| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rtcontrib.c,v 1.34 2005/10/11 04:27:41 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Gather rtrace output to compute contributions from particular sources
| 6 |
| 7 |
| 8 |
#include "standard.h"
| 9 |
#include <ctype.h>
| 10 |
#include <signal.h>
| 11 |
#include "platform.h"
| 12 |
#include "rtprocess.h"
| 13 |
#include "selcall.h"
| 14 |
#include "color.h"
| 15 |
#include "resolu.h"
| 16 |
#include "lookup.h"
| 17 |
#include "calcomp.h"
| 18 |
| 19 |
#ifndef MAXMODLIST
| 20 |
#define MAXMODLIST 1024 /* maximum modifiers we'll track */
| 21 |
#endif
| 22 |
| 23 |
int treebufsiz = BUFSIZ; /* current tree buffer size */
| 24 |
| 25 |
typedef double DCOLOR[3]; /* double-precision color */
| 26 |
| 27 |
| 28 |
* The MODCONT structure is used to accumulate ray contributions
| 29 |
* for a particular modifier, which may be subdivided into bins
| 30 |
* if binv is non-zero. If outspec contains a %s in it, this will
| 31 |
* be replaced with the modifier name. If outspec contains a %d in it,
| 32 |
* this will be used to create one output file per bin, otherwise all bins
| 33 |
* will be written to the same file, in order. If the global outfmt
| 34 |
* is 'c', then a 4-byte RGBE pixel will be output for each bin value
| 35 |
* and the file will conform to a RADIANCE image if xres & yres are set.
| 36 |
| 37 |
typedef struct {
| 38 |
const char *outspec; /* output file specification */
| 39 |
const char *modname; /* modifier name */
| 40 |
EPNODE *binv; /* bin value expression */
| 41 |
int nbins; /* number of accumulation bins */
| 42 |
DCOLOR cbin[1]; /* contribution bins (extends struct) */
| 43 |
} MODCONT; /* modifier contribution */
| 44 |
| 45 |
static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
| 46 |
| 47 |
LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
| 48 |
| 49 |
#define CNT_UNKNOWN 0 /* unknown record length */
| 50 |
#define CNT_PIPE (-1) /* output to a pipe */
| 51 |
| 52 |
* The STREAMOUT structure holds an open FILE pointer and a count of
| 53 |
* the number of RGB triplets per record, or CNT_UNKNOWN (0) if
| 54 |
* unknown or CNT_PIPE (-1) if writing to a command.
| 55 |
| 56 |
typedef struct {
| 57 |
FILE *ofp; /* output file pointer */
| 58 |
int reclen; /* triplets/record */
| 59 |
} STREAMOUT;
| 60 |
| 61 |
/* close output stream and free record */
| 62 |
static void
| 63 |
closestream(void *p)
| 64 |
| 65 |
STREAMOUT *sop = (STREAMOUT *)p;
| 66 |
int status;
| 67 |
if (sop->reclen == CNT_PIPE)
| 68 |
status = pclose(sop->ofp);
| 69 |
else
| 70 |
status = fclose(sop->ofp);
| 71 |
if (status)
| 72 |
error(SYSTEM, "error closing output stream");
| 73 |
free(p);
| 74 |
| 75 |
| 76 |
LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
| 77 |
| 78 |
#define OF_MODIFIER 01
| 79 |
#define OF_BIN 02
| 80 |
| 81 |
STREAMOUT *getostream(const char *ospec, const char *mname, int bn, int noopen);
| 82 |
int ofname(char *oname, const char *ospec, const char *mname, int bn);
| 83 |
void printheader(FILE *fout, const char *info);
| 84 |
void printresolu(FILE *fout);
| 85 |
| 86 |
| 87 |
* The rcont structure is used to manage i/o with a particular
| 88 |
* rtrace child process. Input is passed unchanged from stdin,
| 89 |
* and output is processed in input order and accumulated according
| 90 |
* to the corresponding modifier and bin number.
| 91 |
| 92 |
struct rtproc {
| 93 |
struct rtproc *next; /* next in list of processes */
| 94 |
SUBPROC pd; /* rtrace pipe descriptors */
| 95 |
unsigned long raynum; /* ray number for this tree */
| 96 |
int bsiz; /* ray tree buffer length */
| 97 |
char *buf; /* ray tree buffer */
| 98 |
int nbr; /* number of bytes from rtrace */
| 99 |
}; /* rtrace process buffer */
| 100 |
| 101 |
/* rtrace command and defaults */
| 102 |
char *rtargv[256+2*MAXMODLIST] = { "rtrace",
| 103 |
"-dj", ".5", "-dr", "3",
| 104 |
"-ab", "1", "-ad", "128", };
| 105 |
int rtargc = 9;
| 106 |
/* overriding rtrace options */
| 107 |
char *myrtopts[] = { "-o~~TmWdp", "-h-", "-x", "1", "-y", "0",
| 108 |
"-dt", "0", "-as", "0", "-aa", "0", NULL };
| 109 |
| 110 |
struct rtproc rt0; /* head of rtrace process list */
| 111 |
| 112 |
struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
| 113 |
| 114 |
char persistfn[] = "pfXXXXXX"; /* persist file name */
| 115 |
| 116 |
int gargc; /* global argc */
| 117 |
char **gargv; /* global argv */
| 118 |
#define progname gargv[0]
| 119 |
| 120 |
char *octree; /* global octree argument */
| 121 |
| 122 |
int inpfmt = 'a'; /* input format */
| 123 |
int outfmt = 'a'; /* output format */
| 124 |
| 125 |
int header = 1; /* output header? */
| 126 |
int force_open = 0; /* truncate existing output? */
| 127 |
int xres = 0; /* horiz. output resolution */
| 128 |
int yres = 0; /* vert. output resolution */
| 129 |
| 130 |
unsigned long raysleft; /* number of rays left to trace */
| 131 |
long waitflush; /* how long until next flush */
| 132 |
| 133 |
unsigned long lastray = 0; /* last ray number sent */
| 134 |
unsigned long lastdone = 0; /* last ray processed */
| 135 |
| 136 |
int using_stdout = 0; /* are we using stdout? */
| 137 |
| 138 |
const char *modname[MAXMODLIST]; /* ordered modifier name list */
| 139 |
int nmods = 0; /* number of modifiers */
| 140 |
| 141 |
#define queue_length() (lastray - lastdone)
| 142 |
| 143 |
MODCONT *growmodifier(MODCONT *mp, int nb);
| 144 |
MODCONT *addmodifier(char *modn, char *outf, char *binv, int bincnt);
| 145 |
void addmodfile(char *fname, char *outf, char *binv, int bincnt);
| 146 |
| 147 |
void init(int np);
| 148 |
int done_rprocs(struct rtproc *rtp);
| 149 |
void recover_output(FILE *fin);
| 150 |
void trace_contribs(FILE *fin);
| 151 |
struct rtproc *wait_rproc(void);
| 152 |
struct rtproc *get_rproc(void);
| 153 |
void queue_raytree(struct rtproc *rtp);
| 154 |
void process_queue(void);
| 155 |
| 156 |
void put_contrib(const DCOLOR cnt, FILE *fout);
| 157 |
void add_contrib(const char *modn);
| 158 |
void done_contrib(void);
| 159 |
| 160 |
/* return number of open rtrace processes */
| 161 |
static int
| 162 |
nrtprocs(void)
| 163 |
| 164 |
int nrtp = 0;
| 165 |
struct rtproc *rtp;
| 166 |
| 167 |
for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
| 168 |
nrtp += rtp->pd.running;
| 169 |
return(nrtp);
| 170 |
| 171 |
| 172 |
/* set input/output format */
| 173 |
static void
| 174 |
setformat(const char *fmt)
| 175 |
| 176 |
switch (fmt[0]) {
| 177 |
case 'f':
| 178 |
case 'd':
| 179 |
SET_FILE_BINARY(stdin);
| 180 |
/* fall through */
| 181 |
case 'a':
| 182 |
inpfmt = fmt[0];
| 183 |
break;
| 184 |
default:
| 185 |
goto fmterr;
| 186 |
| 187 |
switch (fmt[1]) {
| 188 |
case '\0':
| 189 |
outfmt = inpfmt;
| 190 |
return;
| 191 |
case 'a':
| 192 |
case 'f':
| 193 |
case 'd':
| 194 |
case 'c':
| 195 |
outfmt = fmt[1];
| 196 |
break;
| 197 |
default:
| 198 |
goto fmterr;
| 199 |
| 200 |
if (!fmt[2])
| 201 |
return;
| 202 |
fmterr:
| 203 |
sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
| 204 |
error(USER, errmsg);
| 205 |
| 206 |
| 207 |
/* gather rays from rtrace and output contributions */
| 208 |
int
| 209 |
main(int argc, char *argv[])
| 210 |
| 211 |
int nprocs = 1;
| 212 |
int recover = 0;
| 213 |
char *curout = NULL;
| 214 |
char *binval = NULL;
| 215 |
int bincnt = 0;
| 216 |
char fmt[8];
| 217 |
int i, j;
| 218 |
/* need at least one argument */
| 219 |
if (argc < 2) {
| 220 |
fprintf(stderr,
| 221 |
"Usage: %s [-n nprocs][-r][-e expr][-f source][-o ospec][-b binv] {-m mod | -M file} [rtrace options] octree\n",
| 222 |
argv[0]);
| 223 |
exit(1);
| 224 |
| 225 |
/* global program name */
| 226 |
gargv = argv;
| 227 |
/* initialize calcomp routines */
| 228 |
esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
| 229 |
esupport &= ~(E_OUTCHAN);
| 230 |
varset("PI", ':', PI);
| 231 |
/* get our options */
| 232 |
for (i = 1; i < argc-1; i++) {
| 233 |
/* expand arguments */
| 234 |
while ((j = expandarg(&argc, &argv, i)) > 0)
| 235 |
| 236 |
if (j < 0) {
| 237 |
fprintf(stderr, "%s: cannot expand '%s'",
| 238 |
argv[0], argv[i]);
| 239 |
exit(1);
| 240 |
| 241 |
if (argv[i][0] == '-')
| 242 |
switch (argv[i][1]) {
| 243 |
case 'r': /* recover output */
| 244 |
if (argv[i][2]) break;
| 245 |
recover++;
| 246 |
continue;
| 247 |
case 'n': /* number of processes */
| 248 |
if (argv[i][2] || i >= argc-2) break;
| 249 |
nprocs = atoi(argv[++i]);
| 250 |
if (nprocs <= 0)
| 251 |
error(USER, "illegal number of processes");
| 252 |
continue;
| 253 |
case 'h': /* output header? */
| 254 |
switch (argv[i][2]) {
| 255 |
case '\0':
| 256 |
header = !header;
| 257 |
continue;
| 258 |
case '+': case '1':
| 259 |
case 'T': case 't':
| 260 |
case 'Y': case 'y':
| 261 |
header = 1;
| 262 |
continue;
| 263 |
case '-': case '0':
| 264 |
case 'F': case 'f':
| 265 |
case 'N': case 'n':
| 266 |
header = 0;
| 267 |
continue;
| 268 |
| 269 |
break;
| 270 |
case 'f': /* file or force or format */
| 271 |
if (!argv[i][2]) {
| 272 |
char *fpath;
| 273 |
if (i >= argc-2) break;
| 274 |
fpath = getpath(argv[++i],
| 275 |
getrlibpath(), R_OK);
| 276 |
if (fpath == NULL) {
| 277 |
sprintf(errmsg,
| 278 |
"cannot find file '%s'",
| 279 |
argv[i]);
| 280 |
| 281 |
| 282 |
fcompile(fpath);
| 283 |
continue;
| 284 |
| 285 |
if (argv[i][2] == 'o') {
| 286 |
force_open++;
| 287 |
continue;
| 288 |
| 289 |
setformat(argv[i]+2);
| 290 |
continue;
| 291 |
case 'e': /* expression */
| 292 |
| 293 |
scompile(argv[++i], NULL, 0);
| 294 |
continue;
| 295 |
case 'o': /* output file spec. */
| 296 |
| 297 |
curout = argv[++i];
| 298 |
continue;
| 299 |
case 'x': /* horiz. output resolution */
| 300 |
| 301 |
xres = atoi(argv[++i]);
| 302 |
continue;
| 303 |
case 'y': /* vert. output resolution */
| 304 |
| 305 |
yres = atoi(argv[++i]);
| 306 |
continue;
| 307 |
case 'b': /* bin expression/count */
| 308 |
| 309 |
if (argv[i][2] == 'n') {
| 310 |
bincnt = atoi(argv[++i]);
| 311 |
continue;
| 312 |
| 313 |
| 314 |
binval = argv[++i];
| 315 |
continue;
| 316 |
case 'm': /* modifier name */
| 317 |
| 318 |
rtargv[rtargc++] = "-ti";
| 319 |
rtargv[rtargc++] = argv[++i];
| 320 |
addmodifier(argv[i], curout, binval, bincnt);
| 321 |
continue;
| 322 |
case 'M': /* modifier file */
| 323 |
| 324 |
rtargv[rtargc++] = "-tI";
| 325 |
| 326 |
addmodfile(argv[i], curout, binval, bincnt);
| 327 |
continue;
| 328 |
| 329 |
rtargv[rtargc++] = argv[i]; /* assume rtrace option */
| 330 |
| 331 |
/* set global argument list */
| 332 |
gargc = argc; gargv = argv;
| 333 |
/* add "mandatory" rtrace settings */
| 334 |
for (j = 0; myrtopts[j] != NULL; j++)
| 335 |
rtargv[rtargc++] = myrtopts[j];
| 336 |
/* just asking for defaults? */
| 337 |
if (!strcmp(argv[i], "-defaults")) {
| 338 |
char sxres[16], syres[16];
| 339 |
char *rtpath;
| 340 |
printf("-n %-2d\t\t\t\t# number of processes\n", nprocs);
| 341 |
fflush(stdout); /* report OUR options */
| 342 |
rtargv[rtargc++] = header ? "-h+" : "-h-";
| 343 |
sprintf(fmt, "-f%c%c", inpfmt, outfmt);
| 344 |
rtargv[rtargc++] = fmt;
| 345 |
rtargv[rtargc++] = "-x";
| 346 |
sprintf(sxres, "%d", xres);
| 347 |
rtargv[rtargc++] = sxres;
| 348 |
rtargv[rtargc++] = "-y";
| 349 |
sprintf(syres, "%d", yres);
| 350 |
rtargv[rtargc++] = syres;
| 351 |
rtargv[rtargc++] = "-oTW";
| 352 |
rtargv[rtargc++] = "-defaults";
| 353 |
rtargv[rtargc] = NULL;
| 354 |
rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
| 355 |
if (rtpath == NULL) {
| 356 |
eputs(rtargv[0]);
| 357 |
eputs(": command not found\n");
| 358 |
exit(1);
| 359 |
| 360 |
execv(rtpath, rtargv);
| 361 |
perror(rtpath); /* execv() should not return */
| 362 |
exit(1);
| 363 |
| 364 |
if (nprocs > 1) { /* add persist file if parallel */
| 365 |
rtargv[rtargc++] = "-PP";
| 366 |
rtargv[rtargc++] = mktemp(persistfn);
| 367 |
| 368 |
/* add format string */
| 369 |
sprintf(fmt, "-f%cf", inpfmt);
| 370 |
| 371 |
/* octree argument is last */
| 372 |
if (i <= 0 || i != argc-1 || argv[i][0] == '-')
| 373 |
error(USER, "missing octree argument");
| 374 |
rtargv[rtargc++] = octree = argv[i];
| 375 |
| 376 |
/* start rtrace */
| 377 |
init(nprocs);
| 378 |
if (recover) /* perform recovery if requested */
| 379 |
recover_output(stdin);
| 380 |
trace_contribs(stdin); /* compute contributions */
| 381 |
quit(0);
| 382 |
| 383 |
| 384 |
#ifndef SIGALRM
| 385 |
#define SIGALRM SIGTERM
| 386 |
#endif
| 387 |
/* kill persistent rtrace process */
| 388 |
static void
| 389 |
killpersist(void)
| 390 |
| 391 |
FILE *fp = fopen(persistfn, "r");
| 392 |
RT_PID pid;
| 393 |
| 394 |
if (fp == NULL)
| 395 |
return;
| 396 |
if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
| 397 |
unlink(persistfn);
| 398 |
fclose(fp);
| 399 |
| 400 |
| 401 |
/* close rtrace processes and clean up */
| 402 |
int
| 403 |
| 404 |
| 405 |
int st0, st1 = 0;
| 406 |
| 407 |
if (rtp->next != NULL) { /* close last opened first! */
| 408 |
st1 = done_rprocs(rtp->next);
| 409 |
free((void *)rtp->next);
| 410 |
rtp->next = NULL;
| 411 |
| 412 |
st0 = close_process(&rtp->pd);
| 413 |
if (st0 < 0)
| 414 |
error(WARNING, "unknown return status from rtrace process");
| 415 |
else if (st0 > 0)
| 416 |
return(st0);
| 417 |
return(st1);
| 418 |
| 419 |
| 420 |
/* exit with status */
| 421 |
void
| 422 |
quit(int status)
| 423 |
| 424 |
int rtstat;
| 425 |
| 426 |
if (rt0.next != NULL) /* terminate persistent rtrace */
| 427 |
killpersist();
| 428 |
/* clean up rtrace process(es) */
| 429 |
rtstat = done_rprocs(&rt0);
| 430 |
if (status == 0)
| 431 |
status = rtstat;
| 432 |
exit(status); /* flushes all output streams */
| 433 |
| 434 |
| 435 |
/* start rtrace processes and initialize */
| 436 |
void
| 437 |
init(int np)
| 438 |
| 439 |
struct rtproc *rtp;
| 440 |
int i;
| 441 |
int maxbytes;
| 442 |
/* make sure we have something to do */
| 443 |
if (!nmods)
| 444 |
error(USER, "No modifiers specified");
| 445 |
/* assign ray variables */
| 446 |
scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
| 447 |
scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
| 448 |
/* set up signal handling */
| 449 |
signal(SIGINT, quit);
| 450 |
#ifdef SIGHUP
| 451 |
signal(SIGHUP, quit);
| 452 |
#endif
| 453 |
#ifdef SIGTERM
| 454 |
signal(SIGTERM, quit);
| 455 |
#endif
| 456 |
#ifdef SIGPIPE
| 457 |
signal(SIGPIPE, quit);
| 458 |
#endif
| 459 |
rtp = &rt0; /* start rtrace process(es) */
| 460 |
for (i = 0; i++ < np; ) {
| 461 |
errno = 0;
| 462 |
maxbytes = open_process(&rtp->pd, rtargv);
| 463 |
if (maxbytes == 0) {
| 464 |
eputs(rtargv[0]);
| 465 |
| 466 |
exit(1);
| 467 |
| 468 |
if (maxbytes < 0)
| 469 |
error(SYSTEM, "cannot start rtrace process");
| 470 |
if (maxbytes > treebufsiz)
| 471 |
treebufsiz = maxbytes;
| 472 |
rtp->raynum = 0;
| 473 |
rtp->bsiz = 0;
| 474 |
rtp->buf = NULL;
| 475 |
rtp->nbr = 0;
| 476 |
if (i == np) /* last process? */
| 477 |
break;
| 478 |
if (i == 1)
| 479 |
sleep(2); /* wait for persist file */
| 480 |
rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
| 481 |
if (rtp->next == NULL)
| 482 |
error(SYSTEM, "out of memory in init");
| 483 |
rtp = rtp->next;
| 484 |
| 485 |
rtp->next = NULL; /* terminate list */
| 486 |
if (yres > 0) {
| 487 |
if (xres > 0)
| 488 |
raysleft = (unsigned long)xres*yres;
| 489 |
else
| 490 |
raysleft = yres;
| 491 |
} else
| 492 |
raysleft = 0;
| 493 |
waitflush = xres;
| 494 |
| 495 |
| 496 |
/* grow modifier to accommodate more bins */
| 497 |
MODCONT *
| 498 |
| 499 |
| 500 |
if (nb <= mp->nbins)
| 501 |
return mp;
| 502 |
mp = (MODCONT *)realloc(mp, sizeof(MODCONT) + sizeof(DCOLOR)*(nb-1));
| 503 |
if (mp == NULL)
| 504 |
error(SYSTEM, "out of memory in growmodifier");
| 505 |
memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(nb-mp->nbins));
| 506 |
mp->nbins = nb;
| 507 |
return mp;
| 508 |
| 509 |
| 510 |
/* add modifier to our list to track */
| 511 |
MODCONT *
| 512 |
| 513 |
| 514 |
LUENT *lep = lu_find(&modconttab, modn);
| 515 |
MODCONT *mp;
| 516 |
int i;
| 517 |
| 518 |
if (lep->data != NULL) {
| 519 |
sprintf(errmsg, "duplicate modifier '%s'", modn);
| 520 |
| 521 |
| 522 |
if (nmods >= MAXMODLIST)
| 523 |
error(USER, "too many modifiers");
| 524 |
modname[nmods++] = modn; /* XXX assumes static string */
| 525 |
lep->key = modn; /* XXX assumes static string */
| 526 |
mp = (MODCONT *)malloc(sizeof(MODCONT));
| 527 |
if (mp == NULL)
| 528 |
error(SYSTEM, "out of memory in addmodifier");
| 529 |
mp->outspec = outf; /* XXX assumes static string */
| 530 |
mp->modname = modn; /* XXX assumes static string */
| 531 |
if (binv != NULL)
| 532 |
mp->binv = eparse(binv);
| 533 |
else
| 534 |
mp->binv = eparse("0");
| 535 |
mp->nbins = 1;
| 536 |
setcolor(mp->cbin[0], 0., 0., 0.);
| 537 |
if (mp->binv->type == NUM) /* assume one bin if constant */
| 538 |
bincnt = 1;
| 539 |
else if (bincnt > 1)
| 540 |
mp = growmodifier(mp, bincnt);
| 541 |
lep->data = (char *)mp;
| 542 |
/* allocate output streams */
| 543 |
for (i = outf==NULL || outf[0]=='!' ? 0 : bincnt; i--; )
| 544 |
getostream(mp->outspec, mp->modname, i, 1);
| 545 |
return mp;
| 546 |
| 547 |
| 548 |
/* add modifiers from a file list */
| 549 |
void
| 550 |
| 551 |
| 552 |
char *mname[MAXMODLIST];
| 553 |
int i;
| 554 |
/* find the file & store strings */
| 555 |
if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
| 556 |
sprintf(errmsg, "cannot find modifier file '%s'", fname);
| 557 |
error(SYSTEM, errmsg);
| 558 |
| 559 |
for (i = 0; mname[i]; i++) /* add each one */
| 560 |
addmodifier(mname[i], outf, binv, bincnt);
| 561 |
| 562 |
| 563 |
/* put string to stderr */
| 564 |
void
| 565 |
eputs(char *s)
| 566 |
| 567 |
static int midline = 0;
| 568 |
| 569 |
if (!*s) return;
| 570 |
if (!midline) {
| 571 |
fputs(progname, stderr);
| 572 |
fputs(": ", stderr);
| 573 |
| 574 |
fputs(s, stderr);
| 575 |
midline = s[strlen(s)-1] != '\n';
| 576 |
| 577 |
| 578 |
/* construct output file name and return flags whether modifier/bin present */
| 579 |
int
| 580 |
| 581 |
| 582 |
const char *mnp = NULL;
| 583 |
const char *bnp = NULL;
| 584 |
const char *cp;
| 585 |
| 586 |
if (ospec == NULL)
| 587 |
return -1;
| 588 |
for (cp = ospec; *cp; cp++) /* check format position(s) */
| 589 |
if (*cp == '%') {
| 590 |
do
| 591 |
++cp;
| 592 |
while (isdigit(*cp));
| 593 |
switch (*cp) {
| 594 |
case '%':
| 595 |
break;
| 596 |
case 's':
| 597 |
if (mnp != NULL)
| 598 |
return -1;
| 599 |
mnp = cp;
| 600 |
break;
| 601 |
case 'd':
| 602 |
if (bnp != NULL)
| 603 |
return -1;
| 604 |
bnp = cp;
| 605 |
break;
| 606 |
default:
| 607 |
return -1;
| 608 |
| 609 |
| 610 |
if (mnp != NULL) { /* create file name */
| 611 |
if (bnp != NULL) {
| 612 |
if (bnp > mnp)
| 613 |
sprintf(oname, ospec, mname, bn);
| 614 |
else
| 615 |
sprintf(oname, ospec, bn, mname);
| 616 |
return OF_MODIFIER|OF_BIN;
| 617 |
| 618 |
sprintf(oname, ospec, mname);
| 619 |
return OF_MODIFIER;
| 620 |
| 621 |
if (bnp != NULL) {
| 622 |
sprintf(oname, ospec, bn);
| 623 |
return OF_BIN;
| 624 |
| 625 |
strcpy(oname, ospec);
| 626 |
return 0;
| 627 |
| 628 |
| 629 |
/* write header to the given output stream */
| 630 |
void
| 631 |
| 632 |
| 633 |
extern char VersionID[];
| 634 |
FILE *fin = fopen(octree, "r");
| 635 |
| 636 |
if (fin == NULL)
| 637 |
quit(1);
| 638 |
checkheader(fin, "ignore", fout); /* copy octree header */
| 639 |
fclose(fin);
| 640 |
printargs(gargc-1, gargv, fout); /* add our command */
| 641 |
fprintf(fout, "SOFTWARE= %s\n", VersionID);
| 642 |
fputnow(fout);
| 643 |
if (info != NULL) /* add extra info if given */
| 644 |
fputs(info, fout);
| 645 |
switch (outfmt) { /* add output format */
| 646 |
case 'a':
| 647 |
fputformat("ascii", fout);
| 648 |
break;
| 649 |
case 'f':
| 650 |
fputformat("float", fout);
| 651 |
break;
| 652 |
case 'd':
| 653 |
fputformat("double", fout);
| 654 |
break;
| 655 |
case 'c':
| 656 |
fputformat(COLRFMT, fout);
| 657 |
break;
| 658 |
| 659 |
fputc('\n', fout);
| 660 |
| 661 |
| 662 |
/* write resolution string to given output stream */
| 663 |
void
| 664 |
| 665 |
| 666 |
if (xres > 0) {
| 667 |
if (yres > 0) /* resolution string */
| 668 |
fprtresolu(xres, yres, fout);
| 669 |
fflush(fout);
| 670 |
| 671 |
| 672 |
| 673 |
/* Get output stream pointer (open and write header if new and noopen==0) */
| 674 |
STREAMOUT *
| 675 |
| 676 |
| 677 |
static STREAMOUT stdos;
| 678 |
int ofl;
| 679 |
char oname[1024];
| 680 |
LUENT *lep;
| 681 |
STREAMOUT *sop;
| 682 |
| 683 |
if (ospec == NULL) { /* use stdout? */
| 684 |
if (!noopen && !using_stdout) {
| 685 |
stdos.reclen = 0;
| 686 |
if (outfmt != 'a')
| 687 |
SET_FILE_BINARY(stdout);
| 688 |
if (header)
| 689 |
printheader(stdout, NULL);
| 690 |
printresolu(stdout);
| 691 |
using_stdout = 1;
| 692 |
| 693 |
stdos.ofp = stdout;
| 694 |
stdos.reclen += noopen;
| 695 |
return &stdos;
| 696 |
| 697 |
ofl = ofname(oname, ospec, mname, bn); /* get output name */
| 698 |
if (ofl < 0) {
| 699 |
sprintf(errmsg, "bad output format '%s'", ospec);
| 700 |
| 701 |
| 702 |
lep = lu_find(&ofiletab, oname); /* look it up */
| 703 |
if (lep->key == NULL) /* new entry */
| 704 |
lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
| 705 |
sop = (STREAMOUT *)lep->data;
| 706 |
if (sop == NULL) { /* allocate stream */
| 707 |
sop = (STREAMOUT *)malloc(sizeof(STREAMOUT));
| 708 |
if (sop == NULL)
| 709 |
error(SYSTEM, "out of memory in getostream");
| 710 |
sop->reclen = oname[0] == '!' ? CNT_PIPE : CNT_UNKNOWN;
| 711 |
sop->ofp = NULL; /* open iff noopen==0 */
| 712 |
lep->data = (char *)sop;
| 713 |
| 714 |
if (!noopen && sop->ofp == NULL) { /* open output stream */
| 715 |
long i;
| 716 |
if (oname[0] == '!') /* output to command */
| 717 |
sop->ofp = popen(oname+1, "w");
| 718 |
else if (!force_open && access(oname, F_OK) == 0)
| 719 |
errno = EEXIST; /* file exists */
| 720 |
else /* else open it */
| 721 |
sop->ofp = fopen(oname, "w");
| 722 |
if (sop->ofp == NULL) {
| 723 |
sprintf(errmsg, "cannot open '%s' for writing", oname);
| 724 |
| 725 |
| 726 |
if (outfmt != 'a')
| 727 |
SET_FILE_BINARY(sop->ofp);
| 728 |
if (header) {
| 729 |
char info[512];
| 730 |
char *cp = info;
| 731 |
if (ofl & OF_MODIFIER || sop->reclen == 1) {
| 732 |
sprintf(cp, "MODIFIER=%s\n", mname);
| 733 |
while (*cp) ++cp;
| 734 |
| 735 |
if (ofl & OF_BIN) {
| 736 |
sprintf(cp, "BIN=%d\n", bn);
| 737 |
while (*cp) ++cp;
| 738 |
| 739 |
*cp = '\0';
| 740 |
printheader(sop->ofp, info);
| 741 |
| 742 |
printresolu(sop->ofp);
| 743 |
/* play catch-up */
| 744 |
for (i = sop->reclen > 1 ? sop->reclen*lastdone : lastdone;
| 745 |
i--; ) {
| 746 |
static const DCOLOR nocontrib = BLKCOLOR;
| 747 |
put_contrib(nocontrib, sop->ofp);
| 748 |
if (outfmt == 'a')
| 749 |
putc('\n', sop->ofp);
| 750 |
| 751 |
if (xres > 0)
| 752 |
fflush(sop->ofp);
| 753 |
| 754 |
if (sop->reclen != CNT_PIPE) /* add to length if noopen */
| 755 |
sop->reclen += noopen;
| 756 |
return sop; /* return open stream */
| 757 |
| 758 |
| 759 |
/* read input ray into buffer */
| 760 |
int
| 761 |
getinp(char *buf, FILE *fp)
| 762 |
| 763 |
char *cp;
| 764 |
int i;
| 765 |
| 766 |
switch (inpfmt) {
| 767 |
case 'a':
| 768 |
cp = buf; /* make sure we get 6 floats */
| 769 |
for (i = 0; i < 6; i++) {
| 770 |
if (fgetword(cp, buf+127-cp, fp) == NULL)
| 771 |
return 0;
| 772 |
if ((cp = fskip(cp)) == NULL || *cp)
| 773 |
return 0;
| 774 |
*cp++ = ' ';
| 775 |
| 776 |
getc(fp); /* get/put eol */
| 777 |
*cp-- = '\0'; *cp = '\n';
| 778 |
return strlen(buf);
| 779 |
case 'f':
| 780 |
if (fread(buf, sizeof(float), 6, fp) < 6)
| 781 |
return 0;
| 782 |
return sizeof(float)*6;
| 783 |
case 'd':
| 784 |
if (fread(buf, sizeof(double), 6, fp) < 6)
| 785 |
return 0;
| 786 |
return sizeof(double)*6;
| 787 |
| 788 |
error(INTERNAL, "botched input format");
| 789 |
return 0; /* pro forma return */
| 790 |
| 791 |
| 792 |
static float rparams[9]; /* traced ray parameters */
| 793 |
| 794 |
/* return channel (ray) value */
| 795 |
double
| 796 |
chanvalue(int n)
| 797 |
| 798 |
if (--n < 0 || n >= 6)
| 799 |
error(USER, "illegal channel number ($N)");
| 800 |
return rparams[n+3];
| 801 |
| 802 |
| 803 |
/* add current ray contribution to the appropriate modifier bin */
| 804 |
void
| 805 |
| 806 |
| 807 |
LUENT *le = lu_find(&modconttab, modn);
| 808 |
MODCONT *mp = (MODCONT *)le->data;
| 809 |
int bn;
| 810 |
| 811 |
if (mp == NULL) {
| 812 |
sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
| 813 |
| 814 |
| 815 |
eclock++; /* get bin number */
| 816 |
bn = (int)(evalue(mp->binv) + .5);
| 817 |
if (bn <= 0)
| 818 |
bn = 0;
| 819 |
else if (bn >= mp->nbins) /* new bin */
| 820 |
le->data = (char *)(mp = growmodifier(mp, bn+1));
| 821 |
addcolor(mp->cbin[bn], rparams);
| 822 |
| 823 |
| 824 |
/* output newline to ASCII file and/or flush as requested */
| 825 |
static int
| 826 |
puteol(const LUENT *e, void *p)
| 827 |
| 828 |
STREAMOUT *sop = (STREAMOUT *)e->data;
| 829 |
| 830 |
if (outfmt == 'a')
| 831 |
| 832 |
if (!waitflush)
| 833 |
fflush(sop->ofp);
| 834 |
if (ferror(sop->ofp)) {
| 835 |
sprintf(errmsg, "write error on file '%s'", e->key);
| 836 |
| 837 |
| 838 |
return 0;
| 839 |
| 840 |
| 841 |
/* put out ray contribution to file */
| 842 |
void
| 843 |
| 844 |
| 845 |
float fv[3];
| 846 |
COLR cv;
| 847 |
| 848 |
switch (outfmt) {
| 849 |
case 'a':
| 850 |
fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
| 851 |
break;
| 852 |
case 'f':
| 853 |
fv[0] = cnt[0];
| 854 |
fv[1] = cnt[1];
| 855 |
fv[2] = cnt[2];
| 856 |
fwrite(fv, sizeof(float), 3, fout);
| 857 |
break;
| 858 |
case 'd':
| 859 |
fwrite(cnt, sizeof(double), 3, fout);
| 860 |
break;
| 861 |
case 'c':
| 862 |
setcolr(cv, cnt[0], cnt[1], cnt[2]);
| 863 |
fwrite(cv, sizeof(cv), 1, fout);
| 864 |
break;
| 865 |
default:
| 866 |
error(INTERNAL, "botched output format");
| 867 |
| 868 |
| 869 |
| 870 |
/* output ray tallies and clear for next primary */
| 871 |
void
| 872 |
done_contrib(void)
| 873 |
| 874 |
int i, j;
| 875 |
MODCONT *mp;
| 876 |
STREAMOUT *sop;
| 877 |
/* output modifiers in order */
| 878 |
for (i = 0; i < nmods; i++) {
| 879 |
mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
| 880 |
sop = getostream(mp->outspec, mp->modname, 0,0);
| 881 |
put_contrib(mp->cbin[0], sop->ofp);
| 882 |
if (mp->nbins > 3 && /* minor optimization */
| 883 |
sop == getostream(mp->outspec, mp->modname, 1,0))
| 884 |
for (j = 1; j < mp->nbins; j++)
| 885 |
put_contrib(mp->cbin[j], sop->ofp);
| 886 |
else
| 887 |
| 888 |
| 889 |
getostream(mp->outspec,mp->modname,j,0)->ofp);
| 890 |
/* clear for next ray tree */
| 891 |
memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
| 892 |
| 893 |
--waitflush; /* terminate records */
| 894 |
lu_doall(&ofiletab, puteol, NULL);
| 895 |
if (using_stdout & (outfmt == 'a'))
| 896 |
putc('\n', stdout);
| 897 |
if (!waitflush) {
| 898 |
waitflush = xres;
| 899 |
if (using_stdout)
| 900 |
fflush(stdout);
| 901 |
| 902 |
| 903 |
| 904 |
/* queue completed ray tree produced by rtrace process */
| 905 |
void
| 906 |
| 907 |
| 908 |
struct rtproc *rtu, *rtl = NULL;
| 909 |
/* insert following ray order */
| 910 |
for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
| 911 |
if (rtp->raynum < rtu->raynum)
| 912 |
break;
| 913 |
rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
| 914 |
if (rtu == NULL)
| 915 |
error(SYSTEM, "out of memory in queue_raytree");
| 916 |
*rtu = *rtp;
| 917 |
if (rtl == NULL) {
| 918 |
rtu->next = rt_unproc;
| 919 |
rt_unproc = rtu;
| 920 |
} else {
| 921 |
rtu->next = rtl->next;
| 922 |
rtl->next = rtu;
| 923 |
| 924 |
rtp->raynum = 0; /* clear path for next ray tree */
| 925 |
rtp->bsiz = 0;
| 926 |
rtp->buf = NULL;
| 927 |
rtp->nbr = 0;
| 928 |
| 929 |
| 930 |
/* process completed ray trees from our queue */
| 931 |
void
| 932 |
process_queue(void)
| 933 |
| 934 |
char modname[128];
| 935 |
/* ray-ordered queue */
| 936 |
while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
| 937 |
struct rtproc *rtp = rt_unproc;
| 938 |
int n = rtp->nbr;
| 939 |
const char *cp = rtp->buf;
| 940 |
while (n > 0) { /* process rays */
| 941 |
register char *mnp = modname;
| 942 |
/* skip leading tabs */
| 943 |
while (n > 0 && *cp == '\t') {
| 944 |
cp++; n--;
| 945 |
| 946 |
if (!n || !(isalpha(*cp) | (*cp == '_')))
| 947 |
error(USER, "bad modifier name from rtrace");
| 948 |
/* get modifier name */
| 949 |
while (n > 0 && *cp != '\t') {
| 950 |
*mnp++ = *cp++; n--;
| 951 |
| 952 |
*mnp = '\0';
| 953 |
cp++; n--; /* eat following tab */
| 954 |
if (n < (int)(sizeof(float)*9))
| 955 |
error(USER, "incomplete ray value from rtrace");
| 956 |
/* add ray contribution */
| 957 |
memcpy(rparams, cp, sizeof(float)*9);
| 958 |
cp += sizeof(float)*9; n -= sizeof(float)*9;
| 959 |
add_contrib(modname);
| 960 |
| 961 |
done_contrib(); /* sum up contributions & output */
| 962 |
lastdone = rtp->raynum;
| 963 |
free(rtp->buf); /* free up buffer space */
| 964 |
rt_unproc = rtp->next;
| 965 |
free(rtp); /* done with this ray tree */
| 966 |
| 967 |
| 968 |
| 969 |
/* wait for rtrace process to finish with ray tree */
| 970 |
struct rtproc *
| 971 |
wait_rproc(void)
| 972 |
| 973 |
struct rtproc *rtfree = NULL;
| 974 |
fd_set readset, errset;
| 975 |
int nr;
| 976 |
struct rtproc *rt;
| 977 |
int n;
| 978 |
| 979 |
do {
| 980 |
nr = 0; /* prepare select call */
| 981 |
FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
| 982 |
for (rt = &rt0; rt != NULL; rt = rt->next) {
| 983 |
if (rt->raynum) {
| 984 |
FD_SET(rt->pd.r, &readset);
| 985 |
++nr;
| 986 |
| 987 |
FD_SET(rt->pd.r, &errset);
| 988 |
if (rt->pd.r >= n)
| 989 |
n = rt->pd.r + 1;
| 990 |
| 991 |
if (!nr) /* no rays pending */
| 992 |
break;
| 993 |
if (nr > 1) { /* call select for multiple proc's */
| 994 |
errno = 0;
| 995 |
if (select(n, &readset, NULL, &errset, NULL) < 0)
| 996 |
error(SYSTEM, "select call error in wait_rproc()");
| 997 |
} else
| 998 |
FD_ZERO(&errset);
| 999 |
nr = 0;
| 1000 |
| 1001 |
if (!FD_ISSET(rt->pd.r, &readset) &&
| 1002 |
!FD_ISSET(rt->pd.r, &errset))
| 1003 |
continue;
| 1004 |
if (rt->buf == NULL) {
| 1005 |
rt->bsiz = treebufsiz;
| 1006 |
rt->buf = (char *)malloc(treebufsiz);
| 1007 |
} else if (rt->nbr + BUFSIZ > rt->bsiz) {
| 1008 |
if (rt->bsiz + BUFSIZ <= treebufsiz)
| 1009 |
| 1010 |
else
| 1011 |
treebufsiz = rt->bsiz += BUFSIZ;
| 1012 |
rt->buf = (char *)realloc(rt->buf, rt->bsiz);
| 1013 |
| 1014 |
| 1015 |
error(SYSTEM, "out of memory in wait_rproc");
| 1016 |
nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
| 1017 |
if (nr <= 0)
| 1018 |
error(USER, "rtrace process died");
| 1019 |
rt->nbr += nr; /* advance & check */
| 1020 |
if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4,
| 1021 |
"~\t~\t", 4)) {
| 1022 |
rt->nbr -= 4; /* elide terminator */
| 1023 |
queue_raytree(rt);
| 1024 |
rtfree = rt; /* ready for next ray */
| 1025 |
| 1026 |
| 1027 |
} while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
| 1028 |
return rtfree;
| 1029 |
| 1030 |
| 1031 |
/* return next available rtrace process */
| 1032 |
struct rtproc *
| 1033 |
get_rproc(void)
| 1034 |
| 1035 |
struct rtproc *rtp;
| 1036 |
/* check for idle rtrace */
| 1037 |
| 1038 |
if (!rtp->raynum)
| 1039 |
return rtp;
| 1040 |
return wait_rproc(); /* need to wait for one */
| 1041 |
| 1042 |
| 1043 |
/* trace ray contributions (main loop) */
| 1044 |
void
| 1045 |
| 1046 |
| 1047 |
char inpbuf[128];
| 1048 |
int iblen;
| 1049 |
struct rtproc *rtp;
| 1050 |
/* loop over input */
| 1051 |
while ((iblen = getinp(inpbuf, fin)) > 0) {
| 1052 |
if (lastray+1 < lastray || /* need reset? */
| 1053 |
queue_length() > 10*nrtprocs()) {
| 1054 |
while (wait_rproc() != NULL)
| 1055 |
process_queue();
| 1056 |
if (lastray+1 < lastray)
| 1057 |
lastdone = lastray = 0;
| 1058 |
| 1059 |
rtp = get_rproc(); /* get avail. rtrace process */
| 1060 |
rtp->raynum = ++lastray; /* assign ray to it */
| 1061 |
writebuf(rtp->pd.w, inpbuf, iblen);
| 1062 |
if (raysleft && !--raysleft)
| 1063 |
break;
| 1064 |
process_queue(); /* catch up with results */
| 1065 |
| 1066 |
while (wait_rproc() != NULL) /* process outstanding rays */
| 1067 |
process_queue();
| 1068 |
if (raysleft)
| 1069 |
error(USER, "unexpected EOF on input");
| 1070 |
lu_done(&ofiletab); /* close output files */
| 1071 |
| 1072 |
| 1073 |
/* seek on the given output file */
| 1074 |
static int
| 1075 |
myseeko(const LUENT *e, void *p)
| 1076 |
| 1077 |
| 1078 |
off_t nbytes = *(off_t *)p;
| 1079 |
| 1080 |
if (sop->reclen > 1)
| 1081 |
nbytes = nbytes * sop->reclen;
| 1082 |
if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) {
| 1083 |
sprintf(errmsg, "seek error on file '%s'", e->key);
| 1084 |
| 1085 |
| 1086 |
| 1087 |
| 1088 |
/* recover output if possible */
| 1089 |
void
| 1090 |
| 1091 |
| 1092 |
off_t lastout = -1;
| 1093 |
int outvsiz, recsiz;
| 1094 |
char *outvfmt;
| 1095 |
int i, j;
| 1096 |
MODCONT *mp;
| 1097 |
int ofl;
| 1098 |
char oname[1024];
| 1099 |
LUENT *ment, *oent;
| 1100 |
STREAMOUT sout;
| 1101 |
off_t nvals;
| 1102 |
int xr, yr;
| 1103 |
| 1104 |
switch (outfmt) {
| 1105 |
case 'a':
| 1106 |
error(USER, "cannot recover ASCII output");
| 1107 |
return;
| 1108 |
case 'f':
| 1109 |
outvsiz = sizeof(float)*3;
| 1110 |
outvfmt = "float";
| 1111 |
break;
| 1112 |
case 'd':
| 1113 |
outvsiz = sizeof(double)*3;
| 1114 |
outvfmt = "double";
| 1115 |
break;
| 1116 |
case 'c':
| 1117 |
outvsiz = sizeof(COLR);
| 1118 |
outvfmt = COLRFMT;
| 1119 |
break;
| 1120 |
default:
| 1121 |
| 1122 |
return;
| 1123 |
| 1124 |
/* check modifier outputs */
| 1125 |
| 1126 |
ment = lu_find(&modconttab,modname[i]);
| 1127 |
mp = (MODCONT *)ment->data;
| 1128 |
if (mp->outspec == NULL)
| 1129 |
error(USER, "cannot recover from stdout");
| 1130 |
if (mp->outspec[0] == '!')
| 1131 |
error(USER, "cannot recover from command");
| 1132 |
for (j = 0; ; j++) { /* check each bin's file */
| 1133 |
ofl = ofname(oname, mp->outspec, mp->modname, j);
| 1134 |
if (ofl < 0)
| 1135 |
error(USER, "bad output file specification");
| 1136 |
oent = lu_find(&ofiletab, oname);
| 1137 |
if (oent->data != NULL) {
| 1138 |
sout = *(STREAMOUT *)oent->data;
| 1139 |
} else {
| 1140 |
sout.reclen = CNT_UNKNOWN;
| 1141 |
sout.ofp = NULL;
| 1142 |
| 1143 |
if (sout.ofp != NULL) { /* already open? */
| 1144 |
if (ofl & OF_BIN)
| 1145 |
continue;
| 1146 |
break;
| 1147 |
| 1148 |
/* open output */
| 1149 |
sout.ofp = fopen(oname, "rb+");
| 1150 |
if (sout.ofp == NULL) {
| 1151 |
if (j)
| 1152 |
break; /* assume end of modifier */
| 1153 |
sprintf(errmsg, "missing recover file '%s'",
| 1154 |
oname);
| 1155 |
| 1156 |
| 1157 |
nvals = lseek(fileno(sout.ofp), 0, SEEK_END);
| 1158 |
if (nvals <= 0) {
| 1159 |
lastout = 0; /* empty output, quit here */
| 1160 |
fclose(sout.ofp);
| 1161 |
break;
| 1162 |
| 1163 |
if (sout.reclen == CNT_UNKNOWN) {
| 1164 |
if (!(ofl & OF_BIN)) {
| 1165 |
sprintf(errmsg,
| 1166 |
"need -bn to recover file '%s'",
| 1167 |
oname);
| 1168 |
| 1169 |
| 1170 |
recsiz = outvsiz;
| 1171 |
} else
| 1172 |
recsiz = outvsiz * sout.reclen;
| 1173 |
| 1174 |
lseek(fileno(sout.ofp), 0, SEEK_SET);
| 1175 |
if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
| 1176 |
sprintf(errmsg, "format mismatch for '%s'",
| 1177 |
oname);
| 1178 |
| 1179 |
| 1180 |
if ((xres > 0) & (yres > 0) &&
| 1181 |
(!fscnresolu(&xr, &yr, sout.ofp) ||
| 1182 |
xr != xres ||
| 1183 |
yr != yres)) {
| 1184 |
sprintf(errmsg, "resolution mismatch for '%s'",
| 1185 |
oname);
| 1186 |
| 1187 |
| 1188 |
nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz;
| 1189 |
if ((lastout < 0) | (nvals < lastout))
| 1190 |
lastout = nvals;
| 1191 |
if (oent->key == NULL) /* new entry */
| 1192 |
oent->key = strcpy((char *)
| 1193 |
| 1194 |
if (oent->data == NULL)
| 1195 |
oent->data = (char *)malloc(sizeof(STREAMOUT));
| 1196 |
*(STREAMOUT *)oent->data = sout;
| 1197 |
| 1198 |
break; /* no bin separation */
| 1199 |
| 1200 |
if (!lastout) { /* empty output */
| 1201 |
error(WARNING, "no previous data to recover");
| 1202 |
lu_done(&ofiletab); /* reclose all outputs */
| 1203 |
return;
| 1204 |
| 1205 |
if (j > mp->nbins) /* reallocate modifier bins */
| 1206 |
ment->data = (char *)(mp = growmodifier(mp, j));
| 1207 |
| 1208 |
if (lastout < 0) {
| 1209 |
error(WARNING, "no output files to recover");
| 1210 |
return;
| 1211 |
| 1212 |
if (raysleft && lastout >= raysleft) {
| 1213 |
error(WARNING, "output appears to be complete");
| 1214 |
/* XXX should read & discard input? */
| 1215 |
quit(0);
| 1216 |
| 1217 |
/* seek on all files */
| 1218 |
nvals = lastout * outvsiz;
| 1219 |
lu_doall(&ofiletab, myseeko, &nvals);
| 1220 |
/* skip repeated input */
| 1221 |
for (nvals = 0; nvals < lastout; nvals++)
| 1222 |
if (getinp(oname, fin) <= 0)
| 1223 |
| 1224 |
lastray = lastdone = (unsigned long)lastout;
| 1225 |
if (raysleft)
| 1226 |
raysleft -= lastray;
| 1227 |
