--- ray/src/util/rsensor.c 2009/12/12 19:01:00 2.7 +++ ray/src/util/rsensor.c 2015/04/23 23:34:18 2.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rsensor.c,v 2.7 2009/12/12 19:01:00 greg Exp $"; +static const char RCSid[] = "$Id: rsensor.c,v 2.15 2015/04/23 23:34:18 greg Exp $"; #endif /* @@ -15,7 +15,7 @@ static const char RCSid[] = "$Id: rsensor.c,v 2.7 2009 #define DEGREE (PI/180.) -#define MAXNT 180 /* maximum number of theta divisions */ +#define MAXNT 181 /* maximum number of theta divisions */ #define MAXNP 360 /* maximum number of phi divisions */ extern char *progname; /* global argv[0] */ @@ -34,8 +34,8 @@ int nprocs = 1; /* number of rendering processes float *sensor = NULL; /* current sensor data */ int sntp[2]; /* number of sensor theta and phi angles */ float maxtheta; /* maximum theta value for this sensor */ -float tvals[MAXNT+1]; /* theta values (1-D table of 1-cos(t)) */ -float *pvals = NULL; /* phi values (2-D table in radians) */ +float tvals[MAXNT+1]; /* theta prob. values (1-D table of 1-cos(t)) */ +float *pvals = NULL; /* phi prob. values (2-D table in radians) */ int ntheta = 0; /* polar angle divisions */ int nphi = 0; /* azimuthal angle divisions */ double gscale = 1.; /* global scaling value */ @@ -120,7 +120,8 @@ main( putchar('\n'); } /* start process(es) */ - ray_pinit(argv[argc-1], nprocs); + if (strcmp(argv[argc-1], ".")) + ray_pinit(argv[argc-1], nprocs); } comp_sensor(argv[i]); /* process a sensor file */ continue; @@ -194,7 +195,7 @@ main( } i += rval; } - if (!ray_pnprocs) + if (sensor == NULL) error(USER, i 1 && sarr[ntp[1]+1] <= sarr[ntp[1]]) { + sprintf(errmsg, + "Phi values not monotinically increasing in sensor file '%s'", + sfile); + error(USER, errmsg); + } ++ntp[1]; } + warnedneg = 0; ntp[0] = 0; /* get thetas + data */ while (fgets(linebuf, sizeof(linebuf), fp) != NULL) { ++ntp[0]; @@ -253,10 +262,25 @@ load_sensor( cp = fskip(cp); if (cp == NULL) break; + if (i && sarr[i] < .0) { + if (!warnedneg++) { + sprintf(errmsg, + "Negative value(s) in sensor file '%s' (ignored)\n", sfile); + error(WARNING, errmsg); + } + sarr[i] = .0; + } ++i; } if (i == ntp[0]*(ntp[1]+1)) break; + if (ntp[0] > 1 && sarr[ntp[0]*(ntp[1]+1)] <= + sarr[(ntp[0]-1)*(ntp[1]+1)]) { + sprintf(errmsg, + "Theta values not monotinically increasing in sensor file '%s'", + sfile); + error(USER, errmsg); + } if (i != (ntp[0]+1)*(ntp[1]+1)) { sprintf(errmsg, "bad column count near line %d in sensor file '%s'", @@ -326,37 +350,43 @@ init_ptable( error(INTERNAL, errmsg); } /* compute boundary angles */ - maxtheta = 1.5f*s_theta(sntp[0]-1) - 0.5f*s_theta(sntp[0]-2); + maxtheta = DEGREE*(1.5f*s_theta(sntp[0]-1) - 0.5f*s_theta(sntp[0]-2)); + if (maxtheta > PI) + maxtheta = PI; thdiv[0] = .0; for (t = 1; t < sntp[0]; t++) thdiv[t] = DEGREE/2.*(s_theta(t-1) + s_theta(t)); - thdiv[sntp[0]] = maxtheta*DEGREE; - phdiv[0] = .0; + thdiv[sntp[0]] = maxtheta; + phdiv[0] = DEGREE*(1.5f*s_phi(0) - 0.5f*s_phi(1)); for (p = 1; p < sntp[1]; p++) phdiv[p] = DEGREE/2.*(s_phi(p-1) + s_phi(p)); - phdiv[sntp[1]] = 2.*PI; + phdiv[sntp[1]] = DEGREE*(1.5f*s_phi(sntp[1]-1) - 0.5f*s_phi(sntp[1]-2)); /* size our table */ - tsize = 1. - cos(maxtheta*DEGREE); - psize = PI*tsize/(maxtheta*DEGREE); + tsize = 1. - cos(maxtheta); + psize = PI*tsize/maxtheta; if (sntp[0]*sntp[1] < samptot) /* don't overdo resolution */ samptot = sntp[0]*sntp[1]; ntheta = (int)(sqrt((double)samptot*tsize/psize) + 0.5); if (ntheta > MAXNT) ntheta = MAXNT; nphi = samptot/ntheta; - pvals = (float *)malloc(sizeof(float)*ntheta*(nphi+1)); + pvals = (float *)malloc(sizeof(float)*(ntheta+1)*(nphi+1)); if (pvals == NULL) error(SYSTEM, "out of memory in init_ptable()"); gscale = .0; /* compute our inverse table */ for (i = 0; i < sntp[0]; i++) { rowp = &s_val(i,0); - rowsum[i] = 0.; + rowsum[i] = 1e-20; for (j = 0; j < sntp[1]; j++) rowsum[i] += *rowp++; rowomega[i] = cos(thdiv[i]) - cos(thdiv[i+1]); rowomega[i] *= 2.*PI / (double)sntp[1]; gscale += rowsum[i] * rowomega[i]; } + if (gscale <= FTINY) { + sprintf(errmsg, "Sensor values sum to zero in file '%s'", sfile); + error(USER, errmsg); + } for (i = 0; i < ntheta; i++) { prob = (double)i / (double)ntheta; for (t = 0; t < sntp[0]; t++) @@ -368,32 +398,35 @@ init_ptable( tvals[i] = 1. - ( (1.-frac)*cos(thdiv[t]) + frac*cos(thdiv[t+1]) ); /* offset b/c sensor values are centered */ - if (t <= 0 || frac > 0.5) + if ((t < sntp[0]-1) & (!t | (frac >= 0.5))) { frac -= 0.5; - else if (t >= sntp[0]-1 || frac < 0.5) { + } else { frac += 0.5; --t; } - pvals[i*(nphi+1)] = .0f; + pvals[i*(nphi+1)] = phdiv[0]; for (j = 1; j < nphi; j++) { prob = (double)j / (double)nphi; rowp = &s_val(t,0); rowp1 = &s_val(t+1,0); - for (p = 0; p < sntp[1]; p++) { + for (p = 0; p < sntp[1]; p++) if ((prob -= (1.-frac)*rowp[p]/rowsum[t] + frac*rowp1[p]/rowsum[t+1]) <= .0) break; - if (p >= sntp[1]) - error(INTERNAL, - "code error 2 in init_ptable()"); - frac1 = 1. + prob/((1.-frac)*rowp[p]/rowsum[t] - + frac*rowp1[p]/rowsum[t+1]); - pvals[i*(nphi+1) + j] = (1.-frac1)*phdiv[p] + - frac1*phdiv[p+1]; + if (p >= sntp[1]) { /* should never happen? */ + p = sntp[1] - 1; + prob = .5; } + frac1 = 1. + prob/((1.-frac)*rowp[p]/rowsum[t] + + frac*rowp1[p]/rowsum[t+1]); + pvals[i*(nphi+1) + j] = (1.-frac1)*phdiv[p] + + frac1*phdiv[p+1]; } - pvals[i*(nphi+1) + nphi] = (float)(2.*PI); + pvals[i*(nphi+1) + nphi] = phdiv[sntp[1]]; } + /* duplicate final row */ + memcpy(pvals+ntheta*(nphi+1), pvals+(ntheta-1)*(nphi+1), + sizeof(*pvals)*(nphi+1)); tvals[0] = .0f; tvals[ntheta] = (float)tsize; } @@ -440,16 +473,18 @@ sens_val( int t, p; dv[2] = DOT(dvec, ourview.vdir); - theta = (float)((1./DEGREE) * acos(dv[2])); + theta = acos(dv[2]); if (theta >= maxtheta) return(.0f); dv[0] = DOT(dvec, ourview.hvec); dv[1] = DOT(dvec, ourview.vvec); - phi = (float)((1./DEGREE) * atan2(-dv[0], dv[1])); - while (phi < .0f) phi += 360.f; + phi = atan2(-dv[0], dv[1]); + while (phi < .0f) phi += (float)(2.*PI); t = (int)(theta/maxtheta * sntp[0]); - p = (int)(phi*(1./360.) * sntp[1]); + p = (int)(phi*(1./(2.*PI)) * sntp[1]); /* hack for non-uniform sensor grid */ + theta *= (float)(1./DEGREE); + phi *= (float)(1./DEGREE); while (t+1 < sntp[0] && theta >= s_theta(t+1)) ++t; while (t-1 >= 0 && theta <= s_theta(t-1)) @@ -461,6 +496,18 @@ sens_val( return(s_val(t,p)); } +/* Print origin and direction */ +static void +print_ray( + FVECT rorg, + FVECT rdir +) +{ + printf("%.6g %.6g %.6g %.8f %.8f %.8f\n", + rorg[0], rorg[1], rorg[2], + rdir[0], rdir[1], rdir[2]); +} + /* Compute sensor output */ static void comp_sensor( @@ -495,8 +542,12 @@ comp_sensor( get_direc(rr.rdir, (i+frandom())/nt, (j+frandom())/np); if (ourview.vfore > FTINY) VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore); + if (!ray_pnprocs) { + print_ray(rr.rorg, rr.rdir); + continue; + } rr.rmax = .0; - rayorigin(&rr, PRIMARY, NULL, NULL); + rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL); scalecolor(rr.rcoef, sf); if (ray_pqueue(&rr) == 1) addcolor(vsum, rr.rcol); @@ -507,12 +558,18 @@ comp_sensor( get_direc(rr.rdir, frandom(), frandom()); if (ourview.vfore > FTINY) VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore); + if (!ray_pnprocs) { + print_ray(rr.rorg, rr.rdir); + continue; + } rr.rmax = .0; - rayorigin(&rr, PRIMARY, NULL, NULL); + rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL); scalecolor(rr.rcoef, sf); if (ray_pqueue(&rr) == 1) addcolor(vsum, rr.rcol); } + if (!ray_pnprocs) /* just printing rays */ + return; /* scale partial result */ scalecolor(vsum, sf); /* add direct component */
