1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rsensor.c,v 2.19 2020/07/20 15:54:29 greg Exp $"; |
3 |
#endif |
4 |
5 |
6 |
* Compute sensor signal based on spatial sensitivity. |
7 |
8 |
* Created Feb 2008 for Architectural Energy Corp. |
9 |
10 |
11 |
#include "ray.h" |
12 |
#include "platform.h" |
13 |
#include "source.h" |
14 |
#include "view.h" |
15 |
#include "random.h" |
16 |
17 |
#define DEGREE (PI/180.) |
18 |
19 |
#define MAXNT 181 /* maximum number of theta divisions */ |
20 |
#define MAXNP 360 /* maximum number of phi divisions */ |
21 |
22 |
extern char *progname; /* global argv[0] */ |
23 |
extern int nowarn; /* don't report warnings? */ |
24 |
25 |
/* current sensor's perspective */ |
26 |
VIEW ourview = {VT_ANG,{0.,0.,0.},{0.,0.,1.},{1.,0.,0.}, |
27 |
1.,180.,180.,0.,0.,0.,0., |
28 |
{0.,0.,0.},{0.,0.,0.},0.,0.}; |
29 |
30 |
unsigned long nsamps = 10000; /* desired number of initial samples */ |
31 |
unsigned long nssamps = 9000; /* number of super-samples */ |
32 |
int ndsamps = 32; /* number of direct samples */ |
33 |
int nprocs = 1; /* number of rendering processes */ |
34 |
35 |
float *sensor = NULL; /* current sensor data */ |
36 |
int sntp[2]; /* number of sensor theta and phi angles */ |
37 |
float maxtheta; /* maximum theta value for this sensor */ |
38 |
float tvals[MAXNT+1]; /* theta prob. values (1-D table of 1-cos(t)) */ |
39 |
float *pvals = NULL; /* phi prob. values (2-D table in radians) */ |
40 |
int ntheta = 0; /* polar angle divisions */ |
41 |
int nphi = 0; /* azimuthal angle divisions */ |
42 |
double gscale = 1.; /* global scaling value */ |
43 |
44 |
#define s_theta(t) sensor[(t+1)*(sntp[1]+1)] |
45 |
#define s_phi(p) sensor[(p)+1] |
46 |
#define s_val(t,p) sensor[(p)+1+(t+1)*(sntp[1]+1)] |
47 |
48 |
static void comp_sensor(char *sfile); |
49 |
50 |
static void |
51 |
over_options() /* overriding options */ |
52 |
53 |
directvis = (ndsamps <= 0); |
54 |
do_irrad = 0; |
55 |
56 |
57 |
static void |
58 |
print_defaults() /* print out default parameters */ |
59 |
60 |
over_options(); |
61 |
printf("-n %-9d\t\t\t# number of processes\n", nprocs); |
62 |
printf("-rd %-9ld\t\t\t# ray directions\n", nsamps); |
63 |
/* printf("-rs %-9ld\t\t\t# ray super-samples\n", nssamps); */ |
64 |
printf("-dn %-9d\t\t\t# direct number of samples\n", ndsamps); |
65 |
printf("-vp %f %f %f\t# view point\n", |
66 |
ourview.vp[0], ourview.vp[1], ourview.vp[2]); |
67 |
printf("-vd %f %f %f\t# view direction\n", |
68 |
ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]); |
69 |
printf("-vu %f %f %f\t# view up\n", |
70 |
ourview.vup[0], ourview.vup[1], ourview.vup[2]); |
71 |
printf("-vo %f\t\t\t# view fore clipping distance\n", ourview.vfore); |
72 |
print_rdefaults(); |
73 |
74 |
75 |
76 |
void |
77 |
quit(ec) /* make sure exit is called */ |
78 |
int ec; |
79 |
80 |
if (ray_pnprocs > 0) /* close children if any */ |
81 |
ray_pclose(0); |
82 |
else if (ray_pnprocs < 0) |
83 |
_exit(ec); /* avoid flush in child */ |
84 |
exit(ec); |
85 |
86 |
87 |
88 |
int |
89 |
main( |
90 |
int argc, |
91 |
char *argv[] |
92 |
93 |
94 |
int doheader = 1; |
95 |
int optwarn = 0; |
96 |
int i, rval; |
97 |
98 |
progname = argv[0]; |
99 |
/* set up rendering defaults */ |
100 |
rand_samp = 1; |
101 |
dstrsrc = 0.65; |
102 |
srcsizerat = 0.1; |
103 |
directrelay = 3; |
104 |
ambounce = 1; |
105 |
maxdepth = -10; |
106 |
/* get options from command line */ |
107 |
for (i = 1; i < argc; i++) { |
108 |
while ((rval = expandarg(&argc, &argv, i)) > 0) |
109 |
110 |
if (rval < 0) { |
111 |
sprintf(errmsg, "cannot expand '%s'", argv[i]); |
112 |
error(SYSTEM, errmsg); |
113 |
114 |
if (argv[i][0] != '-') { |
115 |
if (i >= argc-1) |
116 |
break; /* final octree argument */ |
117 |
if (!ray_pnprocs) { |
118 |
over_options(); |
119 |
if (doheader) { /* print header */ |
120 |
newheader("RADIANCE", stdout); |
121 |
printargs(argc, argv, stdout); |
122 |
fputformat("ascii", stdout); |
123 |
putchar('\n'); |
124 |
125 |
/* start process(es) */ |
126 |
if (strcmp(argv[argc-1], ".")) |
127 |
ray_pinit(argv[argc-1], nprocs); |
128 |
129 |
comp_sensor(argv[i]); /* process a sensor file */ |
130 |
continue; |
131 |
132 |
if (argv[i][1] == 'r') { /* sampling options */ |
133 |
if (argv[i][2] == 'd') |
134 |
nsamps = atol(argv[++i]); |
135 |
else if (argv[i][2] == 's') |
136 |
nssamps = atol(argv[++i]); |
137 |
else { |
138 |
sprintf(errmsg, "bad option at '%s'", argv[i]); |
139 |
error(USER, errmsg); |
140 |
141 |
continue; |
142 |
143 |
/* direct component samples */ |
144 |
if (argv[i][1] == 'd' && argv[i][2] == 'n') { |
145 |
ndsamps = atoi(argv[++i]); |
146 |
continue; |
147 |
148 |
if (argv[i][1] == 'v') { /* next sensor view */ |
149 |
if (argv[i][2] == 'f') { |
150 |
rval = viewfile(argv[++i], &ourview, NULL); |
151 |
if (rval < 0) { |
152 |
sprintf(errmsg, |
153 |
"cannot open view file \"%s\"", |
154 |
argv[i]); |
155 |
156 |
} else if (rval == 0) { |
157 |
sprintf(errmsg, |
158 |
"bad view file \"%s\"", |
159 |
argv[i]); |
160 |
161 |
162 |
continue; |
163 |
164 |
rval = getviewopt(&ourview, argc-i, argv+i); |
165 |
if (rval >= 0) { |
166 |
i += rval; |
167 |
continue; |
168 |
169 |
sprintf(errmsg, "bad view option at '%s'", argv[i]); |
170 |
171 |
172 |
if (!strcmp(argv[i], "-w")) { /* toggle warnings */ |
173 |
nowarn = !nowarn; |
174 |
continue; |
175 |
176 |
if (ray_pnprocs) { |
177 |
if (!optwarn++) |
178 |
error(WARNING, |
179 |
"rendering options should appear before first sensor"); |
180 |
} else if (!strcmp(argv[i], "-defaults")) { |
181 |
print_defaults(); |
182 |
return(0); |
183 |
184 |
if (argv[i][1] == 'h') { /* header toggle */ |
185 |
doheader = !doheader; |
186 |
continue; |
187 |
188 |
if (!strcmp(argv[i], "-n")) { /* number of processes */ |
189 |
nprocs = atoi(argv[++i]); |
190 |
if (nprocs <= 0) |
191 |
error(USER, "illegal number of processes"); |
192 |
continue; |
193 |
194 |
rval = getrenderopt(argc-i, argv+i); |
195 |
if (rval < 0) { |
196 |
sprintf(errmsg, "bad render option at '%s'", argv[i]); |
197 |
198 |
199 |
i += rval; |
200 |
201 |
if (sensor == NULL) |
202 |
error(USER, i<argc ? "missing sensor file" : "missing octree"); |
203 |
quit(0); |
204 |
205 |
206 |
/* Load sensor sensitivities (first row and column are angles) */ |
207 |
static float * |
208 |
load_sensor( |
209 |
int ntp[2], |
210 |
char *sfile |
211 |
212 |
213 |
int warnedneg; |
214 |
char linebuf[8192]; |
215 |
int last_pos_val = 0; |
216 |
int nelem = 1000; |
217 |
float *sarr = (float *)malloc(sizeof(float)*nelem); |
218 |
FILE *fp; |
219 |
char *cp; |
220 |
int i; |
221 |
222 |
fp = frlibopen(sfile); |
223 |
if (fp == NULL) { |
224 |
sprintf(errmsg, "cannot open sensor file '%s'", sfile); |
225 |
226 |
227 |
fgets(linebuf, sizeof(linebuf), fp); |
228 |
if (!strncmp(linebuf, "Elevation ", 10)) |
229 |
230 |
/* get phi values */ |
231 |
sarr[0] = .0f; |
232 |
if (strncmp(linebuf, "degrees", 7)) { |
233 |
sprintf(errmsg, "Missing 'degrees' in sensor file '%s'", sfile); |
234 |
235 |
236 |
cp = sskip(linebuf); |
237 |
ntp[1] = 0; |
238 |
for ( ; ; ) { |
239 |
sarr[ntp[1]+1] = atof(cp); |
240 |
cp = fskip(cp); |
241 |
if (cp == NULL) |
242 |
break; |
243 |
if (ntp[1] > 1 && sarr[ntp[1]+1] <= sarr[ntp[1]]+FTINY) { |
244 |
sprintf(errmsg, |
245 |
"Phi values not monotinically increasing in sensor file '%s'", |
246 |
sfile); |
247 |
248 |
249 |
++ntp[1]; |
250 |
251 |
warnedneg = 0; |
252 |
ntp[0] = 0; /* get thetas + data */ |
253 |
while (fgets(linebuf, sizeof(linebuf), fp) != NULL) { |
254 |
++ntp[0]; |
255 |
if ((ntp[0]+1)*(ntp[1]+1) > nelem) { |
256 |
nelem += (nelem>>2) + ntp[1]; |
257 |
sarr = (float *)realloc((void *)sarr, |
258 |
259 |
if (sarr == NULL) |
260 |
error(SYSTEM, "out of memory in load_sensor()"); |
261 |
262 |
cp = linebuf; |
263 |
i = ntp[0]*(ntp[1]+1); |
264 |
for ( ; ; ) { |
265 |
sarr[i] = atof(cp); |
266 |
cp = fskip(cp); |
267 |
if (cp == NULL) |
268 |
break; |
269 |
if (sarr[i] < .0) { |
270 |
if (!warnedneg++) { |
271 |
sprintf(errmsg, |
272 |
"Negative value(s) in sensor file '%s' (ignored)\n", sfile); |
273 |
error(WARNING, errmsg); |
274 |
275 |
sarr[i] = .0; |
276 |
} else if (sarr[i] > FTINY && i > ntp[0]*(ntp[1]+1)) |
277 |
last_pos_val = i; |
278 |
++i; |
279 |
280 |
if (i == ntp[0]*(ntp[1]+1)) /* empty line? */ |
281 |
break; |
282 |
if (ntp[0] > 1 && sarr[ntp[0]*(ntp[1]+1)] <= |
283 |
sarr[(ntp[0]-1)*(ntp[1]+1)]) { |
284 |
sprintf(errmsg, |
285 |
"Theta values not monotinically increasing in sensor file '%s'", |
286 |
sfile); |
287 |
288 |
289 |
if (i != (ntp[0]+1)*(ntp[1]+1)) { |
290 |
sprintf(errmsg, |
291 |
"bad column count near line %d in sensor file '%s'", |
292 |
ntp[0]+1, sfile); |
293 |
294 |
295 |
296 |
/* truncate zero region */ |
297 |
ntp[0] = (last_pos_val + ntp[1])/(ntp[1]+1) - 1; |
298 |
nelem = (ntp[0]+1)*(ntp[1]+1); |
299 |
fclose(fp); |
300 |
errmsg[0] = '\0'; /* sanity checks */ |
301 |
if (!last_pos_val) |
302 |
sprintf(errmsg, "no positive sensor values in file '%s'", sfile); |
303 |
else if (fabs(sarr[ntp[1]+1]) > FTINY) |
304 |
sprintf(errmsg, "minimum theta must be 0 in sensor file '%s'", |
305 |
sfile); |
306 |
else if (fabs(sarr[1]) > FTINY) |
307 |
sprintf(errmsg, "minimum phi must be 0 in sensor file '%s'", |
308 |
sfile); |
309 |
else if (sarr[ntp[1]] < 270.-FTINY) |
310 |
sprintf(errmsg, |
311 |
"maximum phi must be 270 or greater in sensor file '%s'", |
312 |
sfile); |
313 |
else if (sarr[ntp[1]] >= 360.-FTINY) |
314 |
sprintf(errmsg, |
315 |
"maximum phi must be less than 360 in sensor file '%s'", |
316 |
sfile); |
317 |
if (errmsg[0]) |
318 |
319 |
return((float *)realloc((void *)sarr, sizeof(float)*nelem)); |
320 |
321 |
322 |
/* Initialize probability table */ |
323 |
static void |
324 |
init_ptable( |
325 |
char *sfile |
326 |
327 |
328 |
int samptot = nsamps; |
329 |
float *rowp, *rowp1; |
330 |
double rowsum[MAXNT], rowomega[MAXNT]; |
331 |
double thdiv[MAXNT+1], phdiv[MAXNP+1]; |
332 |
double tsize, psize; |
333 |
double prob, frac, frac1; |
334 |
int i, j, t, p; |
335 |
/* free old table */ |
336 |
if (sensor != NULL) |
337 |
free((void *)sensor); |
338 |
if (pvals != NULL) |
339 |
free((void *)pvals); |
340 |
if (sfile == NULL || !*sfile) { |
341 |
sensor = NULL; |
342 |
sntp[0] = sntp[1] = 0; |
343 |
pvals = NULL; |
344 |
ntheta = nphi = 0; |
345 |
return; |
346 |
347 |
/* load sensor table */ |
348 |
sensor = load_sensor(sntp, sfile); |
349 |
if (sntp[0] > MAXNT) { |
350 |
sprintf(errmsg, "Too many theta rows in sensor file '%s'", |
351 |
sfile); |
352 |
error(INTERNAL, errmsg); |
353 |
354 |
if (sntp[1] > MAXNP) { |
355 |
sprintf(errmsg, "Too many phi columns in sensor file '%s'", |
356 |
sfile); |
357 |
358 |
359 |
/* compute boundary angles */ |
360 |
maxtheta = DEGREE*(1.5f*s_theta(sntp[0]-1) - 0.5f*s_theta(sntp[0]-2)); |
361 |
if (maxtheta > PI) |
362 |
maxtheta = PI; |
363 |
thdiv[0] = .0; |
364 |
for (t = 1; t < sntp[0]; t++) |
365 |
thdiv[t] = DEGREE/2.*(s_theta(t-1) + s_theta(t)); |
366 |
thdiv[sntp[0]] = maxtheta; |
367 |
phdiv[0] = DEGREE*(1.5f*s_phi(0) - 0.5f*s_phi(1)); |
368 |
for (p = 1; p < sntp[1]; p++) |
369 |
phdiv[p] = DEGREE/2.*(s_phi(p-1) + s_phi(p)); |
370 |
phdiv[sntp[1]] = DEGREE*(1.5f*s_phi(sntp[1]-1) - 0.5f*s_phi(sntp[1]-2)); |
371 |
/* size our table */ |
372 |
tsize = 1. - cos(maxtheta); |
373 |
psize = PI*tsize/maxtheta; |
374 |
if (sntp[0]*sntp[1] < samptot) /* don't overdo resolution */ |
375 |
samptot = sntp[0]*sntp[1]; |
376 |
ntheta = (int)(sqrt((double)samptot*tsize/psize)*sntp[0]/sntp[1]) + 1; |
377 |
if (ntheta > MAXNT) |
378 |
ntheta = MAXNT; |
379 |
nphi = samptot/ntheta; |
380 |
pvals = (float *)malloc(sizeof(float)*(ntheta+1)*(nphi+1)); |
381 |
if (pvals == NULL) |
382 |
error(SYSTEM, "out of memory in init_ptable()"); |
383 |
gscale = .0; /* compute our inverse table */ |
384 |
for (i = 0; i < sntp[0]; i++) { |
385 |
rowp = &s_val(i,0); |
386 |
rowsum[i] = 1e-20; |
387 |
for (j = 0; j < sntp[1]; j++) |
388 |
rowsum[i] += *rowp++; |
389 |
rowomega[i] = cos(thdiv[i]) - cos(thdiv[i+1]); |
390 |
rowomega[i] *= 2.*PI / (double)sntp[1]; |
391 |
gscale += rowsum[i] * rowomega[i]; |
392 |
393 |
if (gscale <= FTINY) { |
394 |
sprintf(errmsg, "Sensor values sum to zero in file '%s'", sfile); |
395 |
396 |
397 |
for (i = 0; i < ntheta; i++) { |
398 |
prob = (double)i / (double)ntheta; |
399 |
for (t = 0; t < sntp[0]; t++) |
400 |
if ((prob -= rowsum[t]*rowomega[t]/gscale) <= .0) |
401 |
break; |
402 |
if (t >= sntp[0]) |
403 |
error(INTERNAL, "code error 1 in init_ptable()"); |
404 |
frac = 1. + prob/(rowsum[t]*rowomega[t]/gscale); |
405 |
tvals[i] = 1. - ( (1.-frac)*cos(thdiv[t]) + |
406 |
frac*cos(thdiv[t+1]) ); |
407 |
/* offset b/c sensor values are centered */ |
408 |
if ((t < sntp[0]-1) & (!t | (frac >= 0.5))) { |
409 |
frac -= 0.5; |
410 |
} else { |
411 |
frac += 0.5; |
412 |
--t; |
413 |
414 |
pvals[i*(nphi+1)] = phdiv[0]; |
415 |
for (j = 1; j < nphi; j++) { |
416 |
prob = (double)j / (double)nphi; |
417 |
rowp = &s_val(t,0); |
418 |
rowp1 = &s_val(t+1,0); |
419 |
for (p = 0; p < sntp[1]; p++) |
420 |
if ((prob -= (1.-frac)*rowp[p]/rowsum[t] + |
421 |
frac*rowp1[p]/rowsum[t+1]) <= .0) |
422 |
break; |
423 |
if (p >= sntp[1]) { /* should never happen? */ |
424 |
p = sntp[1] - 1; |
425 |
prob = .5; |
426 |
427 |
frac1 = 1. + prob/((1.-frac)*rowp[p]/rowsum[t] |
428 |
+ frac*rowp1[p]/rowsum[t+1]); |
429 |
pvals[i*(nphi+1) + j] = (1.-frac1)*phdiv[p] + |
430 |
frac1*phdiv[p+1]; |
431 |
432 |
pvals[i*(nphi+1) + nphi] = phdiv[sntp[1]]; |
433 |
434 |
/* duplicate final row */ |
435 |
memcpy(pvals+ntheta*(nphi+1), pvals+(ntheta-1)*(nphi+1), |
436 |
sizeof(*pvals)*(nphi+1)); |
437 |
tvals[0] = .0f; |
438 |
tvals[ntheta] = (float)tsize; |
439 |
440 |
441 |
/* Get normalized direction from random variables in [0,1) range */ |
442 |
static void |
443 |
get_direc( |
444 |
FVECT dvec, |
445 |
double x, |
446 |
double y |
447 |
448 |
449 |
double xfrac = x*ntheta; |
450 |
int tndx = (int)xfrac; |
451 |
double yfrac = y*nphi; |
452 |
int pndx = (int)yfrac; |
453 |
double rad, phi; |
454 |
FVECT dv; |
455 |
int i; |
456 |
457 |
xfrac -= (double)tndx; |
458 |
yfrac -= (double)pndx; |
459 |
pndx += tndx*(nphi+1); |
460 |
461 |
dv[2] = 1. - ((1.-xfrac)*tvals[tndx] + xfrac*tvals[tndx+1]); |
462 |
rad = sqrt(1. - dv[2]*dv[2]); |
463 |
phi = (1.-yfrac)*pvals[pndx] + yfrac*pvals[pndx+1]; |
464 |
dv[0] = -rad*sin(phi); |
465 |
dv[1] = rad*cos(phi); |
466 |
for (i = 3; i--; ) |
467 |
dvec[i] = dv[0]*ourview.hvec[i] + |
468 |
dv[1]*ourview.vvec[i] + |
469 |
dv[2]*ourview.vdir[i] ; |
470 |
471 |
472 |
/* Get sensor value in the specified direction (normalized) */ |
473 |
static float |
474 |
sens_val( |
475 |
FVECT dvec |
476 |
477 |
478 |
FVECT dv; |
479 |
float theta, phi; |
480 |
int t, p; |
481 |
482 |
dv[2] = DOT(dvec, ourview.vdir); |
483 |
theta = acos(dv[2]); |
484 |
if (theta >= maxtheta) |
485 |
return(.0f); |
486 |
dv[0] = DOT(dvec, ourview.hvec); |
487 |
dv[1] = DOT(dvec, ourview.vvec); |
488 |
phi = atan2(-dv[0], dv[1]); |
489 |
while (phi < .0f) phi += (float)(2.*PI); |
490 |
t = (int)(theta/maxtheta * sntp[0]); |
491 |
p = (int)(phi*(1./(2.*PI)) * sntp[1]); |
492 |
/* hack for non-uniform sensor grid */ |
493 |
theta *= (float)(1./DEGREE); |
494 |
phi *= (float)(1./DEGREE); |
495 |
while (t+1 < sntp[0] && theta >= s_theta(t+1)) |
496 |
++t; |
497 |
while (t-1 >= 0 && theta <= s_theta(t-1)) |
498 |
--t; |
499 |
while (p+1 < sntp[1] && phi >= s_phi(p+1)) |
500 |
++p; |
501 |
while (p-1 >= 0 && phi <= s_phi(p-1)) |
502 |
--p; |
503 |
return(s_val(t,p)); |
504 |
505 |
506 |
/* Print origin and direction */ |
507 |
static void |
508 |
print_ray( |
509 |
FVECT rorg, |
510 |
FVECT rdir |
511 |
512 |
513 |
printf("%.6g %.6g %.6g %.8f %.8f %.8f\n", |
514 |
rorg[0], rorg[1], rorg[2], |
515 |
rdir[0], rdir[1], rdir[2]); |
516 |
517 |
518 |
/* Compute sensor output */ |
519 |
static void |
520 |
comp_sensor( |
521 |
char *sfile |
522 |
523 |
524 |
int ndirs = dstrsrc > FTINY ? ndsamps : |
525 |
ndsamps > 0 ? 1 : 0; |
526 |
char *err; |
527 |
int nt, np; |
528 |
COLOR vsum; |
529 |
RAY rr; |
530 |
double sf; |
531 |
int i, j; |
532 |
/* set view */ |
533 |
ourview.type = VT_ANG; |
534 |
ourview.horiz = ourview.vert = 180.; |
535 |
ourview.hoff = ourview.voff = .0; |
536 |
err = setview(&ourview); |
537 |
if (err != NULL) |
538 |
error(USER, err); |
539 |
/* assign probability table */ |
540 |
init_ptable(sfile); |
541 |
/* stratified MC sampling */ |
542 |
setcolor(vsum, .0f, .0f, .0f); |
543 |
nt = (int)(sqrt((double)nsamps*ntheta/nphi) + .5); |
544 |
np = nsamps/nt; |
545 |
sf = gscale/nsamps; |
546 |
for (i = 0; i < nt; i++) |
547 |
for (j = 0; j < np; j++) { |
548 |
VCOPY(rr.rorg, ourview.vp); |
549 |
get_direc(rr.rdir, (i+frandom())/nt, (j+frandom())/np); |
550 |
if (ourview.vfore > FTINY) |
551 |
VSUM(rr.rorg, rr.rorg, rr.rdir, ourview.vfore); |
552 |
553 |
print_ray(rr.rorg, rr.rdir); |
554 |
continue; |
555 |
556 |
rr.rmax = .0; |
557 |
rayorigin(&rr, PRIMARY|SPECULAR, NULL, NULL); |
558 |
scalecolor(rr.rcoef, sf); |
559 |
if (ray_pqueue(&rr) == 1) |
560 |
addcolor(vsum, rr.rcol); |
561 |
562 |
/* remaining rays pure MC */ |
563 |
for (i = nsamps - nt*np; i-- > 0; ) { |
564 |
565 |
get_direc(rr.rdir, frandom(), frandom()); |
566 |
567 |
568 |
569 |
570 |
continue; |
571 |
572 |
rr.rmax = .0; |
573 |
574 |
575 |
576 |
577 |
578 |
if (!ray_pnprocs) /* just printing rays */ |
579 |
return; |
580 |
/* scale partial result */ |
581 |
scalecolor(vsum, sf); |
582 |
/* add direct component */ |
583 |
for (i = ndirs; i-- > 0; ) { |
584 |
SRCINDEX si; |
585 |
initsrcindex(&si); |
586 |
while (srcray(&rr, NULL, &si)) { |
587 |
sf = sens_val(rr.rdir); |
588 |
if (sf <= FTINY) |
589 |
continue; |
590 |
sf *= si.dom/ndirs; |
591 |
592 |
if (ray_pqueue(&rr) == 1) { |
593 |
multcolor(rr.rcol, rr.rcoef); |
594 |
595 |
596 |
597 |
598 |
/* finish our calculation */ |
599 |
while (ray_presult(&rr, 0) > 0) { |
600 |
601 |
602 |
603 |
/* print our result */ |
604 |
printf("%.4e %.4e %.4e\n", colval(vsum,RED), |
605 |
colval(vsum,GRN), colval(vsum,BLU)); |
606 |
