root/radiance/ray/src/util/rtcontrib.c
Revision: 1.60
Committed: Sun Oct 10 09:25:04 2010 UTC (13 years, 7 months ago) by greg
Changes since 1.59: +1 -2 lines
Removed unneeded inclusion of random.h
2 static const char RCSid[] = "$Id: rtcontrib.c,v 1.59 2010/10/10 01:26:51 greg Exp $";
5 * Gather rtrace output to compute contributions from particular sources
6 */
7
8 #include "standard.h"
9 #include <ctype.h>
10 #include <signal.h>
11 #include "platform.h"
12 #include "rtprocess.h"
13 #include "selcall.h"
14 #include "color.h"
15 #include "resolu.h"
16 #include "lookup.h"
17 #include "calcomp.h"
18
19 #ifndef MAXMODLIST
20 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
21 #endif
22
23 size_t treebufsiz = BUFSIZ; /* current tree buffer size */
24
25 typedef double DCOLOR[3]; /* double-precision color */
26
27 /*
28 * The MODCONT structure is used to accumulate ray contributions
29 * for a particular modifier, which may be subdivided into bins
30 * if binv evaluates > 0. If outspec contains a %s in it, this will
31 * be replaced with the modifier name. If outspec contains a %d in it,
32 * this will be used to create one output file per bin, otherwise all bins
33 * will be written to the same file, in order. If the global outfmt
34 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
35 * and the file will conform to a RADIANCE image if xres & yres are set.
36 */
37 typedef struct {
38 const char *outspec; /* output file specification */
39 const char *modname; /* modifier name */
40 EPNODE *binv; /* bin value expression */
41 int nbins; /* number of accumulation bins */
42 DCOLOR cbin[1]; /* contribution bins (extends struct) */
43 } MODCONT; /* modifier contribution */
44
45 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
46
47 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
48
49 /*
50 * The STREAMOUT structure holds an open FILE pointer and a count of
51 * the number of RGB triplets per record, or 0 if unknown.
52 */
53 typedef struct {
54 FILE *ofp; /* output file pointer */
55 int outpipe; /* output is to a pipe */
56 int reclen; /* triplets/record */
57 int xr, yr; /* output resolution for picture */
58 } STREAMOUT;
59
60 /* close output stream and free record */
61 static void
62 closestream(void *p)
63 {
64 STREAMOUT *sop = (STREAMOUT *)p;
65 int status;
66 if (sop->outpipe)
67 status = pclose(sop->ofp);
68 else
69 status = fclose(sop->ofp);
70 if (status)
71 error(SYSTEM, "error closing output stream");
72 free(p);
73 }
74
75 LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
76
77 #define OF_MODIFIER 01
78 #define OF_BIN 02
79
80 STREAMOUT *getostream(const char *ospec, const char *mname, int bn, int noopen);
81 int ofname(char *oname, const char *ospec, const char *mname, int bn);
82 void printheader(FILE *fout, const char *info);
83 void printresolu(FILE *fout, int xr, int yr);
84
85 /*
86 * The rcont structure is used to manage i/o with a particular
87 * rtrace child process. Input is passed unchanged from stdin,
88 * and output is processed in input order and accumulated according
89 * to the corresponding modifier and bin number.
90 */
91 struct rtproc {
92 struct rtproc *next; /* next in list of processes */
93 SUBPROC pd; /* rtrace pipe descriptors */
94 unsigned long raynum; /* ray number for this tree */
95 size_t bsiz; /* ray tree buffer length */
96 char *buf; /* ray tree buffer */
97 size_t nbr; /* number of bytes from rtrace */
98 }; /* rtrace process buffer */
99
100 /* rtrace command and defaults */
101 char *rtargv[256+2*MAXMODLIST] = { "rtrace",
102 "-dj", ".9", "-dr", "3",
103 "-ab", "1", "-ad", "350", };
104
105 int rtargc = 9;
106 /* overriding rtrace options */
107 char *myrtopts[] = { "-h-", "-x", "1", "-y", "0",
108 "-dt", "0", "-as", "0", "-aa", "0", NULL };
109
110 #define RTCOEFF "-o~~TmWdp" /* compute coefficients only */
111 #define RTCONTRIB "-o~~TmVdp" /* compute ray contributions */
112
113 struct rtproc rt0; /* head of rtrace process list */
114
115 struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
116
117 #define PERSIST_NONE 0 /* no persist file */
118 #define PERSIST_SINGLE 1 /* user set -P persist */
119 #define PERSIST_PARALL 2 /* user set -PP persist */
120 #define PERSIST_OURS 3 /* -PP persist belongs to us */
121 int persist_state = PERSIST_NONE; /* persist file state */
122 char persistfn[] = "pfXXXXXX"; /* our persist file name, if set */
123
124 int gargc; /* global argc */
125 char **gargv; /* global argv */
126 #define progname gargv[0]
127
128 char *octree; /* global octree argument */
129
130 int inpfmt = 'a'; /* input format */
131 int outfmt = 'a'; /* output format */
132
133 int header = 1; /* output header? */
134 int force_open = 0; /* truncate existing output? */
135 int recover = 0; /* recover previous output? */
136 int accumulate = 1; /* input rays per output record */
137 int xres = 0; /* horiz. output resolution */
138 int yres = 0; /* vert. output resolution */
139
140 int account; /* current accumulation count */
141 unsigned long raysleft; /* number of rays left to trace */
142 long waitflush; /* how long until next flush */
143
144 unsigned long lastray = 0; /* last ray number sent */
145 unsigned long lastdone = 0; /* last ray processed */
146
147 int using_stdout = 0; /* are we using stdout? */
148
149 const char *modname[MAXMODLIST]; /* ordered modifier name list */
150 int nmods = 0; /* number of modifiers */
151
152 #define queue_length() (lastray - lastdone)
153
154 MODCONT *growmodifier(MODCONT *mp, int nb);
155 MODCONT *addmodifier(char *modn, char *outf, char *binv, int bincnt);
156 void addmodfile(char *fname, char *outf, char *binv, int bincnt);
157
158 void init(int np);
159 int done_rprocs(struct rtproc *rtp);
160 void reload_output(void);
161 void recover_output(FILE *fin);
162 void trace_contribs(FILE *fin);
163 struct rtproc *wait_rproc(void);
164 struct rtproc *get_rproc(void);
165 void queue_raytree(struct rtproc *rtp);
166 void process_queue(void);
167
168 void put_contrib(const DCOLOR cnt, FILE *fout);
169 void add_contrib(const char *modn);
170 void done_contrib(int navg);
171
172 /* return number of open rtrace processes */
173 static int
174 nrtprocs(void)
175 {
176 int nrtp = 0;
177 struct rtproc *rtp;
178
179 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
180 nrtp += rtp->pd.running;
181 return(nrtp);
182 }
183
184 /* set input/output format */
185 static void
186 setformat(const char *fmt)
187 {
188 switch (fmt[0]) {
189 case 'f':
190 case 'd':
191 SET_FILE_BINARY(stdin);
192 /* fall through */
193 case 'a':
194 inpfmt = fmt[0];
195 break;
196 default:
197 goto fmterr;
198 }
199 switch (fmt[1]) {
200 case '\0':
201 outfmt = inpfmt;
202 return;
203 case 'a':
204 case 'f':
205 case 'd':
206 case 'c':
207 outfmt = fmt[1];
208 break;
209 default:
210 goto fmterr;
211 }
212 if (!fmt[2])
213 return;
214 fmterr:
215 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
216 error(USER, errmsg);
217 }
218
219 /* gather rays from rtrace and output contributions */
220 int
221 main(int argc, char *argv[])
222 {
223 int contrib = 0;
224 int nprocs = 1;
225 char *curout = NULL;
226 char *binval = NULL;
227 int bincnt = 0;
228 char fmt[8];
229 int i, j;
230 /* need at least one argument */
231 if (argc < 2) {
232 fprintf(stderr,
233 "Usage: %s [-n nprocs][-V][-r][-e expr][-f source][-o ospec][-b binv] {-m mod | -M file} [rtrace options] octree\n",
234 argv[0]);
235 exit(1);
236 }
237 /* global program name */
238 gargv = argv;
239 /* initialize calcomp routines */
240 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
241 esupport &= ~(E_OUTCHAN);
242 varset("PI", ':', PI);
243 /* get our options */
244 for (i = 1; i < argc-1; i++) {
245 /* expand arguments */
246 while ((j = expandarg(&argc, &argv, i)) > 0)
247 ;
248 if (j < 0) {
249 fprintf(stderr, "%s: cannot expand '%s'\n",
250 argv[0], argv[i]);
251 exit(1);
252 }
253 if (argv[i][0] == '-')
254 switch (argv[i][1]) {
255 case 'n': /* number of processes */
256 if (argv[i][2] || i >= argc-2) break;
257 nprocs = atoi(argv[++i]);
258 if (nprocs <= 0)
259 error(USER, "illegal number of processes");
260 continue;
261 case 'V': /* output contributions */
262 switch (argv[i][2]) {
263 case '\0':
264 contrib = !contrib;
265 continue;
266 case '+': case '1':
267 case 'T': case 't':
268 case 'Y': case 'y':
269 contrib = 1;
270 continue;
271 case '-': case '0':
272 case 'F': case 'f':
273 case 'N': case 'n':
274 contrib = 0;
275 continue;
276 }
277 break;
278 case 'c': /* input rays per output */
279 if (argv[i][2] || i >= argc-2) break;
280 accumulate = atoi(argv[++i]);
281 continue;
282 case 'r': /* recover output */
283 if (argv[i][2]) break;
284 recover = 1;
285 continue;
286 case 'h': /* output header? */
287 switch (argv[i][2]) {
288 case '\0':
289 header = !header;
290 continue;
291 case '+': case '1':
292 case 'T': case 't':
293 case 'Y': case 'y':
294 header = 1;
295 continue;
296 case '-': case '0':
297 case 'F': case 'f':
298 case 'N': case 'n':
299 header = 0;
300 continue;
301 }
302 break;
303 case 'f': /* file or force or format */
304 if (!argv[i][2]) {
305 char *fpath;
306 if (i >= argc-2) break;
307 fpath = getpath(argv[++i],
308 getrlibpath(), R_OK);
309 if (fpath == NULL) {
310 sprintf(errmsg,
311 "cannot find file '%s'",
312 argv[i]);
313 error(USER, errmsg);
314 }
315 fcompile(fpath);
316 continue;
317 }
318 if (argv[i][2] == 'o') {
319 force_open = 1;
320 continue;
321 }
322 setformat(argv[i]+2);
323 continue;
324 case 'e': /* expression */
325 if (argv[i][2] || i >= argc-2) break;
326 scompile(argv[++i], NULL, 0);
327 continue;
328 case 'o': /* output file spec. */
329 if (argv[i][2] || i >= argc-2) break;
330 curout = argv[++i];
331 continue;
332 case 'x': /* horiz. output resolution */
333 if (argv[i][2] || i >= argc-2) break;
334 xres = atoi(argv[++i]);
335 continue;
336 case 'y': /* vert. output resolution */
337 if (argv[i][2] || i >= argc-2) break;
338 yres = atoi(argv[++i]);
339 continue;
340 case 'b': /* bin expression/count */
341 if (i >= argc-2) break;
342 if (argv[i][2] == 'n') {
343 bincnt = (int)(eval(argv[++i]) + .5);
344 continue;
345 }
346 if (argv[i][2]) break;
347 binval = argv[++i];
348 continue;
349 case 'm': /* modifier name */
350 if (argv[i][2] || i >= argc-2) break;
351 rtargv[rtargc++] = "-ti";
352 rtargv[rtargc++] = argv[++i];
353 addmodifier(argv[i], curout, binval, bincnt);
354 continue;
355 case 'M': /* modifier file */
356 if (argv[i][2] || i >= argc-2) break;
357 rtargv[rtargc++] = "-tI";
358 rtargv[rtargc++] = argv[++i];
359 addmodfile(argv[i], curout, binval, bincnt);
360 continue;
361 case 'P': /* persist file */
362 if (i >= argc-2) break;
363 persist_state = (argv[i][2] == 'P') ?
364 PERSIST_PARALL : PERSIST_SINGLE;
365 rtargv[rtargc++] = argv[i];
366 rtargv[rtargc++] = argv[++i];
367 continue;
368 }
369 rtargv[rtargc++] = argv[i]; /* assume rtrace option */
370 }
371 if (accumulate <= 0) /* no output flushing for single record */
372 xres = yres = 0;
373 /* set global argument list */
374 gargc = argc; gargv = argv;
375 /* add "mandatory" rtrace settings */
376 for (j = 0; myrtopts[j] != NULL; j++)
377 rtargv[rtargc++] = myrtopts[j];
378 rtargv[rtargc++] = contrib ? RTCONTRIB : RTCOEFF;
379 /* just asking for defaults? */
380 if (!strcmp(argv[i], "-defaults")) {
381 char nps[8], sxres[16], syres[16];
382 char *rtpath;
383 printf("-c %-5d\t\t\t# accumulated rays per record\n",
384 accumulate);
385 printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-',
386 contrib ? "contributions" : "coefficients");
387 fflush(stdout); /* report OUR options */
388 rtargv[rtargc++] = "-n";
389 sprintf(nps, "%d", nprocs);
390 rtargv[rtargc++] = nps;
391 rtargv[rtargc++] = header ? "-h+" : "-h-";
392 sprintf(fmt, "-f%c%c", inpfmt, outfmt);
393 rtargv[rtargc++] = fmt;
394 rtargv[rtargc++] = "-x";
395 sprintf(sxres, "%d", xres);
396 rtargv[rtargc++] = sxres;
397 rtargv[rtargc++] = "-y";
398 sprintf(syres, "%d", yres);
399 rtargv[rtargc++] = syres;
400 rtargv[rtargc++] = "-defaults";
401 rtargv[rtargc] = NULL;
402 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
403 if (rtpath == NULL) {
404 eputs(rtargv[0]);
405 eputs(": command not found\n");
406 exit(1);
407 }
408 execv(rtpath, rtargv);
409 perror(rtpath); /* execv() should not return */
410 exit(1);
411 }
412 if (nprocs > 1) { /* add persist file if parallel */
413 if (persist_state == PERSIST_SINGLE)
414 error(USER, "use -PP option for multiple processes");
415 if (persist_state == PERSIST_NONE) {
416 rtargv[rtargc++] = "-PP";
417 rtargv[rtargc++] = mktemp(persistfn);
418 persist_state = PERSIST_OURS;
419 }
420 }
421 /* add format string */
422 sprintf(fmt, "-f%cf", inpfmt);
423 rtargv[rtargc++] = fmt;
424 /* octree argument is last */
425 if (i <= 0 || i != argc-1 || argv[i][0] == '-')
426 error(USER, "missing octree argument");
427 rtargv[rtargc++] = octree = argv[i];
428 rtargv[rtargc] = NULL;
429 /* start rtrace & recover if requested */
430 init(nprocs);
431 /* compute contributions */
432 trace_contribs(stdin);
433 /* clean up */
434 quit(0);
435 }
436
437 #ifndef SIGALRM
438 #define SIGALRM SIGTERM
439 #endif
440 /* kill persistent rtrace process */
441 static void
442 killpersist(void)
443 {
444 FILE *fp = fopen(persistfn, "r");
445 RT_PID pid;
446
447 if (fp == NULL)
448 return;
449 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
450 unlink(persistfn);
451 fclose(fp);
452 }
453
454 /* close rtrace processes and clean up */
455 int
456 done_rprocs(struct rtproc *rtp)
457 {
458 int st0, st1 = 0;
459
460 if (rtp->next != NULL) { /* close last opened first! */
461 st1 = done_rprocs(rtp->next);
462 free((void *)rtp->next);
463 rtp->next = NULL;
464 }
465 st0 = close_process(&rtp->pd);
466 if (st0 < 0)
467 error(WARNING, "unknown return status from rtrace process");
468 else if (st0 > 0)
469 return(st0);
470 return(st1);
471 }
472
473 /* exit with status */
474 void
475 quit(int status)
476 {
477 int rtstat;
478
479 if (persist_state == PERSIST_OURS) /* terminate waiting rtrace */
480 killpersist();
481 /* clean up rtrace process(es) */
482 rtstat = done_rprocs(&rt0);
483 if (status == 0)
484 status = rtstat;
485 exit(status); /* flushes all output streams */
486 }
487
488 /* start rtrace processes and initialize */
489 void
490 init(int np)
491 {
492 struct rtproc *rtp;
493 int i;
494 int maxbytes;
495 /* make sure we have something to do */
496 if (!nmods)
497 error(USER, "No modifiers specified");
498 /* assign ray variables */
499 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
500 scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
501 /* set up signal handling */
502 signal(SIGINT, quit);
503 #ifdef SIGHUP
504 signal(SIGHUP, quit);
505 #endif
506 #ifdef SIGTERM
507 signal(SIGTERM, quit);
508 #endif
509 #ifdef SIGPIPE
510 signal(SIGPIPE, quit);
511 #endif
512 rtp = &rt0; /* start rtrace process(es) */
513 for (i = 0; i++ < np; ) {
514 errno = 0;
515 maxbytes = open_process(&rtp->pd, rtargv);
516 if (maxbytes == 0) {
517 eputs(rtargv[0]);
518 eputs(": command not found\n");
519 exit(1);
520 }
521 if (maxbytes < 0)
522 error(SYSTEM, "cannot start rtrace process");
523 if (maxbytes > treebufsiz)
524 treebufsiz = maxbytes;
525 rtp->raynum = 0;
526 rtp->bsiz = 0;
527 rtp->buf = NULL;
528 rtp->nbr = 0;
529 if (i == np) /* last process? */
530 break;
531 if (i == 1)
532 sleep(2); /* wait for persist file */
533 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
534 if (rtp->next == NULL)
535 error(SYSTEM, "out of memory in init");
536 rtp = rtp->next;
537 }
538 rtp->next = NULL; /* terminate list */
539 if (yres > 0) {
540 if (xres > 0)
541 raysleft = (unsigned long)xres*yres;
542 else
543 raysleft = yres;
544 } else
545 raysleft = 0;
546 if ((account = accumulate) > 0)
547 raysleft *= accumulate;
548 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
549 if (!recover)
550 return;
551 /* recover previous values */
552 if (accumulate <= 0)
553 reload_output();
554 else
555 recover_output(stdin);
556 }
557
558 /* grow modifier to accommodate more bins */
559 MODCONT *
560 growmodifier(MODCONT *mp, int nb)
561 {
562 if (nb <= mp->nbins)
563 return mp;
564 mp = (MODCONT *)realloc(mp, sizeof(MODCONT) + sizeof(DCOLOR)*(nb-1));
565 if (mp == NULL)
566 error(SYSTEM, "out of memory in growmodifier");
567 memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(nb-mp->nbins));
568 mp->nbins = nb;
569 return mp;
570 }
571
572 /* add modifier to our list to track */
573 MODCONT *
574 addmodifier(char *modn, char *outf, char *binv, int bincnt)
575 {
576 LUENT *lep = lu_find(&modconttab, modn);
577 MODCONT *mp;
578 int i;
579
580 if (lep->data != NULL) {
581 sprintf(errmsg, "duplicate modifier '%s'", modn);
582 error(USER, errmsg);
583 }
584 if (nmods >= MAXMODLIST)
585 error(INTERNAL, "too many modifiers");
586 modname[nmods++] = modn; /* XXX assumes static string */
587 lep->key = modn; /* XXX assumes static string */
588 mp = (MODCONT *)malloc(sizeof(MODCONT));
589 if (mp == NULL)
590 error(SYSTEM, "out of memory in addmodifier");
591 mp->outspec = outf; /* XXX assumes static string */
592 mp->modname = modn; /* XXX assumes static string */
593 if (binv == NULL)
594 binv = "0"; /* use single bin if unspecified */
595 mp->binv = eparse(binv);
596 if (mp->binv->type == NUM) { /* check value if constant */
597 bincnt = (int)(evalue(mp->binv) + 1.5);
598 if (bincnt != 1) {
599 sprintf(errmsg, "illegal non-zero constant for bin (%s)",
600 binv);
601 error(USER, errmsg);
602 }
603 }
604 mp->nbins = 1; /* initialize results holder */
605 setcolor(mp->cbin[0], 0., 0., 0.);
606 if (bincnt > 1)
607 mp = growmodifier(mp, bincnt);
608 lep->data = (char *)mp;
609 /* allocate output streams */
610 for (i = bincnt; i-- > 0; )
611 getostream(mp->outspec, mp->modname, i, 1);
612 return mp;
613 }
614
615 /* add modifiers from a file list */
616 void
617 addmodfile(char *fname, char *outf, char *binv, int bincnt)
618 {
619 char *mname[MAXMODLIST];
620 int i;
621 /* find the file & store strings */
622 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
623 sprintf(errmsg, "cannot find modifier file '%s'", fname);
624 error(SYSTEM, errmsg);
625 }
626 for (i = 0; mname[i]; i++) /* add each one */
627 addmodifier(mname[i], outf, binv, bincnt);
628 }
629
630 /* put string to stderr */
631 void
632 eputs(char *s)
633 {
634 static int midline = 0;
635
636 if (!*s) return;
637 if (!midline) {
638 fputs(progname, stderr);
639 fputs(": ", stderr);
640 }
641 fputs(s, stderr);
642 midline = s[strlen(s)-1] != '\n';
643 }
644
645 /* construct output file name and return flags whether modifier/bin present */
646 int
647 ofname(char *oname, const char *ospec, const char *mname, int bn)
648 {
649 const char *mnp = NULL;
650 const char *bnp = NULL;
651 const char *cp;
652
653 if (ospec == NULL)
654 return -1;
655 for (cp = ospec; *cp; cp++) /* check format position(s) */
656 if (*cp == '%') {
657 do
658 ++cp;
659 while (isdigit(*cp));
660 switch (*cp) {
661 case '%':
662 break;
663 case 's':
664 if (mnp != NULL)
665 return -1;
666 mnp = cp;
667 break;
668 case 'd':
669 case 'i':
670 case 'o':
671 case 'x':
672 case 'X':
673 if (bnp != NULL)
674 return -1;
675 bnp = cp;
676 break;
677 default:
678 return -1;
679 }
680 }
681 if (mnp != NULL) { /* create file name */
682 if (bnp != NULL) {
683 if (bnp > mnp)
684 sprintf(oname, ospec, mname, bn);
685 else
686 sprintf(oname, ospec, bn, mname);
687 return OF_MODIFIER|OF_BIN;
688 }
689 sprintf(oname, ospec, mname);
690 return OF_MODIFIER;
691 }
692 if (bnp != NULL) {
693 sprintf(oname, ospec, bn);
694 return OF_BIN;
695 }
696 strcpy(oname, ospec);
697 return 0;
698 }
699
700 /* write header to the given output stream */
701 void
702 printheader(FILE *fout, const char *info)
703 {
704 extern char VersionID[];
705 FILE *fin = fopen(octree, "r");
706
707 if (fin == NULL)
708 quit(1);
709 checkheader(fin, "ignore", fout); /* copy octree header */
710 fclose(fin);
711 printargs(gargc-1, gargv, fout); /* add our command */
712 fprintf(fout, "SOFTWARE= %s\n", VersionID);
713 fputnow(fout);
714 if (info != NULL) /* add extra info if given */
715 fputs(info, fout);
716 switch (outfmt) { /* add output format */
717 case 'a':
718 fputformat("ascii", fout);
719 break;
720 case 'f':
721 fputformat("float", fout);
722 break;
723 case 'd':
724 fputformat("double", fout);
725 break;
726 case 'c':
727 fputformat(COLRFMT, fout);
728 break;
729 }
730 fputc('\n', fout);
731 }
732
733 /* write resolution string to given output stream */
734 void
735 printresolu(FILE *fout, int xr, int yr)
736 {
737 if ((xr > 0) & (yr > 0)) /* resolution string */
738 fprtresolu(xr, yr, fout);
739 }
740
741 /* Get output stream pointer (open and write header if new and noopen==0) */
742 STREAMOUT *
743 getostream(const char *ospec, const char *mname, int bn, int noopen)
744 {
745 static const DCOLOR nocontrib = BLKCOLOR;
746 static STREAMOUT stdos;
747 int ofl;
748 char oname[1024];
749 LUENT *lep;
750 STREAMOUT *sop;
751
752 if (ospec == NULL) { /* use stdout? */
753 if (!noopen && !using_stdout) {
754 if (outfmt != 'a')
755 SET_FILE_BINARY(stdout);
756 if (header)
757 printheader(stdout, NULL);
758 printresolu(stdout, xres, yres);
759 if (waitflush > 0)
760 fflush(stdout);
761 stdos.xr = xres; stdos.yr = yres;
762 using_stdout = 1;
763 }
764 stdos.ofp = stdout;
765 stdos.reclen += noopen;
766 return &stdos;
767 }
768 ofl = ofname(oname, ospec, mname, bn); /* get output name */
769 if (ofl < 0) {
770 sprintf(errmsg, "bad output format '%s'", ospec);
771 error(USER, errmsg);
772 }
773 lep = lu_find(&ofiletab, oname); /* look it up */
774 if (lep->key == NULL) /* new entry */
775 lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
776 sop = (STREAMOUT *)lep->data;
777 if (sop == NULL) { /* allocate stream */
778 sop = (STREAMOUT *)malloc(sizeof(STREAMOUT));
779 if (sop == NULL)
780 error(SYSTEM, "out of memory in getostream");
781 sop->outpipe = oname[0] == '!';
782 sop->reclen = 0;
783 sop->ofp = NULL; /* open iff noopen==0 */
784 sop->xr = xres; sop->yr = yres;
785 lep->data = (char *)sop;
786 if (!sop->outpipe & !force_open & !recover &&
787 access(oname, F_OK) == 0) {
788 errno = EEXIST; /* file exists */
789 goto openerr;
790 }
791 }
792 if (!noopen && sop->ofp == NULL) { /* open output stream */
793 long i;
794 if (oname[0] == '!') /* output to command */
795 sop->ofp = popen(oname+1, "w");
796 else /* else open file */
797 sop->ofp = fopen(oname, "w");
798 if (sop->ofp == NULL)
799 goto openerr;
800 if (outfmt != 'a')
801 SET_FILE_BINARY(sop->ofp);
802 if (header) {
803 char info[512];
804 char *cp = info;
805 if (ofl & OF_MODIFIER || sop->reclen == 1) {
806 sprintf(cp, "MODIFIER=%s\n", mname);
807 while (*cp) ++cp;
808 }
809 if (ofl & OF_BIN) {
810 sprintf(cp, "BIN=%d\n", bn);
811 while (*cp) ++cp;
812 }
813 *cp = '\0';
814 printheader(sop->ofp, info);
815 }
816 if (accumulate > 0) { /* global resolution */
817 sop->xr = xres; sop->yr = yres;
818 }
819 printresolu(sop->ofp, sop->xr, sop->yr);
820 /* play catch-up */
821 for (i = accumulate > 0 ? lastdone/accumulate : 0; i--; ) {
822 int j = sop->reclen;
823 if (j <= 0) j = 1;
824 while (j--)
825 put_contrib(nocontrib, sop->ofp);
826 if (outfmt == 'a')
827 putc('\n', sop->ofp);
828 }
829 if (waitflush > 0)
830 fflush(sop->ofp);
831 }
832 sop->reclen += noopen; /* add to length if noopen */
833 return sop; /* return output stream */
834 openerr:
835 sprintf(errmsg, "cannot open '%s' for writing", oname);
836 error(SYSTEM, errmsg);
837 return NULL; /* pro forma return */
838 }
839
840 /* read input ray into buffer */
841 int
842 getinp(char *buf, FILE *fp)
843 {
844 double dv[3], *dvp;
845 float *fvp;
846 char *cp;
847 int i;
848
849 switch (inpfmt) {
850 case 'a':
851 cp = buf; /* make sure we get 6 floats */
852 for (i = 0; i < 6; i++) {
853 if (fgetword(cp, buf+127-cp, fp) == NULL)
854 return -1;
855 if (i >= 3)
856 dv[i-3] = atof(cp);
857 if ((cp = fskip(cp)) == NULL || *cp)
858 return -1;
859 *cp++ = ' ';
860 }
861 getc(fp); /* get/put eol */
862 *cp-- = '\0'; *cp = '\n';
863 if (DOT(dv,dv) <= FTINY*FTINY)
864 return 0; /* dummy ray */
865 return strlen(buf);
866 case 'f':
867 if (fread(buf, sizeof(float), 6, fp) < 6)
868 return -1;
869 fvp = (float *)buf + 3;
870 if (DOT(fvp,fvp) <= FTINY*FTINY)
871 return 0; /* dummy ray */
872 return sizeof(float)*6;
873 case 'd':
874 if (fread(buf, sizeof(double), 6, fp) < 6)
875 return -1;
876 dvp = (double *)buf + 3;
877 if (DOT(dvp,dvp) <= FTINY*FTINY)
878 return 0; /* dummy ray */
879 return sizeof(double)*6;
880 }
881 error(INTERNAL, "botched input format");
882 return -1; /* pro forma return */
883 }
884
885 static float rparams[9]; /* traced ray parameters */
886
887 /* return channel (ray) value */
888 double
889 chanvalue(int n)
890 {
891 if (--n < 0 || n >= 6)
892 error(USER, "illegal channel number ($N)");
893 return rparams[n+3];
894 }
895
896 /* add current ray contribution to the appropriate modifier bin */
897 void
898 add_contrib(const char *modn)
899 {
900 LUENT *le = lu_find(&modconttab, modn);
901 MODCONT *mp = (MODCONT *)le->data;
902 int bn;
903
904 if (mp == NULL) {
905 sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
906 error(USER, errmsg);
907 }
908 eclock++; /* get bin number */
909 bn = (int)(evalue(mp->binv) + .5);
910 if (bn <= 0)
911 bn = 0;
912 else if (bn >= mp->nbins) /* new bin */
913 le->data = (char *)(mp = growmodifier(mp, bn+1));
914 addcolor(mp->cbin[bn], rparams);
915 }
916
917 /* output newline to ASCII file and/or flush as requested */
918 static int
919 puteol(const LUENT *e, void *p)
920 {
921 STREAMOUT *sop = (STREAMOUT *)e->data;
922
923 if (outfmt == 'a')
924 putc('\n', sop->ofp);
925 if (!waitflush)
926 fflush(sop->ofp);
927 if (ferror(sop->ofp)) {
928 sprintf(errmsg, "write error on file '%s'", e->key);
929 error(SYSTEM, errmsg);
930 }
931 return 0;
932 }
933
934 /* put out ray contribution to file */
935 void
936 put_contrib(const DCOLOR cnt, FILE *fout)
937 {
938 float fv[3];
939 COLR cv;
940
941 switch (outfmt) {
942 case 'a':
943 fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
944 break;
945 case 'f':
946 copycolor(fv, cnt);
947 fwrite(fv, sizeof(float), 3, fout);
948 break;
949 case 'd':
950 fwrite(cnt, sizeof(double), 3, fout);
951 break;
952 case 'c':
953 setcolr(cv, cnt[0], cnt[1], cnt[2]);
954 fwrite(cv, sizeof(cv), 1, fout);
955 break;
956 default:
957 error(INTERNAL, "botched output format");
958 }
959 }
960
961 /* output ray tallies and clear for next accumulation */
962 void
963 done_contrib(int navg)
964 {
965 double sf = 1.;
966 int i, j;
967 MODCONT *mp;
968 STREAMOUT *sop;
969 /* set average scaling */
970 if (navg > 1)
971 sf = 1. / (double)navg;
972 /* output modifiers in order */
973 for (i = 0; i < nmods; i++) {
974 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
975 if (navg > 1) /* average scaling */
976 for (j = mp->nbins; j--; )
977 scalecolor(mp->cbin[j], sf);
978 sop = getostream(mp->outspec, mp->modname, 0,0);
979 put_contrib(mp->cbin[0], sop->ofp);
980 if (mp->nbins > 3 && /* minor optimization */
981 sop == getostream(mp->outspec, mp->modname, 1,0))
982 for (j = 1; j < mp->nbins; j++)
983 put_contrib(mp->cbin[j], sop->ofp);
984 else
985 for (j = 1; j < mp->nbins; j++)
986 put_contrib(mp->cbin[j],
987 getostream(mp->outspec,mp->modname,j,0)->ofp);
988 /* clear for next time */
989 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
990 }
991 --waitflush; /* terminate records */
992 lu_doall(&ofiletab, puteol, NULL);
993 if (using_stdout & (outfmt == 'a'))
994 putc('\n', stdout);
995 if (!waitflush) {
996 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
997 if (using_stdout)
998 fflush(stdout);
999 }
1000 }
1001
1002 /* queue completed ray tree produced by rtrace process */
1003 void
1004 queue_raytree(struct rtproc *rtp)
1005 {
1006 struct rtproc *rtu, *rtl = NULL;
1007 /* insert following ray order */
1008 for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
1009 if (rtp->raynum < rtu->raynum)
1010 break;
1011 rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
1012 if (rtu == NULL)
1013 error(SYSTEM, "out of memory in queue_raytree");
1014 *rtu = *rtp;
1015 if (rtl == NULL) {
1016 rtu->next = rt_unproc;
1017 rt_unproc = rtu;
1018 } else {
1019 rtu->next = rtl->next;
1020 rtl->next = rtu;
1021 }
1022 rtp->raynum = 0; /* clear path for next ray tree */
1023 rtp->bsiz = 0;
1024 rtp->buf = NULL;
1025 rtp->nbr = 0;
1026 }
1027
1028 /* process completed ray trees from our queue */
1029 void
1030 process_queue(void)
1031 {
1032 char modname[128];
1033 /* ray-ordered queue */
1034 while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
1035 struct rtproc *rtp = rt_unproc;
1036 int n = rtp->nbr;
1037 const char *cp = rtp->buf;
1038 while (n > 0) { /* process rays */
1039 register char *mnp = modname;
1040 /* skip leading tabs */
1041 while (n > 0 && *cp == '\t') {
1042 cp++; n--;
1043 }
1044 if (!n || !(isalpha(*cp) | (*cp == '_')))
1045 error(USER, "bad modifier name from rtrace");
1046 /* get modifier name */
1047 while (n > 1 && *cp != '\t') {
1048 if (mnp - modname >= sizeof(modname)-2)
1049 error(INTERNAL, "modifier name too long");
1050 *mnp++ = *cp++; n--;
1051 }
1052 *mnp = '\0';
1053 cp++; n--; /* eat following tab */
1054 if (n < (int)(sizeof(float)*9))
1055 error(USER, "incomplete ray value from rtrace");
1056 /* add ray contribution */
1057 memcpy(rparams, cp, sizeof(float)*9);
1058 cp += sizeof(float)*9; n -= sizeof(float)*9;
1059 add_contrib(modname);
1060 }
1061 /* time to produce record? */
1062 if (account > 0 && !--account)
1063 done_contrib(account = accumulate);
1064 lastdone = rtp->raynum;
1065 if (rtp->buf != NULL) /* free up buffer space */
1066 free(rtp->buf);
1067 rt_unproc = rtp->next;
1068 free(rtp); /* done with this ray tree */
1069 }
1070 }
1071
1072 /* wait for rtrace process to finish with ray tree */
1073 struct rtproc *
1074 wait_rproc(void)
1075 {
1076 struct rtproc *rtfree = NULL;
1077 fd_set readset, errset;
1078 ssize_t nr;
1079 struct rtproc *rt;
1080 int n;
1081
1082 do {
1083 nr = 0; /* prepare select call */
1084 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
1085 for (rt = &rt0; rt != NULL; rt = rt->next) {
1086 if (rt->raynum) {
1087 FD_SET(rt->pd.r, &readset);
1088 ++nr;
1089 }
1090 FD_SET(rt->pd.r, &errset);
1091 if (rt->pd.r >= n)
1092 n = rt->pd.r + 1;
1093 }
1094 if (!nr) /* no rays pending */
1095 break;
1096 if (nr > 1) { /* call select for multiple proc's */
1097 errno = 0;
1098 if (select(n, &readset, NULL, &errset, NULL) < 0)
1099 error(SYSTEM, "select call error in wait_rproc()");
1100 } else
1101 FD_ZERO(&errset);
1102 nr = 0;
1103 for (rt = &rt0; rt != NULL; rt = rt->next) {
1104 if (!FD_ISSET(rt->pd.r, &readset) &&
1105 !FD_ISSET(rt->pd.r, &errset))
1106 continue;
1107 if (rt->buf == NULL) {
1108 rt->bsiz = treebufsiz;
1109 rt->buf = (char *)malloc(treebufsiz);
1110 } else if (rt->nbr + BUFSIZ > rt->bsiz) {
1111 if (rt->bsiz + BUFSIZ <= treebufsiz)
1112 rt->bsiz = treebufsiz;
1113 else
1114 treebufsiz = rt->bsiz += BUFSIZ;
1115 rt->buf = (char *)realloc(rt->buf, rt->bsiz);
1116 }
1117 if (rt->buf == NULL)
1118 error(SYSTEM, "out of memory in wait_rproc");
1119 nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
1120 if (nr <= 0)
1121 error(USER, "rtrace process died");
1122 rt->nbr += nr; /* advance & check */
1123 if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4,
1124 "~\t~\t", 4)) {
1125 rt->nbr -= 4; /* elide terminator */
1126 queue_raytree(rt);
1127 rtfree = rt; /* ready for next ray */
1128 }
1129 }
1130 } while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
1131 return rtfree;
1132 }
1133
1134 /* return next available rtrace process */
1135 struct rtproc *
1136 get_rproc(void)
1137 {
1138 struct rtproc *rtp;
1139 /* check for idle rtrace */
1140 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
1141 if (!rtp->raynum)
1142 return rtp;
1143 return wait_rproc(); /* need to wait for one */
1144 }
1145
1146 /* trace ray contributions (main loop) */
1147 void
1148 trace_contribs(FILE *fin)
1149 {
1150 static int ignore_warning_given = 0;
1151 char inpbuf[128];
1152 int iblen;
1153 struct rtproc *rtp;
1154 /* loop over input */
1155 while ((iblen = getinp(inpbuf, fin)) >= 0) {
1156 if (!iblen && accumulate != 1) {
1157 if (!ignore_warning_given++)
1158 error(WARNING,
1159 "dummy ray(s) ignored during accumulation\n");
1160 continue;
1161 }
1162 if (!iblen || /* need flush/reset? */
1163 queue_length() > 10*nrtprocs() ||
1164 lastray+1 < lastray) {
1165 while (wait_rproc() != NULL)
1166 process_queue();
1167 if (lastray+1 < lastray)
1168 lastdone = lastray = 0;
1169 }
1170 rtp = get_rproc(); /* get avail. rtrace process */
1171 rtp->raynum = ++lastray; /* assign ray */
1172 if (iblen) { /* trace ray if valid */
1173 writebuf(rtp->pd.w, inpbuf, iblen);
1174 } else { /* else bypass dummy ray */
1175 queue_raytree(rtp); /* queue empty ray/record */
1176 if ((yres <= 0) | (xres <= 0))
1177 waitflush = 1; /* flush right after */
1178 }
1179 process_queue(); /* catch up with results */
1180 if (raysleft && !--raysleft)
1181 break; /* preemptive EOI */
1182 }
1183 while (wait_rproc() != NULL) /* process outstanding rays */
1184 process_queue();
1185 if (accumulate <= 0)
1186 done_contrib(0); /* output tallies */
1187 else if (account < accumulate) {
1188 error(WARNING, "partial accumulation in final record");
1189 done_contrib(accumulate - account);
1190 }
1191 if (raysleft)
1192 error(USER, "unexpected EOF on input");
1193 lu_done(&ofiletab); /* close output files */
1194 }
1195
1196 /* get ray contribution from previous file */
1197 static int
1198 get_contrib(DCOLOR cnt, FILE *finp)
1199 {
1200 COLOR fv;
1201 COLR cv;
1202
1203 switch (outfmt) {
1204 case 'a':
1205 return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3);
1206 case 'f':
1207 if (fread(fv, sizeof(fv[0]), 3, finp) != 3)
1208 return(0);
1209 copycolor(cnt, fv);
1210 return(1);
1211 case 'd':
1212 return(fread(cnt, sizeof(cnt[0]), 3, finp) == 3);
1213 case 'c':
1214 if (fread(cv, sizeof(cv), 1, finp) != 1)
1215 return(0);
1216 colr_color(fv, cv);
1217 copycolor(cnt, fv);
1218 return(1);
1219 default:
1220 error(INTERNAL, "botched output format");
1221 }
1222 return(0); /* pro forma return */
1223 }
1224
1225 /* close output file opened for input */
1226 static int
1227 myclose(const LUENT *e, void *p)
1228 {
1229 STREAMOUT *sop = (STREAMOUT *)e->data;
1230
1231 if (sop->ofp == NULL)
1232 return(0);
1233 fclose(sop->ofp);
1234 sop->ofp = NULL;
1235 return(0);
1236 }
1237
1238 /* load previously accumulated values */
1239 void
1240 reload_output(void)
1241 {
1242 int i, j;
1243 MODCONT *mp;
1244 int ofl;
1245 char oname[1024];
1246 char *fmode = "rb";
1247 char *outvfmt;
1248 LUENT *ment, *oent;
1249 int xr, yr;
1250 STREAMOUT sout;
1251 DCOLOR rgbv;
1252
1253 switch (outfmt) {
1254 case 'a':
1255 outvfmt = "ascii";
1256 fmode = "r";
1257 break;
1258 case 'f':
1259 outvfmt = "float";
1260 break;
1261 case 'd':
1262 outvfmt = "double";
1263 break;
1264 case 'c':
1265 outvfmt = COLRFMT;
1266 break;
1267 default:
1268 error(INTERNAL, "botched output format");
1269 return;
1270 }
1271 /* reload modifier values */
1272 for (i = 0; i < nmods; i++) {
1273 ment = lu_find(&modconttab,modname[i]);
1274 mp = (MODCONT *)ment->data;
1275 if (mp->outspec == NULL)
1276 error(USER, "cannot reload from stdout");
1277 if (mp->outspec[0] == '!')
1278 error(USER, "cannot reload from command");
1279 for (j = 0; ; j++) { /* load each modifier bin */
1280 ofl = ofname(oname, mp->outspec, mp->modname, j);
1281 if (ofl < 0)
1282 error(USER, "bad output file specification");
1283 oent = lu_find(&ofiletab, oname);
1284 if (oent->data != NULL) {
1285 sout = *(STREAMOUT *)oent->data;
1286 } else {
1287 sout.reclen = 0;
1288 sout.outpipe = 0;
1289 sout.xr = xres; sout.yr = yres;
1290 sout.ofp = NULL;
1291 }
1292 if (sout.ofp == NULL) { /* open output as input */
1293 sout.ofp = fopen(oname, fmode);
1294 if (sout.ofp == NULL) {
1295 if (j)
1296 break; /* assume end of modifier */
1297 sprintf(errmsg, "missing reload file '%s'",
1298 oname);
1299 error(WARNING, errmsg);
1300 break;
1301 }
1302 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1303 sprintf(errmsg, "format mismatch for '%s'",
1304 oname);
1305 error(USER, errmsg);
1306 }
1307 if ((sout.xr > 0) & (sout.yr > 0) &&
1308 (!fscnresolu(&xr, &yr, sout.ofp) ||
1309 (xr != sout.xr) |
1310 (yr != sout.yr))) {
1311 sprintf(errmsg, "resolution mismatch for '%s'",
1312 oname);
1313 error(USER, errmsg);
1314 }
1315 }
1316 /* read in RGB value */
1317 if (!get_contrib(rgbv, sout.ofp)) {
1318 if (!j) {
1319 fclose(sout.ofp);
1320 break; /* ignore empty file */
1321 }
1322 if (j < mp->nbins) {
1323 sprintf(errmsg, "missing data in '%s'",
1324 oname);
1325 error(USER, errmsg);
1326 }
1327 break;
1328 }
1329 if (j >= mp->nbins) /* grow modifier size */
1330 ment->data = (char *)(mp = growmodifier(mp, j+1));
1331 copycolor(mp->cbin[j], rgbv);
1332 if (oent->key == NULL) /* new file entry */
1333 oent->key = strcpy((char *)
1334 malloc(strlen(oname)+1), oname);
1335 if (oent->data == NULL)
1336 oent->data = (char *)malloc(sizeof(STREAMOUT));
1337 *(STREAMOUT *)oent->data = sout;
1338 }
1339 }
1340 lu_doall(&ofiletab, myclose, NULL); /* close all files */
1341 }
1342
1343 /* seek on the given output file */
1344 static int
1345 myseeko(const LUENT *e, void *p)
1346 {
1347 STREAMOUT *sop = (STREAMOUT *)e->data;
1348 off_t nbytes = *(off_t *)p;
1349
1350 if (sop->reclen > 1)
1351 nbytes = nbytes * sop->reclen;
1352 if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) {
1353 sprintf(errmsg, "seek error on file '%s'", e->key);
1354 error(SYSTEM, errmsg);
1355 }
1356 return 0;
1357 }
1358
1359 /* recover output if possible */
1360 void
1361 recover_output(FILE *fin)
1362 {
1363 off_t lastout = -1;
1364 int outvsiz, recsiz;
1365 char *outvfmt;
1366 int i, j;
1367 MODCONT *mp;
1368 int ofl;
1369 char oname[1024];
1370 LUENT *ment, *oent;
1371 STREAMOUT sout;
1372 off_t nvals;
1373 int xr, yr;
1374
1375 switch (outfmt) {
1376 case 'a':
1377 error(USER, "cannot recover ASCII output");
1378 return;
1379 case 'f':
1380 outvsiz = sizeof(float)*3;
1381 outvfmt = "float";
1382 break;
1383 case 'd':
1384 outvsiz = sizeof(double)*3;
1385 outvfmt = "double";
1386 break;
1387 case 'c':
1388 outvsiz = sizeof(COLR);
1389 outvfmt = COLRFMT;
1390 break;
1391 default:
1392 error(INTERNAL, "botched output format");
1393 return;
1394 }
1395 /* check modifier outputs */
1396 for (i = 0; i < nmods; i++) {
1397 ment = lu_find(&modconttab,modname[i]);
1398 mp = (MODCONT *)ment->data;
1399 if (mp->outspec == NULL)
1400 error(USER, "cannot recover from stdout");
1401 if (mp->outspec[0] == '!')
1402 error(USER, "cannot recover from command");
1403 for (j = 0; ; j++) { /* check each bin's file */
1404 ofl = ofname(oname, mp->outspec, mp->modname, j);
1405 if (ofl < 0)
1406 error(USER, "bad output file specification");
1407 oent = lu_find(&ofiletab, oname);
1408 if (oent->data != NULL) {
1409 sout = *(STREAMOUT *)oent->data;
1410 } else {
1411 sout.reclen = 0;
1412 sout.outpipe = 0;
1413 sout.ofp = NULL;
1414 }
1415 if (sout.ofp != NULL) { /* already open? */
1416 if (ofl & OF_BIN)
1417 continue;
1418 break;
1419 }
1420 /* open output */
1421 sout.ofp = fopen(oname, "rb+");
1422 if (sout.ofp == NULL) {
1423 if (j)
1424 break; /* assume end of modifier */
1425 sprintf(errmsg, "missing recover file '%s'",
1426 oname);
1427 error(WARNING, errmsg);
1428 break;
1429 }
1430 nvals = lseek(fileno(sout.ofp), 0, SEEK_END);
1431 if (nvals <= 0) {
1432 lastout = 0; /* empty output, quit here */
1433 fclose(sout.ofp);
1434 break;
1435 }
1436 if (!sout.reclen) {
1437 if (!(ofl & OF_BIN)) {
1438 sprintf(errmsg,
1439 "need -bn to recover file '%s'",
1440 oname);
1441 error(USER, errmsg);
1442 }
1443 recsiz = outvsiz;
1444 } else
1445 recsiz = outvsiz * sout.reclen;
1446
1447 lseek(fileno(sout.ofp), 0, SEEK_SET);
1448 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1449 sprintf(errmsg, "format mismatch for '%s'",
1450 oname);
1451 error(USER, errmsg);
1452 }
1453 sout.xr = xres; sout.yr = yres;
1454 if ((sout.xr > 0) & (sout.yr > 0) &&
1455 (!fscnresolu(&xr, &yr, sout.ofp) ||
1456 (xr != sout.xr) |
1457 (yr != sout.yr))) {
1458 sprintf(errmsg, "resolution mismatch for '%s'",
1459 oname);
1460 error(USER, errmsg);
1461 }
1462 nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz;
1463 if ((lastout < 0) | (nvals < lastout))
1464 lastout = nvals;
1465 if (oent->key == NULL) /* new entry */
1466 oent->key = strcpy((char *)
1467 malloc(strlen(oname)+1), oname);
1468 if (oent->data == NULL)
1469 oent->data = (char *)malloc(sizeof(STREAMOUT));
1470 *(STREAMOUT *)oent->data = sout;
1471 if (!(ofl & OF_BIN))
1472 break; /* no bin separation */
1473 }
1474 if (!lastout) { /* empty output */
1475 error(WARNING, "no previous data to recover");
1476 lu_done(&ofiletab); /* reclose all outputs */
1477 return;
1478 }
1479 if (j > mp->nbins) /* reallocate modifier bins */
1480 ment->data = (char *)(mp = growmodifier(mp, j));
1481 }
1482 if (lastout < 0) {
1483 error(WARNING, "no output files to recover");
1484 return;
1485 }
1486 if (raysleft && lastout >= raysleft/accumulate) {
1487 error(WARNING, "output appears to be complete");
1488 /* XXX should read & discard input? */
1489 quit(0);
1490 }
1491 /* seek on all files */
1492 nvals = lastout * outvsiz;
1493 lu_doall(&ofiletab, myseeko, &nvals);
1494 /* skip repeated input */
1495 for (nvals = 0; nvals < lastout; nvals++)
1496 if (getinp(oname, fin) < 0)
1497 error(USER, "unexpected EOF on input");
1498 lastray = lastdone = (unsigned long)lastout * accumulate;
1499 if (raysleft)
1500 raysleft -= lastray;
1501 }
