--- ray/src/util/rtcontrib.c 2005/06/10 16:42:11 1.17 +++ ray/src/util/rtcontrib.c 2005/06/11 15:01:03 1.21 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtcontrib.c,v 1.17 2005/06/10 16:42:11 greg Exp $"; +static const char RCSid[] = "$Id: rtcontrib.c,v 1.21 2005/06/11 15:01:03 greg Exp $"; #endif /* * Gather rtrace output to compute contributions from particular sources @@ -16,7 +16,9 @@ static const char RCSid[] = "$Id: rtcontrib.c,v 1.17 2 #include "lookup.h" #include "calcomp.h" +#ifndef MAXMODLIST #define MAXMODLIST 1024 /* maximum modifiers we'll track */ +#endif int treebufsiz = BUFSIZ; /* current tree buffer size */ @@ -72,7 +74,8 @@ struct rtproc { }; /* rtrace process buffer */ /* rtrace command and defaults */ -char *rtargv[256] = { "rtrace", "-dj", ".5", "-dr", "3", +char *rtargv[256+2*MAXMODLIST] = { "rtrace", + "-dj", ".5", "-dr", "3", "-ab", "1", "-ad", "128", }; int rtargc = 9; /* overriding rtrace options */ @@ -193,7 +196,7 @@ main(int argc, char *argv[]) recover++; continue; case 'n': /* number of processes */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; nprocs = atoi(argv[++i]); if (nprocs <= 0) error(USER, "illegal number of processes"); @@ -218,7 +221,7 @@ main(int argc, char *argv[]) case 'f': /* file or i/o format */ if (!argv[i][2]) { char *fpath; - if (i >= argc-1) break; + if (i >= argc-2) break; fpath = getpath(argv[++i], getrlibpath(), R_OK); if (fpath == NULL) { @@ -233,34 +236,36 @@ main(int argc, char *argv[]) setformat(argv[i]+2); continue; case 'e': /* expression */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; scompile(argv[++i], NULL, 0); continue; case 'o': /* output file spec. */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; curout = argv[++i]; continue; case 'x': /* horiz. output resolution */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; xres = atoi(argv[++i]); continue; case 'y': /* vert. output resolution */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; yres = atoi(argv[++i]); continue; case 'b': /* bin expression */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; binval = argv[++i]; continue; case 'm': /* modifier name */ - if (argv[i][2] || i >= argc-1) break; + if (argv[i][2] || i >= argc-2) break; rtargv[rtargc++] = "-ti"; rtargv[rtargc++] = argv[++i]; addmodifier(argv[i], curout, binval); continue; case 'M': /* modifier file */ - if (argv[i][2] || i >= argc-1) break; - addmodfile(argv[++i], curout, binval); + if (argv[i][2] || i >= argc-2) break; + rtargv[rtargc++] = "-tI"; + rtargv[rtargc++] = argv[++i]; + addmodfile(argv[i], curout, binval); continue; } rtargv[rtargc++] = argv[i]; /* assume rtrace option */ @@ -463,8 +468,11 @@ addmodfile(char *fname, char *outf, char *binv) { char *mname[MAXMODLIST]; int i; - /* load the file & store strings */ - wordfile(mname, fname); + /* find the file & store strings */ + if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) { + sprintf(errmsg, "cannot find modifier file '%s'", fname); + error(SYSTEM, errmsg); + } for (i = 0; mname[i]; i++) /* add each one */ addmodifier(mname[i], outf, binv); }
