root/radiance/ray/src/util/rtcontrib.c
Revision: 1.65
Committed: Wed Oct 5 17:20:55 2011 UTC (12 years, 8 months ago) by greg
Changes since 1.64: +5 -1 lines
Windows compatibility changes from Bill Hoffman
2 static const char RCSid[] = "$Id: rtcontrib.c,v 1.64 2011/04/16 00:39:07 greg Exp $";
5 * Gather rtrace output to compute contributions from particular sources
6 */
7
8 #include "standard.h"
9 #include <ctype.h>
10 #include <signal.h>
11 #include "platform.h"
12 #include "rtprocess.h"
13 #include "selcall.h"
14 #include "color.h"
15 #include "resolu.h"
16 #include "lookup.h"
17 #include "calcomp.h"
18
19 #ifdef _WIN32
20 typedef long ssize_t;
21 #endif
22
23 #ifndef MAXMODLIST
24 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
25 #endif
26
27 ssize_t treebufsiz = BUFSIZ; /* current tree buffer size */
28
29 typedef double DCOLOR[3]; /* double-precision color */
30
31 /*
32 * The MODCONT structure is used to accumulate ray contributions
33 * for a particular modifier, which may be subdivided into bins
34 * if binv evaluates > 0. If outspec contains a %s in it, this will
35 * be replaced with the modifier name. If outspec contains a %d in it,
36 * this will be used to create one output file per bin, otherwise all bins
37 * will be written to the same file, in order. If the global outfmt
38 * is 'c', then a 4-byte RGBE pixel will be output for each bin value
39 * and the file will conform to a RADIANCE image if xres & yres are set.
40 */
41 typedef struct {
42 const char *outspec; /* output file specification */
43 const char *modname; /* modifier name */
44 EPNODE *binv; /* bin value expression */
45 int nbins; /* number of accumulation bins */
46 DCOLOR cbin[1]; /* contribution bins (extends struct) */
47 } MODCONT; /* modifier contribution */
48
49 static void mcfree(void *p) { epfree((*(MODCONT *)p).binv); free(p); }
50
51 LUTAB modconttab = LU_SINIT(NULL,mcfree); /* modifier lookup table */
52
53 /*
54 * The STREAMOUT structure holds an open FILE pointer and a count of
55 * the number of RGB triplets per record, or 0 if unknown.
56 */
57 typedef struct {
58 FILE *ofp; /* output file pointer */
59 int outpipe; /* output is to a pipe */
60 int reclen; /* triplets/record */
61 int xr, yr; /* output resolution for picture */
62 } STREAMOUT;
63
64 /* close output stream and free record */
65 static void
66 closestream(void *p)
67 {
68 STREAMOUT *sop = (STREAMOUT *)p;
69 int status;
70 if (sop->outpipe)
71 status = pclose(sop->ofp);
72 else
73 status = fclose(sop->ofp);
74 if (status)
75 error(SYSTEM, "error closing output stream");
76 free(p);
77 }
78
79 LUTAB ofiletab = LU_SINIT(free,closestream); /* output file table */
80
81 #define OF_MODIFIER 01
82 #define OF_BIN 02
83
84 STREAMOUT *getostream(const char *ospec, const char *mname, int bn, int noopen);
85 int ofname(char *oname, const char *ospec, const char *mname, int bn);
86 void printheader(FILE *fout, const char *info);
87 void printresolu(FILE *fout, int xr, int yr);
88
89 /*
90 * The rcont structure is used to manage i/o with a particular
91 * rtrace child process. Input is passed unchanged from stdin,
92 * and output is processed in input order and accumulated according
93 * to the corresponding modifier and bin number.
94 */
95 struct rtproc {
96 struct rtproc *next; /* next in list of processes */
97 SUBPROC pd; /* rtrace pipe descriptors */
98 unsigned long raynum; /* ray number for this tree */
99 size_t bsiz; /* ray tree buffer length */
100 char *buf; /* ray tree buffer */
101 size_t nbr; /* number of bytes from rtrace */
102 }; /* rtrace process buffer */
103
104 /* rtrace command and defaults */
105 char *rtargv[256+2*MAXMODLIST] = { "rtrace",
106 "-dj", ".9", "-dr", "3",
107 "-ab", "1", "-ad", "350", };
108
109 int rtargc = 9;
110 /* overriding rtrace options */
111 char *myrtopts[] = { "-h-", "-x", "1", "-y", "0",
112 "-dt", "0", "-as", "0", "-aa", "0", NULL };
113
114 #define RTCOEFF "-o~~~TmWdp" /* compute coefficients only */
115 #define RTCONTRIB "-o~~~TmVdp" /* compute ray contributions */
116
117 struct rtproc rt0; /* head of rtrace process list */
118
119 struct rtproc *rt_unproc = NULL; /* unprocessed ray trees */
120
121 #define PERSIST_NONE 0 /* no persist file */
122 #define PERSIST_SINGLE 1 /* user set -P persist */
123 #define PERSIST_PARALL 2 /* user set -PP persist */
124 #define PERSIST_OURS 3 /* -PP persist belongs to us */
125 int persist_state = PERSIST_NONE; /* persist file state */
126 char persistfn[] = "pfXXXXXX"; /* our persist file name, if set */
127
128 int gargc; /* global argc */
129 char **gargv; /* global argv */
130 #define progname gargv[0]
131
132 char *octree; /* global octree argument */
133
134 int inpfmt = 'a'; /* input format */
135 int outfmt = 'a'; /* output format */
136
137 int header = 1; /* output header? */
138 int force_open = 0; /* truncate existing output? */
139 int recover = 0; /* recover previous output? */
140 int accumulate = 1; /* input rays per output record */
141 int xres = 0; /* horiz. output resolution */
142 int yres = 0; /* vert. output resolution */
143
144 int account; /* current accumulation count */
145 unsigned long raysleft; /* number of rays left to trace */
146 long waitflush; /* how long until next flush */
147
148 unsigned long lastray = 0; /* last ray number sent */
149 unsigned long lastdone = 0; /* last ray processed */
150
151 int using_stdout = 0; /* are we using stdout? */
152
153 const char *modname[MAXMODLIST]; /* ordered modifier name list */
154 int nmods = 0; /* number of modifiers */
155
156 #define queue_length() (lastray - lastdone)
157
158 MODCONT *growmodifier(MODCONT *mp, int nb);
159 MODCONT *addmodifier(char *modn, char *outf, char *binv, int bincnt);
160 void addmodfile(char *fname, char *outf, char *binv, int bincnt);
161
162 void init(int np);
163 int done_rprocs(struct rtproc *rtp);
164 void reload_output(void);
165 void recover_output(FILE *fin);
166 void trace_contribs(FILE *fin);
167 struct rtproc *wait_rproc(void);
168 struct rtproc *get_rproc(void);
169 void queue_raytree(struct rtproc *rtp);
170 void process_queue(void);
171
172 void put_contrib(const DCOLOR cnt, FILE *fout);
173 void add_contrib(const char *modn);
174 void done_contrib(int navg);
175
176 /* return number of open rtrace processes */
177 static int
178 nrtprocs(void)
179 {
180 int nrtp = 0;
181 struct rtproc *rtp;
182
183 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
184 nrtp += rtp->pd.running;
185 return(nrtp);
186 }
187
188 /* set input/output format */
189 static void
190 setformat(const char *fmt)
191 {
192 switch (fmt[0]) {
193 case 'f':
194 case 'd':
195 SET_FILE_BINARY(stdin);
196 /* fall through */
197 case 'a':
198 inpfmt = fmt[0];
199 break;
200 default:
201 goto fmterr;
202 }
203 switch (fmt[1]) {
204 case '\0':
205 outfmt = inpfmt;
206 return;
207 case 'a':
208 case 'f':
209 case 'd':
210 case 'c':
211 outfmt = fmt[1];
212 break;
213 default:
214 goto fmterr;
215 }
216 if (!fmt[2])
217 return;
218 fmterr:
219 sprintf(errmsg, "Illegal i/o format: -f%s", fmt);
220 error(USER, errmsg);
221 }
222
223 /* gather rays from rtrace and output contributions */
224 int
225 main(int argc, char *argv[])
226 {
227 int contrib = 0;
228 int nprocs = 1;
229 char *curout = NULL;
230 char *binval = NULL;
231 int bincnt = 0;
232 char fmt[8];
233 int i, j;
234 /* need at least one argument */
235 if (argc < 2) {
236 fprintf(stderr,
237 "Usage: %s [-n nprocs][-V][-r][-e expr][-f source][-o ospec][-b binv] {-m mod | -M file} [rtrace options] octree\n",
238 argv[0]);
239 exit(1);
240 }
241 /* global program name */
242 gargv = argv;
243 /* initialize calcomp routines */
244 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
245 esupport &= ~(E_OUTCHAN);
246 varset("PI", ':', PI);
247 /* get our options */
248 for (i = 1; i < argc-1; i++) {
249 /* expand arguments */
250 while ((j = expandarg(&argc, &argv, i)) > 0)
251 ;
252 if (j < 0) {
253 fprintf(stderr, "%s: cannot expand '%s'\n",
254 argv[0], argv[i]);
255 exit(1);
256 }
257 if (argv[i][0] == '-')
258 switch (argv[i][1]) {
259 case 'n': /* number of processes */
260 if (argv[i][2] || i >= argc-2) break;
261 nprocs = atoi(argv[++i]);
262 if (nprocs <= 0)
263 error(USER, "illegal number of processes");
264 continue;
265 case 'V': /* output contributions */
266 switch (argv[i][2]) {
267 case '\0':
268 contrib = !contrib;
269 continue;
270 case '+': case '1':
271 case 'T': case 't':
272 case 'Y': case 'y':
273 contrib = 1;
274 continue;
275 case '-': case '0':
276 case 'F': case 'f':
277 case 'N': case 'n':
278 contrib = 0;
279 continue;
280 }
281 break;
282 case 'c': /* input rays per output */
283 if (argv[i][2] || i >= argc-2) break;
284 accumulate = atoi(argv[++i]);
285 continue;
286 case 'r': /* recover output */
287 if (argv[i][2]) break;
288 recover = 1;
289 continue;
290 case 'h': /* output header? */
291 switch (argv[i][2]) {
292 case '\0':
293 header = !header;
294 continue;
295 case '+': case '1':
296 case 'T': case 't':
297 case 'Y': case 'y':
298 header = 1;
299 continue;
300 case '-': case '0':
301 case 'F': case 'f':
302 case 'N': case 'n':
303 header = 0;
304 continue;
305 }
306 break;
307 case 'f': /* file or force or format */
308 if (!argv[i][2]) {
309 char *fpath;
310 if (i >= argc-2) break;
311 fpath = getpath(argv[++i],
312 getrlibpath(), R_OK);
313 if (fpath == NULL) {
314 sprintf(errmsg,
315 "cannot find file '%s'",
316 argv[i]);
317 error(USER, errmsg);
318 }
319 fcompile(fpath);
320 continue;
321 }
322 if (argv[i][2] == 'o') {
323 force_open = 1;
324 continue;
325 }
326 setformat(argv[i]+2);
327 continue;
328 case 'e': /* expression */
329 if (argv[i][2] || i >= argc-2) break;
330 scompile(argv[++i], NULL, 0);
331 continue;
332 case 'o': /* output file spec. */
333 if (argv[i][2] || i >= argc-2) break;
334 curout = argv[++i];
335 continue;
336 case 'x': /* horiz. output resolution */
337 if (argv[i][2] || i >= argc-2) break;
338 xres = atoi(argv[++i]);
339 continue;
340 case 'y': /* vert. output resolution */
341 if (argv[i][2] || i >= argc-2) break;
342 yres = atoi(argv[++i]);
343 continue;
344 case 'b': /* bin expression/count */
345 if (i >= argc-2) break;
346 if (argv[i][2] == 'n') {
347 bincnt = (int)(eval(argv[++i]) + .5);
348 continue;
349 }
350 if (argv[i][2]) break;
351 binval = argv[++i];
352 continue;
353 case 'm': /* modifier name */
354 if (argv[i][2] || i >= argc-2) break;
355 rtargv[rtargc++] = "-ti";
356 rtargv[rtargc++] = argv[++i];
357 addmodifier(argv[i], curout, binval, bincnt);
358 continue;
359 case 'M': /* modifier file */
360 if (argv[i][2] || i >= argc-2) break;
361 rtargv[rtargc++] = "-tI";
362 rtargv[rtargc++] = argv[++i];
363 addmodfile(argv[i], curout, binval, bincnt);
364 continue;
365 case 'P': /* persist file */
366 if (i >= argc-2) break;
367 persist_state = (argv[i][2] == 'P') ?
368 PERSIST_PARALL : PERSIST_SINGLE;
369 rtargv[rtargc++] = argv[i];
370 rtargv[rtargc++] = argv[++i];
371 continue;
372 }
373 rtargv[rtargc++] = argv[i]; /* assume rtrace option */
374 }
375 if (accumulate <= 0) /* no output flushing for single record */
376 xres = yres = 0;
377 /* set global argument list */
378 gargc = argc; gargv = argv;
379 /* add "mandatory" rtrace settings */
380 for (j = 0; myrtopts[j] != NULL; j++)
381 rtargv[rtargc++] = myrtopts[j];
382 rtargv[rtargc++] = contrib ? RTCONTRIB : RTCOEFF;
383 /* just asking for defaults? */
384 if (!strcmp(argv[i], "-defaults")) {
385 char nps[8], sxres[16], syres[16];
386 char *rtpath;
387 printf("-c %-5d\t\t\t# accumulated rays per record\n",
388 accumulate);
389 printf("-V%c\t\t\t\t# output %s\n", contrib ? '+' : '-',
390 contrib ? "contributions" : "coefficients");
391 fflush(stdout); /* report OUR options */
392 rtargv[rtargc++] = "-n";
393 sprintf(nps, "%d", nprocs);
394 rtargv[rtargc++] = nps;
395 rtargv[rtargc++] = header ? "-h+" : "-h-";
396 sprintf(fmt, "-f%c%c", inpfmt, outfmt);
397 rtargv[rtargc++] = fmt;
398 rtargv[rtargc++] = "-x";
399 sprintf(sxres, "%d", xres);
400 rtargv[rtargc++] = sxres;
401 rtargv[rtargc++] = "-y";
402 sprintf(syres, "%d", yres);
403 rtargv[rtargc++] = syres;
404 rtargv[rtargc++] = "-defaults";
405 rtargv[rtargc] = NULL;
406 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
407 if (rtpath == NULL) {
408 eputs(rtargv[0]);
409 eputs(": command not found\n");
410 exit(1);
411 }
412 execv(rtpath, rtargv);
413 perror(rtpath); /* execv() should not return */
414 exit(1);
415 }
416 if (nprocs > 1) { /* add persist file if parallel */
417 if (persist_state == PERSIST_SINGLE)
418 error(USER, "use -PP option for multiple processes");
419 if (persist_state == PERSIST_NONE) {
420 rtargv[rtargc++] = "-PP";
421 rtargv[rtargc++] = mktemp(persistfn);
422 persist_state = PERSIST_OURS;
423 }
424 }
425 /* add format string */
426 sprintf(fmt, "-f%cf", inpfmt);
427 rtargv[rtargc++] = fmt;
428 /* octree argument is last */
429 if (i <= 0 || i != argc-1 || argv[i][0] == '-')
430 error(USER, "missing octree argument");
431 rtargv[rtargc++] = octree = argv[i];
432 rtargv[rtargc] = NULL;
433 /* start rtrace & recover if requested */
434 init(nprocs);
435 /* compute contributions */
436 trace_contribs(stdin);
437 /* clean up */
438 quit(0);
439 }
440
441 #ifndef SIGALRM
442 #define SIGALRM SIGTERM
443 #endif
444 /* kill persistent rtrace process */
445 static void
446 killpersist(void)
447 {
448 FILE *fp = fopen(persistfn, "r");
449 RT_PID pid;
450
451 if (fp == NULL)
452 return;
453 if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
454 unlink(persistfn);
455 fclose(fp);
456 }
457
458 /* close rtrace processes and clean up */
459 int
460 done_rprocs(struct rtproc *rtp)
461 {
462 int st0, st1 = 0;
463
464 if (rtp->next != NULL) { /* close last opened first! */
465 st1 = done_rprocs(rtp->next);
466 free((void *)rtp->next);
467 rtp->next = NULL;
468 }
469 st0 = close_process(&rtp->pd);
470 if (st0 < 0)
471 error(WARNING, "unknown return status from rtrace process");
472 else if (st0 > 0)
473 return(st0);
474 return(st1);
475 }
476
477 /* exit with status */
478 void
479 quit(int status)
480 {
481 int rtstat;
482
483 if (persist_state == PERSIST_OURS) /* terminate waiting rtrace */
484 killpersist();
485 /* clean up rtrace process(es) */
486 rtstat = done_rprocs(&rt0);
487 if (status == 0)
488 status = rtstat;
489 exit(status); /* flushes all output streams */
490 }
491
492 /* start rtrace processes and initialize */
493 void
494 init(int np)
495 {
496 struct rtproc *rtp;
497 int i;
498 int maxbytes;
499 /* make sure we have something to do */
500 if (!nmods)
501 error(USER, "No modifiers specified");
502 /* assign ray variables */
503 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
504 scompile("Px=$4;Py=$5;Pz=$6;", NULL, 0);
505 /* set up signal handling */
506 signal(SIGINT, quit);
507 #ifdef SIGHUP
508 signal(SIGHUP, quit);
509 #endif
510 #ifdef SIGTERM
511 signal(SIGTERM, quit);
512 #endif
513 #ifdef SIGPIPE
514 signal(SIGPIPE, quit);
515 #endif
516 rtp = &rt0; /* start rtrace process(es) */
517 for (i = 0; i++ < np; ) {
518 errno = 0;
519 maxbytes = open_process(&rtp->pd, rtargv);
520 if (maxbytes == 0) {
521 eputs(rtargv[0]);
522 eputs(": command not found\n");
523 exit(1);
524 }
525 if (maxbytes < 0)
526 error(SYSTEM, "cannot start rtrace process");
527 if (maxbytes > treebufsiz)
528 treebufsiz = maxbytes;
529 rtp->raynum = 0;
530 rtp->bsiz = 0;
531 rtp->buf = NULL;
532 rtp->nbr = 0;
533 if (i == np) /* last process? */
534 break;
535 if (i == 1)
536 sleep(2); /* wait for persist file */
537 rtp->next = (struct rtproc *)malloc(sizeof(struct rtproc));
538 if (rtp->next == NULL)
539 error(SYSTEM, "out of memory in init");
540 rtp = rtp->next;
541 }
542 rtp->next = NULL; /* terminate list */
543 if (yres > 0) {
544 if (xres > 0)
545 raysleft = (unsigned long)xres*yres;
546 else
547 raysleft = yres;
548 } else
549 raysleft = 0;
550 if ((account = accumulate) > 0)
551 raysleft *= accumulate;
552 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
553 if (!recover)
554 return;
555 /* recover previous values */
556 if (accumulate <= 0)
557 reload_output();
558 else
559 recover_output(stdin);
560 }
561
562 /* grow modifier to accommodate more bins */
563 MODCONT *
564 growmodifier(MODCONT *mp, int nb)
565 {
566 if (nb <= mp->nbins)
567 return mp;
568 mp = (MODCONT *)realloc(mp, sizeof(MODCONT) + sizeof(DCOLOR)*(nb-1));
569 if (mp == NULL)
570 error(SYSTEM, "out of memory in growmodifier");
571 memset(mp->cbin+mp->nbins, 0, sizeof(DCOLOR)*(nb-mp->nbins));
572 mp->nbins = nb;
573 return mp;
574 }
575
576 /* add modifier to our list to track */
577 MODCONT *
578 addmodifier(char *modn, char *outf, char *binv, int bincnt)
579 {
580 LUENT *lep = lu_find(&modconttab, modn);
581 MODCONT *mp;
582 int i;
583
584 if (lep->data != NULL) {
585 sprintf(errmsg, "duplicate modifier '%s'", modn);
586 error(USER, errmsg);
587 }
588 if (nmods >= MAXMODLIST)
589 error(INTERNAL, "too many modifiers");
590 modname[nmods++] = modn; /* XXX assumes static string */
591 lep->key = modn; /* XXX assumes static string */
592 mp = (MODCONT *)malloc(sizeof(MODCONT));
593 if (mp == NULL)
594 error(SYSTEM, "out of memory in addmodifier");
595 mp->outspec = outf; /* XXX assumes static string */
596 mp->modname = modn; /* XXX assumes static string */
597 if (binv == NULL)
598 binv = "0"; /* use single bin if unspecified */
599 mp->binv = eparse(binv);
600 if (mp->binv->type == NUM) { /* check value if constant */
601 bincnt = (int)(evalue(mp->binv) + 1.5);
602 if (bincnt != 1) {
603 sprintf(errmsg, "illegal non-zero constant for bin (%s)",
604 binv);
605 error(USER, errmsg);
606 }
607 }
608 mp->nbins = 1; /* initialize results holder */
609 setcolor(mp->cbin[0], 0., 0., 0.);
610 if (bincnt > 1)
611 mp = growmodifier(mp, bincnt);
612 lep->data = (char *)mp;
613 /* allocate output streams */
614 for (i = bincnt; i-- > 0; )
615 getostream(mp->outspec, mp->modname, i, 1);
616 return mp;
617 }
618
619 /* add modifiers from a file list */
620 void
621 addmodfile(char *fname, char *outf, char *binv, int bincnt)
622 {
623 char *mname[MAXMODLIST];
624 int i;
625 /* find the file & store strings */
626 if (wordfile(mname, getpath(fname, getrlibpath(), R_OK)) < 0) {
627 sprintf(errmsg, "cannot find modifier file '%s'", fname);
628 error(SYSTEM, errmsg);
629 }
630 for (i = 0; mname[i]; i++) /* add each one */
631 addmodifier(mname[i], outf, binv, bincnt);
632 }
633
634 /* put string to stderr */
635 void
636 eputs(char *s)
637 {
638 static int midline = 0;
639
640 if (!*s) return;
641 if (!midline) {
642 fputs(progname, stderr);
643 fputs(": ", stderr);
644 }
645 fputs(s, stderr);
646 midline = s[strlen(s)-1] != '\n';
647 }
648
649 /* construct output file name and return flags whether modifier/bin present */
650 int
651 ofname(char *oname, const char *ospec, const char *mname, int bn)
652 {
653 const char *mnp = NULL;
654 const char *bnp = NULL;
655 const char *cp;
656
657 if (ospec == NULL)
658 return -1;
659 for (cp = ospec; *cp; cp++) /* check format position(s) */
660 if (*cp == '%') {
661 do
662 ++cp;
663 while (isdigit(*cp));
664 switch (*cp) {
665 case '%':
666 break;
667 case 's':
668 if (mnp != NULL)
669 return -1;
670 mnp = cp;
671 break;
672 case 'd':
673 case 'i':
674 case 'o':
675 case 'x':
676 case 'X':
677 if (bnp != NULL)
678 return -1;
679 bnp = cp;
680 break;
681 default:
682 return -1;
683 }
684 }
685 if (mnp != NULL) { /* create file name */
686 if (bnp != NULL) {
687 if (bnp > mnp)
688 sprintf(oname, ospec, mname, bn);
689 else
690 sprintf(oname, ospec, bn, mname);
691 return OF_MODIFIER|OF_BIN;
692 }
693 sprintf(oname, ospec, mname);
694 return OF_MODIFIER;
695 }
696 if (bnp != NULL) {
697 sprintf(oname, ospec, bn);
698 return OF_BIN;
699 }
700 strcpy(oname, ospec);
701 return 0;
702 }
703
704 /* write header to the given output stream */
705 void
706 printheader(FILE *fout, const char *info)
707 {
708 extern char VersionID[];
709 /* copy octree header */
710 if (octree[0] == '!') {
711 newheader("RADIANCE", fout);
712 fputs(octree+1, fout);
713 if (octree[strlen(octree)-1] != '\n')
714 fputc('\n', fout);
715 } else {
716 FILE *fin = fopen(octree, "r");
717 if (fin == NULL)
718 quit(1);
719 checkheader(fin, "ignore", fout);
720 fclose(fin);
721 }
722 printargs(gargc-1, gargv, fout); /* add our command */
723 fprintf(fout, "SOFTWARE= %s\n", VersionID);
724 fputnow(fout);
725 if (info != NULL) /* add extra info if given */
726 fputs(info, fout);
727 switch (outfmt) { /* add output format */
728 case 'a':
729 fputformat("ascii", fout);
730 break;
731 case 'f':
732 fputformat("float", fout);
733 break;
734 case 'd':
735 fputformat("double", fout);
736 break;
737 case 'c':
738 fputformat(COLRFMT, fout);
739 break;
740 }
741 fputc('\n', fout);
742 }
743
744 /* write resolution string to given output stream */
745 void
746 printresolu(FILE *fout, int xr, int yr)
747 {
748 if ((xr > 0) & (yr > 0)) /* resolution string */
749 fprtresolu(xr, yr, fout);
750 }
751
752 /* Get output stream pointer (open and write header if new and noopen==0) */
753 STREAMOUT *
754 getostream(const char *ospec, const char *mname, int bn, int noopen)
755 {
756 static const DCOLOR nocontrib = BLKCOLOR;
757 static STREAMOUT stdos;
758 int ofl;
759 char oname[1024];
760 LUENT *lep;
761 STREAMOUT *sop;
762
763 if (ospec == NULL) { /* use stdout? */
764 if (!noopen && !using_stdout) {
765 if (outfmt != 'a')
766 SET_FILE_BINARY(stdout);
767 if (header)
768 printheader(stdout, NULL);
769 printresolu(stdout, xres, yres);
770 if (waitflush > 0)
771 fflush(stdout);
772 stdos.xr = xres; stdos.yr = yres;
773 using_stdout = 1;
774 }
775 stdos.ofp = stdout;
776 stdos.reclen += noopen;
777 return &stdos;
778 }
779 ofl = ofname(oname, ospec, mname, bn); /* get output name */
780 if (ofl < 0) {
781 sprintf(errmsg, "bad output format '%s'", ospec);
782 error(USER, errmsg);
783 }
784 lep = lu_find(&ofiletab, oname); /* look it up */
785 if (lep->key == NULL) /* new entry */
786 lep->key = strcpy((char *)malloc(strlen(oname)+1), oname);
787 sop = (STREAMOUT *)lep->data;
788 if (sop == NULL) { /* allocate stream */
789 sop = (STREAMOUT *)malloc(sizeof(STREAMOUT));
790 if (sop == NULL)
791 error(SYSTEM, "out of memory in getostream");
792 sop->outpipe = oname[0] == '!';
793 sop->reclen = 0;
794 sop->ofp = NULL; /* open iff noopen==0 */
795 sop->xr = xres; sop->yr = yres;
796 lep->data = (char *)sop;
797 if (!sop->outpipe & !force_open & !recover &&
798 access(oname, F_OK) == 0) {
799 errno = EEXIST; /* file exists */
800 goto openerr;
801 }
802 }
803 if (!noopen && sop->ofp == NULL) { /* open output stream */
804 long i;
805 if (oname[0] == '!') /* output to command */
806 sop->ofp = popen(oname+1, "w");
807 else /* else open file */
808 sop->ofp = fopen(oname, "w");
809 if (sop->ofp == NULL)
810 goto openerr;
811 if (outfmt != 'a')
812 SET_FILE_BINARY(sop->ofp);
813 if (header) {
814 char info[512];
815 char *cp = info;
816 if (ofl & OF_MODIFIER || sop->reclen == 1) {
817 sprintf(cp, "MODIFIER=%s\n", mname);
818 while (*cp) ++cp;
819 }
820 if (ofl & OF_BIN) {
821 sprintf(cp, "BIN=%d\n", bn);
822 while (*cp) ++cp;
823 }
824 *cp = '\0';
825 printheader(sop->ofp, info);
826 }
827 if (accumulate > 0) { /* global resolution */
828 sop->xr = xres; sop->yr = yres;
829 }
830 printresolu(sop->ofp, sop->xr, sop->yr);
831 /* play catch-up */
832 for (i = accumulate > 0 ? lastdone/accumulate : 0; i--; ) {
833 int j = sop->reclen;
834 if (j <= 0) j = 1;
835 while (j--)
836 put_contrib(nocontrib, sop->ofp);
837 if (outfmt == 'a')
838 putc('\n', sop->ofp);
839 }
840 if (waitflush > 0)
841 fflush(sop->ofp);
842 }
843 sop->reclen += noopen; /* add to length if noopen */
844 return sop; /* return output stream */
845 openerr:
846 sprintf(errmsg, "cannot open '%s' for writing", oname);
847 error(SYSTEM, errmsg);
848 return NULL; /* pro forma return */
849 }
850
851 /* read input ray into buffer */
852 int
853 getinp(char *buf, FILE *fp)
854 {
855 double dv[3], *dvp;
856 float *fvp;
857 char *cp;
858 int i;
859
860 switch (inpfmt) {
861 case 'a':
862 cp = buf; /* make sure we get 6 floats */
863 for (i = 0; i < 6; i++) {
864 if (fgetword(cp, buf+127-cp, fp) == NULL)
865 return -1;
866 if (i >= 3)
867 dv[i-3] = atof(cp);
868 if ((cp = fskip(cp)) == NULL || *cp)
869 return -1;
870 *cp++ = ' ';
871 }
872 getc(fp); /* get/put eol */
873 *cp-- = '\0'; *cp = '\n';
874 if (DOT(dv,dv) <= FTINY*FTINY)
875 return 0; /* dummy ray */
876 return strlen(buf);
877 case 'f':
878 if (fread(buf, sizeof(float), 6, fp) < 6)
879 return -1;
880 fvp = (float *)buf + 3;
881 if (DOT(fvp,fvp) <= FTINY*FTINY)
882 return 0; /* dummy ray */
883 return sizeof(float)*6;
884 case 'd':
885 if (fread(buf, sizeof(double), 6, fp) < 6)
886 return -1;
887 dvp = (double *)buf + 3;
888 if (DOT(dvp,dvp) <= FTINY*FTINY)
889 return 0; /* dummy ray */
890 return sizeof(double)*6;
891 }
892 error(INTERNAL, "botched input format");
893 return -1; /* pro forma return */
894 }
895
896 static float rparams[9]; /* traced ray parameters */
897
898 /* return channel (ray) value */
899 double
900 chanvalue(int n)
901 {
902 if (--n < 0 || n >= 6)
903 error(USER, "illegal channel number ($N)");
904 return rparams[n+3];
905 }
906
907 /* add current ray contribution to the appropriate modifier bin */
908 void
909 add_contrib(const char *modn)
910 {
911 LUENT *le = lu_find(&modconttab, modn);
912 MODCONT *mp = (MODCONT *)le->data;
913 int bn;
914
915 if (mp == NULL) {
916 sprintf(errmsg, "unexpected modifier '%s' from rtrace", modn);
917 error(USER, errmsg);
918 }
919 eclock++; /* get bin number */
920 bn = (int)(evalue(mp->binv) + .5);
921 if (bn <= 0)
922 bn = 0;
923 else if (bn >= mp->nbins) /* new bin */
924 le->data = (char *)(mp = growmodifier(mp, bn+1));
925 addcolor(mp->cbin[bn], rparams);
926 }
927
928 /* output newline to ASCII file and/or flush as requested */
929 static int
930 puteol(const LUENT *e, void *p)
931 {
932 STREAMOUT *sop = (STREAMOUT *)e->data;
933
934 if (outfmt == 'a')
935 putc('\n', sop->ofp);
936 if (!waitflush)
937 fflush(sop->ofp);
938 if (ferror(sop->ofp)) {
939 sprintf(errmsg, "write error on file '%s'", e->key);
940 error(SYSTEM, errmsg);
941 }
942 return 0;
943 }
944
945 /* put out ray contribution to file */
946 void
947 put_contrib(const DCOLOR cnt, FILE *fout)
948 {
949 float fv[3];
950 COLR cv;
951
952 switch (outfmt) {
953 case 'a':
954 fprintf(fout, "%.6e\t%.6e\t%.6e\t", cnt[0], cnt[1], cnt[2]);
955 break;
956 case 'f':
957 copycolor(fv, cnt);
958 fwrite(fv, sizeof(float), 3, fout);
959 break;
960 case 'd':
961 fwrite(cnt, sizeof(double), 3, fout);
962 break;
963 case 'c':
964 setcolr(cv, cnt[0], cnt[1], cnt[2]);
965 fwrite(cv, sizeof(cv), 1, fout);
966 break;
967 default:
968 error(INTERNAL, "botched output format");
969 }
970 }
971
972 /* output ray tallies and clear for next accumulation */
973 void
974 done_contrib(int navg)
975 {
976 double sf = 1.;
977 int i, j;
978 MODCONT *mp;
979 STREAMOUT *sop;
980 /* set average scaling */
981 if (navg > 1)
982 sf = 1. / (double)navg;
983 /* output modifiers in order */
984 for (i = 0; i < nmods; i++) {
985 mp = (MODCONT *)lu_find(&modconttab,modname[i])->data;
986 if (navg > 1) /* average scaling */
987 for (j = mp->nbins; j--; )
988 scalecolor(mp->cbin[j], sf);
989 sop = getostream(mp->outspec, mp->modname, 0,0);
990 put_contrib(mp->cbin[0], sop->ofp);
991 if (mp->nbins > 3 && /* minor optimization */
992 sop == getostream(mp->outspec, mp->modname, 1,0))
993 for (j = 1; j < mp->nbins; j++)
994 put_contrib(mp->cbin[j], sop->ofp);
995 else
996 for (j = 1; j < mp->nbins; j++)
997 put_contrib(mp->cbin[j],
998 getostream(mp->outspec,mp->modname,j,0)->ofp);
999 /* clear for next time */
1000 memset(mp->cbin, 0, sizeof(DCOLOR)*mp->nbins);
1001 }
1002 --waitflush; /* terminate records */
1003 lu_doall(&ofiletab, puteol, NULL);
1004 if (using_stdout & (outfmt == 'a'))
1005 putc('\n', stdout);
1006 if (!waitflush) {
1007 waitflush = (yres > 0) & (xres > 1) ? 0 : xres;
1008 if (using_stdout)
1009 fflush(stdout);
1010 }
1011 }
1012
1013 /* queue completed ray tree produced by rtrace process */
1014 void
1015 queue_raytree(struct rtproc *rtp)
1016 {
1017 struct rtproc *rtu, *rtl = NULL;
1018 /* insert following ray order */
1019 for (rtu = rt_unproc; rtu != NULL; rtu = (rtl=rtu)->next)
1020 if (rtp->raynum < rtu->raynum)
1021 break;
1022 rtu = (struct rtproc *)malloc(sizeof(struct rtproc));
1023 if (rtu == NULL)
1024 error(SYSTEM, "out of memory in queue_raytree");
1025 *rtu = *rtp;
1026 if (rtl == NULL) {
1027 rtu->next = rt_unproc;
1028 rt_unproc = rtu;
1029 } else {
1030 rtu->next = rtl->next;
1031 rtl->next = rtu;
1032 }
1033 rtp->raynum = 0; /* clear path for next ray tree */
1034 rtp->bsiz = 0;
1035 rtp->buf = NULL;
1036 rtp->nbr = 0;
1037 }
1038
1039 /* process completed ray trees from our queue */
1040 void
1041 process_queue(void)
1042 {
1043 char modname[128];
1044 /* ray-ordered queue */
1045 while (rt_unproc != NULL && rt_unproc->raynum == lastdone+1) {
1046 struct rtproc *rtp = rt_unproc;
1047 int n = rtp->nbr;
1048 const char *cp = rtp->buf;
1049 while (n > 0) { /* process rays */
1050 register char *mnp = modname;
1051 /* skip leading tabs */
1052 while (n > 0 && *cp == '\t') {
1053 cp++; n--;
1054 }
1055 if (!n || !(isalpha(*cp) | (*cp == '_')))
1056 error(USER, "bad modifier name from rtrace");
1057 /* get modifier name */
1058 while (n > 1 && *cp != '\t') {
1059 if (mnp - modname >= sizeof(modname)-2)
1060 error(INTERNAL, "modifier name too long");
1061 *mnp++ = *cp++; n--;
1062 }
1063 *mnp = '\0';
1064 cp++; n--; /* eat following tab */
1065 if (n < (int)(sizeof(float)*9))
1066 error(USER, "incomplete ray value from rtrace");
1067 /* add ray contribution */
1068 memcpy(rparams, cp, sizeof(float)*9);
1069 cp += sizeof(float)*9; n -= sizeof(float)*9;
1070 add_contrib(modname);
1071 }
1072 /* time to produce record? */
1073 if (account > 0 && !--account)
1074 done_contrib(account = accumulate);
1075 lastdone = rtp->raynum;
1076 if (rtp->buf != NULL) /* free up buffer space */
1077 free(rtp->buf);
1078 rt_unproc = rtp->next;
1079 free(rtp); /* done with this ray tree */
1080 }
1081 }
1082
1083 /* wait for rtrace process to finish with ray tree */
1084 struct rtproc *
1085 wait_rproc(void)
1086 {
1087 struct rtproc *rtfree = NULL;
1088 fd_set readset, errset;
1089 ssize_t nr;
1090 struct rtproc *rt;
1091 int n;
1092
1093 do {
1094 nr = 0; /* prepare select call */
1095 FD_ZERO(&readset); FD_ZERO(&errset); n = 0;
1096 for (rt = &rt0; rt != NULL; rt = rt->next) {
1097 if (rt->raynum) {
1098 FD_SET(rt->pd.r, &readset);
1099 ++nr;
1100 }
1101 FD_SET(rt->pd.r, &errset);
1102 if (rt->pd.r >= n)
1103 n = rt->pd.r + 1;
1104 }
1105 if (!nr) /* no rays pending */
1106 break;
1107 if (nr > 1) { /* call select for multiple proc's */
1108 errno = 0;
1109 if (select(n, &readset, NULL, &errset, NULL) < 0)
1110 error(SYSTEM, "select call error in wait_rproc()");
1111 } else
1112 FD_ZERO(&errset);
1113 nr = 0;
1114 for (rt = &rt0; rt != NULL; rt = rt->next) {
1115 if (!FD_ISSET(rt->pd.r, &readset) &&
1116 !FD_ISSET(rt->pd.r, &errset))
1117 continue;
1118 if (rt->buf == NULL) {
1119 rt->bsiz = treebufsiz;
1120 rt->buf = (char *)malloc(rt->bsiz);
1121 } else if (rt->nbr + BUFSIZ > rt->bsiz) {
1122 if (rt->bsiz + BUFSIZ <= treebufsiz)
1123 rt->bsiz = treebufsiz;
1124 else if ((treebufsiz = rt->bsiz += BUFSIZ) < 0)
1125 error(INTERNAL,
1126 "ray buffer does not fit memory");
1127 rt->buf = (char *)realloc(rt->buf, rt->bsiz);
1128 }
1129 if (rt->buf == NULL)
1130 error(SYSTEM, "out of memory in wait_rproc");
1131 nr = rt->bsiz - rt->nbr;
1132 if (nr & ~0x7fffffff) /* avoid 32-bit OS issues */
1133 nr = 0x7fffffff;
1134 nr = read(rt->pd.r, rt->buf+rt->nbr, nr);
1135 if (nr < 0)
1136 error(SYSTEM, "read error from rtrace");
1137 if (!nr)
1138 error(USER, "rtrace process died");
1139 rt->nbr += nr; /* advance & check */
1140 if (rt->nbr >= 6 && !memcmp(rt->buf+rt->nbr-6,
1141 "~\t~\t~\t", 6)) {
1142 rt->nbr -= 6; /* elide terminator */
1143 queue_raytree(rt);
1144 rtfree = rt; /* ready for next ray */
1145 }
1146 }
1147 } while ((rtfree == NULL) & (nr > 0)); /* repeat until ready or out */
1148 return rtfree;
1149 }
1150
1151 /* return next available rtrace process */
1152 struct rtproc *
1153 get_rproc(void)
1154 {
1155 struct rtproc *rtp;
1156 /* check for idle rtrace */
1157 for (rtp = &rt0; rtp != NULL; rtp = rtp->next)
1158 if (!rtp->raynum)
1159 return rtp;
1160 return wait_rproc(); /* need to wait for one */
1161 }
1162
1163 /* trace ray contributions (main loop) */
1164 void
1165 trace_contribs(FILE *fin)
1166 {
1167 static int ignore_warning_given = 0;
1168 char inpbuf[128];
1169 int iblen;
1170 struct rtproc *rtp;
1171 /* loop over input */
1172 while ((iblen = getinp(inpbuf, fin)) >= 0) {
1173 if (!iblen && accumulate != 1) {
1174 if (!ignore_warning_given++)
1175 error(WARNING,
1176 "dummy ray(s) ignored during accumulation\n");
1177 continue;
1178 }
1179 if (!iblen || /* need flush/reset? */
1180 queue_length() > 10*nrtprocs() ||
1181 lastray+1 < lastray) {
1182 while (wait_rproc() != NULL)
1183 process_queue();
1184 lastdone = lastray = 0;
1185 }
1186 rtp = get_rproc(); /* get avail. rtrace process */
1187 rtp->raynum = ++lastray; /* assign ray */
1188 if (iblen) { /* trace ray if valid */
1189 writebuf(rtp->pd.w, inpbuf, iblen);
1190 } else { /* else bypass dummy ray */
1191 queue_raytree(rtp); /* queue empty ray/record */
1192 if ((yres <= 0) | (xres <= 0))
1193 waitflush = 1; /* flush right after */
1194 }
1195 process_queue(); /* catch up with results */
1196 if (raysleft && !--raysleft)
1197 break; /* preemptive EOI */
1198 }
1199 while (wait_rproc() != NULL) /* process outstanding rays */
1200 process_queue();
1201 if (accumulate <= 0)
1202 done_contrib(0); /* output tallies */
1203 else if (account < accumulate) {
1204 error(WARNING, "partial accumulation in final record");
1205 done_contrib(accumulate - account);
1206 }
1207 if (raysleft)
1208 error(USER, "unexpected EOF on input");
1209 lu_done(&ofiletab); /* close output files */
1210 }
1211
1212 /* get ray contribution from previous file */
1213 static int
1214 get_contrib(DCOLOR cnt, FILE *finp)
1215 {
1216 COLOR fv;
1217 COLR cv;
1218
1219 switch (outfmt) {
1220 case 'a':
1221 return(fscanf(finp,"%lf %lf %lf",&cnt[0],&cnt[1],&cnt[2]) == 3);
1222 case 'f':
1223 if (fread(fv, sizeof(fv[0]), 3, finp) != 3)
1224 return(0);
1225 copycolor(cnt, fv);
1226 return(1);
1227 case 'd':
1228 return(fread(cnt, sizeof(cnt[0]), 3, finp) == 3);
1229 case 'c':
1230 if (fread(cv, sizeof(cv), 1, finp) != 1)
1231 return(0);
1232 colr_color(fv, cv);
1233 copycolor(cnt, fv);
1234 return(1);
1235 default:
1236 error(INTERNAL, "botched output format");
1237 }
1238 return(0); /* pro forma return */
1239 }
1240
1241 /* close output file opened for input */
1242 static int
1243 myclose(const LUENT *e, void *p)
1244 {
1245 STREAMOUT *sop = (STREAMOUT *)e->data;
1246
1247 if (sop->ofp == NULL)
1248 return(0);
1249 fclose(sop->ofp);
1250 sop->ofp = NULL;
1251 return(0);
1252 }
1253
1254 /* load previously accumulated values */
1255 void
1256 reload_output(void)
1257 {
1258 int i, j;
1259 MODCONT *mp;
1260 int ofl;
1261 char oname[1024];
1262 char *fmode = "rb";
1263 char *outvfmt;
1264 LUENT *ment, *oent;
1265 int xr, yr;
1266 STREAMOUT sout;
1267 DCOLOR rgbv;
1268
1269 switch (outfmt) {
1270 case 'a':
1271 outvfmt = "ascii";
1272 fmode = "r";
1273 break;
1274 case 'f':
1275 outvfmt = "float";
1276 break;
1277 case 'd':
1278 outvfmt = "double";
1279 break;
1280 case 'c':
1281 outvfmt = COLRFMT;
1282 break;
1283 default:
1284 error(INTERNAL, "botched output format");
1285 return;
1286 }
1287 /* reload modifier values */
1288 for (i = 0; i < nmods; i++) {
1289 ment = lu_find(&modconttab,modname[i]);
1290 mp = (MODCONT *)ment->data;
1291 if (mp->outspec == NULL)
1292 error(USER, "cannot reload from stdout");
1293 if (mp->outspec[0] == '!')
1294 error(USER, "cannot reload from command");
1295 for (j = 0; ; j++) { /* load each modifier bin */
1296 ofl = ofname(oname, mp->outspec, mp->modname, j);
1297 if (ofl < 0)
1298 error(USER, "bad output file specification");
1299 oent = lu_find(&ofiletab, oname);
1300 if (oent->data != NULL) {
1301 sout = *(STREAMOUT *)oent->data;
1302 } else {
1303 sout.reclen = 0;
1304 sout.outpipe = 0;
1305 sout.xr = xres; sout.yr = yres;
1306 sout.ofp = NULL;
1307 }
1308 if (sout.ofp == NULL) { /* open output as input */
1309 sout.ofp = fopen(oname, fmode);
1310 if (sout.ofp == NULL) {
1311 if (j)
1312 break; /* assume end of modifier */
1313 sprintf(errmsg, "missing reload file '%s'",
1314 oname);
1315 error(WARNING, errmsg);
1316 break;
1317 }
1318 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1319 sprintf(errmsg, "format mismatch for '%s'",
1320 oname);
1321 error(USER, errmsg);
1322 }
1323 if ((sout.xr > 0) & (sout.yr > 0) &&
1324 (!fscnresolu(&xr, &yr, sout.ofp) ||
1325 (xr != sout.xr) |
1326 (yr != sout.yr))) {
1327 sprintf(errmsg, "resolution mismatch for '%s'",
1328 oname);
1329 error(USER, errmsg);
1330 }
1331 }
1332 /* read in RGB value */
1333 if (!get_contrib(rgbv, sout.ofp)) {
1334 if (!j) {
1335 fclose(sout.ofp);
1336 break; /* ignore empty file */
1337 }
1338 if (j < mp->nbins) {
1339 sprintf(errmsg, "missing data in '%s'",
1340 oname);
1341 error(USER, errmsg);
1342 }
1343 break;
1344 }
1345 if (j >= mp->nbins) /* grow modifier size */
1346 ment->data = (char *)(mp = growmodifier(mp, j+1));
1347 copycolor(mp->cbin[j], rgbv);
1348 if (oent->key == NULL) /* new file entry */
1349 oent->key = strcpy((char *)
1350 malloc(strlen(oname)+1), oname);
1351 if (oent->data == NULL)
1352 oent->data = (char *)malloc(sizeof(STREAMOUT));
1353 *(STREAMOUT *)oent->data = sout;
1354 }
1355 }
1356 lu_doall(&ofiletab, myclose, NULL); /* close all files */
1357 }
1358
1359 /* seek on the given output file */
1360 static int
1361 myseeko(const LUENT *e, void *p)
1362 {
1363 STREAMOUT *sop = (STREAMOUT *)e->data;
1364 off_t nbytes = *(off_t *)p;
1365
1366 if (sop->reclen > 1)
1367 nbytes = nbytes * sop->reclen;
1368 if (fseeko(sop->ofp, nbytes, SEEK_CUR) < 0) {
1369 sprintf(errmsg, "seek error on file '%s'", e->key);
1370 error(SYSTEM, errmsg);
1371 }
1372 return 0;
1373 }
1374
1375 /* recover output if possible */
1376 void
1377 recover_output(FILE *fin)
1378 {
1379 off_t lastout = -1;
1380 int outvsiz, recsiz;
1381 char *outvfmt;
1382 int i, j;
1383 MODCONT *mp;
1384 int ofl;
1385 char oname[1024];
1386 LUENT *ment, *oent;
1387 STREAMOUT sout;
1388 off_t nvals;
1389 int xr, yr;
1390
1391 switch (outfmt) {
1392 case 'a':
1393 error(USER, "cannot recover ASCII output");
1394 return;
1395 case 'f':
1396 outvsiz = sizeof(float)*3;
1397 outvfmt = "float";
1398 break;
1399 case 'd':
1400 outvsiz = sizeof(double)*3;
1401 outvfmt = "double";
1402 break;
1403 case 'c':
1404 outvsiz = sizeof(COLR);
1405 outvfmt = COLRFMT;
1406 break;
1407 default:
1408 error(INTERNAL, "botched output format");
1409 return;
1410 }
1411 /* check modifier outputs */
1412 for (i = 0; i < nmods; i++) {
1413 ment = lu_find(&modconttab,modname[i]);
1414 mp = (MODCONT *)ment->data;
1415 if (mp->outspec == NULL)
1416 error(USER, "cannot recover from stdout");
1417 if (mp->outspec[0] == '!')
1418 error(USER, "cannot recover from command");
1419 for (j = 0; ; j++) { /* check each bin's file */
1420 ofl = ofname(oname, mp->outspec, mp->modname, j);
1421 if (ofl < 0)
1422 error(USER, "bad output file specification");
1423 oent = lu_find(&ofiletab, oname);
1424 if (oent->data != NULL) {
1425 sout = *(STREAMOUT *)oent->data;
1426 } else {
1427 sout.reclen = 0;
1428 sout.outpipe = 0;
1429 sout.ofp = NULL;
1430 }
1431 if (sout.ofp != NULL) { /* already open? */
1432 if (ofl & OF_BIN)
1433 continue;
1434 break;
1435 }
1436 /* open output */
1437 sout.ofp = fopen(oname, "rb+");
1438 if (sout.ofp == NULL) {
1439 if (j)
1440 break; /* assume end of modifier */
1441 sprintf(errmsg, "missing recover file '%s'",
1442 oname);
1443 error(WARNING, errmsg);
1444 break;
1445 }
1446 nvals = lseek(fileno(sout.ofp), 0, SEEK_END);
1447 if (nvals <= 0) {
1448 lastout = 0; /* empty output, quit here */
1449 fclose(sout.ofp);
1450 break;
1451 }
1452 if (!sout.reclen) {
1453 if (!(ofl & OF_BIN)) {
1454 sprintf(errmsg,
1455 "need -bn to recover file '%s'",
1456 oname);
1457 error(USER, errmsg);
1458 }
1459 recsiz = outvsiz;
1460 } else
1461 recsiz = outvsiz * sout.reclen;
1462
1463 lseek(fileno(sout.ofp), 0, SEEK_SET);
1464 if (header && checkheader(sout.ofp, outvfmt, NULL) != 1) {
1465 sprintf(errmsg, "format mismatch for '%s'",
1466 oname);
1467 error(USER, errmsg);
1468 }
1469 sout.xr = xres; sout.yr = yres;
1470 if ((sout.xr > 0) & (sout.yr > 0) &&
1471 (!fscnresolu(&xr, &yr, sout.ofp) ||
1472 (xr != sout.xr) |
1473 (yr != sout.yr))) {
1474 sprintf(errmsg, "resolution mismatch for '%s'",
1475 oname);
1476 error(USER, errmsg);
1477 }
1478 nvals = (nvals - (off_t)ftell(sout.ofp)) / recsiz;
1479 if ((lastout < 0) | (nvals < lastout))
1480 lastout = nvals;
1481 if (oent->key == NULL) /* new entry */
1482 oent->key = strcpy((char *)
1483 malloc(strlen(oname)+1), oname);
1484 if (oent->data == NULL)
1485 oent->data = (char *)malloc(sizeof(STREAMOUT));
1486 *(STREAMOUT *)oent->data = sout;
1487 if (!(ofl & OF_BIN))
1488 break; /* no bin separation */
1489 }
1490 if (!lastout) { /* empty output */
1491 error(WARNING, "no previous data to recover");
1492 lu_done(&ofiletab); /* reclose all outputs */
1493 return;
1494 }
1495 if (j > mp->nbins) /* reallocate modifier bins */
1496 ment->data = (char *)(mp = growmodifier(mp, j));
1497 }
1498 if (lastout < 0) {
1499 error(WARNING, "no output files to recover");
1500 return;
1501 }
1502 if (raysleft && lastout >= raysleft/accumulate) {
1503 error(WARNING, "output appears to be complete");
1504 /* XXX should read & discard input? */
1505 quit(0);
1506 }
1507 /* seek on all files */
1508 nvals = lastout * outvsiz;
1509 lu_doall(&ofiletab, myseeko, &nvals);
1510 /* skip repeated input */
1511 for (nvals = 0; nvals < lastout; nvals++)
1512 if (getinp(oname, fin) < 0)
1513 error(USER, "unexpected EOF on input");
1514 lastray = lastdone = (unsigned long)lastout * accumulate;
1515 if (raysleft)
1516 raysleft -= lastray;
1517 }
