--- ray/src/util/rtcontrib.c 2007/11/17 15:57:28 1.47 +++ ray/src/util/rtcontrib.c 2008/12/06 01:08:53 1.51 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtcontrib.c,v 1.47 2007/11/17 15:57:28 greg Exp $"; +static const char RCSid[] = "$Id: rtcontrib.c,v 1.51 2008/12/06 01:08:53 greg Exp $"; #endif /* * Gather rtrace output to compute contributions from particular sources @@ -99,7 +99,7 @@ struct rtproc { /* rtrace command and defaults */ char *rtargv[256+2*MAXMODLIST] = { "rtrace", - "-dj", ".5", "-dr", "3", + "-dj", ".9", "-dr", "3", "-ab", "1", "-ad", "350", }; int rtargc = 9; @@ -131,12 +131,13 @@ int inpfmt = 'a'; /* input format */ int outfmt = 'a'; /* output format */ int header = 1; /* output header? */ -int accumulate = 0; /* accumulate ray values? */ int force_open = 0; /* truncate existing output? */ int recover = 0; /* recover previous output? */ +int accumulate = 1; /* input rays per output record */ int xres = 0; /* horiz. output resolution */ int yres = 0; /* vert. output resolution */ +int account; /* current accumulation count */ unsigned long raysleft; /* number of rays left to trace */ long waitflush; /* how long until next flush */ @@ -166,7 +167,7 @@ void process_queue(void); void put_contrib(const DCOLOR cnt, FILE *fout); void add_contrib(const char *modn); -void done_contrib(void); +void done_contrib(int navg); /* return number of open rtrace processes */ static int @@ -274,23 +275,10 @@ main(int argc, char *argv[]) continue; } break; - case 'c': /* accumulate ray values */ - switch (argv[i][2]) { - case '\0': - accumulate = !accumulate; - continue; - case '+': case '1': - case 'T': case 't': - case 'Y': case 'y': - accumulate = 1; - continue; - case '-': case '0': - case 'F': case 'f': - case 'N': case 'n': - accumulate = 0; - continue; - } - break; + case 'c': /* input rays per output */ + if (argv[i][2] || i >= argc-2) break; + accumulate = atoi(argv[++i]); + continue; case 'r': /* recover output */ if (argv[i][2]) break; recover = 1; @@ -380,7 +368,7 @@ main(int argc, char *argv[]) } rtargv[rtargc++] = argv[i]; /* assume rtrace option */ } - if (accumulate) /* no output flushing for single record */ + if (accumulate <= 0) /* no output flushing for single record */ xres = yres = 0; /* set global argument list */ gargc = argc; gargv = argv; @@ -392,12 +380,11 @@ main(int argc, char *argv[]) if (!strcmp(argv[i], "-defaults")) { char sxres[16], syres[16]; char *rtpath; - printf("-n %-2d\t\t\t\t# number of processes\n", nprocs); + printf("-n %-2d\t\t\t\t# number of processes\n", nprocs); + printf("-c %-5d\t\t\t# accumulated rays per record\n", + accumulate); printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-', contrib ? "contributions" : "coefficients"); - printf("-c%c\t\t\t\t# %s\n", accumulate ? '+' : '-', - accumulate ? "accumulate ray values" : - "one output record per ray"); fflush(stdout); /* report OUR options */ rtargv[rtargc++] = header ? "-h+" : "-h-"; sprintf(fmt, "-f%c%c", inpfmt, outfmt); @@ -554,11 +541,13 @@ init(int np) raysleft = yres; } else raysleft = 0; + if ((account = accumulate) > 0) + raysleft *= accumulate; waitflush = xres; if (!recover) return; /* recover previous values */ - if (accumulate) + if (accumulate <= 0) reload_output(); else recover_output(stdin); @@ -813,12 +802,12 @@ getostream(const char *ospec, const char *mname, int b *cp = '\0'; printheader(sop->ofp, info); } - if (!accumulate) { /* global res. for -c- */ + if (accumulate > 0) { /* global resolution */ sop->xr = xres; sop->yr = yres; } printresolu(sop->ofp, sop->xr, sop->yr); /* play catch-up */ - for (i = accumulate ? 0 : lastdone; i--; ) { + for (i = accumulate > 0 ? lastdone/accumulate : 0; i--; ) { int j = sop->reclen; if (j <= 0) j = 1; while (j--) @@ -960,14 +949,21 @@ put_contrib(const DCOLOR cnt, FILE *fout) /* output ray tallies and clear for next accumulation */ void -done_contrib(void) +done_contrib(int navg) { + double sf = 1.; int i, j; MODCONT *mp; STREAMOUT *sop; + /* set average scaling */ + if (navg > 1) + sf = 1. / (double)navg; /* output modifiers in order */ for (i = 0; i < nmods; i++) { mp = (MODCONT *)lu_find(&modconttab,modname[i])->data; + if (navg > 1) /* average scaling */ + for (j = mp->nbins; j--; ) + scalecolor(mp->cbin[j], sf); sop = getostream(mp->outspec, mp->modname, 0,0); put_contrib(mp->cbin[0], sop->ofp); if (mp->nbins > 3 && /* minor optimization */ @@ -1051,8 +1047,9 @@ process_queue(void) cp += sizeof(float)*9; n -= sizeof(float)*9; add_contrib(modname); } - if (!accumulate) - done_contrib(); /* sum up contributions & output */ + /* time to produce record? */ + if (account > 0 && !--account) + done_contrib(account = accumulate); lastdone = rtp->raynum; if (rtp->buf != NULL) /* free up buffer space */ free(rtp->buf); @@ -1139,11 +1136,18 @@ get_rproc(void) void trace_contribs(FILE *fin) { + static int ignore_warning_given = 0; char inpbuf[128]; int iblen; struct rtproc *rtp; /* loop over input */ while ((iblen = getinp(inpbuf, fin)) >= 0) { + if (!iblen && accumulate != 1) { + if (!ignore_warning_given++) + error(WARNING, + "dummy ray(s) ignored during accumulation\n"); + continue; + } if (!iblen || /* need reset? */ queue_length() > 10*nrtprocs() || lastray+1 < lastray) { @@ -1167,8 +1171,12 @@ trace_contribs(FILE *fin) } while (wait_rproc() != NULL) /* process outstanding rays */ process_queue(); - if (accumulate) - done_contrib(); /* output tallies */ + if (accumulate <= 0) + done_contrib(0); /* output tallies */ + else if (account < accumulate) { + error(WARNING, "partial accumulation in final record"); + done_contrib(accumulate - account); + } if (raysleft) error(USER, "unexpected EOF on input"); lu_done(&ofiletab); /* close output files */ @@ -1210,9 +1218,10 @@ myclose(const LUENT *e, void *p) STREAMOUT *sop = (STREAMOUT *)e->data; if (sop->ofp == NULL) - return; + return(0); fclose(sop->ofp); sop->ofp = NULL; + return(0); } /* load previously accumulated values */ @@ -1293,16 +1302,12 @@ reload_output(void) error(USER, errmsg); } } - if (oent->key == NULL) /* new file entry */ - oent->key = strcpy((char *) - malloc(strlen(oname)+1), oname); - if (oent->data == NULL) - oent->data = (char *)malloc(sizeof(STREAMOUT)); - *(STREAMOUT *)oent->data = sout; /* read in RGB value */ if (!get_contrib(rgbv, sout.ofp)) { - if (!j) + if (!j) { + fclose(sout.ofp); break; /* ignore empty file */ + } if (j < mp->nbins) { sprintf(errmsg, "missing data in '%s'", oname); @@ -1313,6 +1318,12 @@ reload_output(void) if (j >= mp->nbins) /* grow modifier size */ ment->data = (char *)(mp = growmodifier(mp, j+1)); copycolor(mp->cbin[j], rgbv); + if (oent->key == NULL) /* new file entry */ + oent->key = strcpy((char *) + malloc(strlen(oname)+1), oname); + if (oent->data == NULL) + oent->data = (char *)malloc(sizeof(STREAMOUT)); + *(STREAMOUT *)oent->data = sout; } } lu_doall(&ofiletab, myclose, NULL); /* close all files */ @@ -1388,7 +1399,6 @@ recover_output(FILE *fin) } else { sout.reclen = 0; sout.outpipe = 0; - sout.xr = xres; sout.yr = yres; sout.ofp = NULL; } if (sout.ofp != NULL) { /* already open? */ @@ -1429,10 +1439,11 @@ recover_output(FILE *fin) oname); error(USER, errmsg); } - if ((xres > 0) & (yres > 0) && + sout.xr = xres; sout.yr = yres; + if ((sout.xr > 0) & (sout.yr > 0) && (!fscnresolu(&xr, &yr, sout.ofp) || - (xr != xres) | - (yr != yres))) { + (xr != sout.xr) | + (yr != sout.yr))) { sprintf(errmsg, "resolution mismatch for '%s'", oname); error(USER, errmsg); @@ -1461,7 +1472,7 @@ recover_output(FILE *fin) error(WARNING, "no output files to recover"); return; } - if (raysleft && lastout >= raysleft) { + if (raysleft && lastout >= raysleft/accumulate) { error(WARNING, "output appears to be complete"); /* XXX should read & discard input? */ quit(0); @@ -1473,7 +1484,7 @@ recover_output(FILE *fin) for (nvals = 0; nvals < lastout; nvals++) if (getinp(oname, fin) < 0) error(USER, "unexpected EOF on input"); - lastray = lastdone = (unsigned long)lastout; + lastray = lastdone = (unsigned long)lastout * accumulate; if (raysleft) raysleft -= lastray; }
