--- ray/src/util/rsensor.c 2011/09/26 15:33:29 2.12 +++ ray/src/util/rsensor.c 2020/07/24 17:09:33 2.20 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rsensor.c,v 2.12 2011/09/26 15:33:29 greg Exp $"; +static const char RCSid[] = "$Id: rsensor.c,v 2.20 2020/07/24 17:09:33 greg Exp $"; #endif /* @@ -9,13 +9,14 @@ static const char RCSid[] = "$Id: rsensor.c,v 2.12 201 */ #include "ray.h" +#include "platform.h" #include "source.h" #include "view.h" #include "random.h" #define DEGREE (PI/180.) -#define MAXNT 180 /* maximum number of theta divisions */ +#define MAXNT 181 /* maximum number of theta divisions */ #define MAXNP 360 /* maximum number of phi divisions */ extern char *progname; /* global argv[0] */ @@ -77,7 +78,9 @@ quit(ec) /* make sure exit is called */ int ec; { if (ray_pnprocs > 0) /* close children if any */ - ray_pclose(0); + ray_pclose(0); + else if (ray_pnprocs < 0) + _exit(ec); /* avoid flush in child */ exit(ec); } @@ -209,6 +212,7 @@ load_sensor( { int warnedneg; char linebuf[8192]; + int last_pos_val = 0; int nelem = 1000; float *sarr = (float *)malloc(sizeof(float)*nelem); FILE *fp; @@ -236,7 +240,7 @@ load_sensor( cp = fskip(cp); if (cp == NULL) break; - if (ntp[1] > 1 && sarr[ntp[1]+1] <= sarr[ntp[1]]) { + if (ntp[1] > 1 && sarr[ntp[1]+1] <= sarr[ntp[1]]+FTINY) { sprintf(errmsg, "Phi values not monotinically increasing in sensor file '%s'", sfile); @@ -262,17 +266,18 @@ load_sensor( cp = fskip(cp); if (cp == NULL) break; - if (i && sarr[i] < .0) { + if (sarr[i] < .0) { if (!warnedneg++) { sprintf(errmsg, "Negative value(s) in sensor file '%s' (ignored)\n", sfile); error(WARNING, errmsg); } sarr[i] = .0; - } + } else if (sarr[i] > FTINY && i > ntp[0]*(ntp[1]+1)) + last_pos_val = i; ++i; } - if (i == ntp[0]*(ntp[1]+1)) + if (i == ntp[0]*(ntp[1]+1)) /* empty line? */ break; if (ntp[0] > 1 && sarr[ntp[0]*(ntp[1]+1)] <= sarr[(ntp[0]-1)*(ntp[1]+1)]) { @@ -288,24 +293,26 @@ load_sensor( error(USER, errmsg); } } - nelem = i; + /* truncate zero region */ + ntp[0] = (last_pos_val + ntp[1])/(ntp[1]+1) - 1; + nelem = (ntp[0]+1)*(ntp[1]+1); fclose(fp); errmsg[0] = '\0'; /* sanity checks */ - if (ntp[0] <= 0) - sprintf(errmsg, "no data in sensor file '%s'", sfile); + if (!last_pos_val) + sprintf(errmsg, "no positive sensor values in file '%s'", sfile); else if (fabs(sarr[ntp[1]+1]) > FTINY) sprintf(errmsg, "minimum theta must be 0 in sensor file '%s'", sfile); else if (fabs(sarr[1]) > FTINY) sprintf(errmsg, "minimum phi must be 0 in sensor file '%s'", sfile); - else if (sarr[ntp[1]] <= FTINY) + else if (sarr[ntp[1]] < 270.-FTINY) sprintf(errmsg, - "maximum phi must be positive in sensor file '%s'", + "maximum phi must be 270 or greater in sensor file '%s'", sfile); - else if (sarr[ntp[0]*(ntp[1]+1)] <= FTINY) + else if (sarr[ntp[1]] >= 360.-FTINY) sprintf(errmsg, - "maximum theta must be positive in sensor file '%s'", + "maximum phi must be less than 360 in sensor file '%s'", sfile); if (errmsg[0]) error(USER, errmsg); @@ -366,7 +373,7 @@ init_ptable( psize = PI*tsize/maxtheta; if (sntp[0]*sntp[1] < samptot) /* don't overdo resolution */ samptot = sntp[0]*sntp[1]; - ntheta = (int)(sqrt((double)samptot*tsize/psize) + 0.5); + ntheta = (int)(sqrt((double)samptot*tsize/psize)*sntp[0]/sntp[1]) + 1; if (ntheta > MAXNT) ntheta = MAXNT; nphi = samptot/ntheta; @@ -398,9 +405,9 @@ init_ptable( tvals[i] = 1. - ( (1.-frac)*cos(thdiv[t]) + frac*cos(thdiv[t+1]) ); /* offset b/c sensor values are centered */ - if (!t || (t < sntp[0]-1) & (frac >= 0.5)) + if ((t < sntp[0]-1) & (!t | (frac >= 0.5))) { frac -= 0.5; - else { + } else { frac += 0.5; --t; } @@ -424,6 +431,9 @@ init_ptable( } pvals[i*(nphi+1) + nphi] = phdiv[sntp[1]]; } + /* duplicate final row */ + memcpy(pvals+ntheta*(nphi+1), pvals+(ntheta-1)*(nphi+1), + sizeof(*pvals)*(nphi+1)); tvals[0] = .0f; tvals[ntheta] = (float)tsize; }
