Windows compatibility changes from Bill Hoffman
Bug fix for 32-bit OS
Fixed problem with command specification of octree
Minor adjustments to last change
Attempt to fix bug
Removed unneeded inclusion of random.h
Removed random flush call that was only making matters worse
Fixed issues with integer overflow
Added random flushing of output buffers in attempt to improve performance
Fixed -defaults reporting of number of processes
Made output specification a little more flexible (hex and octal numbers)
Added ability to specify constant name in rtcontrib -bn option
Fixed peculiar flushing case
Added missing newline to error statement
Modified rtcontrib -c option to accumulate a specified number of rays
Minor fixes in reloading procedure
Minor tweaks: -x and -y may again be given after -m options with -c-
Got -r option working with -c
Added -c option to rtcontrib (barely tested, and -r does not work)
Allow -P and -PP options to be set by user
Increased default -ad from 128 to 350
Minor correction to avoid segfault with illegal option
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Added check for -P and -PP option, which causes conflict
Minor fix to ray flushing
Fixed rtcontrib flushing behavior
Made it so zero ray directions flush output in rtcontrib
Added rtcontrib -fo option to override new reluctance to clobber existing files
Fixed bug introduced in rev 1.29 (Oct 5 2005) that broke output synchronization
Added final write error check
Fixes in new rtcontrib -bn option
Minor improvements in output file consistency with rtrace
Bug fix for some systems where rtrace process gets stuck for unknown reasons
Fixed serious bug where rtcontrib would sometimes forget to write last file
Added check for no arguments
Added check for complete output with -r option
Added check for missing recover files
Made it so MODIFIER= line added to every header
Fixed argument checking
Fixed it so rtcontrib -M option searches RAYPATH directories
Fixe in rtcontrib -M option
Fixed array overrun with large number of modifiers
Added rtcontrib -M option to read modifier list from a file
Warning wording tweaks
Added warning & check for case where no output files exist with -r option
Minor optimization to reduce calls to getofile()
Added missing definition of PI for calcomp routines
Added missing include for signal.h
Minor code tweaks
Improved efficiency of queuing behavior to avoid idle process time
