Added checks for extra and missing angles and documented behavior
Fix for anisotropic sensitivity array
Avoid generating rays behind sensor
Minor fixes shouldn't affect behavior
Fixed bug related to many rows (altitude) and few columns (azimuth) for sensor
Fixed bug for distributions with zero sensitivity at zenith
Added SPECULAR flag to ray samples to work better with BSDF materials
Fixed serious bug in rsensor that caused it to fail for source sampling
Bug fix related to zero rows and added check for negative sensitivities
Fixes pointed out by David G-M
Added ability to output sample rays rather than compute results
Improved sampling method very slightly
Changed default view and added handling of fore clipping distance
Fixed minor inaccuracy in phi lookup
Fixed options processing
First tested version
