--- ray/src/util/rtcontrib.c 2005/05/31 03:48:59 1.7 +++ ray/src/util/rtcontrib.c 2005/06/10 20:53:55 1.20 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtcontrib.c,v 1.7 2005/05/31 03:48:59 greg Exp $"; +static const char RCSid[] = "$Id: rtcontrib.c,v 1.20 2005/06/10 20:53:55 greg Exp $"; #endif /* * Gather rtrace output to compute contributions from particular sources @@ -16,7 +16,9 @@ static const char RCSid[] = "$Id: rtcontrib.c,v 1.7 20 #include "lookup.h" #include "calcomp.h" +#ifndef MAXMODLIST #define MAXMODLIST 1024 /* maximum modifiers we'll track */ +#endif int treebufsiz = BUFSIZ; /* current tree buffer size */ @@ -49,7 +51,12 @@ static void closefile(void *p) { fclose((FILE *)p); } LUTAB ofiletab = LU_SINIT(free,closefile); /* output file table */ +#define OF_MODIFIER 01 +#define OF_BIN 02 + FILE *getofile(const char *ospec, const char *mname, int bn); +int ofname(char *oname, const char *ospec, const char *mname, int bn); +void printheader(FILE *fout, const char *info); /* * The rcont structure is used to manage i/o with a particular @@ -67,7 +74,8 @@ struct rtproc { }; /* rtrace process buffer */ /* rtrace command and defaults */ -char *rtargv[256] = { "rtrace", "-dj", ".5", "-dr", "3", +char *rtargv[256+2*MAXMODLIST] = { "rtrace", + "-dj", ".5", "-dr", "3", "-ab", "1", "-ad", "128", }; int rtargc = 9; /* overriding rtrace options */ @@ -93,7 +101,7 @@ int header = 1; /* output header? */ int xres = 0; /* horiz. output resolution */ int yres = 0; /* vert. output resolution */ -long raysleft; /* number of rays left to trace */ +unsigned long raysleft; /* number of rays left to trace */ long waitflush; /* how long until next flush */ unsigned long lastray = 0; /* last ray number sent */ @@ -105,16 +113,18 @@ const char *modname[MAXMODLIST]; /* ordered modifier n int nmods = 0; /* number of modifiers */ MODCONT *addmodifier(char *modn, char *outf, char *binv); +void addmodfile(char *fname, char *outf, char *binv); void init(int np); int done_rprocs(struct rtproc *rtp); -void trace_contribs(FILE *fp); +void recover_output(FILE *fin); +void trace_contribs(FILE *fin); struct rtproc *wait_rproc(void); struct rtproc *get_rproc(void); void queue_raytree(struct rtproc *rtp); void process_queue(void); -void putcontrib(const DCOLOR cnt, FILE *fout); +void put_contrib(const DCOLOR cnt, FILE *fout); void add_contrib(const char *modn); void done_contrib(void); @@ -123,9 +133,11 @@ static void setformat(const char *fmt) { switch (fmt[0]) { - case 'a': case 'f': case 'd': + SET_FILE_BINARY(stdin); + /* fall through */ + case 'a': inpfmt = fmt[0]; break; default: @@ -156,15 +168,17 @@ int main(int argc, char *argv[]) { int nprocs = 1; + int recover = 0; char *curout = NULL; char *binval = NULL; char fmt[8]; int i, j; /* global program name */ gargv = argv; - /* set up calcomp mode */ + /* initialize calcomp routines */ esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW; esupport &= ~(E_OUTCHAN); + varset("PI", ':', PI); /* get our options */ for (i = 1; i < argc-1; i++) { /* expand arguments */ @@ -177,6 +191,10 @@ main(int argc, char *argv[]) } if (argv[i][0] == '-') switch (argv[i][1]) { + case 'r': /* recover output */ + if (argv[i][2]) break; + recover++; + continue; case 'n': /* number of processes */ if (argv[i][2] || i >= argc-1) break; nprocs = atoi(argv[++i]); @@ -202,8 +220,17 @@ main(int argc, char *argv[]) break; case 'f': /* file or i/o format */ if (!argv[i][2]) { + char *fpath; if (i >= argc-1) break; - fcompile(argv[++i]); + fpath = getpath(argv[++i], + getrlibpath(), R_OK); + if (fpath == NULL) { + sprintf(errmsg, + "cannot find file '%s'", + argv[i]); + error(USER, errmsg); + } + fcompile(fpath); continue; } setformat(argv[i]+2); @@ -234,6 +261,12 @@ main(int argc, char *argv[]) rtargv[rtargc++] = argv[++i]; addmodifier(argv[i], curout, binval); continue; + case 'M': /* modifier file */ + if (argv[i][2] || i >= argc-1) break; + rtargv[rtargc++] = "-tI"; + rtargv[rtargc++] = argv[++i]; + addmodfile(argv[i], curout, binval); + continue; } rtargv[rtargc++] = argv[i]; /* assume rtrace option */ } @@ -284,6 +317,8 @@ main(int argc, char *argv[]) rtargv[rtargc] = NULL; /* start rtrace & compute contributions */ init(nprocs); + if (recover) /* perform recovery if requested */ + recover_output(stdin); trace_contribs(stdin); quit(0); } @@ -389,7 +424,7 @@ init(int np) rtp->next = NULL; /* terminate list */ if (yres > 0) { if (xres > 0) - raysleft = xres*yres; + raysleft = (unsigned long)xres*yres; else raysleft = yres; } else @@ -427,6 +462,21 @@ addmodifier(char *modn, char *outf, char *binv) return mp; } +/* add modifiers from a file list */ +void +addmodfile(char *fname, char *outf, char *binv) +{ + char *mname[MAXMODLIST]; + int i; + /* find the file & store strings */ + if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) { + sprintf(errmsg, "cannot find modifier file '%s'", fname); + error(SYSTEM, errmsg); + } + for (i = 0; mname[i]; i++) /* add each one */ + addmodifier(mname[i], outf, binv); +} + /* put string to stderr */ void eputs(char *s) @@ -442,9 +492,60 @@ eputs(char *s) midline = s[strlen(s)-1] != '\n'; } +/* construct output file name and return flags whether modifier/bin present */ +int +ofname(char *oname, const char *ospec, const char *mname, int bn) +{ + const char *mnp = NULL; + const char *bnp = NULL; + const char *cp; + + if (ospec == NULL) + return -1; + for (cp = ospec; *cp; cp++) /* check format position(s) */ + if (*cp == '%') { + do + ++cp; + while (isdigit(*cp)); + switch (*cp) { + case '%': + break; + case 's': + if (mnp != NULL) + return -1; + mnp = cp; + break; + case 'd': + if (bnp != NULL) + return -1; + bnp = cp; + break; + default: + return -1; + } + } + if (mnp != NULL) { /* create file name */ + if (bnp != NULL) { + if (bnp > mnp) + sprintf(oname, ospec, mname, bn); + else + sprintf(oname, ospec, bn, mname); + return OF_MODIFIER|OF_BIN; + } + sprintf(oname, ospec, mname); + return OF_MODIFIER; + } + if (bnp != NULL) { + sprintf(oname, ospec, bn); + return OF_BIN; + } + strcpy(oname, ospec); + return 0; +} + /* write header to the given output stream */ void -printheader(FILE *fout) +printheader(FILE *fout, const char *info) { extern char VersionID[]; FILE *fin = fopen(octree, "r"); @@ -456,6 +557,8 @@ printheader(FILE *fout) printargs(gargc-1, gargv, fout); /* add our command */ fprintf(fout, "SOFTWARE= %s\n", VersionID); fputnow(fout); + if (info != NULL) /* add extra info if given */ + fputs(info, fout); switch (outfmt) { /* add output format */ case 'a': fputformat("ascii", fout); @@ -482,68 +585,59 @@ printheader(FILE *fout) FILE * getofile(const char *ospec, const char *mname, int bn) { - const char *mnp = NULL; - const char *bnp = NULL; - const char *cp; - char ofname[1024]; + int ofl; + char oname[1024]; LUENT *lep; if (ospec == NULL) { /* use stdout? */ - if (!using_stdout && header) - printheader(stdout); + if (!using_stdout) { + if (outfmt != 'a') + SET_FILE_BINARY(stdout); + if (header) + printheader(stdout, NULL); + } using_stdout = 1; return stdout; } - for (cp = ospec; *cp; cp++) /* check format position(s) */ - if (*cp == '%') { - do - ++cp; - while (isdigit(*cp)); - switch (*cp) { - case '%': - break; - case 's': - if (mnp != NULL) - goto badspec; - mnp = cp; - break; - case 'd': - if (bnp != NULL) - goto badspec; - bnp = cp; - break; - default: - goto badspec; - } - } - if (mnp != NULL) { /* create file name */ - if (bnp != NULL) { - if (bnp > mnp) - sprintf(ofname, ospec, mname, bn); - else - sprintf(ofname, ospec, bn, mname); - } else - sprintf(ofname, ospec, mname); - } else if (bnp != NULL) - sprintf(ofname, ospec, bn); - else - strcpy(ofname, ospec); - lep = lu_find(&ofiletab, ofname); /* look it up */ + ofl = ofname(oname, ospec, mname, bn); /* get output name */ + if (ofl < 0) { + sprintf(errmsg, "bad output format '%s'", ospec); + error(USER, errmsg); + } + lep = lu_find(&ofiletab, oname); /* look it up */ if (lep->key == NULL) /* new entry */ - lep->key = strcpy((char *)malloc(strlen(ofname)+1), ofname); + lep->key = strcpy((char *)malloc(strlen(oname)+1), oname); if (lep->data == NULL) { /* open output file */ - FILE *fp = fopen(ofname, "w"); + FILE *fp; int i; + if (oname[0] == '!') /* output to command */ + fp = popen(oname+1, "w"); + else + fp = fopen(oname, "w"); if (fp == NULL) { - sprintf(errmsg, "cannot open '%s' for writing", ofname); + sprintf(errmsg, "cannot open '%s' for writing", oname); error(SYSTEM, errmsg); } - if (header) - printheader(fp); + if (outfmt != 'a') + SET_FILE_BINARY(fp); + if (header) { + char info[512]; + char *cp = info; + if (ofl & OF_MODIFIER) { + sprintf(cp, "MODIFIER=%s\n", mname); + while (*cp) ++cp; + } + if (ofl & OF_BIN) { + sprintf(cp, "BIN=%d\n", bn); + while (*cp) ++cp; + } + *cp = '\0'; + printheader(fp, info); + } /* play catch-up */ for (i = 0; i < lastdone; i++) { static const DCOLOR nocontrib = BLKCOLOR; - putcontrib(nocontrib, fp); + put_contrib(nocontrib, fp); if (outfmt == 'a') putc('\n', fp); } @@ -552,10 +646,6 @@ getofile(const char *ospec, const char *mname, int bn) lep->data = (char *)fp; } return (FILE *)lep->data; /* return open file pointer */ -badspec: - sprintf(errmsg, "bad output format '%s'", ospec); - error(USER, errmsg); - return NULL; /* pro forma return */ } /* read input ray into buffer */ @@ -649,7 +739,7 @@ puteol(const LUENT *e, void *p) /* put out ray contribution to file */ void -putcontrib(const DCOLOR cnt, FILE *fout) +put_contrib(const DCOLOR cnt, FILE *fout) { float fv[3]; COLR cv; @@ -682,11 +772,19 @@ done_contrib(void) { int i, j; MODCONT *mp; + FILE *fp; /* output modifiers in order */ for (i = 0; i < nmods; i++) { mp = (MODCONT *)lu_find(&modconttab,modname[i])->data; - for (j = 0; j < mp->nbins; j++) - putcontrib(mp->cbin[j], + fp = getofile(mp->outspec, mp->modname, 0); + put_contrib(mp->cbin[0], fp); + if (mp->nbins > 3 && /* minor optimization */ + fp == getofile(mp->outspec, mp->modname, 1)) + for (j = 1; j < mp->nbins; j++) + put_contrib(mp->cbin[j], fp); + else + for (j = 1; j < mp->nbins; j++) + put_contrib(mp->cbin[j], getofile(mp->outspec, mp->modname, j)); /* clear for next ray tree */ memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins); @@ -858,12 +956,146 @@ trace_contribs(FILE *fin) rtp = get_rproc(); /* get avail. rtrace process */ rtp->raynum = ++lastray; /* assign ray to it */ writebuf(rtp->pd.w, inpbuf, iblen); - if (!--raysleft) + if (raysleft && !--raysleft) break; process_queue(); /* catch up with results */ } while (wait_rproc() != NULL) /* process outstanding rays */ process_queue(); - if (raysleft > 0) + if (raysleft) error(USER, "unexpected EOF on input"); + lu_done(&ofiletab); /* close output files */ +} + +/* seek on the given output file */ +static int +myseeko(const LUENT *e, void *p) +{ + if (fseeko((FILE *)e->data, *(off_t *)p, SEEK_CUR) < 0) { + sprintf(errmsg, "seek error on file '%s'", e->key); + error(SYSTEM, errmsg); + } +} + +/* recover output if possible */ +void +recover_output(FILE *fin) +{ + off_t lastout = -1; + int outvsiz; + char *outvfmt; + int i, j; + MODCONT *mp; + int ofl; + char oname[1024]; + LUENT *ment, *oent; + FILE *fp; + off_t nvals; + + switch (outfmt) { + case 'a': + error(USER, "cannot recover ASCII output"); + return; + case 'f': + outvsiz = sizeof(float)*3; + outvfmt = "float"; + break; + case 'd': + outvsiz = sizeof(double)*3; + outvfmt = "double"; + break; + case 'c': + outvsiz = sizeof(COLR); + outvfmt = COLRFMT; + break; + default: + error(INTERNAL, "botched output format"); + return; + } + /* check modifier outputs */ + for (i = 0; i < nmods; i++) { + ment = lu_find(&modconttab,modname[i]); + mp = (MODCONT *)ment->data; + if (mp->outspec == NULL) + error(USER, "cannot recover from stdout"); + for (j = 0; ; j++) { /* check each bin's file */ + ofl = ofname(oname, mp->outspec, mp->modname, j); + if (ofl < 0) + error(USER, "bad output file specification"); + oent = lu_find(&ofiletab, oname); + if (oent->data != NULL) { /* saw this one already */ + if (ofl & OF_BIN) + continue; + break; + } + if (oname[0] == '!') + error(USER, "cannot recover from command"); + /* open output */ + fp = fopen(oname, "rb+"); + if (fp == NULL) + break; /* must be end of modifier */ + nvals = lseek(fileno(fp), 0, SEEK_END); + if (nvals <= 0) { + lastout = 0; /* empty output, quit here */ + fclose(fp); + break; + } + lseek(fileno(fp), 0, SEEK_SET); + if (header) { + int xr, yr; + if (checkheader(fp, outvfmt, NULL) != 1) { + sprintf(errmsg, + "format mismatch for '%s'", + oname); + error(USER, errmsg); + } + if (xres > 0 && yres > 0 && + (!fscnresolu(&xr, &yr, fp) || + xr != xres || + yr != yres)) { + sprintf(errmsg, + "resolution mismatch for '%s'", + oname); + error(USER, errmsg); + } + } + nvals = (nvals - (off_t)ftell(fp)) / outvsiz; + if (lastout < 0 || nvals < lastout) + lastout = nvals; + if (oent->key == NULL) /* new entry */ + oent->key = strcpy((char *) + malloc(strlen(oname)+1), oname); + oent->data = (char *)fp; + if (!(ofl & OF_BIN)) + break; /* no bin separation */ + } + if (!lastout) { /* empty output */ + error(WARNING, "no previous data to recover"); + lu_done(&ofiletab); /* reclose all outputs */ + return; + } + if (j > mp->nbins) { /* preallocate modifier bins */ + mp = (MODCONT *)realloc(mp, sizeof(MODCONT) + + (j-1)*sizeof(DCOLOR)); + if (mp == NULL) + error(SYSTEM, "out of memory in recover_output"); + memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins); + mp->nbins = j; + ment->data = (char *)mp; + } + } + if (lastout < 0) { + error(WARNING, "no output files to recover"); + return; + } + /* seek on all files */ + nvals = lastout * outvsiz; + lu_doall(&ofiletab, myseeko, &nvals); + /* discard input */ + for (nvals = 0; nvals < lastout; nvals++) + if (getinp(oname, fin) <= 0) + error(USER, "unexpected EOF on input"); + lastray = lastdone = (unsigned long)lastout; + if (raysleft) + raysleft -= lastray; }
