root/radiance/ray/src/util/rtcontrib.c
Fri Jun 17 16:07:18 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.23: +8 -3 lines
Diff to previous 1.23 , to selected 1.22
Added check for complete output with -r option
Thu Jun 16 19:37:26 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.22: +8 -3 lines
Diff to previous 1.22
Added check for missing recover files
Revision 1.22 - (view) (download) (annotate) - [selected]
Tue Jun 14 02:50:23 2005 UTC (19 years, 11 months ago) by greg
Changes since 1.21: +3 -5 lines
Diff to previous 1.21
Made it so MODIFIER= line added to every header
Sat Jun 11 15:01:03 2005 UTC (20 years ago) by greg
Changes since 1.20: +10 -10 lines
Diff to previous 1.20 , to selected 1.22
Fixed argument checking
Fri Jun 10 20:53:55 2005 UTC (20 years ago) by greg
Changes since 1.19: +6 -3 lines
Diff to previous 1.19 , to selected 1.22
Fixed it so rtcontrib -M option searches RAYPATH directories
Fri Jun 10 20:44:00 2005 UTC (20 years ago) by greg
Changes since 1.18: +6 -2 lines
Diff to previous 1.18 , to selected 1.22
Fixe in rtcontrib -M option
Fri Jun 10 20:38:38 2005 UTC (20 years ago) by greg
Diff to previous 1.17 , to selected 1.22
Fixed array overrun with large number of modifiers
Fri Jun 10 16:42:11 2005 UTC (20 years ago) by greg
Changes since 1.16: +18 -1 lines
Diff to previous 1.16 , to selected 1.22
Added rtcontrib -M option to read modifier list from a file
Thu Jun 9 18:33:06 2005 UTC (20 years ago) by greg
Diff to previous 1.15 , to selected 1.22
Warning wording tweaks
Thu Jun 9 18:27:44 2005 UTC (20 years ago) by greg
Changes since 1.14: +5 -1 lines
Diff to previous 1.14 , to selected 1.22
Added warning & check for case where no output files exist with -r option
Thu Jun 9 17:27:28 2005 UTC (20 years ago) by greg
Changes since 1.13: +238 -65 lines
Diff to previous 1.13 , to selected 1.22
Sun Jun 5 19:52:01 2005 UTC (20 years ago) by greg
Diff to previous 1.12 , to selected 1.22
Fri Jun 3 14:29:42 2005 UTC (20 years ago) by greg
Changes since 1.11: +11 -3 lines
Diff to previous 1.11 , to selected 1.22
Minor optimization to reduce calls to getofile()
Thu Jun 2 18:51:46 2005 UTC (20 years ago) by greg
Diff to previous 1.10 , to selected 1.22
Added missing definition of PI for calcomp routines
Thu Jun 2 04:47:27 2005 UTC (20 years ago) by greg
Changes since 1.9: +17 -5 lines
Diff to previous 1.9 , to selected 1.22
Wed Jun 1 16:11:01 2005 UTC (20 years ago) by greg
Changes since 1.8: +11 -2 lines
Diff to previous 1.8 , to selected 1.22
Tue May 31 18:01:09 2005 UTC (20 years ago) by greg
Diff to previous 1.7 , to selected 1.22
Tue May 31 03:48:59 2005 UTC (20 years ago) by greg
Diff to previous 1.6 , to selected 1.22
Added missing include for signal.h
Sat May 28 22:27:54 2005 UTC (20 years ago) by greg
Changes since 1.5: +5 -6 lines
Diff to previous 1.5 , to selected 1.22
Thu May 26 21:35:35 2005 UTC (20 years ago) by greg
Changes since 1.4: +10 -9 lines
Diff to previous 1.4 , to selected 1.22
Minor code tweaks
Thu May 26 17:53:28 2005 UTC (20 years ago) by greg
Changes since 1.3: +15 -5 lines
Diff to previous 1.3 , to selected 1.22
Thu May 26 15:14:42 2005 UTC (20 years ago) by greg
Changes since 1.2: +59 -44 lines
Diff to previous 1.2 , to selected 1.22
Improved efficiency of queuing behavior to avoid idle process time
Thu May 26 06:55:22 2005 UTC (20 years ago) by greg
Changes since 1.1: +183 -164 lines
Diff to previous 1.1 , to selected 1.22
Wed May 25 04:45:22 2005 UTC (20 years ago) by greg
Diff to selected 1.22
