root/radiance/ray/src/util/rtcontrib.c
Wed Jun 7 17:52:04 2006 UTC (19 years, 1 month ago) by schorsch
Changes since 1.42: +2 -1 lines
Diff to previous 1.42 , to selected 1.28
Wed Apr 5 14:33:34 2006 UTC (19 years, 3 months ago) by greg
Changes since 1.41: +2 -2 lines
Diff to previous 1.41 , to selected 1.28
Increased default -ad from 128 to 350
Wed Mar 29 17:31:59 2006 UTC (19 years, 3 months ago) by greg
Changes since 1.40: +2 -2 lines
Diff to previous 1.40 , to selected 1.28
Minor correction to avoid segfault with illegal option
Sun Feb 5 22:22:21 2006 UTC (19 years, 5 months ago) by greg
Changes since 1.39: +35 -9 lines
Diff to previous 1.39 , to selected 1.28
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Fri Oct 21 01:12:59 2005 UTC (19 years, 8 months ago) by greg
Changes since 1.38: +4 -1 lines
Diff to previous 1.38 , to selected 1.28
Added check for -P and -PP option, which causes conflict
Tue Oct 11 23:55:37 2005 UTC (19 years, 8 months ago) by greg
Changes since 1.37: +4 -4 lines
Diff to previous 1.37 , to selected 1.28
Minor fix to ray flushing
Tue Oct 11 23:41:45 2005 UTC (19 years, 8 months ago) by greg
Changes since 1.36: +2 -2 lines
Diff to previous 1.36 , to selected 1.28
Fixed rtcontrib flushing behavior
Tue Oct 11 19:02:51 2005 UTC (19 years, 8 months ago) by greg
Changes since 1.35: +33 -13 lines
Diff to previous 1.35 , to selected 1.28
Made it so zero ray directions flush output in rtcontrib
Tue Oct 11 16:54:26 2005 UTC (19 years, 8 months ago) by greg
Changes since 1.34: +10 -3 lines
Diff to previous 1.34 , to selected 1.28
Added rtcontrib -fo option to override new reluctance to clobber existing files
Tue Oct 11 04:27:41 2005 UTC (19 years, 9 months ago) by greg
Changes since 1.33: +9 -7 lines
Diff to previous 1.33 , to selected 1.28
Fixed bug introduced in rev 1.29 (Oct 5 2005) that broke output synchronization
Fri Oct 7 03:45:15 2005 UTC (19 years, 9 months ago) by greg
Changes since 1.32: +6 -3 lines
Diff to previous 1.32 , to selected 1.28
Added final write error check
Thu Oct 6 16:28:59 2005 UTC (19 years, 9 months ago) by greg
Changes since 1.31: +19 -19 lines
Diff to previous 1.31 , to selected 1.28
Fixes in new rtcontrib -bn option
Thu Oct 6 05:49:44 2005 UTC (19 years, 9 months ago) by greg
Changes since 1.30: +176 -106 lines
Diff to previous 1.30 , to selected 1.28
Wed Oct 5 19:44:17 2005 UTC (19 years, 9 months ago) by greg
Changes since 1.29: +14 -3 lines
Diff to previous 1.29 , to selected 1.28
Minor improvements in output file consistency with rtrace
Wed Oct 5 05:20:21 2005 UTC (19 years, 9 months ago) by greg
Changes since 1.28: +17 -2 lines
Diff to previous 1.28
Bug fix for some systems where rtrace process gets stuck for unknown reasons
Revision 1.28 - (view) (download) (annotate) - [selected]
Wed Sep 21 17:17:24 2005 UTC (19 years, 9 months ago) by greg
Changes since 1.27: +3 -3 lines
Diff to previous 1.27
Tue Sep 20 17:05:11 2005 UTC (19 years, 9 months ago) by greg
Changes since 1.26: +2 -2 lines
Diff to previous 1.26 , to selected 1.28
Fixed serious bug where rtcontrib would sometimes forget to write last file
Mon Sep 19 11:30:11 2005 UTC (19 years, 9 months ago) by schorsch
Changes since 1.25: +5 -2 lines
Diff to previous 1.25 , to selected 1.28
Tue Sep 13 22:58:22 2005 UTC (19 years, 9 months ago) by greg
Changes since 1.24: +8 -1 lines
Diff to previous 1.24 , to selected 1.28
Added check for no arguments
Fri Jun 17 16:07:18 2005 UTC (20 years ago) by greg
Changes since 1.23: +8 -3 lines
Diff to previous 1.23 , to selected 1.28
Added check for complete output with -r option
Thu Jun 16 19:37:26 2005 UTC (20 years ago) by greg
Changes since 1.22: +8 -3 lines
Diff to previous 1.22 , to selected 1.28
Added check for missing recover files
Tue Jun 14 02:50:23 2005 UTC (20 years ago) by greg
Changes since 1.21: +3 -5 lines
Diff to previous 1.21 , to selected 1.28
Made it so MODIFIER= line added to every header
Sat Jun 11 15:01:03 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.20: +10 -10 lines
Diff to previous 1.20 , to selected 1.28
Fixed argument checking
Fri Jun 10 20:53:55 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.19: +6 -3 lines
Diff to previous 1.19 , to selected 1.28
Fixed it so rtcontrib -M option searches RAYPATH directories
Fri Jun 10 20:44:00 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.18: +6 -2 lines
Diff to previous 1.18 , to selected 1.28
Fixe in rtcontrib -M option
Fri Jun 10 20:38:38 2005 UTC (20 years, 1 month ago) by greg
Diff to previous 1.17 , to selected 1.28
Fixed array overrun with large number of modifiers
Fri Jun 10 16:42:11 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.16: +18 -1 lines
Diff to previous 1.16 , to selected 1.28
Added rtcontrib -M option to read modifier list from a file
Thu Jun 9 18:33:06 2005 UTC (20 years, 1 month ago) by greg
Diff to previous 1.15 , to selected 1.28
Warning wording tweaks
Thu Jun 9 18:27:44 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.14: +5 -1 lines
Diff to previous 1.14 , to selected 1.28
Added warning & check for case where no output files exist with -r option
Thu Jun 9 17:27:28 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.13: +238 -65 lines
Diff to previous 1.13 , to selected 1.28
Sun Jun 5 19:52:01 2005 UTC (20 years, 1 month ago) by greg
Diff to previous 1.12 , to selected 1.28
Fri Jun 3 14:29:42 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.11: +11 -3 lines
Diff to previous 1.11 , to selected 1.28
Minor optimization to reduce calls to getofile()
Thu Jun 2 18:51:46 2005 UTC (20 years, 1 month ago) by greg
Diff to previous 1.10 , to selected 1.28
Added missing definition of PI for calcomp routines
Thu Jun 2 04:47:27 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.9: +17 -5 lines
Diff to previous 1.9 , to selected 1.28
Wed Jun 1 16:11:01 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.8: +11 -2 lines
Diff to previous 1.8 , to selected 1.28
Tue May 31 18:01:09 2005 UTC (20 years, 1 month ago) by greg
Diff to previous 1.7 , to selected 1.28
Tue May 31 03:48:59 2005 UTC (20 years, 1 month ago) by greg
Diff to previous 1.6 , to selected 1.28
Added missing include for signal.h
Sat May 28 22:27:54 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.5: +5 -6 lines
Diff to previous 1.5 , to selected 1.28
Thu May 26 21:35:35 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.4: +10 -9 lines
Diff to previous 1.4 , to selected 1.28
Minor code tweaks
Thu May 26 17:53:28 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.3: +15 -5 lines
Diff to previous 1.3 , to selected 1.28
Thu May 26 15:14:42 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.2: +59 -44 lines
Diff to previous 1.2 , to selected 1.28
Improved efficiency of queuing behavior to avoid idle process time
Thu May 26 06:55:22 2005 UTC (20 years, 1 month ago) by greg
Changes since 1.1: +183 -164 lines
Diff to previous 1.1 , to selected 1.28
Wed May 25 04:45:22 2005 UTC (20 years, 1 month ago) by greg
Diff to selected 1.28
