--- ray/src/util/rsensor.c 2015/04/24 19:17:12 2.17 +++ ray/src/util/rsensor.c 2022/03/15 18:05:03 2.21 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rsensor.c,v 2.17 2015/04/24 19:17:12 greg Exp $"; +static const char RCSid[] = "$Id: rsensor.c,v 2.21 2022/03/15 18:05:03 greg Exp $"; #endif /* @@ -9,6 +9,7 @@ static const char RCSid[] = "$Id: rsensor.c,v 2.17 201 */ #include "ray.h" +#include "platform.h" #include "source.h" #include "view.h" #include "random.h" @@ -26,8 +27,7 @@ VIEW ourview = {VT_ANG,{0.,0.,0.},{0.,0.,1.},{1.,0., 1.,180.,180.,0.,0.,0.,0., {0.,0.,0.},{0.,0.,0.},0.,0.}; -unsigned long nsamps = 10000; /* desired number of initial samples */ -unsigned long nssamps = 9000; /* number of super-samples */ +long nsamps = 10000; /* desired number of initial samples */ int ndsamps = 32; /* number of direct samples */ int nprocs = 1; /* number of rendering processes */ @@ -59,7 +59,6 @@ print_defaults() /* print out default parameters */ over_options(); printf("-n %-9d\t\t\t# number of processes\n", nprocs); printf("-rd %-9ld\t\t\t# ray directions\n", nsamps); - /* printf("-rs %-9ld\t\t\t# ray super-samples\n", nssamps); */ printf("-dn %-9d\t\t\t# direct number of samples\n", ndsamps); printf("-vp %f %f %f\t# view point\n", ourview.vp[0], ourview.vp[1], ourview.vp[2]); @@ -77,7 +76,9 @@ quit(ec) /* make sure exit is called */ int ec; { if (ray_pnprocs > 0) /* close children if any */ - ray_pclose(0); + ray_pclose(0); + else if (ray_pnprocs < 0) + _exit(ec); /* avoid flush in child */ exit(ec); } @@ -129,8 +130,6 @@ main( if (argv[i][1] == 'r') { /* sampling options */ if (argv[i][2] == 'd') nsamps = atol(argv[++i]); - else if (argv[i][2] == 's') - nssamps = atol(argv[++i]); else { sprintf(errmsg, "bad option at '%s'", argv[i]); error(USER, errmsg); @@ -237,7 +236,7 @@ load_sensor( cp = fskip(cp); if (cp == NULL) break; - if (ntp[1] > 1 && sarr[ntp[1]+1] <= sarr[ntp[1]]) { + if (ntp[1] > 1 && sarr[ntp[1]+1] <= sarr[ntp[1]]+FTINY) { sprintf(errmsg, "Phi values not monotinically increasing in sensor file '%s'", sfile); @@ -303,10 +302,14 @@ load_sensor( else if (fabs(sarr[1]) > FTINY) sprintf(errmsg, "minimum phi must be 0 in sensor file '%s'", sfile); - else if (sarr[ntp[1]] <= FTINY) + else if (sarr[ntp[1]] < 270.-FTINY) sprintf(errmsg, - "maximum phi must be positive in sensor file '%s'", + "maximum phi must be 270 or greater in sensor file '%s'", sfile); + else if (sarr[ntp[1]] >= 360.-FTINY) + sprintf(errmsg, + "maximum phi must be less than 360 in sensor file '%s'", + sfile); if (errmsg[0]) error(USER, errmsg); return((float *)realloc((void *)sarr, sizeof(float)*nelem)); @@ -318,7 +321,7 @@ init_ptable( char *sfile ) { - int samptot = nsamps; + long samptot = nsamps; float *rowp, *rowp1; double rowsum[MAXNT], rowomega[MAXNT]; double thdiv[MAXNT+1], phdiv[MAXNP+1];
