--- ray/src/util/rsensor.c 2008/02/21 01:22:06 2.1 +++ ray/src/util/rsensor.c 2008/02/22 21:52:10 2.4 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rsensor.c,v 2.1 2008/02/21 01:22:06 greg Exp $"; +static const char RCSid[] = "$Id: rsensor.c,v 2.4 2008/02/22 21:52:10 greg Exp $"; #endif /* @@ -26,7 +26,7 @@ VIEW ourview = STDVIEW; unsigned long nsamps = 10000; /* desired number of initial samples */ unsigned long nssamps = 9000; /* number of super-samples */ -int ndsamps = 16; /* number of direct samples */ +int ndsamps = 32; /* number of direct samples */ int nprocs = 1; /* number of rendering processes */ float *sensor = NULL; /* current sensor data */ @@ -38,11 +38,23 @@ int ntheta = 0; /* polar angle divisions */ int nphi = 0; /* azimuthal angle divisions */ double gscale = 1.; /* global scaling value */ +#define s_theta(t) sensor[(t+1)*(sntp[1]+1)] +#define s_phi(p) sensor[(p)+1] +#define s_val(t,p) sensor[(p)+1+(t+1)*(sntp[1]+1)] + static void comp_sensor(char *sfile); static void -print_defaults() +over_options() /* overriding options */ { + directvis = (ndsamps <= 0); + do_irrad = 0; +} + +static void +print_defaults() /* print out default parameters */ +{ + over_options(); printf("-n %-9d\t\t\t# number of processes\n", nprocs); printf("-rd %-9ld\t\t\t# ray directions\n", nsamps); /* printf("-rs %-9ld\t\t\t# ray super-samples\n", nssamps); */ @@ -64,34 +76,30 @@ main( ) { int doheader = 1; + int optwarn = 0; int i, rval; progname = argv[0]; /* set up rendering defaults */ - dstrsrc = 0.25; + rand_samp = 1; + dstrsrc = 0.5; + srcsizerat = 0.1; directrelay = 3; ambounce = 1; - /* just asking defaults? */ - if (argc == 2 && !strcmp(argv[1], "-defaults")) { - print_defaults(); - return(0); - } - /* check octree */ - if (argc < 2 || argv[argc-1][0] == '-') - error(USER, "missing octree argument"); + maxdepth = -10; /* get options from command line */ - for (i = 1; i < argc-1; i++) { + for (i = 1; i < argc; i++) { while ((rval = expandarg(&argc, &argv, i)) > 0) ; if (rval < 0) { sprintf(errmsg, "cannot expand '%s'", argv[i]); error(SYSTEM, errmsg); } - if (argv[i][0] != '-') { /* process a sensor file */ + if (argv[i][0] != '-') { + if (i >= argc-1) + break; /* final octree argument */ if (!ray_pnprocs) { - /* overriding options */ - directvis = (ndsamps <= 0); - do_irrad = 0; + over_options(); if (doheader) { /* print header */ printargs(argc, argv, stdout); fputformat("ascii", stdout); @@ -100,7 +108,7 @@ main( /* start process(es) */ ray_pinit(argv[argc-1], nprocs); } - comp_sensor(argv[i]); + comp_sensor(argv[i]); /* process a sensor file */ continue; } if (argv[i][1] == 'r') { /* sampling options */ @@ -143,12 +151,13 @@ main( sprintf(errmsg, "bad view option at '%s'", argv[i]); error(USER, errmsg); } - if (!strcmp(argv[i], "-w")) { /* turn off warnings */ - nowarn = 1; + if (!strcmp(argv[i], "-w")) { /* toggle warnings */ + nowarn = !nowarn; continue; } if (ray_pnprocs) { - error(WARNING, + if (!optwarn++) + error(WARNING, "rendering options should appear before first sensor"); } else if (!strcmp(argv[i], "-defaults")) { print_defaults(); @@ -171,6 +180,8 @@ main( } i += rval; } + if (!ray_pnprocs) + error(USER, i MAXNT) ntheta = MAXNT; nphi = samptot/ntheta; @@ -324,7 +335,7 @@ init_ptable( error(SYSTEM, "out of memory in init_ptable()"); gscale = .0; /* compute our inverse table */ for (i = 0; i < sntp[0]; i++) { - rowp = sensor + (i+1)*(sntp[1]+1) + 1; + rowp = &s_val(i,0); rowsum[i] = 0.; for (j = 0; j < sntp[1]; j++) rowsum[i] += *rowp++; @@ -332,8 +343,7 @@ init_ptable( rowomega[i] *= 2.*PI / (double)sntp[1]; gscale += rowsum[i] * rowomega[i]; } - tvals[0] = .0f; - for (i = 1; i < ntheta; i++) { + for (i = 0; i < ntheta; i++) { prob = (double)i / (double)ntheta; for (t = 0; t < sntp[0]; t++) if ((prob -= rowsum[t]*rowomega[t]/gscale) <= .0) @@ -343,26 +353,34 @@ init_ptable( frac = 1. + prob/(rowsum[t]*rowomega[t]/gscale); tvals[i] = 1. - ( (1.-frac)*cos(thdiv[t]) + frac*cos(thdiv[t+1]) ); + /* offset b/c sensor values are centered */ + if (t <= 0 || frac > 0.5) + frac -= 0.5; + else if (t >= sntp[0]-1 || frac < 0.5) { + frac += 0.5; + --t; + } pvals[i*(nphi+1)] = .0f; for (j = 1; j < nphi; j++) { prob = (double)j / (double)nphi; - rowp = sensor + t*(sntp[1]+1) + 1; - rowp1 = rowp + sntp[1]+1; + rowp = &s_val(t,0); + rowp1 = &s_val(t+1,0); for (p = 0; p < sntp[1]; p++) { - if ((prob -= (1.-frac)*rowp[p]/rowsum[t-1] + - frac*rowp1[p]/rowsum[t]) <= .0) + if ((prob -= (1.-frac)*rowp[p]/rowsum[t] + + frac*rowp1[p]/rowsum[t+1]) <= .0) break; if (p >= sntp[1]) error(INTERNAL, "code error 2 in init_ptable()"); - frac1 = 1. + prob/((1.-frac)*rowp[p]/rowsum[t-1] - + frac*rowp1[p]/rowsum[t]); + frac1 = 1. + prob/((1.-frac)*rowp[p]/rowsum[t] + + frac*rowp1[p]/rowsum[t+1]); pvals[i*(nphi+1) + j] = (1.-frac1)*phdiv[p] + frac1*phdiv[p+1]; } } pvals[i*(nphi+1) + nphi] = (float)(2.*PI); } + tvals[0] = .0f; tvals[ntheta] = (float)tsize; } @@ -418,15 +436,15 @@ sens_val( t = (int)(theta/maxtheta * sntp[0]); p = (int)(phi*(1./360.) * sntp[1]); /* hack for non-uniform sensor grid */ - while (t+1 < sntp[0] && theta >= sensor[(t+2)*(sntp[1]+1)]) + while (t+1 < sntp[0] && theta >= s_theta(t+1)) ++t; - while (t-1 >= 0 && theta < sensor[t*(sntp[1]+1)]) + while (t-1 >= 0 && theta <= s_theta(t-1)) --t; - while (p+1 < sntp[1] && phi >= sensor[p+2]) + while (p+1 < sntp[1] && phi >= s_phi(p+1)) ++p; - while (p-1 >= 0 && phi < sensor[p]) + while (p-1 >= 0 && phi <= s_phi(p-1)) --p; - return(sensor[t*(sntp[1]+1) + p + 1]); + return(s_val(t,p)); } /* Compute sensor output */ @@ -458,9 +476,8 @@ comp_sensor( VCOPY(rr.rorg, ourview.vp); rr.rmax = .0; for (i = 0; i < nt; i++) - for (j =0; j < np; j++) { - get_direc(rr.rdir, (i+frandom())/nt, - (j + frandom())/np); + for (j = 0; j < np; j++) { + get_direc(rr.rdir, (i+frandom())/nt, (j+frandom())/np); rayorigin(&rr, PRIMARY, NULL, NULL); if (ray_pqueue(&rr) == 1) addcolor(vsum, rr.rcol);
