| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rsensor.c,v 2.18 2015/06/09 21:34:15 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
| 6 |
* Compute sensor signal based on spatial sensitivity.
| 7 |
| 8 |
* Created Feb 2008 for Architectural Energy Corp.
| 9 |
| 10 |
| 11 |
#include "ray.h"
| 12 |
#include "source.h"
| 13 |
#include "view.h"
| 14 |
#include "random.h"
| 15 |
| 16 |
#define DEGREE (PI/180.)
| 17 |
| 18 |
#define MAXNT 181 /* maximum number of theta divisions */
| 19 |
#define MAXNP 360 /* maximum number of phi divisions */
| 20 |
| 21 |
extern char *progname; /* global argv[0] */
| 22 |
extern int nowarn; /* don't report warnings? */
| 23 |
| 24 |
/* current sensor's perspective */
| 25 |
VIEW ourview = {VT_ANG,{0.,0.,0.},{0.,0.,1.},{1.,0.,0.},
| 26 |
1.,180.,180.,0.,0.,0.,0.,
| 27 |
{0.,0.,0.},{0.,0.,0.},0.,0.};
| 28 |
| 29 |
unsigned long nsamps = 10000; /* desired number of initial samples */
| 30 |
unsigned long nssamps = 9000; /* number of super-samples */
| 31 |
int ndsamps = 32; /* number of direct samples */
| 32 |
int nprocs = 1; /* number of rendering processes */
| 33 |
| 34 |
float *sensor = NULL; /* current sensor data */
| 35 |
int sntp[2]; /* number of sensor theta and phi angles */
| 36 |
float maxtheta; /* maximum theta value for this sensor */
| 37 |
float tvals[MAXNT+1]; /* theta prob. values (1-D table of 1-cos(t)) */
| 38 |
float *pvals = NULL; /* phi prob. values (2-D table in radians) */
| 39 |
int ntheta = 0; /* polar angle divisions */
| 40 |
int nphi = 0; /* azimuthal angle divisions */
| 41 |
double gscale = 1.; /* global scaling value */
| 42 |
| 43 |
#define s_theta(t) sensor[(t+1)*(sntp[1]+1)]
| 44 |
#define s_phi(p) sensor[(p)+1]
| 45 |
#define s_val(t,p) sensor[(p)+1+(t+1)*(sntp[1]+1)]
| 46 |
| 47 |
static void comp_sensor(char *sfile);
| 48 |
| 49 |
static void
| 50 |
over_options() /* overriding options */
| 51 |
| 52 |
directvis = (ndsamps <= 0);
| 53 |
do_irrad = 0;
| 54 |
| 55 |
| 56 |
static void
| 57 |
print_defaults() /* print out default parameters */
| 58 |
| 59 |
over_options();
| 60 |
printf("-n %-9d\t\t\t# number of processes\n", nprocs);
| 61 |
printf("-rd %-9ld\t\t\t# ray directions\n", nsamps);
| 62 |
/* printf("-rs %-9ld\t\t\t# ray super-samples\n", nssamps); */
| 63 |
printf("-dn %-9d\t\t\t# direct number of samples\n", ndsamps);
| 64 |
printf("-vp %f %f %f\t# view point\n",
| 65 |
ourview.vp[0], ourview.vp[1], ourview.vp[2]);
| 66 |
printf("-vd %f %f %f\t# view direction\n",
| 67 |
ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
| 68 |
printf("-vu %f %f %f\t# view up\n",
| 69 |
ourview.vup[0], ourview.vup[1], ourview.vup[2]);
| 70 |
printf("-vo %f\t\t\t# view fore clipping distance\n", ourview.vfore);
| 71 |
print_rdefaults();
| 72 |
| 73 |
| 74 |
| 75 |
void
| 76 |
quit(ec) /* make sure exit is called */
| 77 |
int ec;
| 78 |
| 79 |
if (ray_pnprocs > 0) /* close children if any */
| 80 |
ray_pclose(0);
| 81 |
else if (ray_pnprocs < 0)
| 82 |
_exit(ec); /* avoid flush in child */
| 83 |
exit(ec);
| 84 |
| 85 |
| 86 |
| 87 |
int
| 88 |
main(
| 89 |
int argc,
| 90 |
char *argv[]
| 91 |
| 92 |
| 93 |
int doheader = 1;
| 94 |
int optwarn = 0;
| 95 |
int i, rval;
| 96 |
| 97 |
progname = argv[0];
| 98 |
/* set up rendering defaults */
| 99 |
rand_samp = 1;
| 100 |
dstrsrc = 0.65;
| 101 |
srcsizerat = 0.1;
| 102 |
directrelay = 3;
| 103 |
ambounce = 1;
| 104 |
maxdepth = -10;
| 105 |
/* get options from command line */
| 106 |
for (i = 1; i < argc; i++) {
| 107 |
while ((rval = expandarg(&argc, &argv, i)) > 0)
| 108 |
| 109 |
if (rval < 0) {
| 110 |
sprintf(errmsg, "cannot expand '%s'", argv[i]);
| 111 |
error(SYSTEM, errmsg);
| 112 |
| 113 |
if (argv[i][0] != '-') {
| 114 |
if (i >= argc-1)
| 115 |
break; /* final octree argument */
| 116 |
if (!ray_pnprocs) {
| 117 |
over_options();
| 118 |
if (doheader) { /* print header */
| 119 |
newheader("RADIANCE", stdout);
| 120 |
printargs(argc, argv, stdout);
| 121 |
fputformat("ascii", stdout);
| 122 |
putchar('\n');
| 123 |
| 124 |
/* start process(es) */
| 125 |
if (strcmp(argv[argc-1], "."))
| 126 |
ray_pinit(argv[argc-1], nprocs);
| 127 |
| 128 |
comp_sensor(argv[i]); /* process a sensor file */
| 129 |
continue;
| 130 |
| 131 |
if (argv[i][1] == 'r') { /* sampling options */
| 132 |
if (argv[i][2] == 'd')
| 133 |
nsamps = atol(argv[++i]);
| 134 |
else if (argv[i][2] == 's')
| 135 |
nssamps = atol(argv[++i]);
| 136 |
else {
| 137 |
sprintf(errmsg, "bad option at '%s'", argv[i]);
| 138 |
error(USER, errmsg);
| 139 |
| 140 |
continue;
| 141 |
| 142 |
/* direct component samples */
| 143 |
if (argv[i][1] == 'd' && argv[i][2] == 'n') {
| 144 |
ndsamps = atoi(argv[++i]);
| 145 |
continue;
| 146 |
| 147 |
if (argv[i][1] == 'v') { /* next sensor view */
| 148 |
if (argv[i][2] == 'f') {
| 149 |
rval = viewfile(argv[++i], &ourview, NULL);
| 150 |
if (rval < 0) {
| 151 |
sprintf(errmsg,
| 152 |
"cannot open view file \"%s\"",
| 153 |
argv[i]);
| 154 |
| 155 |
} else if (rval == 0) {
| 156 |
sprintf(errmsg,
| 157 |
"bad view file \"%s\"",
| 158 |
argv[i]);
| 159 |
| 160 |
| 161 |
continue;
| 162 |
| 163 |
rval = getviewopt(&ourview, argc-i, argv+i);
| 164 |
if (rval >= 0) {
| 165 |
i += rval;
| 166 |
continue;
| 167 |
| 168 |
sprintf(errmsg, "bad view option at '%s'", argv[i]);
| 169 |
| 170 |
| 171 |
if (!strcmp(argv[i], "-w")) { /* toggle warnings */
| 172 |
nowarn = !nowarn;
| 173 |
continue;
| 174 |
| 175 |
if (ray_pnprocs) {
| 176 |
if (!optwarn++)
| 177 |
error(WARNING,
| 178 |
"rendering options should appear before first sensor");
| 179 |
} else if (!strcmp(argv[i], "-defaults")) {
| 180 |
print_defaults();
| 181 |
return(0);
| 182 |
| 183 |
if (argv[i][1] == 'h') { /* header toggle */
| 184 |
doheader = !doheader;
| 185 |
continue;
| 186 |
| 187 |
if (!strcmp(argv[i], "-n")) { /* number of processes */
| 188 |
nprocs = atoi(argv[++i]);
| 189 |
if (nprocs <= 0)
| 190 |
error(USER, "illegal number of processes");
| 191 |
continue;
| 192 |
| 193 |
rval = getrenderopt(argc-i, argv+i);
| 194 |
if (rval < 0) {
| 195 |
sprintf(errmsg, "bad render option at '%s'", argv[i]);
| 196 |
| 197 |
| 198 |
i += rval;
| 199 |
| 200 |
if (sensor == NULL)
| 201 |
error(USER, i<argc ? "missing sensor file" : "missing octree");
| 202 |
quit(0);
| 203 |
| 204 |
| 205 |
/* Load sensor sensitivities (first row and column are angles) */
| 206 |
static float *
| 207 |
load_sensor(
| 208 |
int ntp[2],
| 209 |
char *sfile
| 210 |
| 211 |
| 212 |
int warnedneg;
| 213 |
char linebuf[8192];
| 214 |
int last_pos_val = 0;
| 215 |
int nelem = 1000;
| 216 |
float *sarr = (float *)malloc(sizeof(float)*nelem);
| 217 |
FILE *fp;
| 218 |
char *cp;
| 219 |
int i;
| 220 |
| 221 |
fp = frlibopen(sfile);
| 222 |
if (fp == NULL) {
| 223 |
sprintf(errmsg, "cannot open sensor file '%s'", sfile);
| 224 |
| 225 |
| 226 |
fgets(linebuf, sizeof(linebuf), fp);
| 227 |
if (!strncmp(linebuf, "Elevation ", 10))
| 228 |
| 229 |
/* get phi values */
| 230 |
sarr[0] = .0f;
| 231 |
if (strncmp(linebuf, "degrees", 7)) {
| 232 |
sprintf(errmsg, "Missing 'degrees' in sensor file '%s'", sfile);
| 233 |
| 234 |
| 235 |
cp = sskip(linebuf);
| 236 |
ntp[1] = 0;
| 237 |
for ( ; ; ) {
| 238 |
sarr[ntp[1]+1] = atof(cp);
| 239 |
cp = fskip(cp);
| 240 |
if (cp == NULL)
| 241 |
break;
| 242 |
if (ntp[1] > 1 && sarr[ntp[1]+1] <= sarr[ntp[1]]+FTINY) {
| 243 |
sprintf(errmsg,
| 244 |
"Phi values not monotinically increasing in sensor file '%s'",
| 245 |
sfile);
| 246 |
| 247 |
| 248 |
++ntp[1];
| 249 |
| 250 |
warnedneg = 0;
| 251 |
ntp[0] = 0; /* get thetas + data */
| 252 |
while (fgets(linebuf, sizeof(linebuf), fp) != NULL) {
| 253 |
++ntp[0];
| 254 |
if ((ntp[0]+1)*(ntp[1]+1) > nelem) {
| 255 |
nelem += (nelem>>2) + ntp[1];
| 256 |
sarr = (float *)realloc((void *)sarr,
| 257 |
| 258 |
if (sarr == NULL)
| 259 |
error(SYSTEM, "out of memory in load_sensor()");
| 260 |
| 261 |
cp = linebuf;
| 262 |
i = ntp[0]*(ntp[1]+1);
| 263 |
for ( ; ; ) {
| 264 |
sarr[i] = atof(cp);
| 265 |
cp = fskip(cp);
| 266 |
if (cp == NULL)
| 267 |
break;
| 268 |
if (sarr[i] < .0) {
| 269 |
if (!warnedneg++) {
| 270 |
sprintf(errmsg,
| 271 |
"Negative value(s) in sensor file '%s' (ignored)\n", sfile);
| 272 |
error(WARNING, errmsg);
| 273 |
| 274 |
sarr[i] = .0;
| 275 |
} else if (sarr[i] > FTINY && i > ntp[0]*(ntp[1]+1))
| 276 |
last_pos_val = i;
| 277 |
++i;
| 278 |
| 279 |
if (i == ntp[0]*(ntp[1]+1)) /* empty line? */
| 280 |
break;
| 281 |
if (ntp[0] > 1 && sarr[ntp[0]*(ntp[1]+1)] <=
| 282 |
sarr[(ntp[0]-1)*(ntp[1]+1)]) {
| 283 |
sprintf(errmsg,
| 284 |
"Theta values not monotinically increasing in sensor file '%s'",
| 285 |
sfile);
| 286 |
| 287 |
| 288 |
if (i != (ntp[0]+1)*(ntp[1]+1)) {
| 289 |
sprintf(errmsg,
| 290 |
"bad column count near line %d in sensor file '%s'",
| 291 |
ntp[0]+1, sfile);
| 292 |
| 293 |
| 294 |
| 295 |
/* truncate zero region */
| 296 |
ntp[0] = (last_pos_val + ntp[1])/(ntp[1]+1) - 1;
| 297 |
nelem = (ntp[0]+1)*(ntp[1]+1);
| 298 |
fclose(fp);
| 299 |
errmsg[0] = '\0'; /* sanity checks */
| 300 |
if (!last_pos_val)
| 301 |
sprintf(errmsg, "no positive sensor values in file '%s'", sfile);
| 302 |
else if (fabs(sarr[ntp[1]+1]) > FTINY)
| 303 |
sprintf(errmsg, "minimum theta must be 0 in sensor file '%s'",
| 304 |
sfile);
| 305 |
else if (fabs(sarr[1]) > FTINY)
| 306 |
sprintf(errmsg, "minimum phi must be 0 in sensor file '%s'",
| 307 |
sfile);
| 308 |
else if (sarr[ntp[1]] < 270.-FTINY)
| 309 |
sprintf(errmsg,
| 310 |
"maximum phi must be 270 or greater in sensor file '%s'",
| 311 |
sfile);
| 312 |
else if (sarr[ntp[1]] >= 360.-FTINY)
| 313 |
sprintf(errmsg,
| 314 |
"maximum phi must be less than 360 in sensor file '%s'",
| 315 |
sfile);
| 316 |
if (errmsg[0])
| 317 |
| 318 |
return((float *)realloc((void *)sarr, sizeof(float)*nelem));
| 319 |
| 320 |
| 321 |
/* Initialize probability table */
| 322 |
static void
| 323 |
init_ptable(
| 324 |
char *sfile
| 325 |
| 326 |
| 327 |
int samptot = nsamps;
| 328 |
float *rowp, *rowp1;
| 329 |
double rowsum[MAXNT], rowomega[MAXNT];
| 330 |
double thdiv[MAXNT+1], phdiv[MAXNP+1];
| 331 |
double tsize, psize;
| 332 |
double prob, frac, frac1;
| 333 |
int i, j, t, p;
| 334 |
/* free old table */
| 335 |
if (sensor != NULL)
| 336 |
free((void *)sensor);
| 337 |
if (pvals != NULL)
| 338 |
free((void *)pvals);
| 339 |
if (sfile == NULL || !*sfile) {
| 340 |
sensor = NULL;
| 341 |
sntp[0] = sntp[1] = 0;
| 342 |
pvals = NULL;
| 343 |
ntheta = nphi = 0;
| 344 |
return;
| 345 |
| 346 |
/* load sensor table */
| 347 |
sensor = load_sensor(sntp, sfile);
| 348 |
if (sntp[0] > MAXNT) {
| 349 |
sprintf(errmsg, "Too many theta rows in sensor file '%s'",
| 350 |
sfile);
| 351 |
error(INTERNAL, errmsg);
| 352 |
| 353 |
if (sntp[1] > MAXNP) {
| 354 |
sprintf(errmsg, "Too many phi columns in sensor file '%s'",
| 355 |
sfile);
| 356 |
| 357 |
| 358 |
/* compute boundary angles */
| 359 |
maxtheta = DEGREE*(1.5f*s_theta(sntp[0]-1) - 0.5f*s_theta(sntp[0]-2));
| 360 |
if (maxtheta > PI)
| 361 |
maxtheta = PI;
| 362 |
thdiv[0] = .0;
| 363 |
for (t = 1; t < sntp[0]; t++)
| 364 |
thdiv[t] = DEGREE/2.*(s_theta(t-1) + s_theta(t));
| 365 |
thdiv[sntp[0]] = maxtheta;
| 366 |
phdiv[0] = DEGREE*(1.5f*s_phi(0) - 0.5f*s_phi(1));
| 367 |
for (p = 1; p < sntp[1]; p++)
| 368 |
phdiv[p] = DEGREE/2.*(s_phi(p-1) + s_phi(p));
| 369 |
phdiv[sntp[1]] = DEGREE*(1.5f*s_phi(sntp[1]-1) - 0.5f*s_phi(sntp[1]-2));
| 370 |
/* size our table */
| 371 |
tsize = 1. - cos(maxtheta);
| 372 |
psize = PI*tsize/maxtheta;
| 373 |
if (sntp[0]*sntp[1] < samptot) /* don't overdo resolution */
| 374 |
samptot = sntp[0]*sntp[1];
| 375 |
ntheta = (int)(sqrt((double)samptot*tsize/psize)*sntp[0]/sntp[1]) + 1;
| 376 |
if (ntheta > MAXNT)
| 377 |
ntheta = MAXNT;
| 378 |
nphi = samptot/ntheta;
| 379 |
pvals = (float *)malloc(sizeof(float)*(ntheta+1)*(nphi+1));
| 380 |
if (pvals == NULL)
| 381 |
error(SYSTEM, "out of memory in init_ptable()");
| 382 |
gscale = .0; /* compute our inverse table */
| 383 |
for (i = 0; i < sntp[0]; i++) {
| 384 |
rowp = &s_val(i,0);
| 385 |
rowsum[i] = 1e-20;
| 386 |
for (j = 0; j < sntp[1]; j++)
| 387 |
rowsum[i] += *rowp++;
| 388 |
rowomega[i] = cos(thdiv[i]) - cos(thdiv[i+1]);
| 389 |
rowomega[i] *= 2.*PI / (double)sntp[1];
| 390 |
gscale += rowsum[i] * rowomega[i];
| 391 |
| 392 |
if (gscale <= FTINY) {
| 393 |
sprintf(errmsg, "Sensor values sum to zero in file '%s'", sfile);
| 394 |
| 395 |
| 396 |
for (i = 0; i < ntheta; i++) {
| 397 |
prob = (double)i / (double)ntheta;
| 398 |
for (t = 0; t < sntp[0]; t++)
| 399 |
if ((prob -= rowsum[t]*rowomega[t]/gscale) <= .0)
| 400 |
break;
| 401 |
if (t >= sntp[0])
| 402 |
error(INTERNAL, "code error 1 in init_ptable()");
| 403 |
frac = 1. + prob/(rowsum[t]*rowomega[t]/gscale);
| 404 |
tvals[i] = 1. - ( (1.-frac)*cos(thdiv[t]) +
| 405 |
frac*cos(thdiv[t+1]) );
| 406 |
/* offset b/c sensor values are centered */
| 407 |
if ((t < sntp[0]-1) & (!t | (frac >= 0.5))) {
| 408 |
frac -= 0.5;
| 409 |
} else {
| 410 |
frac += 0.5;
| 411 |
--t;
| 412 |
| 413 |
pvals[i*(nphi+1)] = phdiv[0];
| 414 |
for (j = 1; j < nphi; j++) {
| 415 |
prob = (double)j / (double)nphi;
| 416 |
rowp = &s_val(t,0);
| 417 |
rowp1 = &s_val(t+1,0);
| 418 |
for (p = 0; p < sntp[1]; p++)
| 419 |
if ((prob -= (1.-frac)*rowp[p]/rowsum[t] +
| 420 |
frac*rowp1[p]/rowsum[t+1]) <= .0)
| 421 |
break;
| 422 |
if (p >= sntp[1]) { /* should never happen? */
| 423 |
p = sntp[1] - 1;
| 424 |
prob = .5;
| 425 |
| 426 |
frac1 = 1. + prob/((1.-frac)*rowp[p]/rowsum[t]
| 427 |
+ frac*rowp1[p]/rowsum[t+1]);
| 428 |
pvals[i*(nphi+1) + j] = (1.-frac1)*phdiv[p] +
| 429 |
frac1*phdiv[p+1];
| 430 |
| 431 |
pvals[i*(nphi+1) + nphi] = phdiv[sntp[1]];
| 432 |
| 433 |
/* duplicate final row */
| 434 |
memcpy(pvals+ntheta*(nphi+1), pvals+(ntheta-1)*(nphi+1),
| 435 |
sizeof(*pvals)*(nphi+1));
| 436 |
tvals[0] = .0f;
| 437 |
tvals[ntheta] = (float)tsize;
| 438 |
| 439 |
| 440 |
/* Get normalized direction from random variables in [0,1) range */
| 441 |
static void
| 442 |
get_direc(
| 443 |
FVECT dvec,
| 444 |
double x,
| 445 |
double y
| 446 |
| 447 |
| 448 |
double xfrac = x*ntheta;
| 449 |
int tndx = (int)xfrac;
| 450 |
double yfrac = y*nphi;
| 451 |
int pndx = (int)yfrac;
| 452 |
double rad, phi;
| 453 |
FVECT dv;
| 454 |
int i;
| 455 |
| 456 |
xfrac -= (double)tndx;
| 457 |
yfrac -= (double)pndx;
| 458 |
pndx += tndx*(nphi+1);
| 459 |
| 460 |
dv[2] = 1. - ((1.-xfrac)*tvals[tndx] + xfrac*tvals[tndx+1]);
| 461 |
rad = sqrt(1. - dv[2]*dv[2]);
| 462 |
phi = (1.-yfrac)*pvals[pndx] + yfrac*pvals[pndx+1];
| 463 |
dv[0] = -rad*sin(phi);
| 464 |
dv[1] = rad*cos(phi);
| 465 |
for (i = 3; i--; )
| 466 |
dvec[i] = dv[0]*ourview.hvec[i] +
| 467 |
dv[1]*ourview.vvec[i] +
| 468 |
dv[2]*ourview.vdir[i] ;
| 469 |
| 470 |
| 471 |
/* Get sensor value in the specified direction (normalized) */
| 472 |
static float
| 473 |
sens_val(
| 474 |
FVECT dvec
| 475 |
| 476 |
| 477 |
FVECT dv;
| 478 |
float theta, phi;
| 479 |
int t, p;
| 480 |
| 481 |
dv[2] = DOT(dvec, ourview.vdir);
| 482 |
theta = acos(dv[2]);
| 483 |
if (theta >= maxtheta)
| 484 |
return(.0f);
| 485 |
dv[0] = DOT(dvec, ourview.hvec);
| 486 |
dv[1] = DOT(dvec, ourview.vvec);
| 487 |
phi = atan2(-dv[0], dv[1]);
| 488 |
while (phi < .0f) phi += (float)(2.*PI);
| 489 |
t = (int)(theta/maxtheta * sntp[0]);
| 490 |
p = (int)(phi*(1./(2.*PI)) * sntp[1]);
| 491 |
/* hack for non-uniform sensor grid */
| 492 |
theta *= (float)(1./DEGREE);
| 493 |
phi *= (float)(1./DEGREE);
| 494 |
while (t+1 < sntp[0] && theta >= s_theta(t+1))
| 495 |
++t;
| 496 |
while (t-1 >= 0 && theta <= s_theta(t-1))
| 497 |
--t;
| 498 |
while (p+1 < sntp[1] && phi >= s_phi(p+1))
| 499 |
++p;
| 500 |
while (p-1 >= 0 && phi <= s_phi(p-1))
| 501 |
--p;
| 502 |
return(s_val(t,p));
| 503 |
| 504 |
| 505 |
/* Print origin and direction */
| 506 |
static void
| 507 |
print_ray(
| 508 |
FVECT rorg,
| 509 |
FVECT rdir
| 510 |
| 511 |
| 512 |
printf("%.6g %.6g %.6g %.8f %.8f %.8f\n",
| 513 |
rorg[0], rorg[1], rorg[2],
| 514 |
rdir[0], rdir[1], rdir[2]);
| 515 |
| 516 |
| 517 |
/* Compute sensor output */
| 518 |
static void
| 519 |
comp_sensor(
| 520 |
char *sfile
| 521 |
| 522 |
| 523 |
int ndirs = dstrsrc > FTINY ? ndsamps :
| 524 |
ndsamps > 0 ? 1 : 0;
| 525 |
char *err;
| 526 |
int nt, np;
| 527 |
COLOR vsum;
| 528 |
RAY rr;
| 529 |
double sf;
| 530 |
int i, j;
| 531 |
/* set view */
| 532 |
ourview.type = VT_ANG;
| 533 |
ourview.horiz = ourview.vert = 180.;
| 534 |
ourview.hoff = ourview.voff = .0;
| 535 |
err = setview(&ourview);
| 536 |
if (err != NULL)
| 537 |
error(USER, err);
| 538 |
/* assign probability table */
| 539 |
init_ptable(sfile);
| 540 |
/* stratified MC sampling */
| 541 |
setcolor(vsum, .0f, .0f, .0f);
| 542 |
nt = (int)(sqrt((double)nsamps*ntheta/nphi) + .5);
| 543 |
np = nsamps/nt;
| 544 |
sf = gscale/nsamps;
| 545 |
for (i = 0; i < nt; i++)
| 546 |
for (j = 0; j < np; j++) {
| 547 |
VCOPY(rr.rorg, ourview.vp);
| 548 |
get_direc(rr.rdir, (i+frandom())/nt, (j+frandom())/np);
| 549 |
if (ourview.vfore > FTINY)
| 550 |
VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore);
| 551 |
if (!ray_pnprocs) {
| 552 |
print_ray(rr.rorg, rr.rdir);
| 553 |
continue;
| 554 |
| 555 |
rr.rmax = .0;
| 556 |
rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL);
| 557 |
scalecolor(rr.rcoef, sf);
| 558 |
if (ray_pqueue(&rr) == 1)
| 559 |
addcolor(vsum, rr.rcol);
| 560 |
| 561 |
/* remaining rays pure MC */
| 562 |
for (i = nsamps - nt*np; i-- > 0; ) {
| 563 |
| 564 |
get_direc(rr.rdir, frandom(), frandom());
| 565 |
| 566 |
| 567 |
if (!ray_pnprocs) {
| 568 |
| 569 |
continue;
| 570 |
| 571 |
rr.rmax = .0;
| 572 |
| 573 |
| 574 |
| 575 |
| 576 |
| 577 |
if (!ray_pnprocs) /* just printing rays */
| 578 |
return;
| 579 |
/* scale partial result */
| 580 |
scalecolor(vsum, sf);
| 581 |
/* add direct component */
| 582 |
for (i = ndirs; i-- > 0; ) {
| 583 |
SRCINDEX si;
| 584 |
initsrcindex(&si);
| 585 |
while (srcray(&rr, NULL, &si)) {
| 586 |
sf = sens_val(rr.rdir);
| 587 |
if (sf <= FTINY)
| 588 |
continue;
| 589 |
sf *= si.dom/ndirs;
| 590 |
| 591 |
if (ray_pqueue(&rr) == 1) {
| 592 |
multcolor(rr.rcol, rr.rcoef);
| 593 |
| 594 |
| 595 |
| 596 |
| 597 |
/* finish our calculation */
| 598 |
while (ray_presult(&rr, 0) > 0) {
| 599 |
| 600 |
| 601 |
| 602 |
/* print our result */
| 603 |
printf("%.4e %.4e %.4e\n", colval(vsum,RED),
| 604 |
colval(vsum,GRN), colval(vsum,BLU));
| 605 |
