| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rpiece.c,v 2.51 2010/05/17 17:03:53 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Generate sections of a picture.
| 6 |
| 7 |
| 8 |
| 9 |
#include <stdio.h>
| 10 |
#include <signal.h>
| 11 |
#include <sys/types.h>
| 12 |
| 13 |
#include "platform.h"
| 14 |
#ifndef NON_POSIX /* XXX need abstraction for process management */
| 15 |
#include <sys/wait.h>
| 16 |
#endif
| 17 |
| 18 |
#include "standard.h"
| 19 |
#include "color.h"
| 20 |
#include "view.h"
| 21 |
#include "rtprocess.h"
| 22 |
| 23 |
#ifndef F_SETLKW
| 24 |
| 25 |
int
| 26 |
main(
| 27 |
int argc,
| 28 |
char *argv[]
| 29 |
| 30 |
| 31 |
fprintf(stderr, "%s: no NFS lock manager on this machine\n", argv[0]);
| 32 |
exit(1);
| 33 |
| 34 |
| 35 |
#else
| 36 |
| 37 |
#ifndef NFS
| 38 |
#define NFS 1
| 39 |
#endif
| 40 |
/* set the following to 0 to forgo forking */
| 41 |
#ifndef MAXFORK
| 42 |
#if NFS
| 43 |
#define MAXFORK 3 /* allotment of duped processes */
| 44 |
#else
| 45 |
#define MAXFORK 0
| 46 |
#endif
| 47 |
#endif
| 48 |
/* protection from SYSV signals(!) */
| 49 |
#if defined(sgi)
| 50 |
#define guard_io() sighold(SIGALRM)
| 51 |
#define unguard() sigrelse(SIGALRM)
| 52 |
#endif
| 53 |
#ifndef guard_io
| 54 |
#define guard_io()
| 55 |
#define unguard()
| 56 |
#endif
| 57 |
| 58 |
extern char *strerror();
| 59 |
| 60 |
/* rpict command */
| 61 |
char *rpargv[128] = {"rpict", "-S", "1"};
| 62 |
int rpargc = 3;
| 63 |
FILE *torp, *fromrp;
| 64 |
COLR *pbuf;
| 65 |
/* our view parameters */
| 66 |
VIEW ourview = STDVIEW;
| 67 |
double pixaspect = 1.0;
| 68 |
int hres = 1024, vres = 1024, hmult = 4, vmult = 4;
| 69 |
/* output file */
| 70 |
char *outfile = NULL;
| 71 |
int outfd;
| 72 |
long scanorig;
| 73 |
FILE *syncfp = NULL; /* synchronization file pointer */
| 74 |
int synclst = F_UNLCK; /* synchronization file lock status */
| 75 |
int nforked = 0;
| 76 |
| 77 |
#define sflock(t) if ((t)!=synclst) dolock(fileno(syncfp),synclst=t)
| 78 |
| 79 |
char *progname;
| 80 |
int verbose = 0;
| 81 |
unsigned timelim = 0;
| 82 |
int rvrlim = -1;
| 83 |
| 84 |
int gotalrm = 0;
| 85 |
void onalrm(int i) { gotalrm++; }
| 86 |
| 87 |
static void dolock(int fd, int ltyp);
| 88 |
static void init(int ac, char **av);
| 89 |
static int nextpiece(int *xp, int *yp);
| 90 |
static int rvrpiece(int *xp, int *yp);
| 91 |
static int cleanup(int rstat);
| 92 |
static void rpiece(void);
| 93 |
static int putpiece(int xpos, int ypos);
| 94 |
static void filerr(char *t);
| 95 |
| 96 |
| 97 |
int
| 98 |
main(
| 99 |
int argc,
| 100 |
char *argv[]
| 101 |
| 102 |
| 103 |
register int i, rval;
| 104 |
| 105 |
progname = argv[0];
| 106 |
for (i = 1; i < argc; i++) {
| 107 |
/* expand arguments */
| 108 |
while ((rval = expandarg(&argc, &argv, i)) > 0)
| 109 |
| 110 |
if (rval < 0) {
| 111 |
fprintf(stderr, "%s: cannot expand '%s'\n",
| 112 |
argv[0], argv[i]);
| 113 |
exit(1);
| 114 |
| 115 |
if (argv[i][0] == '-')
| 116 |
switch (argv[i][1]) {
| 117 |
case 'v':
| 118 |
switch (argv[i][2]) {
| 119 |
case '\0': /* verbose option */
| 120 |
verbose = !verbose;
| 121 |
continue;
| 122 |
case 'f': /* view file */
| 123 |
if (viewfile(argv[++i], &ourview, NULL) <= 0) {
| 124 |
fprintf(stderr,
| 125 |
"%s: not a view file\n", argv[i]);
| 126 |
exit(1);
| 127 |
| 128 |
continue;
| 129 |
default: /* view option? */
| 130 |
rval = getviewopt(&ourview, argc-i, argv+i);
| 131 |
if (rval >= 0) {
| 132 |
i += rval;
| 133 |
continue;
| 134 |
| 135 |
break;
| 136 |
| 137 |
break;
| 138 |
case 'p': /* pixel aspect ratio? */
| 139 |
if (argv[i][2] == 'm') {
| 140 |
fprintf(stderr, "%s: -pm unsupported\n",
| 141 |
argv[0]);
| 142 |
++i;
| 143 |
continue;
| 144 |
| 145 |
if (argv[i][2] != 'a' || argv[i][3])
| 146 |
break;
| 147 |
pixaspect = atof(argv[++i]);
| 148 |
continue;
| 149 |
case 'T': /* time limit (hours) */
| 150 |
if (argv[i][2])
| 151 |
break;
| 152 |
timelim = atof(argv[++i])*3600. + .5;
| 153 |
continue;
| 154 |
case 'x': /* overall x resolution */
| 155 |
if (argv[i][2])
| 156 |
break;
| 157 |
hres = atoi(argv[++i]);
| 158 |
continue;
| 159 |
case 'y': /* overall y resolution */
| 160 |
if (argv[i][2])
| 161 |
break;
| 162 |
vres = atoi(argv[++i]);
| 163 |
continue;
| 164 |
case 'X': /* horizontal multiplier */
| 165 |
if (argv[i][2])
| 166 |
break;
| 167 |
hmult = atoi(argv[++i]);
| 168 |
continue;
| 169 |
case 'Y': /* vertical multiplier */
| 170 |
if (argv[i][2])
| 171 |
break;
| 172 |
vmult = atoi(argv[++i]);
| 173 |
continue;
| 174 |
case 'R': /* recover */
| 175 |
if (argv[i][2])
| 176 |
break;
| 177 |
rvrlim = 0;
| 178 |
/* fall through */
| 179 |
case 'F': /* syncronization file */
| 180 |
if (argv[i][2])
| 181 |
break;
| 182 |
if ((syncfp =
| 183 |
fdopen(open(argv[++i],O_RDWR|O_CREAT,0666),"r+")) == NULL) {
| 184 |
fprintf(stderr, "%s: cannot open\n",
| 185 |
argv[i]);
| 186 |
exit(1);
| 187 |
| 188 |
continue;
| 189 |
case 'z': /* z-file ist verbotten */
| 190 |
fprintf(stderr, "%s: -z option not allowed\n",
| 191 |
argv[0]);
| 192 |
exit(1);
| 193 |
case 'o': /* output file */
| 194 |
if (argv[i][2])
| 195 |
break;
| 196 |
outfile = argv[++i];
| 197 |
continue;
| 198 |
} else if (i >= argc-1)
| 199 |
break;
| 200 |
rpargv[rpargc++] = argv[i];
| 201 |
| 202 |
if (i >= argc) {
| 203 |
fprintf(stderr, "%s: missing octree argument\n", argv[0]);
| 204 |
exit(1);
| 205 |
| 206 |
if (outfile == NULL) {
| 207 |
fprintf(stderr, "%s: missing output file\n", argv[0]);
| 208 |
exit(1);
| 209 |
| 210 |
init(argc, argv);
| 211 |
rpiece();
| 212 |
exit(cleanup(0));
| 213 |
| 214 |
| 215 |
| 216 |
static void
| 217 |
dolock( /* lock or unlock a file */
| 218 |
int fd,
| 219 |
int ltyp
| 220 |
| 221 |
| 222 |
static struct flock fls; /* static so initialized to zeroes */
| 223 |
| 224 |
fls.l_type = ltyp;
| 225 |
if (fcntl(fd, F_SETLKW, &fls) < 0) {
| 226 |
fprintf(stderr, "%s: cannot lock/unlock file: %s\n",
| 227 |
progname, strerror(errno));
| 228 |
exit(1);
| 229 |
| 230 |
| 231 |
| 232 |
| 233 |
static void
| 234 |
init( /* set up output file and start rpict */
| 235 |
int ac,
| 236 |
char **av
| 237 |
| 238 |
| 239 |
static char hrbuf[16], vrbuf[16];
| 240 |
extern char VersionID[];
| 241 |
char *err;
| 242 |
FILE *fp;
| 243 |
int hr, vr;
| 244 |
SUBPROC rpd; /* since we don't close_process(), this can be local */
| 245 |
/* set up view */
| 246 |
if ((err = setview(&ourview)) != NULL) {
| 247 |
fprintf(stderr, "%s: %s\n", progname, err);
| 248 |
exit(1);
| 249 |
| 250 |
if (syncfp != NULL) {
| 251 |
sflock(F_RDLCK);
| 252 |
fscanf(syncfp, "%d %d", &hmult, &vmult);
| 253 |
sflock(F_UNLCK);
| 254 |
| 255 |
/* compute piece size */
| 256 |
hres /= hmult;
| 257 |
vres /= vmult;
| 258 |
if (hres <= 0 || vres <= 0) {
| 259 |
fprintf(stderr, "%s: illegal resolution/subdivision\n", progname);
| 260 |
exit(1);
| 261 |
| 262 |
normaspect(viewaspect(&ourview)*hmult/vmult, &pixaspect, &hres, &vres);
| 263 |
sprintf(hrbuf, "%d", hres);
| 264 |
rpargv[rpargc++] = "-x"; rpargv[rpargc++] = hrbuf;
| 265 |
sprintf(vrbuf, "%d", vres);
| 266 |
rpargv[rpargc++] = "-y"; rpargv[rpargc++] = vrbuf;
| 267 |
rpargv[rpargc++] = "-pa"; rpargv[rpargc++] = "0";
| 268 |
rpargv[rpargc++] = av[ac-1];
| 269 |
rpargv[rpargc] = NULL;
| 270 |
/* open output file */
| 271 |
if ((outfd = open(outfile, O_WRONLY|O_CREAT|O_EXCL, 0666)) >= 0) {
| 272 |
dolock(outfd, F_WRLCK);
| 273 |
if ((fp = fdopen(dup(outfd), "w")) == NULL)
| 274 |
goto filerr;
| 275 |
newheader("RADIANCE", fp); /* create header */
| 276 |
printargs(ac, av, fp);
| 277 |
fprintf(fp, "SOFTWARE= %s\n", VersionID);
| 278 |
fputs(VIEWSTR, fp);
| 279 |
fprintview(&ourview, fp);
| 280 |
putc('\n', fp);
| 281 |
fputnow(fp);
| 282 |
if (pixaspect < .99 || pixaspect > 1.01)
| 283 |
fputaspect(pixaspect, fp);
| 284 |
fputformat(COLRFMT, fp);
| 285 |
putc('\n', fp);
| 286 |
fprtresolu(hres*hmult, vres*vmult, fp);
| 287 |
} else if ((outfd = open(outfile, O_RDWR)) >= 0) {
| 288 |
dolock(outfd, F_RDLCK);
| 289 |
if ((fp = fdopen(dup(outfd), "r+")) == NULL)
| 290 |
goto filerr;
| 291 |
getheader(fp, NULL, NULL); /* skip header */
| 292 |
if (!fscnresolu(&hr, &vr, fp) || /* check resolution */
| 293 |
hr != hres*hmult || vr != vres*vmult) {
| 294 |
fprintf(stderr, "%s: resolution mismatch on file \"%s\"\n",
| 295 |
progname, outfile);
| 296 |
exit(1);
| 297 |
| 298 |
} else {
| 299 |
fprintf(stderr, "%s: cannot open file \"%s\"\n",
| 300 |
progname, outfile);
| 301 |
exit(1);
| 302 |
| 303 |
scanorig = ftell(fp); /* record position of first scanline */
| 304 |
if (fclose(fp) == -1) /* done with stream i/o */
| 305 |
goto filerr;
| 306 |
dolock(outfd, F_UNLCK);
| 307 |
/* start rpict process */
| 308 |
if (open_process(&rpd, rpargv) <= 0) {
| 309 |
fprintf(stderr, "%s: cannot start %s\n", progname, rpargv[0]);
| 310 |
exit(1);
| 311 |
| 312 |
if ((fromrp = fdopen(rpd.r, "r")) == NULL ||
| 313 |
(torp = fdopen(rpd.w, "w")) == NULL) {
| 314 |
fprintf(stderr, "%s: cannot open stream to %s\n",
| 315 |
| 316 |
exit(1);
| 317 |
| 318 |
if ((pbuf = (COLR *)bmalloc(hres*vres*sizeof(COLR))) == NULL) {
| 319 |
fprintf(stderr, "%s: out of memory\n", progname);
| 320 |
exit(1);
| 321 |
| 322 |
signal(SIGALRM, onalrm);
| 323 |
if (timelim)
| 324 |
alarm(timelim);
| 325 |
return;
| 326 |
filerr:
| 327 |
fprintf(stderr, "%s: i/o error on file \"%s\"\n", progname, outfile);
| 328 |
exit(1);
| 329 |
| 330 |
| 331 |
| 332 |
static int
| 333 |
nextpiece( /* get next piece assignment */
| 334 |
int *xp,
| 335 |
int *yp
| 336 |
| 337 |
| 338 |
if (gotalrm) /* someone wants us to quit */
| 339 |
return(0);
| 340 |
if (syncfp != NULL) { /* use sync file */
| 341 |
| 342 |
* So we don't necessarily have to lock and unlock the file
| 343 |
* multiple times (very slow), we establish an exclusive
| 344 |
* lock at the beginning on our synchronization file and
| 345 |
* maintain it in the subroutine rvrpiece().
| 346 |
| 347 |
sflock(F_WRLCK);
| 348 |
fseek(syncfp, 0L, 0); /* read position */
| 349 |
if (fscanf(syncfp, "%*d %*d %d %d", xp, yp) < 2) {
| 350 |
*xp = hmult-1;
| 351 |
*yp = vmult;
| 352 |
| 353 |
if (rvrlim == 0) /* initialize recovery limit */
| 354 |
rvrlim = *xp*vmult + *yp;
| 355 |
if (rvrpiece(xp, yp)) { /* do stragglers first */
| 356 |
sflock(F_UNLCK);
| 357 |
return(1);
| 358 |
| 359 |
if (--(*yp) < 0) { /* decrement position */
| 360 |
*yp = vmult-1;
| 361 |
if (--(*xp) < 0) { /* all done */
| 362 |
sflock(F_UNLCK);
| 363 |
return(0);
| 364 |
| 365 |
| 366 |
fseek(syncfp, 0L, 0); /* write new position */
| 367 |
fprintf(syncfp, "%4d %4d\n%4d %4d\n\n", hmult, vmult, *xp, *yp);
| 368 |
fflush(syncfp);
| 369 |
sflock(F_UNLCK); /* release sync file */
| 370 |
return(1);
| 371 |
| 372 |
return(scanf("%d %d", xp, yp) == 2); /* use stdin */
| 373 |
| 374 |
| 375 |
| 376 |
static int
| 377 |
rvrpiece( /* check for recoverable pieces */
| 378 |
register int *xp,
| 379 |
register int *yp
| 380 |
| 381 |
| 382 |
static char *pdone = NULL; /* which pieces are done */
| 383 |
static long readpos = -1; /* how far we've read */
| 384 |
register int i;
| 385 |
| 386 |
* This routine is called by nextpiece() with an
| 387 |
* exclusive lock on syncfp and the file pointer at the
| 388 |
* appropriate position to read in the finished pieces.
| 389 |
| 390 |
if (rvrlim < 0)
| 391 |
return(0); /* only check if asked */
| 392 |
if (pdone == NULL) /* first call */
| 393 |
pdone = calloc(hmult*vmult, sizeof(char));
| 394 |
if (pdone == NULL) {
| 395 |
| 396 |
exit(1);
| 397 |
| 398 |
if (readpos != -1) /* mark what's been done */
| 399 |
fseek(syncfp, readpos, 0);
| 400 |
while (fscanf(syncfp, "%d %d", xp, yp) == 2)
| 401 |
pdone[*xp*vmult+*yp] = 1;
| 402 |
if (!feof(syncfp)) {
| 403 |
fprintf(stderr, "%s: format error in sync file\n", progname);
| 404 |
exit(1);
| 405 |
| 406 |
readpos = ftell(syncfp);
| 407 |
i = hmult*vmult; /* find an unaccounted for piece */
| 408 |
while (i-- > rvrlim)
| 409 |
if (!pdone[i]) {
| 410 |
*xp = i / vmult;
| 411 |
*yp = i % vmult;
| 412 |
pdone[i] = 1; /* consider it done */
| 413 |
return(1);
| 414 |
| 415 |
rvrlim = -1; /* nothing left to recover */
| 416 |
free(pdone);
| 417 |
pdone = NULL;
| 418 |
return(0);
| 419 |
| 420 |
| 421 |
| 422 |
static int
| 423 |
cleanup( /* close rpict process and clean up */
| 424 |
int rstat
| 425 |
| 426 |
| 427 |
int status;
| 428 |
| 429 |
bfree((char *)pbuf, hres*vres*sizeof(COLR));
| 430 |
fclose(torp);
| 431 |
fclose(fromrp);
| 432 |
while (wait(&status) != -1)
| 433 |
if (rstat == 0)
| 434 |
rstat = status>>8 & 0xff;
| 435 |
return(rstat);
| 436 |
| 437 |
| 438 |
| 439 |
static void
| 440 |
rpiece(void) /* render picture piece by piece */
| 441 |
| 442 |
VIEW pview;
| 443 |
int xorg, yorg;
| 444 |
/* compute view parameters */
| 445 |
pview = ourview;
| 446 |
switch (ourview.type) {
| 447 |
case VT_PER:
| 448 |
pview.horiz = (2.*180./PI)*atan(
| 449 |
tan((PI/180./2.)*ourview.horiz)/hmult );
| 450 |
pview.vert = (2.*180./PI)*atan(
| 451 |
tan((PI/180./2.)*ourview.vert)/vmult );
| 452 |
break;
| 453 |
case VT_PAR:
| 454 |
case VT_ANG:
| 455 |
pview.horiz = ourview.horiz / hmult;
| 456 |
pview.vert = ourview.vert / vmult;
| 457 |
break;
| 458 |
case VT_CYL:
| 459 |
| 460 |
| 461 |
| 462 |
break;
| 463 |
case VT_HEM:
| 464 |
pview.horiz = (2.*180./PI)*asin(
| 465 |
sin((PI/180./2.)*ourview.horiz)/hmult );
| 466 |
pview.vert = (2.*180./PI)*asin(
| 467 |
sin((PI/180./2.)*ourview.vert)/vmult );
| 468 |
break;
| 469 |
case VT_PLS:
| 470 |
pview.horiz = sin((PI/180./2.)*ourview.horiz) /
| 471 |
(1.0 + cos((PI/180./2.)*ourview.horiz)) / hmult;
| 472 |
pview.horiz *= pview.horiz;
| 473 |
pview.horiz = (2.*180./PI)*acos((1. - pview.horiz) /
| 474 |
(1. + pview.horiz));
| 475 |
pview.vert = sin((PI/180./2.)*ourview.vert) /
| 476 |
(1.0 + cos((PI/180./2.)*ourview.vert)) / vmult;
| 477 |
pview.vert *= pview.vert;
| 478 |
pview.vert = (2.*180./PI)*acos((1. - pview.vert) /
| 479 |
(1. + pview.vert));
| 480 |
break;
| 481 |
default:
| 482 |
fprintf(stderr, "%s: unknown view type '-vt%c'\n",
| 483 |
progname, ourview.type);
| 484 |
exit(cleanup(1));
| 485 |
| 486 |
/* render each piece */
| 487 |
while (nextpiece(&xorg, &yorg)) {
| 488 |
pview.hoff = ourview.hoff*hmult + xorg - 0.5*(hmult-1);
| 489 |
pview.voff = ourview.voff*vmult + yorg - 0.5*(vmult-1);
| 490 |
fputs(VIEWSTR, torp);
| 491 |
fprintview(&pview, torp);
| 492 |
putc('\n', torp);
| 493 |
fflush(torp); /* assigns piece to rpict */
| 494 |
putpiece(xorg, yorg); /* place piece in output */
| 495 |
| 496 |
| 497 |
| 498 |
| 499 |
static int
| 500 |
putpiece( /* get next piece from rpict */
| 501 |
int xpos,
| 502 |
int ypos
| 503 |
| 504 |
| 505 |
struct flock fls;
| 506 |
int pid, status;
| 507 |
int hr, vr;
| 508 |
register int y;
| 509 |
/* check bounds */
| 510 |
if ((xpos < 0) | (ypos < 0) | (xpos >= hmult) | (ypos >= vmult)) {
| 511 |
fprintf(stderr, "%s: requested piece (%d,%d) out of range\n",
| 512 |
progname, xpos, ypos);
| 513 |
exit(cleanup(1));
| 514 |
| 515 |
/* check header from rpict */
| 516 |
guard_io();
| 517 |
getheader(fromrp, NULL, NULL);
| 518 |
if (!fscnresolu(&hr, &vr, fromrp) || (hr != hres) | (vr != vres)) {
| 519 |
fprintf(stderr, "%s: resolution mismatch from %s\n",
| 520 |
| 521 |
exit(cleanup(1));
| 522 |
| 523 |
if (verbose) { /* notify caller */
| 524 |
printf("%d %d begun\n", xpos, ypos);
| 525 |
fflush(stdout);
| 526 |
| 527 |
unguard();
| 528 |
/* load new piece into buffer */
| 529 |
for (y = 0; y < vr; y++) {
| 530 |
guard_io();
| 531 |
if (freadcolrs(pbuf+y*hr, hr, fromrp) < 0) {
| 532 |
fprintf(stderr, "%s: read error from %s\n",
| 533 |
| 534 |
exit(cleanup(1));
| 535 |
| 536 |
unguard();
| 537 |
| 538 |
#if MAXFORK
| 539 |
/* fork so we don't slow rpict down */
| 540 |
if ((pid = fork()) > 0) {
| 541 |
if (++nforked >= MAXFORK) {
| 542 |
wait(&status); /* reap a child */
| 543 |
if (status)
| 544 |
exit(cleanup(status>>8 & 0xff));
| 545 |
nforked--;
| 546 |
| 547 |
return(pid);
| 548 |
| 549 |
#else
| 550 |
pid = -1; /* no forking */
| 551 |
#endif
| 552 |
fls.l_start = scanorig +
| 553 |
((long)(vmult-1-ypos)*vres*hmult+xpos)*hres*sizeof(COLR);
| 554 |
#if NFS
| 555 |
fls.l_len = ((long)(vres-1)*hmult+1)*hres*sizeof(COLR);
| 556 |
/* lock file section so NFS doesn't mess up */
| 557 |
fls.l_whence = 0;
| 558 |
fls.l_type = F_WRLCK;
| 559 |
if (fcntl(outfd, F_SETLKW, &fls) < 0)
| 560 |
filerr("lock");
| 561 |
#endif
| 562 |
/* write new piece to file */
| 563 |
if (lseek(outfd, (off_t)fls.l_start, SEEK_SET) < 0)
| 564 |
filerr("seek");
| 565 |
if (hmult == 1) {
| 566 |
if (writebuf(outfd, (char *)pbuf,
| 567 |
vr*hr*sizeof(COLR)) != vr*hr*sizeof(COLR))
| 568 |
filerr("write");
| 569 |
} else
| 570 |
| 571 |
if (writebuf(outfd, (char *)(pbuf+y*hr),
| 572 |
hr*sizeof(COLR)) != hr*sizeof(COLR))
| 573 |
filerr("write");
| 574 |
if (y < vr-1 && lseek(outfd,
| 575 |
(off_t)(hmult-1)*hr*sizeof(COLR),
| 576 |
SEEK_CUR) < 0)
| 577 |
filerr("seek");
| 578 |
| 579 |
#if NFS
| 580 |
fls.l_type = F_UNLCK; /* release lock */
| 581 |
| 582 |
filerr("lock");
| 583 |
#endif
| 584 |
| 585 |
printf("%d %d done\n", xpos, ypos);
| 586 |
fflush(stdout);
| 587 |
| 588 |
if (syncfp != NULL) { /* record what's been done */
| 589 |
sflock(F_WRLCK);
| 590 |
fseek(syncfp, 0L, 2); /* append index */
| 591 |
fprintf(syncfp, "%4d %4d\n", xpos, ypos);
| 592 |
fflush(syncfp);
| 593 |
/*** Unlock not necessary, since
| 594 |
sflock(F_UNLCK); _exit() or nextpiece() is next ***/
| 595 |
| 596 |
if (pid == -1) /* didn't fork or fork failed */
| 597 |
return(0);
| 598 |
_exit(0); /* else exit child process (releasing locks) */
| 599 |
| 600 |
| 601 |
| 602 |
static void
| 603 |
filerr( /* report file error and exit */
| 604 |
char *t
| 605 |
| 606 |
| 607 |
fprintf(stderr, "%s: %s error on file \"%s\": %s\n",
| 608 |
progname, t, outfile, strerror(errno));
| 609 |
_exit(1);
| 610 |
| 611 |
| 612 |
#endif
