root/radiance/ray/src/util/rtcontrib.c
Revision: 1.2
Committed: Thu May 26 06:55:22 2005 UTC (20 years ago) by greg
Changes since 1.1: +183 -164 lines
2 static const char RCSid[] = "$Id: rtcontrib.c,v 1.1 2005/05/25 04:45:22 greg Exp $";
5 * Gather rtrace output to compute contributions from particular sources
6 */
7
8 #include <ctype.h>
9 #include "rtio.h"
10 #include "rterror.h"
11 #include "platform.h"
12 #include "rtprocess.h"
13 #include "selcall.h"
14 #include "color.h"
15 #include "resolu.h"
16 #include "lookup.h"
17 #include "calcomp.h"
18
19 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
20
21 int treebufsiz = BUFSIZ; /* current tree buffer size */
22
23 typedef double DCOLOR[3]; /* double-precision color */
24
25 /*
26 * The modcont structure is used to accumulate ray contributions
27 * for a particular modifier, which may be subdivided into bins
28 * if binv is non-NULL. If outspec contains a %s in it, this will
29 * be replaced with the modifier name. If outspec contains a %d in it,
30 * this will be used to create one output file per bin, otherwise all bins
31 * will be written to the same file, in order. If the global outfmt
32 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
33 * and the file will conform to a RADIANCE image if xres & yres are set.
34 */
35 typedef struct {
36 const char *outspec; /* output file specification */
37 const char *modname; /* modifier name */
38 EPNODE *binv; /* bin value expression */
39 int nbins; /* number of accumulation bins */
40 DCOLOR cbin[1]; /* contribution bins (extends struct) */
41 } MODCONT; /* modifier contribution */
42
43 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
44
45 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
46
47 /* close output stream */
48 static void closefile(void *p) { fclose((FILE *)p); }
49
50 LUTAB ofiletab = LU_SINIT(free,closefile); /* output file table */
51
52 FILE *getofile(const char *ospec, const char *mname, int bn);
53
54 /*
55 * The rcont structure is used to manage i/o with a particular
56 * rtrace child process. Input is passed unchanged from stdin,
57 * and output is processed in input order and accumulated according
58 * to the corresponding modifier and bin number.
59 */
60 struct rtproc {
61 struct rtproc *next; /* next in list of processes */
62 SUBPROC pd; /* rtrace pipe descriptors */
63 unsigned long raynum; /* ray number for this tree */
64 int bsiz; /* ray tree buffer length */
65 char *buf; /* ray tree buffer */
66 int nbr; /* number of bytes from rtrace */
67 }; /* rtrace process */
68
69 /* rtrace command and defaults */
70 char *rtargv[256] = { "rtrace", "-dt", "0", "-dj", ".5", "-dr", "3",
71 "-ab", "1", "-ad", "512", };
72 int rtargc = 11;
73 /* overriding rtrace options */
74 char *myrtopts[] = { "-o~~TmWdp", "-h-",
75 "-x", "1", "-y", "0",
76 "-as", "0", "-aa", "0", NULL };
77
78 struct rtproc rt0; /* head of rtrace process list */
79
80 struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
81
82 char persistfn[] = "pfXXXXXX"; /* persist file name */
83 char fmt[8]; /* rtrace i/o format */
84
85 int gargc; /* global argc */
86 char **gargv; /* global argv */
87 #define progname gargv[0]
88
89 char *octree; /* global octree argument */
90
91 int inpfmt = 'a'; /* input format */
92 int outfmt = 'a'; /* output format */
93
94 int header = 1; /* output header? */
95 int xres = 0; /* horiz. output resolution */
96 int yres = 0; /* vert. output resolution */
97
98 long raysleft; /* number of rays left to trace */
99 long waitflush; /* how long until next flush */
100
101 unsigned long lastray = 0; /* last ray number sent */
102 unsigned long lastdone = 0; /* last ray processed */
103
104 int using_stdout = 0; /* are we using stdout? */
105
106 const char *modname[MAXMODLIST]; /* ordered modifier name list */
107 int nmods = 0; /* number of modifiers */
108
109 MODCONT *addmodifier(char *modn, char *outf, char *binv);
110
111 int done_rprocs(struct rtproc *rtp);
112 void init(int np);
113 void tracecontribs(FILE *fp);
114 struct rtproc *wait_rproc(void);
115 struct rtproc *get_rproc(void);
116 void process_rays(struct rtproc *rtp);
117
118 void putcontrib(const DCOLOR cnt, FILE *fout);
119 void add_contrib(const char *modn);
120 void done_contrib(void);
121
122 /* set input/output format */
123 static void
124 setformat(const char *fmt)
125 {
126 switch (fmt[0]) {
127 case 'a':
128 case 'f':
129 case 'd':
130 inpfmt = fmt[0];
131 break;
132 default:
133 goto fmterr;
134 }
135 switch (fmt[1]) {
136 case '\0':
137 outfmt = inpfmt;
138 return;
139 case 'a':
140 case 'f':
141 case 'd':
142 case 'c':
143 outfmt = fmt[1];
144 break;
145 default:
146 goto fmterr;
147 }
148 if (!fmt[2])
149 return;
150 fmterr:
151 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
152 error(USER, errmsg);
153 }
154
155 /* gather rays from rtrace and output contributions */
156 int
157 main(int argc, char *argv[])
158 {
159 int nprocs = 1;
160 char *curout = NULL;
161 char *binval = NULL;
162 int i, j;
163 /* global program name */
164 gargv = argv;
165 /* set up calcomp mode */
166 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
167 esupport &= ~(E_OUTCHAN);
168 /* get our options */
169 for (i = 1; i < argc-1; i++) {
170 /* expand arguments */
171 while ((j = expandarg(&argc, &argv, i)) > 0)
172 ;
173 if (j < 0) {
174 fprintf(stderr, "%s: cannot expand '%s'",
175 argv[0], argv[i]);
176 exit(1);
177 }
178 if (argv[i][0] == '-')
179 switch (argv[i][1]) {
180 case 'n': /* number of processes */
181 if (argv[i][2] || i >= argc-1) break;
182 nprocs = atoi(argv[++i]);
183 if (nprocs <= 0)
184 error(USER, "illegal number of processes");
185 continue;
186 case 'h': /* output header? */
187 switch (argv[i][2]) {
188 case '\0':
189 header = !header;
190 continue;
191 case '+': case '1': case 'T': case 't':
192 header = 1;
193 continue;
194 case '-': case '0': case 'F': case 'f':
195 header = 0;
196 continue;
197 }
198 break;
199 case 'f': /* file or i/o format */
200 if (!argv[i][2]) {
201 if (i >= argc-1) break;
202 fcompile(argv[++i]);
203 continue;
204 }
205 setformat(argv[i]+2);
206 continue;
207 case 'e': /* expression */
208 if (argv[i][2] || i >= argc-1) break;
209 scompile(argv[++i], NULL, 0);
210 continue;
211 case 'o': /* output file spec. */
212 if (argv[i][2] || i >= argc-1) break;
213 curout = argv[++i];
214 continue;
215 case 'x': /* horiz. output resolution */
216 if (argv[i][2] || i >= argc-1) break;
217 xres = atoi(argv[++i]);
218 continue;
219 case 'y': /* vert. output resolution */
220 if (argv[i][2] || i >= argc-1) break;
221 yres = atoi(argv[++i]);
222 continue;
223 case 'b': /* bin expression */
224 if (argv[i][2] || i >= argc-1) break;
225 binval = argv[++i];
226 continue;
227 case 'm': /* modifier name */
228 if (argv[i][2] || i >= argc-1) break;
229 rtargv[rtargc++] = "-ti";
230 rtargv[rtargc++] = argv[++i];
231 addmodifier(argv[i], curout, binval);
232 continue;
233 }
234 rtargv[rtargc++] = argv[i]; /* assume rtrace option */
235 }
236 /* set global argument list */
237 gargc = argc; gargv = argv;
238 /* add "mandatory" rtrace settings */
239 for (j = 0; myrtopts[j] != NULL; j++)
240 rtargv[rtargc++] = myrtopts[j];
241 /* just asking for defaults? */
242 if (!strcmp(argv[i], "-defaults")) {
243 char sxres[16], syres[16];
244 char *rtpath;
245 printf("-n %-2d\t\t\t\t# number of processes\n", nprocs);
246 fflush(stdout); /* report OUR options */
247 rtargv[rtargc++] = header ? "-h+" : "-h-";
248 sprintf(fmt, "-f%c%c", inpfmt, outfmt);
249 rtargv[rtargc++] = fmt;
250 rtargv[rtargc++] = "-x";
251 sprintf(sxres, "%d", xres);
252 rtargv[rtargc++] = sxres;
253 rtargv[rtargc++] = "-y";
254 sprintf(syres, "%d", yres);
255 rtargv[rtargc++] = syres;
256 rtargv[rtargc++] = "-oTW";
257 rtargv[rtargc++] = "-defaults";
258 rtargv[rtargc] = NULL;
259 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
260 if (rtpath == NULL) {
261 eputs(rtargv[0]);
262 eputs(": command not found\n");
263 exit(1);
264 }
265 execv(rtpath, rtargv);
266 perror(rtpath); /* execv() should not return */
267 exit(1);
268 } else if (nprocs > 1) { /* add persist file if parallel */
269 rtargv[rtargc++] = "-PP";
270 rtargv[rtargc++] = mktemp(persistfn);
271 }
272 /* add format string */
273 sprintf(fmt, "-f%cf", inpfmt);
274 rtargv[rtargc++] = fmt;
275 /* octree argument is last */
276 if (i <= 0 || i != argc-1 || argv[i][0] == '-')
277 error(USER, "missing octree argument");
278 rtargv[rtargc++] = octree = argv[i];
279 rtargv[rtargc] = NULL;
280 /* start rtrace & compute contributions */
281 init(nprocs);
282 tracecontribs(stdin);
283 quit(0);
284 }
285
286 /* kill persistent rtrace process */
287 static void
288 killpersist(void)
289 {
290 FILE *fp = fopen(persistfn, "r");
291 int pid;
292
293 if (fp == NULL)
294 return;
295 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
296 unlink(persistfn);
297 fclose(fp);
298 }
299
300 /* close rtrace processes and clean up */
301 int
302 done_rprocs(struct rtproc *rtp)
303 {
304 int st0, st1 = 0;
305
306 if (rtp->next != NULL) { /* close last opened first! */
307 st1 = done_rprocs(rtp->next);
308 free((void *)rtp->next);
309 rtp->next = NULL;
310 }
311 st0 = close_process(&rtp->pd);
312 if (st0 < 0)
313 error(WARNING, "unknown return status from rtrace process");
314 else if (st0 > 0)
315 return(st0);
316 return(st1);
317 }
318
319 /* exit with status */
320 void
321 quit(int status)
322 {
323 int rtstat;
324
325 if (rt0.next != NULL) /* terminate persistent rtrace */
326 killpersist();
327 /* clean up rtrace process(es) */
328 rtstat = done_rprocs(&rt0);
329 if (status == 0)
330 status = rtstat;
331 exit(status); /* flushes all output streams */
332 }
333
334 /* start rtrace and initialize buffers */
335 void
336 init(int np)
337 {
338 struct rtproc *rtp;
339 int i;
340 int maxbytes;
341 /* make sure we have something to do */
342 if (!nmods)
343 error(USER, "No modifiers specified");
344 /* assign ray variables */
345 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
346 scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
347 /* set up signal handling */
348 #ifdef SIGPIPE /* not present on Windows */
349 signal(SIGPIPE, quit);
350 #endif
351 rtp = &rt0; /* start rtrace process(es) */
352 for (i = 0; i++ < np; ) {
353 errno = 0;
354 maxbytes = open_process(&rtp->pd, rtargv);
355 if (maxbytes == 0) {
356 eputs(rtargv[0]);
357 eputs(": command not found\n");
358 exit(1);
359 }
360 if (maxbytes < 0)
361 error(SYSTEM, "cannot start rtrace process");
362 if (maxbytes > treebufsiz)
363 treebufsiz = maxbytes;
364 rtp->raynum = 0;
365 rtp->bsiz = 0;
366 rtp->buf = NULL;
367 rtp->nbr = 0;
368 if (i == np) /* last process? */
369 break;
370 if (i == 1)
371 sleep(2); /* wait for persist file */
372 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
373 if (rtp->next == NULL)
374 error(SYSTEM, "out of memory in init");
375 rtp = rtp->next;
376 }
377 rtp->next = NULL; /* terminate list */
378 if (yres > 0) {
379 if (xres > 0)
380 raysleft = xres*yres;
381 else
382 raysleft = yres;
383 } else
384 raysleft = 0;
385 waitflush = xres;
386 }
387
388 /* add modifier to our list to track */
389 MODCONT *
390 addmodifier(char *modn, char *outf, char *binv)
391 {
392 LUENT *lep = lu_find(&modconttab, modn);
393 MODCONT *mp;
394
395 if (lep->data != NULL) {
396 sprintf(errmsg, "duplicate modifier '%s'", modn);
397 error(USER, errmsg);
398 }
399 if (nmods >= MAXMODLIST)
400 error(USER, "too many modifiers");
401 modname[nmods++] = modn; /* XXX assumes static string */
402 lep->key = modn; /* XXX assumes static string */
403 mp = (MODCONT *)malloc(sizeof(MODCONT));
404 if (mp == NULL)
405 error(SYSTEM, "out of memory in addmodifier");
406 lep->data = (char *)mp;
407 mp->outspec = outf; /* XXX assumes static string */
408 mp->modname = modn; /* XXX assumes static string */
409 if (binv != NULL)
410 mp->binv = eparse(binv);
411 else
412 mp->binv = eparse("0");
413 mp->nbins = 1;
414 setcolor(mp->cbin[0], 0., 0., 0.);
415 return mp;
416 }
417
418 /* put string to stderr */
419 void
420 eputs(char *s)
421 {
422 static int midline = 0;
423
424 if (!*s) return;
425 if (!midline) {
426 fputs(progname, stderr);
427 fputs(": ", stderr);
428 }
429 fputs(s, stderr);
430 midline = s[strlen(s)-1] != '\n';
431 }
432
433 /* write header to the given output stream */
434 void
435 printheader(FILE *fout)
436 {
437 extern char VersionID[];
438 FILE *fin = fopen(octree, "r");
439
440 if (fin == NULL)
441 quit(1);
442 checkheader(fin, "ignore", fout); /* copy octree header */
443 fclose(fin);
444 printargs(gargc-1, gargv, fout); /* add our command */
445 fprintf(fout, "SOFTWARE= %s\n", VersionID);
446 fputnow(fout);
447 switch (outfmt) { /* add output format */
448 case 'a':
449 fputformat("ascii", fout);
450 break;
451 case 'f':
452 fputformat("float", fout);
453 break;
454 case 'd':
455 fputformat("double", fout);
456 break;
457 case 'c':
458 fputformat(COLRFMT, fout);
459 break;
460 }
461 fputc('\n', fout);
462 if (xres > 0) {
463 if (yres > 0) /* resolution string */
464 fprtresolu(xres, yres, fout);
465 fflush(fout);
466 }
467 }
468
469 /* Get output file pointer (open and write header if new) */
470 FILE *
471 getofile(const char *ospec, const char *mname, int bn)
472 {
473 const char *mnp = NULL;
474 const char *bnp = NULL;
475 const char *cp;
476 char ofname[1024];
477 LUENT *lep;
478
479 if (ospec == NULL) { /* use stdout? */
480 if (!using_stdout && header)
481 printheader(stdout);
482 using_stdout = 1;
483 return stdout;
484 }
485 for (cp = ospec; *cp; cp++) /* check format position(s) */
486 if (*cp == '%') {
487 do
488 ++cp;
489 while (isdigit(*cp));
490 switch (*cp) {
491 case '%':
492 break;
493 case 's':
494 if (mnp != NULL)
495 goto badspec;
496 mnp = cp;
497 break;
498 case 'd':
499 if (bnp != NULL)
500 goto badspec;
501 bnp = cp;
502 break;
503 default:
504 goto badspec;
505 }
506 }
507 if (mnp != NULL) { /* create file name */
508 if (bnp != NULL) {
509 if (bnp > mnp)
510 sprintf(ofname, ospec, mname, bn);
511 else
512 sprintf(ofname, ospec, bn, mname);
513 } else
514 sprintf(ofname, ospec, mname);
515 } else if (bnp != NULL)
516 sprintf(ofname, ospec, bn);
517 else
518 strcpy(ofname, ospec);
519 lep = lu_find(&ofiletab, ofname); /* look it up */
520 if (lep->key == NULL) /* new entry */
521 lep->key = strcpy((char *)malloc(strlen(ofname)+1), ofname);
522 if (lep->data == NULL) { /* open output file */
523 FILE *fp = fopen(ofname, "w");
524 int i;
525 if (fp == NULL) {
526 sprintf(errmsg, "cannot open '%s' for writing", ofname);
527 error(SYSTEM, errmsg);
528 }
529 if (header)
530 printheader(fp);
531 /* play catch-up */
532 for (i = 0; i < lastdone; i++) {
533 static const DCOLOR nocontrib = BLKCOLOR;
534 putcontrib(nocontrib, fp);
535 if (outfmt == 'a')
536 putc('\n', fp);
537 }
538 if (xres > 0)
539 fflush(fp);
540 lep->data = (char *)fp;
541 }
542 return (FILE *)lep->data; /* return open file pointer */
543 badspec:
544 sprintf(errmsg, "bad output format '%s'", ospec);
545 error(USER, errmsg);
546 return NULL; /* pro forma return */
547 }
548
549 /* read input ray into buffer */
550 int
551 getinp(char *buf, FILE *fp)
552 {
553 switch (inpfmt) {
554 case 'a':
555 if (fgets(buf, 128, fp) == NULL)
556 return 0;
557 return strlen(buf);
558 case 'f':
559 if (fread(buf, sizeof(float), 6, fp) < 6)
560 return 0;
561 return sizeof(float)*6;
562 case 'd':
563 if (fread(buf, sizeof(double), 6, fp) < 6)
564 return 0;
565 return sizeof(double)*6;
566 }
567 error(INTERNAL, "botched input format");
568 return 0; /* pro forma return */
569 }
570
571 static float rparams[9]; /* traced ray parameters */
572
573 /* return channel (ray) value */
574 double
575 chanvalue(int n)
576 {
577 if (--n < 0 || n >= 6)
578 error(USER, "illegal channel number ($N)");
579 return rparams[n+3];
580 }
581
582 /* add current ray contribution to the appropriate modifier bin */
583 void
584 add_contrib(const char *modn)
585 {
586 LUENT *le = lu_find(&modconttab, modn);
587 MODCONT *mp = (MODCONT *)le->data;
588 int bn;
589
590 if (mp == NULL) {
591 sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
592 error(USER, errmsg);
593 }
594 eclock++; /* get bin number */
595 bn = (int)(evalue(mp->binv) + .5);
596 if (bn <= 0)
597 bn = 0;
598 else if (bn > mp->nbins) { /* new bin */
599 mp = (MODCONT *)realloc(mp, sizeof(MODCONT) +
600 bn*sizeof(DCOLOR));
601 if (mp == NULL)
602 error(SYSTEM, "out of memory in add_contrib");
603 memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(bn+1-mp->nbins));
604 mp->nbins = bn+1;
605 le->data = (char *)mp;
606 }
607 addcolor(mp->cbin[bn], rparams);
608 }
609
610 /* output newline to ASCII file and/or flush as requested */
611 static int
612 puteol(const LUENT *e, void *p)
613 {
614 FILE *fp = (FILE *)e->data;
615
616 if (outfmt == 'a')
617 putc('\n', fp);
618 if (!waitflush)
619 fflush(fp);
620 if (ferror(fp)) {
621 sprintf(errmsg, "write error on file '%s'", e->key);
622 error(SYSTEM, errmsg);
623 }
624 return 0;
625 }
626
627 /* put out ray contribution to file */
628 void
629 putcontrib(const DCOLOR cnt, FILE *fout)
630 {
631 float fv[3];
632 COLR cv;
633
634 switch (outfmt) {
635 case 'a':
636 fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
637 break;
638 case 'f':
639 fv[0] = cnt[0];
640 fv[1] = cnt[1];
641 fv[2] = cnt[2];
642 fwrite(fv, sizeof(float), 3, fout);
643 break;
644 case 'd':
645 fwrite(cnt, sizeof(double), 3, fout);
646 break;
647 case 'c':
648 setcolr(cv, cnt[0], cnt[1], cnt[2]);
649 fwrite(cv, sizeof(cv), 1, fout);
650 break;
651 default:
652 error(INTERNAL, "botched output format");
653 }
654 }
655
656 /* output ray tallies and clear for next primary */
657 void
658 done_contrib(void)
659 {
660 int i, j;
661 MODCONT *mp;
662 /* output modifiers in order */
663 for (i = 0; i < nmods; i++) {
664 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
665 for (j = 0; j < mp->nbins; j++)
666 putcontrib(mp->cbin[j],
667 getofile(mp->outspec, mp->modname, j));
668 /* clear for next ray tree */
669 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
670 }
671 --waitflush; /* terminate records */
672 lu_doall(&ofiletab, puteol, NULL);
673 if (using_stdout & (outfmt == 'a'))
674 putc('\n', stdout);
675 if (!waitflush) {
676 waitflush = xres;
677 if (using_stdout)
678 fflush(stdout);
679 }
680 }
681
682 /* process (or save) ray tree produced by rtrace process */
683 void
684 process_rays(struct rtproc *rtp)
685 {
686 struct rtproc *rtu;
687 /* check if time to process it */
688 if (rtp->raynum == lastdone+1) {
689 int n = rtp->nbr;
690 const char *cp = rtp->buf;
691 char modname[128];
692 while (n > 0) { /* process rays */
693 register char *mnp = modname;
694 /* skip leading tabs */
695 while (n > 0 && *cp == '\t') {
696 cp++; n--;
697 }
698 if (!n || !(isalpha(*cp) | (*cp == '_')))
699 error(USER, "bad modifier name from rtrace");
700 /* get modifier name */
701 while (n > 0 && *cp != '\t') {
702 *mnp++ = *cp++; n--;
703 }
704 *mnp = '\0';
705 cp++; n--; /* eat following tab */
706 if (n < (int)(sizeof(float)*9))
707 error(USER, "incomplete ray value from rtrace");
708 /* add ray contribution */
709 memcpy(rparams, cp, sizeof(float)*9);
710 cp += sizeof(float)*9; n -= sizeof(float)*9;
711 add_contrib(modname);
712 }
713 done_contrib(); /* sum up contributions & output */
714 lastdone = rtp->raynum;
715 free(rtp->buf);
716 /* catch up with unprocessed list */
717 while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
718 process_rays(rt_unproc);
719 rt_unproc = (rtu=rt_unproc)->next;
720 free(rtu);
721 }
722 } else { /* else insert in unprocessed list */
723 struct rtproc *rtl = NULL;
724 for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
725 if (rtp->raynum < rtu->raynum)
726 break;
727 rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
728 if (rtu == NULL)
729 error(SYSTEM, "out of memory in process_rays");
730 *rtu = *rtp;
731 if (rtl == NULL) {
732 rtu->next = rt_unproc;
733 rt_unproc = rtu;
734 } else {
735 rtu->next = rtl->next;
736 rtl->next = rtu;
737 }
738 }
739 rtp->raynum = 0; /* clear path for next ray tree */
740 rtp->bsiz = 0;
741 rtp->buf = NULL;
742 rtp->nbr = 0;
743 }
744
745 /* wait for rtrace process to finish with ray tree */
746 struct rtproc *
747 wait_rproc(void)
748 {
749 struct rtproc *rtfree = NULL;
750 fd_set readset, errset;
751 int nr;
752 struct rtproc *rt;
753 int n;
754
755 do {
756 nr = 0; /* prepare select call */
757 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
758 for (rt = &rt0; rt != NULL; rt = rt->next) {
759 if (rt->raynum) {
760 FD_SET(rt->pd.r, &readset);
761 ++nr;
762 }
763 FD_SET(rt->pd.r, &errset);
764 if (rt->pd.r >= n)
765 n = rt->pd.r + 1;
766 }
767 if (!nr) /* no rays pending */
768 break;
769 if (nr > 1) { /* call select for multiple proc's */
770 errno = 0;
771 if (select(n, &readset, NULL, &errset, NULL) < 0)
772 error(SYSTEM, "select call error in wait_rproc()");
773 } else
774 FD_ZERO(&errset);
775 nr = 0;
776 for (rt = &rt0; rt != NULL; rt = rt->next) {
777 if (!FD_ISSET(rt->pd.r, &readset) &&
778 !FD_ISSET(rt->pd.r, &errset))
779 continue;
780 if (rt->buf == NULL) {
781 rt->bsiz = treebufsiz;
782 rt->buf = (char *)malloc(treebufsiz);
783 } else if (rt->nbr + BUFSIZ > rt->bsiz) {
784 if (rt->bsiz + BUFSIZ <= treebufsiz)
785 rt->bsiz = treebufsiz;
786 else
787 rt->bsiz = treebufsiz += BUFSIZ;
788 rt->buf = (char *)realloc(rt->buf, rt->bsiz);
789 }
790 if (rt->buf == NULL)
791 error(SYSTEM, "out of memory in wait_rproc");
792 nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
793 if (nr <= 0)
794 error(USER, "rtrace process died");
795 rt->nbr += nr; /* advance & check */
796 if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4,
797 "~\t~\t", 4)) {
798 rt->nbr -= 4; /* elide terminator */
799 process_rays(rt);
800 rtfree = rt; /* ready for next ray */
801 }
802 }
803 } while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
804 return rtfree;
805 }
806
807 /* return next available rtrace process */
808 struct rtproc *
809 get_rproc(void)
810 {
811 struct rtproc *rtp;
812 /* check for idle rtrace */
813 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
814 if (!rtp->raynum)
815 return rtp;
816 return wait_rproc(); /* need to wait for one */
817 }
818
819 /* trace ray contributions (main loop) */
820 void
821 tracecontribs(FILE *fin)
822 {
823 char inpbuf[128];
824 int iblen;
825 struct rtproc *rtp;
826 /* loop over input */
827 while ((iblen = getinp(inpbuf, fin)) > 0) {
828 if (lastray+1 < lastray) { /* counter rollover? */
829 while (wait_rproc() != NULL)
830 ;
831 lastdone = lastray = 0;
832 }
833 rtp = get_rproc(); /* get avail. rtrace process */
834 rtp->raynum = ++lastray; /* assign this ray to it */
835 writebuf(rtp->pd.w, inpbuf, iblen);
836 if (!--raysleft)
837 break; /* explicit EOF */
838 }
839 while (wait_rproc() != NULL) /* process outstanding rays */
840 ;
841 if (raysleft > 0)
842 error(USER, "unexpected EOF on input");
843 }
