root/radiance/ray/src/util/rsensor.c
Revision: 2.8
Committed: Sun Sep 26 15:41:46 2010 UTC (14 years, 7 months ago) by greg
Changes since 2.7: +26 -3 lines
Added ability to output sample rays rather than compute results
2 static const char RCSid[] = "$Id: rsensor.c,v 2.7 2009/12/12 19:01:00 greg Exp $";
4
5 /*
6 * Compute sensor signal based on spatial sensitivity.
7 *
8 * Created Feb 2008 for Architectural Energy Corp.
9 */
10
11 #include "ray.h"
12 #include "source.h"
13 #include "view.h"
14 #include "random.h"
15
16 #define DEGREE (PI/180.)
17
18 #define MAXNT 180 /* maximum number of theta divisions */
19 #define MAXNP 360 /* maximum number of phi divisions */
20
21 extern char *progname; /* global argv[0] */
22 extern int nowarn; /* don't report warnings? */
23
24 /* current sensor's perspective */
25 VIEW ourview = {VT_ANG,{0.,0.,0.},{0.,0.,1.},{1.,0.,0.},
26 1.,180.,180.,0.,0.,0.,0.,
27 {0.,0.,0.},{0.,0.,0.},0.,0.};
28
29 unsigned long nsamps = 10000; /* desired number of initial samples */
30 unsigned long nssamps = 9000; /* number of super-samples */
31 int ndsamps = 32; /* number of direct samples */
32 int nprocs = 1; /* number of rendering processes */
33
34 float *sensor = NULL; /* current sensor data */
35 int sntp[2]; /* number of sensor theta and phi angles */
36 float maxtheta; /* maximum theta value for this sensor */
37 float tvals[MAXNT+1]; /* theta values (1-D table of 1-cos(t)) */
38 float *pvals = NULL; /* phi values (2-D table in radians) */
39 int ntheta = 0; /* polar angle divisions */
40 int nphi = 0; /* azimuthal angle divisions */
41 double gscale = 1.; /* global scaling value */
42
43 #define s_theta(t) sensor[(t+1)*(sntp[1]+1)]
44 #define s_phi(p) sensor[(p)+1]
45 #define s_val(t,p) sensor[(p)+1+(t+1)*(sntp[1]+1)]
46
47 static void comp_sensor(char *sfile);
48
49 static void
50 over_options() /* overriding options */
51 {
52 directvis = (ndsamps <= 0);
53 do_irrad = 0;
54 }
55
56 static void
57 print_defaults() /* print out default parameters */
58 {
59 over_options();
60 printf("-n %-9d\t\t\t# number of processes\n", nprocs);
61 printf("-rd %-9ld\t\t\t# ray directions\n", nsamps);
62 /* printf("-rs %-9ld\t\t\t# ray super-samples\n", nssamps); */
63 printf("-dn %-9d\t\t\t# direct number of samples\n", ndsamps);
64 printf("-vp %f %f %f\t# view point\n",
65 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
66 printf("-vd %f %f %f\t# view direction\n",
67 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
68 printf("-vu %f %f %f\t# view up\n",
69 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
70 printf("-vo %f\t\t\t# view fore clipping distance\n", ourview.vfore);
71 print_rdefaults();
72 }
73
74
75 void
76 quit(ec) /* make sure exit is called */
77 int ec;
78 {
79 if (ray_pnprocs > 0) /* close children if any */
80 ray_pclose(0);
81 exit(ec);
82 }
83
84
85 int
86 main(
87 int argc,
88 char *argv[]
89 )
90 {
91 int doheader = 1;
92 int optwarn = 0;
93 int i, rval;
94
95 progname = argv[0];
96 /* set up rendering defaults */
97 rand_samp = 1;
98 dstrsrc = 0.65;
99 srcsizerat = 0.1;
100 directrelay = 3;
101 ambounce = 1;
102 maxdepth = -10;
103 /* get options from command line */
104 for (i = 1; i < argc; i++) {
105 while ((rval = expandarg(&argc, &argv, i)) > 0)
106 ;
107 if (rval < 0) {
108 sprintf(errmsg, "cannot expand '%s'", argv[i]);
109 error(SYSTEM, errmsg);
110 }
111 if (argv[i][0] != '-') {
112 if (i >= argc-1)
113 break; /* final octree argument */
114 if (!ray_pnprocs) {
115 over_options();
116 if (doheader) { /* print header */
117 newheader("RADIANCE", stdout);
118 printargs(argc, argv, stdout);
119 fputformat("ascii", stdout);
120 putchar('\n');
121 }
122 /* start process(es) */
123 if (strcmp(argv[argc-1], "."))
124 ray_pinit(argv[argc-1], nprocs);
125 }
126 comp_sensor(argv[i]); /* process a sensor file */
127 continue;
128 }
129 if (argv[i][1] == 'r') { /* sampling options */
130 if (argv[i][2] == 'd')
131 nsamps = atol(argv[++i]);
132 else if (argv[i][2] == 's')
133 nssamps = atol(argv[++i]);
134 else {
135 sprintf(errmsg, "bad option at '%s'", argv[i]);
136 error(USER, errmsg);
137 }
138 continue;
139 }
140 /* direct component samples */
141 if (argv[i][1] == 'd' && argv[i][2] == 'n') {
142 ndsamps = atoi(argv[++i]);
143 continue;
144 }
145 if (argv[i][1] == 'v') { /* next sensor view */
146 if (argv[i][2] == 'f') {
147 rval = viewfile(argv[++i], &ourview, NULL);
148 if (rval < 0) {
149 sprintf(errmsg,
150 "cannot open view file \"%s\"",
151 argv[i]);
152 error(SYSTEM, errmsg);
153 } else if (rval == 0) {
154 sprintf(errmsg,
155 "bad view file \"%s\"",
156 argv[i]);
157 error(USER, errmsg);
158 }
159 continue;
160 }
161 rval = getviewopt(&ourview, argc-i, argv+i);
162 if (rval >= 0) {
163 i += rval;
164 continue;
165 }
166 sprintf(errmsg, "bad view option at '%s'", argv[i]);
167 error(USER, errmsg);
168 }
169 if (!strcmp(argv[i], "-w")) { /* toggle warnings */
170 nowarn = !nowarn;
171 continue;
172 }
173 if (ray_pnprocs) {
174 if (!optwarn++)
175 error(WARNING,
176 "rendering options should appear before first sensor");
177 } else if (!strcmp(argv[i], "-defaults")) {
178 print_defaults();
179 return(0);
180 }
181 if (argv[i][1] == 'h') { /* header toggle */
182 doheader = !doheader;
183 continue;
184 }
185 if (!strcmp(argv[i], "-n")) { /* number of processes */
186 nprocs = atoi(argv[++i]);
187 if (nprocs <= 0)
188 error(USER, "illegal number of processes");
189 continue;
190 }
191 rval = getrenderopt(argc-i, argv+i);
192 if (rval < 0) {
193 sprintf(errmsg, "bad render option at '%s'", argv[i]);
194 error(USER, errmsg);
195 }
196 i += rval;
197 }
198 if (sensor == NULL)
199 error(USER, i<argc ? "missing sensor file" : "missing octree");
200 quit(0);
201 }
202
203 /* Load sensor sensitivities (first row and column are angles) */
204 static float *
205 load_sensor(
206 int ntp[2],
207 char *sfile
208 )
209 {
210 char linebuf[8192];
211 int nelem = 1000;
212 float *sarr = (float *)malloc(sizeof(float)*nelem);
213 FILE *fp;
214 char *cp;
215 int i;
216
217 fp = frlibopen(sfile);
218 if (fp == NULL) {
219 sprintf(errmsg, "cannot open sensor file '%s'", sfile);
220 error(SYSTEM, errmsg);
221 }
222 fgets(linebuf, sizeof(linebuf), fp);
223 if (!strncmp(linebuf, "Elevation ", 10))
224 fgets(linebuf, sizeof(linebuf), fp);
225 /* get phi values */
226 sarr[0] = .0f;
227 if (strncmp(linebuf, "degrees", 7)) {
228 sprintf(errmsg, "Missing 'degrees' in sensor file '%s'", sfile);
229 error(USER, errmsg);
230 }
231 cp = sskip(linebuf);
232 ntp[1] = 0;
233 for ( ; ; ) {
234 sarr[ntp[1]+1] = atof(cp);
235 cp = fskip(cp);
236 if (cp == NULL)
237 break;
238 ++ntp[1];
239 }
240 ntp[0] = 0; /* get thetas + data */
241 while (fgets(linebuf, sizeof(linebuf), fp) != NULL) {
242 ++ntp[0];
243 if ((ntp[0]+1)*(ntp[1]+1) > nelem) {
244 nelem += (nelem>>2) + ntp[1];
245 sarr = (float *)realloc((void *)sarr,
246 sizeof(float)*nelem);
247 if (sarr == NULL)
248 error(SYSTEM, "out of memory in load_sensor()");
249 }
250 cp = linebuf;
251 i = ntp[0]*(ntp[1]+1);
252 for ( ; ; ) {
253 sarr[i] = atof(cp);
254 cp = fskip(cp);
255 if (cp == NULL)
256 break;
257 ++i;
258 }
259 if (i == ntp[0]*(ntp[1]+1))
260 break;
261 if (i != (ntp[0]+1)*(ntp[1]+1)) {
262 sprintf(errmsg,
263 "bad column count near line %d in sensor file '%s'",
264 ntp[0]+1, sfile);
265 error(USER, errmsg);
266 }
267 }
268 nelem = i;
269 fclose(fp);
270 errmsg[0] = '\0'; /* sanity checks */
271 if (ntp[0] <= 0)
272 sprintf(errmsg, "no data in sensor file '%s'", sfile);
273 else if (fabs(sarr[ntp[1]+1]) > FTINY)
274 sprintf(errmsg, "minimum theta must be 0 in sensor file '%s'",
275 sfile);
276 else if (fabs(sarr[1]) > FTINY)
277 sprintf(errmsg, "minimum phi must be 0 in sensor file '%s'",
278 sfile);
279 else if (sarr[ntp[1]] <= FTINY)
280 sprintf(errmsg,
281 "maximum phi must be positive in sensor file '%s'",
282 sfile);
283 else if (sarr[ntp[0]*(ntp[1]+1)] <= FTINY)
284 sprintf(errmsg,
285 "maximum theta must be positive in sensor file '%s'",
286 sfile);
287 if (errmsg[0])
288 error(USER, errmsg);
289 return((float *)realloc((void *)sarr, sizeof(float)*nelem));
290 }
291
292 /* Initialize probability table */
293 static void
294 init_ptable(
295 char *sfile
296 )
297 {
298 int samptot = nsamps;
299 float *rowp, *rowp1;
300 double rowsum[MAXNT], rowomega[MAXNT];
301 double thdiv[MAXNT+1], phdiv[MAXNP+1];
302 double tsize, psize;
303 double prob, frac, frac1;
304 int i, j, t, p;
305 /* free old table */
306 if (sensor != NULL)
307 free((void *)sensor);
308 if (pvals != NULL)
309 free((void *)pvals);
310 if (sfile == NULL || !*sfile) {
311 sensor = NULL;
312 sntp[0] = sntp[1] = 0;
313 pvals = NULL;
314 ntheta = nphi = 0;
315 return;
316 }
317 /* load sensor table */
318 sensor = load_sensor(sntp, sfile);
319 if (sntp[0] > MAXNT) {
320 sprintf(errmsg, "Too many theta rows in sensor file '%s'",
321 sfile);
322 error(INTERNAL, errmsg);
323 }
324 if (sntp[1] > MAXNP) {
325 sprintf(errmsg, "Too many phi columns in sensor file '%s'",
326 sfile);
327 error(INTERNAL, errmsg);
328 }
329 /* compute boundary angles */
330 maxtheta = 1.5f*s_theta(sntp[0]-1) - 0.5f*s_theta(sntp[0]-2);
331 thdiv[0] = .0;
332 for (t = 1; t < sntp[0]; t++)
333 thdiv[t] = DEGREE/2.*(s_theta(t-1) + s_theta(t));
334 thdiv[sntp[0]] = maxtheta*DEGREE;
335 phdiv[0] = .0;
336 for (p = 1; p < sntp[1]; p++)
337 phdiv[p] = DEGREE/2.*(s_phi(p-1) + s_phi(p));
338 phdiv[sntp[1]] = 2.*PI;
339 /* size our table */
340 tsize = 1. - cos(maxtheta*DEGREE);
341 psize = PI*tsize/(maxtheta*DEGREE);
342 if (sntp[0]*sntp[1] < samptot) /* don't overdo resolution */
343 samptot = sntp[0]*sntp[1];
344 ntheta = (int)(sqrt((double)samptot*tsize/psize) + 0.5);
345 if (ntheta > MAXNT)
346 ntheta = MAXNT;
347 nphi = samptot/ntheta;
348 pvals = (float *)malloc(sizeof(float)*ntheta*(nphi+1));
349 if (pvals == NULL)
350 error(SYSTEM, "out of memory in init_ptable()");
351 gscale = .0; /* compute our inverse table */
352 for (i = 0; i < sntp[0]; i++) {
353 rowp = &s_val(i,0);
354 rowsum[i] = 0.;
355 for (j = 0; j < sntp[1]; j++)
356 rowsum[i] += *rowp++;
357 rowomega[i] = cos(thdiv[i]) - cos(thdiv[i+1]);
358 rowomega[i] *= 2.*PI / (double)sntp[1];
359 gscale += rowsum[i] * rowomega[i];
360 }
361 for (i = 0; i < ntheta; i++) {
362 prob = (double)i / (double)ntheta;
363 for (t = 0; t < sntp[0]; t++)
364 if ((prob -= rowsum[t]*rowomega[t]/gscale) <= .0)
365 break;
366 if (t >= sntp[0])
367 error(INTERNAL, "code error 1 in init_ptable()");
368 frac = 1. + prob/(rowsum[t]*rowomega[t]/gscale);
369 tvals[i] = 1. - ( (1.-frac)*cos(thdiv[t]) +
370 frac*cos(thdiv[t+1]) );
371 /* offset b/c sensor values are centered */
372 if (t <= 0 || frac > 0.5)
373 frac -= 0.5;
374 else if (t >= sntp[0]-1 || frac < 0.5) {
375 frac += 0.5;
376 --t;
377 }
378 pvals[i*(nphi+1)] = .0f;
379 for (j = 1; j < nphi; j++) {
380 prob = (double)j / (double)nphi;
381 rowp = &s_val(t,0);
382 rowp1 = &s_val(t+1,0);
383 for (p = 0; p < sntp[1]; p++) {
384 if ((prob -= (1.-frac)*rowp[p]/rowsum[t] +
385 frac*rowp1[p]/rowsum[t+1]) <= .0)
386 break;
387 if (p >= sntp[1])
388 error(INTERNAL,
389 "code error 2 in init_ptable()");
390 frac1 = 1. + prob/((1.-frac)*rowp[p]/rowsum[t]
391 + frac*rowp1[p]/rowsum[t+1]);
392 pvals[i*(nphi+1) + j] = (1.-frac1)*phdiv[p] +
393 frac1*phdiv[p+1];
394 }
395 }
396 pvals[i*(nphi+1) + nphi] = (float)(2.*PI);
397 }
398 tvals[0] = .0f;
399 tvals[ntheta] = (float)tsize;
400 }
401
402 /* Get normalized direction from random variables in [0,1) range */
403 static void
404 get_direc(
405 FVECT dvec,
406 double x,
407 double y
408 )
409 {
410 double xfrac = x*ntheta;
411 int tndx = (int)xfrac;
412 double yfrac = y*nphi;
413 int pndx = (int)yfrac;
414 double rad, phi;
415 FVECT dv;
416 int i;
417
418 xfrac -= (double)tndx;
419 yfrac -= (double)pndx;
420 pndx += tndx*(nphi+1);
421
422 dv[2] = 1. - ((1.-xfrac)*tvals[tndx] + xfrac*tvals[tndx+1]);
423 rad = sqrt(1. - dv[2]*dv[2]);
424 phi = (1.-yfrac)*pvals[pndx] + yfrac*pvals[pndx+1];
425 dv[0] = -rad*sin(phi);
426 dv[1] = rad*cos(phi);
427 for (i = 3; i--; )
428 dvec[i] = dv[0]*ourview.hvec[i] +
429 dv[1]*ourview.vvec[i] +
430 dv[2]*ourview.vdir[i] ;
431 }
432
433 /* Get sensor value in the specified direction (normalized) */
434 static float
435 sens_val(
436 FVECT dvec
437 )
438 {
439 FVECT dv;
440 float theta, phi;
441 int t, p;
442
443 dv[2] = DOT(dvec, ourview.vdir);
444 theta = (float)((1./DEGREE) * acos(dv[2]));
445 if (theta >= maxtheta)
446 return(.0f);
447 dv[0] = DOT(dvec, ourview.hvec);
448 dv[1] = DOT(dvec, ourview.vvec);
449 phi = (float)((1./DEGREE) * atan2(-dv[0], dv[1]));
450 while (phi < .0f) phi += 360.f;
451 t = (int)(theta/maxtheta * sntp[0]);
452 p = (int)(phi*(1./360.) * sntp[1]);
453 /* hack for non-uniform sensor grid */
454 while (t+1 < sntp[0] && theta >= s_theta(t+1))
455 ++t;
456 while (t-1 >= 0 && theta <= s_theta(t-1))
457 --t;
458 while (p+1 < sntp[1] && phi >= s_phi(p+1))
459 ++p;
460 while (p-1 >= 0 && phi <= s_phi(p-1))
461 --p;
462 return(s_val(t,p));
463 }
464
465 /* Print origin and direction */
466 static void
467 print_ray(
468 FVECT rorg,
469 FVECT rdir
470 )
471 {
472 printf("%.6g %.6g %.6g %.8f %.8f %.8f\n",
473 rorg[0], rorg[1], rorg[2],
474 rdir[0], rdir[1], rdir[2]);
475 }
476
477 /* Compute sensor output */
478 static void
479 comp_sensor(
480 char *sfile
481 )
482 {
483 int ndirs = dstrsrc > FTINY ? ndsamps :
484 ndsamps > 0 ? 1 : 0;
485 char *err;
486 int nt, np;
487 COLOR vsum;
488 RAY rr;
489 double sf;
490 int i, j;
491 /* set view */
492 ourview.type = VT_ANG;
493 ourview.horiz = ourview.vert = 180.;
494 ourview.hoff = ourview.voff = .0;
495 err = setview(&ourview);
496 if (err != NULL)
497 error(USER, err);
498 /* assign probability table */
499 init_ptable(sfile);
500 /* stratified MC sampling */
501 setcolor(vsum, .0f, .0f, .0f);
502 nt = (int)(sqrt((double)nsamps*ntheta/nphi) + .5);
503 np = nsamps/nt;
504 sf = gscale/nsamps;
505 for (i = 0; i < nt; i++)
506 for (j = 0; j < np; j++) {
507 VCOPY(rr.rorg, ourview.vp);
508 get_direc(rr.rdir, (i+frandom())/nt, (j+frandom())/np);
509 if (ourview.vfore > FTINY)
510 VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore);
511 if (!ray_pnprocs) {
512 print_ray(rr.rorg, rr.rdir);
513 continue;
514 }
515 rr.rmax = .0;
516 rayorigin(&rr, PRIMARY, NULL, NULL);
517 scalecolor(rr.rcoef, sf);
518 if (ray_pqueue(&rr) == 1)
519 addcolor(vsum, rr.rcol);
520 }
521 /* remaining rays pure MC */
522 for (i = nsamps - nt*np; i-- > 0; ) {
523 VCOPY(rr.rorg, ourview.vp);
524 get_direc(rr.rdir, frandom(), frandom());
525 if (ourview.vfore > FTINY)
526 VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore);
527 if (!ray_pnprocs) {
528 print_ray(rr.rorg, rr.rdir);
529 continue;
530 }
531 rr.rmax = .0;
532 rayorigin(&rr, PRIMARY, NULL, NULL);
533 scalecolor(rr.rcoef, sf);
534 if (ray_pqueue(&rr) == 1)
535 addcolor(vsum, rr.rcol);
536 }
537 if (!ray_pnprocs) /* just printing rays */
538 return;
539 /* scale partial result */
540 scalecolor(vsum, sf);
541 /* add direct component */
542 for (i = ndirs; i-- > 0; ) {
543 SRCINDEX si;
544 initsrcindex(&si);
545 while (srcray(&rr, NULL, &si)) {
546 sf = sens_val(rr.rdir);
547 if (sf <= FTINY)
548 continue;
549 sf *= si.dom/ndirs;
550 scalecolor(rr.rcoef, sf);
551 if (ray_pqueue(&rr) == 1) {
552 multcolor(rr.rcol, rr.rcoef);
553 addcolor(vsum, rr.rcol);
554 }
555 }
556 }
557 /* finish our calculation */
558 while (ray_presult(&rr, 0) > 0) {
559 multcolor(rr.rcol, rr.rcoef);
560 addcolor(vsum, rr.rcol);
561 }
562 /* print our result */
563 printf("%.4e %.4e %.4e\n", colval(vsum,RED),
564 colval(vsum,GRN), colval(vsum,BLU));
565 }
