Increased default -ad from 128 to 350
Minor correction to avoid segfault with illegal option
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Added check for -P and -PP option, which causes conflict
Minor fix to ray flushing
Fixed rtcontrib flushing behavior
Made it so zero ray directions flush output in rtcontrib
Added rtcontrib -fo option to override new reluctance to clobber existing files
Fixed bug introduced in rev 1.29 (Oct 5 2005) that broke output synchronization
Added final write error check
Fixes in new rtcontrib -bn option
Minor improvements in output file consistency with rtrace
Bug fix for some systems where rtrace process gets stuck for unknown reasons
Fixed serious bug where rtcontrib would sometimes forget to write last file
Added check for no arguments
Added check for complete output with -r option
Added check for missing recover files
Made it so MODIFIER= line added to every header
Fixed argument checking
Fixed it so rtcontrib -M option searches RAYPATH directories
Fixe in rtcontrib -M option
Fixed array overrun with large number of modifiers
Added rtcontrib -M option to read modifier list from a file
Warning wording tweaks
Added warning & check for case where no output files exist with -r option
Minor optimization to reduce calls to getofile()
Added missing definition of PI for calcomp routines
Added missing include for signal.h
Minor code tweaks
Improved efficiency of queuing behavior to avoid idle process time
