| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rtcontrib.c,v 1.8 2005/05/31 18:01:09 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Gather rtrace output to compute contributions from particular sources
| 6 |
| 7 |
| 8 |
#include "standard.h"
| 9 |
#include <ctype.h>
| 10 |
#include <signal.h>
| 11 |
#include "platform.h"
| 12 |
#include "rtprocess.h"
| 13 |
#include "selcall.h"
| 14 |
#include "color.h"
| 15 |
#include "resolu.h"
| 16 |
#include "lookup.h"
| 17 |
#include "calcomp.h"
| 18 |
| 19 |
#define MAXMODLIST 1024 /* maximum modifiers we'll track */
| 20 |
| 21 |
int treebufsiz = BUFSIZ; /* current tree buffer size */
| 22 |
| 23 |
typedef double DCOLOR[3]; /* double-precision color */
| 24 |
| 25 |
| 26 |
* The modcont structure is used to accumulate ray contributions
| 27 |
* for a particular modifier, which may be subdivided into bins
| 28 |
* if binv is non-NULL. If outspec contains a %s in it, this will
| 29 |
* be replaced with the modifier name. If outspec contains a %d in it,
| 30 |
* this will be used to create one output file per bin, otherwise all bins
| 31 |
* will be written to the same file, in order. If the global outfmt
| 32 |
* is 'c', then a 4-byte RGBE pixel will be output for each bin value
| 33 |
* and the file will conform to a RADIANCE image if xres & yres are set.
| 34 |
| 35 |
typedef struct {
| 36 |
const char *outspec; /* output file specification */
| 37 |
const char *modname; /* modifier name */
| 38 |
EPNODE *binv; /* bin value expression */
| 39 |
int nbins; /* number of accumulation bins */
| 40 |
DCOLOR cbin[1]; /* contribution bins (extends struct) */
| 41 |
} MODCONT; /* modifier contribution */
| 42 |
| 43 |
static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
| 44 |
| 45 |
LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
| 46 |
| 47 |
/* close output stream */
| 48 |
static void closefile(void *p) { fclose((FILE *)p); }
| 49 |
| 50 |
LUTAB ofiletab = LU_SINIT(free,closefile); /* output file table */
| 51 |
| 52 |
FILE *getofile(const char *ospec, const char *mname, int bn);
| 53 |
| 54 |
| 55 |
* The rcont structure is used to manage i/o with a particular
| 56 |
* rtrace child process. Input is passed unchanged from stdin,
| 57 |
* and output is processed in input order and accumulated according
| 58 |
* to the corresponding modifier and bin number.
| 59 |
| 60 |
struct rtproc {
| 61 |
struct rtproc *next; /* next in list of processes */
| 62 |
SUBPROC pd; /* rtrace pipe descriptors */
| 63 |
unsigned long raynum; /* ray number for this tree */
| 64 |
int bsiz; /* ray tree buffer length */
| 65 |
char *buf; /* ray tree buffer */
| 66 |
int nbr; /* number of bytes from rtrace */
| 67 |
}; /* rtrace process buffer */
| 68 |
| 69 |
/* rtrace command and defaults */
| 70 |
char *rtargv[256] = { "rtrace", "-dj", ".5", "-dr", "3",
| 71 |
"-ab", "1", "-ad", "128", "-lr", "-10", };
| 72 |
int rtargc = 11;
| 73 |
/* overriding rtrace options */
| 74 |
char *myrtopts[] = { "-o~~TmWdp", "-h-", "-x", "1", "-y", "0",
| 75 |
"-dt", "0", "-as", "0", "-aa", "0", NULL };
| 76 |
| 77 |
struct rtproc rt0; /* head of rtrace process list */
| 78 |
| 79 |
struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
| 80 |
| 81 |
char persistfn[] = "pfXXXXXX"; /* persist file name */
| 82 |
| 83 |
int gargc; /* global argc */
| 84 |
char **gargv; /* global argv */
| 85 |
#define progname gargv[0]
| 86 |
| 87 |
char *octree; /* global octree argument */
| 88 |
| 89 |
int inpfmt = 'a'; /* input format */
| 90 |
int outfmt = 'a'; /* output format */
| 91 |
| 92 |
int header = 1; /* output header? */
| 93 |
int xres = 0; /* horiz. output resolution */
| 94 |
int yres = 0; /* vert. output resolution */
| 95 |
| 96 |
long raysleft; /* number of rays left to trace */
| 97 |
long waitflush; /* how long until next flush */
| 98 |
| 99 |
unsigned long lastray = 0; /* last ray number sent */
| 100 |
unsigned long lastdone = 0; /* last ray processed */
| 101 |
| 102 |
int using_stdout = 0; /* are we using stdout? */
| 103 |
| 104 |
const char *modname[MAXMODLIST]; /* ordered modifier name list */
| 105 |
int nmods = 0; /* number of modifiers */
| 106 |
| 107 |
MODCONT *addmodifier(char *modn, char *outf, char *binv);
| 108 |
| 109 |
void init(int np);
| 110 |
int done_rprocs(struct rtproc *rtp);
| 111 |
void trace_contribs(FILE *fp);
| 112 |
struct rtproc *wait_rproc(void);
| 113 |
struct rtproc *get_rproc(void);
| 114 |
void queue_raytree(struct rtproc *rtp);
| 115 |
void process_queue(void);
| 116 |
| 117 |
void putcontrib(const DCOLOR cnt, FILE *fout);
| 118 |
void add_contrib(const char *modn);
| 119 |
void done_contrib(void);
| 120 |
| 121 |
/* set input/output format */
| 122 |
static void
| 123 |
setformat(const char *fmt)
| 124 |
| 125 |
switch (fmt[0]) {
| 126 |
case 'a':
| 127 |
case 'f':
| 128 |
case 'd':
| 129 |
inpfmt = fmt[0];
| 130 |
break;
| 131 |
default:
| 132 |
goto fmterr;
| 133 |
| 134 |
switch (fmt[1]) {
| 135 |
case '\0':
| 136 |
outfmt = inpfmt;
| 137 |
return;
| 138 |
case 'a':
| 139 |
case 'f':
| 140 |
case 'd':
| 141 |
case 'c':
| 142 |
outfmt = fmt[1];
| 143 |
break;
| 144 |
default:
| 145 |
goto fmterr;
| 146 |
| 147 |
if (!fmt[2])
| 148 |
return;
| 149 |
fmterr:
| 150 |
sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
| 151 |
error(USER, errmsg);
| 152 |
| 153 |
| 154 |
/* gather rays from rtrace and output contributions */
| 155 |
int
| 156 |
main(int argc, char *argv[])
| 157 |
| 158 |
int nprocs = 1;
| 159 |
char *curout = NULL;
| 160 |
char *binval = NULL;
| 161 |
char fmt[8];
| 162 |
int i, j;
| 163 |
/* global program name */
| 164 |
gargv = argv;
| 165 |
/* set up calcomp mode */
| 166 |
esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
| 167 |
esupport &= ~(E_OUTCHAN);
| 168 |
/* get our options */
| 169 |
for (i = 1; i < argc-1; i++) {
| 170 |
/* expand arguments */
| 171 |
while ((j = expandarg(&argc, &argv, i)) > 0)
| 172 |
| 173 |
if (j < 0) {
| 174 |
fprintf(stderr, "%s: cannot expand '%s'",
| 175 |
argv[0], argv[i]);
| 176 |
exit(1);
| 177 |
| 178 |
if (argv[i][0] == '-')
| 179 |
switch (argv[i][1]) {
| 180 |
case 'n': /* number of processes */
| 181 |
if (argv[i][2] || i >= argc-1) break;
| 182 |
nprocs = atoi(argv[++i]);
| 183 |
if (nprocs <= 0)
| 184 |
error(USER, "illegal number of processes");
| 185 |
continue;
| 186 |
case 'h': /* output header? */
| 187 |
switch (argv[i][2]) {
| 188 |
case '\0':
| 189 |
header = !header;
| 190 |
continue;
| 191 |
case '+': case '1':
| 192 |
case 'T': case 't':
| 193 |
case 'Y': case 'y':
| 194 |
header = 1;
| 195 |
continue;
| 196 |
case '-': case '0':
| 197 |
case 'F': case 'f':
| 198 |
case 'N': case 'n':
| 199 |
header = 0;
| 200 |
continue;
| 201 |
| 202 |
break;
| 203 |
case 'f': /* file or i/o format */
| 204 |
if (!argv[i][2]) {
| 205 |
char *fpath;
| 206 |
if (i >= argc-1) break;
| 207 |
fpath = getpath(argv[++i],
| 208 |
getrlibpath(), R_OK);
| 209 |
if (fpath == NULL) {
| 210 |
sprintf(errmsg,
| 211 |
"cannot find file '%s'",
| 212 |
argv[i]);
| 213 |
| 214 |
| 215 |
fcompile(fpath);
| 216 |
continue;
| 217 |
| 218 |
setformat(argv[i]+2);
| 219 |
continue;
| 220 |
case 'e': /* expression */
| 221 |
| 222 |
scompile(argv[++i], NULL, 0);
| 223 |
continue;
| 224 |
case 'o': /* output file spec. */
| 225 |
| 226 |
curout = argv[++i];
| 227 |
continue;
| 228 |
case 'x': /* horiz. output resolution */
| 229 |
| 230 |
xres = atoi(argv[++i]);
| 231 |
continue;
| 232 |
case 'y': /* vert. output resolution */
| 233 |
| 234 |
yres = atoi(argv[++i]);
| 235 |
continue;
| 236 |
case 'b': /* bin expression */
| 237 |
| 238 |
binval = argv[++i];
| 239 |
continue;
| 240 |
case 'm': /* modifier name */
| 241 |
| 242 |
rtargv[rtargc++] = "-ti";
| 243 |
rtargv[rtargc++] = argv[++i];
| 244 |
addmodifier(argv[i], curout, binval);
| 245 |
continue;
| 246 |
| 247 |
rtargv[rtargc++] = argv[i]; /* assume rtrace option */
| 248 |
| 249 |
/* set global argument list */
| 250 |
gargc = argc; gargv = argv;
| 251 |
/* add "mandatory" rtrace settings */
| 252 |
for (j = 0; myrtopts[j] != NULL; j++)
| 253 |
rtargv[rtargc++] = myrtopts[j];
| 254 |
/* just asking for defaults? */
| 255 |
if (!strcmp(argv[i], "-defaults")) {
| 256 |
char sxres[16], syres[16];
| 257 |
char *rtpath;
| 258 |
printf("-n %-2d\t\t\t\t# number of processes\n", nprocs);
| 259 |
fflush(stdout); /* report OUR options */
| 260 |
rtargv[rtargc++] = header ? "-h+" : "-h-";
| 261 |
sprintf(fmt, "-f%c%c", inpfmt, outfmt);
| 262 |
rtargv[rtargc++] = fmt;
| 263 |
rtargv[rtargc++] = "-x";
| 264 |
sprintf(sxres, "%d", xres);
| 265 |
rtargv[rtargc++] = sxres;
| 266 |
rtargv[rtargc++] = "-y";
| 267 |
sprintf(syres, "%d", yres);
| 268 |
rtargv[rtargc++] = syres;
| 269 |
rtargv[rtargc++] = "-oTW";
| 270 |
rtargv[rtargc++] = "-defaults";
| 271 |
rtargv[rtargc] = NULL;
| 272 |
rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
| 273 |
if (rtpath == NULL) {
| 274 |
eputs(rtargv[0]);
| 275 |
eputs(": command not found\n");
| 276 |
exit(1);
| 277 |
| 278 |
execv(rtpath, rtargv);
| 279 |
perror(rtpath); /* execv() should not return */
| 280 |
exit(1);
| 281 |
| 282 |
if (nprocs > 1) { /* add persist file if parallel */
| 283 |
rtargv[rtargc++] = "-PP";
| 284 |
rtargv[rtargc++] = mktemp(persistfn);
| 285 |
| 286 |
/* add format string */
| 287 |
sprintf(fmt, "-f%cf", inpfmt);
| 288 |
| 289 |
/* octree argument is last */
| 290 |
if (i <= 0 || i != argc-1 || argv[i][0] == '-')
| 291 |
error(USER, "missing octree argument");
| 292 |
rtargv[rtargc++] = octree = argv[i];
| 293 |
| 294 |
/* start rtrace & compute contributions */
| 295 |
init(nprocs);
| 296 |
trace_contribs(stdin);
| 297 |
quit(0);
| 298 |
| 299 |
| 300 |
/* kill persistent rtrace process */
| 301 |
static void
| 302 |
killpersist(void)
| 303 |
| 304 |
FILE *fp = fopen(persistfn, "r");
| 305 |
int pid;
| 306 |
| 307 |
if (fp == NULL)
| 308 |
return;
| 309 |
if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
| 310 |
unlink(persistfn);
| 311 |
fclose(fp);
| 312 |
| 313 |
| 314 |
/* close rtrace processes and clean up */
| 315 |
int
| 316 |
| 317 |
| 318 |
int st0, st1 = 0;
| 319 |
| 320 |
if (rtp->next != NULL) { /* close last opened first! */
| 321 |
st1 = done_rprocs(rtp->next);
| 322 |
free((void *)rtp->next);
| 323 |
rtp->next = NULL;
| 324 |
| 325 |
st0 = close_process(&rtp->pd);
| 326 |
if (st0 < 0)
| 327 |
error(WARNING, "unknown return status from rtrace process");
| 328 |
else if (st0 > 0)
| 329 |
return(st0);
| 330 |
return(st1);
| 331 |
| 332 |
| 333 |
/* exit with status */
| 334 |
void
| 335 |
quit(int status)
| 336 |
| 337 |
int rtstat;
| 338 |
| 339 |
if (rt0.next != NULL) /* terminate persistent rtrace */
| 340 |
killpersist();
| 341 |
/* clean up rtrace process(es) */
| 342 |
rtstat = done_rprocs(&rt0);
| 343 |
if (status == 0)
| 344 |
status = rtstat;
| 345 |
exit(status); /* flushes all output streams */
| 346 |
| 347 |
| 348 |
/* start rtrace processes and initialize */
| 349 |
void
| 350 |
init(int np)
| 351 |
| 352 |
struct rtproc *rtp;
| 353 |
int i;
| 354 |
int maxbytes;
| 355 |
/* make sure we have something to do */
| 356 |
if (!nmods)
| 357 |
error(USER, "No modifiers specified");
| 358 |
/* assign ray variables */
| 359 |
scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
| 360 |
scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
| 361 |
/* set up signal handling */
| 362 |
signal(SIGINT, quit);
| 363 |
#ifdef SIGHUP
| 364 |
signal(SIGHUP, quit);
| 365 |
#endif
| 366 |
#ifdef SIGTERM
| 367 |
signal(SIGTERM, quit);
| 368 |
#endif
| 369 |
#ifdef SIGPIPE
| 370 |
signal(SIGPIPE, quit);
| 371 |
#endif
| 372 |
rtp = &rt0; /* start rtrace process(es) */
| 373 |
for (i = 0; i++ < np; ) {
| 374 |
errno = 0;
| 375 |
maxbytes = open_process(&rtp->pd, rtargv);
| 376 |
if (maxbytes == 0) {
| 377 |
eputs(rtargv[0]);
| 378 |
| 379 |
exit(1);
| 380 |
| 381 |
if (maxbytes < 0)
| 382 |
error(SYSTEM, "cannot start rtrace process");
| 383 |
if (maxbytes > treebufsiz)
| 384 |
treebufsiz = maxbytes;
| 385 |
rtp->raynum = 0;
| 386 |
rtp->bsiz = 0;
| 387 |
rtp->buf = NULL;
| 388 |
rtp->nbr = 0;
| 389 |
if (i == np) /* last process? */
| 390 |
break;
| 391 |
if (i == 1)
| 392 |
sleep(2); /* wait for persist file */
| 393 |
rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
| 394 |
if (rtp->next == NULL)
| 395 |
error(SYSTEM, "out of memory in init");
| 396 |
rtp = rtp->next;
| 397 |
| 398 |
rtp->next = NULL; /* terminate list */
| 399 |
if (yres > 0) {
| 400 |
if (xres > 0)
| 401 |
raysleft = xres*yres;
| 402 |
else
| 403 |
raysleft = yres;
| 404 |
} else
| 405 |
raysleft = 0;
| 406 |
waitflush = xres;
| 407 |
| 408 |
| 409 |
/* add modifier to our list to track */
| 410 |
MODCONT *
| 411 |
| 412 |
| 413 |
LUENT *lep = lu_find(&modconttab, modn);
| 414 |
MODCONT *mp;
| 415 |
| 416 |
if (lep->data != NULL) {
| 417 |
sprintf(errmsg, "duplicate modifier '%s'", modn);
| 418 |
| 419 |
| 420 |
if (nmods >= MAXMODLIST)
| 421 |
error(USER, "too many modifiers");
| 422 |
modname[nmods++] = modn; /* XXX assumes static string */
| 423 |
lep->key = modn; /* XXX assumes static string */
| 424 |
mp = (MODCONT *)malloc(sizeof(MODCONT));
| 425 |
if (mp == NULL)
| 426 |
error(SYSTEM, "out of memory in addmodifier");
| 427 |
lep->data = (char *)mp;
| 428 |
mp->outspec = outf; /* XXX assumes static string */
| 429 |
mp->modname = modn; /* XXX assumes static string */
| 430 |
if (binv != NULL)
| 431 |
mp->binv = eparse(binv);
| 432 |
else
| 433 |
mp->binv = eparse("0");
| 434 |
mp->nbins = 1;
| 435 |
setcolor(mp->cbin[0], 0., 0., 0.);
| 436 |
return mp;
| 437 |
| 438 |
| 439 |
/* put string to stderr */
| 440 |
void
| 441 |
eputs(char *s)
| 442 |
| 443 |
static int midline = 0;
| 444 |
| 445 |
if (!*s) return;
| 446 |
if (!midline) {
| 447 |
fputs(progname, stderr);
| 448 |
fputs(": ", stderr);
| 449 |
| 450 |
fputs(s, stderr);
| 451 |
midline = s[strlen(s)-1] != '\n';
| 452 |
| 453 |
| 454 |
/* write header to the given output stream */
| 455 |
void
| 456 |
printheader(FILE *fout)
| 457 |
| 458 |
extern char VersionID[];
| 459 |
FILE *fin = fopen(octree, "r");
| 460 |
| 461 |
if (fin == NULL)
| 462 |
quit(1);
| 463 |
checkheader(fin, "ignore", fout); /* copy octree header */
| 464 |
fclose(fin);
| 465 |
printargs(gargc-1, gargv, fout); /* add our command */
| 466 |
fprintf(fout, "SOFTWARE= %s\n", VersionID);
| 467 |
fputnow(fout);
| 468 |
switch (outfmt) { /* add output format */
| 469 |
case 'a':
| 470 |
fputformat("ascii", fout);
| 471 |
break;
| 472 |
case 'f':
| 473 |
fputformat("float", fout);
| 474 |
break;
| 475 |
case 'd':
| 476 |
fputformat("double", fout);
| 477 |
break;
| 478 |
case 'c':
| 479 |
fputformat(COLRFMT, fout);
| 480 |
break;
| 481 |
| 482 |
fputc('\n', fout);
| 483 |
if (xres > 0) {
| 484 |
if (yres > 0) /* resolution string */
| 485 |
fprtresolu(xres, yres, fout);
| 486 |
fflush(fout);
| 487 |
| 488 |
| 489 |
| 490 |
/* Get output file pointer (open and write header if new) */
| 491 |
FILE *
| 492 |
| 493 |
| 494 |
const char *mnp = NULL;
| 495 |
const char *bnp = NULL;
| 496 |
const char *cp;
| 497 |
char ofname[1024];
| 498 |
LUENT *lep;
| 499 |
| 500 |
if (ospec == NULL) { /* use stdout? */
| 501 |
if (!using_stdout && header)
| 502 |
printheader(stdout);
| 503 |
using_stdout = 1;
| 504 |
return stdout;
| 505 |
| 506 |
for (cp = ospec; *cp; cp++) /* check format position(s) */
| 507 |
if (*cp == '%') {
| 508 |
do
| 509 |
++cp;
| 510 |
while (isdigit(*cp));
| 511 |
switch (*cp) {
| 512 |
case '%':
| 513 |
break;
| 514 |
case 's':
| 515 |
if (mnp != NULL)
| 516 |
goto badspec;
| 517 |
mnp = cp;
| 518 |
break;
| 519 |
case 'd':
| 520 |
if (bnp != NULL)
| 521 |
goto badspec;
| 522 |
bnp = cp;
| 523 |
break;
| 524 |
default:
| 525 |
goto badspec;
| 526 |
| 527 |
| 528 |
if (mnp != NULL) { /* create file name */
| 529 |
if (bnp != NULL) {
| 530 |
if (bnp > mnp)
| 531 |
sprintf(ofname, ospec, mname, bn);
| 532 |
else
| 533 |
sprintf(ofname, ospec, bn, mname);
| 534 |
} else
| 535 |
sprintf(ofname, ospec, mname);
| 536 |
} else if (bnp != NULL)
| 537 |
sprintf(ofname, ospec, bn);
| 538 |
else
| 539 |
strcpy(ofname, ospec);
| 540 |
lep = lu_find(&ofiletab, ofname); /* look it up */
| 541 |
if (lep->key == NULL) /* new entry */
| 542 |
lep->key = strcpy((char *)malloc(strlen(ofname)+1), ofname);
| 543 |
if (lep->data == NULL) { /* open output file */
| 544 |
FILE *fp = fopen(ofname, "w");
| 545 |
int i;
| 546 |
if (fp == NULL) {
| 547 |
sprintf(errmsg, "cannot open '%s' for writing", ofname);
| 548 |
error(SYSTEM, errmsg);
| 549 |
| 550 |
if (header)
| 551 |
printheader(fp);
| 552 |
/* play catch-up */
| 553 |
for (i = 0; i < lastdone; i++) {
| 554 |
static const DCOLOR nocontrib = BLKCOLOR;
| 555 |
putcontrib(nocontrib, fp);
| 556 |
if (outfmt == 'a')
| 557 |
putc('\n', fp);
| 558 |
| 559 |
if (xres > 0)
| 560 |
fflush(fp);
| 561 |
lep->data = (char *)fp;
| 562 |
| 563 |
return (FILE *)lep->data; /* return open file pointer */
| 564 |
badspec:
| 565 |
sprintf(errmsg, "bad output format '%s'", ospec);
| 566 |
| 567 |
return NULL; /* pro forma return */
| 568 |
| 569 |
| 570 |
/* read input ray into buffer */
| 571 |
int
| 572 |
getinp(char *buf, FILE *fp)
| 573 |
| 574 |
char *cp;
| 575 |
int i;
| 576 |
| 577 |
switch (inpfmt) {
| 578 |
case 'a':
| 579 |
cp = buf; /* make sure we get 6 floats */
| 580 |
for (i = 0; i < 6; i++) {
| 581 |
if (fgetword(cp, buf+127-cp, fp) == NULL)
| 582 |
return 0;
| 583 |
if ((cp = fskip(cp)) == NULL || *cp)
| 584 |
return 0;
| 585 |
*cp++ = ' ';
| 586 |
| 587 |
getc(fp); /* get/put eol */
| 588 |
*cp-- = '\0'; *cp = '\n';
| 589 |
return strlen(buf);
| 590 |
case 'f':
| 591 |
if (fread(buf, sizeof(float), 6, fp) < 6)
| 592 |
return 0;
| 593 |
return sizeof(float)*6;
| 594 |
case 'd':
| 595 |
if (fread(buf, sizeof(double), 6, fp) < 6)
| 596 |
return 0;
| 597 |
return sizeof(double)*6;
| 598 |
| 599 |
error(INTERNAL, "botched input format");
| 600 |
return 0; /* pro forma return */
| 601 |
| 602 |
| 603 |
static float rparams[9]; /* traced ray parameters */
| 604 |
| 605 |
/* return channel (ray) value */
| 606 |
double
| 607 |
chanvalue(int n)
| 608 |
| 609 |
if (--n < 0 || n >= 6)
| 610 |
error(USER, "illegal channel number ($N)");
| 611 |
return rparams[n+3];
| 612 |
| 613 |
| 614 |
/* add current ray contribution to the appropriate modifier bin */
| 615 |
void
| 616 |
| 617 |
| 618 |
LUENT *le = lu_find(&modconttab, modn);
| 619 |
MODCONT *mp = (MODCONT *)le->data;
| 620 |
int bn;
| 621 |
| 622 |
if (mp == NULL) {
| 623 |
sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
| 624 |
| 625 |
| 626 |
eclock++; /* get bin number */
| 627 |
bn = (int)(evalue(mp->binv) + .5);
| 628 |
if (bn <= 0)
| 629 |
bn = 0;
| 630 |
else if (bn > mp->nbins) { /* new bin */
| 631 |
mp = (MODCONT *)realloc(mp, sizeof(MODCONT) +
| 632 |
bn*sizeof(DCOLOR));
| 633 |
if (mp == NULL)
| 634 |
error(SYSTEM, "out of memory in add_contrib");
| 635 |
memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(bn+1-mp->nbins));
| 636 |
mp->nbins = bn+1;
| 637 |
le->data = (char *)mp;
| 638 |
| 639 |
addcolor(mp->cbin[bn], rparams);
| 640 |
| 641 |
| 642 |
/* output newline to ASCII file and/or flush as requested */
| 643 |
static int
| 644 |
puteol(const LUENT *e, void *p)
| 645 |
| 646 |
FILE *fp = (FILE *)e->data;
| 647 |
| 648 |
if (outfmt == 'a')
| 649 |
putc('\n', fp);
| 650 |
if (!waitflush)
| 651 |
fflush(fp);
| 652 |
if (ferror(fp)) {
| 653 |
sprintf(errmsg, "write error on file '%s'", e->key);
| 654 |
| 655 |
| 656 |
return 0;
| 657 |
| 658 |
| 659 |
/* put out ray contribution to file */
| 660 |
void
| 661 |
| 662 |
| 663 |
float fv[3];
| 664 |
COLR cv;
| 665 |
| 666 |
switch (outfmt) {
| 667 |
case 'a':
| 668 |
fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
| 669 |
break;
| 670 |
case 'f':
| 671 |
fv[0] = cnt[0];
| 672 |
fv[1] = cnt[1];
| 673 |
fv[2] = cnt[2];
| 674 |
fwrite(fv, sizeof(float), 3, fout);
| 675 |
break;
| 676 |
case 'd':
| 677 |
fwrite(cnt, sizeof(double), 3, fout);
| 678 |
break;
| 679 |
case 'c':
| 680 |
setcolr(cv, cnt[0], cnt[1], cnt[2]);
| 681 |
fwrite(cv, sizeof(cv), 1, fout);
| 682 |
break;
| 683 |
default:
| 684 |
error(INTERNAL, "botched output format");
| 685 |
| 686 |
| 687 |
| 688 |
/* output ray tallies and clear for next primary */
| 689 |
void
| 690 |
done_contrib(void)
| 691 |
| 692 |
int i, j;
| 693 |
MODCONT *mp;
| 694 |
/* output modifiers in order */
| 695 |
for (i = 0; i < nmods; i++) {
| 696 |
mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
| 697 |
for (j = 0; j < mp->nbins; j++)
| 698 |
putcontrib(mp->cbin[j],
| 699 |
getofile(mp->outspec, mp->modname, j));
| 700 |
/* clear for next ray tree */
| 701 |
memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
| 702 |
| 703 |
--waitflush; /* terminate records */
| 704 |
lu_doall(&ofiletab, puteol, NULL);
| 705 |
if (using_stdout & (outfmt == 'a'))
| 706 |
putc('\n', stdout);
| 707 |
if (!waitflush) {
| 708 |
waitflush = xres;
| 709 |
if (using_stdout)
| 710 |
fflush(stdout);
| 711 |
| 712 |
| 713 |
| 714 |
/* queue completed ray tree produced by rtrace process */
| 715 |
void
| 716 |
| 717 |
| 718 |
struct rtproc *rtu, *rtl = NULL;
| 719 |
/* insert following ray order */
| 720 |
for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
| 721 |
if (rtp->raynum < rtu->raynum)
| 722 |
break;
| 723 |
rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
| 724 |
if (rtu == NULL)
| 725 |
error(SYSTEM, "out of memory in queue_raytree");
| 726 |
*rtu = *rtp;
| 727 |
if (rtl == NULL) {
| 728 |
rtu->next = rt_unproc;
| 729 |
rt_unproc = rtu;
| 730 |
} else {
| 731 |
rtu->next = rtl->next;
| 732 |
rtl->next = rtu;
| 733 |
| 734 |
rtp->raynum = 0; /* clear path for next ray tree */
| 735 |
rtp->bsiz = 0;
| 736 |
rtp->buf = NULL;
| 737 |
rtp->nbr = 0;
| 738 |
| 739 |
| 740 |
/* process completed ray trees from our queue */
| 741 |
void
| 742 |
process_queue(void)
| 743 |
| 744 |
char modname[128];
| 745 |
/* ray-ordered queue */
| 746 |
while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
| 747 |
struct rtproc *rtp = rt_unproc;
| 748 |
int n = rtp->nbr;
| 749 |
const char *cp = rtp->buf;
| 750 |
while (n > 0) { /* process rays */
| 751 |
register char *mnp = modname;
| 752 |
/* skip leading tabs */
| 753 |
while (n > 0 && *cp == '\t') {
| 754 |
cp++; n--;
| 755 |
| 756 |
if (!n || !(isalpha(*cp) | (*cp == '_')))
| 757 |
error(USER, "bad modifier name from rtrace");
| 758 |
/* get modifier name */
| 759 |
while (n > 0 && *cp != '\t') {
| 760 |
*mnp++ = *cp++; n--;
| 761 |
| 762 |
*mnp = '\0';
| 763 |
cp++; n--; /* eat following tab */
| 764 |
if (n < (int)(sizeof(float)*9))
| 765 |
error(USER, "incomplete ray value from rtrace");
| 766 |
/* add ray contribution */
| 767 |
memcpy(rparams, cp, sizeof(float)*9);
| 768 |
cp += sizeof(float)*9; n -= sizeof(float)*9;
| 769 |
add_contrib(modname);
| 770 |
| 771 |
done_contrib(); /* sum up contributions & output */
| 772 |
lastdone = rtp->raynum;
| 773 |
free(rtp->buf); /* free up buffer space */
| 774 |
rt_unproc = rtp->next;
| 775 |
free(rtp); /* done with this ray tree */
| 776 |
| 777 |
| 778 |
| 779 |
/* wait for rtrace process to finish with ray tree */
| 780 |
struct rtproc *
| 781 |
wait_rproc(void)
| 782 |
| 783 |
struct rtproc *rtfree = NULL;
| 784 |
fd_set readset, errset;
| 785 |
int nr;
| 786 |
struct rtproc *rt;
| 787 |
int n;
| 788 |
| 789 |
do {
| 790 |
nr = 0; /* prepare select call */
| 791 |
FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
| 792 |
for (rt = &rt0; rt != NULL; rt = rt->next) {
| 793 |
if (rt->raynum) {
| 794 |
FD_SET(rt->pd.r, &readset);
| 795 |
++nr;
| 796 |
| 797 |
FD_SET(rt->pd.r, &errset);
| 798 |
if (rt->pd.r >= n)
| 799 |
n = rt->pd.r + 1;
| 800 |
| 801 |
if (!nr) /* no rays pending */
| 802 |
break;
| 803 |
if (nr > 1) { /* call select for multiple proc's */
| 804 |
errno = 0;
| 805 |
if (select(n, &readset, NULL, &errset, NULL) < 0)
| 806 |
error(SYSTEM, "select call error in wait_rproc()");
| 807 |
} else
| 808 |
FD_ZERO(&errset);
| 809 |
nr = 0;
| 810 |
| 811 |
if (!FD_ISSET(rt->pd.r, &readset) &&
| 812 |
!FD_ISSET(rt->pd.r, &errset))
| 813 |
continue;
| 814 |
if (rt->buf == NULL) {
| 815 |
rt->bsiz = treebufsiz;
| 816 |
rt->buf = (char *)malloc(treebufsiz);
| 817 |
} else if (rt->nbr + BUFSIZ > rt->bsiz) {
| 818 |
if (rt->bsiz + BUFSIZ <= treebufsiz)
| 819 |
| 820 |
else
| 821 |
rt->bsiz = treebufsiz += BUFSIZ;
| 822 |
rt->buf = (char *)realloc(rt->buf, rt->bsiz);
| 823 |
| 824 |
| 825 |
error(SYSTEM, "out of memory in wait_rproc");
| 826 |
nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
| 827 |
if (nr <= 0)
| 828 |
error(USER, "rtrace process died");
| 829 |
rt->nbr += nr; /* advance & check */
| 830 |
if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4,
| 831 |
"~\t~\t", 4)) {
| 832 |
rt->nbr -= 4; /* elide terminator */
| 833 |
queue_raytree(rt);
| 834 |
rtfree = rt; /* ready for next ray */
| 835 |
| 836 |
| 837 |
} while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
| 838 |
return rtfree;
| 839 |
| 840 |
| 841 |
/* return next available rtrace process */
| 842 |
struct rtproc *
| 843 |
get_rproc(void)
| 844 |
| 845 |
struct rtproc *rtp;
| 846 |
/* check for idle rtrace */
| 847 |
for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
| 848 |
if (!rtp->raynum)
| 849 |
return rtp;
| 850 |
return wait_rproc(); /* need to wait for one */
| 851 |
| 852 |
| 853 |
/* trace ray contributions (main loop) */
| 854 |
void
| 855 |
trace_contribs(FILE *fin)
| 856 |
| 857 |
char inpbuf[128];
| 858 |
int iblen;
| 859 |
struct rtproc *rtp;
| 860 |
/* loop over input */
| 861 |
while ((iblen = getinp(inpbuf, fin)) > 0) {
| 862 |
if (lastray+1 < lastray) { /* counter rollover? */
| 863 |
while (wait_rproc() != NULL)
| 864 |
process_queue();
| 865 |
lastdone = lastray = 0;
| 866 |
| 867 |
rtp = get_rproc(); /* get avail. rtrace process */
| 868 |
rtp->raynum = ++lastray; /* assign ray to it */
| 869 |
writebuf(rtp->pd.w, inpbuf, iblen);
| 870 |
if (!--raysleft)
| 871 |
break;
| 872 |
process_queue(); /* catch up with results */
| 873 |
| 874 |
while (wait_rproc() != NULL) /* process outstanding rays */
| 875 |
process_queue();
| 876 |
if (raysleft > 0)
| 877 |
error(USER, "unexpected EOF on input");
| 878 |
