root/Development/ray/src/util/rsensor.c
Revision: 2.24
Committed: Wed Apr 23 02:35:27 2025 UTC (7 months, 2 weeks ago) by greg
Changes since 2.23: +4 -1 lines
fix: Added missing calls to initfunc()
2 static const char RCSid[] = "$Id: rsensor.c,v 2.23 2023/12/16 03:30:35 greg Exp $";
4
5 /*
6 * Compute sensor signal based on spatial sensitivity.
7 *
8 * Created Feb 2008 for Architectural Energy Corp.
9 */
10
11 #include "ray.h"
12 #include "platform.h"
13 #include "source.h"
14 #include "func.h"
15 #include "view.h"
16 #include "random.h"
17
18 #define DEGREE (PI/180.)
19
20 #define MAXNT 181 /* maximum number of theta divisions */
21 #define MAXNP 360 /* maximum number of phi divisions */
22
23 extern char *progname; /* global argv[0] */
24 extern int nowarn; /* don't report warnings? */
25
26 /* current sensor's perspective */
27 VIEW ourview = {VT_ANG,{0.,0.,0.},{0.,0.,1.},{1.,0.,0.},
28 1.,180.,180.,0.,0.,0.,0.,
29 {0.,0.,0.},{0.,0.,0.},0.,0.};
30
31 long nsamps = 10000; /* desired number of initial samples */
32 int ndsamps = 32; /* number of direct samples */
33 int nprocs = 1; /* number of rendering processes */
34
35 float *sensor = NULL; /* current sensor data */
36 int sntp[2]; /* number of sensor theta and phi angles */
37 float maxtheta; /* maximum theta value for this sensor */
38 float tvals[MAXNT+1]; /* theta prob. values (1-D table of 1-cos(t)) */
39 float *pvals = NULL; /* phi prob. values (2-D table in radians) */
40 int ntheta = 0; /* polar angle divisions */
41 int nphi = 0; /* azimuthal angle divisions */
42 double gscale = 1.; /* global scaling value */
43
44 #define s_theta(t) sensor[(t+1)*(sntp[1]+1)]
45 #define s_phi(p) sensor[(p)+1]
46 #define s_val(t,p) sensor[(p)+1+(t+1)*(sntp[1]+1)]
47
48 static void comp_sensor(char *sfile);
49
50 static void
51 over_options() /* overriding options */
52 {
53 directvis = (ndsamps <= 0);
54 do_irrad = 0;
55 }
56
57 static void
58 print_defaults() /* print out default parameters */
59 {
60 over_options();
61 printf("-n %-9d\t\t\t# number of processes\n", nprocs);
62 printf("-rd %-9ld\t\t\t# ray directions\n", nsamps);
63 printf("-dn %-9d\t\t\t# direct number of samples\n", ndsamps);
64 printf("-vp %f %f %f\t# view point\n",
65 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
66 printf("-vd %f %f %f\t# view direction\n",
67 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
68 printf("-vu %f %f %f\t# view up\n",
69 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
70 printf("-vo %f\t\t\t# view fore clipping distance\n", ourview.vfore);
71 print_rdefaults();
72 }
73
74
75 void
76 quit(ec) /* make sure exit is called */
77 int ec;
78 {
79 if (ray_pnprocs > 0) /* close children if any */
80 ray_pclose(0);
81 else if (ray_pnprocs < 0)
82 _exit(ec); /* avoid flush in child */
83 exit(ec);
84 }
85
86
87 int
88 main(
89 int argc,
90 char *argv[]
91 )
92 {
93 int doheader = 1;
94 int optwarn = 0;
95 int i, rval;
96
97 progname = argv[0];
98 /* set up rendering defaults */
99 rand_samp = 1;
100 dstrsrc = 0.65;
101 srcsizerat = 0.1;
102 directrelay = 3;
103 ambounce = 1;
104 maxdepth = -10;
105 /* initialize calcomp routines */
106 initfunc();
107 /* get options from command line */
108 for (i = 1; i < argc; i++) {
109 while ((rval = expandarg(&argc, &argv, i)) > 0)
110 ;
111 if (rval < 0) {
112 sprintf(errmsg, "cannot expand '%s'", argv[i]);
113 error(SYSTEM, errmsg);
114 }
115 if (argv[i][0] != '-') {
116 if (i >= argc-1)
117 break; /* final octree argument */
118 if (!ray_pnprocs) {
119 over_options();
120 if (doheader) { /* print header */
121 newheader("RADIANCE", stdout);
122 printargs(argc, argv, stdout);
123 fputformat("ascii", stdout);
124 putchar('\n');
125 }
126 /* start process(es) */
127 if (strcmp(argv[argc-1], "."))
128 ray_pinit(argv[argc-1], nprocs);
129 }
130 comp_sensor(argv[i]); /* process a sensor file */
131 continue;
132 }
133 if (argv[i][1] == 'r') { /* sampling options */
134 if (argv[i][2] == 'd')
135 nsamps = atol(argv[++i]);
136 else {
137 sprintf(errmsg, "bad option at '%s'", argv[i]);
138 error(USER, errmsg);
139 }
140 continue;
141 }
142 /* direct component samples */
143 if (argv[i][1] == 'd' && argv[i][2] == 'n') {
144 ndsamps = atoi(argv[++i]);
145 continue;
146 }
147 if (argv[i][1] == 'v') { /* next sensor view */
148 if (argv[i][2] == 'f') {
149 rval = viewfile(argv[++i], &ourview, NULL);
150 if (rval < 0) {
151 sprintf(errmsg,
152 "cannot open view file \"%s\"",
153 argv[i]);
154 error(SYSTEM, errmsg);
155 } else if (rval == 0) {
156 sprintf(errmsg,
157 "bad view file \"%s\"",
158 argv[i]);
159 error(USER, errmsg);
160 }
161 continue;
162 }
163 rval = getviewopt(&ourview, argc-i, argv+i);
164 if (rval >= 0) {
165 i += rval;
166 continue;
167 }
168 sprintf(errmsg, "bad view option at '%s'", argv[i]);
169 error(USER, errmsg);
170 }
171 if (!strcmp(argv[i], "-w")) { /* toggle warnings */
172 nowarn = !nowarn;
173 continue;
174 }
175 if (ray_pnprocs) {
176 if (!optwarn++)
177 error(WARNING,
178 "rendering options should appear before first sensor");
179 } else if (!strcmp(argv[i], "-defaults")) {
180 print_defaults();
181 return(0);
182 }
183 if (argv[i][1] == 'h') { /* header toggle */
184 doheader = !doheader;
185 continue;
186 }
187 if (!strcmp(argv[i], "-n")) { /* number of processes */
188 nprocs = atoi(argv[++i]);
189 if (nprocs <= 0)
190 error(USER, "illegal number of processes");
191 continue;
192 }
193 rval = getrenderopt(argc-i, argv+i);
194 if (rval < 0) {
195 sprintf(errmsg, "bad render option at '%s'", argv[i]);
196 error(USER, errmsg);
197 }
198 i += rval;
199 }
200 if (sensor == NULL)
201 error(USER, i<argc ? "missing sensor file" : "missing octree");
202 quit(0);
203 }
204
205 /* Load sensor sensitivities (first row and column are angles) */
206 static float *
207 load_sensor(
208 int ntp[2],
209 char *sfile
210 )
211 {
212 int warnedneg;
213 char linebuf[8192];
214 int last_pos_val = 0;
215 int nelem = 1000;
216 float *sarr = (float *)malloc(sizeof(float)*nelem);
217 FILE *fp;
218 char *cp;
219 int i;
220
221 fp = frlibopen(sfile);
222 if (fp == NULL) {
223 sprintf(errmsg, "cannot open sensor file '%s'", sfile);
224 error(SYSTEM, errmsg);
225 }
226 fgets(linebuf, sizeof(linebuf), fp);
227 if (!strncmp(linebuf, "Elevation ", 10))
228 fgets(linebuf, sizeof(linebuf), fp);
229 /* get phi values */
230 sarr[0] = .0f;
231 if (strncmp(linebuf, "degrees", 7)) {
232 sprintf(errmsg, "Missing 'degrees' in sensor file '%s'", sfile);
233 error(USER, errmsg);
234 }
235 cp = sskip(linebuf);
236 ntp[1] = 0;
237 for ( ; ; ) {
238 sarr[ntp[1]+1] = atof(cp);
239 cp = fskip(cp);
240 if (cp == NULL)
241 break;
242 if (ntp[1] > 1 && sarr[ntp[1]+1] <= sarr[ntp[1]]+FTINY) {
243 sprintf(errmsg,
244 "Phi values not monotinically increasing in sensor file '%s'",
245 sfile);
246 error(USER, errmsg);
247 }
248 ++ntp[1];
249 }
250 warnedneg = 0;
251 ntp[0] = 0; /* get thetas + data */
252 while (fgets(linebuf, sizeof(linebuf), fp) != NULL) {
253 ++ntp[0];
254 if ((ntp[0]+1)*(ntp[1]+1) > nelem) {
255 nelem += (nelem>>2) + ntp[1];
256 sarr = (float *)realloc((void *)sarr,
257 sizeof(float)*nelem);
258 if (sarr == NULL)
259 error(SYSTEM, "out of memory in load_sensor()");
260 }
261 cp = linebuf;
262 i = ntp[0]*(ntp[1]+1);
263 for ( ; ; ) {
264 sarr[i] = atof(cp);
265 cp = fskip(cp);
266 if (cp == NULL)
267 break;
268 if (sarr[i] < .0) {
269 if (!warnedneg++) {
270 sprintf(errmsg,
271 "Negative value(s) in sensor file '%s' (ignored)\n", sfile);
272 error(WARNING, errmsg);
273 }
274 sarr[i] = .0;
275 } else if (sarr[i] > FTINY && i > ntp[0]*(ntp[1]+1))
276 last_pos_val = i;
277 ++i;
278 }
279 if (i == ntp[0]*(ntp[1]+1)) /* empty line? */
280 break;
281 if (ntp[0] > 1 && sarr[ntp[0]*(ntp[1]+1)] <=
282 sarr[(ntp[0]-1)*(ntp[1]+1)]) {
283 sprintf(errmsg,
284 "Theta values not monotinically increasing in sensor file '%s'",
285 sfile);
286 error(USER, errmsg);
287 }
288 if (i != (ntp[0]+1)*(ntp[1]+1)) {
289 sprintf(errmsg,
290 "bad column count near line %d in sensor file '%s'",
291 ntp[0]+1, sfile);
292 error(USER, errmsg);
293 }
294 }
295 /* truncate zero region */
296 ntp[0] = (last_pos_val + ntp[1])/(ntp[1]+1) - 1;
297 nelem = (ntp[0]+1)*(ntp[1]+1);
298 fclose(fp);
299 errmsg[0] = '\0'; /* sanity checks */
300 if (!last_pos_val)
301 sprintf(errmsg, "no positive sensor values in file '%s'", sfile);
302 else if (fabs(sarr[ntp[1]+1]) > FTINY)
303 sprintf(errmsg, "minimum theta must be 0 in sensor file '%s'",
304 sfile);
305 else if (fabs(sarr[1]) > FTINY)
306 sprintf(errmsg, "minimum phi must be 0 in sensor file '%s'",
307 sfile);
308 else if (sarr[ntp[1]] < 270.-FTINY)
309 sprintf(errmsg,
310 "maximum phi must be 270 or greater in sensor file '%s'",
311 sfile);
312 else if (sarr[ntp[1]] >= 360.-FTINY)
313 sprintf(errmsg,
314 "maximum phi must be less than 360 in sensor file '%s'",
315 sfile);
316 if (errmsg[0])
317 error(USER, errmsg);
318 return((float *)realloc((void *)sarr, sizeof(float)*nelem));
319 }
320
321 /* Initialize probability table */
322 static void
323 init_ptable(
324 char *sfile
325 )
326 {
327 long samptot = nsamps;
328 float *rowp, *rowp1;
329 double rowsum[MAXNT], rowomega[MAXNT];
330 double thdiv[MAXNT+1], phdiv[MAXNP+1];
331 double tsize, psize;
332 double prob, frac, frac1;
333 int i, j, t, p;
334 /* free old table */
335 if (sensor != NULL)
336 free((void *)sensor);
337 if (pvals != NULL)
338 free((void *)pvals);
339 if (sfile == NULL || !*sfile) {
340 sensor = NULL;
341 sntp[0] = sntp[1] = 0;
342 pvals = NULL;
343 ntheta = nphi = 0;
344 return;
345 }
346 /* load sensor table */
347 sensor = load_sensor(sntp, sfile);
348 if (sntp[0] > MAXNT) {
349 sprintf(errmsg, "Too many theta rows in sensor file '%s'",
350 sfile);
351 error(INTERNAL, errmsg);
352 }
353 if (sntp[1] > MAXNP) {
354 sprintf(errmsg, "Too many phi columns in sensor file '%s'",
355 sfile);
356 error(INTERNAL, errmsg);
357 }
358 /* compute boundary angles */
359 maxtheta = DEGREE*(1.5f*s_theta(sntp[0]-1) - 0.5f*s_theta(sntp[0]-2));
360 if (maxtheta > PI)
361 maxtheta = PI;
362 thdiv[0] = .0;
363 for (t = 1; t < sntp[0]; t++)
364 thdiv[t] = DEGREE/2.*(s_theta(t-1) + s_theta(t));
365 thdiv[sntp[0]] = maxtheta;
366 phdiv[0] = DEGREE*(1.5f*s_phi(0) - 0.5f*s_phi(1));
367 for (p = 1; p < sntp[1]; p++)
368 phdiv[p] = DEGREE/2.*(s_phi(p-1) + s_phi(p));
369 phdiv[sntp[1]] = DEGREE*(1.5f*s_phi(sntp[1]-1) - 0.5f*s_phi(sntp[1]-2));
370 /* size our table */
371 tsize = 1. - cos(maxtheta);
372 psize = PI*tsize/maxtheta;
373 if (sntp[0]*sntp[1] < samptot) /* don't overdo resolution */
374 samptot = sntp[0]*sntp[1];
375 ntheta = (int)(sqrt((double)samptot*tsize/psize)*sntp[0]/sntp[1]) + 1;
376 if (ntheta > MAXNT)
377 ntheta = MAXNT;
378 nphi = samptot/ntheta;
379 pvals = (float *)malloc(sizeof(float)*(ntheta+1)*(nphi+1));
380 if (pvals == NULL)
381 error(SYSTEM, "out of memory in init_ptable()");
382 gscale = .0; /* compute our inverse table */
383 for (i = 0; i < sntp[0]; i++) {
384 rowp = &s_val(i,0);
385 rowsum[i] = 1e-20;
386 for (j = 0; j < sntp[1]; j++)
387 rowsum[i] += *rowp++;
388 rowomega[i] = cos(thdiv[i]) - cos(thdiv[i+1]);
389 rowomega[i] *= 2.*PI / (double)sntp[1];
390 gscale += rowsum[i] * rowomega[i];
391 }
392 if (gscale <= FTINY) {
393 sprintf(errmsg, "Sensor values sum to zero in file '%s'", sfile);
394 error(USER, errmsg);
395 }
396 for (i = 0; i < ntheta; i++) {
397 prob = (double)i / (double)ntheta;
398 for (t = 0; t < sntp[0]; t++)
399 if ((prob -= rowsum[t]*rowomega[t]/gscale) <= .0)
400 break;
401 if (t >= sntp[0])
402 error(INTERNAL, "code error 1 in init_ptable()");
403 frac = 1. + prob/(rowsum[t]*rowomega[t]/gscale);
404 tvals[i] = 1. - ( (1.-frac)*cos(thdiv[t]) +
405 frac*cos(thdiv[t+1]) );
406 /* offset b/c sensor values are centered */
407 if ((t < sntp[0]-1) & (!t | (frac >= 0.5))) {
408 frac -= 0.5;
409 } else {
410 frac += 0.5;
411 --t;
412 }
413 pvals[i*(nphi+1)] = phdiv[0];
414 for (j = 1; j < nphi; j++) {
415 prob = (double)j / (double)nphi;
416 rowp = &s_val(t,0);
417 rowp1 = &s_val(t+1,0);
418 for (p = 0; p < sntp[1]; p++)
419 if ((prob -= (1.-frac)*rowp[p]/rowsum[t] +
420 frac*rowp1[p]/rowsum[t+1]) <= .0)
421 break;
422 if (p >= sntp[1]) { /* should never happen? */
423 p = sntp[1] - 1;
424 prob = .5;
425 }
426 frac1 = 1. + prob/((1.-frac)*rowp[p]/rowsum[t]
427 + frac*rowp1[p]/rowsum[t+1]);
428 pvals[i*(nphi+1) + j] = (1.-frac1)*phdiv[p] +
429 frac1*phdiv[p+1];
430 }
431 pvals[i*(nphi+1) + nphi] = phdiv[sntp[1]];
432 }
433 /* duplicate final row */
434 memcpy(pvals+ntheta*(nphi+1), pvals+(ntheta-1)*(nphi+1),
435 sizeof(*pvals)*(nphi+1));
436 tvals[0] = .0f;
437 tvals[ntheta] = (float)tsize;
438 }
439
440 /* Get normalized direction from random variables in [0,1) range */
441 static void
442 get_direc(
443 FVECT dvec,
444 double x,
445 double y
446 )
447 {
448 double xfrac = x*ntheta;
449 int tndx = (int)xfrac;
450 double yfrac = y*nphi;
451 int pndx = (int)yfrac;
452 double rad, phi;
453 FVECT dv;
454 int i;
455
456 xfrac -= (double)tndx;
457 yfrac -= (double)pndx;
458 pndx += tndx*(nphi+1);
459
460 dv[2] = 1. - ((1.-xfrac)*tvals[tndx] + xfrac*tvals[tndx+1]);
461 rad = sqrt(1. - dv[2]*dv[2]);
462 phi = (1.-yfrac)*pvals[pndx] + yfrac*pvals[pndx+1];
463 dv[0] = -rad*sin(phi);
464 dv[1] = rad*cos(phi);
465 for (i = 3; i--; )
466 dvec[i] = dv[0]*ourview.hvec[i] +
467 dv[1]*ourview.vvec[i] +
468 dv[2]*ourview.vdir[i] ;
469 }
470
471 /* Get sensor value in the specified direction (normalized) */
472 static float
473 sens_val(
474 FVECT dvec
475 )
476 {
477 FVECT dv;
478 float theta, phi;
479 int t, p;
480
481 dv[2] = DOT(dvec, ourview.vdir);
482 theta = acos(dv[2]);
483 if (theta >= maxtheta)
484 return(.0f);
485 dv[0] = DOT(dvec, ourview.hvec);
486 dv[1] = DOT(dvec, ourview.vvec);
487 phi = atan2(-dv[0], dv[1]);
488 while (phi < .0f) phi += (float)(2.*PI);
489 t = (int)(theta/maxtheta * sntp[0]);
490 p = (int)(phi*(1./(2.*PI)) * sntp[1]);
491 /* hack for non-uniform sensor grid */
492 theta *= (float)(1./DEGREE);
493 phi *= (float)(1./DEGREE);
494 while (t+1 < sntp[0] && theta >= s_theta(t+1))
495 ++t;
496 while (t-1 >= 0 && theta <= s_theta(t-1))
497 --t;
498 while (p+1 < sntp[1] && phi >= s_phi(p+1))
499 ++p;
500 while (p-1 >= 0 && phi <= s_phi(p-1))
501 --p;
502 return(s_val(t,p));
503 }
504
505 /* Print origin and direction */
506 static void
507 print_ray(
508 FVECT rorg,
509 FVECT rdir
510 )
511 {
512 printf("%.6g %.6g %.6g %.8f %.8f %.8f\n",
513 rorg[0], rorg[1], rorg[2],
514 rdir[0], rdir[1], rdir[2]);
515 }
516
517 /* Compute sensor output */
518 static void
519 comp_sensor(
520 char *sfile
521 )
522 {
523 int ndirs = dstrsrc > FTINY ? ndsamps :
524 ndsamps > 0 ? 1 : 0;
525 char *err;
526 int nt, np;
527 SCOLOR vsum;
528 RAY rr;
529 double sf;
530 int i, j;
531 /* set view */
532 ourview.type = VT_ANG;
533 ourview.horiz = ourview.vert = 180.;
534 ourview.hoff = ourview.voff = .0;
535 err = setview(&ourview);
536 if (err != NULL)
537 error(USER, err);
538 /* assign probability table */
539 init_ptable(sfile);
540 /* stratified MC sampling */
541 scolorblack(vsum);
542 nt = (int)(sqrt((double)nsamps*ntheta/nphi) + .5);
543 np = nsamps/nt;
544 sf = gscale/nsamps;
545 for (i = 0; i < nt; i++)
546 for (j = 0; j < np; j++) {
547 VCOPY(rr.rorg, ourview.vp);
548 get_direc(rr.rdir, (i+frandom())/nt, (j+frandom())/np);
549 if (ourview.vfore > FTINY)
550 VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore);
551 if (!ray_pnprocs) {
552 print_ray(rr.rorg, rr.rdir);
553 continue;
554 }
555 rr.rmax = .0;
556 rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL);
557 scalescolor(rr.rcoef, sf);
558 if (ray_pqueue(&rr) == 1)
559 saddscolor(vsum, rr.rcol);
560 }
561 /* remaining rays pure MC */
562 for (i = nsamps - nt*np; i-- > 0; ) {
563 VCOPY(rr.rorg, ourview.vp);
564 get_direc(rr.rdir, frandom(), frandom());
565 if (ourview.vfore > FTINY)
566 VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore);
567 if (!ray_pnprocs) {
568 print_ray(rr.rorg, rr.rdir);
569 continue;
570 }
571 rr.rmax = .0;
572 rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL);
573 scalescolor(rr.rcoef, sf);
574 if (ray_pqueue(&rr) == 1)
575 saddscolor(vsum, rr.rcol);
576 }
577 if (!ray_pnprocs) /* just printing rays */
578 return;
579 /* scale partial result */
580 scalescolor(vsum, sf);
581 /* add direct component */
582 for (i = ndirs; i-- > 0; ) {
583 SRCINDEX si;
584 initsrcindex(&si);
585 while (srcray(&rr, NULL, &si)) {
586 sf = sens_val(rr.rdir);
587 if (sf <= FTINY)
588 continue;
589 sf *= si.dom/ndirs;
590 scalescolor(rr.rcoef, sf);
591 if (ray_pqueue(&rr) == 1) {
592 smultscolor(rr.rcol, rr.rcoef);
593 saddscolor(vsum, rr.rcol);
594 }
595 }
596 }
597 while (ray_presult(&rr, 0) > 0) { /* finish our calculation */
598 smultscolor(rr.rcol, rr.rcoef);
599 saddscolor(vsum, rr.rcol);
600 }
601 for (i = 0; i < NCSAMP; i++) /* print our result */
602 printf(" %.4e", vsum[i]);
603 fputc('\n', stdout);
604 }
