root/radiance/ray/src/util/rsensor.c
Revision: 2.12
Committed: Mon Sep 26 15:33:29 2011 UTC (13 years, 8 months ago) by greg
Added SPECULAR flag to ray samples to work better with BSDF materials
2 static const char RCSid[] = "$Id: rsensor.c,v 2.11 2011/06/20 23:08:43 greg Exp $";
4
5 /*
6 * Compute sensor signal based on spatial sensitivity.
7 *
8 * Created Feb 2008 for Architectural Energy Corp.
9 */
10
11 #include "ray.h"
12 #include "source.h"
13 #include "view.h"
14 #include "random.h"
15
16 #define DEGREE (PI/180.)
17
18 #define MAXNT 180 /* maximum number of theta divisions */
19 #define MAXNP 360 /* maximum number of phi divisions */
20
21 extern char *progname; /* global argv[0] */
22 extern int nowarn; /* don't report warnings? */
23
24 /* current sensor's perspective */
25 VIEW ourview = {VT_ANG,{0.,0.,0.},{0.,0.,1.},{1.,0.,0.},
26 1.,180.,180.,0.,0.,0.,0.,
27 {0.,0.,0.},{0.,0.,0.},0.,0.};
28
29 unsigned long nsamps = 10000; /* desired number of initial samples */
30 unsigned long nssamps = 9000; /* number of super-samples */
31 int ndsamps = 32; /* number of direct samples */
32 int nprocs = 1; /* number of rendering processes */
33
34 float *sensor = NULL; /* current sensor data */
35 int sntp[2]; /* number of sensor theta and phi angles */
36 float maxtheta; /* maximum theta value for this sensor */
37 float tvals[MAXNT+1]; /* theta prob. values (1-D table of 1-cos(t)) */
38 float *pvals = NULL; /* phi prob. values (2-D table in radians) */
39 int ntheta = 0; /* polar angle divisions */
40 int nphi = 0; /* azimuthal angle divisions */
41 double gscale = 1.; /* global scaling value */
42
43 #define s_theta(t) sensor[(t+1)*(sntp[1]+1)]
44 #define s_phi(p) sensor[(p)+1]
45 #define s_val(t,p) sensor[(p)+1+(t+1)*(sntp[1]+1)]
46
47 static void comp_sensor(char *sfile);
48
49 static void
50 over_options() /* overriding options */
51 {
52 directvis = (ndsamps <= 0);
53 do_irrad = 0;
54 }
55
56 static void
57 print_defaults() /* print out default parameters */
58 {
59 over_options();
60 printf("-n %-9d\t\t\t# number of processes\n", nprocs);
61 printf("-rd %-9ld\t\t\t# ray directions\n", nsamps);
62 /* printf("-rs %-9ld\t\t\t# ray super-samples\n", nssamps); */
63 printf("-dn %-9d\t\t\t# direct number of samples\n", ndsamps);
64 printf("-vp %f %f %f\t# view point\n",
65 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
66 printf("-vd %f %f %f\t# view direction\n",
67 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
68 printf("-vu %f %f %f\t# view up\n",
69 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
70 printf("-vo %f\t\t\t# view fore clipping distance\n", ourview.vfore);
71 print_rdefaults();
72 }
73
74
75 void
76 quit(ec) /* make sure exit is called */
77 int ec;
78 {
79 if (ray_pnprocs > 0) /* close children if any */
80 ray_pclose(0);
81 exit(ec);
82 }
83
84
85 int
86 main(
87 int argc,
88 char *argv[]
89 )
90 {
91 int doheader = 1;
92 int optwarn = 0;
93 int i, rval;
94
95 progname = argv[0];
96 /* set up rendering defaults */
97 rand_samp = 1;
98 dstrsrc = 0.65;
99 srcsizerat = 0.1;
100 directrelay = 3;
101 ambounce = 1;
102 maxdepth = -10;
103 /* get options from command line */
104 for (i = 1; i < argc; i++) {
105 while ((rval = expandarg(&argc, &argv, i)) > 0)
106 ;
107 if (rval < 0) {
108 sprintf(errmsg, "cannot expand '%s'", argv[i]);
109 error(SYSTEM, errmsg);
110 }
111 if (argv[i][0] != '-') {
112 if (i >= argc-1)
113 break; /* final octree argument */
114 if (!ray_pnprocs) {
115 over_options();
116 if (doheader) { /* print header */
117 newheader("RADIANCE", stdout);
118 printargs(argc, argv, stdout);
119 fputformat("ascii", stdout);
120 putchar('\n');
121 }
122 /* start process(es) */
123 if (strcmp(argv[argc-1], "."))
124 ray_pinit(argv[argc-1], nprocs);
125 }
126 comp_sensor(argv[i]); /* process a sensor file */
127 continue;
128 }
129 if (argv[i][1] == 'r') { /* sampling options */
130 if (argv[i][2] == 'd')
131 nsamps = atol(argv[++i]);
132 else if (argv[i][2] == 's')
133 nssamps = atol(argv[++i]);
134 else {
135 sprintf(errmsg, "bad option at '%s'", argv[i]);
136 error(USER, errmsg);
137 }
138 continue;
139 }
140 /* direct component samples */
141 if (argv[i][1] == 'd' && argv[i][2] == 'n') {
142 ndsamps = atoi(argv[++i]);
143 continue;
144 }
145 if (argv[i][1] == 'v') { /* next sensor view */
146 if (argv[i][2] == 'f') {
147 rval = viewfile(argv[++i], &ourview, NULL);
148 if (rval < 0) {
149 sprintf(errmsg,
150 "cannot open view file \"%s\"",
151 argv[i]);
152 error(SYSTEM, errmsg);
153 } else if (rval == 0) {
154 sprintf(errmsg,
155 "bad view file \"%s\"",
156 argv[i]);
157 error(USER, errmsg);
158 }
159 continue;
160 }
161 rval = getviewopt(&ourview, argc-i, argv+i);
162 if (rval >= 0) {
163 i += rval;
164 continue;
165 }
166 sprintf(errmsg, "bad view option at '%s'", argv[i]);
167 error(USER, errmsg);
168 }
169 if (!strcmp(argv[i], "-w")) { /* toggle warnings */
170 nowarn = !nowarn;
171 continue;
172 }
173 if (ray_pnprocs) {
174 if (!optwarn++)
175 error(WARNING,
176 "rendering options should appear before first sensor");
177 } else if (!strcmp(argv[i], "-defaults")) {
178 print_defaults();
179 return(0);
180 }
181 if (argv[i][1] == 'h') { /* header toggle */
182 doheader = !doheader;
183 continue;
184 }
185 if (!strcmp(argv[i], "-n")) { /* number of processes */
186 nprocs = atoi(argv[++i]);
187 if (nprocs <= 0)
188 error(USER, "illegal number of processes");
189 continue;
190 }
191 rval = getrenderopt(argc-i, argv+i);
192 if (rval < 0) {
193 sprintf(errmsg, "bad render option at '%s'", argv[i]);
194 error(USER, errmsg);
195 }
196 i += rval;
197 }
198 if (sensor == NULL)
199 error(USER, i<argc ? "missing sensor file" : "missing octree");
200 quit(0);
201 }
202
203 /* Load sensor sensitivities (first row and column are angles) */
204 static float *
205 load_sensor(
206 int ntp[2],
207 char *sfile
208 )
209 {
210 int warnedneg;
211 char linebuf[8192];
212 int nelem = 1000;
213 float *sarr = (float *)malloc(sizeof(float)*nelem);
214 FILE *fp;
215 char *cp;
216 int i;
217
218 fp = frlibopen(sfile);
219 if (fp == NULL) {
220 sprintf(errmsg, "cannot open sensor file '%s'", sfile);
221 error(SYSTEM, errmsg);
222 }
223 fgets(linebuf, sizeof(linebuf), fp);
224 if (!strncmp(linebuf, "Elevation ", 10))
225 fgets(linebuf, sizeof(linebuf), fp);
226 /* get phi values */
227 sarr[0] = .0f;
228 if (strncmp(linebuf, "degrees", 7)) {
229 sprintf(errmsg, "Missing 'degrees' in sensor file '%s'", sfile);
230 error(USER, errmsg);
231 }
232 cp = sskip(linebuf);
233 ntp[1] = 0;
234 for ( ; ; ) {
235 sarr[ntp[1]+1] = atof(cp);
236 cp = fskip(cp);
237 if (cp == NULL)
238 break;
239 if (ntp[1] > 1 && sarr[ntp[1]+1] <= sarr[ntp[1]]) {
240 sprintf(errmsg,
241 "Phi values not monotinically increasing in sensor file '%s'",
242 sfile);
243 error(USER, errmsg);
244 }
245 ++ntp[1];
246 }
247 warnedneg = 0;
248 ntp[0] = 0; /* get thetas + data */
249 while (fgets(linebuf, sizeof(linebuf), fp) != NULL) {
250 ++ntp[0];
251 if ((ntp[0]+1)*(ntp[1]+1) > nelem) {
252 nelem += (nelem>>2) + ntp[1];
253 sarr = (float *)realloc((void *)sarr,
254 sizeof(float)*nelem);
255 if (sarr == NULL)
256 error(SYSTEM, "out of memory in load_sensor()");
257 }
258 cp = linebuf;
259 i = ntp[0]*(ntp[1]+1);
260 for ( ; ; ) {
261 sarr[i] = atof(cp);
262 cp = fskip(cp);
263 if (cp == NULL)
264 break;
265 if (i && sarr[i] < .0) {
266 if (!warnedneg++) {
267 sprintf(errmsg,
268 "Negative value(s) in sensor file '%s' (ignored)\n", sfile);
269 error(WARNING, errmsg);
270 }
271 sarr[i] = .0;
272 }
273 ++i;
274 }
275 if (i == ntp[0]*(ntp[1]+1))
276 break;
277 if (ntp[0] > 1 && sarr[ntp[0]*(ntp[1]+1)] <=
278 sarr[(ntp[0]-1)*(ntp[1]+1)]) {
279 sprintf(errmsg,
280 "Theta values not monotinically increasing in sensor file '%s'",
281 sfile);
282 error(USER, errmsg);
283 }
284 if (i != (ntp[0]+1)*(ntp[1]+1)) {
285 sprintf(errmsg,
286 "bad column count near line %d in sensor file '%s'",
287 ntp[0]+1, sfile);
288 error(USER, errmsg);
289 }
290 }
291 nelem = i;
292 fclose(fp);
293 errmsg[0] = '\0'; /* sanity checks */
294 if (ntp[0] <= 0)
295 sprintf(errmsg, "no data in sensor file '%s'", sfile);
296 else if (fabs(sarr[ntp[1]+1]) > FTINY)
297 sprintf(errmsg, "minimum theta must be 0 in sensor file '%s'",
298 sfile);
299 else if (fabs(sarr[1]) > FTINY)
300 sprintf(errmsg, "minimum phi must be 0 in sensor file '%s'",
301 sfile);
302 else if (sarr[ntp[1]] <= FTINY)
303 sprintf(errmsg,
304 "maximum phi must be positive in sensor file '%s'",
305 sfile);
306 else if (sarr[ntp[0]*(ntp[1]+1)] <= FTINY)
307 sprintf(errmsg,
308 "maximum theta must be positive in sensor file '%s'",
309 sfile);
310 if (errmsg[0])
311 error(USER, errmsg);
312 return((float *)realloc((void *)sarr, sizeof(float)*nelem));
313 }
314
315 /* Initialize probability table */
316 static void
317 init_ptable(
318 char *sfile
319 )
320 {
321 int samptot = nsamps;
322 float *rowp, *rowp1;
323 double rowsum[MAXNT], rowomega[MAXNT];
324 double thdiv[MAXNT+1], phdiv[MAXNP+1];
325 double tsize, psize;
326 double prob, frac, frac1;
327 int i, j, t, p;
328 /* free old table */
329 if (sensor != NULL)
330 free((void *)sensor);
331 if (pvals != NULL)
332 free((void *)pvals);
333 if (sfile == NULL || !*sfile) {
334 sensor = NULL;
335 sntp[0] = sntp[1] = 0;
336 pvals = NULL;
337 ntheta = nphi = 0;
338 return;
339 }
340 /* load sensor table */
341 sensor = load_sensor(sntp, sfile);
342 if (sntp[0] > MAXNT) {
343 sprintf(errmsg, "Too many theta rows in sensor file '%s'",
344 sfile);
345 error(INTERNAL, errmsg);
346 }
347 if (sntp[1] > MAXNP) {
348 sprintf(errmsg, "Too many phi columns in sensor file '%s'",
349 sfile);
350 error(INTERNAL, errmsg);
351 }
352 /* compute boundary angles */
353 maxtheta = DEGREE*(1.5f*s_theta(sntp[0]-1) - 0.5f*s_theta(sntp[0]-2));
354 if (maxtheta > PI)
355 maxtheta = PI;
356 thdiv[0] = .0;
357 for (t = 1; t < sntp[0]; t++)
358 thdiv[t] = DEGREE/2.*(s_theta(t-1) + s_theta(t));
359 thdiv[sntp[0]] = maxtheta;
360 phdiv[0] = DEGREE*(1.5f*s_phi(0) - 0.5f*s_phi(1));
361 for (p = 1; p < sntp[1]; p++)
362 phdiv[p] = DEGREE/2.*(s_phi(p-1) + s_phi(p));
363 phdiv[sntp[1]] = DEGREE*(1.5f*s_phi(sntp[1]-1) - 0.5f*s_phi(sntp[1]-2));
364 /* size our table */
365 tsize = 1. - cos(maxtheta);
366 psize = PI*tsize/maxtheta;
367 if (sntp[0]*sntp[1] < samptot) /* don't overdo resolution */
368 samptot = sntp[0]*sntp[1];
369 ntheta = (int)(sqrt((double)samptot*tsize/psize) + 0.5);
370 if (ntheta > MAXNT)
371 ntheta = MAXNT;
372 nphi = samptot/ntheta;
373 pvals = (float *)malloc(sizeof(float)*(ntheta+1)*(nphi+1));
374 if (pvals == NULL)
375 error(SYSTEM, "out of memory in init_ptable()");
376 gscale = .0; /* compute our inverse table */
377 for (i = 0; i < sntp[0]; i++) {
378 rowp = &s_val(i,0);
379 rowsum[i] = 1e-20;
380 for (j = 0; j < sntp[1]; j++)
381 rowsum[i] += *rowp++;
382 rowomega[i] = cos(thdiv[i]) - cos(thdiv[i+1]);
383 rowomega[i] *= 2.*PI / (double)sntp[1];
384 gscale += rowsum[i] * rowomega[i];
385 }
386 if (gscale <= FTINY) {
387 sprintf(errmsg, "Sensor values sum to zero in file '%s'", sfile);
388 error(USER, errmsg);
389 }
390 for (i = 0; i < ntheta; i++) {
391 prob = (double)i / (double)ntheta;
392 for (t = 0; t < sntp[0]; t++)
393 if ((prob -= rowsum[t]*rowomega[t]/gscale) <= .0)
394 break;
395 if (t >= sntp[0])
396 error(INTERNAL, "code error 1 in init_ptable()");
397 frac = 1. + prob/(rowsum[t]*rowomega[t]/gscale);
398 tvals[i] = 1. - ( (1.-frac)*cos(thdiv[t]) +
399 frac*cos(thdiv[t+1]) );
400 /* offset b/c sensor values are centered */
401 if (!t || (t < sntp[0]-1) & (frac >= 0.5))
402 frac -= 0.5;
403 else {
404 frac += 0.5;
405 --t;
406 }
407 pvals[i*(nphi+1)] = phdiv[0];
408 for (j = 1; j < nphi; j++) {
409 prob = (double)j / (double)nphi;
410 rowp = &s_val(t,0);
411 rowp1 = &s_val(t+1,0);
412 for (p = 0; p < sntp[1]; p++)
413 if ((prob -= (1.-frac)*rowp[p]/rowsum[t] +
414 frac*rowp1[p]/rowsum[t+1]) <= .0)
415 break;
416 if (p >= sntp[1]) { /* should never happen? */
417 p = sntp[1] - 1;
418 prob = .5;
419 }
420 frac1 = 1. + prob/((1.-frac)*rowp[p]/rowsum[t]
421 + frac*rowp1[p]/rowsum[t+1]);
422 pvals[i*(nphi+1) + j] = (1.-frac1)*phdiv[p] +
423 frac1*phdiv[p+1];
424 }
425 pvals[i*(nphi+1) + nphi] = phdiv[sntp[1]];
426 }
427 tvals[0] = .0f;
428 tvals[ntheta] = (float)tsize;
429 }
430
431 /* Get normalized direction from random variables in [0,1) range */
432 static void
433 get_direc(
434 FVECT dvec,
435 double x,
436 double y
437 )
438 {
439 double xfrac = x*ntheta;
440 int tndx = (int)xfrac;
441 double yfrac = y*nphi;
442 int pndx = (int)yfrac;
443 double rad, phi;
444 FVECT dv;
445 int i;
446
447 xfrac -= (double)tndx;
448 yfrac -= (double)pndx;
449 pndx += tndx*(nphi+1);
450
451 dv[2] = 1. - ((1.-xfrac)*tvals[tndx] + xfrac*tvals[tndx+1]);
452 rad = sqrt(1. - dv[2]*dv[2]);
453 phi = (1.-yfrac)*pvals[pndx] + yfrac*pvals[pndx+1];
454 dv[0] = -rad*sin(phi);
455 dv[1] = rad*cos(phi);
456 for (i = 3; i--; )
457 dvec[i] = dv[0]*ourview.hvec[i] +
458 dv[1]*ourview.vvec[i] +
459 dv[2]*ourview.vdir[i] ;
460 }
461
462 /* Get sensor value in the specified direction (normalized) */
463 static float
464 sens_val(
465 FVECT dvec
466 )
467 {
468 FVECT dv;
469 float theta, phi;
470 int t, p;
471
472 dv[2] = DOT(dvec, ourview.vdir);
473 theta = acos(dv[2]);
474 if (theta >= maxtheta)
475 return(.0f);
476 dv[0] = DOT(dvec, ourview.hvec);
477 dv[1] = DOT(dvec, ourview.vvec);
478 phi = atan2(-dv[0], dv[1]);
479 while (phi < .0f) phi += (float)(2.*PI);
480 t = (int)(theta/maxtheta * sntp[0]);
481 p = (int)(phi*(1./(2.*PI)) * sntp[1]);
482 /* hack for non-uniform sensor grid */
483 theta *= (float)(1./DEGREE);
484 phi *= (float)(1./DEGREE);
485 while (t+1 < sntp[0] && theta >= s_theta(t+1))
486 ++t;
487 while (t-1 >= 0 && theta <= s_theta(t-1))
488 --t;
489 while (p+1 < sntp[1] && phi >= s_phi(p+1))
490 ++p;
491 while (p-1 >= 0 && phi <= s_phi(p-1))
492 --p;
493 return(s_val(t,p));
494 }
495
496 /* Print origin and direction */
497 static void
498 print_ray(
499 FVECT rorg,
500 FVECT rdir
501 )
502 {
503 printf("%.6g %.6g %.6g %.8f %.8f %.8f\n",
504 rorg[0], rorg[1], rorg[2],
505 rdir[0], rdir[1], rdir[2]);
506 }
507
508 /* Compute sensor output */
509 static void
510 comp_sensor(
511 char *sfile
512 )
513 {
514 int ndirs = dstrsrc > FTINY ? ndsamps :
515 ndsamps > 0 ? 1 : 0;
516 char *err;
517 int nt, np;
518 COLOR vsum;
519 RAY rr;
520 double sf;
521 int i, j;
522 /* set view */
523 ourview.type = VT_ANG;
524 ourview.horiz = ourview.vert = 180.;
525 ourview.hoff = ourview.voff = .0;
526 err = setview(&ourview);
527 if (err != NULL)
528 error(USER, err);
529 /* assign probability table */
530 init_ptable(sfile);
531 /* stratified MC sampling */
532 setcolor(vsum, .0f, .0f, .0f);
533 nt = (int)(sqrt((double)nsamps*ntheta/nphi) + .5);
534 np = nsamps/nt;
535 sf = gscale/nsamps;
536 for (i = 0; i < nt; i++)
537 for (j = 0; j < np; j++) {
538 VCOPY(rr.rorg, ourview.vp);
539 get_direc(rr.rdir, (i+frandom())/nt, (j+frandom())/np);
540 if (ourview.vfore > FTINY)
541 VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore);
542 if (!ray_pnprocs) {
543 print_ray(rr.rorg, rr.rdir);
544 continue;
545 }
546 rr.rmax = .0;
547 rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL);
548 scalecolor(rr.rcoef, sf);
549 if (ray_pqueue(&rr) == 1)
550 addcolor(vsum, rr.rcol);
551 }
552 /* remaining rays pure MC */
553 for (i = nsamps - nt*np; i-- > 0; ) {
554 VCOPY(rr.rorg, ourview.vp);
555 get_direc(rr.rdir, frandom(), frandom());
556 if (ourview.vfore > FTINY)
557 VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore);
558 if (!ray_pnprocs) {
559 print_ray(rr.rorg, rr.rdir);
560 continue;
561 }
562 rr.rmax = .0;
563 rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL);
564 scalecolor(rr.rcoef, sf);
565 if (ray_pqueue(&rr) == 1)
566 addcolor(vsum, rr.rcol);
567 }
568 if (!ray_pnprocs) /* just printing rays */
569 return;
570 /* scale partial result */
571 scalecolor(vsum, sf);
572 /* add direct component */
573 for (i = ndirs; i-- > 0; ) {
574 SRCINDEX si;
575 initsrcindex(&si);
576 while (srcray(&rr, NULL, &si)) {
577 sf = sens_val(rr.rdir);
578 if (sf <= FTINY)
579 continue;
580 sf *= si.dom/ndirs;
581 scalecolor(rr.rcoef, sf);
582 if (ray_pqueue(&rr) == 1) {
583 multcolor(rr.rcol, rr.rcoef);
584 addcolor(vsum, rr.rcol);
585 }
586 }
587 }
588 /* finish our calculation */
589 while (ray_presult(&rr, 0) > 0) {
590 multcolor(rr.rcol, rr.rcoef);
591 addcolor(vsum, rr.rcol);
592 }
593 /* print our result */
594 printf("%.4e %.4e %.4e\n", colval(vsum,RED),
595 colval(vsum,GRN), colval(vsum,BLU));
596 }
