root/radiance/ray/src/util/rtcontrib.c
Revision 1.69
Tue Apr 8 23:46:05 2014 UTC (10 years, 1 month ago) by greg
Changes since 1.68: +1 -1 lines
FILE REMOVED
Formally retired rtcontrib
Thu Apr 12 01:56:07 2012 UTC (12 years, 1 month ago) by greg
Changes since 1.67: +17 -12 lines
Diff to previous 1.67 , to selected 1.64
Added #define for RNUMBER, which matches ray.h
Tue Apr 10 05:16:50 2012 UTC (12 years, 1 month ago) by greg
Changes since 1.66: +58 -3 lines
Diff to previous 1.66 , to selected 1.64
Eliminated file thread locking in parent process
Thu Feb 23 06:03:46 2012 UTC (12 years, 2 months ago) by greg
Changes since 1.65: +2 -2 lines
Diff to previous 1.65 , to selected 1.64
Changed data size for Windows
Wed Oct 5 17:20:55 2011 UTC (12 years, 7 months ago) by greg
Changes since 1.64: +5 -1 lines
Diff to previous 1.64
Windows compatibility changes from Bill Hoffman
Revision 1.64 - (view) (download) (annotate) - [selected]
Sat Apr 16 00:39:07 2011 UTC (13 years, 1 month ago) by greg
Changes since 1.63: +12 -6 lines
Diff to previous 1.63
Bug fix for 32-bit OS
Sat Apr 9 18:05:18 2011 UTC (13 years, 1 month ago) by greg
Changes since 1.62: +14 -7 lines
Diff to previous 1.62 , to selected 1.64
Fixed problem with command specification of octree
Wed Apr 6 00:39:07 2011 UTC (13 years, 1 month ago) by greg
Changes since 1.61: +8 -9 lines
Diff to previous 1.61 , to selected 1.64
Minor adjustments to last change
Mon Apr 4 22:17:35 2011 UTC (13 years, 1 month ago) by greg
Changes since 1.60: +6 -6 lines
Diff to previous 1.60 , to selected 1.64
Attempt to fix bug
Sun Oct 10 09:25:04 2010 UTC (13 years, 7 months ago) by greg
Changes since 1.59: +1 -2 lines
Diff to previous 1.59 , to selected 1.64
Removed unneeded inclusion of random.h
Sun Oct 10 01:26:51 2010 UTC (13 years, 7 months ago) by greg
Changes since 1.58: +1 -3 lines
Diff to previous 1.58 , to selected 1.64
Removed random flush call that was only making matters worse
Tue Oct 5 18:05:22 2010 UTC (13 years, 7 months ago) by greg
Changes since 1.57: +5 -5 lines
Diff to previous 1.57 , to selected 1.64
Fixed issues with integer overflow
Sun Sep 26 15:44:00 2010 UTC (13 years, 7 months ago) by greg
Changes since 1.56: +9 -6 lines
Diff to previous 1.56 , to selected 1.64
Added random flushing of output buffers in attempt to improve performance
Fri Jun 11 20:26:09 2010 UTC (13 years, 11 months ago) by greg
Changes since 1.55: +5 -3 lines
Diff to previous 1.55 , to selected 1.64
Fixed -defaults reporting of number of processes
Wed Dec 9 21:43:35 2009 UTC (14 years, 5 months ago) by greg
Changes since 1.54: +5 -1 lines
Diff to previous 1.54 , to selected 1.64
Made output specification a little more flexible (hex and octal numbers)
Sun Jun 14 18:21:58 2009 UTC (14 years, 11 months ago) by greg
Changes since 1.53: +16 -11 lines
Diff to previous 1.53 , to selected 1.64
Added ability to specify constant name in rtcontrib -bn option
Thu Jun 11 18:32:24 2009 UTC (14 years, 11 months ago) by greg
Changes since 1.52: +5 -5 lines
Diff to previous 1.52 , to selected 1.64
Fixed peculiar flushing case
Sat Feb 7 05:40:47 2009 UTC (15 years, 3 months ago) by greg
Changes since 1.51: +2 -2 lines
Diff to previous 1.51 , to selected 1.64
Added missing newline to error statement
Sat Dec 6 01:08:53 2008 UTC (15 years, 5 months ago) by greg
Changes since 1.50: +2 -2 lines
Diff to previous 1.50 , to selected 1.64
Thu May 1 16:42:06 2008 UTC (16 years ago) by greg
Changes since 1.49: +3 -2 lines
Diff to previous 1.49 , to selected 1.64
Fri Apr 18 18:06:29 2008 UTC (16 years, 1 month ago) by greg
Changes since 1.48: +43 -35 lines
Diff to previous 1.48 , to selected 1.64
Modified rtcontrib -c option to accumulate a specified number of rays
Sat Nov 17 16:27:14 2007 UTC (16 years, 6 months ago) by greg
Changes since 1.47: +14 -12 lines
Diff to previous 1.47 , to selected 1.64
Minor fixes in reloading procedure
Sat Nov 17 15:57:28 2007 UTC (16 years, 6 months ago) by greg
Changes since 1.46: +9 -6 lines
Diff to previous 1.46 , to selected 1.64
Minor tweaks: -x and -y may again be given after -m options with -c-
Sat Nov 17 06:21:28 2007 UTC (16 years, 6 months ago) by greg
Changes since 1.45: +116 -49 lines
Diff to previous 1.45 , to selected 1.64
Got -r option working with -c
Sat Nov 17 01:13:51 2007 UTC (16 years, 6 months ago) by greg
Changes since 1.44: +164 -46 lines
Diff to previous 1.44 , to selected 1.64
Added -c option to rtcontrib (barely tested, and -r does not work)
Thu Nov 15 18:32:34 2007 UTC (16 years, 6 months ago) by greg
Changes since 1.43: +21 -7 lines
Diff to previous 1.43 , to selected 1.64
Allow -P and -PP options to be set by user
Wed Jun 7 17:52:04 2006 UTC (17 years, 11 months ago) by schorsch
Changes since 1.42: +2 -1 lines
Diff to previous 1.42 , to selected 1.64
Wed Apr 5 14:33:34 2006 UTC (18 years, 1 month ago) by greg
Changes since 1.41: +2 -2 lines
Diff to previous 1.41 , to selected 1.64
Increased default -ad from 128 to 350
Wed Mar 29 17:31:59 2006 UTC (18 years, 1 month ago) by greg
Changes since 1.40: +2 -2 lines
Diff to previous 1.40 , to selected 1.64
Minor correction to avoid segfault with illegal option
Sun Feb 5 22:22:21 2006 UTC (18 years, 3 months ago) by greg
Changes since 1.39: +35 -9 lines
Diff to previous 1.39 , to selected 1.64
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Fri Oct 21 01:12:59 2005 UTC (18 years, 6 months ago) by greg
Changes since 1.38: +4 -1 lines
Diff to previous 1.38 , to selected 1.64
Added check for -P and -PP option, which causes conflict
Tue Oct 11 23:55:37 2005 UTC (18 years, 7 months ago) by greg
Changes since 1.37: +4 -4 lines
Diff to previous 1.37 , to selected 1.64
Minor fix to ray flushing
Tue Oct 11 23:41:45 2005 UTC (18 years, 7 months ago) by greg
Changes since 1.36: +2 -2 lines
Diff to previous 1.36 , to selected 1.64
Fixed rtcontrib flushing behavior
Tue Oct 11 19:02:51 2005 UTC (18 years, 7 months ago) by greg
Changes since 1.35: +33 -13 lines
Diff to previous 1.35 , to selected 1.64
Made it so zero ray directions flush output in rtcontrib
Tue Oct 11 16:54:26 2005 UTC (18 years, 7 months ago) by greg
Changes since 1.34: +10 -3 lines
Diff to previous 1.34 , to selected 1.64
Added rtcontrib -fo option to override new reluctance to clobber existing files
Tue Oct 11 04:27:41 2005 UTC (18 years, 7 months ago) by greg
Changes since 1.33: +9 -7 lines
Diff to previous 1.33 , to selected 1.64
Fixed bug introduced in rev 1.29 (Oct 5 2005) that broke output synchronization
Fri Oct 7 03:45:15 2005 UTC (18 years, 7 months ago) by greg
Changes since 1.32: +6 -3 lines
Diff to previous 1.32 , to selected 1.64
Added final write error check
Thu Oct 6 16:28:59 2005 UTC (18 years, 7 months ago) by greg
Changes since 1.31: +19 -19 lines
Diff to previous 1.31 , to selected 1.64
Fixes in new rtcontrib -bn option
Thu Oct 6 05:49:44 2005 UTC (18 years, 7 months ago) by greg
Changes since 1.30: +176 -106 lines
Diff to previous 1.30 , to selected 1.64
Wed Oct 5 19:44:17 2005 UTC (18 years, 7 months ago) by greg
Changes since 1.29: +14 -3 lines
Diff to previous 1.29 , to selected 1.64
Minor improvements in output file consistency with rtrace
Wed Oct 5 05:20:21 2005 UTC (18 years, 7 months ago) by greg
Changes since 1.28: +17 -2 lines
Diff to previous 1.28 , to selected 1.64
Bug fix for some systems where rtrace process gets stuck for unknown reasons
Wed Sep 21 17:17:24 2005 UTC (18 years, 7 months ago) by greg
Changes since 1.27: +3 -3 lines
Diff to previous 1.27 , to selected 1.64
Tue Sep 20 17:05:11 2005 UTC (18 years, 7 months ago) by greg
Changes since 1.26: +2 -2 lines
Diff to previous 1.26 , to selected 1.64
Fixed serious bug where rtcontrib would sometimes forget to write last file
Mon Sep 19 11:30:11 2005 UTC (18 years, 8 months ago) by schorsch
Changes since 1.25: +5 -2 lines
Diff to previous 1.25 , to selected 1.64
Tue Sep 13 22:58:22 2005 UTC (18 years, 8 months ago) by greg
Changes since 1.24: +8 -1 lines
Diff to previous 1.24 , to selected 1.64
Added check for no arguments
Fri Jun 17 16:07:18 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.23: +8 -3 lines
Diff to previous 1.23 , to selected 1.64
Added check for complete output with -r option
Thu Jun 16 19:37:26 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.22: +8 -3 lines
Diff to previous 1.22 , to selected 1.64
Added check for missing recover files
Tue Jun 14 02:50:23 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.21: +3 -5 lines
Diff to previous 1.21 , to selected 1.64
Made it so MODIFIER= line added to every header
Sat Jun 11 15:01:03 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.20: +10 -10 lines
Diff to previous 1.20 , to selected 1.64
Fixed argument checking
Fri Jun 10 20:53:55 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.19: +6 -3 lines
Diff to previous 1.19 , to selected 1.64
Fixed it so rtcontrib -M option searches RAYPATH directories
Fri Jun 10 20:44:00 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.18: +6 -2 lines
Diff to previous 1.18 , to selected 1.64
Fixe in rtcontrib -M option
Fri Jun 10 20:38:38 2005 UTC (18 years, 11 months ago) by greg
Diff to previous 1.17 , to selected 1.64
Fixed array overrun with large number of modifiers
Fri Jun 10 16:42:11 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.16: +18 -1 lines
Diff to previous 1.16 , to selected 1.64
Added rtcontrib -M option to read modifier list from a file
Thu Jun 9 18:33:06 2005 UTC (18 years, 11 months ago) by greg
Diff to previous 1.15 , to selected 1.64
Warning wording tweaks
Thu Jun 9 18:27:44 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.14: +5 -1 lines
Diff to previous 1.14 , to selected 1.64
Added warning & check for case where no output files exist with -r option
Thu Jun 9 17:27:28 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.13: +238 -65 lines
Diff to previous 1.13 , to selected 1.64
Sun Jun 5 19:52:01 2005 UTC (18 years, 11 months ago) by greg
Diff to previous 1.12 , to selected 1.64
Fri Jun 3 14:29:42 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.11: +11 -3 lines
Diff to previous 1.11 , to selected 1.64
Minor optimization to reduce calls to getofile()
Thu Jun 2 18:51:46 2005 UTC (18 years, 11 months ago) by greg
Diff to previous 1.10 , to selected 1.64
Added missing definition of PI for calcomp routines
Thu Jun 2 04:47:27 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.9: +17 -5 lines
Diff to previous 1.9 , to selected 1.64
Wed Jun 1 16:11:01 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.8: +11 -2 lines
Diff to previous 1.8 , to selected 1.64
Tue May 31 18:01:09 2005 UTC (18 years, 11 months ago) by greg
Diff to previous 1.7 , to selected 1.64
Tue May 31 03:48:59 2005 UTC (18 years, 11 months ago) by greg
Diff to previous 1.6 , to selected 1.64
Added missing include for signal.h
Sat May 28 22:27:54 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.5: +5 -6 lines
Diff to previous 1.5 , to selected 1.64
Thu May 26 21:35:35 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.4: +10 -9 lines
Diff to previous 1.4 , to selected 1.64
Minor code tweaks
Thu May 26 17:53:28 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.3: +15 -5 lines
Diff to previous 1.3 , to selected 1.64
Thu May 26 15:14:42 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.2: +59 -44 lines
Diff to previous 1.2 , to selected 1.64
Improved efficiency of queuing behavior to avoid idle process time
Thu May 26 06:55:22 2005 UTC (18 years, 11 months ago) by greg
Changes since 1.1: +183 -164 lines
Diff to previous 1.1 , to selected 1.64
Wed May 25 04:45:22 2005 UTC (18 years, 11 months ago) by greg
Diff to selected 1.64
