root/radiance/ray/src/util/rsensor.c
Revision: 2.20
Committed: Fri Jul 24 17:09:33 2020 UTC (3 years, 10 months ago) by greg
Changes since 2.19: +2 -1 lines
fix(rsensor): added missing declaration for _exit()
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.20 static const char RCSid[] = "$Id: rsensor.c,v 2.19 2020/07/20 15:54:29 greg Exp $";
3 greg 2.1 #endif
4
5     /*
6     * Compute sensor signal based on spatial sensitivity.
7     *
8     * Created Feb 2008 for Architectural Energy Corp.
9     */
10
11     #include "ray.h"
12 greg 2.20 #include "platform.h"
13 greg 2.1 #include "source.h"
14     #include "view.h"
15     #include "random.h"
16
17     #define DEGREE (PI/180.)
18
19 greg 2.15 #define MAXNT 181 /* maximum number of theta divisions */
20 greg 2.1 #define MAXNP 360 /* maximum number of phi divisions */
21
22     extern char *progname; /* global argv[0] */
23     extern int nowarn; /* don't report warnings? */
24
25     /* current sensor's perspective */
26 greg 2.5 VIEW ourview = {VT_ANG,{0.,0.,0.},{0.,0.,1.},{1.,0.,0.},
27     1.,180.,180.,0.,0.,0.,0.,
28     {0.,0.,0.},{0.,0.,0.},0.,0.};
29 greg 2.1
30     unsigned long nsamps = 10000; /* desired number of initial samples */
31     unsigned long nssamps = 9000; /* number of super-samples */
32 greg 2.2 int ndsamps = 32; /* number of direct samples */
33 greg 2.1 int nprocs = 1; /* number of rendering processes */
34
35     float *sensor = NULL; /* current sensor data */
36     int sntp[2]; /* number of sensor theta and phi angles */
37     float maxtheta; /* maximum theta value for this sensor */
38 greg 2.9 float tvals[MAXNT+1]; /* theta prob. values (1-D table of 1-cos(t)) */
39     float *pvals = NULL; /* phi prob. values (2-D table in radians) */
40 greg 2.1 int ntheta = 0; /* polar angle divisions */
41     int nphi = 0; /* azimuthal angle divisions */
42     double gscale = 1.; /* global scaling value */
43
44 greg 2.2 #define s_theta(t) sensor[(t+1)*(sntp[1]+1)]
45     #define s_phi(p) sensor[(p)+1]
46     #define s_val(t,p) sensor[(p)+1+(t+1)*(sntp[1]+1)]
47
48 greg 2.1 static void comp_sensor(char *sfile);
49
50     static void
51 greg 2.3 over_options() /* overriding options */
52 greg 2.1 {
53 greg 2.3 directvis = (ndsamps <= 0);
54     do_irrad = 0;
55     }
56
57     static void
58     print_defaults() /* print out default parameters */
59     {
60     over_options();
61 greg 2.1 printf("-n %-9d\t\t\t# number of processes\n", nprocs);
62     printf("-rd %-9ld\t\t\t# ray directions\n", nsamps);
63     /* printf("-rs %-9ld\t\t\t# ray super-samples\n", nssamps); */
64     printf("-dn %-9d\t\t\t# direct number of samples\n", ndsamps);
65     printf("-vp %f %f %f\t# view point\n",
66     ourview.vp[0], ourview.vp[1], ourview.vp[2]);
67     printf("-vd %f %f %f\t# view direction\n",
68     ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
69     printf("-vu %f %f %f\t# view up\n",
70     ourview.vup[0], ourview.vup[1], ourview.vup[2]);
71     printf("-vo %f\t\t\t# view fore clipping distance\n", ourview.vfore);
72     print_rdefaults();
73     }
74
75 greg 2.7
76     void
77     quit(ec) /* make sure exit is called */
78     int ec;
79     {
80     if (ray_pnprocs > 0) /* close children if any */
81 greg 2.19 ray_pclose(0);
82     else if (ray_pnprocs < 0)
83     _exit(ec); /* avoid flush in child */
84 greg 2.7 exit(ec);
85     }
86
87
88 greg 2.1 int
89     main(
90     int argc,
91     char *argv[]
92     )
93     {
94     int doheader = 1;
95 greg 2.3 int optwarn = 0;
96 greg 2.1 int i, rval;
97
98     progname = argv[0];
99     /* set up rendering defaults */
100 greg 2.2 rand_samp = 1;
101 greg 2.6 dstrsrc = 0.65;
102 greg 2.2 srcsizerat = 0.1;
103 greg 2.1 directrelay = 3;
104     ambounce = 1;
105 greg 2.2 maxdepth = -10;
106 greg 2.1 /* get options from command line */
107 greg 2.3 for (i = 1; i < argc; i++) {
108 greg 2.1 while ((rval = expandarg(&argc, &argv, i)) > 0)
109     ;
110     if (rval < 0) {
111     sprintf(errmsg, "cannot expand '%s'", argv[i]);
112     error(SYSTEM, errmsg);
113     }
114 greg 2.3 if (argv[i][0] != '-') {
115     if (i >= argc-1)
116     break; /* final octree argument */
117 greg 2.1 if (!ray_pnprocs) {
118 greg 2.3 over_options();
119 greg 2.1 if (doheader) { /* print header */
120 greg 2.6 newheader("RADIANCE", stdout);
121 greg 2.1 printargs(argc, argv, stdout);
122     fputformat("ascii", stdout);
123     putchar('\n');
124     }
125     /* start process(es) */
126 greg 2.8 if (strcmp(argv[argc-1], "."))
127     ray_pinit(argv[argc-1], nprocs);
128 greg 2.1 }
129 greg 2.3 comp_sensor(argv[i]); /* process a sensor file */
130 greg 2.1 continue;
131     }
132     if (argv[i][1] == 'r') { /* sampling options */
133     if (argv[i][2] == 'd')
134     nsamps = atol(argv[++i]);
135     else if (argv[i][2] == 's')
136     nssamps = atol(argv[++i]);
137     else {
138     sprintf(errmsg, "bad option at '%s'", argv[i]);
139     error(USER, errmsg);
140     }
141     continue;
142     }
143     /* direct component samples */
144     if (argv[i][1] == 'd' && argv[i][2] == 'n') {
145     ndsamps = atoi(argv[++i]);
146     continue;
147     }
148     if (argv[i][1] == 'v') { /* next sensor view */
149     if (argv[i][2] == 'f') {
150     rval = viewfile(argv[++i], &ourview, NULL);
151     if (rval < 0) {
152     sprintf(errmsg,
153     "cannot open view file \"%s\"",
154     argv[i]);
155     error(SYSTEM, errmsg);
156     } else if (rval == 0) {
157     sprintf(errmsg,
158     "bad view file \"%s\"",
159     argv[i]);
160     error(USER, errmsg);
161     }
162     continue;
163     }
164     rval = getviewopt(&ourview, argc-i, argv+i);
165     if (rval >= 0) {
166     i += rval;
167     continue;
168     }
169     sprintf(errmsg, "bad view option at '%s'", argv[i]);
170     error(USER, errmsg);
171     }
172 greg 2.3 if (!strcmp(argv[i], "-w")) { /* toggle warnings */
173     nowarn = !nowarn;
174 greg 2.1 continue;
175     }
176     if (ray_pnprocs) {
177 greg 2.3 if (!optwarn++)
178     error(WARNING,
179 greg 2.1 "rendering options should appear before first sensor");
180     } else if (!strcmp(argv[i], "-defaults")) {
181     print_defaults();
182     return(0);
183     }
184     if (argv[i][1] == 'h') { /* header toggle */
185     doheader = !doheader;
186     continue;
187     }
188     if (!strcmp(argv[i], "-n")) { /* number of processes */
189     nprocs = atoi(argv[++i]);
190     if (nprocs <= 0)
191     error(USER, "illegal number of processes");
192     continue;
193     }
194     rval = getrenderopt(argc-i, argv+i);
195     if (rval < 0) {
196     sprintf(errmsg, "bad render option at '%s'", argv[i]);
197     error(USER, errmsg);
198     }
199     i += rval;
200     }
201 greg 2.8 if (sensor == NULL)
202 greg 2.3 error(USER, i<argc ? "missing sensor file" : "missing octree");
203 greg 2.1 quit(0);
204     }
205
206     /* Load sensor sensitivities (first row and column are angles) */
207     static float *
208     load_sensor(
209     int ntp[2],
210     char *sfile
211     )
212     {
213 greg 2.10 int warnedneg;
214 greg 2.1 char linebuf[8192];
215 greg 2.16 int last_pos_val = 0;
216 greg 2.1 int nelem = 1000;
217     float *sarr = (float *)malloc(sizeof(float)*nelem);
218     FILE *fp;
219     char *cp;
220     int i;
221
222     fp = frlibopen(sfile);
223     if (fp == NULL) {
224     sprintf(errmsg, "cannot open sensor file '%s'", sfile);
225     error(SYSTEM, errmsg);
226     }
227     fgets(linebuf, sizeof(linebuf), fp);
228     if (!strncmp(linebuf, "Elevation ", 10))
229     fgets(linebuf, sizeof(linebuf), fp);
230     /* get phi values */
231     sarr[0] = .0f;
232     if (strncmp(linebuf, "degrees", 7)) {
233     sprintf(errmsg, "Missing 'degrees' in sensor file '%s'", sfile);
234     error(USER, errmsg);
235     }
236     cp = sskip(linebuf);
237     ntp[1] = 0;
238     for ( ; ; ) {
239     sarr[ntp[1]+1] = atof(cp);
240     cp = fskip(cp);
241     if (cp == NULL)
242     break;
243 greg 2.18 if (ntp[1] > 1 && sarr[ntp[1]+1] <= sarr[ntp[1]]+FTINY) {
244 greg 2.9 sprintf(errmsg,
245     "Phi values not monotinically increasing in sensor file '%s'",
246     sfile);
247     error(USER, errmsg);
248     }
249 greg 2.1 ++ntp[1];
250     }
251 greg 2.10 warnedneg = 0;
252 greg 2.1 ntp[0] = 0; /* get thetas + data */
253     while (fgets(linebuf, sizeof(linebuf), fp) != NULL) {
254     ++ntp[0];
255     if ((ntp[0]+1)*(ntp[1]+1) > nelem) {
256     nelem += (nelem>>2) + ntp[1];
257     sarr = (float *)realloc((void *)sarr,
258     sizeof(float)*nelem);
259     if (sarr == NULL)
260     error(SYSTEM, "out of memory in load_sensor()");
261     }
262     cp = linebuf;
263     i = ntp[0]*(ntp[1]+1);
264     for ( ; ; ) {
265     sarr[i] = atof(cp);
266     cp = fskip(cp);
267     if (cp == NULL)
268     break;
269 greg 2.17 if (sarr[i] < .0) {
270 greg 2.10 if (!warnedneg++) {
271     sprintf(errmsg,
272     "Negative value(s) in sensor file '%s' (ignored)\n", sfile);
273     error(WARNING, errmsg);
274     }
275     sarr[i] = .0;
276 greg 2.17 } else if (sarr[i] > FTINY && i > ntp[0]*(ntp[1]+1))
277 greg 2.16 last_pos_val = i;
278 greg 2.1 ++i;
279     }
280 greg 2.17 if (i == ntp[0]*(ntp[1]+1)) /* empty line? */
281 greg 2.1 break;
282 greg 2.9 if (ntp[0] > 1 && sarr[ntp[0]*(ntp[1]+1)] <=
283     sarr[(ntp[0]-1)*(ntp[1]+1)]) {
284     sprintf(errmsg,
285     "Theta values not monotinically increasing in sensor file '%s'",
286     sfile);
287     error(USER, errmsg);
288     }
289 greg 2.1 if (i != (ntp[0]+1)*(ntp[1]+1)) {
290     sprintf(errmsg,
291     "bad column count near line %d in sensor file '%s'",
292     ntp[0]+1, sfile);
293     error(USER, errmsg);
294     }
295     }
296 greg 2.16 /* truncate zero region */
297     ntp[0] = (last_pos_val + ntp[1])/(ntp[1]+1) - 1;
298     nelem = (ntp[0]+1)*(ntp[1]+1);
299 greg 2.1 fclose(fp);
300     errmsg[0] = '\0'; /* sanity checks */
301 greg 2.16 if (!last_pos_val)
302     sprintf(errmsg, "no positive sensor values in file '%s'", sfile);
303 greg 2.1 else if (fabs(sarr[ntp[1]+1]) > FTINY)
304     sprintf(errmsg, "minimum theta must be 0 in sensor file '%s'",
305     sfile);
306     else if (fabs(sarr[1]) > FTINY)
307     sprintf(errmsg, "minimum phi must be 0 in sensor file '%s'",
308     sfile);
309 greg 2.18 else if (sarr[ntp[1]] < 270.-FTINY)
310 greg 2.1 sprintf(errmsg,
311 greg 2.18 "maximum phi must be 270 or greater in sensor file '%s'",
312     sfile);
313     else if (sarr[ntp[1]] >= 360.-FTINY)
314     sprintf(errmsg,
315     "maximum phi must be less than 360 in sensor file '%s'",
316 greg 2.1 sfile);
317     if (errmsg[0])
318     error(USER, errmsg);
319     return((float *)realloc((void *)sarr, sizeof(float)*nelem));
320     }
321
322     /* Initialize probability table */
323     static void
324     init_ptable(
325     char *sfile
326     )
327     {
328     int samptot = nsamps;
329     float *rowp, *rowp1;
330     double rowsum[MAXNT], rowomega[MAXNT];
331     double thdiv[MAXNT+1], phdiv[MAXNP+1];
332     double tsize, psize;
333     double prob, frac, frac1;
334     int i, j, t, p;
335     /* free old table */
336     if (sensor != NULL)
337     free((void *)sensor);
338     if (pvals != NULL)
339     free((void *)pvals);
340     if (sfile == NULL || !*sfile) {
341 greg 2.2 sensor = NULL;
342     sntp[0] = sntp[1] = 0;
343 greg 2.1 pvals = NULL;
344     ntheta = nphi = 0;
345     return;
346     }
347     /* load sensor table */
348     sensor = load_sensor(sntp, sfile);
349     if (sntp[0] > MAXNT) {
350     sprintf(errmsg, "Too many theta rows in sensor file '%s'",
351     sfile);
352     error(INTERNAL, errmsg);
353     }
354     if (sntp[1] > MAXNP) {
355     sprintf(errmsg, "Too many phi columns in sensor file '%s'",
356     sfile);
357     error(INTERNAL, errmsg);
358     }
359     /* compute boundary angles */
360 greg 2.9 maxtheta = DEGREE*(1.5f*s_theta(sntp[0]-1) - 0.5f*s_theta(sntp[0]-2));
361     if (maxtheta > PI)
362     maxtheta = PI;
363 greg 2.1 thdiv[0] = .0;
364     for (t = 1; t < sntp[0]; t++)
365 greg 2.2 thdiv[t] = DEGREE/2.*(s_theta(t-1) + s_theta(t));
366 greg 2.9 thdiv[sntp[0]] = maxtheta;
367     phdiv[0] = DEGREE*(1.5f*s_phi(0) - 0.5f*s_phi(1));
368 greg 2.1 for (p = 1; p < sntp[1]; p++)
369 greg 2.2 phdiv[p] = DEGREE/2.*(s_phi(p-1) + s_phi(p));
370 greg 2.9 phdiv[sntp[1]] = DEGREE*(1.5f*s_phi(sntp[1]-1) - 0.5f*s_phi(sntp[1]-2));
371 greg 2.1 /* size our table */
372 greg 2.9 tsize = 1. - cos(maxtheta);
373     psize = PI*tsize/maxtheta;
374 greg 2.1 if (sntp[0]*sntp[1] < samptot) /* don't overdo resolution */
375     samptot = sntp[0]*sntp[1];
376 greg 2.17 ntheta = (int)(sqrt((double)samptot*tsize/psize)*sntp[0]/sntp[1]) + 1;
377 greg 2.1 if (ntheta > MAXNT)
378     ntheta = MAXNT;
379     nphi = samptot/ntheta;
380 greg 2.9 pvals = (float *)malloc(sizeof(float)*(ntheta+1)*(nphi+1));
381 greg 2.1 if (pvals == NULL)
382     error(SYSTEM, "out of memory in init_ptable()");
383     gscale = .0; /* compute our inverse table */
384     for (i = 0; i < sntp[0]; i++) {
385 greg 2.2 rowp = &s_val(i,0);
386 greg 2.9 rowsum[i] = 1e-20;
387 greg 2.1 for (j = 0; j < sntp[1]; j++)
388     rowsum[i] += *rowp++;
389     rowomega[i] = cos(thdiv[i]) - cos(thdiv[i+1]);
390     rowomega[i] *= 2.*PI / (double)sntp[1];
391     gscale += rowsum[i] * rowomega[i];
392     }
393 greg 2.9 if (gscale <= FTINY) {
394     sprintf(errmsg, "Sensor values sum to zero in file '%s'", sfile);
395     error(USER, errmsg);
396     }
397 greg 2.2 for (i = 0; i < ntheta; i++) {
398 greg 2.1 prob = (double)i / (double)ntheta;
399     for (t = 0; t < sntp[0]; t++)
400     if ((prob -= rowsum[t]*rowomega[t]/gscale) <= .0)
401     break;
402     if (t >= sntp[0])
403     error(INTERNAL, "code error 1 in init_ptable()");
404     frac = 1. + prob/(rowsum[t]*rowomega[t]/gscale);
405     tvals[i] = 1. - ( (1.-frac)*cos(thdiv[t]) +
406     frac*cos(thdiv[t+1]) );
407 greg 2.2 /* offset b/c sensor values are centered */
408 greg 2.14 if ((t < sntp[0]-1) & (!t | (frac >= 0.5))) {
409     frac -= 0.5;
410 greg 2.13 } else {
411 greg 2.2 frac += 0.5;
412     --t;
413     }
414 greg 2.9 pvals[i*(nphi+1)] = phdiv[0];
415 greg 2.1 for (j = 1; j < nphi; j++) {
416     prob = (double)j / (double)nphi;
417 greg 2.2 rowp = &s_val(t,0);
418     rowp1 = &s_val(t+1,0);
419 greg 2.9 for (p = 0; p < sntp[1]; p++)
420 greg 2.2 if ((prob -= (1.-frac)*rowp[p]/rowsum[t] +
421     frac*rowp1[p]/rowsum[t+1]) <= .0)
422 greg 2.1 break;
423 greg 2.10 if (p >= sntp[1]) { /* should never happen? */
424 greg 2.9 p = sntp[1] - 1;
425     prob = .5;
426 greg 2.1 }
427 greg 2.9 frac1 = 1. + prob/((1.-frac)*rowp[p]/rowsum[t]
428     + frac*rowp1[p]/rowsum[t+1]);
429     pvals[i*(nphi+1) + j] = (1.-frac1)*phdiv[p] +
430     frac1*phdiv[p+1];
431 greg 2.1 }
432 greg 2.9 pvals[i*(nphi+1) + nphi] = phdiv[sntp[1]];
433 greg 2.1 }
434 greg 2.15 /* duplicate final row */
435     memcpy(pvals+ntheta*(nphi+1), pvals+(ntheta-1)*(nphi+1),
436     sizeof(*pvals)*(nphi+1));
437 greg 2.2 tvals[0] = .0f;
438 greg 2.1 tvals[ntheta] = (float)tsize;
439     }
440
441     /* Get normalized direction from random variables in [0,1) range */
442     static void
443     get_direc(
444     FVECT dvec,
445     double x,
446     double y
447     )
448     {
449     double xfrac = x*ntheta;
450     int tndx = (int)xfrac;
451     double yfrac = y*nphi;
452     int pndx = (int)yfrac;
453     double rad, phi;
454     FVECT dv;
455     int i;
456
457     xfrac -= (double)tndx;
458     yfrac -= (double)pndx;
459     pndx += tndx*(nphi+1);
460
461     dv[2] = 1. - ((1.-xfrac)*tvals[tndx] + xfrac*tvals[tndx+1]);
462     rad = sqrt(1. - dv[2]*dv[2]);
463     phi = (1.-yfrac)*pvals[pndx] + yfrac*pvals[pndx+1];
464     dv[0] = -rad*sin(phi);
465     dv[1] = rad*cos(phi);
466     for (i = 3; i--; )
467     dvec[i] = dv[0]*ourview.hvec[i] +
468     dv[1]*ourview.vvec[i] +
469     dv[2]*ourview.vdir[i] ;
470     }
471
472     /* Get sensor value in the specified direction (normalized) */
473     static float
474     sens_val(
475     FVECT dvec
476     )
477     {
478     FVECT dv;
479     float theta, phi;
480     int t, p;
481
482     dv[2] = DOT(dvec, ourview.vdir);
483 greg 2.11 theta = acos(dv[2]);
484 greg 2.1 if (theta >= maxtheta)
485     return(.0f);
486     dv[0] = DOT(dvec, ourview.hvec);
487     dv[1] = DOT(dvec, ourview.vvec);
488 greg 2.11 phi = atan2(-dv[0], dv[1]);
489     while (phi < .0f) phi += (float)(2.*PI);
490 greg 2.1 t = (int)(theta/maxtheta * sntp[0]);
491 greg 2.11 p = (int)(phi*(1./(2.*PI)) * sntp[1]);
492 greg 2.1 /* hack for non-uniform sensor grid */
493 greg 2.11 theta *= (float)(1./DEGREE);
494     phi *= (float)(1./DEGREE);
495 greg 2.2 while (t+1 < sntp[0] && theta >= s_theta(t+1))
496 greg 2.1 ++t;
497 greg 2.2 while (t-1 >= 0 && theta <= s_theta(t-1))
498 greg 2.1 --t;
499 greg 2.2 while (p+1 < sntp[1] && phi >= s_phi(p+1))
500 greg 2.1 ++p;
501 greg 2.2 while (p-1 >= 0 && phi <= s_phi(p-1))
502 greg 2.1 --p;
503 greg 2.2 return(s_val(t,p));
504 greg 2.1 }
505
506 greg 2.8 /* Print origin and direction */
507     static void
508     print_ray(
509     FVECT rorg,
510     FVECT rdir
511     )
512     {
513     printf("%.6g %.6g %.6g %.8f %.8f %.8f\n",
514     rorg[0], rorg[1], rorg[2],
515     rdir[0], rdir[1], rdir[2]);
516     }
517
518 greg 2.1 /* Compute sensor output */
519     static void
520     comp_sensor(
521     char *sfile
522     )
523     {
524     int ndirs = dstrsrc > FTINY ? ndsamps :
525     ndsamps > 0 ? 1 : 0;
526     char *err;
527     int nt, np;
528     COLOR vsum;
529     RAY rr;
530 greg 2.6 double sf;
531 greg 2.1 int i, j;
532     /* set view */
533     ourview.type = VT_ANG;
534     ourview.horiz = ourview.vert = 180.;
535     ourview.hoff = ourview.voff = .0;
536     err = setview(&ourview);
537     if (err != NULL)
538     error(USER, err);
539     /* assign probability table */
540     init_ptable(sfile);
541 greg 2.6 /* stratified MC sampling */
542 greg 2.1 setcolor(vsum, .0f, .0f, .0f);
543     nt = (int)(sqrt((double)nsamps*ntheta/nphi) + .5);
544     np = nsamps/nt;
545 greg 2.6 sf = gscale/nsamps;
546 greg 2.1 for (i = 0; i < nt; i++)
547 greg 2.2 for (j = 0; j < np; j++) {
548 greg 2.5 VCOPY(rr.rorg, ourview.vp);
549 greg 2.2 get_direc(rr.rdir, (i+frandom())/nt, (j+frandom())/np);
550 greg 2.5 if (ourview.vfore > FTINY)
551     VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore);
552 greg 2.8 if (!ray_pnprocs) {
553     print_ray(rr.rorg, rr.rdir);
554     continue;
555     }
556 greg 2.5 rr.rmax = .0;
557 greg 2.12 rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL);
558 greg 2.6 scalecolor(rr.rcoef, sf);
559 greg 2.1 if (ray_pqueue(&rr) == 1)
560     addcolor(vsum, rr.rcol);
561     }
562 greg 2.6 /* remaining rays pure MC */
563     for (i = nsamps - nt*np; i-- > 0; ) {
564     VCOPY(rr.rorg, ourview.vp);
565     get_direc(rr.rdir, frandom(), frandom());
566     if (ourview.vfore > FTINY)
567     VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore);
568 greg 2.8 if (!ray_pnprocs) {
569     print_ray(rr.rorg, rr.rdir);
570     continue;
571     }
572 greg 2.6 rr.rmax = .0;
573 greg 2.12 rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL);
574 greg 2.6 scalecolor(rr.rcoef, sf);
575     if (ray_pqueue(&rr) == 1)
576     addcolor(vsum, rr.rcol);
577     }
578 greg 2.8 if (!ray_pnprocs) /* just printing rays */
579     return;
580 greg 2.6 /* scale partial result */
581     scalecolor(vsum, sf);
582     /* add direct component */
583 greg 2.1 for (i = ndirs; i-- > 0; ) {
584     SRCINDEX si;
585     initsrcindex(&si);
586     while (srcray(&rr, NULL, &si)) {
587 greg 2.6 sf = sens_val(rr.rdir);
588     if (sf <= FTINY)
589 greg 2.1 continue;
590 greg 2.6 sf *= si.dom/ndirs;
591     scalecolor(rr.rcoef, sf);
592 greg 2.1 if (ray_pqueue(&rr) == 1) {
593     multcolor(rr.rcol, rr.rcoef);
594     addcolor(vsum, rr.rcol);
595     }
596     }
597     }
598 greg 2.6 /* finish our calculation */
599 greg 2.1 while (ray_presult(&rr, 0) > 0) {
600     multcolor(rr.rcol, rr.rcoef);
601     addcolor(vsum, rr.rcol);
602     }
603     /* print our result */
604     printf("%.4e %.4e %.4e\n", colval(vsum,RED),
605     colval(vsum,GRN), colval(vsum,BLU));
606     }
