--- ray/src/util/rtcontrib.c 2007/11/17 01:13:51 1.45 +++ ray/src/util/rtcontrib.c 2007/11/17 06:21:28 1.46 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtcontrib.c,v 1.45 2007/11/17 01:13:51 greg Exp $"; +static const char RCSid[] = "$Id: rtcontrib.c,v 1.46 2007/11/17 06:21:28 greg Exp $"; #endif /* * Gather rtrace output to compute contributions from particular sources @@ -133,6 +133,7 @@ int outfmt = 'a'; /* output format */ int header = 1; /* output header? */ int accumulate = 0; /* accumulate ray values? */ int force_open = 0; /* truncate existing output? */ +int recover = 0; /* recover previous output? */ int xres = 0; /* horiz. output resolution */ int yres = 0; /* vert. output resolution */ @@ -220,7 +221,6 @@ main(int argc, char *argv[]) { int contrib = 0; int nprocs = 1; - int recover = 0; char *curout = NULL; char *binval = NULL; int bincnt = 0; @@ -293,7 +293,7 @@ main(int argc, char *argv[]) break; case 'r': /* recover output */ if (argv[i][2]) break; - recover++; + recover = 1; continue; case 'h': /* output header? */ switch (argv[i][2]) { @@ -328,7 +328,7 @@ main(int argc, char *argv[]) continue; } if (argv[i][2] == 'o') { - force_open++; + force_open = 1; continue; } setformat(argv[i]+2); @@ -437,14 +437,11 @@ main(int argc, char *argv[]) error(USER, "missing octree argument"); rtargv[rtargc++] = octree = argv[i]; rtargv[rtargc] = NULL; - /* start rtrace */ + /* start rtrace & recover if requested */ init(nprocs); - if (recover) /* perform recovery if requested */ - if ((force_open = accumulate)) - reload_output(); - else - recover_output(stdin); - trace_contribs(stdin); /* compute contributions */ + /* compute contributions */ + trace_contribs(stdin); + /* clean up */ quit(0); } @@ -558,6 +555,13 @@ init(int np) } else raysleft = 0; waitflush = xres; + if (!recover) + return; + /* recover previous values */ + if (accumulate) + reload_output(); + else + recover_output(stdin); } /* grow modifier to accommodate more bins */ @@ -779,7 +783,8 @@ getostream(const char *ospec, const char *mname, int b sop->ofp = NULL; /* open iff noopen==0 */ sop->xr = xres; sop->yr = yres; lep->data = (char *)sop; - if (!force_open && access(oname, F_OK) == 0) { + if (!sop->outpipe & !force_open & !recover && + access(oname, F_OK) == 0) { errno = EEXIST; /* file exists */ goto openerr; } @@ -935,9 +940,7 @@ put_contrib(const DCOLOR cnt, FILE *fout) fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]); break; case 'f': - fv[0] = cnt[0]; - fv[1] = cnt[1]; - fv[2] = cnt[2]; + copycolor(fv, cnt); fwrite(fv, sizeof(float), 3, fout); break; case 'd': @@ -1168,20 +1171,45 @@ trace_contribs(FILE *fin) lu_done(&ofiletab); /* close output files */ } -/* seek on the given output file */ +/* get ray contribution from previous file */ static int -myseeko(const LUENT *e, void *p) +get_contrib(DCOLOR cnt, FILE *finp) { + COLOR fv; + COLR cv; + + switch (outfmt) { + case 'a': + return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3); + case 'f': + if (fread(fv, sizeof(fv[0]), 3, finp) != 3) + return(0); + copycolor(cnt, fv); + return(1); + case 'd': + return(fread(cnt, sizeof(cnt[0]), 3, finp) == 3); + case 'c': + if (fread(cv, sizeof(cv), 1, finp) != 1) + return(0); + colr_color(fv, cv); + copycolor(cnt, fv); + return(1); + default: + error(INTERNAL, "botched output format"); + } + return(0); /* pro forma return */ +} + +/* close output file opened for input */ +static int +myclose(const LUENT *e, void *p) +{ STREAMOUT *sop = (STREAMOUT *)e->data; - off_t nbytes = *(off_t *)p; - if (sop->reclen > 1) - nbytes = nbytes * sop->reclen; - if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) { - sprintf(errmsg, "seek error on file '%s'", e->key); - error(SYSTEM, errmsg); - } - return 0; + if (sop->ofp == NULL) + return; + fclose(sop->ofp); + sop->ofp = NULL; } /* load previously accumulated values */ @@ -1195,10 +1223,10 @@ reload_output(void) char *fmode = "rb"; char *outvfmt; LUENT *ment, *oent; + int xr, yr; STREAMOUT sout; + DCOLOR rgbv; - error(INTERNAL, "-r option not yet implemented with -c"); - switch (outfmt) { case 'a': outvfmt = "ascii"; @@ -1217,7 +1245,7 @@ reload_output(void) error(INTERNAL, "botched output format"); return; } - /* check modifier outputs */ + /* reload modifier values */ for (i = 0; i < nmods; i++) { ment = lu_find(&modconttab,modname[i]); mp = (MODCONT *)ment->data; @@ -1225,7 +1253,7 @@ reload_output(void) error(USER, "cannot reload from stdout"); if (mp->outspec[0] == '!') error(USER, "cannot reload from command"); - for (j = 0; ; j++) { /* check each bin's file */ + for (j = 0; ; j++) { /* load each modifier bin */ ofl = ofname(oname, mp->outspec, mp->modname, j); if (ofl < 0) error(USER, "bad output file specification"); @@ -1234,38 +1262,75 @@ reload_output(void) sout = *(STREAMOUT *)oent->data; } else { sout.reclen = 0; + sout.outpipe = 0; + sout.xr = xres; sout.yr = yres; sout.ofp = NULL; } - if (sout.ofp != NULL) { /* already open? */ - if (ofl & OF_BIN) - continue; - break; + if (sout.ofp == NULL) { /* open output as input */ + sout.ofp = fopen(oname, fmode); + if (sout.ofp == NULL) { + if (j) + break; /* assume end of modifier */ + sprintf(errmsg, "missing reload file '%s'", + oname); + error(WARNING, errmsg); + break; + } + if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) { + sprintf(errmsg, "format mismatch for '%s'", + oname); + error(USER, errmsg); + } + if ((sout.xr > 0) & (sout.yr > 0) && + (!fscnresolu(&xr, &yr, sout.ofp) || + xr != sout.xr || + yr != sout.yr)) { + sprintf(errmsg, "resolution mismatch for '%s'", + oname); + error(USER, errmsg); + } } - /* open output */ - sout.ofp = fopen(oname, fmode); - if (sout.ofp == NULL) { - if (j) - break; /* assume end of modifier */ - sprintf(errmsg, "missing reload file '%s'", - oname); - error(WARNING, errmsg); - break; - } - if (oent->key == NULL) /* new entry */ + if (oent->key == NULL) /* new file entry */ oent->key = strcpy((char *) malloc(strlen(oname)+1), oname); if (oent->data == NULL) oent->data = (char *)malloc(sizeof(STREAMOUT)); *(STREAMOUT *)oent->data = sout; - if (!(ofl & OF_BIN)) - break; /* no bin separation */ + /* read in RGB value */ + if (!get_contrib(rgbv, sout.ofp)) { + if (!j) + break; /* ignore empty file */ + if (j && j < mp->nbins) { + sprintf(errmsg, "missing data in '%s'", + oname); + error(USER, errmsg); + } + break; + } + if (j >= mp->nbins) /* grow modifier size */ + ment->data = (char *)(mp = growmodifier(mp, j+1)); + copycolor(mp->cbin[j], rgbv); } - if (j > mp->nbins) /* reallocate modifier bins */ - ment->data = (char *)(mp = growmodifier(mp, j)); } - lu_done(&ofiletab); /* close all files */ + lu_doall(&ofiletab, myclose, NULL); /* close all files */ } +/* seek on the given output file */ +static int +myseeko(const LUENT *e, void *p) +{ + STREAMOUT *sop = (STREAMOUT *)e->data; + off_t nbytes = *(off_t *)p; + + if (sop->reclen > 1) + nbytes = nbytes * sop->reclen; + if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) { + sprintf(errmsg, "seek error on file '%s'", e->key); + error(SYSTEM, errmsg); + } + return 0; +} + /* recover output if possible */ void recover_output(FILE *fin) @@ -1319,6 +1384,8 @@ recover_output(FILE *fin) sout = *(STREAMOUT *)oent->data; } else { sout.reclen = 0; + sout.outpipe = 0; + sout.xr = xres; sout.yr = yres; sout.ofp = NULL; } if (sout.ofp != NULL) { /* already open? */
