--- ray/src/util/rtcontrib.c 2005/06/10 20:53:55 1.20 +++ ray/src/util/rtcontrib.c 2005/09/19 11:30:11 1.26 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtcontrib.c,v 1.20 2005/06/10 20:53:55 greg Exp $"; +static const char RCSid[] = "$Id: rtcontrib.c,v 1.26 2005/09/19 11:30:11 schorsch Exp $"; #endif /* * Gather rtrace output to compute contributions from particular sources @@ -173,6 +173,13 @@ main(int argc, char *argv[]) char *binval = NULL; char fmt[8]; int i, j; + /* need at least one argument */ + if (argc < 2) { + fprintf(stderr, +"Usage: %s [-n nprocs][-r][-e expr][-f source][-o ospec][-b binv] {-m mod | -M file} [rtrace options] octree\n", + argv[0]); + exit(1); + } /* global program name */ gargv = argv; /* initialize calcomp routines */ @@ -196,7 +203,7 @@ main(int argc, char *argv[]) recover++; continue; case 'n': /* number of processes */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; nprocs = atoi(argv[++i]); if (nprocs <= 0) error(USER, "illegal number of processes"); @@ -221,7 +228,7 @@ main(int argc, char *argv[]) case 'f': /* file or i/o format */ if (!argv[i][2]) { char *fpath; - if (i >= argc-1) break; + if (i >= argc-2) break; fpath = getpath(argv[++i], getrlibpath(), R_OK); if (fpath == NULL) { @@ -236,33 +243,33 @@ main(int argc, char *argv[]) setformat(argv[i]+2); continue; case 'e': /* expression */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; scompile(argv[++i], NULL, 0); continue; case 'o': /* output file spec. */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; curout = argv[++i]; continue; case 'x': /* horiz. output resolution */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; xres = atoi(argv[++i]); continue; case 'y': /* vert. output resolution */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; yres = atoi(argv[++i]); continue; case 'b': /* bin expression */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; binval = argv[++i]; continue; case 'm': /* modifier name */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; rtargv[rtargc++] = "-ti"; rtargv[rtargc++] = argv[++i]; addmodifier(argv[i], curout, binval); continue; case 'M': /* modifier file */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; rtargv[rtargc++] = "-tI"; rtargv[rtargc++] = argv[++i]; addmodfile(argv[i], curout, binval); @@ -315,20 +322,23 @@ main(int argc, char *argv[]) error(USER, "missing octree argument"); rtargv[rtargc++] = octree = argv[i]; rtargv[rtargc] = NULL; - /* start rtrace & compute contributions */ + /* start rtrace */ init(nprocs); if (recover) /* perform recovery if requested */ recover_output(stdin); - trace_contribs(stdin); + trace_contribs(stdin); /* compute contributions */ quit(0); } +#ifndef SIGALRM +#define SIGALRM SIGTERM +#endif /* kill persistent rtrace process */ static void killpersist(void) { FILE *fp = fopen(persistfn, "r"); - int pid; + RT_PID pid; if (fp == NULL) return; @@ -623,10 +633,8 @@ getofile(const char *ospec, const char *mname, int bn) if (header) { char info[512]; char *cp = info; - if (ofl & OF_MODIFIER) { - sprintf(cp, "MODIFIER=%s\n", mname); - while (*cp) ++cp; - } + sprintf(cp, "MODIFIER=%s\n", mname); + while (*cp) ++cp; if (ofl & OF_BIN) { sprintf(cp, "BIN=%d\n", bn); while (*cp) ++cp; @@ -1032,8 +1040,13 @@ recover_output(FILE *fin) error(USER, "cannot recover from command"); /* open output */ fp = fopen(oname, "rb+"); - if (fp == NULL) - break; /* must be end of modifier */ + if (fp == NULL) { + if (j) + break; /* assume end of modifier */ + sprintf(errmsg, "missing recover file '%s'", + oname); + error(USER, errmsg); + } nvals = lseek(fileno(fp), 0, SEEK_END); if (nvals <= 0) { lastout = 0; /* empty output, quit here */ @@ -1087,6 +1100,11 @@ recover_output(FILE *fin) if (lastout < 0) { error(WARNING, "no output files to recover"); return; + } + if (raysleft && lastout >= raysleft) { + error(WARNING, "output appears to be complete"); + /* XXX should read & discard input? */ + quit(0); } /* seek on all files */ nvals = lastout * outvsiz;
