--- ray/src/util/rtcontrib.c 2009/06/14 18:21:58 1.54 +++ ray/src/util/rtcontrib.c 2010/10/10 09:25:04 1.60 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtcontrib.c,v 1.54 2009/06/14 18:21:58 greg Exp $"; +static const char RCSid[] = "$Id: rtcontrib.c,v 1.60 2010/10/10 09:25:04 greg Exp $"; #endif /* * Gather rtrace output to compute contributions from particular sources @@ -20,7 +20,7 @@ static const char RCSid[] = "$Id: rtcontrib.c,v 1.54 2 #define MAXMODLIST 1024 /* maximum modifiers we'll track */ #endif -int treebufsiz = BUFSIZ; /* current tree buffer size */ +size_t treebufsiz = BUFSIZ; /* current tree buffer size */ typedef double DCOLOR[3]; /* double-precision color */ @@ -92,9 +92,9 @@ struct rtproc { struct rtproc *next; /* next in list of processes */ SUBPROC pd; /* rtrace pipe descriptors */ unsigned long raynum; /* ray number for this tree */ - int bsiz; /* ray tree buffer length */ + size_t bsiz; /* ray tree buffer length */ char *buf; /* ray tree buffer */ - int nbr; /* number of bytes from rtrace */ + size_t nbr; /* number of bytes from rtrace */ }; /* rtrace process buffer */ /* rtrace command and defaults */ @@ -378,14 +378,16 @@ main(int argc, char *argv[]) rtargv[rtargc++] = contrib ? RTCONTRIB : RTCOEFF; /* just asking for defaults? */ if (!strcmp(argv[i], "-defaults")) { - char sxres[16], syres[16]; + char nps[8], sxres[16], syres[16]; char *rtpath; - printf("-n %-2d\t\t\t\t# number of processes\n", nprocs); printf("-c %-5d\t\t\t# accumulated rays per record\n", accumulate); printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-', contrib ? "contributions" : "coefficients"); fflush(stdout); /* report OUR options */ + rtargv[rtargc++] = "-n"; + sprintf(nps, "%d", nprocs); + rtargv[rtargc++] = nps; rtargv[rtargc++] = header ? "-h+" : "-h-"; sprintf(fmt, "-f%c%c", inpfmt, outfmt); rtargv[rtargc++] = fmt; @@ -543,7 +545,7 @@ init(int np) raysleft = 0; if ((account = accumulate) > 0) raysleft *= accumulate; - waitflush = xres; + waitflush = (yres > 0) & (xres > 1) ? 0 : xres; if (!recover) return; /* recover previous values */ @@ -664,6 +666,10 @@ ofname(char *oname, const char *ospec, const char *mna mnp = cp; break; case 'd': + case 'i': + case 'o': + case 'x': + case 'X': if (bnp != NULL) return -1; bnp = cp; @@ -730,8 +736,6 @@ printresolu(FILE *fout, int xr, int yr) { if ((xr > 0) & (yr > 0)) /* resolution string */ fprtresolu(xr, yr, fout); - if (xres > 0) /* global flush flag */ - fflush(fout); } /* Get output stream pointer (open and write header if new and noopen==0) */ @@ -752,6 +756,8 @@ getostream(const char *ospec, const char *mname, int b if (header) printheader(stdout, NULL); printresolu(stdout, xres, yres); + if (waitflush > 0) + fflush(stdout); stdos.xr = xres; stdos.yr = yres; using_stdout = 1; } @@ -820,7 +826,7 @@ getostream(const char *ospec, const char *mname, int b if (outfmt == 'a') putc('\n', sop->ofp); } - if (xres > 0) + if (waitflush > 0) fflush(sop->ofp); } sop->reclen += noopen; /* add to length if noopen */ @@ -987,7 +993,7 @@ done_contrib(int navg) if (using_stdout & (outfmt == 'a')) putc('\n', stdout); if (!waitflush) { - waitflush = xres; + waitflush = (yres > 0) & (xres > 1) ? 0 : xres; if (using_stdout) fflush(stdout); } @@ -1069,7 +1075,7 @@ wait_rproc(void) { struct rtproc *rtfree = NULL; fd_set readset, errset; - int nr; + ssize_t nr; struct rtproc *rt; int n;
