root/Development/ray/src/util/rtcontrib.c
Revision: 1.33
Committed: Fri Oct 7 03:45:15 2005 UTC (20 years, 3 months ago) by greg
Changes since 1.32: +6 -3 lines
Added final write error check
2 static const char RCSid[] = "$Id: rtcontrib.c,v 1.32 2005/10/06 16:28:59 greg Exp $";
5 * Gather rtrace output to compute contributions from particular sources
6 */
7
8 #include "standard.h"
9 #include <ctype.h>
10 #include <signal.h>
11 #include "platform.h"
12 #include "rtprocess.h"
13 #include "selcall.h"
14 #include "color.h"
15 #include "resolu.h"
16 #include "lookup.h"
17 #include "calcomp.h"
18
19 #ifndef MAXMODLIST
20 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
21 #endif
22
23 int treebufsiz = BUFSIZ; /* current tree buffer size */
24
25 typedef double DCOLOR[3]; /* double-precision color */
26
27 /*
28 * The MODCONT structure is used to accumulate ray contributions
29 * for a particular modifier, which may be subdivided into bins
30 * if binv is non-zero. If outspec contains a %s in it, this will
31 * be replaced with the modifier name. If outspec contains a %d in it,
32 * this will be used to create one output file per bin, otherwise all bins
33 * will be written to the same file, in order. If the global outfmt
34 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
35 * and the file will conform to a RADIANCE image if xres & yres are set.
36 */
37 typedef struct {
38 const char *outspec; /* output file specification */
39 const char *modname; /* modifier name */
40 EPNODE *binv; /* bin value expression */
41 int nbins; /* number of accumulation bins */
42 DCOLOR cbin[1]; /* contribution bins (extends struct) */
43 } MODCONT; /* modifier contribution */
44
45 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
46
47 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
48
49 #define CNT_UNKNOWN 0 /* unknown record length */
50 #define CNT_PIPE (-1) /* output to a pipe */
51 /*
52 * The STREAMOUT structure holds an open FILE pointer and a count of
53 * the number of RGB triplets per record, or CNT_UNKNOWN (0) if
54 * unknown or CNT_PIPE (-1) if writing to a command.
55 */
56 typedef struct {
57 FILE *ofp; /* output file pointer */
58 int reclen; /* triplets/record */
59 } STREAMOUT;
60
61 /* close output stream and free record */
62 static void
63 closestream(void *p)
64 {
65 STREAMOUT *sop = (STREAMOUT *)p;
66 int status;
67 if (sop->reclen == CNT_PIPE)
68 status = pclose(sop->ofp);
69 else
70 status = fclose(sop->ofp);
71 if (status)
72 error(SYSTEM, "error closing output stream");
73 free(p);
74 }
75
76 LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
77
78 #define OF_MODIFIER 01
79 #define OF_BIN 02
80
81 STREAMOUT *getostream(const char *ospec, const char *mname, int bn, int noopen);
82 int ofname(char *oname, const char *ospec, const char *mname, int bn);
83 void printheader(FILE *fout, const char *info);
84 void printresolu(FILE *fout);
85
86 /*
87 * The rcont structure is used to manage i/o with a particular
88 * rtrace child process. Input is passed unchanged from stdin,
89 * and output is processed in input order and accumulated according
90 * to the corresponding modifier and bin number.
91 */
92 struct rtproc {
93 struct rtproc *next; /* next in list of processes */
94 SUBPROC pd; /* rtrace pipe descriptors */
95 unsigned long raynum; /* ray number for this tree */
96 int bsiz; /* ray tree buffer length */
97 char *buf; /* ray tree buffer */
98 int nbr; /* number of bytes from rtrace */
99 }; /* rtrace process buffer */
100
101 /* rtrace command and defaults */
102 char *rtargv[256+2*MAXMODLIST] = { "rtrace",
103 "-dj", ".5", "-dr", "3",
104 "-ab", "1", "-ad", "128", };
105 int rtargc = 9;
106 /* overriding rtrace options */
107 char *myrtopts[] = { "-o~~TmWdp", "-h-", "-x", "1", "-y", "0",
108 "-dt", "0", "-as", "0", "-aa", "0", NULL };
109
110 struct rtproc rt0; /* head of rtrace process list */
111
112 struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
113
114 char persistfn[] = "pfXXXXXX"; /* persist file name */
115
116 int gargc; /* global argc */
117 char **gargv; /* global argv */
118 #define progname gargv[0]
119
120 char *octree; /* global octree argument */
121
122 int inpfmt = 'a'; /* input format */
123 int outfmt = 'a'; /* output format */
124
125 int header = 1; /* output header? */
126 int xres = 0; /* horiz. output resolution */
127 int yres = 0; /* vert. output resolution */
128
129 unsigned long raysleft; /* number of rays left to trace */
130 long waitflush; /* how long until next flush */
131
132 unsigned long lastray = 0; /* last ray number sent */
133 unsigned long lastdone = 0; /* last ray processed */
134
135 int using_stdout = 0; /* are we using stdout? */
136
137 const char *modname[MAXMODLIST]; /* ordered modifier name list */
138 int nmods = 0; /* number of modifiers */
139
140 #define queue_length() (lastray - lastdone)
141
142 MODCONT *growmodifier(MODCONT *mp, int nb);
143 MODCONT *addmodifier(char *modn, char *outf, char *binv, int bincnt);
144 void addmodfile(char *fname, char *outf, char *binv, int bincnt);
145
146 void init(int np);
147 int done_rprocs(struct rtproc *rtp);
148 void recover_output(FILE *fin);
149 void trace_contribs(FILE *fin);
150 struct rtproc *wait_rproc(void);
151 struct rtproc *get_rproc(void);
152 void queue_raytree(struct rtproc *rtp);
153 void process_queue(void);
154
155 void put_contrib(const DCOLOR cnt, FILE *fout);
156 void add_contrib(const char *modn);
157 void done_contrib(void);
158
159 /* return number of open rtrace processes */
160 static int
161 nrtprocs(void)
162 {
163 int nrtp = 0;
164 struct rtproc *rtp;
165
166 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
167 nrtp += rtp->pd.running;
168 return(nrtp);
169 }
170
171 /* set input/output format */
172 static void
173 setformat(const char *fmt)
174 {
175 switch (fmt[0]) {
176 case 'f':
177 case 'd':
178 SET_FILE_BINARY(stdin);
179 /* fall through */
180 case 'a':
181 inpfmt = fmt[0];
182 break;
183 default:
184 goto fmterr;
185 }
186 switch (fmt[1]) {
187 case '\0':
188 outfmt = inpfmt;
189 return;
190 case 'a':
191 case 'f':
192 case 'd':
193 case 'c':
194 outfmt = fmt[1];
195 break;
196 default:
197 goto fmterr;
198 }
199 if (!fmt[2])
200 return;
201 fmterr:
202 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
203 error(USER, errmsg);
204 }
205
206 /* gather rays from rtrace and output contributions */
207 int
208 main(int argc, char *argv[])
209 {
210 int nprocs = 1;
211 int recover = 0;
212 char *curout = NULL;
213 char *binval = NULL;
214 int bincnt = 0;
215 char fmt[8];
216 int i, j;
217 /* need at least one argument */
218 if (argc < 2) {
219 fprintf(stderr,
220 "Usage: %s [-n nprocs][-r][-e expr][-f source][-o ospec][-b binv] {-m mod | -M file} [rtrace options] octree\n",
221 argv[0]);
222 exit(1);
223 }
224 /* global program name */
225 gargv = argv;
226 /* initialize calcomp routines */
227 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
228 esupport &= ~(E_OUTCHAN);
229 varset("PI", ':', PI);
230 /* get our options */
231 for (i = 1; i < argc-1; i++) {
232 /* expand arguments */
233 while ((j = expandarg(&argc, &argv, i)) > 0)
234 ;
235 if (j < 0) {
236 fprintf(stderr, "%s: cannot expand '%s'",
237 argv[0], argv[i]);
238 exit(1);
239 }
240 if (argv[i][0] == '-')
241 switch (argv[i][1]) {
242 case 'r': /* recover output */
243 if (argv[i][2]) break;
244 recover++;
245 continue;
246 case 'n': /* number of processes */
247 if (argv[i][2] || i >= argc-2) break;
248 nprocs = atoi(argv[++i]);
249 if (nprocs <= 0)
250 error(USER, "illegal number of processes");
251 continue;
252 case 'h': /* output header? */
253 switch (argv[i][2]) {
254 case '\0':
255 header = !header;
256 continue;
257 case '+': case '1':
258 case 'T': case 't':
259 case 'Y': case 'y':
260 header = 1;
261 continue;
262 case '-': case '0':
263 case 'F': case 'f':
264 case 'N': case 'n':
265 header = 0;
266 continue;
267 }
268 break;
269 case 'f': /* file or i/o format */
270 if (!argv[i][2]) {
271 char *fpath;
272 if (i >= argc-2) break;
273 fpath = getpath(argv[++i],
274 getrlibpath(), R_OK);
275 if (fpath == NULL) {
276 sprintf(errmsg,
277 "cannot find file '%s'",
278 argv[i]);
279 error(USER, errmsg);
280 }
281 fcompile(fpath);
282 continue;
283 }
284 setformat(argv[i]+2);
285 continue;
286 case 'e': /* expression */
287 if (argv[i][2] || i >= argc-2) break;
288 scompile(argv[++i], NULL, 0);
289 continue;
290 case 'o': /* output file spec. */
291 if (argv[i][2] || i >= argc-2) break;
292 curout = argv[++i];
293 continue;
294 case 'x': /* horiz. output resolution */
295 if (argv[i][2] || i >= argc-2) break;
296 xres = atoi(argv[++i]);
297 continue;
298 case 'y': /* vert. output resolution */
299 if (argv[i][2] || i >= argc-2) break;
300 yres = atoi(argv[++i]);
301 continue;
302 case 'b': /* bin expression/count */
303 if (i >= argc-2) break;
304 if (argv[i][2] == 'n') {
305 bincnt = atoi(argv[++i]);
306 continue;
307 }
308 if (argv[i][2]) break;
309 binval = argv[++i];
310 continue;
311 case 'm': /* modifier name */
312 if (argv[i][2] || i >= argc-2) break;
313 rtargv[rtargc++] = "-ti";
314 rtargv[rtargc++] = argv[++i];
315 addmodifier(argv[i], curout, binval, bincnt);
316 continue;
317 case 'M': /* modifier file */
318 if (argv[i][2] || i >= argc-2) break;
319 rtargv[rtargc++] = "-tI";
320 rtargv[rtargc++] = argv[++i];
321 addmodfile(argv[i], curout, binval, bincnt);
322 continue;
323 }
324 rtargv[rtargc++] = argv[i]; /* assume rtrace option */
325 }
326 /* set global argument list */
327 gargc = argc; gargv = argv;
328 /* add "mandatory" rtrace settings */
329 for (j = 0; myrtopts[j] != NULL; j++)
330 rtargv[rtargc++] = myrtopts[j];
331 /* just asking for defaults? */
332 if (!strcmp(argv[i], "-defaults")) {
333 char sxres[16], syres[16];
334 char *rtpath;
335 printf("-n %-2d\t\t\t\t# number of processes\n", nprocs);
336 fflush(stdout); /* report OUR options */
337 rtargv[rtargc++] = header ? "-h+" : "-h-";
338 sprintf(fmt, "-f%c%c", inpfmt, outfmt);
339 rtargv[rtargc++] = fmt;
340 rtargv[rtargc++] = "-x";
341 sprintf(sxres, "%d", xres);
342 rtargv[rtargc++] = sxres;
343 rtargv[rtargc++] = "-y";
344 sprintf(syres, "%d", yres);
345 rtargv[rtargc++] = syres;
346 rtargv[rtargc++] = "-oTW";
347 rtargv[rtargc++] = "-defaults";
348 rtargv[rtargc] = NULL;
349 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
350 if (rtpath == NULL) {
351 eputs(rtargv[0]);
352 eputs(": command not found\n");
353 exit(1);
354 }
355 execv(rtpath, rtargv);
356 perror(rtpath); /* execv() should not return */
357 exit(1);
358 }
359 if (nprocs > 1) { /* add persist file if parallel */
360 rtargv[rtargc++] = "-PP";
361 rtargv[rtargc++] = mktemp(persistfn);
362 }
363 /* add format string */
364 sprintf(fmt, "-f%cf", inpfmt);
365 rtargv[rtargc++] = fmt;
366 /* octree argument is last */
367 if (i <= 0 || i != argc-1 || argv[i][0] == '-')
368 error(USER, "missing octree argument");
369 rtargv[rtargc++] = octree = argv[i];
370 rtargv[rtargc] = NULL;
371 /* start rtrace */
372 init(nprocs);
373 if (recover) /* perform recovery if requested */
374 recover_output(stdin);
375 trace_contribs(stdin); /* compute contributions */
376 quit(0);
377 }
378
379 #ifndef SIGALRM
380 #define SIGALRM SIGTERM
381 #endif
382 /* kill persistent rtrace process */
383 static void
384 killpersist(void)
385 {
386 FILE *fp = fopen(persistfn, "r");
387 RT_PID pid;
388
389 if (fp == NULL)
390 return;
391 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
392 unlink(persistfn);
393 fclose(fp);
394 }
395
396 /* close rtrace processes and clean up */
397 int
398 done_rprocs(struct rtproc *rtp)
399 {
400 int st0, st1 = 0;
401
402 if (rtp->next != NULL) { /* close last opened first! */
403 st1 = done_rprocs(rtp->next);
404 free((void *)rtp->next);
405 rtp->next = NULL;
406 }
407 st0 = close_process(&rtp->pd);
408 if (st0 < 0)
409 error(WARNING, "unknown return status from rtrace process");
410 else if (st0 > 0)
411 return(st0);
412 return(st1);
413 }
414
415 /* exit with status */
416 void
417 quit(int status)
418 {
419 int rtstat;
420
421 if (rt0.next != NULL) /* terminate persistent rtrace */
422 killpersist();
423 /* clean up rtrace process(es) */
424 rtstat = done_rprocs(&rt0);
425 if (status == 0)
426 status = rtstat;
427 exit(status); /* flushes all output streams */
428 }
429
430 /* start rtrace processes and initialize */
431 void
432 init(int np)
433 {
434 struct rtproc *rtp;
435 int i;
436 int maxbytes;
437 /* make sure we have something to do */
438 if (!nmods)
439 error(USER, "No modifiers specified");
440 /* assign ray variables */
441 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
442 scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
443 /* set up signal handling */
444 signal(SIGINT, quit);
445 #ifdef SIGHUP
446 signal(SIGHUP, quit);
447 #endif
448 #ifdef SIGTERM
449 signal(SIGTERM, quit);
450 #endif
451 #ifdef SIGPIPE
452 signal(SIGPIPE, quit);
453 #endif
454 rtp = &rt0; /* start rtrace process(es) */
455 for (i = 0; i++ < np; ) {
456 errno = 0;
457 maxbytes = open_process(&rtp->pd, rtargv);
458 if (maxbytes == 0) {
459 eputs(rtargv[0]);
460 eputs(": command not found\n");
461 exit(1);
462 }
463 if (maxbytes < 0)
464 error(SYSTEM, "cannot start rtrace process");
465 if (maxbytes > treebufsiz)
466 treebufsiz = maxbytes;
467 rtp->raynum = 0;
468 rtp->bsiz = 0;
469 rtp->buf = NULL;
470 rtp->nbr = 0;
471 if (i == np) /* last process? */
472 break;
473 if (i == 1)
474 sleep(2); /* wait for persist file */
475 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
476 if (rtp->next == NULL)
477 error(SYSTEM, "out of memory in init");
478 rtp = rtp->next;
479 }
480 rtp->next = NULL; /* terminate list */
481 if (yres > 0) {
482 if (xres > 0)
483 raysleft = (unsigned long)xres*yres;
484 else
485 raysleft = yres;
486 } else
487 raysleft = 0;
488 waitflush = xres;
489 }
490
491 /* grow modifier to accommodate more bins */
492 MODCONT *
493 growmodifier(MODCONT *mp, int nb)
494 {
495 if (nb <= mp->nbins)
496 return mp;
497 mp = (MODCONT *)realloc(mp, sizeof(MODCONT) + sizeof(DCOLOR)*(nb-1));
498 if (mp == NULL)
499 error(SYSTEM, "out of memory in growmodifier");
500 memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(nb-mp->nbins));
501 mp->nbins = nb;
502 return mp;
503 }
504
505 /* add modifier to our list to track */
506 MODCONT *
507 addmodifier(char *modn, char *outf, char *binv, int bincnt)
508 {
509 LUENT *lep = lu_find(&modconttab, modn);
510 MODCONT *mp;
511 int i;
512
513 if (lep->data != NULL) {
514 sprintf(errmsg, "duplicate modifier '%s'", modn);
515 error(USER, errmsg);
516 }
517 if (nmods >= MAXMODLIST)
518 error(USER, "too many modifiers");
519 modname[nmods++] = modn; /* XXX assumes static string */
520 lep->key = modn; /* XXX assumes static string */
521 mp = (MODCONT *)malloc(sizeof(MODCONT));
522 if (mp == NULL)
523 error(SYSTEM, "out of memory in addmodifier");
524 mp->outspec = outf; /* XXX assumes static string */
525 mp->modname = modn; /* XXX assumes static string */
526 if (binv != NULL)
527 mp->binv = eparse(binv);
528 else
529 mp->binv = eparse("0");
530 mp->nbins = 1;
531 setcolor(mp->cbin[0], 0., 0., 0.);
532 if (mp->binv->type == NUM) /* assume one bin if constant */
533 bincnt = 1;
534 else if (bincnt > 1)
535 mp = growmodifier(mp, bincnt);
536 lep->data = (char *)mp;
537 /* allocate output streams */
538 for (i = outf==NULL || outf[0]=='!' ? 0 : bincnt; i--; )
539 getostream(mp->outspec, mp->modname, i, 1);
540 return mp;
541 }
542
543 /* add modifiers from a file list */
544 void
545 addmodfile(char *fname, char *outf, char *binv, int bincnt)
546 {
547 char *mname[MAXMODLIST];
548 int i;
549 /* find the file & store strings */
550 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
551 sprintf(errmsg, "cannot find modifier file '%s'", fname);
552 error(SYSTEM, errmsg);
553 }
554 for (i = 0; mname[i]; i++) /* add each one */
555 addmodifier(mname[i], outf, binv, bincnt);
556 }
557
558 /* put string to stderr */
559 void
560 eputs(char *s)
561 {
562 static int midline = 0;
563
564 if (!*s) return;
565 if (!midline) {
566 fputs(progname, stderr);
567 fputs(": ", stderr);
568 }
569 fputs(s, stderr);
570 midline = s[strlen(s)-1] != '\n';
571 }
572
573 /* construct output file name and return flags whether modifier/bin present */
574 int
575 ofname(char *oname, const char *ospec, const char *mname, int bn)
576 {
577 const char *mnp = NULL;
578 const char *bnp = NULL;
579 const char *cp;
580
581 if (ospec == NULL)
582 return -1;
583 for (cp = ospec; *cp; cp++) /* check format position(s) */
584 if (*cp == '%') {
585 do
586 ++cp;
587 while (isdigit(*cp));
588 switch (*cp) {
589 case '%':
590 break;
591 case 's':
592 if (mnp != NULL)
593 return -1;
594 mnp = cp;
595 break;
596 case 'd':
597 if (bnp != NULL)
598 return -1;
599 bnp = cp;
600 break;
601 default:
602 return -1;
603 }
604 }
605 if (mnp != NULL) { /* create file name */
606 if (bnp != NULL) {
607 if (bnp > mnp)
608 sprintf(oname, ospec, mname, bn);
609 else
610 sprintf(oname, ospec, bn, mname);
611 return OF_MODIFIER|OF_BIN;
612 }
613 sprintf(oname, ospec, mname);
614 return OF_MODIFIER;
615 }
616 if (bnp != NULL) {
617 sprintf(oname, ospec, bn);
618 return OF_BIN;
619 }
620 strcpy(oname, ospec);
621 return 0;
622 }
623
624 /* write header to the given output stream */
625 void
626 printheader(FILE *fout, const char *info)
627 {
628 extern char VersionID[];
629 FILE *fin = fopen(octree, "r");
630
631 if (fin == NULL)
632 quit(1);
633 checkheader(fin, "ignore", fout); /* copy octree header */
634 fclose(fin);
635 printargs(gargc-1, gargv, fout); /* add our command */
636 fprintf(fout, "SOFTWARE= %s\n", VersionID);
637 fputnow(fout);
638 if (info != NULL) /* add extra info if given */
639 fputs(info, fout);
640 switch (outfmt) { /* add output format */
641 case 'a':
642 fputformat("ascii", fout);
643 break;
644 case 'f':
645 fputformat("float", fout);
646 break;
647 case 'd':
648 fputformat("double", fout);
649 break;
650 case 'c':
651 fputformat(COLRFMT, fout);
652 break;
653 }
654 fputc('\n', fout);
655 }
656
657 /* write resolution string to given output stream */
658 void
659 printresolu(FILE *fout)
660 {
661 if (xres > 0) {
662 if (yres > 0) /* resolution string */
663 fprtresolu(xres, yres, fout);
664 fflush(fout);
665 }
666 }
667
668 /* Get output stream pointer (open and write header if new and noopen==0) */
669 STREAMOUT *
670 getostream(const char *ospec, const char *mname, int bn, int noopen)
671 {
672 static STREAMOUT stdos;
673 int ofl;
674 char oname[1024];
675 LUENT *lep;
676 STREAMOUT *sop;
677
678 if (ospec == NULL) { /* use stdout? */
679 if (!noopen && !using_stdout) {
680 stdos.reclen = 0;
681 if (outfmt != 'a')
682 SET_FILE_BINARY(stdout);
683 if (header)
684 printheader(stdout, NULL);
685 printresolu(stdout);
686 using_stdout = 1;
687 }
688 stdos.ofp = stdout;
689 stdos.reclen += noopen;
690 return &stdos;
691 }
692 ofl = ofname(oname, ospec, mname, bn); /* get output name */
693 if (ofl < 0) {
694 sprintf(errmsg, "bad output format '%s'", ospec);
695 error(USER, errmsg);
696 }
697 lep = lu_find(&ofiletab, oname); /* look it up */
698 if (lep->key == NULL) /* new entry */
699 lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
700 sop = (STREAMOUT *)lep->data;
701 if (sop == NULL) { /* allocate stream */
702 sop = (STREAMOUT *)malloc(sizeof(STREAMOUT));
703 if (sop == NULL)
704 error(SYSTEM, "out of memory in getostream");
705 sop->reclen = oname[0] == '!' ? CNT_PIPE : 0;
706 sop->ofp = NULL; /* open iff noopen==0 */
707 lep->data = (char *)sop;
708 }
709 if (!noopen && sop->ofp == NULL) { /* open output stream */
710 int i;
711 if (oname[0] == '!') /* output to command */
712 sop->ofp = popen(oname+1, "w");
713 else
714 sop->ofp = fopen(oname, "w");
715 if (sop->ofp == NULL) {
716 sprintf(errmsg, "cannot open '%s' for writing", oname);
717 error(SYSTEM, errmsg);
718 }
719 if (outfmt != 'a')
720 SET_FILE_BINARY(sop->ofp);
721 if (header) {
722 char info[512];
723 char *cp = info;
724 if (ofl & OF_MODIFIER || sop->reclen == 1) {
725 sprintf(cp, "MODIFIER=%s\n", mname);
726 while (*cp) ++cp;
727 }
728 if (ofl & OF_BIN) {
729 sprintf(cp, "BIN=%d\n", bn);
730 while (*cp) ++cp;
731 }
732 *cp = '\0';
733 printheader(sop->ofp, info);
734 }
735 printresolu(sop->ofp);
736 /* play catch-up */
737 for (i = 0; i < lastdone; i++) {
738 static const DCOLOR nocontrib = BLKCOLOR;
739 put_contrib(nocontrib, sop->ofp);
740 if (outfmt == 'a')
741 putc('\n', sop->ofp);
742 }
743 if (xres > 0)
744 fflush(sop->ofp);
745 }
746 if (sop->reclen != CNT_PIPE) /* add to length if noopen */
747 sop->reclen += noopen;
748 return sop; /* return open stream */
749 }
750
751 /* read input ray into buffer */
752 int
753 getinp(char *buf, FILE *fp)
754 {
755 char *cp;
756 int i;
757
758 switch (inpfmt) {
759 case 'a':
760 cp = buf; /* make sure we get 6 floats */
761 for (i = 0; i < 6; i++) {
762 if (fgetword(cp, buf+127-cp, fp) == NULL)
763 return 0;
764 if ((cp = fskip(cp)) == NULL || *cp)
765 return 0;
766 *cp++ = ' ';
767 }
768 getc(fp); /* get/put eol */
769 *cp-- = '\0'; *cp = '\n';
770 return strlen(buf);
771 case 'f':
772 if (fread(buf, sizeof(float), 6, fp) < 6)
773 return 0;
774 return sizeof(float)*6;
775 case 'd':
776 if (fread(buf, sizeof(double), 6, fp) < 6)
777 return 0;
778 return sizeof(double)*6;
779 }
780 error(INTERNAL, "botched input format");
781 return 0; /* pro forma return */
782 }
783
784 static float rparams[9]; /* traced ray parameters */
785
786 /* return channel (ray) value */
787 double
788 chanvalue(int n)
789 {
790 if (--n < 0 || n >= 6)
791 error(USER, "illegal channel number ($N)");
792 return rparams[n+3];
793 }
794
795 /* add current ray contribution to the appropriate modifier bin */
796 void
797 add_contrib(const char *modn)
798 {
799 LUENT *le = lu_find(&modconttab, modn);
800 MODCONT *mp = (MODCONT *)le->data;
801 int bn;
802
803 if (mp == NULL) {
804 sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
805 error(USER, errmsg);
806 }
807 eclock++; /* get bin number */
808 bn = (int)(evalue(mp->binv) + .5);
809 if (bn <= 0)
810 bn = 0;
811 else if (bn >= mp->nbins) /* new bin */
812 le->data = (char *)(mp = growmodifier(mp, bn+1));
813 addcolor(mp->cbin[bn], rparams);
814 }
815
816 /* output newline to ASCII file and/or flush as requested */
817 static int
818 puteol(const LUENT *e, void *p)
819 {
820 STREAMOUT *sop = (STREAMOUT *)e->data;
821
822 if (outfmt == 'a')
823 putc('\n', sop->ofp);
824 if (!waitflush)
825 fflush(sop->ofp);
826 if (ferror(sop->ofp)) {
827 sprintf(errmsg, "write error on file '%s'", e->key);
828 error(SYSTEM, errmsg);
829 }
830 return 0;
831 }
832
833 /* put out ray contribution to file */
834 void
835 put_contrib(const DCOLOR cnt, FILE *fout)
836 {
837 float fv[3];
838 COLR cv;
839
840 switch (outfmt) {
841 case 'a':
842 fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
843 break;
844 case 'f':
845 fv[0] = cnt[0];
846 fv[1] = cnt[1];
847 fv[2] = cnt[2];
848 fwrite(fv, sizeof(float), 3, fout);
849 break;
850 case 'd':
851 fwrite(cnt, sizeof(double), 3, fout);
852 break;
853 case 'c':
854 setcolr(cv, cnt[0], cnt[1], cnt[2]);
855 fwrite(cv, sizeof(cv), 1, fout);
856 break;
857 default:
858 error(INTERNAL, "botched output format");
859 }
860 }
861
862 /* output ray tallies and clear for next primary */
863 void
864 done_contrib(void)
865 {
866 int i, j;
867 MODCONT *mp;
868 STREAMOUT *sop;
869 /* output modifiers in order */
870 for (i = 0; i < nmods; i++) {
871 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
872 sop = getostream(mp->outspec, mp->modname, 0,0);
873 put_contrib(mp->cbin[0], sop->ofp);
874 if (mp->nbins > 3 && /* minor optimization */
875 sop == getostream(mp->outspec, mp->modname, 1,0))
876 for (j = 1; j < mp->nbins; j++)
877 put_contrib(mp->cbin[j], sop->ofp);
878 else
879 for (j = 1; j < mp->nbins; j++)
880 put_contrib(mp->cbin[j],
881 getostream(mp->outspec,mp->modname,j,0)->ofp);
882 /* clear for next ray tree */
883 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
884 }
885 --waitflush; /* terminate records */
886 lu_doall(&ofiletab, puteol, NULL);
887 if (using_stdout & (outfmt == 'a'))
888 putc('\n', stdout);
889 if (!waitflush) {
890 waitflush = xres;
891 if (using_stdout)
892 fflush(stdout);
893 }
894 }
895
896 /* queue completed ray tree produced by rtrace process */
897 void
898 queue_raytree(struct rtproc *rtp)
899 {
900 struct rtproc *rtu, *rtl = NULL;
901 /* insert following ray order */
902 for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
903 if (rtp->raynum < rtu->raynum)
904 break;
905 rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
906 if (rtu == NULL)
907 error(SYSTEM, "out of memory in queue_raytree");
908 *rtu = *rtp;
909 if (rtl == NULL) {
910 rtu->next = rt_unproc;
911 rt_unproc = rtu;
912 } else {
913 rtu->next = rtl->next;
914 rtl->next = rtu;
915 }
916 rtp->raynum = 0; /* clear path for next ray tree */
917 rtp->bsiz = 0;
918 rtp->buf = NULL;
919 rtp->nbr = 0;
920 }
921
922 /* process completed ray trees from our queue */
923 void
924 process_queue(void)
925 {
926 char modname[128];
927 /* ray-ordered queue */
928 while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
929 struct rtproc *rtp = rt_unproc;
930 int n = rtp->nbr;
931 const char *cp = rtp->buf;
932 while (n > 0) { /* process rays */
933 register char *mnp = modname;
934 /* skip leading tabs */
935 while (n > 0 && *cp == '\t') {
936 cp++; n--;
937 }
938 if (!n || !(isalpha(*cp) | (*cp == '_')))
939 error(USER, "bad modifier name from rtrace");
940 /* get modifier name */
941 while (n > 0 && *cp != '\t') {
942 *mnp++ = *cp++; n--;
943 }
944 *mnp = '\0';
945 cp++; n--; /* eat following tab */
946 if (n < (int)(sizeof(float)*9))
947 error(USER, "incomplete ray value from rtrace");
948 /* add ray contribution */
949 memcpy(rparams, cp, sizeof(float)*9);
950 cp += sizeof(float)*9; n -= sizeof(float)*9;
951 add_contrib(modname);
952 }
953 done_contrib(); /* sum up contributions & output */
954 lastdone = rtp->raynum;
955 free(rtp->buf); /* free up buffer space */
956 rt_unproc = rtp->next;
957 free(rtp); /* done with this ray tree */
958 }
959 }
960
961 /* wait for rtrace process to finish with ray tree */
962 struct rtproc *
963 wait_rproc(void)
964 {
965 struct rtproc *rtfree = NULL;
966 fd_set readset, errset;
967 int nr;
968 struct rtproc *rt;
969 int n;
970
971 do {
972 nr = 0; /* prepare select call */
973 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
974 for (rt = &rt0; rt != NULL; rt = rt->next) {
975 if (rt->raynum) {
976 FD_SET(rt->pd.r, &readset);
977 ++nr;
978 }
979 FD_SET(rt->pd.r, &errset);
980 if (rt->pd.r >= n)
981 n = rt->pd.r + 1;
982 }
983 if (!nr) /* no rays pending */
984 break;
985 if (nr > 1) { /* call select for multiple proc's */
986 errno = 0;
987 if (select(n, &readset, NULL, &errset, NULL) < 0)
988 error(SYSTEM, "select call error in wait_rproc()");
989 } else
990 FD_ZERO(&errset);
991 nr = 0;
992 for (rt = &rt0; rt != NULL; rt = rt->next) {
993 if (!FD_ISSET(rt->pd.r, &readset) &&
994 !FD_ISSET(rt->pd.r, &errset))
995 continue;
996 if (rt->buf == NULL) {
997 rt->bsiz = treebufsiz;
998 rt->buf = (char *)malloc(treebufsiz);
999 } else if (rt->nbr + BUFSIZ > rt->bsiz) {
1000 if (rt->bsiz + BUFSIZ <= treebufsiz)
1001 rt->bsiz = treebufsiz;
1002 else
1003 treebufsiz = rt->bsiz += BUFSIZ;
1004 rt->buf = (char *)realloc(rt->buf, rt->bsiz);
1005 }
1006 if (rt->buf == NULL)
1007 error(SYSTEM, "out of memory in wait_rproc");
1008 nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
1009 if (nr <= 0)
1010 error(USER, "rtrace process died");
1011 rt->nbr += nr; /* advance & check */
1012 if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4,
1013 "~\t~\t", 4)) {
1014 rt->nbr -= 4; /* elide terminator */
1015 queue_raytree(rt);
1016 rtfree = rt; /* ready for next ray */
1017 }
1018 }
1019 } while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
1020 return rtfree;
1021 }
1022
1023 /* return next available rtrace process */
1024 struct rtproc *
1025 get_rproc(void)
1026 {
1027 struct rtproc *rtp;
1028 /* check for idle rtrace */
1029 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
1030 if (!rtp->raynum)
1031 return rtp;
1032 return wait_rproc(); /* need to wait for one */
1033 }
1034
1035 /* trace ray contributions (main loop) */
1036 void
1037 trace_contribs(FILE *fin)
1038 {
1039 char inpbuf[128];
1040 int iblen;
1041 struct rtproc *rtp;
1042 /* loop over input */
1043 while ((iblen = getinp(inpbuf, fin)) > 0) {
1044 if (lastray+1 < lastray || /* need reset? */
1045 queue_length() > 5*nrtprocs()) {
1046 while (wait_rproc() != NULL)
1047 process_queue();
1048 lastdone = lastray = 0;
1049 }
1050 rtp = get_rproc(); /* get avail. rtrace process */
1051 rtp->raynum = ++lastray; /* assign ray to it */
1052 writebuf(rtp->pd.w, inpbuf, iblen);
1053 if (raysleft && !--raysleft)
1054 break;
1055 process_queue(); /* catch up with results */
1056 }
1057 while (wait_rproc() != NULL) /* process outstanding rays */
1058 process_queue();
1059 if (raysleft)
1060 error(USER, "unexpected EOF on input");
1061 lu_done(&ofiletab); /* close output files */
1062 }
1063
1064 /* seek on the given output file */
1065 static int
1066 myseeko(const LUENT *e, void *p)
1067 {
1068 STREAMOUT *sop = (STREAMOUT *)e->data;
1069 off_t nbytes = *(off_t *)p;
1070
1071 if (sop->reclen > 1)
1072 nbytes = nbytes * sop->reclen;
1073 if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) {
1074 sprintf(errmsg, "seek error on file '%s'", e->key);
1075 error(SYSTEM, errmsg);
1076 }
1077 }
1078
1079 /* recover output if possible */
1080 void
1081 recover_output(FILE *fin)
1082 {
1083 off_t lastout = -1;
1084 int outvsiz, recsiz;
1085 char *outvfmt;
1086 int i, j;
1087 MODCONT *mp;
1088 int ofl;
1089 char oname[1024];
1090 LUENT *ment, *oent;
1091 STREAMOUT sout;
1092 off_t nvals;
1093 int xr, yr;
1094
1095 switch (outfmt) {
1096 case 'a':
1097 error(USER, "cannot recover ASCII output");
1098 return;
1099 case 'f':
1100 outvsiz = sizeof(float)*3;
1101 outvfmt = "float";
1102 break;
1103 case 'd':
1104 outvsiz = sizeof(double)*3;
1105 outvfmt = "double";
1106 break;
1107 case 'c':
1108 outvsiz = sizeof(COLR);
1109 outvfmt = COLRFMT;
1110 break;
1111 default:
1112 error(INTERNAL, "botched output format");
1113 return;
1114 }
1115 /* check modifier outputs */
1116 for (i = 0; i < nmods; i++) {
1117 ment = lu_find(&modconttab,modname[i]);
1118 mp = (MODCONT *)ment->data;
1119 if (mp->outspec == NULL)
1120 error(USER, "cannot recover from stdout");
1121 if (mp->outspec[0] == '!')
1122 error(USER, "cannot recover from command");
1123 for (j = 0; ; j++) { /* check each bin's file */
1124 ofl = ofname(oname, mp->outspec, mp->modname, j);
1125 if (ofl < 0)
1126 error(USER, "bad output file specification");
1127 oent = lu_find(&ofiletab, oname);
1128 if (oent->data != NULL) {
1129 sout = *(STREAMOUT *)oent->data;
1130 } else {
1131 sout.reclen = 0;
1132 sout.ofp = NULL;
1133 }
1134 if (sout.ofp != NULL) { /* already open? */
1135 if (ofl & OF_BIN)
1136 continue;
1137 break;
1138 }
1139 /* open output */
1140 sout.ofp = fopen(oname, "rb+");
1141 if (sout.ofp == NULL) {
1142 if (j)
1143 break; /* assume end of modifier */
1144 sprintf(errmsg, "missing recover file '%s'",
1145 oname);
1146 error(USER, errmsg);
1147 }
1148 nvals = lseek(fileno(sout.ofp), 0, SEEK_END);
1149 if (nvals <= 0) {
1150 lastout = 0; /* empty output, quit here */
1151 fclose(sout.ofp);
1152 break;
1153 }
1154 if (sout.reclen == CNT_UNKNOWN) {
1155 if (!(ofl & OF_BIN)) {
1156 sprintf(errmsg,
1157 "need -bn to recover file '%s'",
1158 oname);
1159 error(USER, errmsg);
1160 }
1161 recsiz = outvsiz;
1162 } else
1163 recsiz = outvsiz * sout.reclen;
1164
1165 lseek(fileno(sout.ofp), 0, SEEK_SET);
1166 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1167 sprintf(errmsg, "format mismatch for '%s'",
1168 oname);
1169 error(USER, errmsg);
1170 }
1171 if ((xres > 0) & (yres > 0) &&
1172 (!fscnresolu(&xr, &yr, sout.ofp) ||
1173 xr != xres ||
1174 yr != yres)) {
1175 sprintf(errmsg, "resolution mismatch for '%s'",
1176 oname);
1177 error(USER, errmsg);
1178 }
1179 nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz;
1180 if ((lastout < 0) | (nvals < lastout))
1181 lastout = nvals;
1182 if (oent->key == NULL) /* new entry */
1183 oent->key = strcpy((char *)
1184 malloc(strlen(oname)+1), oname);
1185 if (oent->data == NULL)
1186 oent->data = (char *)malloc(sizeof(STREAMOUT));
1187 *(STREAMOUT *)oent->data = sout;
1188 if (!(ofl & OF_BIN))
1189 break; /* no bin separation */
1190 }
1191 if (!lastout) { /* empty output */
1192 error(WARNING, "no previous data to recover");
1193 lu_done(&ofiletab); /* reclose all outputs */
1194 return;
1195 }
1196 if (j > mp->nbins) /* reallocate modifier bins */
1197 ment->data = (char *)(mp = growmodifier(mp, j));
1198 }
1199 if (lastout < 0) {
1200 error(WARNING, "no output files to recover");
1201 return;
1202 }
1203 if (raysleft && lastout >= raysleft) {
1204 error(WARNING, "output appears to be complete");
1205 /* XXX should read & discard input? */
1206 quit(0);
1207 }
1208 /* seek on all files */
1209 nvals = lastout * outvsiz;
1210 lu_doall(&ofiletab, myseeko, &nvals);
1211 /* skip repeated input */
1212 for (nvals = 0; nvals < lastout; nvals++)
1213 if (getinp(oname, fin) <= 0)
1214 error(USER, "unexpected EOF on input");
1215 lastray = lastdone = (unsigned long)lastout;
1216 if (raysleft)
1217 raysleft -= lastray;
1218 }
