| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rtcontrib.c,v 1.21 2005/06/11 15:01:03 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Gather rtrace output to compute contributions from particular sources
| 6 |
| 7 |
| 8 |
#include "standard.h"
| 9 |
#include <ctype.h>
| 10 |
#include <signal.h>
| 11 |
#include "platform.h"
| 12 |
#include "rtprocess.h"
| 13 |
#include "selcall.h"
| 14 |
#include "color.h"
| 15 |
#include "resolu.h"
| 16 |
#include "lookup.h"
| 17 |
#include "calcomp.h"
| 18 |
| 19 |
#ifndef MAXMODLIST
| 20 |
#define MAXMODLIST 1024 /* maximum modifiers we'll track */
| 21 |
#endif
| 22 |
| 23 |
int treebufsiz = BUFSIZ; /* current tree buffer size */
| 24 |
| 25 |
typedef double DCOLOR[3]; /* double-precision color */
| 26 |
| 27 |
| 28 |
* The modcont structure is used to accumulate ray contributions
| 29 |
* for a particular modifier, which may be subdivided into bins
| 30 |
* if binv is non-NULL. If outspec contains a %s in it, this will
| 31 |
* be replaced with the modifier name. If outspec contains a %d in it,
| 32 |
* this will be used to create one output file per bin, otherwise all bins
| 33 |
* will be written to the same file, in order. If the global outfmt
| 34 |
* is 'c', then a 4-byte RGBE pixel will be output for each bin value
| 35 |
* and the file will conform to a RADIANCE image if xres & yres are set.
| 36 |
| 37 |
typedef struct {
| 38 |
const char *outspec; /* output file specification */
| 39 |
const char *modname; /* modifier name */
| 40 |
EPNODE *binv; /* bin value expression */
| 41 |
int nbins; /* number of accumulation bins */
| 42 |
DCOLOR cbin[1]; /* contribution bins (extends struct) */
| 43 |
} MODCONT; /* modifier contribution */
| 44 |
| 45 |
static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
| 46 |
| 47 |
LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
| 48 |
| 49 |
/* close output stream */
| 50 |
static void closefile(void *p) { fclose((FILE *)p); }
| 51 |
| 52 |
LUTAB ofiletab = LU_SINIT(free,closefile); /* output file table */
| 53 |
| 54 |
#define OF_MODIFIER 01
| 55 |
#define OF_BIN 02
| 56 |
| 57 |
FILE *getofile(const char *ospec, const char *mname, int bn);
| 58 |
int ofname(char *oname, const char *ospec, const char *mname, int bn);
| 59 |
void printheader(FILE *fout, const char *info);
| 60 |
| 61 |
| 62 |
* The rcont structure is used to manage i/o with a particular
| 63 |
* rtrace child process. Input is passed unchanged from stdin,
| 64 |
* and output is processed in input order and accumulated according
| 65 |
* to the corresponding modifier and bin number.
| 66 |
| 67 |
struct rtproc {
| 68 |
struct rtproc *next; /* next in list of processes */
| 69 |
SUBPROC pd; /* rtrace pipe descriptors */
| 70 |
unsigned long raynum; /* ray number for this tree */
| 71 |
int bsiz; /* ray tree buffer length */
| 72 |
char *buf; /* ray tree buffer */
| 73 |
int nbr; /* number of bytes from rtrace */
| 74 |
}; /* rtrace process buffer */
| 75 |
| 76 |
/* rtrace command and defaults */
| 77 |
char *rtargv[256+2*MAXMODLIST] = { "rtrace",
| 78 |
"-dj", ".5", "-dr", "3",
| 79 |
"-ab", "1", "-ad", "128", };
| 80 |
int rtargc = 9;
| 81 |
/* overriding rtrace options */
| 82 |
char *myrtopts[] = { "-o~~TmWdp", "-h-", "-x", "1", "-y", "0",
| 83 |
"-dt", "0", "-as", "0", "-aa", "0", NULL };
| 84 |
| 85 |
struct rtproc rt0; /* head of rtrace process list */
| 86 |
| 87 |
struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
| 88 |
| 89 |
char persistfn[] = "pfXXXXXX"; /* persist file name */
| 90 |
| 91 |
int gargc; /* global argc */
| 92 |
char **gargv; /* global argv */
| 93 |
#define progname gargv[0]
| 94 |
| 95 |
char *octree; /* global octree argument */
| 96 |
| 97 |
int inpfmt = 'a'; /* input format */
| 98 |
int outfmt = 'a'; /* output format */
| 99 |
| 100 |
int header = 1; /* output header? */
| 101 |
int xres = 0; /* horiz. output resolution */
| 102 |
int yres = 0; /* vert. output resolution */
| 103 |
| 104 |
unsigned long raysleft; /* number of rays left to trace */
| 105 |
long waitflush; /* how long until next flush */
| 106 |
| 107 |
unsigned long lastray = 0; /* last ray number sent */
| 108 |
unsigned long lastdone = 0; /* last ray processed */
| 109 |
| 110 |
int using_stdout = 0; /* are we using stdout? */
| 111 |
| 112 |
const char *modname[MAXMODLIST]; /* ordered modifier name list */
| 113 |
int nmods = 0; /* number of modifiers */
| 114 |
| 115 |
MODCONT *addmodifier(char *modn, char *outf, char *binv);
| 116 |
void addmodfile(char *fname, char *outf, char *binv);
| 117 |
| 118 |
void init(int np);
| 119 |
int done_rprocs(struct rtproc *rtp);
| 120 |
void recover_output(FILE *fin);
| 121 |
void trace_contribs(FILE *fin);
| 122 |
struct rtproc *wait_rproc(void);
| 123 |
struct rtproc *get_rproc(void);
| 124 |
void queue_raytree(struct rtproc *rtp);
| 125 |
void process_queue(void);
| 126 |
| 127 |
void put_contrib(const DCOLOR cnt, FILE *fout);
| 128 |
void add_contrib(const char *modn);
| 129 |
void done_contrib(void);
| 130 |
| 131 |
/* set input/output format */
| 132 |
static void
| 133 |
setformat(const char *fmt)
| 134 |
| 135 |
switch (fmt[0]) {
| 136 |
case 'f':
| 137 |
case 'd':
| 138 |
SET_FILE_BINARY(stdin);
| 139 |
/* fall through */
| 140 |
case 'a':
| 141 |
inpfmt = fmt[0];
| 142 |
break;
| 143 |
default:
| 144 |
goto fmterr;
| 145 |
| 146 |
switch (fmt[1]) {
| 147 |
case '\0':
| 148 |
outfmt = inpfmt;
| 149 |
return;
| 150 |
case 'a':
| 151 |
case 'f':
| 152 |
case 'd':
| 153 |
case 'c':
| 154 |
outfmt = fmt[1];
| 155 |
break;
| 156 |
default:
| 157 |
goto fmterr;
| 158 |
| 159 |
if (!fmt[2])
| 160 |
return;
| 161 |
fmterr:
| 162 |
sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
| 163 |
error(USER, errmsg);
| 164 |
| 165 |
| 166 |
/* gather rays from rtrace and output contributions */
| 167 |
int
| 168 |
main(int argc, char *argv[])
| 169 |
| 170 |
int nprocs = 1;
| 171 |
int recover = 0;
| 172 |
char *curout = NULL;
| 173 |
char *binval = NULL;
| 174 |
char fmt[8];
| 175 |
int i, j;
| 176 |
/* global program name */
| 177 |
gargv = argv;
| 178 |
/* initialize calcomp routines */
| 179 |
esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
| 180 |
esupport &= ~(E_OUTCHAN);
| 181 |
varset("PI", ':', PI);
| 182 |
/* get our options */
| 183 |
for (i = 1; i < argc-1; i++) {
| 184 |
/* expand arguments */
| 185 |
while ((j = expandarg(&argc, &argv, i)) > 0)
| 186 |
| 187 |
if (j < 0) {
| 188 |
fprintf(stderr, "%s: cannot expand '%s'",
| 189 |
argv[0], argv[i]);
| 190 |
exit(1);
| 191 |
| 192 |
if (argv[i][0] == '-')
| 193 |
switch (argv[i][1]) {
| 194 |
case 'r': /* recover output */
| 195 |
if (argv[i][2]) break;
| 196 |
recover++;
| 197 |
continue;
| 198 |
case 'n': /* number of processes */
| 199 |
if (argv[i][2] || i >= argc-2) break;
| 200 |
nprocs = atoi(argv[++i]);
| 201 |
if (nprocs <= 0)
| 202 |
error(USER, "illegal number of processes");
| 203 |
continue;
| 204 |
case 'h': /* output header? */
| 205 |
switch (argv[i][2]) {
| 206 |
case '\0':
| 207 |
header = !header;
| 208 |
continue;
| 209 |
case '+': case '1':
| 210 |
case 'T': case 't':
| 211 |
case 'Y': case 'y':
| 212 |
header = 1;
| 213 |
continue;
| 214 |
case '-': case '0':
| 215 |
case 'F': case 'f':
| 216 |
case 'N': case 'n':
| 217 |
header = 0;
| 218 |
continue;
| 219 |
| 220 |
break;
| 221 |
case 'f': /* file or i/o format */
| 222 |
if (!argv[i][2]) {
| 223 |
char *fpath;
| 224 |
if (i >= argc-2) break;
| 225 |
fpath = getpath(argv[++i],
| 226 |
getrlibpath(), R_OK);
| 227 |
if (fpath == NULL) {
| 228 |
sprintf(errmsg,
| 229 |
"cannot find file '%s'",
| 230 |
argv[i]);
| 231 |
| 232 |
| 233 |
fcompile(fpath);
| 234 |
continue;
| 235 |
| 236 |
setformat(argv[i]+2);
| 237 |
continue;
| 238 |
case 'e': /* expression */
| 239 |
| 240 |
scompile(argv[++i], NULL, 0);
| 241 |
continue;
| 242 |
case 'o': /* output file spec. */
| 243 |
| 244 |
curout = argv[++i];
| 245 |
continue;
| 246 |
case 'x': /* horiz. output resolution */
| 247 |
| 248 |
xres = atoi(argv[++i]);
| 249 |
continue;
| 250 |
case 'y': /* vert. output resolution */
| 251 |
| 252 |
yres = atoi(argv[++i]);
| 253 |
continue;
| 254 |
case 'b': /* bin expression */
| 255 |
| 256 |
binval = argv[++i];
| 257 |
continue;
| 258 |
case 'm': /* modifier name */
| 259 |
| 260 |
rtargv[rtargc++] = "-ti";
| 261 |
rtargv[rtargc++] = argv[++i];
| 262 |
addmodifier(argv[i], curout, binval);
| 263 |
continue;
| 264 |
case 'M': /* modifier file */
| 265 |
| 266 |
rtargv[rtargc++] = "-tI";
| 267 |
| 268 |
addmodfile(argv[i], curout, binval);
| 269 |
continue;
| 270 |
| 271 |
rtargv[rtargc++] = argv[i]; /* assume rtrace option */
| 272 |
| 273 |
/* set global argument list */
| 274 |
gargc = argc; gargv = argv;
| 275 |
/* add "mandatory" rtrace settings */
| 276 |
for (j = 0; myrtopts[j] != NULL; j++)
| 277 |
rtargv[rtargc++] = myrtopts[j];
| 278 |
/* just asking for defaults? */
| 279 |
if (!strcmp(argv[i], "-defaults")) {
| 280 |
char sxres[16], syres[16];
| 281 |
char *rtpath;
| 282 |
printf("-n %-2d\t\t\t\t# number of processes\n", nprocs);
| 283 |
fflush(stdout); /* report OUR options */
| 284 |
rtargv[rtargc++] = header ? "-h+" : "-h-";
| 285 |
sprintf(fmt, "-f%c%c", inpfmt, outfmt);
| 286 |
rtargv[rtargc++] = fmt;
| 287 |
rtargv[rtargc++] = "-x";
| 288 |
sprintf(sxres, "%d", xres);
| 289 |
rtargv[rtargc++] = sxres;
| 290 |
rtargv[rtargc++] = "-y";
| 291 |
sprintf(syres, "%d", yres);
| 292 |
rtargv[rtargc++] = syres;
| 293 |
rtargv[rtargc++] = "-oTW";
| 294 |
rtargv[rtargc++] = "-defaults";
| 295 |
rtargv[rtargc] = NULL;
| 296 |
rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
| 297 |
if (rtpath == NULL) {
| 298 |
eputs(rtargv[0]);
| 299 |
eputs(": command not found\n");
| 300 |
exit(1);
| 301 |
| 302 |
execv(rtpath, rtargv);
| 303 |
perror(rtpath); /* execv() should not return */
| 304 |
exit(1);
| 305 |
| 306 |
if (nprocs > 1) { /* add persist file if parallel */
| 307 |
rtargv[rtargc++] = "-PP";
| 308 |
rtargv[rtargc++] = mktemp(persistfn);
| 309 |
| 310 |
/* add format string */
| 311 |
sprintf(fmt, "-f%cf", inpfmt);
| 312 |
| 313 |
/* octree argument is last */
| 314 |
if (i <= 0 || i != argc-1 || argv[i][0] == '-')
| 315 |
error(USER, "missing octree argument");
| 316 |
rtargv[rtargc++] = octree = argv[i];
| 317 |
| 318 |
/* start rtrace & compute contributions */
| 319 |
init(nprocs);
| 320 |
if (recover) /* perform recovery if requested */
| 321 |
recover_output(stdin);
| 322 |
trace_contribs(stdin);
| 323 |
quit(0);
| 324 |
| 325 |
| 326 |
/* kill persistent rtrace process */
| 327 |
static void
| 328 |
killpersist(void)
| 329 |
| 330 |
FILE *fp = fopen(persistfn, "r");
| 331 |
int pid;
| 332 |
| 333 |
if (fp == NULL)
| 334 |
return;
| 335 |
if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
| 336 |
unlink(persistfn);
| 337 |
fclose(fp);
| 338 |
| 339 |
| 340 |
/* close rtrace processes and clean up */
| 341 |
int
| 342 |
| 343 |
| 344 |
int st0, st1 = 0;
| 345 |
| 346 |
if (rtp->next != NULL) { /* close last opened first! */
| 347 |
st1 = done_rprocs(rtp->next);
| 348 |
free((void *)rtp->next);
| 349 |
rtp->next = NULL;
| 350 |
| 351 |
st0 = close_process(&rtp->pd);
| 352 |
if (st0 < 0)
| 353 |
error(WARNING, "unknown return status from rtrace process");
| 354 |
else if (st0 > 0)
| 355 |
return(st0);
| 356 |
return(st1);
| 357 |
| 358 |
| 359 |
/* exit with status */
| 360 |
void
| 361 |
quit(int status)
| 362 |
| 363 |
int rtstat;
| 364 |
| 365 |
if (rt0.next != NULL) /* terminate persistent rtrace */
| 366 |
killpersist();
| 367 |
/* clean up rtrace process(es) */
| 368 |
rtstat = done_rprocs(&rt0);
| 369 |
if (status == 0)
| 370 |
status = rtstat;
| 371 |
exit(status); /* flushes all output streams */
| 372 |
| 373 |
| 374 |
/* start rtrace processes and initialize */
| 375 |
void
| 376 |
init(int np)
| 377 |
| 378 |
struct rtproc *rtp;
| 379 |
int i;
| 380 |
int maxbytes;
| 381 |
/* make sure we have something to do */
| 382 |
if (!nmods)
| 383 |
error(USER, "No modifiers specified");
| 384 |
/* assign ray variables */
| 385 |
scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
| 386 |
scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
| 387 |
/* set up signal handling */
| 388 |
signal(SIGINT, quit);
| 389 |
#ifdef SIGHUP
| 390 |
signal(SIGHUP, quit);
| 391 |
#endif
| 392 |
#ifdef SIGTERM
| 393 |
signal(SIGTERM, quit);
| 394 |
#endif
| 395 |
#ifdef SIGPIPE
| 396 |
signal(SIGPIPE, quit);
| 397 |
#endif
| 398 |
rtp = &rt0; /* start rtrace process(es) */
| 399 |
for (i = 0; i++ < np; ) {
| 400 |
errno = 0;
| 401 |
maxbytes = open_process(&rtp->pd, rtargv);
| 402 |
if (maxbytes == 0) {
| 403 |
eputs(rtargv[0]);
| 404 |
| 405 |
exit(1);
| 406 |
| 407 |
if (maxbytes < 0)
| 408 |
error(SYSTEM, "cannot start rtrace process");
| 409 |
if (maxbytes > treebufsiz)
| 410 |
treebufsiz = maxbytes;
| 411 |
rtp->raynum = 0;
| 412 |
rtp->bsiz = 0;
| 413 |
rtp->buf = NULL;
| 414 |
rtp->nbr = 0;
| 415 |
if (i == np) /* last process? */
| 416 |
break;
| 417 |
if (i == 1)
| 418 |
sleep(2); /* wait for persist file */
| 419 |
rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
| 420 |
if (rtp->next == NULL)
| 421 |
error(SYSTEM, "out of memory in init");
| 422 |
rtp = rtp->next;
| 423 |
| 424 |
rtp->next = NULL; /* terminate list */
| 425 |
if (yres > 0) {
| 426 |
if (xres > 0)
| 427 |
raysleft = (unsigned long)xres*yres;
| 428 |
else
| 429 |
raysleft = yres;
| 430 |
} else
| 431 |
raysleft = 0;
| 432 |
waitflush = xres;
| 433 |
| 434 |
| 435 |
/* add modifier to our list to track */
| 436 |
MODCONT *
| 437 |
| 438 |
| 439 |
LUENT *lep = lu_find(&modconttab, modn);
| 440 |
MODCONT *mp;
| 441 |
| 442 |
if (lep->data != NULL) {
| 443 |
sprintf(errmsg, "duplicate modifier '%s'", modn);
| 444 |
| 445 |
| 446 |
if (nmods >= MAXMODLIST)
| 447 |
error(USER, "too many modifiers");
| 448 |
modname[nmods++] = modn; /* XXX assumes static string */
| 449 |
lep->key = modn; /* XXX assumes static string */
| 450 |
mp = (MODCONT *)malloc(sizeof(MODCONT));
| 451 |
if (mp == NULL)
| 452 |
error(SYSTEM, "out of memory in addmodifier");
| 453 |
lep->data = (char *)mp;
| 454 |
mp->outspec = outf; /* XXX assumes static string */
| 455 |
mp->modname = modn; /* XXX assumes static string */
| 456 |
if (binv != NULL)
| 457 |
mp->binv = eparse(binv);
| 458 |
else
| 459 |
mp->binv = eparse("0");
| 460 |
mp->nbins = 1;
| 461 |
setcolor(mp->cbin[0], 0., 0., 0.);
| 462 |
return mp;
| 463 |
| 464 |
| 465 |
/* add modifiers from a file list */
| 466 |
void
| 467 |
| 468 |
| 469 |
char *mname[MAXMODLIST];
| 470 |
int i;
| 471 |
/* find the file & store strings */
| 472 |
if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
| 473 |
sprintf(errmsg, "cannot find modifier file '%s'", fname);
| 474 |
error(SYSTEM, errmsg);
| 475 |
| 476 |
for (i = 0; mname[i]; i++) /* add each one */
| 477 |
addmodifier(mname[i], outf, binv);
| 478 |
| 479 |
| 480 |
/* put string to stderr */
| 481 |
void
| 482 |
eputs(char *s)
| 483 |
| 484 |
static int midline = 0;
| 485 |
| 486 |
if (!*s) return;
| 487 |
if (!midline) {
| 488 |
fputs(progname, stderr);
| 489 |
fputs(": ", stderr);
| 490 |
| 491 |
fputs(s, stderr);
| 492 |
midline = s[strlen(s)-1] != '\n';
| 493 |
| 494 |
| 495 |
/* construct output file name and return flags whether modifier/bin present */
| 496 |
int
| 497 |
| 498 |
| 499 |
const char *mnp = NULL;
| 500 |
const char *bnp = NULL;
| 501 |
const char *cp;
| 502 |
| 503 |
if (ospec == NULL)
| 504 |
return -1;
| 505 |
for (cp = ospec; *cp; cp++) /* check format position(s) */
| 506 |
if (*cp == '%') {
| 507 |
do
| 508 |
++cp;
| 509 |
while (isdigit(*cp));
| 510 |
switch (*cp) {
| 511 |
case '%':
| 512 |
break;
| 513 |
case 's':
| 514 |
if (mnp != NULL)
| 515 |
return -1;
| 516 |
mnp = cp;
| 517 |
break;
| 518 |
case 'd':
| 519 |
if (bnp != NULL)
| 520 |
return -1;
| 521 |
bnp = cp;
| 522 |
break;
| 523 |
default:
| 524 |
return -1;
| 525 |
| 526 |
| 527 |
if (mnp != NULL) { /* create file name */
| 528 |
if (bnp != NULL) {
| 529 |
if (bnp > mnp)
| 530 |
sprintf(oname, ospec, mname, bn);
| 531 |
else
| 532 |
sprintf(oname, ospec, bn, mname);
| 533 |
return OF_MODIFIER|OF_BIN;
| 534 |
| 535 |
sprintf(oname, ospec, mname);
| 536 |
return OF_MODIFIER;
| 537 |
| 538 |
if (bnp != NULL) {
| 539 |
sprintf(oname, ospec, bn);
| 540 |
return OF_BIN;
| 541 |
| 542 |
strcpy(oname, ospec);
| 543 |
return 0;
| 544 |
| 545 |
| 546 |
/* write header to the given output stream */
| 547 |
void
| 548 |
| 549 |
| 550 |
extern char VersionID[];
| 551 |
FILE *fin = fopen(octree, "r");
| 552 |
| 553 |
if (fin == NULL)
| 554 |
quit(1);
| 555 |
checkheader(fin, "ignore", fout); /* copy octree header */
| 556 |
fclose(fin);
| 557 |
printargs(gargc-1, gargv, fout); /* add our command */
| 558 |
fprintf(fout, "SOFTWARE= %s\n", VersionID);
| 559 |
fputnow(fout);
| 560 |
if (info != NULL) /* add extra info if given */
| 561 |
fputs(info, fout);
| 562 |
switch (outfmt) { /* add output format */
| 563 |
case 'a':
| 564 |
fputformat("ascii", fout);
| 565 |
break;
| 566 |
case 'f':
| 567 |
fputformat("float", fout);
| 568 |
break;
| 569 |
case 'd':
| 570 |
fputformat("double", fout);
| 571 |
break;
| 572 |
case 'c':
| 573 |
fputformat(COLRFMT, fout);
| 574 |
break;
| 575 |
| 576 |
fputc('\n', fout);
| 577 |
if (xres > 0) {
| 578 |
if (yres > 0) /* resolution string */
| 579 |
fprtresolu(xres, yres, fout);
| 580 |
fflush(fout);
| 581 |
| 582 |
| 583 |
| 584 |
/* Get output file pointer (open and write header if new) */
| 585 |
FILE *
| 586 |
| 587 |
| 588 |
int ofl;
| 589 |
char oname[1024];
| 590 |
LUENT *lep;
| 591 |
| 592 |
if (ospec == NULL) { /* use stdout? */
| 593 |
if (!using_stdout) {
| 594 |
if (outfmt != 'a')
| 595 |
SET_FILE_BINARY(stdout);
| 596 |
if (header)
| 597 |
printheader(stdout, NULL);
| 598 |
| 599 |
using_stdout = 1;
| 600 |
return stdout;
| 601 |
| 602 |
ofl = ofname(oname, ospec, mname, bn); /* get output name */
| 603 |
if (ofl < 0) {
| 604 |
sprintf(errmsg, "bad output format '%s'", ospec);
| 605 |
| 606 |
| 607 |
lep = lu_find(&ofiletab, oname); /* look it up */
| 608 |
if (lep->key == NULL) /* new entry */
| 609 |
lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
| 610 |
if (lep->data == NULL) { /* open output file */
| 611 |
FILE *fp;
| 612 |
int i;
| 613 |
if (oname[0] == '!') /* output to command */
| 614 |
fp = popen(oname+1, "w");
| 615 |
else
| 616 |
fp = fopen(oname, "w");
| 617 |
if (fp == NULL) {
| 618 |
sprintf(errmsg, "cannot open '%s' for writing", oname);
| 619 |
| 620 |
| 621 |
if (outfmt != 'a')
| 622 |
SET_FILE_BINARY(fp);
| 623 |
if (header) {
| 624 |
char info[512];
| 625 |
char *cp = info;
| 626 |
sprintf(cp, "MODIFIER=%s\n", mname);
| 627 |
while (*cp) ++cp;
| 628 |
if (ofl & OF_BIN) {
| 629 |
sprintf(cp, "BIN=%d\n", bn);
| 630 |
while (*cp) ++cp;
| 631 |
| 632 |
*cp = '\0';
| 633 |
printheader(fp, info);
| 634 |
| 635 |
/* play catch-up */
| 636 |
for (i = 0; i < lastdone; i++) {
| 637 |
static const DCOLOR nocontrib = BLKCOLOR;
| 638 |
put_contrib(nocontrib, fp);
| 639 |
if (outfmt == 'a')
| 640 |
putc('\n', fp);
| 641 |
| 642 |
if (xres > 0)
| 643 |
fflush(fp);
| 644 |
lep->data = (char *)fp;
| 645 |
| 646 |
return (FILE *)lep->data; /* return open file pointer */
| 647 |
| 648 |
| 649 |
/* read input ray into buffer */
| 650 |
int
| 651 |
getinp(char *buf, FILE *fp)
| 652 |
| 653 |
char *cp;
| 654 |
int i;
| 655 |
| 656 |
switch (inpfmt) {
| 657 |
case 'a':
| 658 |
cp = buf; /* make sure we get 6 floats */
| 659 |
for (i = 0; i < 6; i++) {
| 660 |
if (fgetword(cp, buf+127-cp, fp) == NULL)
| 661 |
return 0;
| 662 |
if ((cp = fskip(cp)) == NULL || *cp)
| 663 |
return 0;
| 664 |
*cp++ = ' ';
| 665 |
| 666 |
getc(fp); /* get/put eol */
| 667 |
*cp-- = '\0'; *cp = '\n';
| 668 |
return strlen(buf);
| 669 |
case 'f':
| 670 |
if (fread(buf, sizeof(float), 6, fp) < 6)
| 671 |
return 0;
| 672 |
return sizeof(float)*6;
| 673 |
case 'd':
| 674 |
if (fread(buf, sizeof(double), 6, fp) < 6)
| 675 |
return 0;
| 676 |
return sizeof(double)*6;
| 677 |
| 678 |
error(INTERNAL, "botched input format");
| 679 |
return 0; /* pro forma return */
| 680 |
| 681 |
| 682 |
static float rparams[9]; /* traced ray parameters */
| 683 |
| 684 |
/* return channel (ray) value */
| 685 |
double
| 686 |
chanvalue(int n)
| 687 |
| 688 |
if (--n < 0 || n >= 6)
| 689 |
error(USER, "illegal channel number ($N)");
| 690 |
return rparams[n+3];
| 691 |
| 692 |
| 693 |
/* add current ray contribution to the appropriate modifier bin */
| 694 |
void
| 695 |
| 696 |
| 697 |
LUENT *le = lu_find(&modconttab, modn);
| 698 |
MODCONT *mp = (MODCONT *)le->data;
| 699 |
int bn;
| 700 |
| 701 |
if (mp == NULL) {
| 702 |
sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
| 703 |
| 704 |
| 705 |
eclock++; /* get bin number */
| 706 |
bn = (int)(evalue(mp->binv) + .5);
| 707 |
if (bn <= 0)
| 708 |
bn = 0;
| 709 |
else if (bn > mp->nbins) { /* new bin */
| 710 |
mp = (MODCONT *)realloc(mp, sizeof(MODCONT) +
| 711 |
bn*sizeof(DCOLOR));
| 712 |
if (mp == NULL)
| 713 |
error(SYSTEM, "out of memory in add_contrib");
| 714 |
memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(bn+1-mp->nbins));
| 715 |
mp->nbins = bn+1;
| 716 |
le->data = (char *)mp;
| 717 |
| 718 |
addcolor(mp->cbin[bn], rparams);
| 719 |
| 720 |
| 721 |
/* output newline to ASCII file and/or flush as requested */
| 722 |
static int
| 723 |
puteol(const LUENT *e, void *p)
| 724 |
| 725 |
FILE *fp = (FILE *)e->data;
| 726 |
| 727 |
if (outfmt == 'a')
| 728 |
putc('\n', fp);
| 729 |
if (!waitflush)
| 730 |
fflush(fp);
| 731 |
if (ferror(fp)) {
| 732 |
sprintf(errmsg, "write error on file '%s'", e->key);
| 733 |
| 734 |
| 735 |
return 0;
| 736 |
| 737 |
| 738 |
/* put out ray contribution to file */
| 739 |
void
| 740 |
| 741 |
| 742 |
float fv[3];
| 743 |
COLR cv;
| 744 |
| 745 |
switch (outfmt) {
| 746 |
case 'a':
| 747 |
fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
| 748 |
break;
| 749 |
case 'f':
| 750 |
fv[0] = cnt[0];
| 751 |
fv[1] = cnt[1];
| 752 |
fv[2] = cnt[2];
| 753 |
fwrite(fv, sizeof(float), 3, fout);
| 754 |
break;
| 755 |
case 'd':
| 756 |
fwrite(cnt, sizeof(double), 3, fout);
| 757 |
break;
| 758 |
case 'c':
| 759 |
setcolr(cv, cnt[0], cnt[1], cnt[2]);
| 760 |
fwrite(cv, sizeof(cv), 1, fout);
| 761 |
break;
| 762 |
default:
| 763 |
error(INTERNAL, "botched output format");
| 764 |
| 765 |
| 766 |
| 767 |
/* output ray tallies and clear for next primary */
| 768 |
void
| 769 |
done_contrib(void)
| 770 |
| 771 |
int i, j;
| 772 |
MODCONT *mp;
| 773 |
FILE *fp;
| 774 |
/* output modifiers in order */
| 775 |
for (i = 0; i < nmods; i++) {
| 776 |
mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
| 777 |
fp = getofile(mp->outspec, mp->modname, 0);
| 778 |
put_contrib(mp->cbin[0], fp);
| 779 |
if (mp->nbins > 3 && /* minor optimization */
| 780 |
fp == getofile(mp->outspec, mp->modname, 1))
| 781 |
for (j = 1; j < mp->nbins; j++)
| 782 |
put_contrib(mp->cbin[j], fp);
| 783 |
else
| 784 |
| 785 |
| 786 |
getofile(mp->outspec, mp->modname, j));
| 787 |
/* clear for next ray tree */
| 788 |
memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
| 789 |
| 790 |
--waitflush; /* terminate records */
| 791 |
lu_doall(&ofiletab, puteol, NULL);
| 792 |
if (using_stdout & (outfmt == 'a'))
| 793 |
putc('\n', stdout);
| 794 |
if (!waitflush) {
| 795 |
waitflush = xres;
| 796 |
if (using_stdout)
| 797 |
fflush(stdout);
| 798 |
| 799 |
| 800 |
| 801 |
/* queue completed ray tree produced by rtrace process */
| 802 |
void
| 803 |
| 804 |
| 805 |
struct rtproc *rtu, *rtl = NULL;
| 806 |
/* insert following ray order */
| 807 |
for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
| 808 |
if (rtp->raynum < rtu->raynum)
| 809 |
break;
| 810 |
rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
| 811 |
if (rtu == NULL)
| 812 |
error(SYSTEM, "out of memory in queue_raytree");
| 813 |
*rtu = *rtp;
| 814 |
if (rtl == NULL) {
| 815 |
rtu->next = rt_unproc;
| 816 |
rt_unproc = rtu;
| 817 |
} else {
| 818 |
rtu->next = rtl->next;
| 819 |
rtl->next = rtu;
| 820 |
| 821 |
rtp->raynum = 0; /* clear path for next ray tree */
| 822 |
rtp->bsiz = 0;
| 823 |
rtp->buf = NULL;
| 824 |
rtp->nbr = 0;
| 825 |
| 826 |
| 827 |
/* process completed ray trees from our queue */
| 828 |
void
| 829 |
process_queue(void)
| 830 |
| 831 |
char modname[128];
| 832 |
/* ray-ordered queue */
| 833 |
while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
| 834 |
struct rtproc *rtp = rt_unproc;
| 835 |
int n = rtp->nbr;
| 836 |
const char *cp = rtp->buf;
| 837 |
while (n > 0) { /* process rays */
| 838 |
register char *mnp = modname;
| 839 |
/* skip leading tabs */
| 840 |
while (n > 0 && *cp == '\t') {
| 841 |
cp++; n--;
| 842 |
| 843 |
if (!n || !(isalpha(*cp) | (*cp == '_')))
| 844 |
error(USER, "bad modifier name from rtrace");
| 845 |
/* get modifier name */
| 846 |
while (n > 0 && *cp != '\t') {
| 847 |
*mnp++ = *cp++; n--;
| 848 |
| 849 |
*mnp = '\0';
| 850 |
cp++; n--; /* eat following tab */
| 851 |
if (n < (int)(sizeof(float)*9))
| 852 |
error(USER, "incomplete ray value from rtrace");
| 853 |
/* add ray contribution */
| 854 |
memcpy(rparams, cp, sizeof(float)*9);
| 855 |
cp += sizeof(float)*9; n -= sizeof(float)*9;
| 856 |
add_contrib(modname);
| 857 |
| 858 |
done_contrib(); /* sum up contributions & output */
| 859 |
lastdone = rtp->raynum;
| 860 |
free(rtp->buf); /* free up buffer space */
| 861 |
rt_unproc = rtp->next;
| 862 |
free(rtp); /* done with this ray tree */
| 863 |
| 864 |
| 865 |
| 866 |
/* wait for rtrace process to finish with ray tree */
| 867 |
struct rtproc *
| 868 |
wait_rproc(void)
| 869 |
| 870 |
struct rtproc *rtfree = NULL;
| 871 |
fd_set readset, errset;
| 872 |
int nr;
| 873 |
struct rtproc *rt;
| 874 |
int n;
| 875 |
| 876 |
do {
| 877 |
nr = 0; /* prepare select call */
| 878 |
FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
| 879 |
for (rt = &rt0; rt != NULL; rt = rt->next) {
| 880 |
if (rt->raynum) {
| 881 |
FD_SET(rt->pd.r, &readset);
| 882 |
++nr;
| 883 |
| 884 |
FD_SET(rt->pd.r, &errset);
| 885 |
if (rt->pd.r >= n)
| 886 |
n = rt->pd.r + 1;
| 887 |
| 888 |
if (!nr) /* no rays pending */
| 889 |
break;
| 890 |
if (nr > 1) { /* call select for multiple proc's */
| 891 |
errno = 0;
| 892 |
if (select(n, &readset, NULL, &errset, NULL) < 0)
| 893 |
error(SYSTEM, "select call error in wait_rproc()");
| 894 |
} else
| 895 |
FD_ZERO(&errset);
| 896 |
nr = 0;
| 897 |
| 898 |
if (!FD_ISSET(rt->pd.r, &readset) &&
| 899 |
!FD_ISSET(rt->pd.r, &errset))
| 900 |
continue;
| 901 |
if (rt->buf == NULL) {
| 902 |
rt->bsiz = treebufsiz;
| 903 |
rt->buf = (char *)malloc(treebufsiz);
| 904 |
} else if (rt->nbr + BUFSIZ > rt->bsiz) {
| 905 |
if (rt->bsiz + BUFSIZ <= treebufsiz)
| 906 |
| 907 |
else
| 908 |
rt->bsiz = treebufsiz += BUFSIZ;
| 909 |
rt->buf = (char *)realloc(rt->buf, rt->bsiz);
| 910 |
| 911 |
| 912 |
error(SYSTEM, "out of memory in wait_rproc");
| 913 |
nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
| 914 |
if (nr <= 0)
| 915 |
error(USER, "rtrace process died");
| 916 |
rt->nbr += nr; /* advance & check */
| 917 |
if (rt->nbr >= 4 && !memcmp(rt->buf+rt->nbr-4,
| 918 |
"~\t~\t", 4)) {
| 919 |
rt->nbr -= 4; /* elide terminator */
| 920 |
queue_raytree(rt);
| 921 |
rtfree = rt; /* ready for next ray */
| 922 |
| 923 |
| 924 |
} while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
| 925 |
return rtfree;
| 926 |
| 927 |
| 928 |
/* return next available rtrace process */
| 929 |
struct rtproc *
| 930 |
get_rproc(void)
| 931 |
| 932 |
struct rtproc *rtp;
| 933 |
/* check for idle rtrace */
| 934 |
for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
| 935 |
if (!rtp->raynum)
| 936 |
return rtp;
| 937 |
return wait_rproc(); /* need to wait for one */
| 938 |
| 939 |
| 940 |
/* trace ray contributions (main loop) */
| 941 |
void
| 942 |
| 943 |
| 944 |
char inpbuf[128];
| 945 |
int iblen;
| 946 |
struct rtproc *rtp;
| 947 |
/* loop over input */
| 948 |
while ((iblen = getinp(inpbuf, fin)) > 0) {
| 949 |
if (lastray+1 < lastray) { /* counter rollover? */
| 950 |
while (wait_rproc() != NULL)
| 951 |
process_queue();
| 952 |
lastdone = lastray = 0;
| 953 |
| 954 |
rtp = get_rproc(); /* get avail. rtrace process */
| 955 |
rtp->raynum = ++lastray; /* assign ray to it */
| 956 |
writebuf(rtp->pd.w, inpbuf, iblen);
| 957 |
if (raysleft && !--raysleft)
| 958 |
break;
| 959 |
process_queue(); /* catch up with results */
| 960 |
| 961 |
while (wait_rproc() != NULL) /* process outstanding rays */
| 962 |
process_queue();
| 963 |
if (raysleft)
| 964 |
error(USER, "unexpected EOF on input");
| 965 |
lu_done(&ofiletab); /* close output files */
| 966 |
| 967 |
| 968 |
/* seek on the given output file */
| 969 |
static int
| 970 |
myseeko(const LUENT *e, void *p)
| 971 |
| 972 |
if (fseeko((FILE *)e->data, *(off_t *)p, SEEK_CUR) < 0) {
| 973 |
sprintf(errmsg, "seek error on file '%s'", e->key);
| 974 |
| 975 |
| 976 |
| 977 |
| 978 |
/* recover output if possible */
| 979 |
void
| 980 |
| 981 |
| 982 |
off_t lastout = -1;
| 983 |
int outvsiz;
| 984 |
char *outvfmt;
| 985 |
int i, j;
| 986 |
MODCONT *mp;
| 987 |
int ofl;
| 988 |
char oname[1024];
| 989 |
LUENT *ment, *oent;
| 990 |
FILE *fp;
| 991 |
off_t nvals;
| 992 |
| 993 |
switch (outfmt) {
| 994 |
case 'a':
| 995 |
error(USER, "cannot recover ASCII output");
| 996 |
return;
| 997 |
case 'f':
| 998 |
outvsiz = sizeof(float)*3;
| 999 |
outvfmt = "float";
| 1000 |
break;
| 1001 |
case 'd':
| 1002 |
outvsiz = sizeof(double)*3;
| 1003 |
outvfmt = "double";
| 1004 |
break;
| 1005 |
case 'c':
| 1006 |
outvsiz = sizeof(COLR);
| 1007 |
outvfmt = COLRFMT;
| 1008 |
break;
| 1009 |
default:
| 1010 |
| 1011 |
return;
| 1012 |
| 1013 |
/* check modifier outputs */
| 1014 |
| 1015 |
ment = lu_find(&modconttab,modname[i]);
| 1016 |
mp = (MODCONT *)ment->data;
| 1017 |
if (mp->outspec == NULL)
| 1018 |
error(USER, "cannot recover from stdout");
| 1019 |
for (j = 0; ; j++) { /* check each bin's file */
| 1020 |
ofl = ofname(oname, mp->outspec, mp->modname, j);
| 1021 |
if (ofl < 0)
| 1022 |
error(USER, "bad output file specification");
| 1023 |
oent = lu_find(&ofiletab, oname);
| 1024 |
if (oent->data != NULL) { /* saw this one already */
| 1025 |
if (ofl & OF_BIN)
| 1026 |
continue;
| 1027 |
break;
| 1028 |
| 1029 |
| 1030 |
error(USER, "cannot recover from command");
| 1031 |
/* open output */
| 1032 |
fp = fopen(oname, "rb+");
| 1033 |
if (fp == NULL)
| 1034 |
break; /* must be end of modifier */
| 1035 |
nvals = lseek(fileno(fp), 0, SEEK_END);
| 1036 |
if (nvals <= 0) {
| 1037 |
lastout = 0; /* empty output, quit here */
| 1038 |
fclose(fp);
| 1039 |
break;
| 1040 |
| 1041 |
lseek(fileno(fp), 0, SEEK_SET);
| 1042 |
if (header) {
| 1043 |
int xr, yr;
| 1044 |
if (checkheader(fp, outvfmt, NULL) != 1) {
| 1045 |
sprintf(errmsg,
| 1046 |
"format mismatch for '%s'",
| 1047 |
oname);
| 1048 |
| 1049 |
| 1050 |
if (xres > 0 && yres > 0 &&
| 1051 |
(!fscnresolu(&xr, &yr, fp) ||
| 1052 |
xr != xres ||
| 1053 |
yr != yres)) {
| 1054 |
sprintf(errmsg,
| 1055 |
"resolution mismatch for '%s'",
| 1056 |
oname);
| 1057 |
| 1058 |
| 1059 |
| 1060 |
nvals = (nvals - (off_t)ftell(fp)) / outvsiz;
| 1061 |
if (lastout < 0 || nvals < lastout)
| 1062 |
lastout = nvals;
| 1063 |
if (oent->key == NULL) /* new entry */
| 1064 |
oent->key = strcpy((char *)
| 1065 |
| 1066 |
oent->data = (char *)fp;
| 1067 |
if (!(ofl & OF_BIN))
| 1068 |
break; /* no bin separation */
| 1069 |
| 1070 |
if (!lastout) { /* empty output */
| 1071 |
error(WARNING, "no previous data to recover");
| 1072 |
lu_done(&ofiletab); /* reclose all outputs */
| 1073 |
return;
| 1074 |
| 1075 |
if (j > mp->nbins) { /* preallocate modifier bins */
| 1076 |
| 1077 |
(j-1)*sizeof(DCOLOR));
| 1078 |
if (mp == NULL)
| 1079 |
error(SYSTEM, "out of memory in recover_output");
| 1080 |
| 1081 |
mp->nbins = j;
| 1082 |
ment->data = (char *)mp;
| 1083 |
| 1084 |
| 1085 |
if (lastout < 0) {
| 1086 |
error(WARNING, "no output files to recover");
| 1087 |
return;
| 1088 |
| 1089 |
/* seek on all files */
| 1090 |
nvals = lastout * outvsiz;
| 1091 |
lu_doall(&ofiletab, myseeko, &nvals);
| 1092 |
/* discard input */
| 1093 |
for (nvals = 0; nvals < lastout; nvals++)
| 1094 |
if (getinp(oname, fin) <= 0)
| 1095 |
| 1096 |
lastray = lastdone = (unsigned long)lastout;
| 1097 |
if (raysleft)
| 1098 |
raysleft -= lastray;
| 1099 |
