--- ray/src/util/rtcontrib.c 2005/10/11 04:27:41 1.34 +++ ray/src/util/rtcontrib.c 2005/10/11 16:54:26 1.35 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtcontrib.c,v 1.34 2005/10/11 04:27:41 greg Exp $"; +static const char RCSid[] = "$Id: rtcontrib.c,v 1.35 2005/10/11 16:54:26 greg Exp $"; #endif /* * Gather rtrace output to compute contributions from particular sources @@ -123,6 +123,7 @@ int inpfmt = 'a'; /* input format */ int outfmt = 'a'; /* output format */ int header = 1; /* output header? */ +int force_open = 0; /* truncate existing output? */ int xres = 0; /* horiz. output resolution */ int yres = 0; /* vert. output resolution */ @@ -266,7 +267,7 @@ main(int argc, char *argv[]) continue; } break; - case 'f': /* file or i/o format */ + case 'f': /* file or force or format */ if (!argv[i][2]) { char *fpath; if (i >= argc-2) break; @@ -281,6 +282,10 @@ main(int argc, char *argv[]) fcompile(fpath); continue; } + if (argv[i][2] == 'o') { + force_open++; + continue; + } setformat(argv[i]+2); continue; case 'e': /* expression */ @@ -710,7 +715,9 @@ getostream(const char *ospec, const char *mname, int b long i; if (oname[0] == '!') /* output to command */ sop->ofp = popen(oname+1, "w"); - else + else if (!force_open && access(oname, F_OK) == 0) + errno = EEXIST; /* file exists */ + else /* else open it */ sop->ofp = fopen(oname, "w"); if (sop->ofp == NULL) { sprintf(errmsg, "cannot open '%s' for writing", oname);
