root/radiance/ray/src/util/rtcontrib.c
Revision: 1.58
Committed: Tue Oct 5 18:05:22 2010 UTC (14 years, 8 months ago) by greg
Changes since 1.57: +5 -5 lines
Fixed issues with integer overflow
2 static const char RCSid[] = "$Id: rtcontrib.c,v 1.57 2010/09/26 15:44:00 greg Exp $";
5 * Gather rtrace output to compute contributions from particular sources
6 */
7
8 #include "standard.h"
9 #include <ctype.h>
10 #include <signal.h>
11 #include "platform.h"
12 #include "rtprocess.h"
13 #include "selcall.h"
14 #include "color.h"
15 #include "resolu.h"
16 #include "lookup.h"
17 #include "random.h"
18 #include "calcomp.h"
19
20 #ifndef MAXMODLIST
21 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
22 #endif
23
24 size_t treebufsiz = BUFSIZ; /* current tree buffer size */
25
26 typedef double DCOLOR[3]; /* double-precision color */
27
28 /*
29 * The MODCONT structure is used to accumulate ray contributions
30 * for a particular modifier, which may be subdivided into bins
31 * if binv evaluates > 0. If outspec contains a %s in it, this will
32 * be replaced with the modifier name. If outspec contains a %d in it,
33 * this will be used to create one output file per bin, otherwise all bins
34 * will be written to the same file, in order. If the global outfmt
35 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
36 * and the file will conform to a RADIANCE image if xres & yres are set.
37 */
38 typedef struct {
39 const char *outspec; /* output file specification */
40 const char *modname; /* modifier name */
41 EPNODE *binv; /* bin value expression */
42 int nbins; /* number of accumulation bins */
43 DCOLOR cbin[1]; /* contribution bins (extends struct) */
44 } MODCONT; /* modifier contribution */
45
46 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
47
48 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
49
50 /*
51 * The STREAMOUT structure holds an open FILE pointer and a count of
52 * the number of RGB triplets per record, or 0 if unknown.
53 */
54 typedef struct {
55 FILE *ofp; /* output file pointer */
56 int outpipe; /* output is to a pipe */
57 int reclen; /* triplets/record */
58 int xr, yr; /* output resolution for picture */
59 } STREAMOUT;
60
61 /* close output stream and free record */
62 static void
63 closestream(void *p)
64 {
65 STREAMOUT *sop = (STREAMOUT *)p;
66 int status;
67 if (sop->outpipe)
68 status = pclose(sop->ofp);
69 else
70 status = fclose(sop->ofp);
71 if (status)
72 error(SYSTEM, "error closing output stream");
73 free(p);
74 }
75
76 LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
77
78 #define OF_MODIFIER 01
79 #define OF_BIN 02
80
81 STREAMOUT *getostream(const char *ospec, const char *mname, int bn, int noopen);
82 int ofname(char *oname, const char *ospec, const char *mname, int bn);
83 void printheader(FILE *fout, const char *info);
84 void printresolu(FILE *fout, int xr, int yr);
85
86 /*
87 * The rcont structure is used to manage i/o with a particular
88 * rtrace child process. Input is passed unchanged from stdin,
89 * and output is processed in input order and accumulated according
90 * to the corresponding modifier and bin number.
91 */
92 struct rtproc {
93 struct rtproc *next; /* next in list of processes */
94 SUBPROC pd; /* rtrace pipe descriptors */
95 unsigned long raynum; /* ray number for this tree */
96 size_t bsiz; /* ray tree buffer length */
97 char *buf; /* ray tree buffer */
98 size_t nbr; /* number of bytes from rtrace */
99 }; /* rtrace process buffer */
100
101 /* rtrace command and defaults */
102 char *rtargv[256+2*MAXMODLIST] = { "rtrace",
103 "-dj", ".9", "-dr", "3",
104 "-ab", "1", "-ad", "350", };
105
106 int rtargc = 9;
107 /* overriding rtrace options */
108 char *myrtopts[] = { "-h-", "-x", "1", "-y", "0",
109 "-dt", "0", "-as", "0", "-aa", "0", NULL };
110
111 #define RTCOEFF "-o~~TmWdp" /* compute coefficients only */
112 #define RTCONTRIB "-o~~TmVdp" /* compute ray contributions */
113
114 struct rtproc rt0; /* head of rtrace process list */
115
116 struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
117
118 #define PERSIST_NONE 0 /* no persist file */
119 #define PERSIST_SINGLE 1 /* user set -P persist */
120 #define PERSIST_PARALL 2 /* user set -PP persist */
121 #define PERSIST_OURS 3 /* -PP persist belongs to us */
122 int persist_state = PERSIST_NONE; /* persist file state */
123 char persistfn[] = "pfXXXXXX"; /* our persist file name, if set */
124
125 int gargc; /* global argc */
126 char **gargv; /* global argv */
127 #define progname gargv[0]
128
129 char *octree; /* global octree argument */
130
131 int inpfmt = 'a'; /* input format */
132 int outfmt = 'a'; /* output format */
133
134 int header = 1; /* output header? */
135 int force_open = 0; /* truncate existing output? */
136 int recover = 0; /* recover previous output? */
137 int accumulate = 1; /* input rays per output record */
138 int xres = 0; /* horiz. output resolution */
139 int yres = 0; /* vert. output resolution */
140
141 int account; /* current accumulation count */
142 unsigned long raysleft; /* number of rays left to trace */
143 long waitflush; /* how long until next flush */
144
145 unsigned long lastray = 0; /* last ray number sent */
146 unsigned long lastdone = 0; /* last ray processed */
147
148 int using_stdout = 0; /* are we using stdout? */
149
150 const char *modname[MAXMODLIST]; /* ordered modifier name list */
151 int nmods = 0; /* number of modifiers */
152
153 #define queue_length() (lastray - lastdone)
154
155 MODCONT *growmodifier(MODCONT *mp, int nb);
156 MODCONT *addmodifier(char *modn, char *outf, char *binv, int bincnt);
157 void addmodfile(char *fname, char *outf, char *binv, int bincnt);
158
159 void init(int np);
160 int done_rprocs(struct rtproc *rtp);
161 void reload_output(void);
162 void recover_output(FILE *fin);
163 void trace_contribs(FILE *fin);
164 struct rtproc *wait_rproc(void);
165 struct rtproc *get_rproc(void);
166 void queue_raytree(struct rtproc *rtp);
167 void process_queue(void);
168
169 void put_contrib(const DCOLOR cnt, FILE *fout);
170 void add_contrib(const char *modn);
171 void done_contrib(int navg);
172
173 /* return number of open rtrace processes */
174 static int
175 nrtprocs(void)
176 {
177 int nrtp = 0;
178 struct rtproc *rtp;
179
180 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
181 nrtp += rtp->pd.running;
182 return(nrtp);
183 }
184
185 /* set input/output format */
186 static void
187 setformat(const char *fmt)
188 {
189 switch (fmt[0]) {
190 case 'f':
191 case 'd':
192 SET_FILE_BINARY(stdin);
193 /* fall through */
194 case 'a':
195 inpfmt = fmt[0];
196 break;
197 default:
198 goto fmterr;
199 }
200 switch (fmt[1]) {
201 case '\0':
202 outfmt = inpfmt;
203 return;
204 case 'a':
205 case 'f':
206 case 'd':
207 case 'c':
208 outfmt = fmt[1];
209 break;
210 default:
211 goto fmterr;
212 }
213 if (!fmt[2])
214 return;
215 fmterr:
216 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
217 error(USER, errmsg);
218 }
219
220 /* gather rays from rtrace and output contributions */
221 int
222 main(int argc, char *argv[])
223 {
224 int contrib = 0;
225 int nprocs = 1;
226 char *curout = NULL;
227 char *binval = NULL;
228 int bincnt = 0;
229 char fmt[8];
230 int i, j;
231 /* need at least one argument */
232 if (argc < 2) {
233 fprintf(stderr,
234 "Usage: %s [-n nprocs][-V][-r][-e expr][-f source][-o ospec][-b binv] {-m mod | -M file} [rtrace options] octree\n",
235 argv[0]);
236 exit(1);
237 }
238 /* global program name */
239 gargv = argv;
240 /* initialize calcomp routines */
241 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
242 esupport &= ~(E_OUTCHAN);
243 varset("PI", ':', PI);
244 /* get our options */
245 for (i = 1; i < argc-1; i++) {
246 /* expand arguments */
247 while ((j = expandarg(&argc, &argv, i)) > 0)
248 ;
249 if (j < 0) {
250 fprintf(stderr, "%s: cannot expand '%s'\n",
251 argv[0], argv[i]);
252 exit(1);
253 }
254 if (argv[i][0] == '-')
255 switch (argv[i][1]) {
256 case 'n': /* number of processes */
257 if (argv[i][2] || i >= argc-2) break;
258 nprocs = atoi(argv[++i]);
259 if (nprocs <= 0)
260 error(USER, "illegal number of processes");
261 continue;
262 case 'V': /* output contributions */
263 switch (argv[i][2]) {
264 case '\0':
265 contrib = !contrib;
266 continue;
267 case '+': case '1':
268 case 'T': case 't':
269 case 'Y': case 'y':
270 contrib = 1;
271 continue;
272 case '-': case '0':
273 case 'F': case 'f':
274 case 'N': case 'n':
275 contrib = 0;
276 continue;
277 }
278 break;
279 case 'c': /* input rays per output */
280 if (argv[i][2] || i >= argc-2) break;
281 accumulate = atoi(argv[++i]);
282 continue;
283 case 'r': /* recover output */
284 if (argv[i][2]) break;
285 recover = 1;
286 continue;
287 case 'h': /* output header? */
288 switch (argv[i][2]) {
289 case '\0':
290 header = !header;
291 continue;
292 case '+': case '1':
293 case 'T': case 't':
294 case 'Y': case 'y':
295 header = 1;
296 continue;
297 case '-': case '0':
298 case 'F': case 'f':
299 case 'N': case 'n':
300 header = 0;
301 continue;
302 }
303 break;
304 case 'f': /* file or force or format */
305 if (!argv[i][2]) {
306 char *fpath;
307 if (i >= argc-2) break;
308 fpath = getpath(argv[++i],
309 getrlibpath(), R_OK);
310 if (fpath == NULL) {
311 sprintf(errmsg,
312 "cannot find file '%s'",
313 argv[i]);
314 error(USER, errmsg);
315 }
316 fcompile(fpath);
317 continue;
318 }
319 if (argv[i][2] == 'o') {
320 force_open = 1;
321 continue;
322 }
323 setformat(argv[i]+2);
324 continue;
325 case 'e': /* expression */
326 if (argv[i][2] || i >= argc-2) break;
327 scompile(argv[++i], NULL, 0);
328 continue;
329 case 'o': /* output file spec. */
330 if (argv[i][2] || i >= argc-2) break;
331 curout = argv[++i];
332 continue;
333 case 'x': /* horiz. output resolution */
334 if (argv[i][2] || i >= argc-2) break;
335 xres = atoi(argv[++i]);
336 continue;
337 case 'y': /* vert. output resolution */
338 if (argv[i][2] || i >= argc-2) break;
339 yres = atoi(argv[++i]);
340 continue;
341 case 'b': /* bin expression/count */
342 if (i >= argc-2) break;
343 if (argv[i][2] == 'n') {
344 bincnt = (int)(eval(argv[++i]) + .5);
345 continue;
346 }
347 if (argv[i][2]) break;
348 binval = argv[++i];
349 continue;
350 case 'm': /* modifier name */
351 if (argv[i][2] || i >= argc-2) break;
352 rtargv[rtargc++] = "-ti";
353 rtargv[rtargc++] = argv[++i];
354 addmodifier(argv[i], curout, binval, bincnt);
355 continue;
356 case 'M': /* modifier file */
357 if (argv[i][2] || i >= argc-2) break;
358 rtargv[rtargc++] = "-tI";
359 rtargv[rtargc++] = argv[++i];
360 addmodfile(argv[i], curout, binval, bincnt);
361 continue;
362 case 'P': /* persist file */
363 if (i >= argc-2) break;
364 persist_state = (argv[i][2] == 'P') ?
365 PERSIST_PARALL : PERSIST_SINGLE;
366 rtargv[rtargc++] = argv[i];
367 rtargv[rtargc++] = argv[++i];
368 continue;
369 }
370 rtargv[rtargc++] = argv[i]; /* assume rtrace option */
371 }
372 if (accumulate <= 0) /* no output flushing for single record */
373 xres = yres = 0;
374 /* set global argument list */
375 gargc = argc; gargv = argv;
376 /* add "mandatory" rtrace settings */
377 for (j = 0; myrtopts[j] != NULL; j++)
378 rtargv[rtargc++] = myrtopts[j];
379 rtargv[rtargc++] = contrib ? RTCONTRIB : RTCOEFF;
380 /* just asking for defaults? */
381 if (!strcmp(argv[i], "-defaults")) {
382 char nps[8], sxres[16], syres[16];
383 char *rtpath;
384 printf("-c %-5d\t\t\t# accumulated rays per record\n",
385 accumulate);
386 printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-',
387 contrib ? "contributions" : "coefficients");
388 fflush(stdout); /* report OUR options */
389 rtargv[rtargc++] = "-n";
390 sprintf(nps, "%d", nprocs);
391 rtargv[rtargc++] = nps;
392 rtargv[rtargc++] = header ? "-h+" : "-h-";
393 sprintf(fmt, "-f%c%c", inpfmt, outfmt);
394 rtargv[rtargc++] = fmt;
395 rtargv[rtargc++] = "-x";
396 sprintf(sxres, "%d", xres);
397 rtargv[rtargc++] = sxres;
398 rtargv[rtargc++] = "-y";
399 sprintf(syres, "%d", yres);
400 rtargv[rtargc++] = syres;
401 rtargv[rtargc++] = "-defaults";
402 rtargv[rtargc] = NULL;
403 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
404 if (rtpath == NULL) {
405 eputs(rtargv[0]);
406 eputs(": command not found\n");
407 exit(1);
408 }
409 execv(rtpath, rtargv);
410 perror(rtpath); /* execv() should not return */
411 exit(1);
412 }
413 if (nprocs > 1) { /* add persist file if parallel */
414 if (persist_state == PERSIST_SINGLE)
415 error(USER, "use -PP option for multiple processes");
416 if (persist_state == PERSIST_NONE) {
417 rtargv[rtargc++] = "-PP";
418 rtargv[rtargc++] = mktemp(persistfn);
419 persist_state = PERSIST_OURS;
420 }
421 }
422 /* add format string */
423 sprintf(fmt, "-f%cf", inpfmt);
424 rtargv[rtargc++] = fmt;
425 /* octree argument is last */
426 if (i <= 0 || i != argc-1 || argv[i][0] == '-')
427 error(USER, "missing octree argument");
428 rtargv[rtargc++] = octree = argv[i];
429 rtargv[rtargc] = NULL;
430 /* start rtrace & recover if requested */
431 init(nprocs);
432 /* compute contributions */
433 trace_contribs(stdin);
434 /* clean up */
435 quit(0);
436 }
437
438 #ifndef SIGALRM
439 #define SIGALRM SIGTERM
440 #endif
441 /* kill persistent rtrace process */
442 static void
443 killpersist(void)
444 {
445 FILE *fp = fopen(persistfn, "r");
446 RT_PID pid;
447
448 if (fp == NULL)
449 return;
450 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
451 unlink(persistfn);
452 fclose(fp);
453 }
454
455 /* close rtrace processes and clean up */
456 int
457 done_rprocs(struct rtproc *rtp)
458 {
459 int st0, st1 = 0;
460
461 if (rtp->next != NULL) { /* close last opened first! */
462 st1 = done_rprocs(rtp->next);
463 free((void *)rtp->next);
464 rtp->next = NULL;
465 }
466 st0 = close_process(&rtp->pd);
467 if (st0 < 0)
468 error(WARNING, "unknown return status from rtrace process");
469 else if (st0 > 0)
470 return(st0);
471 return(st1);
472 }
473
474 /* exit with status */
475 void
476 quit(int status)
477 {
478 int rtstat;
479
480 if (persist_state == PERSIST_OURS) /* terminate waiting rtrace */
481 killpersist();
482 /* clean up rtrace process(es) */
483 rtstat = done_rprocs(&rt0);
484 if (status == 0)
485 status = rtstat;
486 exit(status); /* flushes all output streams */
487 }
488
489 /* start rtrace processes and initialize */
490 void
491 init(int np)
492 {
493 struct rtproc *rtp;
494 int i;
495 int maxbytes;
496 /* make sure we have something to do */
497 if (!nmods)
498 error(USER, "No modifiers specified");
499 /* assign ray variables */
500 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
501 scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
502 /* set up signal handling */
503 signal(SIGINT, quit);
504 #ifdef SIGHUP
505 signal(SIGHUP, quit);
506 #endif
507 #ifdef SIGTERM
508 signal(SIGTERM, quit);
509 #endif
510 #ifdef SIGPIPE
511 signal(SIGPIPE, quit);
512 #endif
513 rtp = &rt0; /* start rtrace process(es) */
514 for (i = 0; i++ < np; ) {
515 errno = 0;
516 maxbytes = open_process(&rtp->pd, rtargv);
517 if (maxbytes == 0) {
518 eputs(rtargv[0]);
519 eputs(": command not found\n");
520 exit(1);
521 }
522 if (maxbytes < 0)
523 error(SYSTEM, "cannot start rtrace process");
524 if (maxbytes > treebufsiz)
525 treebufsiz = maxbytes;
526 rtp->raynum = 0;
527 rtp->bsiz = 0;
528 rtp->buf = NULL;
529 rtp->nbr = 0;
530 if (i == np) /* last process? */
531 break;
532 if (i == 1)
533 sleep(2); /* wait for persist file */
534 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
535 if (rtp->next == NULL)
536 error(SYSTEM, "out of memory in init");
537 rtp = rtp->next;
538 }
539 rtp->next = NULL; /* terminate list */
540 if (yres > 0) {
541 if (xres > 0)
542 raysleft = (unsigned long)xres*yres;
543 else
544 raysleft = yres;
545 } else
546 raysleft = 0;
547 if ((account = accumulate) > 0)
548 raysleft *= accumulate;
549 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
550 if (!recover)
551 return;
552 /* recover previous values */
553 if (accumulate <= 0)
554 reload_output();
555 else
556 recover_output(stdin);
557 }
558
559 /* grow modifier to accommodate more bins */
560 MODCONT *
561 growmodifier(MODCONT *mp, int nb)
562 {
563 if (nb <= mp->nbins)
564 return mp;
565 mp = (MODCONT *)realloc(mp, sizeof(MODCONT) + sizeof(DCOLOR)*(nb-1));
566 if (mp == NULL)
567 error(SYSTEM, "out of memory in growmodifier");
568 memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(nb-mp->nbins));
569 mp->nbins = nb;
570 return mp;
571 }
572
573 /* add modifier to our list to track */
574 MODCONT *
575 addmodifier(char *modn, char *outf, char *binv, int bincnt)
576 {
577 LUENT *lep = lu_find(&modconttab, modn);
578 MODCONT *mp;
579 int i;
580
581 if (lep->data != NULL) {
582 sprintf(errmsg, "duplicate modifier '%s'", modn);
583 error(USER, errmsg);
584 }
585 if (nmods >= MAXMODLIST)
586 error(INTERNAL, "too many modifiers");
587 modname[nmods++] = modn; /* XXX assumes static string */
588 lep->key = modn; /* XXX assumes static string */
589 mp = (MODCONT *)malloc(sizeof(MODCONT));
590 if (mp == NULL)
591 error(SYSTEM, "out of memory in addmodifier");
592 mp->outspec = outf; /* XXX assumes static string */
593 mp->modname = modn; /* XXX assumes static string */
594 if (binv == NULL)
595 binv = "0"; /* use single bin if unspecified */
596 mp->binv = eparse(binv);
597 if (mp->binv->type == NUM) { /* check value if constant */
598 bincnt = (int)(evalue(mp->binv) + 1.5);
599 if (bincnt != 1) {
600 sprintf(errmsg, "illegal non-zero constant for bin (%s)",
601 binv);
602 error(USER, errmsg);
603 }
604 }
605 mp->nbins = 1; /* initialize results holder */
606 setcolor(mp->cbin[0], 0., 0., 0.);
607 if (bincnt > 1)
608 mp = growmodifier(mp, bincnt);
609 lep->data = (char *)mp;
610 /* allocate output streams */
611 for (i = bincnt; i-- > 0; )
612 getostream(mp->outspec, mp->modname, i, 1);
613 return mp;
614 }
615
616 /* add modifiers from a file list */
617 void
618 addmodfile(char *fname, char *outf, char *binv, int bincnt)
619 {
620 char *mname[MAXMODLIST];
621 int i;
622 /* find the file & store strings */
623 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
624 sprintf(errmsg, "cannot find modifier file '%s'", fname);
625 error(SYSTEM, errmsg);
626 }
627 for (i = 0; mname[i]; i++) /* add each one */
628 addmodifier(mname[i], outf, binv, bincnt);
629 }
630
631 /* put string to stderr */
632 void
633 eputs(char *s)
634 {
635 static int midline = 0;
636
637 if (!*s) return;
638 if (!midline) {
639 fputs(progname, stderr);
640 fputs(": ", stderr);
641 }
642 fputs(s, stderr);
643 midline = s[strlen(s)-1] != '\n';
644 }
645
646 /* construct output file name and return flags whether modifier/bin present */
647 int
648 ofname(char *oname, const char *ospec, const char *mname, int bn)
649 {
650 const char *mnp = NULL;
651 const char *bnp = NULL;
652 const char *cp;
653
654 if (ospec == NULL)
655 return -1;
656 for (cp = ospec; *cp; cp++) /* check format position(s) */
657 if (*cp == '%') {
658 do
659 ++cp;
660 while (isdigit(*cp));
661 switch (*cp) {
662 case '%':
663 break;
664 case 's':
665 if (mnp != NULL)
666 return -1;
667 mnp = cp;
668 break;
669 case 'd':
670 case 'i':
671 case 'o':
672 case 'x':
673 case 'X':
674 if (bnp != NULL)
675 return -1;
676 bnp = cp;
677 break;
678 default:
679 return -1;
680 }
681 }
682 if (mnp != NULL) { /* create file name */
683 if (bnp != NULL) {
684 if (bnp > mnp)
685 sprintf(oname, ospec, mname, bn);
686 else
687 sprintf(oname, ospec, bn, mname);
688 return OF_MODIFIER|OF_BIN;
689 }
690 sprintf(oname, ospec, mname);
691 return OF_MODIFIER;
692 }
693 if (bnp != NULL) {
694 sprintf(oname, ospec, bn);
695 return OF_BIN;
696 }
697 strcpy(oname, ospec);
698 return 0;
699 }
700
701 /* write header to the given output stream */
702 void
703 printheader(FILE *fout, const char *info)
704 {
705 extern char VersionID[];
706 FILE *fin = fopen(octree, "r");
707
708 if (fin == NULL)
709 quit(1);
710 checkheader(fin, "ignore", fout); /* copy octree header */
711 fclose(fin);
712 printargs(gargc-1, gargv, fout); /* add our command */
713 fprintf(fout, "SOFTWARE= %s\n", VersionID);
714 fputnow(fout);
715 if (info != NULL) /* add extra info if given */
716 fputs(info, fout);
717 switch (outfmt) { /* add output format */
718 case 'a':
719 fputformat("ascii", fout);
720 break;
721 case 'f':
722 fputformat("float", fout);
723 break;
724 case 'd':
725 fputformat("double", fout);
726 break;
727 case 'c':
728 fputformat(COLRFMT, fout);
729 break;
730 }
731 fputc('\n', fout);
732 }
733
734 /* write resolution string to given output stream */
735 void
736 printresolu(FILE *fout, int xr, int yr)
737 {
738 if ((xr > 0) & (yr > 0)) /* resolution string */
739 fprtresolu(xr, yr, fout);
740 }
741
742 /* Get output stream pointer (open and write header if new and noopen==0) */
743 STREAMOUT *
744 getostream(const char *ospec, const char *mname, int bn, int noopen)
745 {
746 static const DCOLOR nocontrib = BLKCOLOR;
747 static STREAMOUT stdos;
748 int ofl;
749 char oname[1024];
750 LUENT *lep;
751 STREAMOUT *sop;
752
753 if (ospec == NULL) { /* use stdout? */
754 if (!noopen && !using_stdout) {
755 if (outfmt != 'a')
756 SET_FILE_BINARY(stdout);
757 if (header)
758 printheader(stdout, NULL);
759 printresolu(stdout, xres, yres);
760 if (waitflush > 0)
761 fflush(stdout);
762 stdos.xr = xres; stdos.yr = yres;
763 using_stdout = 1;
764 }
765 stdos.ofp = stdout;
766 stdos.reclen += noopen;
767 return &stdos;
768 }
769 ofl = ofname(oname, ospec, mname, bn); /* get output name */
770 if (ofl < 0) {
771 sprintf(errmsg, "bad output format '%s'", ospec);
772 error(USER, errmsg);
773 }
774 lep = lu_find(&ofiletab, oname); /* look it up */
775 if (lep->key == NULL) /* new entry */
776 lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
777 sop = (STREAMOUT *)lep->data;
778 if (sop == NULL) { /* allocate stream */
779 sop = (STREAMOUT *)malloc(sizeof(STREAMOUT));
780 if (sop == NULL)
781 error(SYSTEM, "out of memory in getostream");
782 sop->outpipe = oname[0] == '!';
783 sop->reclen = 0;
784 sop->ofp = NULL; /* open iff noopen==0 */
785 sop->xr = xres; sop->yr = yres;
786 lep->data = (char *)sop;
787 if (!sop->outpipe & !force_open & !recover &&
788 access(oname, F_OK) == 0) {
789 errno = EEXIST; /* file exists */
790 goto openerr;
791 }
792 }
793 if (!noopen && sop->ofp == NULL) { /* open output stream */
794 long i;
795 if (oname[0] == '!') /* output to command */
796 sop->ofp = popen(oname+1, "w");
797 else /* else open file */
798 sop->ofp = fopen(oname, "w");
799 if (sop->ofp == NULL)
800 goto openerr;
801 if (outfmt != 'a')
802 SET_FILE_BINARY(sop->ofp);
803 if (header) {
804 char info[512];
805 char *cp = info;
806 if (ofl & OF_MODIFIER || sop->reclen == 1) {
807 sprintf(cp, "MODIFIER=%s\n", mname);
808 while (*cp) ++cp;
809 }
810 if (ofl & OF_BIN) {
811 sprintf(cp, "BIN=%d\n", bn);
812 while (*cp) ++cp;
813 }
814 *cp = '\0';
815 printheader(sop->ofp, info);
816 }
817 if (accumulate > 0) { /* global resolution */
818 sop->xr = xres; sop->yr = yres;
819 }
820 printresolu(sop->ofp, sop->xr, sop->yr);
821 /* play catch-up */
822 for (i = accumulate > 0 ? lastdone/accumulate : 0; i--; ) {
823 int j = sop->reclen;
824 if (j <= 0) j = 1;
825 while (j--)
826 put_contrib(nocontrib, sop->ofp);
827 if (outfmt == 'a')
828 putc('\n', sop->ofp);
829 }
830 if (waitflush > 0)
831 fflush(sop->ofp);
832 }
833 sop->reclen += noopen; /* add to length if noopen */
834 return sop; /* return output stream */
835 openerr:
836 sprintf(errmsg, "cannot open '%s' for writing", oname);
837 error(SYSTEM, errmsg);
838 return NULL; /* pro forma return */
839 }
840
841 /* read input ray into buffer */
842 int
843 getinp(char *buf, FILE *fp)
844 {
845 double dv[3], *dvp;
846 float *fvp;
847 char *cp;
848 int i;
849
850 switch (inpfmt) {
851 case 'a':
852 cp = buf; /* make sure we get 6 floats */
853 for (i = 0; i < 6; i++) {
854 if (fgetword(cp, buf+127-cp, fp) == NULL)
855 return -1;
856 if (i >= 3)
857 dv[i-3] = atof(cp);
858 if ((cp = fskip(cp)) == NULL || *cp)
859 return -1;
860 *cp++ = ' ';
861 }
862 getc(fp); /* get/put eol */
863 *cp-- = '\0'; *cp = '\n';
864 if (DOT(dv,dv) <= FTINY*FTINY)
865 return 0; /* dummy ray */
866 return strlen(buf);
867 case 'f':
868 if (fread(buf, sizeof(float), 6, fp) < 6)
869 return -1;
870 fvp = (float *)buf + 3;
871 if (DOT(fvp,fvp) <= FTINY*FTINY)
872 return 0; /* dummy ray */
873 return sizeof(float)*6;
874 case 'd':
875 if (fread(buf, sizeof(double), 6, fp) < 6)
876 return -1;
877 dvp = (double *)buf + 3;
878 if (DOT(dvp,dvp) <= FTINY*FTINY)
879 return 0; /* dummy ray */
880 return sizeof(double)*6;
881 }
882 error(INTERNAL, "botched input format");
883 return -1; /* pro forma return */
884 }
885
886 static float rparams[9]; /* traced ray parameters */
887
888 /* return channel (ray) value */
889 double
890 chanvalue(int n)
891 {
892 if (--n < 0 || n >= 6)
893 error(USER, "illegal channel number ($N)");
894 return rparams[n+3];
895 }
896
897 /* add current ray contribution to the appropriate modifier bin */
898 void
899 add_contrib(const char *modn)
900 {
901 LUENT *le = lu_find(&modconttab, modn);
902 MODCONT *mp = (MODCONT *)le->data;
903 int bn;
904
905 if (mp == NULL) {
906 sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
907 error(USER, errmsg);
908 }
909 eclock++; /* get bin number */
910 bn = (int)(evalue(mp->binv) + .5);
911 if (bn <= 0)
912 bn = 0;
913 else if (bn >= mp->nbins) /* new bin */
914 le->data = (char *)(mp = growmodifier(mp, bn+1));
915 addcolor(mp->cbin[bn], rparams);
916 }
917
918 /* output newline to ASCII file and/or flush as requested */
919 static int
920 puteol(const LUENT *e, void *p)
921 {
922 STREAMOUT *sop = (STREAMOUT *)e->data;
923
924 if (outfmt == 'a')
925 putc('\n', sop->ofp);
926 if (!waitflush)
927 fflush(sop->ofp);
928 if (ferror(sop->ofp)) {
929 sprintf(errmsg, "write error on file '%s'", e->key);
930 error(SYSTEM, errmsg);
931 }
932 return 0;
933 }
934
935 /* put out ray contribution to file */
936 void
937 put_contrib(const DCOLOR cnt, FILE *fout)
938 {
939 float fv[3];
940 COLR cv;
941
942 switch (outfmt) {
943 case 'a':
944 fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
945 break;
946 case 'f':
947 copycolor(fv, cnt);
948 fwrite(fv, sizeof(float), 3, fout);
949 break;
950 case 'd':
951 fwrite(cnt, sizeof(double), 3, fout);
952 break;
953 case 'c':
954 setcolr(cv, cnt[0], cnt[1], cnt[2]);
955 fwrite(cv, sizeof(cv), 1, fout);
956 break;
957 default:
958 error(INTERNAL, "botched output format");
959 }
960 if (waitflush < 0 && frandom() < 0.001)
961 fflush(fout); /* staggers writes */
962 }
963
964 /* output ray tallies and clear for next accumulation */
965 void
966 done_contrib(int navg)
967 {
968 double sf = 1.;
969 int i, j;
970 MODCONT *mp;
971 STREAMOUT *sop;
972 /* set average scaling */
973 if (navg > 1)
974 sf = 1. / (double)navg;
975 /* output modifiers in order */
976 for (i = 0; i < nmods; i++) {
977 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
978 if (navg > 1) /* average scaling */
979 for (j = mp->nbins; j--; )
980 scalecolor(mp->cbin[j], sf);
981 sop = getostream(mp->outspec, mp->modname, 0,0);
982 put_contrib(mp->cbin[0], sop->ofp);
983 if (mp->nbins > 3 && /* minor optimization */
984 sop == getostream(mp->outspec, mp->modname, 1,0))
985 for (j = 1; j < mp->nbins; j++)
986 put_contrib(mp->cbin[j], sop->ofp);
987 else
988 for (j = 1; j < mp->nbins; j++)
989 put_contrib(mp->cbin[j],
990 getostream(mp->outspec,mp->modname,j,0)->ofp);
991 /* clear for next time */
992 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
993 }
994 --waitflush; /* terminate records */
995 lu_doall(&ofiletab, puteol, NULL);
996 if (using_stdout & (outfmt == 'a'))
997 putc('\n', stdout);
998 if (!waitflush) {
999 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
1000 if (using_stdout)
1001 fflush(stdout);
1002 }
1003 }
1004
1005 /* queue completed ray tree produced by rtrace process */
1006 void
1007 queue_raytree(struct rtproc *rtp)
1008 {
1009 struct rtproc *rtu, *rtl = NULL;
1010 /* insert following ray order */
1011 for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
1012 if (rtp->raynum < rtu->raynum)
1013 break;
1014 rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
1015 if (rtu == NULL)
1016 error(SYSTEM, "out of memory in queue_raytree");
1017 *rtu = *rtp;
1018 if (rtl == NULL) {
1019 rtu->next = rt_unproc;
1020 rt_unproc = rtu;
1021 } else {
1022 rtu->next = rtl->next;
1023 rtl->next = rtu;
1024 }
1025 rtp->raynum = 0; /* clear path for next ray tree */
1026 rtp->bsiz = 0;
1027 rtp->buf = NULL;
1028 rtp->nbr = 0;
1029 }
1030
1031 /* process completed ray trees from our queue */
1032 void
1033 process_queue(void)
1034 {
1035 char modname[128];
1036 /* ray-ordered queue */
1037 while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
1038 struct rtproc *rtp = rt_unproc;
1039 int n = rtp->nbr;
1040 const char *cp = rtp->buf;
1041 while (n > 0) { /* process rays */
1042 register char *mnp = modname;
1043 /* skip leading tabs */
1044 while (n > 0 && *cp == '\t') {
1045 cp++; n--;
1046 }
1047 if (!n || !(isalpha(*cp) | (*cp == '_')))
1048 error(USER, "bad modifier name from rtrace");
1049 /* get modifier name */
1050 while (n > 1 && *cp != '\t') {
1051 if (mnp - modname >= sizeof(modname)-2)
1052 error(INTERNAL, "modifier name too long");
1053 *mnp++ = *cp++; n--;
1054 }
1055 *mnp = '\0';
1056 cp++; n--; /* eat following tab */
1057 if (n < (int)(sizeof(float)*9))
1058 error(USER, "incomplete ray value from rtrace");
1059 /* add ray contribution */
1060 memcpy(rparams, cp, sizeof(float)*9);
1061 cp += sizeof(float)*9; n -= sizeof(float)*9;
1062 add_contrib(modname);
1063 }
1064 /* time to produce record? */
1065 if (account > 0 && !--account)
1066 done_contrib(account = accumulate);
1067 lastdone = rtp->raynum;
1068 if (rtp->buf != NULL) /* free up buffer space */
1069 free(rtp->buf);
1070 rt_unproc = rtp->next;
1071 free(rtp); /* done with this ray tree */
1072 }
1073 }
1074
1075 /* wait for rtrace process to finish with ray tree */
1076 struct rtproc *
1077 wait_rproc(void)
1078 {
1079 struct rtproc *rtfree = NULL;
1080 fd_set readset, errset;
1081 ssize_t nr;
1082 struct rtproc *rt;
1083 int n;
1084
1085 do {
1086 nr = 0; /* prepare select call */
1087 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
1088 for (rt = &rt0; rt != NULL; rt = rt->next) {
1089 if (rt->raynum) {
1090 FD_SET(rt->pd.r, &readset);
1091 ++nr;
1092 }
1093 FD_SET(rt->pd.r, &errset);
1094 if (rt->pd.r >= n)
1095 n = rt->pd.r + 1;
1096 }
1097 if (!nr) /* no rays pending */
1098 break;
1099 if (nr > 1) { /* call select for multiple proc's */
1100 errno = 0;
1101 if (select(n, &readset, NULL, &errset, NULL) < 0)
1102 error(SYSTEM, "select call error in wait_rproc()");
1103 } else
1104 FD_ZERO(&errset);
1105 nr = 0;
1106 for (rt = &rt0; rt != NULL; rt = rt->next) {
1107 if (!FD_ISSET(rt->pd.r, &readset) &&
1108 !FD_ISSET(rt->pd.r, &errset))
1109 continue;
1110 if (rt->buf == NULL) {
1111 rt->bsiz = treebufsiz;
1112 rt->buf = (char *)malloc(treebufsiz);
1113 } else if (rt->nbr + BUFSIZ > rt->bsiz) {
1114 if (rt->bsiz + BUFSIZ <= treebufsiz)
1115 rt->bsiz = treebufsiz;
1116 else
1117 treebufsiz = rt->bsiz += BUFSIZ;
1118 rt->buf = (char *)realloc(rt->buf, rt->bsiz);
1119 }
1120 if (rt->buf == NULL)
1121 error(SYSTEM, "out of memory in wait_rproc");
1122 nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
1123 if (nr <= 0)
1124 error(USER, "rtrace process died");
1125 rt->nbr += nr; /* advance & check */
1126 if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4,
1127 "~\t~\t", 4)) {
1128 rt->nbr -= 4; /* elide terminator */
1129 queue_raytree(rt);
1130 rtfree = rt; /* ready for next ray */
1131 }
1132 }
1133 } while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
1134 return rtfree;
1135 }
1136
1137 /* return next available rtrace process */
1138 struct rtproc *
1139 get_rproc(void)
1140 {
1141 struct rtproc *rtp;
1142 /* check for idle rtrace */
1143 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
1144 if (!rtp->raynum)
1145 return rtp;
1146 return wait_rproc(); /* need to wait for one */
1147 }
1148
1149 /* trace ray contributions (main loop) */
1150 void
1151 trace_contribs(FILE *fin)
1152 {
1153 static int ignore_warning_given = 0;
1154 char inpbuf[128];
1155 int iblen;
1156 struct rtproc *rtp;
1157 /* loop over input */
1158 while ((iblen = getinp(inpbuf, fin)) >= 0) {
1159 if (!iblen && accumulate != 1) {
1160 if (!ignore_warning_given++)
1161 error(WARNING,
1162 "dummy ray(s) ignored during accumulation\n");
1163 continue;
1164 }
1165 if (!iblen || /* need flush/reset? */
1166 queue_length() > 10*nrtprocs() ||
1167 lastray+1 < lastray) {
1168 while (wait_rproc() != NULL)
1169 process_queue();
1170 if (lastray+1 < lastray)
1171 lastdone = lastray = 0;
1172 }
1173 rtp = get_rproc(); /* get avail. rtrace process */
1174 rtp->raynum = ++lastray; /* assign ray */
1175 if (iblen) { /* trace ray if valid */
1176 writebuf(rtp->pd.w, inpbuf, iblen);
1177 } else { /* else bypass dummy ray */
1178 queue_raytree(rtp); /* queue empty ray/record */
1179 if ((yres <= 0) | (xres <= 0))
1180 waitflush = 1; /* flush right after */
1181 }
1182 process_queue(); /* catch up with results */
1183 if (raysleft && !--raysleft)
1184 break; /* preemptive EOI */
1185 }
1186 while (wait_rproc() != NULL) /* process outstanding rays */
1187 process_queue();
1188 if (accumulate <= 0)
1189 done_contrib(0); /* output tallies */
1190 else if (account < accumulate) {
1191 error(WARNING, "partial accumulation in final record");
1192 done_contrib(accumulate - account);
1193 }
1194 if (raysleft)
1195 error(USER, "unexpected EOF on input");
1196 lu_done(&ofiletab); /* close output files */
1197 }
1198
1199 /* get ray contribution from previous file */
1200 static int
1201 get_contrib(DCOLOR cnt, FILE *finp)
1202 {
1203 COLOR fv;
1204 COLR cv;
1205
1206 switch (outfmt) {
1207 case 'a':
1208 return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3);
1209 case 'f':
1210 if (fread(fv, sizeof(fv[0]), 3, finp) != 3)
1211 return(0);
1212 copycolor(cnt, fv);
1213 return(1);
1214 case 'd':
1215 return(fread(cnt, sizeof(cnt[0]), 3, finp) == 3);
1216 case 'c':
1217 if (fread(cv, sizeof(cv), 1, finp) != 1)
1218 return(0);
1219 colr_color(fv, cv);
1220 copycolor(cnt, fv);
1221 return(1);
1222 default:
1223 error(INTERNAL, "botched output format");
1224 }
1225 return(0); /* pro forma return */
1226 }
1227
1228 /* close output file opened for input */
1229 static int
1230 myclose(const LUENT *e, void *p)
1231 {
1232 STREAMOUT *sop = (STREAMOUT *)e->data;
1233
1234 if (sop->ofp == NULL)
1235 return(0);
1236 fclose(sop->ofp);
1237 sop->ofp = NULL;
1238 return(0);
1239 }
1240
1241 /* load previously accumulated values */
1242 void
1243 reload_output(void)
1244 {
1245 int i, j;
1246 MODCONT *mp;
1247 int ofl;
1248 char oname[1024];
1249 char *fmode = "rb";
1250 char *outvfmt;
1251 LUENT *ment, *oent;
1252 int xr, yr;
1253 STREAMOUT sout;
1254 DCOLOR rgbv;
1255
1256 switch (outfmt) {
1257 case 'a':
1258 outvfmt = "ascii";
1259 fmode = "r";
1260 break;
1261 case 'f':
1262 outvfmt = "float";
1263 break;
1264 case 'd':
1265 outvfmt = "double";
1266 break;
1267 case 'c':
1268 outvfmt = COLRFMT;
1269 break;
1270 default:
1271 error(INTERNAL, "botched output format");
1272 return;
1273 }
1274 /* reload modifier values */
1275 for (i = 0; i < nmods; i++) {
1276 ment = lu_find(&modconttab,modname[i]);
1277 mp = (MODCONT *)ment->data;
1278 if (mp->outspec == NULL)
1279 error(USER, "cannot reload from stdout");
1280 if (mp->outspec[0] == '!')
1281 error(USER, "cannot reload from command");
1282 for (j = 0; ; j++) { /* load each modifier bin */
1283 ofl = ofname(oname, mp->outspec, mp->modname, j);
1284 if (ofl < 0)
1285 error(USER, "bad output file specification");
1286 oent = lu_find(&ofiletab, oname);
1287 if (oent->data != NULL) {
1288 sout = *(STREAMOUT *)oent->data;
1289 } else {
1290 sout.reclen = 0;
1291 sout.outpipe = 0;
1292 sout.xr = xres; sout.yr = yres;
1293 sout.ofp = NULL;
1294 }
1295 if (sout.ofp == NULL) { /* open output as input */
1296 sout.ofp = fopen(oname, fmode);
1297 if (sout.ofp == NULL) {
1298 if (j)
1299 break; /* assume end of modifier */
1300 sprintf(errmsg, "missing reload file '%s'",
1301 oname);
1302 error(WARNING, errmsg);
1303 break;
1304 }
1305 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1306 sprintf(errmsg, "format mismatch for '%s'",
1307 oname);
1308 error(USER, errmsg);
1309 }
1310 if ((sout.xr > 0) & (sout.yr > 0) &&
1311 (!fscnresolu(&xr, &yr, sout.ofp) ||
1312 (xr != sout.xr) |
1313 (yr != sout.yr))) {
1314 sprintf(errmsg, "resolution mismatch for '%s'",
1315 oname);
1316 error(USER, errmsg);
1317 }
1318 }
1319 /* read in RGB value */
1320 if (!get_contrib(rgbv, sout.ofp)) {
1321 if (!j) {
1322 fclose(sout.ofp);
1323 break; /* ignore empty file */
1324 }
1325 if (j < mp->nbins) {
1326 sprintf(errmsg, "missing data in '%s'",
1327 oname);
1328 error(USER, errmsg);
1329 }
1330 break;
1331 }
1332 if (j >= mp->nbins) /* grow modifier size */
1333 ment->data = (char *)(mp = growmodifier(mp, j+1));
1334 copycolor(mp->cbin[j], rgbv);
1335 if (oent->key == NULL) /* new file entry */
1336 oent->key = strcpy((char *)
1337 malloc(strlen(oname)+1), oname);
1338 if (oent->data == NULL)
1339 oent->data = (char *)malloc(sizeof(STREAMOUT));
1340 *(STREAMOUT *)oent->data = sout;
1341 }
1342 }
1343 lu_doall(&ofiletab, myclose, NULL); /* close all files */
1344 }
1345
1346 /* seek on the given output file */
1347 static int
1348 myseeko(const LUENT *e, void *p)
1349 {
1350 STREAMOUT *sop = (STREAMOUT *)e->data;
1351 off_t nbytes = *(off_t *)p;
1352
1353 if (sop->reclen > 1)
1354 nbytes = nbytes * sop->reclen;
1355 if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) {
1356 sprintf(errmsg, "seek error on file '%s'", e->key);
1357 error(SYSTEM, errmsg);
1358 }
1359 return 0;
1360 }
1361
1362 /* recover output if possible */
1363 void
1364 recover_output(FILE *fin)
1365 {
1366 off_t lastout = -1;
1367 int outvsiz, recsiz;
1368 char *outvfmt;
1369 int i, j;
1370 MODCONT *mp;
1371 int ofl;
1372 char oname[1024];
1373 LUENT *ment, *oent;
1374 STREAMOUT sout;
1375 off_t nvals;
1376 int xr, yr;
1377
1378 switch (outfmt) {
1379 case 'a':
1380 error(USER, "cannot recover ASCII output");
1381 return;
1382 case 'f':
1383 outvsiz = sizeof(float)*3;
1384 outvfmt = "float";
1385 break;
1386 case 'd':
1387 outvsiz = sizeof(double)*3;
1388 outvfmt = "double";
1389 break;
1390 case 'c':
1391 outvsiz = sizeof(COLR);
1392 outvfmt = COLRFMT;
1393 break;
1394 default:
1395 error(INTERNAL, "botched output format");
1396 return;
1397 }
1398 /* check modifier outputs */
1399 for (i = 0; i < nmods; i++) {
1400 ment = lu_find(&modconttab,modname[i]);
1401 mp = (MODCONT *)ment->data;
1402 if (mp->outspec == NULL)
1403 error(USER, "cannot recover from stdout");
1404 if (mp->outspec[0] == '!')
1405 error(USER, "cannot recover from command");
1406 for (j = 0; ; j++) { /* check each bin's file */
1407 ofl = ofname(oname, mp->outspec, mp->modname, j);
1408 if (ofl < 0)
1409 error(USER, "bad output file specification");
1410 oent = lu_find(&ofiletab, oname);
1411 if (oent->data != NULL) {
1412 sout = *(STREAMOUT *)oent->data;
1413 } else {
1414 sout.reclen = 0;
1415 sout.outpipe = 0;
1416 sout.ofp = NULL;
1417 }
1418 if (sout.ofp != NULL) { /* already open? */
1419 if (ofl & OF_BIN)
1420 continue;
1421 break;
1422 }
1423 /* open output */
1424 sout.ofp = fopen(oname, "rb+");
1425 if (sout.ofp == NULL) {
1426 if (j)
1427 break; /* assume end of modifier */
1428 sprintf(errmsg, "missing recover file '%s'",
1429 oname);
1430 error(WARNING, errmsg);
1431 break;
1432 }
1433 nvals = lseek(fileno(sout.ofp), 0, SEEK_END);
1434 if (nvals <= 0) {
1435 lastout = 0; /* empty output, quit here */
1436 fclose(sout.ofp);
1437 break;
1438 }
1439 if (!sout.reclen) {
1440 if (!(ofl & OF_BIN)) {
1441 sprintf(errmsg,
1442 "need -bn to recover file '%s'",
1443 oname);
1444 error(USER, errmsg);
1445 }
1446 recsiz = outvsiz;
1447 } else
1448 recsiz = outvsiz * sout.reclen;
1449
1450 lseek(fileno(sout.ofp), 0, SEEK_SET);
1451 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1452 sprintf(errmsg, "format mismatch for '%s'",
1453 oname);
1454 error(USER, errmsg);
1455 }
1456 sout.xr = xres; sout.yr = yres;
1457 if ((sout.xr > 0) & (sout.yr > 0) &&
1458 (!fscnresolu(&xr, &yr, sout.ofp) ||
1459 (xr != sout.xr) |
1460 (yr != sout.yr))) {
1461 sprintf(errmsg, "resolution mismatch for '%s'",
1462 oname);
1463 error(USER, errmsg);
1464 }
1465 nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz;
1466 if ((lastout < 0) | (nvals < lastout))
1467 lastout = nvals;
1468 if (oent->key == NULL) /* new entry */
1469 oent->key = strcpy((char *)
1470 malloc(strlen(oname)+1), oname);
1471 if (oent->data == NULL)
1472 oent->data = (char *)malloc(sizeof(STREAMOUT));
1473 *(STREAMOUT *)oent->data = sout;
1474 if (!(ofl & OF_BIN))
1475 break; /* no bin separation */
1476 }
1477 if (!lastout) { /* empty output */
1478 error(WARNING, "no previous data to recover");
1479 lu_done(&ofiletab); /* reclose all outputs */
1480 return;
1481 }
1482 if (j > mp->nbins) /* reallocate modifier bins */
1483 ment->data = (char *)(mp = growmodifier(mp, j));
1484 }
1485 if (lastout < 0) {
1486 error(WARNING, "no output files to recover");
1487 return;
1488 }
1489 if (raysleft && lastout >= raysleft/accumulate) {
1490 error(WARNING, "output appears to be complete");
1491 /* XXX should read & discard input? */
1492 quit(0);
1493 }
1494 /* seek on all files */
1495 nvals = lastout * outvsiz;
1496 lu_doall(&ofiletab, myseeko, &nvals);
1497 /* skip repeated input */
1498 for (nvals = 0; nvals < lastout; nvals++)
1499 if (getinp(oname, fin) < 0)
1500 error(USER, "unexpected EOF on input");
1501 lastray = lastdone = (unsigned long)lastout * accumulate;
1502 if (raysleft)
1503 raysleft -= lastray;
1504 }
