root/radiance/ray/src/util/rtcontrib.c
Revision: 1.28
Committed: Wed Sep 21 17:17:24 2005 UTC (19 years, 9 months ago) by greg
Changes since 1.27: +3 -3 lines
2 static const char RCSid[] = "$Id: rtcontrib.c,v 1.27 2005/09/20 17:05:11 greg Exp $";
5 * Gather rtrace output to compute contributions from particular sources
6 */
7
8 #include "standard.h"
9 #include <ctype.h>
10 #include <signal.h>
11 #include "platform.h"
12 #include "rtprocess.h"
13 #include "selcall.h"
14 #include "color.h"
15 #include "resolu.h"
16 #include "lookup.h"
17 #include "calcomp.h"
18
19 #ifndef MAXMODLIST
20 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
21 #endif
22
23 int treebufsiz = BUFSIZ; /* current tree buffer size */
24
25 typedef double DCOLOR[3]; /* double-precision color */
26
27 /*
28 * The modcont structure is used to accumulate ray contributions
29 * for a particular modifier, which may be subdivided into bins
30 * if binv is non-NULL. If outspec contains a %s in it, this will
31 * be replaced with the modifier name. If outspec contains a %d in it,
32 * this will be used to create one output file per bin, otherwise all bins
33 * will be written to the same file, in order. If the global outfmt
34 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
35 * and the file will conform to a RADIANCE image if xres & yres are set.
36 */
37 typedef struct {
38 const char *outspec; /* output file specification */
39 const char *modname; /* modifier name */
40 EPNODE *binv; /* bin value expression */
41 int nbins; /* number of accumulation bins */
42 DCOLOR cbin[1]; /* contribution bins (extends struct) */
43 } MODCONT; /* modifier contribution */
44
45 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
46
47 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
48
49 /* close output stream */
50 static void closefile(void *p) { fclose((FILE *)p); }
51
52 LUTAB ofiletab = LU_SINIT(free,closefile); /* output file table */
53
54 #define OF_MODIFIER 01
55 #define OF_BIN 02
56
57 FILE *getofile(const char *ospec, const char *mname, int bn);
58 int ofname(char *oname, const char *ospec, const char *mname, int bn);
59 void printheader(FILE *fout, const char *info);
60
61 /*
62 * The rcont structure is used to manage i/o with a particular
63 * rtrace child process. Input is passed unchanged from stdin,
64 * and output is processed in input order and accumulated according
65 * to the corresponding modifier and bin number.
66 */
67 struct rtproc {
68 struct rtproc *next; /* next in list of processes */
69 SUBPROC pd; /* rtrace pipe descriptors */
70 unsigned long raynum; /* ray number for this tree */
71 int bsiz; /* ray tree buffer length */
72 char *buf; /* ray tree buffer */
73 int nbr; /* number of bytes from rtrace */
74 }; /* rtrace process buffer */
75
76 /* rtrace command and defaults */
77 char *rtargv[256+2*MAXMODLIST] = { "rtrace",
78 "-dj", ".5", "-dr", "3",
79 "-ab", "1", "-ad", "128", };
80 int rtargc = 9;
81 /* overriding rtrace options */
82 char *myrtopts[] = { "-o~~TmWdp", "-h-", "-x", "1", "-y", "0",
83 "-dt", "0", "-as", "0", "-aa", "0", NULL };
84
85 struct rtproc rt0; /* head of rtrace process list */
86
87 struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
88
89 char persistfn[] = "pfXXXXXX"; /* persist file name */
90
91 int gargc; /* global argc */
92 char **gargv; /* global argv */
93 #define progname gargv[0]
94
95 char *octree; /* global octree argument */
96
97 int inpfmt = 'a'; /* input format */
98 int outfmt = 'a'; /* output format */
99
100 int header = 1; /* output header? */
101 int xres = 0; /* horiz. output resolution */
102 int yres = 0; /* vert. output resolution */
103
104 unsigned long raysleft; /* number of rays left to trace */
105 long waitflush; /* how long until next flush */
106
107 unsigned long lastray = 0; /* last ray number sent */
108 unsigned long lastdone = 0; /* last ray processed */
109
110 int using_stdout = 0; /* are we using stdout? */
111
112 const char *modname[MAXMODLIST]; /* ordered modifier name list */
113 int nmods = 0; /* number of modifiers */
114
115 MODCONT *addmodifier(char *modn, char *outf, char *binv);
116 void addmodfile(char *fname, char *outf, char *binv);
117
118 void init(int np);
119 int done_rprocs(struct rtproc *rtp);
120 void recover_output(FILE *fin);
121 void trace_contribs(FILE *fin);
122 struct rtproc *wait_rproc(void);
123 struct rtproc *get_rproc(void);
124 void queue_raytree(struct rtproc *rtp);
125 void process_queue(void);
126
127 void put_contrib(const DCOLOR cnt, FILE *fout);
128 void add_contrib(const char *modn);
129 void done_contrib(void);
130
131 /* set input/output format */
132 static void
133 setformat(const char *fmt)
134 {
135 switch (fmt[0]) {
136 case 'f':
137 case 'd':
138 SET_FILE_BINARY(stdin);
139 /* fall through */
140 case 'a':
141 inpfmt = fmt[0];
142 break;
143 default:
144 goto fmterr;
145 }
146 switch (fmt[1]) {
147 case '\0':
148 outfmt = inpfmt;
149 return;
150 case 'a':
151 case 'f':
152 case 'd':
153 case 'c':
154 outfmt = fmt[1];
155 break;
156 default:
157 goto fmterr;
158 }
159 if (!fmt[2])
160 return;
161 fmterr:
162 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
163 error(USER, errmsg);
164 }
165
166 /* gather rays from rtrace and output contributions */
167 int
168 main(int argc, char *argv[])
169 {
170 int nprocs = 1;
171 int recover = 0;
172 char *curout = NULL;
173 char *binval = NULL;
174 char fmt[8];
175 int i, j;
176 /* need at least one argument */
177 if (argc < 2) {
178 fprintf(stderr,
179 "Usage: %s [-n nprocs][-r][-e expr][-f source][-o ospec][-b binv] {-m mod | -M file} [rtrace options] octree\n",
180 argv[0]);
181 exit(1);
182 }
183 /* global program name */
184 gargv = argv;
185 /* initialize calcomp routines */
186 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
187 esupport &= ~(E_OUTCHAN);
188 varset("PI", ':', PI);
189 /* get our options */
190 for (i = 1; i < argc-1; i++) {
191 /* expand arguments */
192 while ((j = expandarg(&argc, &argv, i)) > 0)
193 ;
194 if (j < 0) {
195 fprintf(stderr, "%s: cannot expand '%s'",
196 argv[0], argv[i]);
197 exit(1);
198 }
199 if (argv[i][0] == '-')
200 switch (argv[i][1]) {
201 case 'r': /* recover output */
202 if (argv[i][2]) break;
203 recover++;
204 continue;
205 case 'n': /* number of processes */
206 if (argv[i][2] || i >= argc-2) break;
207 nprocs = atoi(argv[++i]);
208 if (nprocs <= 0)
209 error(USER, "illegal number of processes");
210 continue;
211 case 'h': /* output header? */
212 switch (argv[i][2]) {
213 case '\0':
214 header = !header;
215 continue;
216 case '+': case '1':
217 case 'T': case 't':
218 case 'Y': case 'y':
219 header = 1;
220 continue;
221 case '-': case '0':
222 case 'F': case 'f':
223 case 'N': case 'n':
224 header = 0;
225 continue;
226 }
227 break;
228 case 'f': /* file or i/o format */
229 if (!argv[i][2]) {
230 char *fpath;
231 if (i >= argc-2) break;
232 fpath = getpath(argv[++i],
233 getrlibpath(), R_OK);
234 if (fpath == NULL) {
235 sprintf(errmsg,
236 "cannot find file '%s'",
237 argv[i]);
238 error(USER, errmsg);
239 }
240 fcompile(fpath);
241 continue;
242 }
243 setformat(argv[i]+2);
244 continue;
245 case 'e': /* expression */
246 if (argv[i][2] || i >= argc-2) break;
247 scompile(argv[++i], NULL, 0);
248 continue;
249 case 'o': /* output file spec. */
250 if (argv[i][2] || i >= argc-2) break;
251 curout = argv[++i];
252 continue;
253 case 'x': /* horiz. output resolution */
254 if (argv[i][2] || i >= argc-2) break;
255 xres = atoi(argv[++i]);
256 continue;
257 case 'y': /* vert. output resolution */
258 if (argv[i][2] || i >= argc-2) break;
259 yres = atoi(argv[++i]);
260 continue;
261 case 'b': /* bin expression */
262 if (argv[i][2] || i >= argc-2) break;
263 binval = argv[++i];
264 continue;
265 case 'm': /* modifier name */
266 if (argv[i][2] || i >= argc-2) break;
267 rtargv[rtargc++] = "-ti";
268 rtargv[rtargc++] = argv[++i];
269 addmodifier(argv[i], curout, binval);
270 continue;
271 case 'M': /* modifier file */
272 if (argv[i][2] || i >= argc-2) break;
273 rtargv[rtargc++] = "-tI";
274 rtargv[rtargc++] = argv[++i];
275 addmodfile(argv[i], curout, binval);
276 continue;
277 }
278 rtargv[rtargc++] = argv[i]; /* assume rtrace option */
279 }
280 /* set global argument list */
281 gargc = argc; gargv = argv;
282 /* add "mandatory" rtrace settings */
283 for (j = 0; myrtopts[j] != NULL; j++)
284 rtargv[rtargc++] = myrtopts[j];
285 /* just asking for defaults? */
286 if (!strcmp(argv[i], "-defaults")) {
287 char sxres[16], syres[16];
288 char *rtpath;
289 printf("-n %-2d\t\t\t\t# number of processes\n", nprocs);
290 fflush(stdout); /* report OUR options */
291 rtargv[rtargc++] = header ? "-h+" : "-h-";
292 sprintf(fmt, "-f%c%c", inpfmt, outfmt);
293 rtargv[rtargc++] = fmt;
294 rtargv[rtargc++] = "-x";
295 sprintf(sxres, "%d", xres);
296 rtargv[rtargc++] = sxres;
297 rtargv[rtargc++] = "-y";
298 sprintf(syres, "%d", yres);
299 rtargv[rtargc++] = syres;
300 rtargv[rtargc++] = "-oTW";
301 rtargv[rtargc++] = "-defaults";
302 rtargv[rtargc] = NULL;
303 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
304 if (rtpath == NULL) {
305 eputs(rtargv[0]);
306 eputs(": command not found\n");
307 exit(1);
308 }
309 execv(rtpath, rtargv);
310 perror(rtpath); /* execv() should not return */
311 exit(1);
312 }
313 if (nprocs > 1) { /* add persist file if parallel */
314 rtargv[rtargc++] = "-PP";
315 rtargv[rtargc++] = mktemp(persistfn);
316 }
317 /* add format string */
318 sprintf(fmt, "-f%cf", inpfmt);
319 rtargv[rtargc++] = fmt;
320 /* octree argument is last */
321 if (i <= 0 || i != argc-1 || argv[i][0] == '-')
322 error(USER, "missing octree argument");
323 rtargv[rtargc++] = octree = argv[i];
324 rtargv[rtargc] = NULL;
325 /* start rtrace */
326 init(nprocs);
327 if (recover) /* perform recovery if requested */
328 recover_output(stdin);
329 trace_contribs(stdin); /* compute contributions */
330 quit(0);
331 }
332
333 #ifndef SIGALRM
334 #define SIGALRM SIGTERM
335 #endif
336 /* kill persistent rtrace process */
337 static void
338 killpersist(void)
339 {
340 FILE *fp = fopen(persistfn, "r");
341 RT_PID pid;
342
343 if (fp == NULL)
344 return;
345 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
346 unlink(persistfn);
347 fclose(fp);
348 }
349
350 /* close rtrace processes and clean up */
351 int
352 done_rprocs(struct rtproc *rtp)
353 {
354 int st0, st1 = 0;
355
356 if (rtp->next != NULL) { /* close last opened first! */
357 st1 = done_rprocs(rtp->next);
358 free((void *)rtp->next);
359 rtp->next = NULL;
360 }
361 st0 = close_process(&rtp->pd);
362 if (st0 < 0)
363 error(WARNING, "unknown return status from rtrace process");
364 else if (st0 > 0)
365 return(st0);
366 return(st1);
367 }
368
369 /* exit with status */
370 void
371 quit(int status)
372 {
373 int rtstat;
374
375 if (rt0.next != NULL) /* terminate persistent rtrace */
376 killpersist();
377 /* clean up rtrace process(es) */
378 rtstat = done_rprocs(&rt0);
379 if (status == 0)
380 status = rtstat;
381 exit(status); /* flushes all output streams */
382 }
383
384 /* start rtrace processes and initialize */
385 void
386 init(int np)
387 {
388 struct rtproc *rtp;
389 int i;
390 int maxbytes;
391 /* make sure we have something to do */
392 if (!nmods)
393 error(USER, "No modifiers specified");
394 /* assign ray variables */
395 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
396 scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
397 /* set up signal handling */
398 signal(SIGINT, quit);
399 #ifdef SIGHUP
400 signal(SIGHUP, quit);
401 #endif
402 #ifdef SIGTERM
403 signal(SIGTERM, quit);
404 #endif
405 #ifdef SIGPIPE
406 signal(SIGPIPE, quit);
407 #endif
408 rtp = &rt0; /* start rtrace process(es) */
409 for (i = 0; i++ < np; ) {
410 errno = 0;
411 maxbytes = open_process(&rtp->pd, rtargv);
412 if (maxbytes == 0) {
413 eputs(rtargv[0]);
414 eputs(": command not found\n");
415 exit(1);
416 }
417 if (maxbytes < 0)
418 error(SYSTEM, "cannot start rtrace process");
419 if (maxbytes > treebufsiz)
420 treebufsiz = maxbytes;
421 rtp->raynum = 0;
422 rtp->bsiz = 0;
423 rtp->buf = NULL;
424 rtp->nbr = 0;
425 if (i == np) /* last process? */
426 break;
427 if (i == 1)
428 sleep(2); /* wait for persist file */
429 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
430 if (rtp->next == NULL)
431 error(SYSTEM, "out of memory in init");
432 rtp = rtp->next;
433 }
434 rtp->next = NULL; /* terminate list */
435 if (yres > 0) {
436 if (xres > 0)
437 raysleft = (unsigned long)xres*yres;
438 else
439 raysleft = yres;
440 } else
441 raysleft = 0;
442 waitflush = xres;
443 }
444
445 /* add modifier to our list to track */
446 MODCONT *
447 addmodifier(char *modn, char *outf, char *binv)
448 {
449 LUENT *lep = lu_find(&modconttab, modn);
450 MODCONT *mp;
451
452 if (lep->data != NULL) {
453 sprintf(errmsg, "duplicate modifier '%s'", modn);
454 error(USER, errmsg);
455 }
456 if (nmods >= MAXMODLIST)
457 error(USER, "too many modifiers");
458 modname[nmods++] = modn; /* XXX assumes static string */
459 lep->key = modn; /* XXX assumes static string */
460 mp = (MODCONT *)malloc(sizeof(MODCONT));
461 if (mp == NULL)
462 error(SYSTEM, "out of memory in addmodifier");
463 lep->data = (char *)mp;
464 mp->outspec = outf; /* XXX assumes static string */
465 mp->modname = modn; /* XXX assumes static string */
466 if (binv != NULL)
467 mp->binv = eparse(binv);
468 else
469 mp->binv = eparse("0");
470 mp->nbins = 1;
471 setcolor(mp->cbin[0], 0., 0., 0.);
472 return mp;
473 }
474
475 /* add modifiers from a file list */
476 void
477 addmodfile(char *fname, char *outf, char *binv)
478 {
479 char *mname[MAXMODLIST];
480 int i;
481 /* find the file & store strings */
482 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
483 sprintf(errmsg, "cannot find modifier file '%s'", fname);
484 error(SYSTEM, errmsg);
485 }
486 for (i = 0; mname[i]; i++) /* add each one */
487 addmodifier(mname[i], outf, binv);
488 }
489
490 /* put string to stderr */
491 void
492 eputs(char *s)
493 {
494 static int midline = 0;
495
496 if (!*s) return;
497 if (!midline) {
498 fputs(progname, stderr);
499 fputs(": ", stderr);
500 }
501 fputs(s, stderr);
502 midline = s[strlen(s)-1] != '\n';
503 }
504
505 /* construct output file name and return flags whether modifier/bin present */
506 int
507 ofname(char *oname, const char *ospec, const char *mname, int bn)
508 {
509 const char *mnp = NULL;
510 const char *bnp = NULL;
511 const char *cp;
512
513 if (ospec == NULL)
514 return -1;
515 for (cp = ospec; *cp; cp++) /* check format position(s) */
516 if (*cp == '%') {
517 do
518 ++cp;
519 while (isdigit(*cp));
520 switch (*cp) {
521 case '%':
522 break;
523 case 's':
524 if (mnp != NULL)
525 return -1;
526 mnp = cp;
527 break;
528 case 'd':
529 if (bnp != NULL)
530 return -1;
531 bnp = cp;
532 break;
533 default:
534 return -1;
535 }
536 }
537 if (mnp != NULL) { /* create file name */
538 if (bnp != NULL) {
539 if (bnp > mnp)
540 sprintf(oname, ospec, mname, bn);
541 else
542 sprintf(oname, ospec, bn, mname);
543 return OF_MODIFIER|OF_BIN;
544 }
545 sprintf(oname, ospec, mname);
546 return OF_MODIFIER;
547 }
548 if (bnp != NULL) {
549 sprintf(oname, ospec, bn);
550 return OF_BIN;
551 }
552 strcpy(oname, ospec);
553 return 0;
554 }
555
556 /* write header to the given output stream */
557 void
558 printheader(FILE *fout, const char *info)
559 {
560 extern char VersionID[];
561 FILE *fin = fopen(octree, "r");
562
563 if (fin == NULL)
564 quit(1);
565 checkheader(fin, "ignore", fout); /* copy octree header */
566 fclose(fin);
567 printargs(gargc-1, gargv, fout); /* add our command */
568 fprintf(fout, "SOFTWARE= %s\n", VersionID);
569 fputnow(fout);
570 if (info != NULL) /* add extra info if given */
571 fputs(info, fout);
572 switch (outfmt) { /* add output format */
573 case 'a':
574 fputformat("ascii", fout);
575 break;
576 case 'f':
577 fputformat("float", fout);
578 break;
579 case 'd':
580 fputformat("double", fout);
581 break;
582 case 'c':
583 fputformat(COLRFMT, fout);
584 break;
585 }
586 fputc('\n', fout);
587 if (xres > 0) {
588 if (yres > 0) /* resolution string */
589 fprtresolu(xres, yres, fout);
590 fflush(fout);
591 }
592 }
593
594 /* Get output file pointer (open and write header if new) */
595 FILE *
596 getofile(const char *ospec, const char *mname, int bn)
597 {
598 int ofl;
599 char oname[1024];
600 LUENT *lep;
601
602 if (ospec == NULL) { /* use stdout? */
603 if (!using_stdout) {
604 if (outfmt != 'a')
605 SET_FILE_BINARY(stdout);
606 if (header)
607 printheader(stdout, NULL);
608 }
609 using_stdout = 1;
610 return stdout;
611 }
612 ofl = ofname(oname, ospec, mname, bn); /* get output name */
613 if (ofl < 0) {
614 sprintf(errmsg, "bad output format '%s'", ospec);
615 error(USER, errmsg);
616 }
617 lep = lu_find(&ofiletab, oname); /* look it up */
618 if (lep->key == NULL) /* new entry */
619 lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
620 if (lep->data == NULL) { /* open output file */
621 FILE *fp;
622 int i;
623 if (oname[0] == '!') /* output to command */
624 fp = popen(oname+1, "w");
625 else
626 fp = fopen(oname, "w");
627 if (fp == NULL) {
628 sprintf(errmsg, "cannot open '%s' for writing", oname);
629 error(SYSTEM, errmsg);
630 }
631 if (outfmt != 'a')
632 SET_FILE_BINARY(fp);
633 if (header) {
634 char info[512];
635 char *cp = info;
636 sprintf(cp, "MODIFIER=%s\n", mname);
637 while (*cp) ++cp;
638 if (ofl & OF_BIN) {
639 sprintf(cp, "BIN=%d\n", bn);
640 while (*cp) ++cp;
641 }
642 *cp = '\0';
643 printheader(fp, info);
644 }
645 /* play catch-up */
646 for (i = 0; i < lastdone; i++) {
647 static const DCOLOR nocontrib = BLKCOLOR;
648 put_contrib(nocontrib, fp);
649 if (outfmt == 'a')
650 putc('\n', fp);
651 }
652 if (xres > 0)
653 fflush(fp);
654 lep->data = (char *)fp;
655 }
656 return (FILE *)lep->data; /* return open file pointer */
657 }
658
659 /* read input ray into buffer */
660 int
661 getinp(char *buf, FILE *fp)
662 {
663 char *cp;
664 int i;
665
666 switch (inpfmt) {
667 case 'a':
668 cp = buf; /* make sure we get 6 floats */
669 for (i = 0; i < 6; i++) {
670 if (fgetword(cp, buf+127-cp, fp) == NULL)
671 return 0;
672 if ((cp = fskip(cp)) == NULL || *cp)
673 return 0;
674 *cp++ = ' ';
675 }
676 getc(fp); /* get/put eol */
677 *cp-- = '\0'; *cp = '\n';
678 return strlen(buf);
679 case 'f':
680 if (fread(buf, sizeof(float), 6, fp) < 6)
681 return 0;
682 return sizeof(float)*6;
683 case 'd':
684 if (fread(buf, sizeof(double), 6, fp) < 6)
685 return 0;
686 return sizeof(double)*6;
687 }
688 error(INTERNAL, "botched input format");
689 return 0; /* pro forma return */
690 }
691
692 static float rparams[9]; /* traced ray parameters */
693
694 /* return channel (ray) value */
695 double
696 chanvalue(int n)
697 {
698 if (--n < 0 || n >= 6)
699 error(USER, "illegal channel number ($N)");
700 return rparams[n+3];
701 }
702
703 /* add current ray contribution to the appropriate modifier bin */
704 void
705 add_contrib(const char *modn)
706 {
707 LUENT *le = lu_find(&modconttab, modn);
708 MODCONT *mp = (MODCONT *)le->data;
709 int bn;
710
711 if (mp == NULL) {
712 sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
713 error(USER, errmsg);
714 }
715 eclock++; /* get bin number */
716 bn = (int)(evalue(mp->binv) + .5);
717 if (bn <= 0)
718 bn = 0;
719 else if (bn >= mp->nbins) { /* new bin */
720 mp = (MODCONT *)realloc(mp, sizeof(MODCONT) +
721 bn*sizeof(DCOLOR));
722 if (mp == NULL)
723 error(SYSTEM, "out of memory in add_contrib");
724 memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(bn+1-mp->nbins));
725 mp->nbins = bn+1;
726 le->data = (char *)mp;
727 }
728 addcolor(mp->cbin[bn], rparams);
729 }
730
731 /* output newline to ASCII file and/or flush as requested */
732 static int
733 puteol(const LUENT *e, void *p)
734 {
735 FILE *fp = (FILE *)e->data;
736
737 if (outfmt == 'a')
738 putc('\n', fp);
739 if (!waitflush)
740 fflush(fp);
741 if (ferror(fp)) {
742 sprintf(errmsg, "write error on file '%s'", e->key);
743 error(SYSTEM, errmsg);
744 }
745 return 0;
746 }
747
748 /* put out ray contribution to file */
749 void
750 put_contrib(const DCOLOR cnt, FILE *fout)
751 {
752 float fv[3];
753 COLR cv;
754
755 switch (outfmt) {
756 case 'a':
757 fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
758 break;
759 case 'f':
760 fv[0] = cnt[0];
761 fv[1] = cnt[1];
762 fv[2] = cnt[2];
763 fwrite(fv, sizeof(float), 3, fout);
764 break;
765 case 'd':
766 fwrite(cnt, sizeof(double), 3, fout);
767 break;
768 case 'c':
769 setcolr(cv, cnt[0], cnt[1], cnt[2]);
770 fwrite(cv, sizeof(cv), 1, fout);
771 break;
772 default:
773 error(INTERNAL, "botched output format");
774 }
775 }
776
777 /* output ray tallies and clear for next primary */
778 void
779 done_contrib(void)
780 {
781 int i, j;
782 MODCONT *mp;
783 FILE *fp;
784 /* output modifiers in order */
785 for (i = 0; i < nmods; i++) {
786 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
787 fp = getofile(mp->outspec, mp->modname, 0);
788 put_contrib(mp->cbin[0], fp);
789 if (mp->nbins > 3 && /* minor optimization */
790 fp == getofile(mp->outspec, mp->modname, 1))
791 for (j = 1; j < mp->nbins; j++)
792 put_contrib(mp->cbin[j], fp);
793 else
794 for (j = 1; j < mp->nbins; j++)
795 put_contrib(mp->cbin[j],
796 getofile(mp->outspec, mp->modname, j));
797 /* clear for next ray tree */
798 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
799 }
800 --waitflush; /* terminate records */
801 lu_doall(&ofiletab, puteol, NULL);
802 if (using_stdout & (outfmt == 'a'))
803 putc('\n', stdout);
804 if (!waitflush) {
805 waitflush = xres;
806 if (using_stdout)
807 fflush(stdout);
808 }
809 }
810
811 /* queue completed ray tree produced by rtrace process */
812 void
813 queue_raytree(struct rtproc *rtp)
814 {
815 struct rtproc *rtu, *rtl = NULL;
816 /* insert following ray order */
817 for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
818 if (rtp->raynum < rtu->raynum)
819 break;
820 rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
821 if (rtu == NULL)
822 error(SYSTEM, "out of memory in queue_raytree");
823 *rtu = *rtp;
824 if (rtl == NULL) {
825 rtu->next = rt_unproc;
826 rt_unproc = rtu;
827 } else {
828 rtu->next = rtl->next;
829 rtl->next = rtu;
830 }
831 rtp->raynum = 0; /* clear path for next ray tree */
832 rtp->bsiz = 0;
833 rtp->buf = NULL;
834 rtp->nbr = 0;
835 }
836
837 /* process completed ray trees from our queue */
838 void
839 process_queue(void)
840 {
841 char modname[128];
842 /* ray-ordered queue */
843 while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
844 struct rtproc *rtp = rt_unproc;
845 int n = rtp->nbr;
846 const char *cp = rtp->buf;
847 while (n > 0) { /* process rays */
848 register char *mnp = modname;
849 /* skip leading tabs */
850 while (n > 0 && *cp == '\t') {
851 cp++; n--;
852 }
853 if (!n || !(isalpha(*cp) | (*cp == '_')))
854 error(USER, "bad modifier name from rtrace");
855 /* get modifier name */
856 while (n > 0 && *cp != '\t') {
857 *mnp++ = *cp++; n--;
858 }
859 *mnp = '\0';
860 cp++; n--; /* eat following tab */
861 if (n < (int)(sizeof(float)*9))
862 error(USER, "incomplete ray value from rtrace");
863 /* add ray contribution */
864 memcpy(rparams, cp, sizeof(float)*9);
865 cp += sizeof(float)*9; n -= sizeof(float)*9;
866 add_contrib(modname);
867 }
868 done_contrib(); /* sum up contributions & output */
869 lastdone = rtp->raynum;
870 free(rtp->buf); /* free up buffer space */
871 rt_unproc = rtp->next;
872 free(rtp); /* done with this ray tree */
873 }
874 }
875
876 /* wait for rtrace process to finish with ray tree */
877 struct rtproc *
878 wait_rproc(void)
879 {
880 struct rtproc *rtfree = NULL;
881 fd_set readset, errset;
882 int nr;
883 struct rtproc *rt;
884 int n;
885
886 do {
887 nr = 0; /* prepare select call */
888 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
889 for (rt = &rt0; rt != NULL; rt = rt->next) {
890 if (rt->raynum) {
891 FD_SET(rt->pd.r, &readset);
892 ++nr;
893 }
894 FD_SET(rt->pd.r, &errset);
895 if (rt->pd.r >= n)
896 n = rt->pd.r + 1;
897 }
898 if (!nr) /* no rays pending */
899 break;
900 if (nr > 1) { /* call select for multiple proc's */
901 errno = 0;
902 if (select(n, &readset, NULL, &errset, NULL) < 0)
903 error(SYSTEM, "select call error in wait_rproc()");
904 } else
905 FD_ZERO(&errset);
906 nr = 0;
907 for (rt = &rt0; rt != NULL; rt = rt->next) {
908 if (!FD_ISSET(rt->pd.r, &readset) &&
909 !FD_ISSET(rt->pd.r, &errset))
910 continue;
911 if (rt->buf == NULL) {
912 rt->bsiz = treebufsiz;
913 rt->buf = (char *)malloc(treebufsiz);
914 } else if (rt->nbr + BUFSIZ > rt->bsiz) {
915 if (rt->bsiz + BUFSIZ <= treebufsiz)
916 rt->bsiz = treebufsiz;
917 else
918 treebufsiz = rt->bsiz += BUFSIZ;
919 rt->buf = (char *)realloc(rt->buf, rt->bsiz);
920 }
921 if (rt->buf == NULL)
922 error(SYSTEM, "out of memory in wait_rproc");
923 nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
924 if (nr <= 0)
925 error(USER, "rtrace process died");
926 rt->nbr += nr; /* advance & check */
927 if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4,
928 "~\t~\t", 4)) {
929 rt->nbr -= 4; /* elide terminator */
930 queue_raytree(rt);
931 rtfree = rt; /* ready for next ray */
932 }
933 }
934 } while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
935 return rtfree;
936 }
937
938 /* return next available rtrace process */
939 struct rtproc *
940 get_rproc(void)
941 {
942 struct rtproc *rtp;
943 /* check for idle rtrace */
944 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
945 if (!rtp->raynum)
946 return rtp;
947 return wait_rproc(); /* need to wait for one */
948 }
949
950 /* trace ray contributions (main loop) */
951 void
952 trace_contribs(FILE *fin)
953 {
954 char inpbuf[128];
955 int iblen;
956 struct rtproc *rtp;
957 /* loop over input */
958 while ((iblen = getinp(inpbuf, fin)) > 0) {
959 if (lastray+1 < lastray) { /* counter rollover? */
960 while (wait_rproc() != NULL)
961 process_queue();
962 lastdone = lastray = 0;
963 }
964 rtp = get_rproc(); /* get avail. rtrace process */
965 rtp->raynum = ++lastray; /* assign ray to it */
966 writebuf(rtp->pd.w, inpbuf, iblen);
967 if (raysleft && !--raysleft)
968 break;
969 process_queue(); /* catch up with results */
970 }
971 while (wait_rproc() != NULL) /* process outstanding rays */
972 process_queue();
973 if (raysleft)
974 error(USER, "unexpected EOF on input");
975 lu_done(&ofiletab); /* close output files */
976 }
977
978 /* seek on the given output file */
979 static int
980 myseeko(const LUENT *e, void *p)
981 {
982 if (fseeko((FILE *)e->data, *(off_t *)p, SEEK_CUR) < 0) {
983 sprintf(errmsg, "seek error on file '%s'", e->key);
984 error(SYSTEM, errmsg);
985 }
986 }
987
988 /* recover output if possible */
989 void
990 recover_output(FILE *fin)
991 {
992 off_t lastout = -1;
993 int outvsiz;
994 char *outvfmt;
995 int i, j;
996 MODCONT *mp;
997 int ofl;
998 char oname[1024];
999 LUENT *ment, *oent;
1000 FILE *fp;
1001 off_t nvals;
1002
1003 switch (outfmt) {
1004 case 'a':
1005 error(USER, "cannot recover ASCII output");
1006 return;
1007 case 'f':
1008 outvsiz = sizeof(float)*3;
1009 outvfmt = "float";
1010 break;
1011 case 'd':
1012 outvsiz = sizeof(double)*3;
1013 outvfmt = "double";
1014 break;
1015 case 'c':
1016 outvsiz = sizeof(COLR);
1017 outvfmt = COLRFMT;
1018 break;
1019 default:
1020 error(INTERNAL, "botched output format");
1021 return;
1022 }
1023 /* check modifier outputs */
1024 for (i = 0; i < nmods; i++) {
1025 ment = lu_find(&modconttab,modname[i]);
1026 mp = (MODCONT *)ment->data;
1027 if (mp->outspec == NULL)
1028 error(USER, "cannot recover from stdout");
1029 for (j = 0; ; j++) { /* check each bin's file */
1030 ofl = ofname(oname, mp->outspec, mp->modname, j);
1031 if (ofl < 0)
1032 error(USER, "bad output file specification");
1033 oent = lu_find(&ofiletab, oname);
1034 if (oent->data != NULL) { /* saw this one already */
1035 if (ofl & OF_BIN)
1036 continue;
1037 break;
1038 }
1039 if (oname[0] == '!')
1040 error(USER, "cannot recover from command");
1041 /* open output */
1042 fp = fopen(oname, "rb+");
1043 if (fp == NULL) {
1044 if (j)
1045 break; /* assume end of modifier */
1046 sprintf(errmsg, "missing recover file '%s'",
1047 oname);
1048 error(USER, errmsg);
1049 }
1050 nvals = lseek(fileno(fp), 0, SEEK_END);
1051 if (nvals <= 0) {
1052 lastout = 0; /* empty output, quit here */
1053 fclose(fp);
1054 break;
1055 }
1056 lseek(fileno(fp), 0, SEEK_SET);
1057 if (header) {
1058 int xr, yr;
1059 if (checkheader(fp, outvfmt, NULL) != 1) {
1060 sprintf(errmsg,
1061 "format mismatch for '%s'",
1062 oname);
1063 error(USER, errmsg);
1064 }
1065 if (xres > 0 && yres > 0 &&
1066 (!fscnresolu(&xr, &yr, fp) ||
1067 xr != xres ||
1068 yr != yres)) {
1069 sprintf(errmsg,
1070 "resolution mismatch for '%s'",
1071 oname);
1072 error(USER, errmsg);
1073 }
1074 }
1075 nvals = (nvals - (off_t)ftell(fp)) / outvsiz;
1076 if (lastout < 0 || nvals < lastout)
1077 lastout = nvals;
1078 if (oent->key == NULL) /* new entry */
1079 oent->key = strcpy((char *)
1080 malloc(strlen(oname)+1), oname);
1081 oent->data = (char *)fp;
1082 if (!(ofl & OF_BIN))
1083 break; /* no bin separation */
1084 }
1085 if (!lastout) { /* empty output */
1086 error(WARNING, "no previous data to recover");
1087 lu_done(&ofiletab); /* reclose all outputs */
1088 return;
1089 }
1090 if (j > mp->nbins) { /* preallocate modifier bins */
1091 mp = (MODCONT *)realloc(mp, sizeof(MODCONT) +
1092 (j-1)*sizeof(DCOLOR));
1093 if (mp == NULL)
1094 error(SYSTEM, "out of memory in recover_output");
1095 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
1096 mp->nbins = j;
1097 ment->data = (char *)mp;
1098 }
1099 }
1100 if (lastout < 0) {
1101 error(WARNING, "no output files to recover");
1102 return;
1103 }
1104 if (raysleft && lastout >= raysleft) {
1105 error(WARNING, "output appears to be complete");
1106 /* XXX should read & discard input? */
1107 quit(0);
1108 }
1109 /* seek on all files */
1110 nvals = lastout * outvsiz;
1111 lu_doall(&ofiletab, myseeko, &nvals);
1112 /* skip repeated input */
1113 for (nvals = 0; nvals < lastout; nvals++)
1114 if (getinp(oname, fin) <= 0)
1115 error(USER, "unexpected EOF on input");
1116 lastray = lastdone = (unsigned long)lastout;
1117 if (raysleft)
1118 raysleft -= lastray;
1119 }
