root/radiance/ray/src/util/rtcontrib.c
Revision: 1.10
Committed: Thu Jun 2 04:47:27 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.9: +17 -5 lines
2 static const char RCSid[] = "$Id: rtcontrib.c,v 1.9 2005/06/01 16:11:01 greg Exp $";
5 * Gather rtrace output to compute contributions from particular sources
6 */
7
8 #include "standard.h"
9 #include <ctype.h>
10 #include <signal.h>
11 #include "platform.h"
12 #include "rtprocess.h"
13 #include "selcall.h"
14 #include "color.h"
15 #include "resolu.h"
16 #include "lookup.h"
17 #include "calcomp.h"
18
19 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
20
21 int treebufsiz = BUFSIZ; /* current tree buffer size */
22
23 typedef double DCOLOR[3]; /* double-precision color */
24
25 /*
26 * The modcont structure is used to accumulate ray contributions
27 * for a particular modifier, which may be subdivided into bins
28 * if binv is non-NULL. If outspec contains a %s in it, this will
29 * be replaced with the modifier name. If outspec contains a %d in it,
30 * this will be used to create one output file per bin, otherwise all bins
31 * will be written to the same file, in order. If the global outfmt
32 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
33 * and the file will conform to a RADIANCE image if xres & yres are set.
34 */
35 typedef struct {
36 const char *outspec; /* output file specification */
37 const char *modname; /* modifier name */
38 EPNODE *binv; /* bin value expression */
39 int nbins; /* number of accumulation bins */
40 DCOLOR cbin[1]; /* contribution bins (extends struct) */
41 } MODCONT; /* modifier contribution */
42
43 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
44
45 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
46
47 /* close output stream */
48 static void closefile(void *p) { fclose((FILE *)p); }
49
50 LUTAB ofiletab = LU_SINIT(free,closefile); /* output file table */
51
52 FILE *getofile(const char *ospec, const char *mname, int bn);
53
54 /*
55 * The rcont structure is used to manage i/o with a particular
56 * rtrace child process. Input is passed unchanged from stdin,
57 * and output is processed in input order and accumulated according
58 * to the corresponding modifier and bin number.
59 */
60 struct rtproc {
61 struct rtproc *next; /* next in list of processes */
62 SUBPROC pd; /* rtrace pipe descriptors */
63 unsigned long raynum; /* ray number for this tree */
64 int bsiz; /* ray tree buffer length */
65 char *buf; /* ray tree buffer */
66 int nbr; /* number of bytes from rtrace */
67 }; /* rtrace process buffer */
68
69 /* rtrace command and defaults */
70 char *rtargv[256] = { "rtrace", "-dj", ".5", "-dr", "3",
71 "-ab", "1", "-ad", "128", "-lr", "-10", };
72 int rtargc = 11;
73 /* overriding rtrace options */
74 char *myrtopts[] = { "-o~~TmWdp", "-h-", "-x", "1", "-y", "0",
75 "-dt", "0", "-as", "0", "-aa", "0", NULL };
76
77 struct rtproc rt0; /* head of rtrace process list */
78
79 struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
80
81 char persistfn[] = "pfXXXXXX"; /* persist file name */
82
83 int gargc; /* global argc */
84 char **gargv; /* global argv */
85 #define progname gargv[0]
86
87 char *octree; /* global octree argument */
88
89 int inpfmt = 'a'; /* input format */
90 int outfmt = 'a'; /* output format */
91
92 int header = 1; /* output header? */
93 int xres = 0; /* horiz. output resolution */
94 int yres = 0; /* vert. output resolution */
95
96 long raysleft; /* number of rays left to trace */
97 long waitflush; /* how long until next flush */
98
99 unsigned long lastray = 0; /* last ray number sent */
100 unsigned long lastdone = 0; /* last ray processed */
101
102 int using_stdout = 0; /* are we using stdout? */
103
104 const char *modname[MAXMODLIST]; /* ordered modifier name list */
105 int nmods = 0; /* number of modifiers */
106
107 MODCONT *addmodifier(char *modn, char *outf, char *binv);
108
109 void init(int np);
110 int done_rprocs(struct rtproc *rtp);
111 void trace_contribs(FILE *fp);
112 struct rtproc *wait_rproc(void);
113 struct rtproc *get_rproc(void);
114 void queue_raytree(struct rtproc *rtp);
115 void process_queue(void);
116
117 void putcontrib(const DCOLOR cnt, FILE *fout);
118 void add_contrib(const char *modn);
119 void done_contrib(void);
120
121 /* set input/output format */
122 static void
123 setformat(const char *fmt)
124 {
125 switch (fmt[0]) {
126 case 'f':
127 case 'd':
128 SET_FILE_BINARY(stdin);
129 /* fall through */
130 case 'a':
131 inpfmt = fmt[0];
132 break;
133 default:
134 goto fmterr;
135 }
136 switch (fmt[1]) {
137 case '\0':
138 outfmt = inpfmt;
139 return;
140 case 'a':
141 case 'f':
142 case 'd':
143 case 'c':
144 outfmt = fmt[1];
145 break;
146 default:
147 goto fmterr;
148 }
149 if (!fmt[2])
150 return;
151 fmterr:
152 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
153 error(USER, errmsg);
154 }
155
156 /* gather rays from rtrace and output contributions */
157 int
158 main(int argc, char *argv[])
159 {
160 int nprocs = 1;
161 char *curout = NULL;
162 char *binval = NULL;
163 char fmt[8];
164 int i, j;
165 /* global program name */
166 gargv = argv;
167 /* set up calcomp mode */
168 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
169 esupport &= ~(E_OUTCHAN);
170 /* get our options */
171 for (i = 1; i < argc-1; i++) {
172 /* expand arguments */
173 while ((j = expandarg(&argc, &argv, i)) > 0)
174 ;
175 if (j < 0) {
176 fprintf(stderr, "%s: cannot expand '%s'",
177 argv[0], argv[i]);
178 exit(1);
179 }
180 if (argv[i][0] == '-')
181 switch (argv[i][1]) {
182 case 'n': /* number of processes */
183 if (argv[i][2] || i >= argc-1) break;
184 nprocs = atoi(argv[++i]);
185 if (nprocs <= 0)
186 error(USER, "illegal number of processes");
187 continue;
188 case 'h': /* output header? */
189 switch (argv[i][2]) {
190 case '\0':
191 header = !header;
192 continue;
193 case '+': case '1':
194 case 'T': case 't':
195 case 'Y': case 'y':
196 header = 1;
197 continue;
198 case '-': case '0':
199 case 'F': case 'f':
200 case 'N': case 'n':
201 header = 0;
202 continue;
203 }
204 break;
205 case 'f': /* file or i/o format */
206 if (!argv[i][2]) {
207 char *fpath;
208 if (i >= argc-1) break;
209 fpath = getpath(argv[++i],
210 getrlibpath(), R_OK);
211 if (fpath == NULL) {
212 sprintf(errmsg,
213 "cannot find file '%s'",
214 argv[i]);
215 error(USER, errmsg);
216 }
217 fcompile(fpath);
218 continue;
219 }
220 setformat(argv[i]+2);
221 continue;
222 case 'e': /* expression */
223 if (argv[i][2] || i >= argc-1) break;
224 scompile(argv[++i], NULL, 0);
225 continue;
226 case 'o': /* output file spec. */
227 if (argv[i][2] || i >= argc-1) break;
228 curout = argv[++i];
229 continue;
230 case 'x': /* horiz. output resolution */
231 if (argv[i][2] || i >= argc-1) break;
232 xres = atoi(argv[++i]);
233 continue;
234 case 'y': /* vert. output resolution */
235 if (argv[i][2] || i >= argc-1) break;
236 yres = atoi(argv[++i]);
237 continue;
238 case 'b': /* bin expression */
239 if (argv[i][2] || i >= argc-1) break;
240 binval = argv[++i];
241 continue;
242 case 'm': /* modifier name */
243 if (argv[i][2] || i >= argc-1) break;
244 rtargv[rtargc++] = "-ti";
245 rtargv[rtargc++] = argv[++i];
246 addmodifier(argv[i], curout, binval);
247 continue;
248 }
249 rtargv[rtargc++] = argv[i]; /* assume rtrace option */
250 }
251 /* set global argument list */
252 gargc = argc; gargv = argv;
253 /* add "mandatory" rtrace settings */
254 for (j = 0; myrtopts[j] != NULL; j++)
255 rtargv[rtargc++] = myrtopts[j];
256 /* just asking for defaults? */
257 if (!strcmp(argv[i], "-defaults")) {
258 char sxres[16], syres[16];
259 char *rtpath;
260 printf("-n %-2d\t\t\t\t# number of processes\n", nprocs);
261 fflush(stdout); /* report OUR options */
262 rtargv[rtargc++] = header ? "-h+" : "-h-";
263 sprintf(fmt, "-f%c%c", inpfmt, outfmt);
264 rtargv[rtargc++] = fmt;
265 rtargv[rtargc++] = "-x";
266 sprintf(sxres, "%d", xres);
267 rtargv[rtargc++] = sxres;
268 rtargv[rtargc++] = "-y";
269 sprintf(syres, "%d", yres);
270 rtargv[rtargc++] = syres;
271 rtargv[rtargc++] = "-oTW";
272 rtargv[rtargc++] = "-defaults";
273 rtargv[rtargc] = NULL;
274 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
275 if (rtpath == NULL) {
276 eputs(rtargv[0]);
277 eputs(": command not found\n");
278 exit(1);
279 }
280 execv(rtpath, rtargv);
281 perror(rtpath); /* execv() should not return */
282 exit(1);
283 }
284 if (nprocs > 1) { /* add persist file if parallel */
285 rtargv[rtargc++] = "-PP";
286 rtargv[rtargc++] = mktemp(persistfn);
287 }
288 /* add format string */
289 sprintf(fmt, "-f%cf", inpfmt);
290 rtargv[rtargc++] = fmt;
291 /* octree argument is last */
292 if (i <= 0 || i != argc-1 || argv[i][0] == '-')
293 error(USER, "missing octree argument");
294 rtargv[rtargc++] = octree = argv[i];
295 rtargv[rtargc] = NULL;
296 /* start rtrace & compute contributions */
297 init(nprocs);
298 trace_contribs(stdin);
299 quit(0);
300 }
301
302 /* kill persistent rtrace process */
303 static void
304 killpersist(void)
305 {
306 FILE *fp = fopen(persistfn, "r");
307 int pid;
308
309 if (fp == NULL)
310 return;
311 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
312 unlink(persistfn);
313 fclose(fp);
314 }
315
316 /* close rtrace processes and clean up */
317 int
318 done_rprocs(struct rtproc *rtp)
319 {
320 int st0, st1 = 0;
321
322 if (rtp->next != NULL) { /* close last opened first! */
323 st1 = done_rprocs(rtp->next);
324 free((void *)rtp->next);
325 rtp->next = NULL;
326 }
327 st0 = close_process(&rtp->pd);
328 if (st0 < 0)
329 error(WARNING, "unknown return status from rtrace process");
330 else if (st0 > 0)
331 return(st0);
332 return(st1);
333 }
334
335 /* exit with status */
336 void
337 quit(int status)
338 {
339 int rtstat;
340
341 if (rt0.next != NULL) /* terminate persistent rtrace */
342 killpersist();
343 /* clean up rtrace process(es) */
344 rtstat = done_rprocs(&rt0);
345 if (status == 0)
346 status = rtstat;
347 exit(status); /* flushes all output streams */
348 }
349
350 /* start rtrace processes and initialize */
351 void
352 init(int np)
353 {
354 struct rtproc *rtp;
355 int i;
356 int maxbytes;
357 /* make sure we have something to do */
358 if (!nmods)
359 error(USER, "No modifiers specified");
360 /* assign ray variables */
361 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
362 scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
363 /* set up signal handling */
364 signal(SIGINT, quit);
365 #ifdef SIGHUP
366 signal(SIGHUP, quit);
367 #endif
368 #ifdef SIGTERM
369 signal(SIGTERM, quit);
370 #endif
371 #ifdef SIGPIPE
372 signal(SIGPIPE, quit);
373 #endif
374 rtp = &rt0; /* start rtrace process(es) */
375 for (i = 0; i++ < np; ) {
376 errno = 0;
377 maxbytes = open_process(&rtp->pd, rtargv);
378 if (maxbytes == 0) {
379 eputs(rtargv[0]);
380 eputs(": command not found\n");
381 exit(1);
382 }
383 if (maxbytes < 0)
384 error(SYSTEM, "cannot start rtrace process");
385 if (maxbytes > treebufsiz)
386 treebufsiz = maxbytes;
387 rtp->raynum = 0;
388 rtp->bsiz = 0;
389 rtp->buf = NULL;
390 rtp->nbr = 0;
391 if (i == np) /* last process? */
392 break;
393 if (i == 1)
394 sleep(2); /* wait for persist file */
395 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
396 if (rtp->next == NULL)
397 error(SYSTEM, "out of memory in init");
398 rtp = rtp->next;
399 }
400 rtp->next = NULL; /* terminate list */
401 if (yres > 0) {
402 if (xres > 0)
403 raysleft = xres*yres;
404 else
405 raysleft = yres;
406 } else
407 raysleft = 0;
408 waitflush = xres;
409 }
410
411 /* add modifier to our list to track */
412 MODCONT *
413 addmodifier(char *modn, char *outf, char *binv)
414 {
415 LUENT *lep = lu_find(&modconttab, modn);
416 MODCONT *mp;
417
418 if (lep->data != NULL) {
419 sprintf(errmsg, "duplicate modifier '%s'", modn);
420 error(USER, errmsg);
421 }
422 if (nmods >= MAXMODLIST)
423 error(USER, "too many modifiers");
424 modname[nmods++] = modn; /* XXX assumes static string */
425 lep->key = modn; /* XXX assumes static string */
426 mp = (MODCONT *)malloc(sizeof(MODCONT));
427 if (mp == NULL)
428 error(SYSTEM, "out of memory in addmodifier");
429 lep->data = (char *)mp;
430 mp->outspec = outf; /* XXX assumes static string */
431 mp->modname = modn; /* XXX assumes static string */
432 if (binv != NULL)
433 mp->binv = eparse(binv);
434 else
435 mp->binv = eparse("0");
436 mp->nbins = 1;
437 setcolor(mp->cbin[0], 0., 0., 0.);
438 return mp;
439 }
440
441 /* put string to stderr */
442 void
443 eputs(char *s)
444 {
445 static int midline = 0;
446
447 if (!*s) return;
448 if (!midline) {
449 fputs(progname, stderr);
450 fputs(": ", stderr);
451 }
452 fputs(s, stderr);
453 midline = s[strlen(s)-1] != '\n';
454 }
455
456 /* write header to the given output stream */
457 void
458 printheader(FILE *fout)
459 {
460 extern char VersionID[];
461 FILE *fin = fopen(octree, "r");
462
463 if (fin == NULL)
464 quit(1);
465 checkheader(fin, "ignore", fout); /* copy octree header */
466 fclose(fin);
467 printargs(gargc-1, gargv, fout); /* add our command */
468 fprintf(fout, "SOFTWARE= %s\n", VersionID);
469 fputnow(fout);
470 switch (outfmt) { /* add output format */
471 case 'a':
472 fputformat("ascii", fout);
473 break;
474 case 'f':
475 fputformat("float", fout);
476 break;
477 case 'd':
478 fputformat("double", fout);
479 break;
480 case 'c':
481 fputformat(COLRFMT, fout);
482 break;
483 }
484 fputc('\n', fout);
485 if (xres > 0) {
486 if (yres > 0) /* resolution string */
487 fprtresolu(xres, yres, fout);
488 fflush(fout);
489 }
490 }
491
492 /* Get output file pointer (open and write header if new) */
493 FILE *
494 getofile(const char *ospec, const char *mname, int bn)
495 {
496 const char *mnp = NULL;
497 const char *bnp = NULL;
498 const char *cp;
499 char ofname[1024];
500 LUENT *lep;
501
502 if (ospec == NULL) { /* use stdout? */
503 if (!using_stdout) {
504 if (outfmt != 'a')
505 SET_FILE_BINARY(stdout);
506 if (header)
507 printheader(stdout);
508 }
509 using_stdout = 1;
510 return stdout;
511 }
512 for (cp = ospec; *cp; cp++) /* check format position(s) */
513 if (*cp == '%') {
514 do
515 ++cp;
516 while (isdigit(*cp));
517 switch (*cp) {
518 case '%':
519 break;
520 case 's':
521 if (mnp != NULL)
522 goto badspec;
523 mnp = cp;
524 break;
525 case 'd':
526 if (bnp != NULL)
527 goto badspec;
528 bnp = cp;
529 break;
530 default:
531 goto badspec;
532 }
533 }
534 if (mnp != NULL) { /* create file name */
535 if (bnp != NULL) {
536 if (bnp > mnp)
537 sprintf(ofname, ospec, mname, bn);
538 else
539 sprintf(ofname, ospec, bn, mname);
540 } else
541 sprintf(ofname, ospec, mname);
542 } else if (bnp != NULL)
543 sprintf(ofname, ospec, bn);
544 else
545 strcpy(ofname, ospec);
546 lep = lu_find(&ofiletab, ofname); /* look it up */
547 if (lep->key == NULL) /* new entry */
548 lep->key = strcpy((char *)malloc(strlen(ofname)+1), ofname);
549 if (lep->data == NULL) { /* open output file */
550 FILE *fp;
551 int i;
552 if (ofname[0] == '!') /* output to command */
553 fp = popen(ofname+1, "w");
554 else
555 fp = fopen(ofname, "w");
556 if (fp == NULL) {
557 sprintf(errmsg, "cannot open '%s' for writing", ofname);
558 error(SYSTEM, errmsg);
559 }
560 if (outfmt != 'a')
561 SET_FILE_BINARY(fp);
562 if (header)
563 printheader(fp);
564 /* play catch-up */
565 for (i = 0; i < lastdone; i++) {
566 static const DCOLOR nocontrib = BLKCOLOR;
567 putcontrib(nocontrib, fp);
568 if (outfmt == 'a')
569 putc('\n', fp);
570 }
571 if (xres > 0)
572 fflush(fp);
573 lep->data = (char *)fp;
574 }
575 return (FILE *)lep->data; /* return open file pointer */
576 badspec:
577 sprintf(errmsg, "bad output format '%s'", ospec);
578 error(USER, errmsg);
579 return NULL; /* pro forma return */
580 }
581
582 /* read input ray into buffer */
583 int
584 getinp(char *buf, FILE *fp)
585 {
586 char *cp;
587 int i;
588
589 switch (inpfmt) {
590 case 'a':
591 cp = buf; /* make sure we get 6 floats */
592 for (i = 0; i < 6; i++) {
593 if (fgetword(cp, buf+127-cp, fp) == NULL)
594 return 0;
595 if ((cp = fskip(cp)) == NULL || *cp)
596 return 0;
597 *cp++ = ' ';
598 }
599 getc(fp); /* get/put eol */
600 *cp-- = '\0'; *cp = '\n';
601 return strlen(buf);
602 case 'f':
603 if (fread(buf, sizeof(float), 6, fp) < 6)
604 return 0;
605 return sizeof(float)*6;
606 case 'd':
607 if (fread(buf, sizeof(double), 6, fp) < 6)
608 return 0;
609 return sizeof(double)*6;
610 }
611 error(INTERNAL, "botched input format");
612 return 0; /* pro forma return */
613 }
614
615 static float rparams[9]; /* traced ray parameters */
616
617 /* return channel (ray) value */
618 double
619 chanvalue(int n)
620 {
621 if (--n < 0 || n >= 6)
622 error(USER, "illegal channel number ($N)");
623 return rparams[n+3];
624 }
625
626 /* add current ray contribution to the appropriate modifier bin */
627 void
628 add_contrib(const char *modn)
629 {
630 LUENT *le = lu_find(&modconttab, modn);
631 MODCONT *mp = (MODCONT *)le->data;
632 int bn;
633
634 if (mp == NULL) {
635 sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
636 error(USER, errmsg);
637 }
638 eclock++; /* get bin number */
639 bn = (int)(evalue(mp->binv) + .5);
640 if (bn <= 0)
641 bn = 0;
642 else if (bn > mp->nbins) { /* new bin */
643 mp = (MODCONT *)realloc(mp, sizeof(MODCONT) +
644 bn*sizeof(DCOLOR));
645 if (mp == NULL)
646 error(SYSTEM, "out of memory in add_contrib");
647 memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(bn+1-mp->nbins));
648 mp->nbins = bn+1;
649 le->data = (char *)mp;
650 }
651 addcolor(mp->cbin[bn], rparams);
652 }
653
654 /* output newline to ASCII file and/or flush as requested */
655 static int
656 puteol(const LUENT *e, void *p)
657 {
658 FILE *fp = (FILE *)e->data;
659
660 if (outfmt == 'a')
661 putc('\n', fp);
662 if (!waitflush)
663 fflush(fp);
664 if (ferror(fp)) {
665 sprintf(errmsg, "write error on file '%s'", e->key);
666 error(SYSTEM, errmsg);
667 }
668 return 0;
669 }
670
671 /* put out ray contribution to file */
672 void
673 putcontrib(const DCOLOR cnt, FILE *fout)
674 {
675 float fv[3];
676 COLR cv;
677
678 switch (outfmt) {
679 case 'a':
680 fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
681 break;
682 case 'f':
683 fv[0] = cnt[0];
684 fv[1] = cnt[1];
685 fv[2] = cnt[2];
686 fwrite(fv, sizeof(float), 3, fout);
687 break;
688 case 'd':
689 fwrite(cnt, sizeof(double), 3, fout);
690 break;
691 case 'c':
692 setcolr(cv, cnt[0], cnt[1], cnt[2]);
693 fwrite(cv, sizeof(cv), 1, fout);
694 break;
695 default:
696 error(INTERNAL, "botched output format");
697 }
698 }
699
700 /* output ray tallies and clear for next primary */
701 void
702 done_contrib(void)
703 {
704 int i, j;
705 MODCONT *mp;
706 /* output modifiers in order */
707 for (i = 0; i < nmods; i++) {
708 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
709 for (j = 0; j < mp->nbins; j++)
710 putcontrib(mp->cbin[j],
711 getofile(mp->outspec, mp->modname, j));
712 /* clear for next ray tree */
713 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
714 }
715 --waitflush; /* terminate records */
716 lu_doall(&ofiletab, puteol, NULL);
717 if (using_stdout & (outfmt == 'a'))
718 putc('\n', stdout);
719 if (!waitflush) {
720 waitflush = xres;
721 if (using_stdout)
722 fflush(stdout);
723 }
724 }
725
726 /* queue completed ray tree produced by rtrace process */
727 void
728 queue_raytree(struct rtproc *rtp)
729 {
730 struct rtproc *rtu, *rtl = NULL;
731 /* insert following ray order */
732 for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
733 if (rtp->raynum < rtu->raynum)
734 break;
735 rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
736 if (rtu == NULL)
737 error(SYSTEM, "out of memory in queue_raytree");
738 *rtu = *rtp;
739 if (rtl == NULL) {
740 rtu->next = rt_unproc;
741 rt_unproc = rtu;
742 } else {
743 rtu->next = rtl->next;
744 rtl->next = rtu;
745 }
746 rtp->raynum = 0; /* clear path for next ray tree */
747 rtp->bsiz = 0;
748 rtp->buf = NULL;
749 rtp->nbr = 0;
750 }
751
752 /* process completed ray trees from our queue */
753 void
754 process_queue(void)
755 {
756 char modname[128];
757 /* ray-ordered queue */
758 while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
759 struct rtproc *rtp = rt_unproc;
760 int n = rtp->nbr;
761 const char *cp = rtp->buf;
762 while (n > 0) { /* process rays */
763 register char *mnp = modname;
764 /* skip leading tabs */
765 while (n > 0 && *cp == '\t') {
766 cp++; n--;
767 }
768 if (!n || !(isalpha(*cp) | (*cp == '_')))
769 error(USER, "bad modifier name from rtrace");
770 /* get modifier name */
771 while (n > 0 && *cp != '\t') {
772 *mnp++ = *cp++; n--;
773 }
774 *mnp = '\0';
775 cp++; n--; /* eat following tab */
776 if (n < (int)(sizeof(float)*9))
777 error(USER, "incomplete ray value from rtrace");
778 /* add ray contribution */
779 memcpy(rparams, cp, sizeof(float)*9);
780 cp += sizeof(float)*9; n -= sizeof(float)*9;
781 add_contrib(modname);
782 }
783 done_contrib(); /* sum up contributions & output */
784 lastdone = rtp->raynum;
785 free(rtp->buf); /* free up buffer space */
786 rt_unproc = rtp->next;
787 free(rtp); /* done with this ray tree */
788 }
789 }
790
791 /* wait for rtrace process to finish with ray tree */
792 struct rtproc *
793 wait_rproc(void)
794 {
795 struct rtproc *rtfree = NULL;
796 fd_set readset, errset;
797 int nr;
798 struct rtproc *rt;
799 int n;
800
801 do {
802 nr = 0; /* prepare select call */
803 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
804 for (rt = &rt0; rt != NULL; rt = rt->next) {
805 if (rt->raynum) {
806 FD_SET(rt->pd.r, &readset);
807 ++nr;
808 }
809 FD_SET(rt->pd.r, &errset);
810 if (rt->pd.r >= n)
811 n = rt->pd.r + 1;
812 }
813 if (!nr) /* no rays pending */
814 break;
815 if (nr > 1) { /* call select for multiple proc's */
816 errno = 0;
817 if (select(n, &readset, NULL, &errset, NULL) < 0)
818 error(SYSTEM, "select call error in wait_rproc()");
819 } else
820 FD_ZERO(&errset);
821 nr = 0;
822 for (rt = &rt0; rt != NULL; rt = rt->next) {
823 if (!FD_ISSET(rt->pd.r, &readset) &&
824 !FD_ISSET(rt->pd.r, &errset))
825 continue;
826 if (rt->buf == NULL) {
827 rt->bsiz = treebufsiz;
828 rt->buf = (char *)malloc(treebufsiz);
829 } else if (rt->nbr + BUFSIZ > rt->bsiz) {
830 if (rt->bsiz + BUFSIZ <= treebufsiz)
831 rt->bsiz = treebufsiz;
832 else
833 rt->bsiz = treebufsiz += BUFSIZ;
834 rt->buf = (char *)realloc(rt->buf, rt->bsiz);
835 }
836 if (rt->buf == NULL)
837 error(SYSTEM, "out of memory in wait_rproc");
838 nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
839 if (nr <= 0)
840 error(USER, "rtrace process died");
841 rt->nbr += nr; /* advance & check */
842 if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4,
843 "~\t~\t", 4)) {
844 rt->nbr -= 4; /* elide terminator */
845 queue_raytree(rt);
846 rtfree = rt; /* ready for next ray */
847 }
848 }
849 } while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
850 return rtfree;
851 }
852
853 /* return next available rtrace process */
854 struct rtproc *
855 get_rproc(void)
856 {
857 struct rtproc *rtp;
858 /* check for idle rtrace */
859 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
860 if (!rtp->raynum)
861 return rtp;
862 return wait_rproc(); /* need to wait for one */
863 }
864
865 /* trace ray contributions (main loop) */
866 void
867 trace_contribs(FILE *fin)
868 {
869 char inpbuf[128];
870 int iblen;
871 struct rtproc *rtp;
872 /* loop over input */
873 while ((iblen = getinp(inpbuf, fin)) > 0) {
874 if (lastray+1 < lastray) { /* counter rollover? */
875 while (wait_rproc() != NULL)
876 process_queue();
877 lastdone = lastray = 0;
878 }
879 rtp = get_rproc(); /* get avail. rtrace process */
880 rtp->raynum = ++lastray; /* assign ray to it */
881 writebuf(rtp->pd.w, inpbuf, iblen);
882 if (!--raysleft)
883 break;
884 process_queue(); /* catch up with results */
885 }
886 while (wait_rproc() != NULL) /* process outstanding rays */
887 process_queue();
888 if (raysleft > 0)
889 error(USER, "unexpected EOF on input");
890 }
