--- ray/src/util/rsensor.c 2008/02/22 18:04:02 2.3 +++ ray/src/util/rsensor.c 2009/12/12 19:01:00 2.7 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rsensor.c,v 2.3 2008/02/22 18:04:02 greg Exp $"; +static const char RCSid[] = "$Id: rsensor.c,v 2.7 2009/12/12 19:01:00 greg Exp $"; #endif /* @@ -22,7 +22,9 @@ extern char *progname; /* global argv[0] */ extern int nowarn; /* don't report warnings? */ /* current sensor's perspective */ -VIEW ourview = STDVIEW; +VIEW ourview = {VT_ANG,{0.,0.,0.},{0.,0.,1.},{1.,0.,0.}, + 1.,180.,180.,0.,0.,0.,0., + {0.,0.,0.},{0.,0.,0.},0.,0.}; unsigned long nsamps = 10000; /* desired number of initial samples */ unsigned long nssamps = 9000; /* number of super-samples */ @@ -69,6 +71,17 @@ print_defaults() /* print out default parameters */ print_rdefaults(); } + +void +quit(ec) /* make sure exit is called */ +int ec; +{ + if (ray_pnprocs > 0) /* close children if any */ + ray_pclose(0); + exit(ec); +} + + int main( int argc, @@ -82,7 +95,7 @@ main( progname = argv[0]; /* set up rendering defaults */ rand_samp = 1; - dstrsrc = 0.5; + dstrsrc = 0.65; srcsizerat = 0.1; directrelay = 3; ambounce = 1; @@ -101,6 +114,7 @@ main( if (!ray_pnprocs) { over_options(); if (doheader) { /* print header */ + newheader("RADIANCE", stdout); printargs(argc, argv, stdout); fputformat("ascii", stdout); putchar('\n'); @@ -374,12 +388,6 @@ init_ptable( "code error 2 in init_ptable()"); frac1 = 1. + prob/((1.-frac)*rowp[p]/rowsum[t] + frac*rowp1[p]/rowsum[t+1]); - if (p <= 0 || frac1 > 0.5) - frac1 -= 0.5; - else if (p >= sntp[1]-1 || frac1 < 0.5) { - frac1 += 0.5; - --p; - } pvals[i*(nphi+1) + j] = (1.-frac1)*phdiv[p] + frac1*phdiv[p+1]; } @@ -465,6 +473,7 @@ comp_sensor( int nt, np; COLOR vsum; RAY rr; + double sf; int i, j; /* set view */ ourview.type = VT_ANG; @@ -475,40 +484,54 @@ comp_sensor( error(USER, err); /* assign probability table */ init_ptable(sfile); - /* do Monte Carlo sampling */ + /* stratified MC sampling */ setcolor(vsum, .0f, .0f, .0f); nt = (int)(sqrt((double)nsamps*ntheta/nphi) + .5); np = nsamps/nt; - VCOPY(rr.rorg, ourview.vp); - rr.rmax = .0; + sf = gscale/nsamps; for (i = 0; i < nt; i++) for (j = 0; j < np; j++) { + VCOPY(rr.rorg, ourview.vp); get_direc(rr.rdir, (i+frandom())/nt, (j+frandom())/np); + if (ourview.vfore > FTINY) + VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore); + rr.rmax = .0; rayorigin(&rr, PRIMARY, NULL, NULL); + scalecolor(rr.rcoef, sf); if (ray_pqueue(&rr) == 1) addcolor(vsum, rr.rcol); } - /* finish MC calculation */ - while (ray_presult(&rr, 0) > 0) - addcolor(vsum, rr.rcol); - scalecolor(vsum, gscale/(nt*np)); - /* compute direct component */ + /* remaining rays pure MC */ + for (i = nsamps - nt*np; i-- > 0; ) { + VCOPY(rr.rorg, ourview.vp); + get_direc(rr.rdir, frandom(), frandom()); + if (ourview.vfore > FTINY) + VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore); + rr.rmax = .0; + rayorigin(&rr, PRIMARY, NULL, NULL); + scalecolor(rr.rcoef, sf); + if (ray_pqueue(&rr) == 1) + addcolor(vsum, rr.rcol); + } + /* scale partial result */ + scalecolor(vsum, sf); + /* add direct component */ for (i = ndirs; i-- > 0; ) { SRCINDEX si; initsrcindex(&si); while (srcray(&rr, NULL, &si)) { - double d = sens_val(rr.rdir); - if (d <= FTINY) + sf = sens_val(rr.rdir); + if (sf <= FTINY) continue; - d *= si.dom/ndirs; - scalecolor(rr.rcoef, d); + sf *= si.dom/ndirs; + scalecolor(rr.rcoef, sf); if (ray_pqueue(&rr) == 1) { multcolor(rr.rcol, rr.rcoef); addcolor(vsum, rr.rcol); } } } - /* finish direct calculation */ + /* finish our calculation */ while (ray_presult(&rr, 0) > 0) { multcolor(rr.rcol, rr.rcoef); addcolor(vsum, rr.rcol);
