root/radiance/ray/src/util/rtcontrib.c
Revision: 1.63
Committed: Sat Apr 9 18:05:18 2011 UTC (13 years, 2 months ago) by greg
Changes since 1.62: +14 -7 lines
Fixed problem with command specification of octree
2 static const char RCSid[] = "$Id: rtcontrib.c,v 1.62 2011/04/06 00:39:07 greg Exp $";
5 * Gather rtrace output to compute contributions from particular sources
6 */
7
8 #include "standard.h"
9 #include <ctype.h>
10 #include <signal.h>
11 #include "platform.h"
12 #include "rtprocess.h"
13 #include "selcall.h"
14 #include "color.h"
15 #include "resolu.h"
16 #include "lookup.h"
17 #include "calcomp.h"
18
19 #ifndef MAXMODLIST
20 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
21 #endif
22
23 size_t treebufsiz = BUFSIZ; /* current tree buffer size */
24
25 typedef double DCOLOR[3]; /* double-precision color */
26
27 /*
28 * The MODCONT structure is used to accumulate ray contributions
29 * for a particular modifier, which may be subdivided into bins
30 * if binv evaluates > 0. If outspec contains a %s in it, this will
31 * be replaced with the modifier name. If outspec contains a %d in it,
32 * this will be used to create one output file per bin, otherwise all bins
33 * will be written to the same file, in order. If the global outfmt
34 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
35 * and the file will conform to a RADIANCE image if xres & yres are set.
36 */
37 typedef struct {
38 const char *outspec; /* output file specification */
39 const char *modname; /* modifier name */
40 EPNODE *binv; /* bin value expression */
41 int nbins; /* number of accumulation bins */
42 DCOLOR cbin[1]; /* contribution bins (extends struct) */
43 } MODCONT; /* modifier contribution */
44
45 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
46
47 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
48
49 /*
50 * The STREAMOUT structure holds an open FILE pointer and a count of
51 * the number of RGB triplets per record, or 0 if unknown.
52 */
53 typedef struct {
54 FILE *ofp; /* output file pointer */
55 int outpipe; /* output is to a pipe */
56 int reclen; /* triplets/record */
57 int xr, yr; /* output resolution for picture */
58 } STREAMOUT;
59
60 /* close output stream and free record */
61 static void
62 closestream(void *p)
63 {
64 STREAMOUT *sop = (STREAMOUT *)p;
65 int status;
66 if (sop->outpipe)
67 status = pclose(sop->ofp);
68 else
69 status = fclose(sop->ofp);
70 if (status)
71 error(SYSTEM, "error closing output stream");
72 free(p);
73 }
74
75 LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
76
77 #define OF_MODIFIER 01
78 #define OF_BIN 02
79
80 STREAMOUT *getostream(const char *ospec, const char *mname, int bn, int noopen);
81 int ofname(char *oname, const char *ospec, const char *mname, int bn);
82 void printheader(FILE *fout, const char *info);
83 void printresolu(FILE *fout, int xr, int yr);
84
85 /*
86 * The rcont structure is used to manage i/o with a particular
87 * rtrace child process. Input is passed unchanged from stdin,
88 * and output is processed in input order and accumulated according
89 * to the corresponding modifier and bin number.
90 */
91 struct rtproc {
92 struct rtproc *next; /* next in list of processes */
93 SUBPROC pd; /* rtrace pipe descriptors */
94 unsigned long raynum; /* ray number for this tree */
95 size_t bsiz; /* ray tree buffer length */
96 char *buf; /* ray tree buffer */
97 size_t nbr; /* number of bytes from rtrace */
98 }; /* rtrace process buffer */
99
100 /* rtrace command and defaults */
101 char *rtargv[256+2*MAXMODLIST] = { "rtrace",
102 "-dj", ".9", "-dr", "3",
103 "-ab", "1", "-ad", "350", };
104
105 int rtargc = 9;
106 /* overriding rtrace options */
107 char *myrtopts[] = { "-h-", "-x", "1", "-y", "0",
108 "-dt", "0", "-as", "0", "-aa", "0", NULL };
109
110 #define RTCOEFF "-o~~~TmWdp" /* compute coefficients only */
111 #define RTCONTRIB "-o~~~TmVdp" /* compute ray contributions */
112
113 struct rtproc rt0; /* head of rtrace process list */
114
115 struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
116
117 #define PERSIST_NONE 0 /* no persist file */
118 #define PERSIST_SINGLE 1 /* user set -P persist */
119 #define PERSIST_PARALL 2 /* user set -PP persist */
120 #define PERSIST_OURS 3 /* -PP persist belongs to us */
121 int persist_state = PERSIST_NONE; /* persist file state */
122 char persistfn[] = "pfXXXXXX"; /* our persist file name, if set */
123
124 int gargc; /* global argc */
125 char **gargv; /* global argv */
126 #define progname gargv[0]
127
128 char *octree; /* global octree argument */
129
130 int inpfmt = 'a'; /* input format */
131 int outfmt = 'a'; /* output format */
132
133 int header = 1; /* output header? */
134 int force_open = 0; /* truncate existing output? */
135 int recover = 0; /* recover previous output? */
136 int accumulate = 1; /* input rays per output record */
137 int xres = 0; /* horiz. output resolution */
138 int yres = 0; /* vert. output resolution */
139
140 int account; /* current accumulation count */
141 unsigned long raysleft; /* number of rays left to trace */
142 long waitflush; /* how long until next flush */
143
144 unsigned long lastray = 0; /* last ray number sent */
145 unsigned long lastdone = 0; /* last ray processed */
146
147 int using_stdout = 0; /* are we using stdout? */
148
149 const char *modname[MAXMODLIST]; /* ordered modifier name list */
150 int nmods = 0; /* number of modifiers */
151
152 #define queue_length() (lastray - lastdone)
153
154 MODCONT *growmodifier(MODCONT *mp, int nb);
155 MODCONT *addmodifier(char *modn, char *outf, char *binv, int bincnt);
156 void addmodfile(char *fname, char *outf, char *binv, int bincnt);
157
158 void init(int np);
159 int done_rprocs(struct rtproc *rtp);
160 void reload_output(void);
161 void recover_output(FILE *fin);
162 void trace_contribs(FILE *fin);
163 struct rtproc *wait_rproc(void);
164 struct rtproc *get_rproc(void);
165 void queue_raytree(struct rtproc *rtp);
166 void process_queue(void);
167
168 void put_contrib(const DCOLOR cnt, FILE *fout);
169 void add_contrib(const char *modn);
170 void done_contrib(int navg);
171
172 /* return number of open rtrace processes */
173 static int
174 nrtprocs(void)
175 {
176 int nrtp = 0;
177 struct rtproc *rtp;
178
179 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
180 nrtp += rtp->pd.running;
181 return(nrtp);
182 }
183
184 /* set input/output format */
185 static void
186 setformat(const char *fmt)
187 {
188 switch (fmt[0]) {
189 case 'f':
190 case 'd':
191 SET_FILE_BINARY(stdin);
192 /* fall through */
193 case 'a':
194 inpfmt = fmt[0];
195 break;
196 default:
197 goto fmterr;
198 }
199 switch (fmt[1]) {
200 case '\0':
201 outfmt = inpfmt;
202 return;
203 case 'a':
204 case 'f':
205 case 'd':
206 case 'c':
207 outfmt = fmt[1];
208 break;
209 default:
210 goto fmterr;
211 }
212 if (!fmt[2])
213 return;
214 fmterr:
215 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
216 error(USER, errmsg);
217 }
218
219 /* gather rays from rtrace and output contributions */
220 int
221 main(int argc, char *argv[])
222 {
223 int contrib = 0;
224 int nprocs = 1;
225 char *curout = NULL;
226 char *binval = NULL;
227 int bincnt = 0;
228 char fmt[8];
229 int i, j;
230 /* need at least one argument */
231 if (argc < 2) {
232 fprintf(stderr,
233 "Usage: %s [-n nprocs][-V][-r][-e expr][-f source][-o ospec][-b binv] {-m mod | -M file} [rtrace options] octree\n",
234 argv[0]);
235 exit(1);
236 }
237 /* global program name */
238 gargv = argv;
239 /* initialize calcomp routines */
240 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
241 esupport &= ~(E_OUTCHAN);
242 varset("PI", ':', PI);
243 /* get our options */
244 for (i = 1; i < argc-1; i++) {
245 /* expand arguments */
246 while ((j = expandarg(&argc, &argv, i)) > 0)
247 ;
248 if (j < 0) {
249 fprintf(stderr, "%s: cannot expand '%s'\n",
250 argv[0], argv[i]);
251 exit(1);
252 }
253 if (argv[i][0] == '-')
254 switch (argv[i][1]) {
255 case 'n': /* number of processes */
256 if (argv[i][2] || i >= argc-2) break;
257 nprocs = atoi(argv[++i]);
258 if (nprocs <= 0)
259 error(USER, "illegal number of processes");
260 continue;
261 case 'V': /* output contributions */
262 switch (argv[i][2]) {
263 case '\0':
264 contrib = !contrib;
265 continue;
266 case '+': case '1':
267 case 'T': case 't':
268 case 'Y': case 'y':
269 contrib = 1;
270 continue;
271 case '-': case '0':
272 case 'F': case 'f':
273 case 'N': case 'n':
274 contrib = 0;
275 continue;
276 }
277 break;
278 case 'c': /* input rays per output */
279 if (argv[i][2] || i >= argc-2) break;
280 accumulate = atoi(argv[++i]);
281 continue;
282 case 'r': /* recover output */
283 if (argv[i][2]) break;
284 recover = 1;
285 continue;
286 case 'h': /* output header? */
287 switch (argv[i][2]) {
288 case '\0':
289 header = !header;
290 continue;
291 case '+': case '1':
292 case 'T': case 't':
293 case 'Y': case 'y':
294 header = 1;
295 continue;
296 case '-': case '0':
297 case 'F': case 'f':
298 case 'N': case 'n':
299 header = 0;
300 continue;
301 }
302 break;
303 case 'f': /* file or force or format */
304 if (!argv[i][2]) {
305 char *fpath;
306 if (i >= argc-2) break;
307 fpath = getpath(argv[++i],
308 getrlibpath(), R_OK);
309 if (fpath == NULL) {
310 sprintf(errmsg,
311 "cannot find file '%s'",
312 argv[i]);
313 error(USER, errmsg);
314 }
315 fcompile(fpath);
316 continue;
317 }
318 if (argv[i][2] == 'o') {
319 force_open = 1;
320 continue;
321 }
322 setformat(argv[i]+2);
323 continue;
324 case 'e': /* expression */
325 if (argv[i][2] || i >= argc-2) break;
326 scompile(argv[++i], NULL, 0);
327 continue;
328 case 'o': /* output file spec. */
329 if (argv[i][2] || i >= argc-2) break;
330 curout = argv[++i];
331 continue;
332 case 'x': /* horiz. output resolution */
333 if (argv[i][2] || i >= argc-2) break;
334 xres = atoi(argv[++i]);
335 continue;
336 case 'y': /* vert. output resolution */
337 if (argv[i][2] || i >= argc-2) break;
338 yres = atoi(argv[++i]);
339 continue;
340 case 'b': /* bin expression/count */
341 if (i >= argc-2) break;
342 if (argv[i][2] == 'n') {
343 bincnt = (int)(eval(argv[++i]) + .5);
344 continue;
345 }
346 if (argv[i][2]) break;
347 binval = argv[++i];
348 continue;
349 case 'm': /* modifier name */
350 if (argv[i][2] || i >= argc-2) break;
351 rtargv[rtargc++] = "-ti";
352 rtargv[rtargc++] = argv[++i];
353 addmodifier(argv[i], curout, binval, bincnt);
354 continue;
355 case 'M': /* modifier file */
356 if (argv[i][2] || i >= argc-2) break;
357 rtargv[rtargc++] = "-tI";
358 rtargv[rtargc++] = argv[++i];
359 addmodfile(argv[i], curout, binval, bincnt);
360 continue;
361 case 'P': /* persist file */
362 if (i >= argc-2) break;
363 persist_state = (argv[i][2] == 'P') ?
364 PERSIST_PARALL : PERSIST_SINGLE;
365 rtargv[rtargc++] = argv[i];
366 rtargv[rtargc++] = argv[++i];
367 continue;
368 }
369 rtargv[rtargc++] = argv[i]; /* assume rtrace option */
370 }
371 if (accumulate <= 0) /* no output flushing for single record */
372 xres = yres = 0;
373 /* set global argument list */
374 gargc = argc; gargv = argv;
375 /* add "mandatory" rtrace settings */
376 for (j = 0; myrtopts[j] != NULL; j++)
377 rtargv[rtargc++] = myrtopts[j];
378 rtargv[rtargc++] = contrib ? RTCONTRIB : RTCOEFF;
379 /* just asking for defaults? */
380 if (!strcmp(argv[i], "-defaults")) {
381 char nps[8], sxres[16], syres[16];
382 char *rtpath;
383 printf("-c %-5d\t\t\t# accumulated rays per record\n",
384 accumulate);
385 printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-',
386 contrib ? "contributions" : "coefficients");
387 fflush(stdout); /* report OUR options */
388 rtargv[rtargc++] = "-n";
389 sprintf(nps, "%d", nprocs);
390 rtargv[rtargc++] = nps;
391 rtargv[rtargc++] = header ? "-h+" : "-h-";
392 sprintf(fmt, "-f%c%c", inpfmt, outfmt);
393 rtargv[rtargc++] = fmt;
394 rtargv[rtargc++] = "-x";
395 sprintf(sxres, "%d", xres);
396 rtargv[rtargc++] = sxres;
397 rtargv[rtargc++] = "-y";
398 sprintf(syres, "%d", yres);
399 rtargv[rtargc++] = syres;
400 rtargv[rtargc++] = "-defaults";
401 rtargv[rtargc] = NULL;
402 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
403 if (rtpath == NULL) {
404 eputs(rtargv[0]);
405 eputs(": command not found\n");
406 exit(1);
407 }
408 execv(rtpath, rtargv);
409 perror(rtpath); /* execv() should not return */
410 exit(1);
411 }
412 if (nprocs > 1) { /* add persist file if parallel */
413 if (persist_state == PERSIST_SINGLE)
414 error(USER, "use -PP option for multiple processes");
415 if (persist_state == PERSIST_NONE) {
416 rtargv[rtargc++] = "-PP";
417 rtargv[rtargc++] = mktemp(persistfn);
418 persist_state = PERSIST_OURS;
419 }
420 }
421 /* add format string */
422 sprintf(fmt, "-f%cf", inpfmt);
423 rtargv[rtargc++] = fmt;
424 /* octree argument is last */
425 if (i <= 0 || i != argc-1 || argv[i][0] == '-')
426 error(USER, "missing octree argument");
427 rtargv[rtargc++] = octree = argv[i];
428 rtargv[rtargc] = NULL;
429 /* start rtrace & recover if requested */
430 init(nprocs);
431 /* compute contributions */
432 trace_contribs(stdin);
433 /* clean up */
434 quit(0);
435 }
436
437 #ifndef SIGALRM
438 #define SIGALRM SIGTERM
439 #endif
440 /* kill persistent rtrace process */
441 static void
442 killpersist(void)
443 {
444 FILE *fp = fopen(persistfn, "r");
445 RT_PID pid;
446
447 if (fp == NULL)
448 return;
449 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
450 unlink(persistfn);
451 fclose(fp);
452 }
453
454 /* close rtrace processes and clean up */
455 int
456 done_rprocs(struct rtproc *rtp)
457 {
458 int st0, st1 = 0;
459
460 if (rtp->next != NULL) { /* close last opened first! */
461 st1 = done_rprocs(rtp->next);
462 free((void *)rtp->next);
463 rtp->next = NULL;
464 }
465 st0 = close_process(&rtp->pd);
466 if (st0 < 0)
467 error(WARNING, "unknown return status from rtrace process");
468 else if (st0 > 0)
469 return(st0);
470 return(st1);
471 }
472
473 /* exit with status */
474 void
475 quit(int status)
476 {
477 int rtstat;
478
479 if (persist_state == PERSIST_OURS) /* terminate waiting rtrace */
480 killpersist();
481 /* clean up rtrace process(es) */
482 rtstat = done_rprocs(&rt0);
483 if (status == 0)
484 status = rtstat;
485 exit(status); /* flushes all output streams */
486 }
487
488 /* start rtrace processes and initialize */
489 void
490 init(int np)
491 {
492 struct rtproc *rtp;
493 int i;
494 int maxbytes;
495 /* make sure we have something to do */
496 if (!nmods)
497 error(USER, "No modifiers specified");
498 /* assign ray variables */
499 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
500 scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
501 /* set up signal handling */
502 signal(SIGINT, quit);
503 #ifdef SIGHUP
504 signal(SIGHUP, quit);
505 #endif
506 #ifdef SIGTERM
507 signal(SIGTERM, quit);
508 #endif
509 #ifdef SIGPIPE
510 signal(SIGPIPE, quit);
511 #endif
512 rtp = &rt0; /* start rtrace process(es) */
513 for (i = 0; i++ < np; ) {
514 errno = 0;
515 maxbytes = open_process(&rtp->pd, rtargv);
516 if (maxbytes == 0) {
517 eputs(rtargv[0]);
518 eputs(": command not found\n");
519 exit(1);
520 }
521 if (maxbytes < 0)
522 error(SYSTEM, "cannot start rtrace process");
523 if (maxbytes > treebufsiz)
524 treebufsiz = maxbytes;
525 rtp->raynum = 0;
526 rtp->bsiz = 0;
527 rtp->buf = NULL;
528 rtp->nbr = 0;
529 if (i == np) /* last process? */
530 break;
531 if (i == 1)
532 sleep(2); /* wait for persist file */
533 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
534 if (rtp->next == NULL)
535 error(SYSTEM, "out of memory in init");
536 rtp = rtp->next;
537 }
538 rtp->next = NULL; /* terminate list */
539 if (yres > 0) {
540 if (xres > 0)
541 raysleft = (unsigned long)xres*yres;
542 else
543 raysleft = yres;
544 } else
545 raysleft = 0;
546 if ((account = accumulate) > 0)
547 raysleft *= accumulate;
548 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
549 if (!recover)
550 return;
551 /* recover previous values */
552 if (accumulate <= 0)
553 reload_output();
554 else
555 recover_output(stdin);
556 }
557
558 /* grow modifier to accommodate more bins */
559 MODCONT *
560 growmodifier(MODCONT *mp, int nb)
561 {
562 if (nb <= mp->nbins)
563 return mp;
564 mp = (MODCONT *)realloc(mp, sizeof(MODCONT) + sizeof(DCOLOR)*(nb-1));
565 if (mp == NULL)
566 error(SYSTEM, "out of memory in growmodifier");
567 memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(nb-mp->nbins));
568 mp->nbins = nb;
569 return mp;
570 }
571
572 /* add modifier to our list to track */
573 MODCONT *
574 addmodifier(char *modn, char *outf, char *binv, int bincnt)
575 {
576 LUENT *lep = lu_find(&modconttab, modn);
577 MODCONT *mp;
578 int i;
579
580 if (lep->data != NULL) {
581 sprintf(errmsg, "duplicate modifier '%s'", modn);
582 error(USER, errmsg);
583 }
584 if (nmods >= MAXMODLIST)
585 error(INTERNAL, "too many modifiers");
586 modname[nmods++] = modn; /* XXX assumes static string */
587 lep->key = modn; /* XXX assumes static string */
588 mp = (MODCONT *)malloc(sizeof(MODCONT));
589 if (mp == NULL)
590 error(SYSTEM, "out of memory in addmodifier");
591 mp->outspec = outf; /* XXX assumes static string */
592 mp->modname = modn; /* XXX assumes static string */
593 if (binv == NULL)
594 binv = "0"; /* use single bin if unspecified */
595 mp->binv = eparse(binv);
596 if (mp->binv->type == NUM) { /* check value if constant */
597 bincnt = (int)(evalue(mp->binv) + 1.5);
598 if (bincnt != 1) {
599 sprintf(errmsg, "illegal non-zero constant for bin (%s)",
600 binv);
601 error(USER, errmsg);
602 }
603 }
604 mp->nbins = 1; /* initialize results holder */
605 setcolor(mp->cbin[0], 0., 0., 0.);
606 if (bincnt > 1)
607 mp = growmodifier(mp, bincnt);
608 lep->data = (char *)mp;
609 /* allocate output streams */
610 for (i = bincnt; i-- > 0; )
611 getostream(mp->outspec, mp->modname, i, 1);
612 return mp;
613 }
614
615 /* add modifiers from a file list */
616 void
617 addmodfile(char *fname, char *outf, char *binv, int bincnt)
618 {
619 char *mname[MAXMODLIST];
620 int i;
621 /* find the file & store strings */
622 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
623 sprintf(errmsg, "cannot find modifier file '%s'", fname);
624 error(SYSTEM, errmsg);
625 }
626 for (i = 0; mname[i]; i++) /* add each one */
627 addmodifier(mname[i], outf, binv, bincnt);
628 }
629
630 /* put string to stderr */
631 void
632 eputs(char *s)
633 {
634 static int midline = 0;
635
636 if (!*s) return;
637 if (!midline) {
638 fputs(progname, stderr);
639 fputs(": ", stderr);
640 }
641 fputs(s, stderr);
642 midline = s[strlen(s)-1] != '\n';
643 }
644
645 /* construct output file name and return flags whether modifier/bin present */
646 int
647 ofname(char *oname, const char *ospec, const char *mname, int bn)
648 {
649 const char *mnp = NULL;
650 const char *bnp = NULL;
651 const char *cp;
652
653 if (ospec == NULL)
654 return -1;
655 for (cp = ospec; *cp; cp++) /* check format position(s) */
656 if (*cp == '%') {
657 do
658 ++cp;
659 while (isdigit(*cp));
660 switch (*cp) {
661 case '%':
662 break;
663 case 's':
664 if (mnp != NULL)
665 return -1;
666 mnp = cp;
667 break;
668 case 'd':
669 case 'i':
670 case 'o':
671 case 'x':
672 case 'X':
673 if (bnp != NULL)
674 return -1;
675 bnp = cp;
676 break;
677 default:
678 return -1;
679 }
680 }
681 if (mnp != NULL) { /* create file name */
682 if (bnp != NULL) {
683 if (bnp > mnp)
684 sprintf(oname, ospec, mname, bn);
685 else
686 sprintf(oname, ospec, bn, mname);
687 return OF_MODIFIER|OF_BIN;
688 }
689 sprintf(oname, ospec, mname);
690 return OF_MODIFIER;
691 }
692 if (bnp != NULL) {
693 sprintf(oname, ospec, bn);
694 return OF_BIN;
695 }
696 strcpy(oname, ospec);
697 return 0;
698 }
699
700 /* write header to the given output stream */
701 void
702 printheader(FILE *fout, const char *info)
703 {
704 extern char VersionID[];
705 /* copy octree header */
706 if (octree[0] == '!') {
707 newheader("RADIANCE", fout);
708 fputs(octree+1, fout);
709 if (octree[strlen(octree)-1] != '\n')
710 fputc('\n', fout);
711 } else {
712 FILE *fin = fopen(octree, "r");
713 if (fin == NULL)
714 quit(1);
715 checkheader(fin, "ignore", fout);
716 fclose(fin);
717 }
718 printargs(gargc-1, gargv, fout); /* add our command */
719 fprintf(fout, "SOFTWARE= %s\n", VersionID);
720 fputnow(fout);
721 if (info != NULL) /* add extra info if given */
722 fputs(info, fout);
723 switch (outfmt) { /* add output format */
724 case 'a':
725 fputformat("ascii", fout);
726 break;
727 case 'f':
728 fputformat("float", fout);
729 break;
730 case 'd':
731 fputformat("double", fout);
732 break;
733 case 'c':
734 fputformat(COLRFMT, fout);
735 break;
736 }
737 fputc('\n', fout);
738 }
739
740 /* write resolution string to given output stream */
741 void
742 printresolu(FILE *fout, int xr, int yr)
743 {
744 if ((xr > 0) & (yr > 0)) /* resolution string */
745 fprtresolu(xr, yr, fout);
746 }
747
748 /* Get output stream pointer (open and write header if new and noopen==0) */
749 STREAMOUT *
750 getostream(const char *ospec, const char *mname, int bn, int noopen)
751 {
752 static const DCOLOR nocontrib = BLKCOLOR;
753 static STREAMOUT stdos;
754 int ofl;
755 char oname[1024];
756 LUENT *lep;
757 STREAMOUT *sop;
758
759 if (ospec == NULL) { /* use stdout? */
760 if (!noopen && !using_stdout) {
761 if (outfmt != 'a')
762 SET_FILE_BINARY(stdout);
763 if (header)
764 printheader(stdout, NULL);
765 printresolu(stdout, xres, yres);
766 if (waitflush > 0)
767 fflush(stdout);
768 stdos.xr = xres; stdos.yr = yres;
769 using_stdout = 1;
770 }
771 stdos.ofp = stdout;
772 stdos.reclen += noopen;
773 return &stdos;
774 }
775 ofl = ofname(oname, ospec, mname, bn); /* get output name */
776 if (ofl < 0) {
777 sprintf(errmsg, "bad output format '%s'", ospec);
778 error(USER, errmsg);
779 }
780 lep = lu_find(&ofiletab, oname); /* look it up */
781 if (lep->key == NULL) /* new entry */
782 lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
783 sop = (STREAMOUT *)lep->data;
784 if (sop == NULL) { /* allocate stream */
785 sop = (STREAMOUT *)malloc(sizeof(STREAMOUT));
786 if (sop == NULL)
787 error(SYSTEM, "out of memory in getostream");
788 sop->outpipe = oname[0] == '!';
789 sop->reclen = 0;
790 sop->ofp = NULL; /* open iff noopen==0 */
791 sop->xr = xres; sop->yr = yres;
792 lep->data = (char *)sop;
793 if (!sop->outpipe & !force_open & !recover &&
794 access(oname, F_OK) == 0) {
795 errno = EEXIST; /* file exists */
796 goto openerr;
797 }
798 }
799 if (!noopen && sop->ofp == NULL) { /* open output stream */
800 long i;
801 if (oname[0] == '!') /* output to command */
802 sop->ofp = popen(oname+1, "w");
803 else /* else open file */
804 sop->ofp = fopen(oname, "w");
805 if (sop->ofp == NULL)
806 goto openerr;
807 if (outfmt != 'a')
808 SET_FILE_BINARY(sop->ofp);
809 if (header) {
810 char info[512];
811 char *cp = info;
812 if (ofl & OF_MODIFIER || sop->reclen == 1) {
813 sprintf(cp, "MODIFIER=%s\n", mname);
814 while (*cp) ++cp;
815 }
816 if (ofl & OF_BIN) {
817 sprintf(cp, "BIN=%d\n", bn);
818 while (*cp) ++cp;
819 }
820 *cp = '\0';
821 printheader(sop->ofp, info);
822 }
823 if (accumulate > 0) { /* global resolution */
824 sop->xr = xres; sop->yr = yres;
825 }
826 printresolu(sop->ofp, sop->xr, sop->yr);
827 /* play catch-up */
828 for (i = accumulate > 0 ? lastdone/accumulate : 0; i--; ) {
829 int j = sop->reclen;
830 if (j <= 0) j = 1;
831 while (j--)
832 put_contrib(nocontrib, sop->ofp);
833 if (outfmt == 'a')
834 putc('\n', sop->ofp);
835 }
836 if (waitflush > 0)
837 fflush(sop->ofp);
838 }
839 sop->reclen += noopen; /* add to length if noopen */
840 return sop; /* return output stream */
841 openerr:
842 sprintf(errmsg, "cannot open '%s' for writing", oname);
843 error(SYSTEM, errmsg);
844 return NULL; /* pro forma return */
845 }
846
847 /* read input ray into buffer */
848 int
849 getinp(char *buf, FILE *fp)
850 {
851 double dv[3], *dvp;
852 float *fvp;
853 char *cp;
854 int i;
855
856 switch (inpfmt) {
857 case 'a':
858 cp = buf; /* make sure we get 6 floats */
859 for (i = 0; i < 6; i++) {
860 if (fgetword(cp, buf+127-cp, fp) == NULL)
861 return -1;
862 if (i >= 3)
863 dv[i-3] = atof(cp);
864 if ((cp = fskip(cp)) == NULL || *cp)
865 return -1;
866 *cp++ = ' ';
867 }
868 getc(fp); /* get/put eol */
869 *cp-- = '\0'; *cp = '\n';
870 if (DOT(dv,dv) <= FTINY*FTINY)
871 return 0; /* dummy ray */
872 return strlen(buf);
873 case 'f':
874 if (fread(buf, sizeof(float), 6, fp) < 6)
875 return -1;
876 fvp = (float *)buf + 3;
877 if (DOT(fvp,fvp) <= FTINY*FTINY)
878 return 0; /* dummy ray */
879 return sizeof(float)*6;
880 case 'd':
881 if (fread(buf, sizeof(double), 6, fp) < 6)
882 return -1;
883 dvp = (double *)buf + 3;
884 if (DOT(dvp,dvp) <= FTINY*FTINY)
885 return 0; /* dummy ray */
886 return sizeof(double)*6;
887 }
888 error(INTERNAL, "botched input format");
889 return -1; /* pro forma return */
890 }
891
892 static float rparams[9]; /* traced ray parameters */
893
894 /* return channel (ray) value */
895 double
896 chanvalue(int n)
897 {
898 if (--n < 0 || n >= 6)
899 error(USER, "illegal channel number ($N)");
900 return rparams[n+3];
901 }
902
903 /* add current ray contribution to the appropriate modifier bin */
904 void
905 add_contrib(const char *modn)
906 {
907 LUENT *le = lu_find(&modconttab, modn);
908 MODCONT *mp = (MODCONT *)le->data;
909 int bn;
910
911 if (mp == NULL) {
912 sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
913 error(USER, errmsg);
914 }
915 eclock++; /* get bin number */
916 bn = (int)(evalue(mp->binv) + .5);
917 if (bn <= 0)
918 bn = 0;
919 else if (bn >= mp->nbins) /* new bin */
920 le->data = (char *)(mp = growmodifier(mp, bn+1));
921 addcolor(mp->cbin[bn], rparams);
922 }
923
924 /* output newline to ASCII file and/or flush as requested */
925 static int
926 puteol(const LUENT *e, void *p)
927 {
928 STREAMOUT *sop = (STREAMOUT *)e->data;
929
930 if (outfmt == 'a')
931 putc('\n', sop->ofp);
932 if (!waitflush)
933 fflush(sop->ofp);
934 if (ferror(sop->ofp)) {
935 sprintf(errmsg, "write error on file '%s'", e->key);
936 error(SYSTEM, errmsg);
937 }
938 return 0;
939 }
940
941 /* put out ray contribution to file */
942 void
943 put_contrib(const DCOLOR cnt, FILE *fout)
944 {
945 float fv[3];
946 COLR cv;
947
948 switch (outfmt) {
949 case 'a':
950 fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
951 break;
952 case 'f':
953 copycolor(fv, cnt);
954 fwrite(fv, sizeof(float), 3, fout);
955 break;
956 case 'd':
957 fwrite(cnt, sizeof(double), 3, fout);
958 break;
959 case 'c':
960 setcolr(cv, cnt[0], cnt[1], cnt[2]);
961 fwrite(cv, sizeof(cv), 1, fout);
962 break;
963 default:
964 error(INTERNAL, "botched output format");
965 }
966 }
967
968 /* output ray tallies and clear for next accumulation */
969 void
970 done_contrib(int navg)
971 {
972 double sf = 1.;
973 int i, j;
974 MODCONT *mp;
975 STREAMOUT *sop;
976 /* set average scaling */
977 if (navg > 1)
978 sf = 1. / (double)navg;
979 /* output modifiers in order */
980 for (i = 0; i < nmods; i++) {
981 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
982 if (navg > 1) /* average scaling */
983 for (j = mp->nbins; j--; )
984 scalecolor(mp->cbin[j], sf);
985 sop = getostream(mp->outspec, mp->modname, 0,0);
986 put_contrib(mp->cbin[0], sop->ofp);
987 if (mp->nbins > 3 && /* minor optimization */
988 sop == getostream(mp->outspec, mp->modname, 1,0))
989 for (j = 1; j < mp->nbins; j++)
990 put_contrib(mp->cbin[j], sop->ofp);
991 else
992 for (j = 1; j < mp->nbins; j++)
993 put_contrib(mp->cbin[j],
994 getostream(mp->outspec,mp->modname,j,0)->ofp);
995 /* clear for next time */
996 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
997 }
998 --waitflush; /* terminate records */
999 lu_doall(&ofiletab, puteol, NULL);
1000 if (using_stdout & (outfmt == 'a'))
1001 putc('\n', stdout);
1002 if (!waitflush) {
1003 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
1004 if (using_stdout)
1005 fflush(stdout);
1006 }
1007 }
1008
1009 /* queue completed ray tree produced by rtrace process */
1010 void
1011 queue_raytree(struct rtproc *rtp)
1012 {
1013 struct rtproc *rtu, *rtl = NULL;
1014 /* insert following ray order */
1015 for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
1016 if (rtp->raynum < rtu->raynum)
1017 break;
1018 rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
1019 if (rtu == NULL)
1020 error(SYSTEM, "out of memory in queue_raytree");
1021 *rtu = *rtp;
1022 if (rtl == NULL) {
1023 rtu->next = rt_unproc;
1024 rt_unproc = rtu;
1025 } else {
1026 rtu->next = rtl->next;
1027 rtl->next = rtu;
1028 }
1029 rtp->raynum = 0; /* clear path for next ray tree */
1030 rtp->bsiz = 0;
1031 rtp->buf = NULL;
1032 rtp->nbr = 0;
1033 }
1034
1035 /* process completed ray trees from our queue */
1036 void
1037 process_queue(void)
1038 {
1039 char modname[128];
1040 /* ray-ordered queue */
1041 while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
1042 struct rtproc *rtp = rt_unproc;
1043 int n = rtp->nbr;
1044 const char *cp = rtp->buf;
1045 while (n > 0) { /* process rays */
1046 register char *mnp = modname;
1047 /* skip leading tabs */
1048 while (n > 0 && *cp == '\t') {
1049 cp++; n--;
1050 }
1051 if (!n || !(isalpha(*cp) | (*cp == '_')))
1052 error(USER, "bad modifier name from rtrace");
1053 /* get modifier name */
1054 while (n > 1 && *cp != '\t') {
1055 if (mnp - modname >= sizeof(modname)-2)
1056 error(INTERNAL, "modifier name too long");
1057 *mnp++ = *cp++; n--;
1058 }
1059 *mnp = '\0';
1060 cp++; n--; /* eat following tab */
1061 if (n < (int)(sizeof(float)*9))
1062 error(USER, "incomplete ray value from rtrace");
1063 /* add ray contribution */
1064 memcpy(rparams, cp, sizeof(float)*9);
1065 cp += sizeof(float)*9; n -= sizeof(float)*9;
1066 add_contrib(modname);
1067 }
1068 /* time to produce record? */
1069 if (account > 0 && !--account)
1070 done_contrib(account = accumulate);
1071 lastdone = rtp->raynum;
1072 if (rtp->buf != NULL) /* free up buffer space */
1073 free(rtp->buf);
1074 rt_unproc = rtp->next;
1075 free(rtp); /* done with this ray tree */
1076 }
1077 }
1078
1079 /* wait for rtrace process to finish with ray tree */
1080 struct rtproc *
1081 wait_rproc(void)
1082 {
1083 struct rtproc *rtfree = NULL;
1084 fd_set readset, errset;
1085 ssize_t nr;
1086 struct rtproc *rt;
1087 int n;
1088
1089 do {
1090 nr = 0; /* prepare select call */
1091 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
1092 for (rt = &rt0; rt != NULL; rt = rt->next) {
1093 if (rt->raynum) {
1094 FD_SET(rt->pd.r, &readset);
1095 ++nr;
1096 }
1097 FD_SET(rt->pd.r, &errset);
1098 if (rt->pd.r >= n)
1099 n = rt->pd.r + 1;
1100 }
1101 if (!nr) /* no rays pending */
1102 break;
1103 if (nr > 1) { /* call select for multiple proc's */
1104 errno = 0;
1105 if (select(n, &readset, NULL, &errset, NULL) < 0)
1106 error(SYSTEM, "select call error in wait_rproc()");
1107 } else
1108 FD_ZERO(&errset);
1109 nr = 0;
1110 for (rt = &rt0; rt != NULL; rt = rt->next) {
1111 if (!FD_ISSET(rt->pd.r, &readset) &&
1112 !FD_ISSET(rt->pd.r, &errset))
1113 continue;
1114 if (rt->buf == NULL) {
1115 rt->bsiz = treebufsiz;
1116 rt->buf = (char *)malloc(rt->bsiz);
1117 } else if (rt->nbr + BUFSIZ > rt->bsiz) {
1118 if (rt->bsiz + BUFSIZ <= treebufsiz)
1119 rt->bsiz = treebufsiz;
1120 else
1121 treebufsiz = rt->bsiz += BUFSIZ;
1122 rt->buf = (char *)realloc(rt->buf, rt->bsiz);
1123 }
1124 if (rt->buf == NULL)
1125 error(SYSTEM, "out of memory in wait_rproc");
1126 nr = read(rt->pd.r, rt->buf+rt->nbr, rt->bsiz-rt->nbr);
1127 if (nr <= 0)
1128 error(USER, "rtrace process died");
1129 rt->nbr += nr; /* advance & check */
1130 if (rt->nbr >= 6 && !memcmp(rt->buf+rt->nbr-6,
1131 "~\t~\t~\t", 6)) {
1132 rt->nbr -= 6; /* elide terminator */
1133 queue_raytree(rt);
1134 rtfree = rt; /* ready for next ray */
1135 }
1136 }
1137 } while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
1138 return rtfree;
1139 }
1140
1141 /* return next available rtrace process */
1142 struct rtproc *
1143 get_rproc(void)
1144 {
1145 struct rtproc *rtp;
1146 /* check for idle rtrace */
1147 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
1148 if (!rtp->raynum)
1149 return rtp;
1150 return wait_rproc(); /* need to wait for one */
1151 }
1152
1153 /* trace ray contributions (main loop) */
1154 void
1155 trace_contribs(FILE *fin)
1156 {
1157 static int ignore_warning_given = 0;
1158 char inpbuf[128];
1159 int iblen;
1160 struct rtproc *rtp;
1161 /* loop over input */
1162 while ((iblen = getinp(inpbuf, fin)) >= 0) {
1163 if (!iblen && accumulate != 1) {
1164 if (!ignore_warning_given++)
1165 error(WARNING,
1166 "dummy ray(s) ignored during accumulation\n");
1167 continue;
1168 }
1169 if (!iblen || /* need flush/reset? */
1170 queue_length() > 10*nrtprocs() ||
1171 lastray+1 < lastray) {
1172 while (wait_rproc() != NULL)
1173 process_queue();
1174 lastdone = lastray = 0;
1175 }
1176 rtp = get_rproc(); /* get avail. rtrace process */
1177 rtp->raynum = ++lastray; /* assign ray */
1178 if (iblen) { /* trace ray if valid */
1179 writebuf(rtp->pd.w, inpbuf, iblen);
1180 } else { /* else bypass dummy ray */
1181 queue_raytree(rtp); /* queue empty ray/record */
1182 if ((yres <= 0) | (xres <= 0))
1183 waitflush = 1; /* flush right after */
1184 }
1185 process_queue(); /* catch up with results */
1186 if (raysleft && !--raysleft)
1187 break; /* preemptive EOI */
1188 }
1189 while (wait_rproc() != NULL) /* process outstanding rays */
1190 process_queue();
1191 if (accumulate <= 0)
1192 done_contrib(0); /* output tallies */
1193 else if (account < accumulate) {
1194 error(WARNING, "partial accumulation in final record");
1195 done_contrib(accumulate - account);
1196 }
1197 if (raysleft)
1198 error(USER, "unexpected EOF on input");
1199 lu_done(&ofiletab); /* close output files */
1200 }
1201
1202 /* get ray contribution from previous file */
1203 static int
1204 get_contrib(DCOLOR cnt, FILE *finp)
1205 {
1206 COLOR fv;
1207 COLR cv;
1208
1209 switch (outfmt) {
1210 case 'a':
1211 return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3);
1212 case 'f':
1213 if (fread(fv, sizeof(fv[0]), 3, finp) != 3)
1214 return(0);
1215 copycolor(cnt, fv);
1216 return(1);
1217 case 'd':
1218 return(fread(cnt, sizeof(cnt[0]), 3, finp) == 3);
1219 case 'c':
1220 if (fread(cv, sizeof(cv), 1, finp) != 1)
1221 return(0);
1222 colr_color(fv, cv);
1223 copycolor(cnt, fv);
1224 return(1);
1225 default:
1226 error(INTERNAL, "botched output format");
1227 }
1228 return(0); /* pro forma return */
1229 }
1230
1231 /* close output file opened for input */
1232 static int
1233 myclose(const LUENT *e, void *p)
1234 {
1235 STREAMOUT *sop = (STREAMOUT *)e->data;
1236
1237 if (sop->ofp == NULL)
1238 return(0);
1239 fclose(sop->ofp);
1240 sop->ofp = NULL;
1241 return(0);
1242 }
1243
1244 /* load previously accumulated values */
1245 void
1246 reload_output(void)
1247 {
1248 int i, j;
1249 MODCONT *mp;
1250 int ofl;
1251 char oname[1024];
1252 char *fmode = "rb";
1253 char *outvfmt;
1254 LUENT *ment, *oent;
1255 int xr, yr;
1256 STREAMOUT sout;
1257 DCOLOR rgbv;
1258
1259 switch (outfmt) {
1260 case 'a':
1261 outvfmt = "ascii";
1262 fmode = "r";
1263 break;
1264 case 'f':
1265 outvfmt = "float";
1266 break;
1267 case 'd':
1268 outvfmt = "double";
1269 break;
1270 case 'c':
1271 outvfmt = COLRFMT;
1272 break;
1273 default:
1274 error(INTERNAL, "botched output format");
1275 return;
1276 }
1277 /* reload modifier values */
1278 for (i = 0; i < nmods; i++) {
1279 ment = lu_find(&modconttab,modname[i]);
1280 mp = (MODCONT *)ment->data;
1281 if (mp->outspec == NULL)
1282 error(USER, "cannot reload from stdout");
1283 if (mp->outspec[0] == '!')
1284 error(USER, "cannot reload from command");
1285 for (j = 0; ; j++) { /* load each modifier bin */
1286 ofl = ofname(oname, mp->outspec, mp->modname, j);
1287 if (ofl < 0)
1288 error(USER, "bad output file specification");
1289 oent = lu_find(&ofiletab, oname);
1290 if (oent->data != NULL) {
1291 sout = *(STREAMOUT *)oent->data;
1292 } else {
1293 sout.reclen = 0;
1294 sout.outpipe = 0;
1295 sout.xr = xres; sout.yr = yres;
1296 sout.ofp = NULL;
1297 }
1298 if (sout.ofp == NULL) { /* open output as input */
1299 sout.ofp = fopen(oname, fmode);
1300 if (sout.ofp == NULL) {
1301 if (j)
1302 break; /* assume end of modifier */
1303 sprintf(errmsg, "missing reload file '%s'",
1304 oname);
1305 error(WARNING, errmsg);
1306 break;
1307 }
1308 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1309 sprintf(errmsg, "format mismatch for '%s'",
1310 oname);
1311 error(USER, errmsg);
1312 }
1313 if ((sout.xr > 0) & (sout.yr > 0) &&
1314 (!fscnresolu(&xr, &yr, sout.ofp) ||
1315 (xr != sout.xr) |
1316 (yr != sout.yr))) {
1317 sprintf(errmsg, "resolution mismatch for '%s'",
1318 oname);
1319 error(USER, errmsg);
1320 }
1321 }
1322 /* read in RGB value */
1323 if (!get_contrib(rgbv, sout.ofp)) {
1324 if (!j) {
1325 fclose(sout.ofp);
1326 break; /* ignore empty file */
1327 }
1328 if (j < mp->nbins) {
1329 sprintf(errmsg, "missing data in '%s'",
1330 oname);
1331 error(USER, errmsg);
1332 }
1333 break;
1334 }
1335 if (j >= mp->nbins) /* grow modifier size */
1336 ment->data = (char *)(mp = growmodifier(mp, j+1));
1337 copycolor(mp->cbin[j], rgbv);
1338 if (oent->key == NULL) /* new file entry */
1339 oent->key = strcpy((char *)
1340 malloc(strlen(oname)+1), oname);
1341 if (oent->data == NULL)
1342 oent->data = (char *)malloc(sizeof(STREAMOUT));
1343 *(STREAMOUT *)oent->data = sout;
1344 }
1345 }
1346 lu_doall(&ofiletab, myclose, NULL); /* close all files */
1347 }
1348
1349 /* seek on the given output file */
1350 static int
1351 myseeko(const LUENT *e, void *p)
1352 {
1353 STREAMOUT *sop = (STREAMOUT *)e->data;
1354 off_t nbytes = *(off_t *)p;
1355
1356 if (sop->reclen > 1)
1357 nbytes = nbytes * sop->reclen;
1358 if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) {
1359 sprintf(errmsg, "seek error on file '%s'", e->key);
1360 error(SYSTEM, errmsg);
1361 }
1362 return 0;
1363 }
1364
1365 /* recover output if possible */
1366 void
1367 recover_output(FILE *fin)
1368 {
1369 off_t lastout = -1;
1370 int outvsiz, recsiz;
1371 char *outvfmt;
1372 int i, j;
1373 MODCONT *mp;
1374 int ofl;
1375 char oname[1024];
1376 LUENT *ment, *oent;
1377 STREAMOUT sout;
1378 off_t nvals;
1379 int xr, yr;
1380
1381 switch (outfmt) {
1382 case 'a':
1383 error(USER, "cannot recover ASCII output");
1384 return;
1385 case 'f':
1386 outvsiz = sizeof(float)*3;
1387 outvfmt = "float";
1388 break;
1389 case 'd':
1390 outvsiz = sizeof(double)*3;
1391 outvfmt = "double";
1392 break;
1393 case 'c':
1394 outvsiz = sizeof(COLR);
1395 outvfmt = COLRFMT;
1396 break;
1397 default:
1398 error(INTERNAL, "botched output format");
1399 return;
1400 }
1401 /* check modifier outputs */
1402 for (i = 0; i < nmods; i++) {
1403 ment = lu_find(&modconttab,modname[i]);
1404 mp = (MODCONT *)ment->data;
1405 if (mp->outspec == NULL)
1406 error(USER, "cannot recover from stdout");
1407 if (mp->outspec[0] == '!')
1408 error(USER, "cannot recover from command");
1409 for (j = 0; ; j++) { /* check each bin's file */
1410 ofl = ofname(oname, mp->outspec, mp->modname, j);
1411 if (ofl < 0)
1412 error(USER, "bad output file specification");
1413 oent = lu_find(&ofiletab, oname);
1414 if (oent->data != NULL) {
1415 sout = *(STREAMOUT *)oent->data;
1416 } else {
1417 sout.reclen = 0;
1418 sout.outpipe = 0;
1419 sout.ofp = NULL;
1420 }
1421 if (sout.ofp != NULL) { /* already open? */
1422 if (ofl & OF_BIN)
1423 continue;
1424 break;
1425 }
1426 /* open output */
1427 sout.ofp = fopen(oname, "rb+");
1428 if (sout.ofp == NULL) {
1429 if (j)
1430 break; /* assume end of modifier */
1431 sprintf(errmsg, "missing recover file '%s'",
1432 oname);
1433 error(WARNING, errmsg);
1434 break;
1435 }
1436 nvals = lseek(fileno(sout.ofp), 0, SEEK_END);
1437 if (nvals <= 0) {
1438 lastout = 0; /* empty output, quit here */
1439 fclose(sout.ofp);
1440 break;
1441 }
1442 if (!sout.reclen) {
1443 if (!(ofl & OF_BIN)) {
1444 sprintf(errmsg,
1445 "need -bn to recover file '%s'",
1446 oname);
1447 error(USER, errmsg);
1448 }
1449 recsiz = outvsiz;
1450 } else
1451 recsiz = outvsiz * sout.reclen;
1452
1453 lseek(fileno(sout.ofp), 0, SEEK_SET);
1454 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1455 sprintf(errmsg, "format mismatch for '%s'",
1456 oname);
1457 error(USER, errmsg);
1458 }
1459 sout.xr = xres; sout.yr = yres;
1460 if ((sout.xr > 0) & (sout.yr > 0) &&
1461 (!fscnresolu(&xr, &yr, sout.ofp) ||
1462 (xr != sout.xr) |
1463 (yr != sout.yr))) {
1464 sprintf(errmsg, "resolution mismatch for '%s'",
1465 oname);
1466 error(USER, errmsg);
1467 }
1468 nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz;
1469 if ((lastout < 0) | (nvals < lastout))
1470 lastout = nvals;
1471 if (oent->key == NULL) /* new entry */
1472 oent->key = strcpy((char *)
1473 malloc(strlen(oname)+1), oname);
1474 if (oent->data == NULL)
1475 oent->data = (char *)malloc(sizeof(STREAMOUT));
1476 *(STREAMOUT *)oent->data = sout;
1477 if (!(ofl & OF_BIN))
1478 break; /* no bin separation */
1479 }
1480 if (!lastout) { /* empty output */
1481 error(WARNING, "no previous data to recover");
1482 lu_done(&ofiletab); /* reclose all outputs */
1483 return;
1484 }
1485 if (j > mp->nbins) /* reallocate modifier bins */
1486 ment->data = (char *)(mp = growmodifier(mp, j));
1487 }
1488 if (lastout < 0) {
1489 error(WARNING, "no output files to recover");
1490 return;
1491 }
1492 if (raysleft && lastout >= raysleft/accumulate) {
1493 error(WARNING, "output appears to be complete");
1494 /* XXX should read & discard input? */
1495 quit(0);
1496 }
1497 /* seek on all files */
1498 nvals = lastout * outvsiz;
1499 lu_doall(&ofiletab, myseeko, &nvals);
1500 /* skip repeated input */
1501 for (nvals = 0; nvals < lastout; nvals++)
1502 if (getinp(oname, fin) < 0)
1503 error(USER, "unexpected EOF on input");
1504 lastray = lastdone = (unsigned long)lastout * accumulate;
1505 if (raysleft)
1506 raysleft -= lastray;
1507 }
