--- ray/src/util/rsensor.c 2011/06/20 23:08:43 2.11 +++ ray/src/util/rsensor.c 2015/04/24 19:17:12 2.17 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rsensor.c,v 2.11 2011/06/20 23:08:43 greg Exp $"; +static const char RCSid[] = "$Id: rsensor.c,v 2.17 2015/04/24 19:17:12 greg Exp $"; #endif /* @@ -15,7 +15,7 @@ static const char RCSid[] = "$Id: rsensor.c,v 2.11 201 #define DEGREE (PI/180.) -#define MAXNT 180 /* maximum number of theta divisions */ +#define MAXNT 181 /* maximum number of theta divisions */ #define MAXNP 360 /* maximum number of phi divisions */ extern char *progname; /* global argv[0] */ @@ -209,6 +209,7 @@ load_sensor( { int warnedneg; char linebuf[8192]; + int last_pos_val = 0; int nelem = 1000; float *sarr = (float *)malloc(sizeof(float)*nelem); FILE *fp; @@ -262,17 +263,18 @@ load_sensor( cp = fskip(cp); if (cp == NULL) break; - if (i && sarr[i] < .0) { + if (sarr[i] < .0) { if (!warnedneg++) { sprintf(errmsg, "Negative value(s) in sensor file '%s' (ignored)\n", sfile); error(WARNING, errmsg); } sarr[i] = .0; - } + } else if (sarr[i] > FTINY && i > ntp[0]*(ntp[1]+1)) + last_pos_val = i; ++i; } - if (i == ntp[0]*(ntp[1]+1)) + if (i == ntp[0]*(ntp[1]+1)) /* empty line? */ break; if (ntp[0] > 1 && sarr[ntp[0]*(ntp[1]+1)] <= sarr[(ntp[0]-1)*(ntp[1]+1)]) { @@ -288,11 +290,13 @@ load_sensor( error(USER, errmsg); } } - nelem = i; + /* truncate zero region */ + ntp[0] = (last_pos_val + ntp[1])/(ntp[1]+1) - 1; + nelem = (ntp[0]+1)*(ntp[1]+1); fclose(fp); errmsg[0] = '\0'; /* sanity checks */ - if (ntp[0] <= 0) - sprintf(errmsg, "no data in sensor file '%s'", sfile); + if (!last_pos_val) + sprintf(errmsg, "no positive sensor values in file '%s'", sfile); else if (fabs(sarr[ntp[1]+1]) > FTINY) sprintf(errmsg, "minimum theta must be 0 in sensor file '%s'", sfile); @@ -303,10 +307,6 @@ load_sensor( sprintf(errmsg, "maximum phi must be positive in sensor file '%s'", sfile); - else if (sarr[ntp[0]*(ntp[1]+1)] <= FTINY) - sprintf(errmsg, - "maximum theta must be positive in sensor file '%s'", - sfile); if (errmsg[0]) error(USER, errmsg); return((float *)realloc((void *)sarr, sizeof(float)*nelem)); @@ -366,7 +366,7 @@ init_ptable( psize = PI*tsize/maxtheta; if (sntp[0]*sntp[1] < samptot) /* don't overdo resolution */ samptot = sntp[0]*sntp[1]; - ntheta = (int)(sqrt((double)samptot*tsize/psize) + 0.5); + ntheta = (int)(sqrt((double)samptot*tsize/psize)*sntp[0]/sntp[1]) + 1; if (ntheta > MAXNT) ntheta = MAXNT; nphi = samptot/ntheta; @@ -398,9 +398,9 @@ init_ptable( tvals[i] = 1. - ( (1.-frac)*cos(thdiv[t]) + frac*cos(thdiv[t+1]) ); /* offset b/c sensor values are centered */ - if (!t || (t < sntp[0]-1) & (frac >= 0.5)) + if ((t < sntp[0]-1) & (!t | (frac >= 0.5))) { frac -= 0.5; - else { + } else { frac += 0.5; --t; } @@ -424,6 +424,9 @@ init_ptable( } pvals[i*(nphi+1) + nphi] = phdiv[sntp[1]]; } + /* duplicate final row */ + memcpy(pvals+ntheta*(nphi+1), pvals+(ntheta-1)*(nphi+1), + sizeof(*pvals)*(nphi+1)); tvals[0] = .0f; tvals[ntheta] = (float)tsize; } @@ -544,7 +547,7 @@ comp_sensor( continue; } rr.rmax = .0; - rayorigin(&rr, PRIMARY, NULL, NULL); + rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL); scalecolor(rr.rcoef, sf); if (ray_pqueue(&rr) == 1) addcolor(vsum, rr.rcol); @@ -560,7 +563,7 @@ comp_sensor( continue; } rr.rmax = .0; - rayorigin(&rr, PRIMARY, NULL, NULL); + rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL); scalecolor(rr.rcoef, sf); if (ray_pqueue(&rr) == 1) addcolor(vsum, rr.rcol);
