--- ray/src/util/rtcontrib.c 2006/03/29 17:31:59 1.41 +++ ray/src/util/rtcontrib.c 2007/11/17 15:57:28 1.47 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtcontrib.c,v 1.41 2006/03/29 17:31:59 greg Exp $"; +static const char RCSid[] = "$Id: rtcontrib.c,v 1.47 2007/11/17 15:57:28 greg Exp $"; #endif /* * Gather rtrace output to compute contributions from particular sources @@ -27,7 +27,7 @@ typedef double DCOLOR[3]; /* double-precision color * /* * The MODCONT structure is used to accumulate ray contributions * for a particular modifier, which may be subdivided into bins - * if binv is non-zero. If outspec contains a %s in it, this will + * if binv evaluates > 0. If outspec contains a %s in it, this will * be replaced with the modifier name. If outspec contains a %d in it, * this will be used to create one output file per bin, otherwise all bins * will be written to the same file, in order. If the global outfmt @@ -46,16 +46,15 @@ static void mcfree(void *p) { epfree((*(MODCONT *)p).b LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */ -#define CNT_UNKNOWN 0 /* unknown record length */ -#define CNT_PIPE (-1) /* output to a pipe */ /* * The STREAMOUT structure holds an open FILE pointer and a count of - * the number of RGB triplets per record, or CNT_UNKNOWN (0) if - * unknown or CNT_PIPE (-1) if writing to a command. + * the number of RGB triplets per record, or 0 if unknown. */ typedef struct { FILE *ofp; /* output file pointer */ + int outpipe; /* output is to a pipe */ int reclen; /* triplets/record */ + int xr, yr; /* output resolution for picture */ } STREAMOUT; /* close output stream and free record */ @@ -64,7 +63,7 @@ closestream(void *p) { STREAMOUT *sop = (STREAMOUT *)p; int status; - if (sop->reclen == CNT_PIPE) + if (sop->outpipe) status = pclose(sop->ofp); else status = fclose(sop->ofp); @@ -81,7 +80,7 @@ LUTAB ofiletab = LU_SINIT(free,closestream); /* output STREAMOUT *getostream(const char *ospec, const char *mname, int bn, int noopen); int ofname(char *oname, const char *ospec, const char *mname, int bn); void printheader(FILE *fout, const char *info); -void printresolu(FILE *fout); +void printresolu(FILE *fout, int xr, int yr); /* * The rcont structure is used to manage i/o with a particular @@ -101,7 +100,7 @@ struct rtproc { /* rtrace command and defaults */ char *rtargv[256+2*MAXMODLIST] = { "rtrace", "-dj", ".5", "-dr", "3", - "-ab", "1", "-ad", "128", }; + "-ab", "1", "-ad", "350", }; int rtargc = 9; /* overriding rtrace options */ @@ -115,7 +114,12 @@ struct rtproc rt0; /* head of rtrace process list */ struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */ -char persistfn[] = "pfXXXXXX"; /* persist file name */ +#define PERSIST_NONE 0 /* no persist file */ +#define PERSIST_SINGLE 1 /* user set -P persist */ +#define PERSIST_PARALL 2 /* user set -PP persist */ +#define PERSIST_OURS 3 /* -PP persist belongs to us */ +int persist_state = PERSIST_NONE; /* persist file state */ +char persistfn[] = "pfXXXXXX"; /* our persist file name, if set */ int gargc; /* global argc */ char **gargv; /* global argv */ @@ -127,7 +131,9 @@ int inpfmt = 'a'; /* input format */ int outfmt = 'a'; /* output format */ int header = 1; /* output header? */ +int accumulate = 0; /* accumulate ray values? */ int force_open = 0; /* truncate existing output? */ +int recover = 0; /* recover previous output? */ int xres = 0; /* horiz. output resolution */ int yres = 0; /* vert. output resolution */ @@ -150,6 +156,7 @@ void addmodfile(char *fname, char *outf, char *binv, i void init(int np); int done_rprocs(struct rtproc *rtp); +void reload_output(void); void recover_output(FILE *fin); void trace_contribs(FILE *fin); struct rtproc *wait_rproc(void); @@ -214,7 +221,6 @@ main(int argc, char *argv[]) { int contrib = 0; int nprocs = 1; - int recover = 0; char *curout = NULL; char *binval = NULL; int bincnt = 0; @@ -268,9 +274,26 @@ main(int argc, char *argv[]) continue; } break; + case 'c': /* accumulate ray values */ + switch (argv[i][2]) { + case '\0': + accumulate = !accumulate; + continue; + case '+': case '1': + case 'T': case 't': + case 'Y': case 'y': + accumulate = 1; + continue; + case '-': case '0': + case 'F': case 'f': + case 'N': case 'n': + accumulate = 0; + continue; + } + break; case 'r': /* recover output */ if (argv[i][2]) break; - recover++; + recover = 1; continue; case 'h': /* output header? */ switch (argv[i][2]) { @@ -305,7 +328,7 @@ main(int argc, char *argv[]) continue; } if (argv[i][2] == 'o') { - force_open++; + force_open = 1; continue; } setformat(argv[i]+2); @@ -348,11 +371,17 @@ main(int argc, char *argv[]) addmodfile(argv[i], curout, binval, bincnt); continue; case 'P': /* persist file */ - error(USER, "persist file is automatic"); - break; + if (i >= argc-2) break; + persist_state = (argv[i][2] == 'P') ? + PERSIST_PARALL : PERSIST_SINGLE; + rtargv[rtargc++] = argv[i]; + rtargv[rtargc++] = argv[++i]; + continue; } rtargv[rtargc++] = argv[i]; /* assume rtrace option */ } + if (accumulate) /* no output flushing for single record */ + xres = yres = 0; /* set global argument list */ gargc = argc; gargv = argv; /* add "mandatory" rtrace settings */ @@ -366,6 +395,9 @@ main(int argc, char *argv[]) printf("-n %-2d\t\t\t\t# number of processes\n", nprocs); printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-', contrib ? "contributions" : "coefficients"); + printf("-c%c\t\t\t\t# %s\n", accumulate ? '+' : '-', + accumulate ? "accumulate ray values" : + "one output record per ray"); fflush(stdout); /* report OUR options */ rtargv[rtargc++] = header ? "-h+" : "-h-"; sprintf(fmt, "-f%c%c", inpfmt, outfmt); @@ -389,8 +421,13 @@ main(int argc, char *argv[]) exit(1); } if (nprocs > 1) { /* add persist file if parallel */ - rtargv[rtargc++] = "-PP"; - rtargv[rtargc++] = mktemp(persistfn); + if (persist_state == PERSIST_SINGLE) + error(USER, "use -PP option for multiple processes"); + if (persist_state == PERSIST_NONE) { + rtargv[rtargc++] = "-PP"; + rtargv[rtargc++] = mktemp(persistfn); + persist_state = PERSIST_OURS; + } } /* add format string */ sprintf(fmt, "-f%cf", inpfmt); @@ -400,11 +437,11 @@ main(int argc, char *argv[]) error(USER, "missing octree argument"); rtargv[rtargc++] = octree = argv[i]; rtargv[rtargc] = NULL; - /* start rtrace */ + /* start rtrace & recover if requested */ init(nprocs); - if (recover) /* perform recovery if requested */ - recover_output(stdin); - trace_contribs(stdin); /* compute contributions */ + /* compute contributions */ + trace_contribs(stdin); + /* clean up */ quit(0); } @@ -450,7 +487,7 @@ quit(int status) { int rtstat; - if (rt0.next != NULL) /* terminate persistent rtrace */ + if (persist_state == PERSIST_OURS) /* terminate waiting rtrace */ killpersist(); /* clean up rtrace process(es) */ rtstat = done_rprocs(&rt0); @@ -518,6 +555,13 @@ init(int np) } else raysleft = 0; waitflush = xres; + if (!recover) + return; + /* recover previous values */ + if (accumulate) + reload_output(); + else + recover_output(stdin); } /* grow modifier to accommodate more bins */ @@ -567,7 +611,7 @@ addmodifier(char *modn, char *outf, char *binv, int bi mp = growmodifier(mp, bincnt); lep->data = (char *)mp; /* allocate output streams */ - for (i = outf==NULL || outf[0]=='!' ? 0 : bincnt; i-- > 0; ) + for (i = bincnt; i-- > 0; ) getostream(mp->outspec, mp->modname, i, 1); return mp; } @@ -688,19 +732,19 @@ printheader(FILE *fout, const char *info) /* write resolution string to given output stream */ void -printresolu(FILE *fout) +printresolu(FILE *fout, int xr, int yr) { - if (xres > 0) { - if (yres > 0) /* resolution string */ - fprtresolu(xres, yres, fout); + if ((xr > 0) & (yr > 0)) /* resolution string */ + fprtresolu(xr, yr, fout); + if (xres > 0) /* global flush flag */ fflush(fout); - } } /* Get output stream pointer (open and write header if new and noopen==0) */ STREAMOUT * getostream(const char *ospec, const char *mname, int bn, int noopen) { + static const DCOLOR nocontrib = BLKCOLOR; static STREAMOUT stdos; int ofl; char oname[1024]; @@ -709,12 +753,12 @@ getostream(const char *ospec, const char *mname, int b if (ospec == NULL) { /* use stdout? */ if (!noopen && !using_stdout) { - stdos.reclen = 0; if (outfmt != 'a') SET_FILE_BINARY(stdout); if (header) printheader(stdout, NULL); - printresolu(stdout); + printresolu(stdout, xres, yres); + stdos.xr = xres; stdos.yr = yres; using_stdout = 1; } stdos.ofp = stdout; @@ -734,22 +778,25 @@ getostream(const char *ospec, const char *mname, int b sop = (STREAMOUT *)malloc(sizeof(STREAMOUT)); if (sop == NULL) error(SYSTEM, "out of memory in getostream"); - sop->reclen = oname[0] == '!' ? CNT_PIPE : CNT_UNKNOWN; + sop->outpipe = oname[0] == '!'; + sop->reclen = 0; sop->ofp = NULL; /* open iff noopen==0 */ + sop->xr = xres; sop->yr = yres; lep->data = (char *)sop; + if (!sop->outpipe & !force_open & !recover && + access(oname, F_OK) == 0) { + errno = EEXIST; /* file exists */ + goto openerr; + } } if (!noopen && sop->ofp == NULL) { /* open output stream */ long i; if (oname[0] == '!') /* output to command */ sop->ofp = popen(oname+1, "w"); - else if (!force_open && access(oname, F_OK) == 0) - errno = EEXIST; /* file exists */ - else /* else open it */ + else /* else open file */ sop->ofp = fopen(oname, "w"); - if (sop->ofp == NULL) { - sprintf(errmsg, "cannot open '%s' for writing", oname); - error(SYSTEM, errmsg); - } + if (sop->ofp == NULL) + goto openerr; if (outfmt != 'a') SET_FILE_BINARY(sop->ofp); if (header) { @@ -766,29 +813,36 @@ getostream(const char *ospec, const char *mname, int b *cp = '\0'; printheader(sop->ofp, info); } - printresolu(sop->ofp); + if (!accumulate) { /* global res. for -c- */ + sop->xr = xres; sop->yr = yres; + } + printresolu(sop->ofp, sop->xr, sop->yr); /* play catch-up */ - for (i = sop->reclen > 1 ? sop->reclen*lastdone : lastdone; - i--; ) { - static const DCOLOR nocontrib = BLKCOLOR; - put_contrib(nocontrib, sop->ofp); + for (i = accumulate ? 0 : lastdone; i--; ) { + int j = sop->reclen; + if (j <= 0) j = 1; + while (j--) + put_contrib(nocontrib, sop->ofp); if (outfmt == 'a') putc('\n', sop->ofp); } if (xres > 0) fflush(sop->ofp); } - if (sop->reclen != CNT_PIPE) /* add to length if noopen */ - sop->reclen += noopen; - return sop; /* return open stream */ + sop->reclen += noopen; /* add to length if noopen */ + return sop; /* return output stream */ +openerr: + sprintf(errmsg, "cannot open '%s' for writing", oname); + error(SYSTEM, errmsg); + return NULL; /* pro forma return */ } /* read input ray into buffer */ int getinp(char *buf, FILE *fp) { - double dv[3]; - float fv[3]; + double dv[3], *dvp; + float *fvp; char *cp; int i; @@ -812,15 +866,15 @@ getinp(char *buf, FILE *fp) case 'f': if (fread(buf, sizeof(float), 6, fp) < 6) return -1; - memcpy(fv, buf+3*sizeof(float), 3*sizeof(float)); - if (DOT(fv,fv) <= FTINY*FTINY) + fvp = (float *)buf + 3; + if (DOT(fvp,fvp) <= FTINY*FTINY) return 0; /* dummy ray */ return sizeof(float)*6; case 'd': if (fread(buf, sizeof(double), 6, fp) < 6) return -1; - memcpy(dv, buf+3*sizeof(double), 3*sizeof(double)); - if (DOT(dv,dv) <= FTINY*FTINY) + dvp = (double *)buf + 3; + if (DOT(dvp,dvp) <= FTINY*FTINY) return 0; /* dummy ray */ return sizeof(double)*6; } @@ -889,9 +943,7 @@ put_contrib(const DCOLOR cnt, FILE *fout) fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]); break; case 'f': - fv[0] = cnt[0]; - fv[1] = cnt[1]; - fv[2] = cnt[2]; + copycolor(fv, cnt); fwrite(fv, sizeof(float), 3, fout); break; case 'd': @@ -906,7 +958,7 @@ put_contrib(const DCOLOR cnt, FILE *fout) } } -/* output ray tallies and clear for next primary */ +/* output ray tallies and clear for next accumulation */ void done_contrib(void) { @@ -926,7 +978,7 @@ done_contrib(void) for (j = 1; j < mp->nbins; j++) put_contrib(mp->cbin[j], getostream(mp->outspec,mp->modname,j,0)->ofp); - /* clear for next ray tree */ + /* clear for next time */ memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins); } --waitflush; /* terminate records */ @@ -999,7 +1051,8 @@ process_queue(void) cp += sizeof(float)*9; n -= sizeof(float)*9; add_contrib(modname); } - done_contrib(); /* sum up contributions & output */ + if (!accumulate) + done_contrib(); /* sum up contributions & output */ lastdone = rtp->raynum; if (rtp->buf != NULL) /* free up buffer space */ free(rtp->buf); @@ -1114,11 +1167,157 @@ trace_contribs(FILE *fin) } while (wait_rproc() != NULL) /* process outstanding rays */ process_queue(); + if (accumulate) + done_contrib(); /* output tallies */ if (raysleft) error(USER, "unexpected EOF on input"); lu_done(&ofiletab); /* close output files */ } +/* get ray contribution from previous file */ +static int +get_contrib(DCOLOR cnt, FILE *finp) +{ + COLOR fv; + COLR cv; + + switch (outfmt) { + case 'a': + return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3); + case 'f': + if (fread(fv, sizeof(fv[0]), 3, finp) != 3) + return(0); + copycolor(cnt, fv); + return(1); + case 'd': + return(fread(cnt, sizeof(cnt[0]), 3, finp) == 3); + case 'c': + if (fread(cv, sizeof(cv), 1, finp) != 1) + return(0); + colr_color(fv, cv); + copycolor(cnt, fv); + return(1); + default: + error(INTERNAL, "botched output format"); + } + return(0); /* pro forma return */ +} + +/* close output file opened for input */ +static int +myclose(const LUENT *e, void *p) +{ + STREAMOUT *sop = (STREAMOUT *)e->data; + + if (sop->ofp == NULL) + return; + fclose(sop->ofp); + sop->ofp = NULL; +} + +/* load previously accumulated values */ +void +reload_output(void) +{ + int i, j; + MODCONT *mp; + int ofl; + char oname[1024]; + char *fmode = "rb"; + char *outvfmt; + LUENT *ment, *oent; + int xr, yr; + STREAMOUT sout; + DCOLOR rgbv; + + switch (outfmt) { + case 'a': + outvfmt = "ascii"; + fmode = "r"; + break; + case 'f': + outvfmt = "float"; + break; + case 'd': + outvfmt = "double"; + break; + case 'c': + outvfmt = COLRFMT; + break; + default: + error(INTERNAL, "botched output format"); + return; + } + /* reload modifier values */ + for (i = 0; i < nmods; i++) { + ment = lu_find(&modconttab,modname[i]); + mp = (MODCONT *)ment->data; + if (mp->outspec == NULL) + error(USER, "cannot reload from stdout"); + if (mp->outspec[0] == '!') + error(USER, "cannot reload from command"); + for (j = 0; ; j++) { /* load each modifier bin */ + ofl = ofname(oname, mp->outspec, mp->modname, j); + if (ofl < 0) + error(USER, "bad output file specification"); + oent = lu_find(&ofiletab, oname); + if (oent->data != NULL) { + sout = *(STREAMOUT *)oent->data; + } else { + sout.reclen = 0; + sout.outpipe = 0; + sout.xr = xres; sout.yr = yres; + sout.ofp = NULL; + } + if (sout.ofp == NULL) { /* open output as input */ + sout.ofp = fopen(oname, fmode); + if (sout.ofp == NULL) { + if (j) + break; /* assume end of modifier */ + sprintf(errmsg, "missing reload file '%s'", + oname); + error(WARNING, errmsg); + break; + } + if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) { + sprintf(errmsg, "format mismatch for '%s'", + oname); + error(USER, errmsg); + } + if ((sout.xr > 0) & (sout.yr > 0) && + (!fscnresolu(&xr, &yr, sout.ofp) || + (xr != sout.xr) | + (yr != sout.yr))) { + sprintf(errmsg, "resolution mismatch for '%s'", + oname); + error(USER, errmsg); + } + } + if (oent->key == NULL) /* new file entry */ + oent->key = strcpy((char *) + malloc(strlen(oname)+1), oname); + if (oent->data == NULL) + oent->data = (char *)malloc(sizeof(STREAMOUT)); + *(STREAMOUT *)oent->data = sout; + /* read in RGB value */ + if (!get_contrib(rgbv, sout.ofp)) { + if (!j) + break; /* ignore empty file */ + if (j < mp->nbins) { + sprintf(errmsg, "missing data in '%s'", + oname); + error(USER, errmsg); + } + break; + } + if (j >= mp->nbins) /* grow modifier size */ + ment->data = (char *)(mp = growmodifier(mp, j+1)); + copycolor(mp->cbin[j], rgbv); + } + } + lu_doall(&ofiletab, myclose, NULL); /* close all files */ +} + /* seek on the given output file */ static int myseeko(const LUENT *e, void *p) @@ -1132,6 +1331,7 @@ myseeko(const LUENT *e, void *p) sprintf(errmsg, "seek error on file '%s'", e->key); error(SYSTEM, errmsg); } + return 0; } /* recover output if possible */ @@ -1186,7 +1386,9 @@ recover_output(FILE *fin) if (oent->data != NULL) { sout = *(STREAMOUT *)oent->data; } else { - sout.reclen = CNT_UNKNOWN; + sout.reclen = 0; + sout.outpipe = 0; + sout.xr = xres; sout.yr = yres; sout.ofp = NULL; } if (sout.ofp != NULL) { /* already open? */ @@ -1201,7 +1403,8 @@ recover_output(FILE *fin) break; /* assume end of modifier */ sprintf(errmsg, "missing recover file '%s'", oname); - error(USER, errmsg); + error(WARNING, errmsg); + break; } nvals = lseek(fileno(sout.ofp), 0, SEEK_END); if (nvals <= 0) { @@ -1209,7 +1412,7 @@ recover_output(FILE *fin) fclose(sout.ofp); break; } - if (sout.reclen == CNT_UNKNOWN) { + if (!sout.reclen) { if (!(ofl & OF_BIN)) { sprintf(errmsg, "need -bn to recover file '%s'", @@ -1228,8 +1431,8 @@ recover_output(FILE *fin) } if ((xres > 0) & (yres > 0) && (!fscnresolu(&xr, &yr, sout.ofp) || - xr != xres || - yr != yres)) { + (xr != xres) | + (yr != yres))) { sprintf(errmsg, "resolution mismatch for '%s'", oname); error(USER, errmsg);
