbin[0], 0., 0., 0.);
540 if (mp->binv->type == NUM) /* assume one bin if constant */
541 bincnt = 1;
542 else if (bincnt > 1)
543 mp = growmodifier(mp, bincnt);
544 lep->data = (char *)mp;
545 /* allocate output streams */
546 for (i = outf==NULL || outf[0]=='!' ? 0 : bincnt; i--; )
547 getostream(mp->outspec, mp->modname, i, 1);
548 return mp;
549 }
550
551 /* add modifiers from a file list */
552 void
553 addmodfile(char *fname, char *outf, char *binv, int bincnt)
554 {
555 char *mname[MAXMODLIST];
556 int i;
557 /* find the file & store strings */
558 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
559 sprintf(errmsg, "cannot find modifier file '%s'", fname);
560 error(SYSTEM, errmsg);
561 }
562 for (i = 0; mname[i]; i++) /* add each one */
563 addmodifier(mname[i], outf, binv, bincnt);
564 }
565
566 /* put string to stderr */
567 void
568 eputs(char *s)
569 {
570 static int midline = 0;
571
572 if (!*s) return;
573 if (!midline) {
574 fputs(progname, stderr);
575 fputs(": ", stderr);
576 }
577 fputs(s, stderr);
578 midline = s[strlen(s)-1] != '\n';
579 }
580
581 /* construct output file name and return flags whether modifier/bin present */
582 int
583 ofname(char *oname, const char *ospec, const char *mname, int bn)
584 {
585 const char *mnp = NULL;
586 const char *bnp = NULL;
587 const char *cp;
588
589 if (ospec == NULL)
590 return -1;
591 for (cp = ospec; *cp; cp++) /* check format position(s) */
592 if (*cp == '%') {
593 do
594 ++cp;
595 while (isdigit(*cp));
596 switch (*cp) {
597 case '%':
598 break;
599 case 's':
600 if (mnp != NULL)
601 return -1;
602 mnp = cp;
603 break;
604 case 'd':
605 if (bnp != NULL)
606 return -1;
607 bnp = cp;
608 break;
609 default:
610 return -1;
611 }
612 }
613 if (mnp != NULL) { /* create file name */
614 if (bnp != NULL) {
615 if (bnp > mnp)
616 sprintf(oname, ospec, mname, bn);
617 else
618 sprintf(oname, ospec, bn, mname);
619 return OF_MODIFIER|OF_BIN;
620 }
621 sprintf(oname, ospec, mname);
622 return OF_MODIFIER;
623 }
624 if (bnp != NULL) {
625 sprintf(oname, ospec, bn);
626 return OF_BIN;
627 }
628 strcpy(oname, ospec);
629 return 0;
630 }
631
632 /* write header to the given output stream */
633 void
634 printheader(FILE *fout, const char *info)
635 {
636 extern char VersionID[];
637 FILE *fin = fopen(octree, "r");
638
639 if (fin == NULL)
640 quit(1);
641 checkheader(fin, "ignore", fout); /* copy octree header */
642 fclose(fin);
643 printargs(gargc-1, gargv, fout); /* add our command */
644 fprintf(fout, "SOFTWARE= %s\n", VersionID);
645 fputnow(fout);
646 if (info != NULL) /* add extra info if given */
647 fputs(info, fout);
648 switch (outfmt) { /* add output format */
649 case 'a':
650 fputformat("ascii", fout);
651 break;
652 case 'f':
653 fputformat("float", fout);
654 break;
655 case 'd':
656 fputformat("double", fout);
657 break;
658 case 'c':
659 fputformat(COLRFMT, fout);
660 break;
661 }
662 fputc('\n', fout);
663 }
664
665 /* write resolution string to given output stream */
666 void
667 printresolu(FILE *fout)
668 {
669 if (xres > 0) {
670 if (yres > 0) /* resolution string */
671 fprtresolu(xres, yres, fout);
672 fflush(fout);
673 }
674 }
675
676 /* Get output stream pointer (open and write header if new and noopen==0) */
677 STREAMOUT *
678 getostream(const char *ospec, const char *mname, int bn, int noopen)
679 {
680 static STREAMOUT stdos;
681 int ofl;
682 char oname[1024];
683 LUENT *lep;
684 STREAMOUT *sop;
685
686 if (ospec == NULL) { /* use stdout? */
687 if (!noopen && !using_stdout) {
688 stdos.reclen = 0;
689 if (outfmt != 'a')
690 SET_FILE_BINARY(stdout);
691 if (header)
692 printheader(stdout, NULL);
693 printresolu(stdout);
694 using_stdout = 1;
695 }
696 stdos.ofp = stdout;
697 stdos.reclen += noopen;
698 return &stdos;
699 }
700 ofl = ofname(oname, ospec, mname, bn); /* get output name */
701 if (ofl < 0) {
702 sprintf(errmsg, "bad output format '%s'", ospec);
703 error(USER, errmsg);
704 }
705 lep = lu_find(&ofiletab, oname); /* look it up */
706 if (lep->key == NULL) /* new entry */
707 lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
708 sop = (STREAMOUT *)lep->data;
709 if (sop == NULL) { /* allocate stream */
710 sop = (STREAMOUT *)malloc(sizeof(STREAMOUT));
711 if (sop == NULL)
712 error(SYSTEM, "out of memory in getostream");
713 sop->reclen = oname[0] == '!' ? CNT_PIPE : CNT_UNKNOWN;
714 sop->ofp = NULL; /* open iff noopen==0 */
715 lep->data = (char *)sop;
716 }
717 if (!noopen && sop->ofp == NULL) { /* open output stream */
718 long i;
719 if (oname[0] == '!') /* output to command */
720 sop->ofp = popen(oname+1, "w");
721 else if (!force_open && access(oname, F_OK) == 0)
722 errno = EEXIST; /* file exists */
723 else /* else open it */
724 sop->ofp = fopen(oname, "w");
725 if (sop->ofp == NULL) {
726 sprintf(errmsg, "cannot open '%s' for writing", oname);
727 error(SYSTEM, errmsg);
728 }
729 if (outfmt != 'a')
730 SET_FILE_BINARY(sop->ofp);
731 if (header) {
732 char info[512];
733 char *cp = info;
734 if (ofl & OF_MODIFIER || sop->reclen == 1) {
735 sprintf(cp, "MODIFIER=%s\n", mname);
736 while (*cp) ++cp;
737 }
738 if (ofl & OF_BIN) {
739 sprintf(cp, "BIN=%d\n", bn);
740 while (*cp) ++cp;
741 }
742 *cp = '\0';
743 printheader(sop->ofp, info);
744 }
745 printresolu(sop->ofp);
746 /* play catch-up */
747 for (i = sop->reclen > 1 ? sop->reclen*lastdone : lastdone;
748 i--; ) {
749 static const DCOLOR nocontrib = BLKCOLOR;
750 put_contrib(nocontrib, sop->ofp);
751 if (outfmt == 'a')
752 putc('\n', sop->ofp);
753 }
754 if (xres > 0)
755 fflush(sop->ofp);
756 }
757 if (sop->reclen != CNT_PIPE) /* add to length if noopen */
758 sop->reclen += noopen;
759 return sop; /* return open stream */
760 }
761
762 /* read input ray into buffer */
763 int
764 getinp(char *buf, FILE *fp)
765 {
766 double dv[3];
767 float fv[3];
768 char *cp;
769 int i;
770
771 switch (inpfmt) {
772 case 'a':
773 cp = buf; /* make sure we get 6 floats */
774 for (i = 0; i < 6; i++) {
775 if (fgetword(cp, buf+127-cp, fp) == NULL)
776 return -1;
777 if (i >= 3)
778 dv[i-3] = atof(cp);
779 if ((cp = fskip(cp)) == NULL || *cp)
780 return -1;
781 *cp++ = ' ';
782 }
783 getc(fp); /* get/put eol */
784 *cp-- = '\0'; *cp = '\n';
785 if (DOT(dv,dv) <= FTINY*FTINY)
786 return 0; /* dummy ray */
787 return strlen(buf);
788 case 'f':
789 if (fread(buf, sizeof(float), 6, fp) < 6)
790 return -1;
791 memcpy(fv, buf+3*sizeof(float), 3*sizeof(float));
792 if (DOT(fv,fv) <= FTINY*FTINY)
793 return 0; /* dummy ray */
794 return sizeof(float)*6;
795 case 'd':
796 if (fread(buf, sizeof(double), 6, fp) < 6)
797 return -1;
798 memcpy(dv, buf+3*sizeof(double), 3*sizeof(double));
799 if (DOT(dv,dv) <= FTINY*FTINY)
800 return 0; /* dummy ray */
801 return sizeof(double)*6;
802 }
803 error(INTERNAL, "botched input format");
804 return -1; /* pro forma return */
805 }
806
807 static float rparams[9]; /* traced ray parameters */
808
809 /* return channel (ray) value */
810 double
811 chanvalue(int n)
812 {
813 if (--n < 0 || n >= 6)
814 error(USER, "illegal channel number ($N)");
815 return rparams[n+3];
816 }
817
818 /* add current ray contribution to the appropriate modifier bin */
819 void
820 add_contrib(const char *modn)
821 {
822 LUENT *le = lu_find(&modconttab, modn);
823 MODCONT *mp = (MODCONT *)le->data;
824 int bn;
825
826 if (mp == NULL) {
827 sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
828 error(USER, errmsg);
829 }
830 eclock++; /* get bin number */
831 bn = (int)(evalue(mp->binv) + .5);
832 if (bn <= 0)
833 bn = 0;
834 else if (bn >= mp->nbins) /* new bin */
835 le->data = (char *)(mp = growmodifier(mp, bn+1));
836 addcolor(mp->cbin[bn], rparams);
837 }
838
839 /* output newline to ASCII file and/or flush as requested */
840 static int
841 puteol(const LUENT *e, void *p)
842 {
843 STREAMOUT *sop = (STREAMOUT *)e->data;
844
845 if (outfmt == 'a')
846 putc('\n', sop->ofp);
847 if (!waitflush)
848 fflush(sop->ofp);
849 if (ferror(sop->ofp)) {
850 sprintf(errmsg, "write error on file '%s'", e->key);
851 error(SYSTEM, errmsg);
852 }
853 return 0;
854 }
855
856 /* put out ray contribution to file */
857 void
858 put_contrib(const DCOLOR cnt, FILE *fout)
859 {
860 float fv[3];
861 COLR cv;
862
863 switch (outfmt) {
864 case 'a':
865 fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
866 break;
867 case 'f':
868 fv[0] = cnt[0];
869 fv[1] = cnt[1];
870 fv[2] = cnt[2];
871 fwrite(fv, sizeof(float), 3, fout);
872 break;
873 case 'd':
874 fwrite(cnt, sizeof(double), 3, fout);
875 break;
876 case 'c':
877 setcolr(cv, cnt[0], cnt[1], cnt[2]);
878 fwrite(cv, sizeof(cv), 1, fout);
879 break;
880 default:
881 error(INTERNAL, "botched output format");
882 }
883 }
884
885 /* output ray tallies and clear for next primary */
886 void
887 done_contrib(void)
888 {
889 int i, j;
890 MODCONT *mp;
891 STREAMOUT *sop;
892 /* output modifiers in order */
893 for (i = 0; i < nmods; i++) {
894 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
895 sop = getostream(mp->outspec, mp->modname, 0,0);
896 put_contrib(mp->cbin[0], sop->ofp);
897 if (mp->nbins > 3 && /* minor optimization */
898 sop == getostream(mp->outspec, mp->modname, 1,0))
899 for (j = 1; j < mp->nbins; j++)
900 put_contrib(mp->cbin[j], sop->ofp);
901 else
902 for (j = 1; j < mp->nbins; j++)
903 put_contrib(mp->cbin[j],
904 getostream(mp->outspec,mp->modname,j,0)->ofp);
905 /* clear for next ray tree */
906 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
907 }
908 --waitflush; /* terminate records */
909 lu_doall(&ofiletab, puteol, NULL);
910 if (using_stdout & (outfmt == 'a'))
911 putc('\n', stdout);
912 if (!waitflush) {
913 waitflush = xres;
914 if (using_stdout)
915 fflush(stdout);
916 }
917 }
918
919 /* queue completed ray tree produced by rtrace process */
920 void
921 queue_raytree(struct rtproc *rtp)
922 {
923 struct rtproc *rtu, *rtl = NULL;
924 /* insert following ray order */
925 for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
926 if (rtp->raynum < rtu->raynum)
927 break;
928 rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
929 if (rtu == NULL)
930 error(SYSTEM, "out of memory in queue_raytree");
931 *rtu = *rtp;
932 if (rtl == NULL) {
933 rtu->next = rt_unproc;
934 rt_unproc = rtu;
935 } else {
936 rtu->next = rtl->next;
937 rtl->next = rtu;
938 }
939 rtp->raynum = 0; /* clear path for next ray tree */
940 rtp->bsiz = 0;
941 rtp->buf = NULL;
942 rtp->nbr = 0;
943 }
944
945 /* process completed ray trees from our queue */
946 void
947 process_queue(void)
948 {
949 char modname[128];
950 /* ray-ordered queue */
951 while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
952 struct rtproc *rtp = rt_unproc;
953 int n = rtp->nbr;
954 const char *cp = rtp->buf;
955 while (n > 0) { /* process rays */
956 register char *mnp = modname;
957 /* skip leading tabs */
958 while (n > 0 && *cp == '\t') {
959 cp++; n--;
960 }
961 if (!n || !(isalpha(*cp) | (*cp == '_')))
962 error(USER, "bad modifier name from rtrace");
963 /* get modifier name */
964 while (n > 0 && *cp != '\t') {
965 *mnp++ = *cp++; n--;
966 }
967 *mnp = '\0';
968 cp++; n--; /* eat following tab */
969 if (n < (int)(sizeof(float)*9))
970 error(USER, "incomplete ray value from rtrace");
971 /* add ray contribution */
972 memcpy(rparams, cp, sizeof(float)*9);
973 cp += sizeof(float)*9; n -= sizeof(float)*9;
974 add_contrib(modname);
975 }
976 done_contrib(); /* sum up contributions & output */
977 lastdone = rtp->raynum;
978 if (rtp->buf != NULL) /* free up buffer space */
979 free(rtp->buf);
980 rt_unproc = rtp->next;
981 free(rtp); /* done with this ray tree */
982 }
983 }
984
985 /* wait for rtrace process to finish with ray tree */
986 struct rtproc *
987 wait_rproc(void)
988 {
989 struct rtproc *rtfree = NULL;
990 fd_set readset, errset;
991 int nr;
992 struct rtproc *rt;
993 int n;
994
995 do {
996 nr = 0; /* prepare select call */
997 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
998 for (rt = &rt0; rt != NULL; rt = rt->next) {
999 if (rt->raynum) {
1000 FD_SET(rt->pd.r, &readset);
1001 ++nr;
1002 }
1003 FD_SET(rt->pd.r, &errset);
1004 if (rt->pd.r >= n)
1005 n = rt->pd.r + 1;
1006 }
1007 if (!nr) /* no rays pending */
1008 break;
1009 if (nr > 1) { /* call select for multiple proc's */
1010 errno = 0;
1011 if (select(n, &readset, NULL, &errset, NULL) < 0)
1012 error(SYSTEM, "select call error in wait_rproc()");
1013 } else
1014 FD_ZERO(&errset);
1015 nr = 0;
1016 for (rt = &rt0; rt != NULL; rt = rt->next) {
1017 if (!FD_ISSET(rt->pd.r, &readset) &&
1018 !FD_ISSET(rt->pd.r, &errset))
1019 continue;
1020 if (rt->buf == NULL) {
1021 rt->bsiz = treebufsiz;
1022 rt->buf = (char *)malloc(treebufsiz);
1023 } else if (rt->nbr + BUFSIZ > rt->bsiz) {
1024 if (rt->bsiz + BUFSIZ <= treebufsiz)
1025 rt->bsiz = treebufsiz;
1026 else
1027 treebufsiz = rt->bsiz += BUFSIZ;
1028 rt->buf = (char *)realloc(rt->buf, rt->bsiz);
1029 }
1030 if (rt->buf == NULL)
1031 error(SYSTEM, "out of memory in wait_rproc");
1032 nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
1033 if (nr <= 0)
1034 error(USER, "rtrace process died");
1035 rt->nbr += nr; /* advance & check */
1036 if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4,
1037 "~\t~\t", 4)) {
1038 rt->nbr -= 4; /* elide terminator */
1039 queue_raytree(rt);
1040 rtfree = rt; /* ready for next ray */
1041 }
1042 }
1043 } while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
1044 return rtfree;
1045 }
1046
1047 /* return next available rtrace process */
1048 struct rtproc *
1049 get_rproc(void)
1050 {
1051 struct rtproc *rtp;
1052 /* check for idle rtrace */
1053 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
1054 if (!rtp->raynum)
1055 return rtp;
1056 return wait_rproc(); /* need to wait for one */
1057 }
1058
1059 /* trace ray contributions (main loop) */
1060 void
1061 trace_contribs(FILE *fin)
1062 {
1063 char inpbuf[128];
1064 int iblen;
1065 struct rtproc *rtp;
1066 /* loop over input */
1067 while ((iblen = getinp(inpbuf, fin)) >= 0) {
1068 if (!iblen || /* need reset? */
1069 queue_length() > 10*nrtprocs() ||
1070 lastray+1 < lastray) {
1071 while (wait_rproc() != NULL)
1072 process_queue();
1073 if (lastray+1 < lastray)
1074 lastdone = lastray = 0;
1075 }
1076 rtp = get_rproc(); /* get avail. rtrace process */
1077 rtp->raynum = ++lastray; /* assign ray */
1078 if (iblen) { /* trace ray if valid */
1079 writebuf(rtp->pd.w, inpbuf, iblen);
1080 } else { /* else bypass dummy ray */
1081 queue_raytree(rtp); /* empty tree */
1082 if ((yres <= 0) | (waitflush > 1))
1083 waitflush = 1; /* flush after this */
1084 }
1085 process_queue(); /* catch up with results */
1086 if (raysleft && !--raysleft)
1087 break; /* preemptive EOI */
1088 }
1089 while (wait_rproc() != NULL) /* process outstanding rays */
1090 process_queue();
1091 if (raysleft)
1092 error(USER, "unexpected EOF on input");
1093 lu_done(&ofiletab); /* close output files */
1094 }
1095
1096 /* seek on the given output file */
1097 static int
1098 myseeko(const LUENT *e, void *p)
1099 {
1100 STREAMOUT *sop = (STREAMOUT *)e->data;
1101 off_t nbytes = *(off_t *)p;
1102
1103 if (sop->reclen > 1)
1104 nbytes = nbytes * sop->reclen;
1105 if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) {
1106 sprintf(errmsg, "seek error on file '%s'", e->key);
1107 error(SYSTEM, errmsg);
1108 }
1109 }
1110
1111 /* recover output if possible */
1112 void
1113 recover_output(FILE *fin)
1114 {
1115 off_t lastout = -1;
1116 int outvsiz, recsiz;
1117 char *outvfmt;
1118 int i, j;
1119 MODCONT *mp;
1120 int ofl;
1121 char oname[1024];
1122 LUENT *ment, *oent;
1123 STREAMOUT sout;
1124 off_t nvals;
1125 int xr, yr;
1126
1127 switch (outfmt) {
1128 case 'a':
1129 error(USER, "cannot recover ASCII output");
1130 return;
1131 case 'f':
1132 outvsiz = sizeof(float)*3;
1133 outvfmt = "float";
1134 break;
1135 case 'd':
1136 outvsiz = sizeof(double)*3;
1137 outvfmt = "double";
1138 break;
1139 case 'c':
1140 outvsiz = sizeof(COLR);
1141 outvfmt = COLRFMT;
1142 break;
1143 default:
1144 error(INTERNAL, "botched output format");
1145 return;
1146 }
1147 /* check modifier outputs */
1148 for (i = 0; i < nmods; i++) {
1149 ment = lu_find(&modconttab,modname[i]);
1150 mp = (MODCONT *)ment->data;
1151 if (mp->outspec == NULL)
1152 error(USER, "cannot recover from stdout");
1153 if (mp->outspec[0] == '!')
1154 error(USER, "cannot recover from command");
1155 for (j = 0; ; j++) { /* check each bin's file */
1156 ofl = ofname(oname, mp->outspec, mp->modname, j);
1157 if (ofl < 0)
1158 error(USER, "bad output file specification");
1159 oent = lu_find(&ofiletab, oname);
1160 if (oent->data != NULL) {
1161 sout = *(STREAMOUT *)oent->data;
1162 } else {
1163 sout.reclen = CNT_UNKNOWN;
1164 sout.ofp = NULL;
1165 }
1166 if (sout.ofp != NULL) { /* already open? */
1167 if (ofl & OF_BIN)
1168 continue;
1169 break;
1170 }
1171 /* open output */
1172 sout.ofp = fopen(oname, "rb+");
1173 if (sout.ofp == NULL) {
1174 if (j)
1175 break; /* assume end of modifier */
1176 sprintf(errmsg, "missing recover file '%s'",
1177 oname);
1178 error(USER, errmsg);
1179 }
1180 nvals = lseek(fileno(sout.ofp), 0, SEEK_END);
1181 if (nvals <= 0) {
1182 lastout = 0; /* empty output, quit here */
1183 fclose(sout.ofp);
1184 break;
1185 }
1186 if (sout.reclen == CNT_UNKNOWN) {
1187 if (!(ofl & OF_BIN)) {
1188 sprintf(errmsg,
1189 "need -bn to recover file '%s'",
1190 oname);
1191 error(USER, errmsg);
1192 }
1193 recsiz = outvsiz;
1194 } else
1195 recsiz = outvsiz * sout.reclen;
1196
1197 lseek(fileno(sout.ofp), 0, SEEK_SET);
1198 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1199 sprintf(errmsg, "format mismatch for '%s'",
1200 oname);
1201 error(USER, errmsg);
1202 }
1203 if ((xres > 0) & (yres > 0) &&
1204 (!fscnresolu(&xr, &yr, sout.ofp) ||
1205 xr != xres ||
1206 yr != yres)) {
1207 sprintf(errmsg, "resolution mismatch for '%s'",
1208 oname);
1209 error(USER, errmsg);
1210 }
1211 nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz;
1212 if ((lastout < 0) | (nvals < lastout))
1213 lastout = nvals;
1214 if (oent->key == NULL) /* new entry */
1215 oent->key = strcpy((char *)
1216 malloc(strlen(oname)+1), oname);
1217 if (oent->data == NULL)
1218 oent->data = (char *)malloc(sizeof(STREAMOUT));
1219 *(STREAMOUT *)oent->data = sout;
1220 if (!(ofl & OF_BIN))
1221 break; /* no bin separation */
1222 }
1223 if (!lastout) { /* empty output */
1224 error(WARNING, "no previous data to recover");
1225 lu_done(&ofiletab); /* reclose all outputs */
1226 return;
1227 }
1228 if (j > mp->nbins) /* reallocate modifier bins */
1229 ment->data = (char *)(mp = growmodifier(mp, j));
1230 }
1231 if (lastout < 0) {
1232 error(WARNING, "no output files to recover");
1233 return;
1234 }
1235 if (raysleft && lastout >= raysleft) {
1236 error(WARNING, "output appears to be complete");
1237 /* XXX should read & discard input? */
1238 quit(0);
1239 }
1240 /* seek on all files */
1241 nvals = lastout * outvsiz;
1242 lu_doall(&ofiletab, myseeko, &nvals);
1243 /* skip repeated input */
1244 for (nvals = 0; nvals < lastout; nvals++)
1245 if (getinp(oname, fin) < 0)
1246 error(USER, "unexpected EOF on input");
1247 lastray = lastdone = (unsigned long)lastout;
1248 if (raysleft)
1249 raysleft -= lastray;
1250 }
