root/radiance/ray/src/util/rsensor.c
Revision: 2.20
Committed: Fri Jul 24 17:09:33 2020 UTC (3 years, 10 months ago) by greg
Changes since 2.19: +2 -1 lines
fix(rsensor): added missing declaration for _exit()
2 static const char RCSid[] = "$Id: rsensor.c,v 2.19 2020/07/20 15:54:29 greg Exp $";
4
5 /*
6 * Compute sensor signal based on spatial sensitivity.
7 *
8 * Created Feb 2008 for Architectural Energy Corp.
9 */
10
11 #include "ray.h"
12 #include "platform.h"
13 #include "source.h"
14 #include "view.h"
15 #include "random.h"
16
17 #define DEGREE (PI/180.)
18
19 #define MAXNT 181 /* maximum number of theta divisions */
20 #define MAXNP 360 /* maximum number of phi divisions */
21
22 extern char *progname; /* global argv[0] */
23 extern int nowarn; /* don't report warnings? */
24
25 /* current sensor's perspective */
26 VIEW ourview = {VT_ANG,{0.,0.,0.},{0.,0.,1.},{1.,0.,0.},
27 1.,180.,180.,0.,0.,0.,0.,
28 {0.,0.,0.},{0.,0.,0.},0.,0.};
29
30 unsigned long nsamps = 10000; /* desired number of initial samples */
31 unsigned long nssamps = 9000; /* number of super-samples */
32 int ndsamps = 32; /* number of direct samples */
33 int nprocs = 1; /* number of rendering processes */
34
35 float *sensor = NULL; /* current sensor data */
36 int sntp[2]; /* number of sensor theta and phi angles */
37 float maxtheta; /* maximum theta value for this sensor */
38 float tvals[MAXNT+1]; /* theta prob. values (1-D table of 1-cos(t)) */
39 float *pvals = NULL; /* phi prob. values (2-D table in radians) */
40 int ntheta = 0; /* polar angle divisions */
41 int nphi = 0; /* azimuthal angle divisions */
42 double gscale = 1.; /* global scaling value */
43
44 #define s_theta(t) sensor[(t+1)*(sntp[1]+1)]
45 #define s_phi(p) sensor[(p)+1]
46 #define s_val(t,p) sensor[(p)+1+(t+1)*(sntp[1]+1)]
47
48 static void comp_sensor(char *sfile);
49
50 static void
51 over_options() /* overriding options */
52 {
53 directvis = (ndsamps <= 0);
54 do_irrad = 0;
55 }
56
57 static void
58 print_defaults() /* print out default parameters */
59 {
60 over_options();
61 printf("-n %-9d\t\t\t# number of processes\n", nprocs);
62 printf("-rd %-9ld\t\t\t# ray directions\n", nsamps);
63 /* printf("-rs %-9ld\t\t\t# ray super-samples\n", nssamps); */
64 printf("-dn %-9d\t\t\t# direct number of samples\n", ndsamps);
65 printf("-vp %f %f %f\t# view point\n",
66 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
67 printf("-vd %f %f %f\t# view direction\n",
68 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
69 printf("-vu %f %f %f\t# view up\n",
70 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
71 printf("-vo %f\t\t\t# view fore clipping distance\n", ourview.vfore);
72 print_rdefaults();
73 }
74
75
76 void
77 quit(ec) /* make sure exit is called */
78 int ec;
79 {
80 if (ray_pnprocs > 0) /* close children if any */
81 ray_pclose(0);
82 else if (ray_pnprocs < 0)
83 _exit(ec); /* avoid flush in child */
84 exit(ec);
85 }
86
87
88 int
89 main(
90 int argc,
91 char *argv[]
92 )
93 {
94 int doheader = 1;
95 int optwarn = 0;
96 int i, rval;
97
98 progname = argv[0];
99 /* set up rendering defaults */
100 rand_samp = 1;
101 dstrsrc = 0.65;
102 srcsizerat = 0.1;
103 directrelay = 3;
104 ambounce = 1;
105 maxdepth = -10;
106 /* get options from command line */
107 for (i = 1; i < argc; i++) {
108 while ((rval = expandarg(&argc, &argv, i)) > 0)
109 ;
110 if (rval < 0) {
111 sprintf(errmsg, "cannot expand '%s'", argv[i]);
112 error(SYSTEM, errmsg);
113 }
114 if (argv[i][0] != '-') {
115 if (i >= argc-1)
116 break; /* final octree argument */
117 if (!ray_pnprocs) {
118 over_options();
119 if (doheader) { /* print header */
120 newheader("RADIANCE", stdout);
121 printargs(argc, argv, stdout);
122 fputformat("ascii", stdout);
123 putchar('\n');
124 }
125 /* start process(es) */
126 if (strcmp(argv[argc-1], "."))
127 ray_pinit(argv[argc-1], nprocs);
128 }
129 comp_sensor(argv[i]); /* process a sensor file */
130 continue;
131 }
132 if (argv[i][1] == 'r') { /* sampling options */
133 if (argv[i][2] == 'd')
134 nsamps = atol(argv[++i]);
135 else if (argv[i][2] == 's')
136 nssamps = atol(argv[++i]);
137 else {
138 sprintf(errmsg, "bad option at '%s'", argv[i]);
139 error(USER, errmsg);
140 }
141 continue;
142 }
143 /* direct component samples */
144 if (argv[i][1] == 'd' && argv[i][2] == 'n') {
145 ndsamps = atoi(argv[++i]);
146 continue;
147 }
148 if (argv[i][1] == 'v') { /* next sensor view */
149 if (argv[i][2] == 'f') {
150 rval = viewfile(argv[++i], &ourview, NULL);
151 if (rval < 0) {
152 sprintf(errmsg,
153 "cannot open view file \"%s\"",
154 argv[i]);
155 error(SYSTEM, errmsg);
156 } else if (rval == 0) {
157 sprintf(errmsg,
158 "bad view file \"%s\"",
159 argv[i]);
160 error(USER, errmsg);
161 }
162 continue;
163 }
164 rval = getviewopt(&ourview, argc-i, argv+i);
165 if (rval >= 0) {
166 i += rval;
167 continue;
168 }
169 sprintf(errmsg, "bad view option at '%s'", argv[i]);
170 error(USER, errmsg);
171 }
172 if (!strcmp(argv[i], "-w")) { /* toggle warnings */
173 nowarn = !nowarn;
174 continue;
175 }
176 if (ray_pnprocs) {
177 if (!optwarn++)
178 error(WARNING,
179 "rendering options should appear before first sensor");
180 } else if (!strcmp(argv[i], "-defaults")) {
181 print_defaults();
182 return(0);
183 }
184 if (argv[i][1] == 'h') { /* header toggle */
185 doheader = !doheader;
186 continue;
187 }
188 if (!strcmp(argv[i], "-n")) { /* number of processes */
189 nprocs = atoi(argv[++i]);
190 if (nprocs <= 0)
191 error(USER, "illegal number of processes");
192 continue;
193 }
194 rval = getrenderopt(argc-i, argv+i);
195 if (rval < 0) {
196 sprintf(errmsg, "bad render option at '%s'", argv[i]);
197 error(USER, errmsg);
198 }
199 i += rval;
200 }
201 if (sensor == NULL)
202 error(USER, i<argc ? "missing sensor file" : "missing octree");
203 quit(0);
204 }
205
206 /* Load sensor sensitivities (first row and column are angles) */
207 static float *
208 load_sensor(
209 int ntp[2],
210 char *sfile
211 )
212 {
213 int warnedneg;
214 char linebuf[8192];
215 int last_pos_val = 0;
216 int nelem = 1000;
217 float *sarr = (float *)malloc(sizeof(float)*nelem);
218 FILE *fp;
219 char *cp;
220 int i;
221
222 fp = frlibopen(sfile);
223 if (fp == NULL) {
224 sprintf(errmsg, "cannot open sensor file '%s'", sfile);
225 error(SYSTEM, errmsg);
226 }
227 fgets(linebuf, sizeof(linebuf), fp);
228 if (!strncmp(linebuf, "Elevation ", 10))
229 fgets(linebuf, sizeof(linebuf), fp);
230 /* get phi values */
231 sarr[0] = .0f;
232 if (strncmp(linebuf, "degrees", 7)) {
233 sprintf(errmsg, "Missing 'degrees' in sensor file '%s'", sfile);
234 error(USER, errmsg);
235 }
236 cp = sskip(linebuf);
237 ntp[1] = 0;
238 for ( ; ; ) {
239 sarr[ntp[1]+1] = atof(cp);
240 cp = fskip(cp);
241 if (cp == NULL)
242 break;
243 if (ntp[1] > 1 && sarr[ntp[1]+1] <= sarr[ntp[1]]+FTINY) {
244 sprintf(errmsg,
245 "Phi values not monotinically increasing in sensor file '%s'",
246 sfile);
247 error(USER, errmsg);
248 }
249 ++ntp[1];
250 }
251 warnedneg = 0;
252 ntp[0] = 0; /* get thetas + data */
253 while (fgets(linebuf, sizeof(linebuf), fp) != NULL) {
254 ++ntp[0];
255 if ((ntp[0]+1)*(ntp[1]+1) > nelem) {
256 nelem += (nelem>>2) + ntp[1];
257 sarr = (float *)realloc((void *)sarr,
258 sizeof(float)*nelem);
259 if (sarr == NULL)
260 error(SYSTEM, "out of memory in load_sensor()");
261 }
262 cp = linebuf;
263 i = ntp[0]*(ntp[1]+1);
264 for ( ; ; ) {
265 sarr[i] = atof(cp);
266 cp = fskip(cp);
267 if (cp == NULL)
268 break;
269 if (sarr[i] < .0) {
270 if (!warnedneg++) {
271 sprintf(errmsg,
272 "Negative value(s) in sensor file '%s' (ignored)\n", sfile);
273 error(WARNING, errmsg);
274 }
275 sarr[i] = .0;
276 } else if (sarr[i] > FTINY && i > ntp[0]*(ntp[1]+1))
277 last_pos_val = i;
278 ++i;
279 }
280 if (i == ntp[0]*(ntp[1]+1)) /* empty line? */
281 break;
282 if (ntp[0] > 1 && sarr[ntp[0]*(ntp[1]+1)] <=
283 sarr[(ntp[0]-1)*(ntp[1]+1)]) {
284 sprintf(errmsg,
285 "Theta values not monotinically increasing in sensor file '%s'",
286 sfile);
287 error(USER, errmsg);
288 }
289 if (i != (ntp[0]+1)*(ntp[1]+1)) {
290 sprintf(errmsg,
291 "bad column count near line %d in sensor file '%s'",
292 ntp[0]+1, sfile);
293 error(USER, errmsg);
294 }
295 }
296 /* truncate zero region */
297 ntp[0] = (last_pos_val + ntp[1])/(ntp[1]+1) - 1;
298 nelem = (ntp[0]+1)*(ntp[1]+1);
299 fclose(fp);
300 errmsg[0] = '\0'; /* sanity checks */
301 if (!last_pos_val)
302 sprintf(errmsg, "no positive sensor values in file '%s'", sfile);
303 else if (fabs(sarr[ntp[1]+1]) > FTINY)
304 sprintf(errmsg, "minimum theta must be 0 in sensor file '%s'",
305 sfile);
306 else if (fabs(sarr[1]) > FTINY)
307 sprintf(errmsg, "minimum phi must be 0 in sensor file '%s'",
308 sfile);
309 else if (sarr[ntp[1]] < 270.-FTINY)
310 sprintf(errmsg,
311 "maximum phi must be 270 or greater in sensor file '%s'",
312 sfile);
313 else if (sarr[ntp[1]] >= 360.-FTINY)
314 sprintf(errmsg,
315 "maximum phi must be less than 360 in sensor file '%s'",
316 sfile);
317 if (errmsg[0])
318 error(USER, errmsg);
319 return((float *)realloc((void *)sarr, sizeof(float)*nelem));
320 }
321
322 /* Initialize probability table */
323 static void
324 init_ptable(
325 char *sfile
326 )
327 {
328 int samptot = nsamps;
329 float *rowp, *rowp1;
330 double rowsum[MAXNT], rowomega[MAXNT];
331 double thdiv[MAXNT+1], phdiv[MAXNP+1];
332 double tsize, psize;
333 double prob, frac, frac1;
334 int i, j, t, p;
335 /* free old table */
336 if (sensor != NULL)
337 free((void *)sensor);
338 if (pvals != NULL)
339 free((void *)pvals);
340 if (sfile == NULL || !*sfile) {
341 sensor = NULL;
342 sntp[0] = sntp[1] = 0;
343 pvals = NULL;
344 ntheta = nphi = 0;
345 return;
346 }
347 /* load sensor table */
348 sensor = load_sensor(sntp, sfile);
349 if (sntp[0] > MAXNT) {
350 sprintf(errmsg, "Too many theta rows in sensor file '%s'",
351 sfile);
352 error(INTERNAL, errmsg);
353 }
354 if (sntp[1] > MAXNP) {
355 sprintf(errmsg, "Too many phi columns in sensor file '%s'",
356 sfile);
357 error(INTERNAL, errmsg);
358 }
359 /* compute boundary angles */
360 maxtheta = DEGREE*(1.5f*s_theta(sntp[0]-1) - 0.5f*s_theta(sntp[0]-2));
361 if (maxtheta > PI)
362 maxtheta = PI;
363 thdiv[0] = .0;
364 for (t = 1; t < sntp[0]; t++)
365 thdiv[t] = DEGREE/2.*(s_theta(t-1) + s_theta(t));
366 thdiv[sntp[0]] = maxtheta;
367 phdiv[0] = DEGREE*(1.5f*s_phi(0) - 0.5f*s_phi(1));
368 for (p = 1; p < sntp[1]; p++)
369 phdiv[p] = DEGREE/2.*(s_phi(p-1) + s_phi(p));
370 phdiv[sntp[1]] = DEGREE*(1.5f*s_phi(sntp[1]-1) - 0.5f*s_phi(sntp[1]-2));
371 /* size our table */
372 tsize = 1. - cos(maxtheta);
373 psize = PI*tsize/maxtheta;
374 if (sntp[0]*sntp[1] < samptot) /* don't overdo resolution */
375 samptot = sntp[0]*sntp[1];
376 ntheta = (int)(sqrt((double)samptot*tsize/psize)*sntp[0]/sntp[1]) + 1;
377 if (ntheta > MAXNT)
378 ntheta = MAXNT;
379 nphi = samptot/ntheta;
380 pvals = (float *)malloc(sizeof(float)*(ntheta+1)*(nphi+1));
381 if (pvals == NULL)
382 error(SYSTEM, "out of memory in init_ptable()");
383 gscale = .0; /* compute our inverse table */
384 for (i = 0; i < sntp[0]; i++) {
385 rowp = &s_val(i,0);
386 rowsum[i] = 1e-20;
387 for (j = 0; j < sntp[1]; j++)
388 rowsum[i] += *rowp++;
389 rowomega[i] = cos(thdiv[i]) - cos(thdiv[i+1]);
390 rowomega[i] *= 2.*PI / (double)sntp[1];
391 gscale += rowsum[i] * rowomega[i];
392 }
393 if (gscale <= FTINY) {
394 sprintf(errmsg, "Sensor values sum to zero in file '%s'", sfile);
395 error(USER, errmsg);
396 }
397 for (i = 0; i < ntheta; i++) {
398 prob = (double)i / (double)ntheta;
399 for (t = 0; t < sntp[0]; t++)
400 if ((prob -= rowsum[t]*rowomega[t]/gscale) <= .0)
401 break;
402 if (t >= sntp[0])
403 error(INTERNAL, "code error 1 in init_ptable()");
404 frac = 1. + prob/(rowsum[t]*rowomega[t]/gscale);
405 tvals[i] = 1. - ( (1.-frac)*cos(thdiv[t]) +
406 frac*cos(thdiv[t+1]) );
407 /* offset b/c sensor values are centered */
408 if ((t < sntp[0]-1) & (!t | (frac >= 0.5))) {
409 frac -= 0.5;
410 } else {
411 frac += 0.5;
412 --t;
413 }
414 pvals[i*(nphi+1)] = phdiv[0];
415 for (j = 1; j < nphi; j++) {
416 prob = (double)j / (double)nphi;
417 rowp = &s_val(t,0);
418 rowp1 = &s_val(t+1,0);
419 for (p = 0; p < sntp[1]; p++)
420 if ((prob -= (1.-frac)*rowp[p]/rowsum[t] +
421 frac*rowp1[p]/rowsum[t+1]) <= .0)
422 break;
423 if (p >= sntp[1]) { /* should never happen? */
424 p = sntp[1] - 1;
425 prob = .5;
426 }
427 frac1 = 1. + prob/((1.-frac)*rowp[p]/rowsum[t]
428 + frac*rowp1[p]/rowsum[t+1]);
429 pvals[i*(nphi+1) + j] = (1.-frac1)*phdiv[p] +
430 frac1*phdiv[p+1];
431 }
432 pvals[i*(nphi+1) + nphi] = phdiv[sntp[1]];
433 }
434 /* duplicate final row */
435 memcpy(pvals+ntheta*(nphi+1), pvals+(ntheta-1)*(nphi+1),
436 sizeof(*pvals)*(nphi+1));
437 tvals[0] = .0f;
438 tvals[ntheta] = (float)tsize;
439 }
440
441 /* Get normalized direction from random variables in [0,1) range */
442 static void
443 get_direc(
444 FVECT dvec,
445 double x,
446 double y
447 )
448 {
449 double xfrac = x*ntheta;
450 int tndx = (int)xfrac;
451 double yfrac = y*nphi;
452 int pndx = (int)yfrac;
453 double rad, phi;
454 FVECT dv;
455 int i;
456
457 xfrac -= (double)tndx;
458 yfrac -= (double)pndx;
459 pndx += tndx*(nphi+1);
460
461 dv[2] = 1. - ((1.-xfrac)*tvals[tndx] + xfrac*tvals[tndx+1]);
462 rad = sqrt(1. - dv[2]*dv[2]);
463 phi = (1.-yfrac)*pvals[pndx] + yfrac*pvals[pndx+1];
464 dv[0] = -rad*sin(phi);
465 dv[1] = rad*cos(phi);
466 for (i = 3; i--; )
467 dvec[i] = dv[0]*ourview.hvec[i] +
468 dv[1]*ourview.vvec[i] +
469 dv[2]*ourview.vdir[i] ;
470 }
471
472 /* Get sensor value in the specified direction (normalized) */
473 static float
474 sens_val(
475 FVECT dvec
476 )
477 {
478 FVECT dv;
479 float theta, phi;
480 int t, p;
481
482 dv[2] = DOT(dvec, ourview.vdir);
483 theta = acos(dv[2]);
484 if (theta >= maxtheta)
485 return(.0f);
486 dv[0] = DOT(dvec, ourview.hvec);
487 dv[1] = DOT(dvec, ourview.vvec);
488 phi = atan2(-dv[0], dv[1]);
489 while (phi < .0f) phi += (float)(2.*PI);
490 t = (int)(theta/maxtheta * sntp[0]);
491 p = (int)(phi*(1./(2.*PI)) * sntp[1]);
492 /* hack for non-uniform sensor grid */
493 theta *= (float)(1./DEGREE);
494 phi *= (float)(1./DEGREE);
495 while (t+1 < sntp[0] && theta >= s_theta(t+1))
496 ++t;
497 while (t-1 >= 0 && theta <= s_theta(t-1))
498 --t;
499 while (p+1 < sntp[1] && phi >= s_phi(p+1))
500 ++p;
501 while (p-1 >= 0 && phi <= s_phi(p-1))
502 --p;
503 return(s_val(t,p));
504 }
505
506 /* Print origin and direction */
507 static void
508 print_ray(
509 FVECT rorg,
510 FVECT rdir
511 )
512 {
513 printf("%.6g %.6g %.6g %.8f %.8f %.8f\n",
514 rorg[0], rorg[1], rorg[2],
515 rdir[0], rdir[1], rdir[2]);
516 }
517
518 /* Compute sensor output */
519 static void
520 comp_sensor(
521 char *sfile
522 )
523 {
524 int ndirs = dstrsrc > FTINY ? ndsamps :
525 ndsamps > 0 ? 1 : 0;
526 char *err;
527 int nt, np;
528 COLOR vsum;
529 RAY rr;
530 double sf;
531 int i, j;
532 /* set view */
533 ourview.type = VT_ANG;
534 ourview.horiz = ourview.vert = 180.;
535 ourview.hoff = ourview.voff = .0;
536 err = setview(&ourview);
537 if (err != NULL)
538 error(USER, err);
539 /* assign probability table */
540 init_ptable(sfile);
541 /* stratified MC sampling */
542 setcolor(vsum, .0f, .0f, .0f);
543 nt = (int)(sqrt((double)nsamps*ntheta/nphi) + .5);
544 np = nsamps/nt;
545 sf = gscale/nsamps;
546 for (i = 0; i < nt; i++)
547 for (j = 0; j < np; j++) {
548 VCOPY(rr.rorg, ourview.vp);
549 get_direc(rr.rdir, (i+frandom())/nt, (j+frandom())/np);
550 if (ourview.vfore > FTINY)
551 VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore);
552 if (!ray_pnprocs) {
553 print_ray(rr.rorg, rr.rdir);
554 continue;
555 }
556 rr.rmax = .0;
557 rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL);
558 scalecolor(rr.rcoef, sf);
559 if (ray_pqueue(&rr) == 1)
560 addcolor(vsum, rr.rcol);
561 }
562 /* remaining rays pure MC */
563 for (i = nsamps - nt*np; i-- > 0; ) {
564 VCOPY(rr.rorg, ourview.vp);
565 get_direc(rr.rdir, frandom(), frandom());
566 if (ourview.vfore > FTINY)
567 VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore);
568 if (!ray_pnprocs) {
569 print_ray(rr.rorg, rr.rdir);
570 continue;
571 }
572 rr.rmax = .0;
573 rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL);
574 scalecolor(rr.rcoef, sf);
575 if (ray_pqueue(&rr) == 1)
576 addcolor(vsum, rr.rcol);
577 }
578 if (!ray_pnprocs) /* just printing rays */
579 return;
580 /* scale partial result */
581 scalecolor(vsum, sf);
582 /* add direct component */
583 for (i = ndirs; i-- > 0; ) {
584 SRCINDEX si;
585 initsrcindex(&si);
586 while (srcray(&rr, NULL, &si)) {
587 sf = sens_val(rr.rdir);
588 if (sf <= FTINY)
589 continue;
590 sf *= si.dom/ndirs;
591 scalecolor(rr.rcoef, sf);
592 if (ray_pqueue(&rr) == 1) {
593 multcolor(rr.rcol, rr.rcoef);
594 addcolor(vsum, rr.rcol);
595 }
596 }
597 }
598 /* finish our calculation */
599 while (ray_presult(&rr, 0) > 0) {
600 multcolor(rr.rcol, rr.rcoef);
601 addcolor(vsum, rr.rcol);
602 }
603 /* print our result */
604 printf("%.4e %.4e %.4e\n", colval(vsum,RED),
605 colval(vsum,GRN), colval(vsum,BLU));
606 }
